Lost key
Scottarossjr
Philadephia, PA, USA
C?ID=571411
I lost the key to my 2008 Audi a3. Had a locksmith come out to make new key. He couldn’t pull the pin so he took the ecu back to his shop to and turned off the immobilizer. I put the ecu back in the car and now got code p3054 jammed or electrical malfunction and the car won’t crank. I also still have the safe light on dash but he is saying that is normal. Can anyone give me any advice on this? Thank you in advance for any help.
Jef
HQ
When asking for assistance, you need to post a complete Auto-Scan. Unsure what you mean by a "safe light"... can you post a photo?
And I would call that guy back and have him undo whatever tweaking he did to the ECM.
Ziddywerks
Northern NJ USA
C?ID=208579
Safe light meaning the odometer lcd is showing " SAFE" because the key is not added to the dash or ecu. Immo off is the worst solution because with immo off you cannot adapt keys to existing immobilizer system. As much as I hate to say it you need to find a competent locksmith. Also if you have the chance please check if the windows in the vehicle still work. Report back.
Ziddywerks
Northern NJ USA
C?ID=208579
I suspect immo off was done incorrectly. Not to mention this vehicle is easy to do if you have the right tools. Pull CS and Pin from ecm or cluster. Make dealer key and program. It's not hard if you know what your doing and have the tools to do it.
Scottarossjr
C?ID=571411
Thank you I did get ahold of him. He said he’s coming out tomorrow to undo it. But yes the windows will not go down. He said he’s coming did it because he couldn’t pull the pin for some reason
Ziddywerks
Northern NJ USA
C?ID=208579
Windows will not go down because immobilizer is turned off in the ecm.
Ziddywerks
Northern NJ USA
C?ID=208579
PIN..... they love PIN .... seems he is from XIX century
LOL that they do. There is a pin present in that system but its useless, however many locksmiths always think they know better. In this vehicle write CS to key to make dealer key or purchase oem key and have it programmed. It's not hard.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Did car start and run for 2-3 seconds before he did anything to ECU?
The Dtc you getting could be also bad starter.
BTW , if you send me cluster and key I can make it work. For more info send me message.
Jef
HQ
<snark>
Oh! Oh! Oh! .... the pin is on that black plastic tag!!!!!!
</snark>
Lets get that Auto-Scan and see what clues it offers up.
Scottarossjr
C?ID=571411
Sorry for taking so long for reply. I just got home. I saved the scan but now nothing is coming up just a bunch of lines. I will rescan tomorrow and send. The lock smith said he will be out tomorrow to reprogram my original file back on the ecu. Says he got the pin and sku too. So we will see. I will send a scan tomorrow when I get back to the car
Ziddywerks
Northern NJ USA
C?ID=208579
Looking forward this PIN solution lmfao.
Scottarossjr
C?ID=571411
Thursday,31,October,2024,17:19:48:02756
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)
VCDS Version: 24.7.1.0 (arm64)  HEX-V2 CB: 0.4643.4
VIN: WAUNE78PX8A175683   License Plate: 9876
Mileage: 218930km-136036mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 65 72
VIN: WAUNE78PX8A175683   Mileage: 218930km-136036miles
44-Steering Assist -- Status: Cannot be reached 1100
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 8P0 907 115 M    HW: 8P0 907 115 M
   Component: 2.0l R4/4V TFSI     0060
   Revision: E3H10---    Serial number: AUX7Z0H2FNE09Z
   Coding: 010301081C070160
   Shop #: WSC 00017 666 00411
   VCID: 3C2124399A6B0BAA433-8068
   VINID: 9D195E547220A084411C51880CF3B6EE6A
012372 - Starter Will Not Turn
               P3054 - 000 - Jammed or Electrical Malfunction
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 00:00:13
                    Temperature: 18.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 12.319 V
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 000 - Implausible Signal
                    Fault Frequency: 8
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 00:05:14
                    Temperature: 19.0°C
                    Temperature: 21.0°C
                    Voltage: 12.319 V
012370 - Starter Control; Returned Message
               P3052 - 000 - 50 Short to Plus - MIL ON
                    Fault Status: 11100000
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 00:00:50
                    Temperature: 19.0°C
                    Temperature: 19.0°C
                    Voltage: 12.192 V
Readiness: 0110 1101
   Part No SW: 02E 300 051 C    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1815
   Revision: 04843012    Serial number: 00000805220651
   Shop #: WSC 01279 785 00200
   VCID: 1373AF85D77524D2F29-8046
17086 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG)
            P0702 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 255
                    Reset counter: 8
            P0702 - 002 -  - Intermittent
                    Reset counter: 8
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 00:04:40
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0053890
   Shop #: WSC 06314 000 00000
   VCID: 6889A869BE73770AF7B-803C
   Part No SW: 8P0 820 043 AH    HW: 8P0 820 043 AH
   Component: KlimavollautomatH19 0430
   Revision: 140269      Serial number: 8P0820043AH
   VCID: 72BDCA0188AF8DDA59F-8026
00796 - Fan for Interior Temp Sensor (V42)
                    Fault Status: 00101011
                    Reset counter: 29
                    Mileage: 218930 km
                    Date: 2024.04.19
                    Time: 00:03:01
                    Voltage: 12.40 V
                    Temperature: 50.5°C
                    Fault Status: 01101000
                    Reset counter: 245
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 00:01:19
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H53 2701
   Revision: 00H53000    Serial number: 00000007963442
   Coding: E18C1F81D01410804F1818001800000000285E075C110001000000000000
   Shop #: WSC 06314 000 08192
   VCID: 48C948E9DEB3570AD7B-801C
   Subsystem 1 - Part No: 8P1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H02 0130
   Coding: 00062736
   Shop #: WSC 06314
   Coding: 00150573
   Shop #: WSC 06314
10 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 245
                    Mileage: 218930 km
                    Date: 2024.04.19
                    Time: 01:06:00
                    Voltage: 9.85 V
                    Reset counter: 245
                    Mileage: 218930 km
                    Date: 2024.04.19
                    Time: 01:06:00
                    Voltage: 9.85 V
00984 - Left Tail Light (M4)
                    Reset counter: 245
                    Mileage: 218853 km
                    Date: 2024.04.15
                    Time: 08:53:00
                    Voltage: 12.95 V
00985 - Right Tail Light (M2)
                    Reset counter: 245
                    Mileage: 218853 km
                    Date: 2024.04.15
                    Time: 08:53:00
                    Voltage: 12.95 V
01800 - Light Switch (E1)
                    Reset counter: 249
                    Mileage: 218930 km
                    Date: 2024.04.19
                    Voltage: 11.40 V
                    Reset counter: 30
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 16:41:00
                    Voltage: 8.75 V
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 245
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 00:01:00
                    Voltage: 12.70 V
                    Reset counter: 245
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 00:01:00
                    Voltage: 12.70 V
                    Reset counter: 245
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Voltage: 12.70 V
                    Reset counter: 245
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 00:01:00
                    Voltage: 12.70 V
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 M    HW: 8P0 959 655 M
   Component:    Airbag 9.41  H01 4220
   Revision: 91H01422    Serial number: 003CQ0003VF4
   Coding: 0032605
   VCID: 4CC174F9CACBBB2AF33-8018
   Subsystem 1 - Part No: 8P0 910 339 C
   Component: BF-Gewichtsens. H02 0030
   Subsystem 2 - Serial number: 02KAJ
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB407140A99Nÿ†63
   Subsystem 5 - Serial number: 40A99Nÿ†6342DRB40714941EOÿ†63
   Subsystem 6 - Serial number: 4941EOÿ†63528RB403A6240BGÿ†63
   Subsystem 7 - Serial number: 6240BGÿ†63628RB403A61B5FWÿ†63
   Subsystem 8 - Serial number: 61B5FWÿ†63747RB403914067Dÿ†63
   Subsystem 9 - Serial number: 14067Dÿ†63847RB403914094Eÿ
   Subsystem 10 - Serial number: 14094Eÿ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0012142
   VCID: 41DF55CDFD896642105-8014
   Component: E0221           H07 0050
01304 - Radio
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective
   Part No SW: 8P0 920 981 N    HW: 8P0 920 981 N
   Component: KOMBIINSTR. VDO H22 0660
   Revision: D0H22003    Serial number: 2242H003102793
   Coding: 0016288
   Shop #: WSC 60565 067 57207
   VCID: 43D35FC5E7957452029-8016
                    Mileage: 218930 km
                    Date: 2024.04.19
                    Time: 00:00:58
                    Reset counter: 245
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 00:03:04
                    Reset counter: 245
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 00:04:03
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K0831510E9
   Coding: ED807F071002022102
   VCID: 34310C19B23BC3EA8B3-8060
01304 - Radio
                    Reset counter: 242
                    Mileage: 218853 km
                    Date: 2024.04.15
                    Time: 08:50:29
                    Fault Frequency: 51
                    Reset counter: 245
                    Mileage: 218930 km
                    Date: 2024.04.20
                    Time: 00:07:33
   Revision: D0H22003    Serial number: AUX7Z0H2FNE09Z
01176 - Key
02241 - Engine Control Module; Immobilizer Data not Adapted
01176 - Key
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0001209
Address 44: Steering Assist
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 K
   Component:    KSG          H11 0080
   Coding: 1B8022A001382D09050FCC8F0477
   VCID: 44D15CD9E29B736A3B3-8010
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
   Component: AB2 SUBWOOFERBOXH06 0180
   Revision: 00005       Serial number: 30674802401450
   VCID: 3537311DB941DAE2BCD-8060
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0001209
Address 56: Radio
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0001176
   Shop #: WSC 06314 000 1012544
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 65: Tire Pressure        Labels: 8J0-907-273.clb
   Part No SW: 8J0 907 273 A    HW: 8J0 907 273 A
   Component: J502-RDK        H03 0370
   Revision: --H03-D0    Serial number: 12956780336363
   Coding: 0860021
   Shop #: WSC 06435 000 00000
   VCID: 2F3B03755B1DE032F61-807A
02214 - Tire Pressure Warning
            000 - - - MIL ON
                    Reset counter: 243
                    Mileage: 218923 km
                    Date: 2024.04.15
                    Time: 17:06:00
                        Not Recogn.
                    Bin. Bits: 00001000 10001000
                    Voltage: 12.70 V
                    Text:  18,0°C;  7,67bar;3434723047;00h;-50°C
            002 - Lower Limit Exceeded - MIL ON
                    Fault Status: 11100010
                    Reset counter: 243
                    Mileage: 218921 km
                    Date: 2024.04.15
                    Time: 15:41:54
                    Bin. Bits: 00001000 10001001
                    Voltage: 13.50 V
                    Text:
Westbury, UK
Looks like the end of the scan is missing?
I agree and it looks like fuses are blown, missing or in wrong positions.
@Scottarossjr , as long as you don't see any fresh rodent damage or activity I would put my focus on the starter circuit in addition to the steering rack.
Also, let us know:
  • Did it crank, start and run before it stalled out after the new key was made and before he did anything to the ECM? That will help determine if the starter DTCs are related to the ECM modifications versus a different problem.
  • Does it crank at all right now?
Ziddywerks
Northern NJ USA
C?ID=208579
Idk I have seen similar fault when ecm was fucked with like immo was butchered.
Scottarossjr
C?ID=571411
I don’t think so I copied with button and past
I thought that at first and put the starter from my gti on it and same thing
Also, let us know:
Scottarossjr
C?ID=571411
Also, let us know:
I’m unsure but it did start and run before I lost the key. There’s no blown fuses. I checked all of them and I Changed the starter. You can here the relay click but that’s it
OK, if the car had power steering and you didn't have any starter issues previously I would post another scan because the last one has the bottom cut off. The voltages at the end of the scan may be the clue we need if terminal 15 doesn't have switched power to it.
In the meanwhile determine if this car has E-Box low versus E-Box high. That's the under hood panel and it will have positions for 2 possible relays when Low. The High box has positions for 4 possible relays. I believe it will be the Low box and in that case fuse SB28 (40 Amp) may be missing or moved to the wrong slot. Those will be marked with the letter F so you are looking for F28 on the plastic panel.
If you determine this is the Low box and find that fuse to be blown or missing it would kill the high amp power to Power Supply Relay 2 (J681) and a bunch of fuses inside the car would lack power. That appears to be the common link between the starter relay circuit and steering rack.
