Hi,
My friend has a 2009 Volkswagen Touareg V6 TDI. She says the car was taken care of. Recently the car overheated on the highway after a long trip. It does not start anymore.
I did a full scan, which I am attaching below. I tried googling around for all the symptoms and they seem to be separate issues. I also checked fuse boxes on both sides and the one under the windshield - all the fuses are good. I vaguely remember that the friend said they replaced the battery about a month ago, so I have a suspicion about the battery not being connected well - I still need to check that.
In the meantime, I would appreciate your help to understand which of the issues I should be chasing first if I want the car to start.
Thank you.
Thank you.
VCDS-Mobile
Auto-Scan
Finished
VCDS Mobile: 0.4643
Data Version: 30000060
VIN: WVGZZZ7LZ8D079627
Scan: 01 02 03 05 08 09 15 16 17 19 22 46 56 68 69 76
01-Engine -- Status: Malfunction 2048010
02-Auto Trans -- Status: OK 2048000
03-ABS Brakes -- Status: Malfunction 1024010
05-Acc/Start Auth. -- Status: Malfunction 1056010
08-Auto HVAC -- Status: Malfunction 1056010
09-Cent. Elect. -- Status: OK 1056000
15-Airbags -- Status: OK 1024000
16-Steering wheel -- Status: OK 1056000
17-Instruments -- Status: Malfunction 672010
19-CAN Gateway -- Status: OK 672000
22-AWD -- Status: OK 2048000
42-Door Elect, Driver -- Status: OK 3616000
46-Central Conv. -- Status: OK 2080000
52-Door Elect, Pass. -- Status: OK 3616000
56-Radio -- Status: OK 576000
62-Door, Rear Left -- Status: Malfunction 3616010
68-Wiper Electr. -- Status: OK 576000
69-Trailer -- Status: Malfunction 1056010
72-Door, Rear Right -- Status: OK 3616000
76-Park Assist -- Status: OK 1056000
Address 01: Engine Labels: 059-907-401-CAT1.clb
Part No SW: 7L0 907 401 N HW: 7L0907401H
Component: 3.0TDI EDC17G100AG 0060
Revision: --H02--- Serial Number: VWX3Z0H1758611
Coding: 04210023590F0168
Shop #: WSC 00999 444 64523
VCID: 362F85DB647B6C9D7F0D76-5184
8 Faults Found:
005276 - EGR Coolant Pump
P149C - 000 - Open Circuit - Intermittent
001592 - Throttle Body Actuator Bank 1 (J338)
P0638 - 000 - Implausible Signal - Intermittent
005643 - Check Repair Manual or Contact Ross-Tech
P160B - 011 - Open Circuit - Intermittent
004139 - Torque Restriction due to Engine Oil Temperature
P102B - 000 - - - Intermittent
012370 - Starter Control; Returned Message
P3052 - 000 - 50 Short to Plus - Intermittent
000257 - Mass Air Flow Sensor (G70)
P0101 - 004 - Implausible Signal
004109 - Actuator for Turbocharger Adjustment
P100D - 000 - Stuck or Hard to Move - Intermittent
000385 - Fuel Temp. Sensor A (G81)
P0181 - 000 - Implausible Signal - Intermittent
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 JK HW: 09D927750JK
Component: AL 750 6A 1411
Revision: 00H75000 Serial Number:
Coding: 0004456
Shop #: WSC 31414 790 00001
VCID: 8043A303F63F922D1511A0-5160
No fault codes found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 L HW: 7L0907379L
Component: ESP ALLRAD MK25E1 0303
Revision: 00H53001
Coding: 0004354
VCID: 42C7E90B38B3C53DC385FA-8017
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 D HW: 3D0909139D
Component: Kessy 6850
Revision: 00H22070 Serial Number: VWX3Z0H1758611
Coding: 0000232
VCID: 2A17A1ABA0C33D7DEBB5F2-807F
Subsystem 1 - Part No SW: XXX-XXX-XXX-XX
Component: ELV XXXX
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No SW: 7L6 907 040 AF
Component: CLIMAtronic R/L 4331
Coding: 0021520
VCID: 74AB7FD332873B8D8199DC-8021
00657 - Positioning Motor for Central Vents (V102)
01596 - Motor for Outside/Recirculated Air Flap (V154)
Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6937049AF
Component: 2000J519
Serial Number: --------------
Shop #: WSC 00000 000
VCID: 8043A303F63F972D1511A0-80D5
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0959655
Component: J234__39 VW8T 0250
Revision: 92012025 Serial Number: 0039P00539FQ
Coding: 0013113
VCID: FAB7D1EB90E3CDFD5BD5E2-80AF
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No SW: 7L6 953 549 F
Component: J527 3601
Coding: 0010011
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 875 L HW: 7L6920875L
Component: J285 KOMBI-INST. 7320
Revision: KHH05V03
Coding: 0007101
Shop #: WSC 01050 067 57207
VCID: 44CBEF1322A7CF0DF1B9CC-8011
Part No SW: 6N0 909 901 HW: 7L6920875L
Component: J533 GW-K-CAN TP20 7320
Coding: 57E2E78B40046003
VCID: F0A3F3C3C69F83ADE57170-80A5
Address 22: AWD Labels: 0A-22.lbl
Part No SW: 0AD 927 755 BG
Component: TRANSFERCASE 0126
VCID: 8145A607FD359B251A1FAD-5184
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No SW: 7L6 959 933 A
Component: 25 HSG 0601
Coding: 0000065
Shop #: WSC 13160 004 1048576
VCID: 40C3E30336BFD22DD591E0-4B3C
Subsystem 1 - Part No SW: 7L0-959-701-R
Component: Tuersteuergeraet FS 6303
Subsystem 2 - Part No SW: 7L0-959-702-R
Component: Tuersteuergeraet BF 6302
Subsystem 3 - Part No SW: 7L6-959-703
Component: Tuersteuergeraet HL 0202
Subsystem 4 - Part No SW: 7L6-959-704
Component: Tuersteuergeraet HR 0202
Subsystem 5 - Part No SW: 7L0-907-719-A
Component: Neigungssensor 0020
Subsystem 6 - Part No SW: 7L6-951-171-B
Component: Innenraumsensor 0020
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No SW: 7L6 035 195 B HW: 7L6035195B
Component: Radio DE2 0009
Revision: 00006000 Serial Number: VWZ4Z4H1047952
Coding: 0001402
VCID: 3227B9CB881371BD53E50A-8067
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No SW: 7L6 955 119 C
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 3A3791EB506389FD9B55A2-806F
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 N HW: 7L0907383N
Component: J345 Anhaenger 0080
Revision: 4A008002 Serial Number: 00000119635251
Coding: 0016385
VCID: 3FC1E0FF4B41A8D5AC6B9B-806A
011 - Open Circuit - MIL ON
Address 76: Park Assist Labels: None
Part No SW: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 39358EE7556586E5922F55-806C
End--(Elapsed Time: 02:43, VBatt start/end: 12.3/12.2 Vign: 12.1)-
