Retrofit ACC on Audi SQ5 (FY) - Issues with Fault Codes and Drive Select
vossie
Hi everyone,
I’m Vossie from the Netherlands. I’m in the process of retrofitting Adaptive Cruise Control (ACC) on my Audi SQ5 (FY). So far, I’ve replaced the gateway, ABS module, and steering column switch, and installed the radar sensors. Component protection has been removed successfully, and I’ve coded modules 0x01, 0x03, 0x19, and 0x5F as required.
However, I’m running into persistent fault codes:
  • In module 0x13:
    • FAULT_MAINSWITCH_FAIL
    • FAULT_TSK_IRREV_FAIL
  • In module 0x5F:
    • “Driving mode selection (0x17) - function restriction due to communication error”
I also see a “Drive Select not available” message on the MMI screen, which I suspect may be due to a coding issue. Has anyone experienced these fault codes or a similar issue during an ACC retrofit on an SQ5? Any advice or insight would be very helpful.
Thanks in advance for any help!
Chassis Type  FY-AU49 (8W7)
Scan: 01 02 03 08 09 13 15 16 17 19 29 39 3C 42 44 46 47 52 5F 69
          6C 6D 74 81 8B A5 A9 BB BC CF D6 D7
VIN: WAUZZZFY9J2159231   Mileage: 123311km-76621miles
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CWGD)       Labels:. 06M-907-309-V1.clb
   Part No SW: 80A 907 559 B    HW: 06M 907 309 D
   Component: V6 3.0l TFSI  H22 0005
   Revision: B2H22000    CVN: E97D3C45
   Coding: 2A2A0032257E050B34280000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS01180A907559B 001005
   ROD: EV_ECM30TFS01180A907559B.rod
   VCID: 2E5328C5710C18E669-807A
   VINID: 9D196AAAA5A925A08114908304964F4707
21472 - Databus
          U1122 00 [00100111] - Implausible Message
Readiness: 1110 0001
   Part No SW: 80A 927 158     HW: 0D5 927 156 H
   Component: 0D5  30TSIRdW H05 1003
   Revision: --H05---    CVN: 466FB97F
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 69D99BD98862BFDE7C-803C
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 80A 907 379 C    HW: 80A 907 379 A
   Component: ESP9 Premium  H13 0767
   CVN: A941ECBF
   Coding: 1CAA14BE30A70A9FD1A05894187E52A2E4A59A38280C508B1A184A4527A559
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 2F6D35C1760611EE62-807A
   Part No SW: 80A 820 043 K    HW: 80A 820 043 K
   Component: Klima Zone 3  H60 0210
   Coding: 6608000D5544400D02000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 2541D7E924FA5BBE98-8070
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002053912
   Humidity sensor: exterior:
   Serial number: D141D3E800PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 80B909517F  0029
   Coding: 07501143C13900CD050D51199CBF80B9110B310C0000000000000000200016810A45022A025705
   Shop #: WSC 00046 000 00000
   VCID: 020BAC7595144C86DD-8056
   Subsystem 1 - Part No SW: 80B 955 119     HW: 80B 955 119
   Component: 426 LL 180226  040 0570
   Serial number: 00000001802242110143
   Coding: 5FC7F7
   Serial number: 21086909X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 22 03 2018  80810013
   Serial number: GX1CE115021823810073
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 80A 947 135 G    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00031872
   Coding: 0D0104
   Subsystem 6 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000037531001
   Valve block 1 in front seat driver side:
   Subsystem 7 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J873 MKS_FSv  H03 0034
   Serial number: 7008174235B180204573
   Coding: 1E0500
   Valve block 1 in front seat passenger side:
   Subsystem 8 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J872 MKS_BFSv  H03 0034
   Serial number: 7008174235B180205222
   Coding: 120500
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 80A 907 561     HW: 8W0 907 561
   Component: LRR4          H10 0220
   Coding: 3465FF5A58FFEC06747860A4
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 65C197E9647A9BBE58-8030
2062 - Databus
2068 - Databus
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    031 0513
   Serial number: 003WBM040KLR Dataset Number: 80A909602G  0014
   Coding: AACCF0C00C800000585400FFF00C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
   VCID: 3E731885A16CE866F9-806A
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 80A857705G0020S00221
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 80A857706G0030S00368
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 480 003 101 18
   Serial number: 3570000000056661BB2K
   Subsystem 4 - Part No SW: -----------    HW: 480 003 101 18
   Serial number: 35800000000722A86B2L
   Subsystem 5 - Part No SW: -----------    HW: 480 031 401 18
   Serial number: 351001C08F0899614C4C
   Subsystem 6 - Part No SW: -----------    HW: 480 031 401 18
   Serial number: 352001C08F09D5909E9S
   Subsystem 7 - Part No SW: -----------    HW: 480 030 303 18
   Serial number: 355001C0C6ECCC807D6%
   Subsystem 8 - Part No SW: -----------    HW: 480 030 303 18
   Serial number: 356001C0C6E50050DBBI
   Subsystem 9 - Part No SW: -----------    HW: 480 030 402 18
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C08C1CE0A0BA0A
   Subsystem 10 - Part No SW: -----------    HW: 480 002 709 22
   Serial number: I0M00000000C1A7C61EH
   Subsystem 11 - Part No SW: -----------    HW: 480 002 709 22
   Serial number: I0N0000000011A7C61E7
   Central crash sensor X/Y:
   Subsystem 12 - Part No SW: -----------    HW: 480 022 312 17
   Component: CentrSensorXY  000 0108
   Serial number: I0O00019D28B1CF4D6FN
   Part No SW: 80A 907 129 DT    HW: 80A 907 129 DT
   Component: Lenks.Modul   H03 0009
   VCID: 7DF1DF89ECEA337EA0-8028
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H18 0373
   Coding: 05AD96C43C8800080003E9601028600000000000
   Shop #: WSC 99999 999 83333
   VCID: 43856971CA8E858E96-8016
   Part No SW: 8W7 907 468 E    HW: 8W7 907 468 E
   Component: Gateway       H42 0119
   Revision: 6C030004    Serial number: 0486C791817A23 Dataset Number: 4M0909515L  0080
   Coding: 03010003000006405407000000590032FC9A0007180000000175078E10000000
   GVL: 01503C1008000000C0CCC8000002C800010C0000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003092
   VCID: 4D914F491CCA43FE70-8018
   Subsystem 1 - Part No SW: 80A 951 523 D    HW: 80A 951 523 D
   Component: J453 MFL  H06 0004
   Serial number: 20180315190702 00752
   Serial number: 7053855600
Address 29: Left Light
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Address 39: Right Light
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 80A 907 566     HW: 80A 907 566
   Component: MRR1Rear      H18 0420
   Revision: --------    Dataset Number: 80B909535B  0013
   Coding: 1E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 6ADBE4D58D64B4C675-803E
   Part No SW: 4M1 959 793 B    HW: 4M1 959 793 B
   Component: TSG FS006 0737
   Serial number: CLSM1RCA008QI Dataset Number: 80B909872A  0025
   Coding: 005D1B0150000480000010B0
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000443430 Dataset Number: 80B909852K  0001
   Coding: B0002001000100
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 34673AAD9F2032361F-8060
Address 46: Central Conv.
   Part No SW: 80A 035 223 A    HW: 80A 035 223
   Component: MIB2_amp_P_Q5 H03 0420
   Revision: 00000001    Serial number: AUZ8ZAJTK025BNM Dataset Number: 80B909510B  0007
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   VCID: 1939EB191882EF5E2C-804C
   Part No SW: 4M1 959 792 B    HW: 4M1 959 792 B
   Component: TSG BFS006 0737
   Serial number: CLSM1RCA007HT Dataset Number: 80B909873A  0025
   Coding: 005D1B015C000480000010B0
   VCID: 3D711F89AC6AF37EE0-8068
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 036 B    HW: 8W5 035 036
   Component: MU-P-LN-EU    034 1177
   Serial number: A795C0J9410237 Dataset Number: 80B909545N  0026
   Coding: 012456010000000053110002000A00332F001AE5017001009E
   VCID: 377D0DA18E56D92E3A-8062
   Subsystem 1 - Part No SW: V03 959 802 TL    HW: -----------
   Component: ECE 2020/2021  --- 0187
   Multimedia System 1:
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9JBL03T5N
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 19011800000000000239
   Compact disc data bank:
   Component: Gracenote2  --- 1016
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
   Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
   Revision: 9A001003    Serial number: 0465073219 Dataset Number: 80B909527A  0008
   Coding: 0110000202000000
   VCID: 356107A9945A2B3E28-8060
   Component: RVC Compact   H12 0250
   Dataset Number: 80B909460F  0007
   Coding: 0224060103002005400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 336539B19A2E350E06-8066
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: A2-C748-5750-5 Dataset Number: 80B909541C  0009
   Coding: 07B0
   Shop #: WSC 31984 182 00000
   ROD: EV_DeckLidCONTIAU736_VW48.rod
   VCID: 489F7E5DF3A8A6D643-801C
Address 74: Chassis Control
   Part No SW: 80B 713 041 F    HW: 80B 713 041 F
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 20180304000900
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 204FC6FD3BD8BE96EB-8074
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 80A 907 541     HW: 8W0 907 541
   Dataset Number: 80B909885D  0009
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 63C589F16A4EE58EB6-8036
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 A    HW: 80A 907 217 A
   Component: BVS           H16 0050
   Dataset Number: 80B909466D  0023
   Coding: 0404020600000404022023A7AC0000FE10F0C020C280
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: 2447CAED2FC0A2B68F-8070
   Part No SW: 80A 907 159     HW: 4H0 907 159 A
   Serial number: 180119202441
   VCID: 68DF9EDD936886D663-803C
   Part No SW: 4M1 959 795 B    HW: 4M1 959 795 B
   Component: TSG HFS006 0737
   Serial number: CLSM1RC90045N Dataset Number: 80B909897A  0026
   Coding: 000D190000000480000010A0
   VCID: 408F667DDB989E968B-8014
   Component: TSG HBFS006 0737
   Serial number: CLSM1RC900522 Dataset Number: 80B909896A  0026
Address CF: Lane Chge Asst 2
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
TTT
C?ID=547002
Cropping auto scan is not ok.
vossie
Sorry, will make sure to include the full scan next time.
Monday,14,October,2024,17:04:02:07005
VCDS Version: 24.7.1.0 (x64)
Workshop Code: 785 02391 000200
VIN: WAUZZZFY9J2159231   License Plate:
Mileage: 123311km-76621mi   Repair Order:
21472 - Databus
   Coding: 100000
   CVN: A941ECBF
   Coding: 5FC7F7
   Coding: 02006E
   Coding: 030000
   Coding: 0D0104
   Coding: 1E0500
   Coding: 120500
2062 - Databus
2068 - Databus
   Coding: 88001B
   Coding: 88001B
   Coding: 1E8002
   Coding: 07B0
End-------------------------(Elapsed Time: 06:23)--------------------------
