Airbag Module Coding
PowerNoob
Bristol, UK
Hello all who read, I am hoping someone can point me in the right direction. I have a customers Audi A1 accident repaired when bought. Air bag fault due to "high resistace" on the battery interupt igniter (not present). I believe the module is either incorrect or incorrectly coded. I would like to code out the battery interupt igniter as it is not present (OE harness doesnt have battery interupter). I dont have access to the old module unfortunatley to scrape the long code. Thank you all in advance for any assistance.
LOG:
Sunday,27,October,2024,09:35:36:27425
VCDS Version: 24.7.1.0 (x64)
VIN: WAUZZZ8X8DB079458   License Plate: A1
Mileage: 138310km-85941mi   Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F 62 72
VIN: WAUZZZ8X8DB079458   Mileage: 138310km-85941miles
Address 01: Engine (J623-CBZA)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GN    HW: 03F 907 309 AC
   Component: SIMOS10.24AH10 4046
   Revision: --H10---    Serial number:                CVN: 5EFF8230
   Coding: 00110096230401080000
   Shop #: WSC 00046 412 00000
   ASAM Dataset: EV_ECM12TFS02103F906070GN 004006
   ROD: GV_ECM12TFS021VW36X.rod
   VCID: 74E7908CDFD00E36DF-8020
   VINID: 9D196AAAA2282144801C9105201E3EE401
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 BR    HW: 6R0 907 379 BA
   Component: ESP9.0i front H02 0003
   Serial number: --------------
   Coding: 33DF288B232A02C9CC18146EC45940981004
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003031
   ROD: EV_Brake1ESP90iBOSCH_003_VW23.rod
   VCID: 0F2DFF60D6364DEE42-805A
   Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
   Component: J255 Klima Manuell  0150
   Revision: 0000708S    Serial number: 03030017863065
   Shop #: WSC 00046 000 00000
   VCID: 3467508C57504E361F-8060
                    Fault Frequency: 237
                    Reset counter: 147
                    Mileage: 127812 km
                    Date: 2023.12.16
                    Time: 14:27:02
   Part No SW: 8X0 907 063 K    HW: 8X0 907 063 K
   Component: BCM PQ35  M   111 0715
   Revision: AH111715
   Coding: 0E000A2CA805F1C0201841E000000154438B6C0A00CF4922DC0087830041
   VCID: 4487004CC7F0FEB6AF-8010
   Subsystem 1 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 107
                    Mileage: 138311 km
                    Date: 2024.10.25
                    Time: 18:32:38
                        Term 15 Off
                    Voltage: 12.10 V
                        Term 50 Off
   Part No SW: 8X0 959 655 B    HW: 8X0 959 655 B
   Component: Airbag10.41   H06 0009
   Revision: --------    Serial number: 003KZ006DS8R Dataset Number: 8X0909602C  0003
   Coding: 30323236303230303138554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001018
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 49991178E8D223DE5C-801C
   Serial number: 3554VRB40651NOT298UC
   Serial number: 3575HRB405L1SJR29O33
   Serial number: 3585HRB405B1S1NIG11D
   Rear end impact crash sensor:
   Serial number: 3515ZRB40124UIV8R8SX
9442587 - Igniter for battery interrupt
          B1015 1B [10001001] - Resistance Too High
                    Mileage: 138311 km
                    Date: 2024.10.25
                    Time: 15:02:53
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Revision: FF010017    Serial number: 20130115201357
   Coding: 1184004000
   VCID: 397961B8B832B35ECC-806C
365080 - Controls in Steering Wheel
          U108E 00 [00001001] - No Communications
                    Reset counter: 79
                    Mileage: 87018 km
                    Date: 2020.04.24
                    Time: 19:24:18
Address 17: Instruments (J285)       Labels:| 8X0-920-KOM-V1.clb-SRI1
   Part No SW: 8X0 920 980 F    HW: 8X0 920 980 F
   Component: KOMBI_MEDIUM  H03 0252
   Coding: 41CE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04396
   VCID: 428B0654D5E4F0869D-8016
1048578 - No Basic Setting
          B2010 00 [00001001] - -
                    Reset counter: 60
                    Mileage: 111710 km
                    Date: 2022.06.14
                    Time: 12:34:22
Address 19: CAN Gateway (J533)       Labels:. 8X0-907-468.clb
   Part No SW: 8U0 907 468 G    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0059
   Revision: 1P100034    Serial number: 3441P131160274
   Coding: FBCF7A64000100010353
   VCID: 46831A44F1CCCCA6B1-8012
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 00000000002030937978
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 12102700000000000103
00458 - Control Module for Battery Monitoring (J367)
                    Reset counter: 147
                    Mileage: 138305 km
                    Date: 2024.10.24
                    Time: 12:04:15
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
   Component: IMMO          H03 0252
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 F    HW: 8X0 959 793 F
   Component: TSG FA        H10 0415
   Coding: 011802200001000000
   VCID: 50AF3C1C038812161B-8004
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11251
   Shop #: WSC 00046
   VCID: 306F5C9CF74872167B-8064
   Part No SW: 8X0 959 792 F    HW: 8X0 959 792 F
   Component: TSG BF        H10 0415
   VCID: 4FAD3F601EB60DEE02-801A
   Part No SW: 8X0 035 183 F    HW: 8X0 035 183 D
   Component: RMC Cnct      H53 0801
   Coding: 01010400000051070023000103010000010000
   VCID: 3A7B7EB4B534B846C5-806E
   Subsystem 1 - Part No SW: 8X0 919 603 A    HW: 8X0 919 603 A
   Component: DU6 Basic  H43 0084
   Serial number: 9462AV0D2622936
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Reset counter: 139
                    Mileage: 95783 km
                    Date: 2021.01.23
                    Time: 18:34:33
                    Voltage: 12.70 V
Address 62: Door, Rear Left (J388)       Labels:. 8X0-959-795.clb
   Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
   Component: TSG HL        H07 0415
   Coding: 010002200001000000
Address 72: Door, Rear Right (J389)       Labels:. 8X0-959-795.clb
   Component: TSG HR        H07 0415
End-------------------------(Elapsed Time: 02:39)--------------------------
I don't think this is a coding issue. Check this Adaptation channel:
MAS00975-MAS00022 -- Airbag adaptations - Battery Interrupt Igniter
If it can't be set there, then I suspect it will need a different dataset.
PowerNoob
Bristol, UK
Thanks for quick reply. I Think it was channel 8B ( I dont have car on hand but can check tomrrow)
Appologies, first NOOB question. "Need a different dataset " ?
If it needs that altered, it would need to be flashed, and that's something you can't do with VCDS.
PowerNoob
Bristol, UK
Beautitful, understood. So either flashed or new module. Thank you for your time and help.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Let's go step by step.
Was the currently installed module used or new? If it was a new module, who did the initial coding etc.? If it is a used module, this has likely an incorrect dataset as Uwe already indicated, personally I would not play with that. Nobody in their right might will guarantee full functionality after such attempts.
Now here's why I am shaking my head. On an Airbag 10.41 system like this, a replacement module should not have been necessary in the first place. Unless the car literally rolled over, the old module should still be good according to manufacturer specifications. That raises even more questions. Was this actually a different (used) module or (what sounds much more plausible to me), did sb. mess with the software/dataset of the original airbag control module? In either case, I don't think this module could be trusted.
PowerNoob
Bristol, UK
Sebastian, thank you for weighing in. Unfortunatley my knoledge on the modules providence is limited and same for the customer. The person they bought the car from advised the AB light was on due to steering wheel change. so who knows if its the original module ornot. Your plausible idea deffinatley has merrit as there doesnt seem to be much sign of tom foolery when it comes to the AB modules surrounding components being disturbed. May I please ask your recommendations for moving forward (OE new replacement?). I appreciate your help as I am here to learn.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
It's hard to come up with a specific recommendation without knowing all the details/history. If the module was replaced, I would expect there to be some invoice for the work/replacement etc., in order to look into this after the fact you could certainly check the Advanced ID details in the airbag control module (feel free to post the details displayed by VCDS here). This would give some hints towards the production date of the module, which could be a clue. There may be some additional details, which could also be helpful but this is a long shot and would likely not solve but merely investigate the issue further.
What it boils down to, the module has either been replaced, reset or somehow been programmed incorrectly. Since this is a safety system, I am not a friend of playing any games and would work along the manufacturer specifications. This will most likely imply replacing the module with a new one and programming it accordingly.
