Vw Up 2012 MFSW retrofit
abraco
Croatia
C?ID=505552
can someone point in me right direction which BCM should I install so that MFSW works as original one (1S0937087) doesn't support it.
Customer wants to buy BCM 1S0937090J but I'm not sure if it's suitable.
Regards
Friday,11,October,2024,12:58:20:38387
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WVWZZZAAZCD055655   License Plate:
Chassis Type: AA-VW12 (6N0)
Scan: 01 03 09 10 13 15 17 19 25 44 56 AD
VIN: WVWZZZAAZCD055655   Mileage: 31500km-19573miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 020 A    HW: 04C 907 309
   Component: 1.0l R3 MPI   H01 6463
   Revision: U7H01---    Serial number: 00000000000000 CVN: 28B5B5DD
   Coding: 00110012022400000000
   Shop #: WSC 50562 000 1048576
   ASAM Dataset: EV_ECM10MPI01104C906020A 001014
   ROD: EV_ECM10MPI01104C906020_VW12.rod
   VCID: 1964A3937910EDF2B85-804C
   VINID: 9E69EAAAA451A93500145185148E8E3F4A
Readiness: 0010 0101
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 E    HW: 1S0 614 517 E
   Component: EBC 460 ESP   H08 0012
   Serial number: A00LHOC
   Coding: 12BF247189B202F6480024FA91AE404058B100
   Shop #: WSC 58438 006 1048576
   ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
   ROD: EV_Brake1ESPMP1TRWVW120.rod
   VCID: 31347B3301A005B2E05-8064
Address 09: Cent. Elect. (J519)       Labels:. 1S0-937-09x-V1.clb
   Part No SW: 1S0 937 087     HW: 1S0 937 087
   Component: PQ25 BCM      H57 0512
   Revision: -9------    Serial number: 1009069000
   Coding: 3CB8290000010000000000042C28ACD000C0400C60020000200000420100
   Shop #: WSC 00931 202 08200
   VCID: 76BE882FA8CE628A757-8022
Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
   Part No SW: 1S0 919 475     HW: 1Q0 919 475
   Component: PARKHILFE 3K  H03 0006
   Revision: --------    Serial number: 32961210200345
   Coding: 100001
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_EPHVA14VW1200000 001004
   ROD: EV_EPHVA14VW1200000.rod
   VCID: 77A0852BAF441B826E1-8022
   Part No SW: 1S0 959 655     HW: 1S0 959 655
   Component: VW10Airbag009 H02 0005
   Revision: --------    Serial number: 003G3001WMZQ Dataset Number: 120003v____ 0044
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 7BA8991B936C3FE20A9-802E
   Serial number: 3575HRB405D18NQS2GG2
   Serial number: 3585HRB405F18NQS8GLG
   Serial number: 3555NRB4067197FG8OEI
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1S0 920 870 K    HW: 1S0 920 870 K
   Component: KOMBI         H40 0402
   Revision: X0040001    Serial number: 00000000000000
   Coding: 114A010000
   Shop #: WSC 31414 183 00001
   ASAM Dataset: EV_KombiUDSMM9RM10 A05811
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 39244313D9D0CDF2585-806C
   Part No SW: 6N0 909 901     HW: 1S0 937 087
   Component: GW-K-CAN TP20 H57 0512
   Revision: -9------
   Coding: 001000
   Shop #: WSC 12594 026 411366
   VCID: 70B2BE37CAAA4CBAAFB-8024
   Part No SW: 5K0 953 234     HW: 1S0 920 870 K
   Component: IMMO          H40 0402
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   VCID: 6A86AC5FECF6B66AE1F-803E
Address 44: Steering Assist (J792)       Labels:| 1Sx-909-144-44.clb
   Part No SW: 1S1 909 144 G    HW: 1S1 909 144 G
   Component: EPS_ECU       H30 1503
   Dataset Number: 1S0074v____ 1209
   Coding: 0001000101000000
   ASAM Dataset: EV_SteerAssisNSK 009004
   ROD: EV_SteerAssisNSK_009.rod
   VCID: 3720452BEFC4DB82AE1-8062
   Part No SW: 1S0 035 156 A    HW: 1S0 035 156 A
   Component: Radio         567 5536
   Revision: AA001001    Serial number: VWZ8Z1M2001646
   Coding: 0000040802
   VCID: 2904935329F07D72285-807C
Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
   Part No SW: 1S0 907 201     HW: 1S0 907 201
   Component: CV-SENSOR     H06 0450
   ASAM Dataset: EV_CVSen 001001
   ROD: EV_CVSen.rod
   VCID: 6780D56BFFE48B02FE1-8032
End----------(Elapsed Time: 00:53, VBatt start/end: 12.6V/12.5V)-----------
siLc
Tallinn, Estonia
C?ID=330192
This original BCM is superceded to 1S0937090D. 090J is a much newer BCM from a 2019+ Up.
abraco
Croatia
C?ID=505552
So you think 090D supports mfsw?
siLc
Tallinn, Estonia
C?ID=330192
MFSW support isn't explicitly stated in the parts catalogue. But following the example of BCM numbering of PQ25 platform stablemate Transporter T5.1, 090 probably supports it. If you want to be certain, look for autoscan examples of Up-s with MFSW.
abraco
Croatia
C?ID=505552
Ok. Thank you very much
