P2096 2012 jetta 2.0 SOHC
q76767
New Jersey, USA
C?ID=445722
I have a 2012 VW Jetta 2.0 non turbo and I am getting P2096 My exhaust has no leaks and neither does the vacuum system. I smoke test both. What else should I look for? Here are my fuel trims aswell
Monday,28,October,2024,17:01:36:58701
VIN: 3VW2K7AJ4CM311089   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 56
VIN: 3VW2K7AJ4CM311089   Mileage: 245230km-152378miles
Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
   Part No SW: 06G 906 055 S    HW: 06G 906 055 B
   Component: 2.0l / 85 KW     01 1106
   Revision: T5H06---    Serial number:
   Coding: 0001015
   Shop #: WSC 07212 444 101339
   VCID: 392F24AA8557C612585-806C
   VINID: 0E69C26C745A113743041008241720A809
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
               P2096 - 000 - Too Lean
                    Mileage: 245230 km
                    Date: 2019.03.21.
                    Time: 01:23:42
                    RPM: 1471 /min
                    Load: 25.1 %
                    Speed: 67.0 km/h
                    Temperature: 85.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
Readiness: 0110 0100
   Part No SW: 09G 927 750 LE    HW: 09G 927 750 LE
   Component: AQ 250 6F           2618
   Revision: 00H97000    Serial number:
   Coding: 0000840
   Shop #: WSC 43988 001 1048576
   VCID: 7F5B0AB2DBF32822261-802A
   Revision: 00H31001
   Coding: B14B240C512308FB8D0B24EC8A221061A70000
   Shop #: WSC 00066 000 00000
   VCID: 7BA3FEA2C3EB34020A9-802E
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AM    HW: 5C0 820 047 AM
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000487300
   VCID: 6B83CEE2BF8BA4829A9-803E
00898 - Control Circuit A/C compressor
                    Fault Status: 00110111
                    Reset counter: 118
                    Mileage: 244798 km
                    Date: 2019.03.21.
                    Time: 00:04:44
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0251
   Revision: B2066001    Serial number: 04371208110261
   Coding: 7B994B1808AB0B0000302000240884D40042502E60000000300000000000
   Shop #: WSC 00066 123 12345
   VCID: 2F3B1AF2471318A2F61-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
00538 - Reference Voltage
                    Fault Status: 00101011
                    Reset counter: 123
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTM00S7YA   Dataset Number: 160003v____ 0154
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3431159EAEB53B7A8B3-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100005YBC0V
   Coding: 303148
   Serial number: 3572MSME08341660ZZZL
   Serial number: 3582MSME0A590560ZZZT
   Serial number: 3516KSME73632711ZZZJ
   Serial number: 3526KSME44462411ZZZG
   Serial number: 3556LSME02001B12ZZZB
   Serial number: 3566LSME29031B12ZZZO
   Part No SW: 5C6 920 951     HW: 5C6 920 951
   Component: KOMBI         H04 0604
   Coding: 270201
   Shop #: WSC 00066 000 00123
   VCID: 6889B1EEA2FD8F9AF7B-803C
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0251
   Revision: B2066001
   Coding: 102200
   VCID: 70B9D98E9AAD475AAFB-8024
   Component: IMMO          H04 0604
   Shop #: WSC 00066 000 00199
   VCID: 6A8DCBE6BCF1BD8AE1F-803E
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0004
   Revision: -----03S    Serial number: VWZ4Z6L3163870
   Coding: 05000400010006
   VCID: 2313E6C21BDBACC2629-8076
End----------(Elapsed Time: 00:59, VBatt start/end: 14.0V/14.1V)-----------
EuroX
Northern NJ USA
C?ID=208579
Drive it some 60 miles when repost fuel trim readings. Every time codes are clear fuel trim readings reset. Does this vehicle has a spacer for the rear o2 sensor installed?
EuroX
Northern NJ USA
C?ID=208579
It's adding fuel, but thats not enough. Drive it more 60miles and then recheck readings. Normally for that fault to be throw that reading needs to be past 10 or 15%. IF it is adding fuel this means you may have a vacuum leak. Could be a rear main seal with the mileage its got or something else. Hard to say. I would try checking vacuum at idle.
q76767
New Jersey, USA
C?ID=445722
ill drive more and check back. Rear main seems fine no oil leaks and had smoke machine hooked up for 20 mins and did not see anything coming from between motor and trans and car was jacked up to see underneath.
EuroX
Northern NJ USA
C?ID=208579
Spray brake clean between engine and trans and watch the values.
q76767
New Jersey, USA
C?ID=445722
Is this my mass air flow senor I believe? When unplugged it doesn't make a difference in how it runs or throw a code for anything. When spray brake clean between motor and trans numbers do not change
I don't think so. The MAF sensor should be in-line with all of the airflow, not in a "branch". Look closer to the air box.
q76767
New Jersey, USA
C?ID=445722
Nothing else on or near airbox. On sensor only stamping I see is pbt-gf30 which appears could be a maf sensor
EuroX
Northern NJ USA
C?ID=208579
Not possible that line comes off the crankcase so theres no chance that a MAF. Not possible. PBT GF30 is what it's made of it's a type of plastic.
q76767
New Jersey, USA
C?ID=445722
So far I've smoked exhaust for leaks and no leaks, smoke tested vacum lines no leaks. Sprayed carb cleaner between motor and trans and no change in fuel trims. Anyone knowing this car has a maf sensor?
Looking at the MVB data for that ECU, I'm thinking it does doesn't have a MAF; that it uses the speed/density method of control.
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
It has a MAP sensor located just above timing belt cover bolted to intake manifold.
So it uses a MAP sensor instead of a Mass Air Meter.
Check the big plastic line behind intake going to the brake booster they crack at connections.
Good Luck
Waxing pedantic here, but the two are not always mutually exclusive. Some engines have both a MAF and a MAP.
gigi123
C?ID=30490
See if you can look at signal from Sensor 2. Might just be a bad sensor (after cat) that shows low voltage for nothing. Assuming fuel trim looks good still.
The "sensor" in the pics is a heater for the breather.
vwtech
Wilkes-Barre, PA
C?ID=7573
This is true some motors have both but not this motor MAP only.
I just answered his question.
Good Luck
q76767
New Jersey, USA
C?ID=445722
Good Luck
Would bad map sensor cause lean code?
q76767
New Jersey, USA
C?ID=445722
I don't have vcdcs in front of me but it is a brand new bosch sensor
