- Apr 25, 2023
- 43
- 5
- Northwich, UK
- C?ID=546157
Hi,
I had an engine swap done but there seems to be an issue with the wiring.
My van is a VW Caddy SDI and its now got a 2.0l TDI CBAB 140 from a 2009 Eos.
The engine will crank but won't start.
The glow plug light is flashing and here is the latest scan.
Initially I just want it to start to make sure its running right because I've completely rebuilt it (rehoned,reground crank,new bearings,rings,head gasket etc etc etc :-)_
Can anyone tell me whether the engine can start with the DTC's it currently has? Not sure if the readiness should be 0 0 0 0 0 as mine is 0 0 0 0 1 which shows the EGR as incomplete which I think is fine as it can't test it without vacuum with the engine started.
The other worrying error is the ECU one, I was told this error is fine and its just because its been modded to sort the mileage and immobilizer?
Tuesday,22,October,2024,11:14:31:43604
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WV1ZZZ2KZ6X041646 License Plate:
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52
VIN: WV1ZZZ2KZ6X041646 Mileage: 580820km-360904miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 PM HW: 03L 906 022 G
Component: R4 2.0l TDI 0000SG 9979
Revision: 13H01--- Serial number: VWX7Z0HN3NR7V2
Coding: 0001072
Shop #: WSC 26214 051 00000
VCID: 7F5B10439BF7D9B22E9-802A
VINID: 9E606AAAA09BA86A00101184183C18C7B8
8 Faults Found:
008487 - Accelerator Position Sensor 2 (G185)
P2127 - 000 - Signal too Low - MIL ON
Fault Status: 11100000
Mileage: 580821 km
Time: 01:34:32
Voltage: 11.86 V
Voltage: 0.760 V
Voltage: 0.000 V
Bin. Bits: 1 00 0
009778 - Relay for Fuel Pump 2 (J49)
P2632 - 000 - Open Circuit - MIL ON
Mileage: 580821 km
Time: 01:34:32
Voltage: 11.86 V
Pressure: 0.0 bar
Inj. Quantity: 0.0 mg/str
Lambda: 15.0 %
Lambda: 7.9 %
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 000 - Signal too High - MIL ON
Mileage: 580821 km
Time: 01:34:33
Voltage: 11.86 V
Absolute Pres.: 1020.0 mbar
Absolute Pres.: 2193.0 mbar
Temperature: 10.8°C
Temperature: 22.5°C
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High
Mileage: 580821 km
Time: 01:34:33
Voltage: 11.86 V
Temperature: 11.7°C
Temperature: 99.0°C
Temperature: 15.3°C
Temperature: 134.1°C
000275 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High
Mileage: 580821 km
Time: 01:34:33
Voltage: 11.86 V
Temperature: 11.7°C
Temperature: 99.0°C
Temperature: 15.3°C
000072 - Boost Pressure Control Valve/Solenoid (Bank 1)
P0048 - 000 - Short to Plus - MIL ON
Mileage: 580821 km
Time: 01:34:33
Load: 9.8 %
Lambda: -1.6 %
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - MIL ON
Mileage: 580821 km
Time: 01:34:33
Voltage: 11.86 V
Load: 100.0 %
Load: 100.0 %
Mass Air / Rev.: 1070.0 mg/str
Mass Air / Rev.: 0.0 mg/str
001552 - Engine Control Unit Incorrectly Coded
P0610 - 000 - - MIL ON
Mileage: 580821 km
Time: 01:34:33
Voltage: 11.86 V
Voltage: 11.86 V
Voltage: 11.86 V
Voltage: 11.86 V
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.clb
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017106
Shop #: WSC 35110 377 00161
VCID: 3FDB5043DB7719B26E9-806A
Part No SW: 1K0 820 047 FT HW: 1K0 820 047 FT
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 7BA3E4538FEFC592021-802E
009 - Open or Short to Ground
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005096278
Coding: 00004E130004100000000000000000000008FB075C
Shop #: WSC 12345 111 45725
VCID: 2A0D111730F58C1A297-807E
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 211207 021 0501
Coding: 00038805
Shop #: WSC 12345
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 09 AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD081LB7
Coding: 0012345
VCID: 7DA7EA4B91FBCBA23C5-8028
Part No SW: 1K0 953 549 AE HW: 1K0 953 549 AE
Component: Lenksäulenmodul 034 0070
Coding: 0000001
Shop #: WSC 35110 377 08192
VCID: 75B7F26BA9CB93E2745-8020
Part No: 2K0 920 942 C
Component: KOMBIINSTRUMENT VDD 1012
Coding: 0017401
Shop #: WSC 00391 067 57207
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105922036E
Coding: 3D0F0300079001
Component: IMMO VDD 1012
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2302
Coding: 0000693
Shop #: WSC 12345 111 45799
VCID: 36353567F44DD8FABDF-8062
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 140 3201
Revision: 00H20000
Shop #: WSC 00288 210 98634
VCID: 34310F6FE231CAEA83B-8060
000 - - - MIL ON
Mileage: 580821 km
Time: 01:35:45
Battery Volts: 12.1 V
DD
Temperature: 17.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 4F8A000080008505481A0D0011C0
VCID: 79AFFE5B85D3F78210D-802C
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000693
VCID: 372B3863F34721F2A69-8062
End----------(Elapsed Time: 00:48, VBatt start/end: 12.0V/12.0V)-----------
Mileage: 580821 km
Time: 01:34:33
Voltage: 11.86 V
Voltage: 11.86 V
Voltage: 11.86 V
Voltage: 11.86 V
