Volkswagen scirocco: folding mirrors when car is locked
renato06
Italy
C?ID=596204
Hello to everybody, i recently buyed a hex-v2 cable cause i wanted to active folding mirrors while the car is locked, but when i try to enter the access code in module 42 to unlock the adaption function the ballon with code didn't show, is there a way to fix this? thanks to everybody for the reply. Below you can find the car auto scan that i made with vcds:
Wednesday,23,October,2024,15:36:33:46594
VIN: WVWZZZ13ZEV016613   License Plate: PLAIN-TEXT
Mileage: 171530km-106583mi   Repair Order:
Chassis Type: 13-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 55 56 65 77
VIN: WVWZZZ13ZEV016613   Mileage: 171530km-106583miles
37-Navigation -- Status: Not registered 0011
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 AN    HW: 03L 907 309 R
   Component: R4 2.0l TDI   H25 9979
   Revision: 42H25---    Serial number:                CVN: 37418DB8
   Coding: 00190012040400080000
   Shop #: WSC 64424 182 00000
   ASAM Dataset: EV_ECM20TDI01103L906018AN 003012
   ROD: EV_ECM20TDI01103L906018AM_003_VW36.rod
   VCID: 76B23E76184C5D9A757-8022
   VINID: 9E69EAAAA043A959800461810C1F3511D8
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 743B40F5492300002E1102E5921C0042A1000053
   Shop #: WSC 00020 790 00000
   VCID: 7EA2265630FC15DA2D7-802A
03543 - Mechanical Malfunction in Suspension
                    Reset counter: 8
                    Mileage: 171008 km
                    Date: 2019.02.08.
                    Time: 16:36:15
                    Count: 2
                    Count: 4096
                    Count: 16389
                    Count: 42496
                    Count: 767
   Part No SW: 3AA 907 044 BQ    HW: 3AA 907 044 BQ
   Component: Climatronic   H05 0505
   Revision: 00001K02
   Coding: 001000C002
   Shop #: WSC 00020 999 00000
   VCID: 005E58AE4A88632A5FB-8054
   Part No SW: 5K0 937 087 AB    HW: 5K0 937 087 AB
   Component: BCM PQ35 H    122 0173
   Revision: BE122001
   Coding: 68190A3FF83A2A04C08800C0750049E44FF50A88736D8520648860040040
   Shop #: WSC 00020 790 12345
   VCID: 75B0397A05CA56827CD-8020
   Subsystem 1 - Part No SW: 1K8 955 119 H    HW: 1K8 955 119 H  Labels: 1KX-955-119.CLB
   Component: WWS364 120214  24  0654
   Coding: 044D9D
   Component: RLS 030314 05  54  0403
   Coding: 0730ED
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 L    HW: 1K0 919 475 L
   Component: PARKHILFE     006 1806
   Revision: 00006000    Serial number: 0 263 004 450
   Coding: 108001
   VCID: 3B24EF42636EC0F24A9-806E
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0G AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D065ZG6
   Coding: 0012359
   VCID: 6FBC0B126B966C52B61-803A
   Subsystem 1 - Serial number: 6332MSME411D7A1AI
   Subsystem 2 - Serial number: 6342MSME411E04343
   Subsystem 3 - Serial number: 6352QSME433E584CU
   Subsystem 4 - Serial number: 6362QSME463E346CU
   Part No SW: 5K0 953 521 DP    HW: 5K0 953 569 AG
   Revision: FF010042    Serial number: 20140305101539
   Coding: 108A040000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA0215A3D7A0EC234D-8028
   Coding: 820000
   Part No SW: 1K8 920 874 D    HW: 1K8 920 874 D
   Component: KOMBI         H04 0809
   Coding: 171F01
   Shop #: WSC 00020 999 12345
   VCID: 3632FE7658CC1D9AB57-8062
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 010314F1002178
   Coding: 354000
   VCID: 7BA42F4223EE00F20A9-802E
00469 - Infotainment Databus in Single Wire Operation
                    Fault Status: 00101011
                    Reset counter: 251
                    Mileage: 170796 km
                    Date: 2019.01.28.
                    Time: 13:59:46
01304 - Radio
                    Fault Status: 00110100
                    Reset counter: 251
                    Mileage: 170796 km
                    Date: 2019.01.28.
                    Time: 11:44:09
                    Mileage: 167683 km
                    Date: 2018.08.01.
                    Time: 01:11:48
   Component: IMMO          H04 0809
   VCID: 6A8A1A065CF4897AE1F-803E
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H06 2680
   Revision: AB001001    Serial number: VWZ6Z7K7077008
   Coding: 04000402040000A200
   Shop #: WSC 12345 123 61029
   VCID: 2E02D616A01C255AFD7-807A
03138 - Input AUX IN
                    Reset counter: 29
                    Mileage: 92800 km
                    Date: 2019.11.16.
                    Time: 15:45:56
01523 - Microphone for Telephone (R38)
                    Fault Frequency: 142
                    Reset counter: 245
                    Mileage: 92800 km
                    Date: 2019.11.16.
                    Time: 15:46:02
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2161
   Coding: 0021559
   VCID: 3928F54A6552F2E2585-806C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   Component: EZE_2         H55 1642
   Coding: 01030100
   VCID: 6FBC0B1267966C52B61-803A
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 406300092575
   Coding: 000005
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0021814
   VCID: 3A2AEA466054F9FA51F-806E
   Part No: 8P0 907 357 K
   Coding: 0000015
   VCID: 42DA92A60884B13A09F-8016
                    Reset counter: 29
                    Mileage: 92800 km
                    Date: 2019.11.16.
                    Time: 15:45:56
                    Reset counter: 245
                    Mileage: 92800 km
                    Date: 2019.11.16.
                    Time: 15:46:02
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           122 0821
                    Mileage: 167683 km
                    Date: 2018.08.01.
                    Time: 01:08:45
                    Fault Status: 01100101
                    Mileage: 167683 km
                    Date: 2018.08.01.
                    Time: 01:08:45
   Part No SW: 7P6 035 730 P    HW: 7P6 035 730 P
   Component: TELEFON       H15 4217
   Revision: 1B001001    Serial number: 00007665820632 Dataset Number: 7P6035730P  0001
   Coding: 0A00000000000001
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3FDC9B5277F6DCD2661-806A
          B104F 13 [00001000] - Short to GND
                    Reset counter: 251
                    Mileage: 170796 km
                    Date: 2024.09.06.
                    Time: 16:17:47
          B104E 13 [00001000] - Short to GND
                    Reset counter: 251
                    Mileage: 170796 km
                    Date: 2024.09.06.
                    Time: 16:17:47
0022 - Radio
          U1066 00 [00001000] - No Communication
          [Steuergerät Radio (RNS): kein Signal/Kommunikation]
                    Reset counter: 251
                    Mileage: 170796 km
                    Date: 2024.09.06.
                    Time: 16:17:49
End----------(Elapsed Time: 01:15, VBatt start/end: 12.1V/12.1V)-----------
What instructions are you trying to follow? I don't think your door control modules support Adaptation.
renato06
Italy
C?ID=596204
in this video you can find all the information that you need:
i followed every step but when i try to insert the access security code the ballon didn't appear so i can't unlock adaption function and modify the parameter that i need.
here you can find another video that show us that coding is possible but i don't know if they did it with vag or not:
The first video has very different, much newer door control modules than the ones in your car that use the UDS protocol, which yours do not.
The second video shows nothing useful at all.
renato06
Italy
C?ID=596204
could be a stupid point of view but i saw in the module of tire pressure (i don't rember the excat number now) i can insert a code to unlock adaption,. So the tire pressure module is newer than 42 electric driver module? if i can't unlock this function with vag do you know another way to do that kile the second video that i posted?
AINils
Germany (AIB)
C?ID=56975
If car is equipped with UDS controller you can do it with VCDS in PQ36 cars.
If it is CAN (TP2.0) you have to modify EEPROM, which isn't possible with VCDS.
The Second variant is yours ;-) So not possible with VCDS in this case
renato06
Italy
C?ID=596204
Ok thanks a lot to both of us for your answers, so it easy and worthy to modify EEPROM to add this function? And do you know a way to do that?
