Lost key
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I’m unsure but it did start and run before I lost the key. There’s no blown fuses. I checked all of them and I Changed the starter. You can here the relay click but that’s it
Sorry for taking so long for reply. I just got home. I saved the scan but now nothing is coming up just a bunch of lines. I will rescan tomorrow and send. The lock smith said he will be out tomorrow to reprogram my original file back on the ecu. Says he got the pin and sku too. So we will see. I will send a scan tomorrow when I get back to the car
He will not be able to do anything with Pin, and I can assure you this guy do not know anything abut this car . The key has to be pre coded with Immo data then program with correct tool.
BTW , I do have this ECU in hand if you find out ECU is mess up.
Also this DTC , Short to plus means it is missing Ground. Check and make sure al ground are OK and engine has ground.
012370 - Starter Control; Returned Message
P3052 - 000 - 50 Short to Plus - MIL ON
   #23
Ziddywerks
Northern NJ USA
C?ID=208579
I would have to Agree with @Jetta 97. In this case aftermarket key needs to have CS written into it before it can be coded to the car. It cannot be done Via pin and whatever sku he came up with. Find someone who knows these cars and systems.
