Philip
Pirate
I've been having an intermittent problem with an Audi A2 1.6 FSI, engine code BAD - under load or hard acceleration, the engine will occasionally stumble (it feels like it cuts out completely, rather than a misfire). This illuminates the ASR light, ABS light and the exclamation mark warning on the dash, along with the warning beep - turning the ignition on and off clears the dash messages, but VCDS gives the following codes after it has happened:
Otherwise, everything runs well and only those codes are recorded; it has recently had new plugs, filters etc. Once cleared, the codes only return if the same engine hesitation occurs - ABS and ASR appear to work as normal, whether the warning lights are lit or not. The only code which reoccurs is an intermittent one for the EGT sensor, which I don't think is related:
Can anyone suggest where to start looking? I'm assuming the engine cutting out is causing the fault to be logged by the ABS module rather than the other way around.
[b]Removed. Data from pirated copies of VCDS is not welcome here![/b]
