Hello
I am new to the forums. I will do my best to be active on the forums. Now let's dig in.
We have done a rebuild on a CAVA engine 1.4 TSI VW scirocco due to broken piston (common problem). We put on new KS pistons +0.5mm, new upgraded timing chain kit 03C198229C (original VW), new kit for oil pump (chain tensioner), new shaft seal for crankshaft (corteco), water pump, belts, cleaned, repaired and tested injectors, valves grinded on cylinder head perfectly, new gasket kit for everything, new filters (including fuel filter), new spark plugs ect.
So the problem here is that the car cranks perfectly, works and sound very smooth on idle. Revving the engine up to 4000rpm runs perfectly and the only issue that in misfiring between 2000-3000 rpm if you keep it there steady for a few seconds. The check engine starts to flush and through live data you can see A LOT of misfires on 2nd and 3rd cylinder. If you stay there for another 2 seconds EPC comes on and disables the cylinder (stops the injectors on 2nd and 3rd cylinder).
We took out the injectors again, send them to the technician for a recheck. In fact he cleaned them again and tested them. Nothing wrong. We swap them places from 2nd and 3rd cylinder to 1st and 4th cylinder. Put everything back on and the problem still insists.
We will do more check by Tuesday once we are open again. But i suspect that the car will need a software update in order to match all the new parts and upgrades it has right now on the engine. I will gladly hear your opinions below!
Chris
Chris
