Heater doesn't work on older Passat or A4
Jef
HQ
Starting to get these phone calls, so may as well put this up....
The problem as described by the customer:
No or low heat output. May work fine while driving, but very little heat when engine is at idle.
The reason:
Clogged heater core. This is a very common issue with the older Passat (3B) and A4 (8E). The heater core will get a build up of "mineral deposits" in it, this reduces the flow through the heater core, so there is a lot less surface area actively exchanging heat.
The solution:
The boring details:
  • Run full a full Auto-Scan.
  • Clamp off the 2 hoses going to the heater core and remove them.
  • Blow air through the heater core to empty it out as best you can.
  • Get 2 hoses to fit to the heater core and fill the heater core up with CLR.
  • Let soak for 2 hours or more.
  • Flush heater core out with garden hose.
  • If you think it needs it, do a second CLR soak, then garden hose flush.
  • Fill heater core with 50/50 coolant (G12 or G12 Plus).
  • Secure heater hoses back to heater core.
  • Profit.
I like it! The equivalent of EZ-OFF for heater cores! :cool:
