2017 Golf Station, facelift. Change oil change intervals, but not service/inspection
DangerDane
Denmark
C?ID=586577
I have a 2017 facelift Golf Variant. I would like to change my oil change intervals from 30.000 km to 15.000 but would like to keep the inspection/service intervals as is. I have tried searching on here as well as having a look with OBD11 but without it shedding any real light on how to do it properly, at least to me. Because looking at OBD11 it at least to me only seemed like it it would change the service/inspecction interval, which is not what I wanted.
My main reason for changing is that I like to change my oil at 15K instead of 30K, as well as the fact that the least time I had the car serviced, the dealership completely negated the oil change that I asked for, since the car didn't prompt for it. So I had to wait for 1 extra hour because they only relied on what the car reported as opposed to what I requested. And thus by changed the oil change interval I at least can avoid that confusion another time :)
Let's get some base-line data. Go to [SRI Reset], wait a few moment for VCDS to read the SRI-related channels, then click [Add to logfile] and post the resulting log here.
DangerDane
Denmark
C?ID=586577
Sunday,03,November,2024,20:25:52:49562
VCDS Version: 24.7.1.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WVWZZZAUZHP787440   License Plate: EB60406
Mileage: 135025km-83900mi   Repair Order:
VCDS Release 24.7.1:  SRI Reset-SRI3.CLB
Control Module Part Number: 5G1 920 740 B       Labels:  .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI         204 8311, Coding:07A521002780000801883A011400000000000000
Channel        Description                                                     Current val.                                                    New val.
IDE00342-ESI: Resetting ESI        ESI: Service Status                                             no warning                                                      ---
IDE00510-ESI: distance driven from inspection                                                           ESI: Distance SINCE last Oil Service                            1573 km                                                         ---
IDE00511-ESI: time from inspection        ESI: Time SINCE last Oil Service                                16 d                                                            ---
IDE00512-ESI: minimum value km-driving distance/inspection                                              ESI: Minimum Distance to Oil Service(s)                         15000 km                                                        ---
IDE00513-ESI: maximum value km-driving distance/inspection                                              ESI: Maximum Distance to Oil Service(s)                         30000 km                                                        ---
IDE00827-ESI: minimum value of time between inspections                                                 ESI: Minimum Time to Oil Service(s)                             365 d                                                           ---
IDE00514-ESI: maximum value of time between inspections                                                 ESI: Maximum Time to Oil Service(s)                             730 d                                                           ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance SINCE last mileage-dependent Inspection           1500 km                                                         ---
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time SINCE last time-dependent Inspection                  16 d                                                            ---
IDE03349-FIX:Max. distance driven until next mileage-related inspection                                 FIX: Max. Distance to mileage-dependent Inspection(s)           30000 km                                                        ---
IDE03350-FIX: Maximum time until next time-dependent inspection                                         FIX: Max. Time to time-dependent Inspection(s)                  365 d                                                           ---
IDE01153-SIA: maximum value of distance to service                                                      SIA/SID: Maximum Distance to Service/Inspection                 15000 km                                                        ---
IDE01154-SIA: maximum value of time to service                                                          SIA/SID: Maximum Time to Service/Inspection                     365 d                                                           ---
        ESI/INFO: Theoretical Oil Service Interval        ---
        ESI/INFO: Remaining Distance to Oil Service        ---
        ESI/INFO: Remaining Time to Oil Service        ---
        ESI/INFO: Oil Service Exceedance        ---
        INFO: Day Counter (since Delivery Inspection)        ---
        INFO: Vehicle/Odomoter Mileage                                  ---                                                             ---
IDE00517-ESI: soot entry        ESI/INFO: Soot Entry                                            0 km                                                            ---
IDE00518-ESI: thermal load        ESI/INFO: Thermal Load                                          1900 km                                                         ---
IDE00515-ESI: oil quality        ESI/INFO: Oil Quality                                           good oil quality                                                ---
        ESI/CODING: Oil Level Evaluation                                ---                                                             ---
        ESI/CODING: ESI-SIA/SID ON/OFF                                  ---                                                             ---
        ESI/CODING: ESI or SIA/SID                                      ---                                                             ---
        ESI/CODING: Oil Pressure Warning                                ---                                                             ---
        ESI/CODING: Remote Clock Receiver                               ---                                                             ---
        ESI/CODING: Oil Quality                                         ---                                                             ---
        ESI/CODING: Oil Level & Thermal Sensor                          ---                                                             ---
There are several ways to skin a cat.
* You could try changing IDE00515-ESI: oil quality from Good to Poor. I believe that will get you onto fixed intervals of 15,000 km.
* You could try changing IDE00513-ESI: Maximum Distance to Oil Service(s) to 15,000 km, but it's possible that will produce a "Basic Settings" DTC in the cluster.
