Lining change gone from Basic setting??
Mknsweden
Sweden
C?ID=352414
Hello!
I set out to do a quick brake change on my 2014 Audi A4 TDI this morning. Fired up VCDS to open the handbrake. I havn't used VCDS for a while and it was out of date and I updated it. When I opened the ABS module and went to basic setting that page was completely different from last time i did this. (car has been running with me since new and it is at 410 000km now. So i have done this a couple of times)
But the normal drop down menu is gone. Now it is just groups and and a few fields. There is a drop down window but only with three options. None of them are lining change modes.
Wednesday,30,October,2024,10:39:00:14283
VIN: WAUZZZ8K2FA050938   License Plate:
                Address 01: Engine       Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 021 BM    HW: 04L 907 309
  Component and/or Version: R4 2,0L EDC   H23 8508
           Software Coding: 12254012243601080000
            Work Shop Code: WSC 29268 001 1048576
              ASAM Dataset: EV_ECM20TDI01104L906021BM 002008 (AU48)
                       ROD: EV_ECM20TDI01104L906021BG_002.rod
                      VCID: 71BFD481112A6632A05-8024
9 Faults Found:
7140 - Function Restriction due to Faults in Other Modules
          U1113 00 [00100000] - -
5158 - Particulate Filter; Differential Pressure Sensor
          P2456 00 [01101000] - Intermittent
                    Fault Frequency: 220
                    Mileage: 367283 km
                    Date: 2023.09.08
                    Time: 15:45:54
                    Engine RPM: 1975.50 /min
                    Normed load value: 87.1 %
                    Vehicle speed: 26 km/h
                    Coolant temperature: 90  C
                    Intake air temperature: 76  C
                    Voltage terminal 30: 14.460 V
                    Unlearning counter according OBD: 27
                    Particle filter: air pressure sensor 1 bank 1: raw value: 299 hPa
                    Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 381 hPa
                    Par.fil: diff.pr.sens.1 bank 1: offset: -80 hPa
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -84 hPa
                    Outside temperature sensor 1: B1: raw value: 23.5  C
                    Particle filter: soot mass measured: 21.75 g
                    Particle filter: soot mass calculated: 6.81 g
5253 - Particulate Filter; Differential Pressure Sensor
          P2452 00 [10101100] - Elect. Malfunction
                    Mileage: 367147 km
                    Date: 2023.09.07
                    Time: 15:03:37
                    Engine RPM: 0.00 /min
                    Coolant temperature: 88  C
                    Intake air temperature: 61  C
                    Voltage terminal 30: 12.360 V
                    Particle filter: air pressure sensor 1 bank 1: raw value: 1057 hPa
                    Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 1200 hPa
                    Par.fil: diff.pr.sens.1 bank 1: offset: -143 hPa
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -150 hPa
                    Outside temperature sensor 1: B1: raw value: 24.5  C
                    Particle filter: soot mass measured: 21.76 g
                    Particle filter: soot mass calculated: 20.63 g
5262 - Particulate Filter; Differential Pressure Sensor
          P2454 00 [00101110] - Short to GND
                    Mileage: 367147 km
                    Date: 2023.09.07
                    Time: 14:57:39
                    Coolant temperature: 18  C
                    Intake air temperature: 19  C
                    Voltage terminal 30: 12.380 V
                    Particle filter: air pressure sensor 1 bank 1: raw value: -214 hPa
                    Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: -278 hPa
                    Par.fil: diff.pr.sens.1 bank 1: offset: 64 hPa
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -149 hPa
                    Outside temperature sensor 1: B1: raw value: 21.0  C
                    Particle filter: soot mass measured: 21.48 g
                    Particle filter: soot mass calculated: 16.14 g
4984 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [11101101] - Electrical Fault
                    Mileage: 367232 km
                    Date: 2023.09.08
                    Time: 10:58:13
                    Engine RPM: 846.00 /min
                    Normed load value: 34.5 %
                    Coolant temperature: 17  C
                    Intake air temperature: 18  C
                    Voltage terminal 30: 11.860 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 20
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Pre-glow time: 1000 ms
                    Glow status-Bits 0-7: 0
                    Glow status-Bits 0-7: 176
                    Glow cycles above temperature threshold-Bits 0-7: 9
                    Glow cycles above temperature threshold-Bits 0-7: 152
                    Glow cycles below temperature threshold-Bits 0-7: 5
                    Glow cycles below temperature threshold-Bits 0-7: 38
                    Outside temperature sensor 1: B1: raw value: 16.0  C
4985 - Cylinder 2 Glow Plug Circuit (Q11)
          P0672 00 [11101101] - Electrical Fault
                    Mileage: 395858 km
                    Date: 2024.04.29
                    Time: 06:03:27
                    Engine RPM: 841.50 /min
                    Normed load value: 36.9 %
                    Coolant temperature: 14  C
                    Intake air temperature: 15  C
                    Voltage terminal 30: 12.040 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Pre-glow time: 1700 ms
                    Glow cycles above temperature threshold-Bits 0-7: 10
                    Glow cycles above temperature threshold-Bits 0-7: 74
                    Glow cycles below temperature threshold-Bits 0-7: 121
                    Outside temperature sensor 1: B1: raw value: 14.5  C
4986 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [11101101] - Electrical Fault
                    Mileage: 379647 km
                    Date: 2023.11.28
                    Time: 11:51:48
                    Engine RPM: 128.50 /min
                    Coolant temperature: -9  C
                    Intake air temperature: -8  C
                    Voltage terminal 30: 9.540 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 28
                    Pre-glow time: 2500 ms
                    Glow status-Bits 0-7: 112
                    Glow cycles above temperature threshold-Bits 0-7: 223
                    Glow cycles below temperature threshold-Bits 0-7: 76
                    Outside temperature sensor 1: B1: raw value: -6.0  C
4987 - Cylinder 4 Glow Plug Circuit (Q13)
          P0674 00 [11101101] - Electrical Fault
                    Mileage: 377117 km
                    Date: 2023.11.06
                    Time: 07:33:14
                    Engine RPM: 940.50 /min
                    Normed load value: 52.9 %
                    Vehicle speed: 20 km/h
                    Coolant temperature: 21  C
                    Intake air temperature: 16  C
                    Voltage terminal 30: 14.100 V
                    Electric auxiliary heater: relay activation-Bits 0-7: 2
                    Glow cycles above temperature threshold-Bits 0-7: 212
                    Glow cycles below temperature threshold-Bits 0-7: 58
                    Outside temperature sensor 1: B1: raw value: 8.0  C
4113 - Camshaft Position Sensor (G40)
          P0341 00 [01100000] - Implausible Signal
Readiness: 1 7 0 0 0
Dr Sheldon
Windsor UK
C?ID=334979
Go into ABS or Park Brake module and look for it there - it will be there somewhere
a search on youtube will for sure
2014 Audi A4 [...] When I opened the ABS module and went to basic setting that page was completely different from last time i did this.
I suspect a 2014 A4 still has a dedicated EPB controller at address 53, which is not yet integrated into the ABS at address 03 like it is on newer cars.
