Recently had vehicle returned after having Reconditioned engine fitted. Engine, Turbo, Fuel Pump (high Pressure), Reconditioned Injectors, EGR Valves, Glow Plugs and DPF Cleaned. Vehicle ran ok initially, while taking it for it's annual test (here in the UK) dropped into Limp Mode, Glow Plug Light Flashing and EML came on. Ran a check and it had a load of faults but put most of them down to battery being removed and perhaps 'old' faults listed in ECU. Cleared them all off but only got a relatively short distance before it happened again. Cancelled test and returned home. Cleared off the fault, again, ran it up on the drive and even kicked in stationary. Mechanic is coming Saturday to check it out but any suggestions welcome.
Pasted from Notepad not direct from VCDS
Mileage: 251903 Repair Order:
Address 01: Engine (04L 906 016 HJ)
14:56:01
IDE01387 Injector 1: rail pressure calibration point 1 -30.80 µs
IDE01388 Injector 1: rail pressure calibration point 2 -18.40 µs
IDE01389 Injector 1: rail pressure calibration point 3 -17.20 µs
IDE01390 Injector 2: rail pressure calibration point 1 -16.40 µs
IDE01391 Injector 2: rail pressure calibration point 2 -12.40 µs
IDE01392 Injector 2: rail pressure calibration point 3 -10.80 µs
IDE01393 Injector 3: rail pressure calibration point 1 -9.20 µs
IDE01394 Injector 3: rail pressure calibration point 2 -11.20 µs
IDE01395 Injector 3: rail pressure calibration point 3 -8.40 µs
IDE01396 Injector 4: rail pressure calibration point 1 -19.60 µs
IDE01397 Injector 4: rail pressure calibration point 2 -20.80 µs
IDE01398 Injector 4: rail pressure calibration point 3 -14.40 µs
Thursday,24,October,2024,15:23:15:08428
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
14:56:01
