Rain Sensor not working after retrofit
matomm4
Pirate
Walking the Plank
Slovakia
LP/IP
I retrofitted to Skoda Octavia 3 2014 RLHS sensor 5Q0 955 547 and light switch with AUTO position. Light switching works perfect, Coming home/leaving home too, but the rain sensor is still in the manual mode, like before, that means in first position of wipers switch, I still have the manual cyclic function, not automatic screen wiping according to the intensity of the rain. Where can I have problem?
My BCM is: 5Q0-937-086-P
In [09 cent. eletric] in Coding [07] I did these changes:
Coding RLHS:
Byte 0, Bit 1: Rain light fuction active - turned on
Byte 0, bit 2: Rain closing active - turned on
Byte 0, bit 3-5: 00 light activation threshold normal
Byte 0, bit 6-7: 00 rain sensor function active [standard]
Final coding of RLHS sensor is: 02805D.
Coding in BCM 5Q0-937-086-P:
Byte 6, Bit 0-1:Light sensor (RP-8N4) installed
Byte 7, Bit 5: Light switch with assistance driving light (ADL) installed - turned on
Final coding of BCM: 0C000846424702FB47E04000001407080000000000000000000000000000
Here are my adaptation:
Removed.   Data from a clone/pirate copy of VCDS is not acceptable in Ross-Tech's forum.
Is here somebody who can help me with that problem please?
  • Disagree
