Resolved 2016 VW Sharan ACC fault
Resolved
Marnus18t
C?ID=599832
Good day all,
I’m experiencing an issue with my ACC system where the car goes into limp mode, losing power, and I have to pull over. After turning the car off and on, the ACC works again on the second try. This problem seems to occur mostly during acceleration, but it feels quite random.
I’ve already unplugged and cleaned the connectors (no corrosion on the wires), and I’ve cleaned the emblem and the camera. Sometimes the fault appears on a short 5km drive, while other times it doesn’t occur even on a 500km drive.
Any help would be greatly appreciated.
Thursday,24,October,2024,11:45:57:19130
VIN: WVWZZZ7NZGV234070   License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 25 2B 42 44 46 4C 4F
          52 53 55 5F 61 62 6C 6D 72 A5 BE BF
VIN: WVWZZZ7NZGV234070   Mileage: 149450km-92863miles
6C-Back-up Cam. -- Status: Malfunction 1010
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-DEDA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 BC    HW: 06K 907 425 C
   Component: R4 2.0l TFS   H13 1444
   Revision: --H13---    CVN: 700547C2
   Coding: 001D00BA2464010A3000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TFS02006K906071BC 001002
   ROD: EV_ECM20TFS02006K906071BC_VW36.rod
   VCID: 6D86CF0C7D1555C284D-8038
   VINID: 9E69EAAAA1DEA979820C400700342981F3
Readiness: 0010 0001
   Part No SW: 02E 300 064 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4906
   Revision: 06253104    Serial number: 00001601180957
   Shop #: WSC 44551 111 44551
   VCID: 1576C7EC39853D029CD-8040
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CG    HW: 5N0 614 109 CG
   Component: ESC-EBC460iV1 H10 0013
   Serial number: A013AQY
   Coding: 12F0449A2923C2700877480722C39443103917F8F00B4983
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 72BCDC70642B8A3A59F-8026
0335 - Databus
          [MSG_MO1_STA_BREMSE_INVALID]
                    Reset counter: 221
                    Mileage: 149446 km
                    Date: 2024.10.24.
                    Time: 09:03:55
                    Additional_Codes: 18 C0 00 0E CF 7F 00 68 02
                    DTC: 00 01 4F
                    Additional2: 00 05 01 00 05 22 83 00 83 00
   Part No SW: 5K0 959 434 F    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1202
   Revision: 00093000    Serial number: 0393977488
   Coding: 03100C
   Shop #: WSC 00020 999 39850
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 38282E5842D7206AA7B-806C
   Part No SW: 7N0 907 044 AN    HW: 7N0 907 044 AN
   Component: Clima-Sharan  H03 0606
   Revision: 00001K05
   Coding: 021010C449
   VCID: 7CA0F248366FCC4A033-8028
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0183
   Revision: BC122001
   Coding: 40590A3FE937E1C0508804C8B40011FC03D50008676D2DB2E4808720A2C9
   VCID: 45D657AC05A54D822CD-8010
   Subsystem 1 - Part No SW: 7N1 955 119 B    HW: 7N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS428 151215  024 0644
   Serial number: 15121403014631
   Coding: 004DBD
   Component: RLHS  037 0059
   Serial number: S5Y16M02D12H11M11S09
   Coding: 0228BB
Address 10: Park/Steer Assist (J791)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475 E    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0005
   Serial number: 000305183616039 Dataset Number: V03935219XN 0001
   Coding: 0071161051
   ASAM Dataset: EV_EPHVA3CVW428GP00 001005
   ROD: EV_EPHVA2CVW428GP00.rod
   VCID: 3D263F4C6DF5054274D-8068
13637426 - Databus
                    Reset counter: 221
                    Mileage: 149446 km
                    Date: 2024.10.24.
                    Time: 09:03:55
13637427 - Databus
          [Bremsensteuergerät - ESP_02.ESP_Status_ESP_PLA - Fehlerspeicher auslesen]
                    Mileage: 149446 km
                    Date: 2024.10.24.
                    Time: 09:04:00
   Part No SW: 7N0 907 572 B    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0120
   Serial number: 17021604381531
   Coding: 00001100FE0739
   ASAM Dataset: EV_ACCBEGVW361 001005
   ROD: EV_ACCBEGVW361.rod
   VCID: 3536276C55C5DD02BCD-8060
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 221
                    Mileage: 149446 km
                    Date: 2024.10.24.
                    Time: 09:03:55
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 14.6 V
                    Vehicle speed: 17.63 m/s
                    Acceleration: 0.49 m/s²
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 221
                    Mileage: 149446 km
                    Date: 2024.10.24.
                    Time: 09:03:55
                    Acceleration: 0.51 m/s²
1043 - Automatic Distance Control
          B10E7 F0 [00001000] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 221
                    Mileage: 149446 km
                    Date: 2024.10.24.
                    Time: 09:03:55
                    Voltage terminal 15: 14.5 V
                    Vehicle speed: 17.56 m/s
                    Acceleration: 0.50 m/s²
   Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Component: VW10Airbag102 H15 0016
   Serial number: 003PWP2CE6H7
   Coding: 003032
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 40D846B81A0768AA1FB-8014
   Serial number: 3493ETS60F8D3681CDDG
   Serial number: 3503ETS60740D6A1CDD
   Serial number: 3513ETS60DC6F691CDDH
   Serial number: 3523ETS606B0D6A1C9D%
   Serial number: 35540TS609C28CE1B9D%
   Part No SW: 5K0 953 569 AK    HW: 5K0 953 569 AK
   Revision: --X01---    Serial number: 20220926200127
   Coding: 1112C40008
   Shop #: WSC 58401 004 1048576
   VCID: 015E83BC518DA1A2505-8054
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 0221603234100340AE1B
   Coding: 2D0000
   Part No SW: 7N0 920 880 H    HW: 7N0 920 880 H
   Component: KOMBI         H04 1008
   Coding: 140F010800
   Part No: 7N0 963 271 D
   Component: Zuheizer        051 3042
   Revision: 00051000    Serial number: 09031871000000
   Coding: 0000041
   Shop #: WSC 00020 790 00000
   VCID: 3536276C5945DD02BCD-8060
   Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1673
   Revision:   H56       Serial number: 140216F1001115
   Coding: 468032
   Shop #: WSC 12345 560 110255
   VCID: 76B4E06008C3961A757-8022
                    Fault Status: 00110100
                    Reset counter: 218
                    Mileage: 149378 km
                    Date: 2019.03.16.
                    Time: 11:12:29
   Component: IMMO          H04 1008
   Coding: 000007
   VCID: 6A8CC4104CFB42FAE1F-803E
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000026006010
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 313E137CA1ADF122E05-8064
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H05 0561
   Revision:             Serial number: 0000186072505
   Coding: 01152E20D000411011
   Shop #: WSC 00020 790 12345
   VCID: 49CE5B9C29BDA9E2C85-801C
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.324 1401
   Revision: 1BH04739    Serial number: 00160290206501
   Coding: 0000258
   VCID: 41DE43BC1D8D61A2105-8014
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1673
   Coding: 050B0100
   VCID: 6FBAD5047799A7D2B61-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H05 0561
   Revision:             Serial number: 0000186084354
   Coding: 01152C20DE00411011
   VCID: 48C85E9832B750EAD7B-801C
02119 - Potentiometer for Vertical Mirror Adjustment
                    Fault Status: 00101100
                    Reset counter: 221
                    Mileage: 149454 km
                    Date: 2019.03.17.
                    Time: 09:16:59
   Component: AFS-ECU       H05 0111
   Coding: 058200104F000200
   VCID: 372A2D644FC92F12AE1-8062
   Subsystem 1 - Part No: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H22 0245
   Serial number: VWZAZ2S8265642 Dataset Number: V03935240VJ 0001
   Coding: 02240801FF00000011110001000808001F0100D400200100CF
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2018E638FA4748AA7FB-8074
   Subsystem 1 - Part No SW: 5NA 919 866 R    HW: -----------
   Component: ECE AS 19/20  --- 1115
   Component: Batt.regelung H56 1673
   Coding: 032F7859
   VCID: 71BED37C61ADB122A05-8024
   Component: J367-BDM  H07 0180
   Serial number: 43039516521491524557
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 L    HW: 7N0 959 794 H
   Component: TSG HL        H03 0561
   Revision:             Serial number: 0000185989184
   Coding: 01006C200000411001
   VCID: 4CC0628826CFBCCAF33-8018
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 011300012201000300
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428_VW36.rod
   VCID: 30381678AAA7F82AEFB-8064
10489856 - No Basic Setting
          B2010 00 [00001001] - -
                    Reset counter: 171
                    passive
Address 6D: Trunk Elect. (J605)       Labels:| 7N0-959-107.clb
   Part No SW: 7N0 959 107 G    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0250
   Revision: 41011001    Serial number: 028602193
   Coding: 0733334002
   ASAM Dataset: EV_HDSGVW428 201138
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 3B22315473E10B724A9-806E
   Component: TSG HR        H03 0561
   Revision:             Serial number: 0000185989185
   Part No SW: 3Q0 980 654 C    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0023
   Serial number: 28011611K21771 Dataset Number: V03935224JT 0001
   Coding: 000402080000040100261304C080400080000E100040
   Shop #: WSC 00020 999 12345
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 16021297
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 16021816
   ROD: EV_AST.rod
End----------(Elapsed Time: 02:06, VBatt start/end: 12.0V/12.0V)-----------
Marnus18t
C?ID=599832
I wouldn't expect an ACC fault to cause a power loss?
What faults have you cleared from your ECU?
Thanks for your response. I haven't cleared any fault codes yet. It's a bit confusing for me because I initially assumed the engine was going into limp mode and disabling the ACC. However, the scan shows 01-Engine -- Status: Malfunction 0010, but no actual fault code is displayed.
I'm considering disconnecting the battery for a week, driving the car until the error reappears, and hopefully, that will trigger the engine fault code to show.
davisev5225
C?ID=263265
Has this vehicle been "tuned" (e.g. is it running modified ECU software)?
Marnus18t
C?ID=599832
Not that I am aware of, and the power does not seem to be more than the stock 220PS. What is the stock boost so that I can verify?
davisev5225
C?ID=263265
MVB or Advance Measure Values should show you "specified" boost pressure and "actual" boost pressure. "Specified" is what the ECU is commanding, "actual" is what is being measured by the sensor(s).
TTT
C?ID=547002
Seen this before, just move focus somewhere else.
Marnus18t
C?ID=599832
This morning, I logged the car to check if it might be tuned. The outside temperature was about 10°C, and I was in 3rd gear. Comparing the actual vs. requested boost pressure, it showed a peak of around 1.38 bar, which seems normal.
I also attempted a readiness test, but it got stuck and didn’t complete. The Oxygen Sensor(s) and Catalytic Converter(s) failed or showed as incomplete. So, I’m now considering replacing the Oxygen Sensor(s).
I have a couple of questions:
  1. How many Oxygen Sensors are there?
  2. If the sensors are faulty, why isn’t there an error code stored in the ECU?
karldietmann
C?ID=339222
Your engine's SW is 1444. The most current one is 3069. I'd perform the SW update and see if the problem prevails.
Marnus18t
C?ID=599832
Can VCDS perform a software update, or is that only possible with dealer tools or would an independent shop be able to update the software I’m new to the Netherlands, so any advice would be greatly appreciated.
davisev5225
C?ID=263265
ODIS with online access to VW's file server required. It's possible that an independent shop has all that, but not likely.
Getting the 01-Engine controller flash updated to the newest level would be a good idea but I wonder if something silly is causing this intermittent issue? Perhaps buggy data from one of the wheel speed sensors or brake light switch inputs? Take note if the EPC light comes on the next time this happens.
It would be ideal to capture data when it malfunctions but in order to establish a baseline I'd run Measuring Value function control module maps on address 01-Engine and 03-ABS. Mapping instructions can be found here: https://www.ross-tech.com/vcds/tour/controller-channels-map.php
If you can do those immediately after a drive (but while stopped) I think there's a better chance of obtaining more data. If you happened to have the laptop and could capture maps while pulled over and before you restart the car when it malfunctions that would be ideal.
You can open those CSV files with Notepad, copy the contents and paste them in-between CODE tags just like the Auto-Scans. They end up looking like this at that point: https://forums.ross-tech.com/index.php?threads/40746
The hope is the maps help determine which IDE07599 Drivetrain coord: cause of shutdown in cruise cntr and ACC mode -and- IDE07904 Brake test switch / Brake light switch ADV measuring values are supported by your 01 controller in addition to what kind of data 03 supports for brake light, brake pressure and wheel speeds. In that case we may be able to point you to a few groups that can be focused on.
golfi_vend
Tartu, Estonia
C?ID=195131
For the specific update:
06K 906 071 BC ( 1444 , 1250 ) > 06K 906 071 BC ( 3069 )
and
06K 906 071 AE ( 2554 , 2369 , 0677 ) > 06K 906 071 AE ( 3179 )
You should check TSB 2043400/1 , but in short it addresses fault code P102F00 torque limitation because of fuel pressure / symptom: 15357
Marnus18t
C?ID=599832
Here’s an update on the issue: I ordered some parts from VW to try and resolve the readiness problem. I replaced the mechatronics seal after noticing a small oil leak and changed the gearbox oil along with all the correct seals and filter. I also replaced the upstream oxygen sensor. However, the readiness test still fails, so I’m wondering if the downstream sensor is faulty or if the car’s catalytic converter has been removed. I’ll check when I have time.
This weekend, I went on a 200km drive, and the car ran perfectly—no signs of limp mode at all. My next steps are to replace the downstream oxygen sensor (if the catalytic converter is still in place) and to make an appointment with VW to update the control modules. I’ll also ask them to perform the basic settings for the backup camera.
dnoermann
C?ID=358118
Probably i am a bit late to the Party.
But the error chain i see is:
1. ABS/ESP is unhappy
0335 - Databus
2. Because of 1. than ACC is unhappy, too.
NEtech
Denmark
C?ID=56995
Don't know if it has impact on ACC,
but have you or somebody activated Byte 16 Bit 7 for [A5] ?
You car has PR-7Y0 (No lane change assistant).
Marnus18t
C?ID=599832
This must have been me, I activated Lane Keep Assist and likely enabled Lane Change Assist in the process. I’m planning to retrofit Blind Spot Monitoring and enable Lane Change Assist in the future.
It’s worth noting that the car was going into limp mode even before I activated Lane Keep Assist.
How far are You from @iichel?
I’ll reach out to @iichel to see if they can assist.
0335 - Databus
Thank you! I’ve checked and thoroughly cleaned all the wheel speed sensors to address the ABS/ESP problem but did not fix the problem.
dnoermann
C?ID=358118
MO1_Sta_Bremse is not related to the Wheelspeed Sensors.
Here is the German explanation: "Eingriffswunsch (ASR oder MSR) vom Bremsen-Steuergerät (ABS) kann nicht ausgeführt werden, weil im Motorsteuergerät ein statischer Fehler vorliegt oder die Funktion durch die Applikation abgeschaltet ist Fehlerstatus Brems-Momenteneingriff"
In short English: ABS requests Engine Power reduction, but Engine does have an internal Error and can not do it, so updating the ECU Software is the best guess to solve this.
Marnus18t
C?ID=599832
I have an update regarding the ACC fault. I contacted my local VW dealer, and they confirmed that the car has been tuned since 2022. Because of this, they’re unable to perform the ECU update. I’ve requested that they flash the car back to stock and am currently waiting for their response.
In the meantime, is anyone able to assist with flashing the car back to stock and resolving this issue? After some research, it seems like vagtechniek.nl might be able to help.
