Airbag module replacement/retrofit
Mike T
Valrico, FL, USA
C?ID=601016
Is there a substitute module for the Airbag 8N0 959 655 D? I'm having trouble locating one and mine has crash data stored and memory error 65535. There are some available on fleabay, but last letter is different. Will my 06 TT MK1 1.8L accept it?
Derek
UK (ilexa)
C?ID=56983
Hello Mike
Please post an autoscan from the car so we can see the model and full module details
Best regards
Derek
Mike T
Valrico, FL, USA
C?ID=601016
I can't right now. Removed the gauge pod to get repaired and don't want to reconnect the battery without it.
I can email you a copy of the printout I have.
Derek
UK (ilexa)
C?ID=56983
If you've previously scanned the car VCDS made a backup copy of the scan in "C:\Ross-Tech\VCDS\Scans"
Best regards
Derek
Derek
UK (ilexa)
C?ID=56983
Please post the autoscan text into the page as shown in the guide
Mike T
Valrico, FL, USA
C?ID=601016
Wednesday,30,October,2024,06:25:47:60431
VIN: TRUSC28N961009784   License Plate:
Mileage:    Repair Order: 3
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine        Labels: 06A-906-032-AWP.lbl
   Part No: 8N0 906 018 CM
   Component: 1.8L R4/5VT     G   0010
   Coding: 07570
   Shop #: WSC 01236
   VCID: 7EA2262B29E9B50A2D7-5160
   VINID: 9229634C221E2460400091C8101C5C8B80
   TRUSC28N961009784     AUZ5Z0F2305008
Readiness: 0110 1101
   Part No: 09G 927 750 AQ
   Component: AQ 250 6F           0623
   Coding: 0008201
   Shop #: WSC 01236 785 00200
   VCID: 005E58D3561DC3FA5FB-5160
Address 03: ABS Brakes        Labels: 8N0-907-379-MK60-F.lbl
   Part No: 8N0 907 379 J
   Coding: 0019473
   VCID: 43D497DF078B18E2029-5160
00493 - ESP-Sensor Unit (G419)
            014 - Defective
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 280E20739BEDDBBA37B-258E
Address 15: Airbags        Labels: 8N0-959-655.lbl
   Part No: 8N0 959 655 D
   Component: Airbag Front+Seite 1000
   Coding: 01103
   Shop #: WSC 01236
   VCID: 41D89DD718970AF2105-5196
            00-00 - -
01217 - Side Airbag Igniter; Driver Side (N199)
            32-10 - Resistance Too High - Intermittent
00591 - Seat Belt Switch; Driver (E24)
00595 - Crash Data Stored
            35-10 - - - Intermittent
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 980 E
   Component: KOMBI+WEGFAHRS. M73 D09
   Coding: 20244
   Shop #: WSC 05777
   VCID: 382EF0334B4D4B3AA7B-4B1E
Address 35: Centr. Locks        Labels:. 8Nx-962-267.clb
   Part No: 8N8 962 267 F
   Component: Central Lock/Alarm  D09
   Coding: 15884
   Shop #: WSC 01236
   VCID: 44D694C307851FDA3B3-4EEA
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00009
   Shop #: WSC 01236
   VCID: 65906947AC7F06D2CCD-518C
Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
   Part No: 4B0 035 186 L
   Component: concert II  PM6    0460
   Coding: 00302
   Shop #: WSC 68096
   VCID: 2908257780E7E2B2285-50B4
End----------(Elapsed Time: 02:57, VBatt start/end: 12.3V/12.4V)-----------
Mike T
Valrico, FL, USA
C?ID=601016
So any thoughts/ideas?
Westbury, UK
Not only does the part number have to be the same (including the suffix letter) but also there will be printed on the module itself a so-called "color code" (which the module does not report via diagnostics so you have to inspect it visually) and this MUST match as well.
So is there a substitute? No is what I would say.
Probably not on this one. Airbag modules in Mk1 TT cars did didn't use "Index Coding".
As for exactly what will work, I suggest consulting with a dealer or proper parts catalog to see if there have been any superseding part numbers and suggest you stay within those bounds.
Mike T
Valrico, FL, USA
C?ID=601016
Seeing if they'll ship to USA.....
Westbury, UK
As @Uwe says please check with a dealer or someone with a proper parts catalog what part number supersede 8N0 959 655 D.
Mike T
Valrico, FL, USA
C?ID=601016
Dealer by me was useless.
From Audiusa.com support:
Thank you for taking the time to chat with me today. I wanted to reach out to you and follow up with regarding your inquiry about the part that replaced air bag module 8N0 959 655 D.
I will reach out to my product support team to see if I am able to locate that information for you. Once I hear back, I will follow up with you again. Please allow 2 business days for a response.
