2014 Audi A3 8v Mechatronic, Basic Setting failed when executing
Fuhrer69
Cayman Islands
C?ID=592574
Hello all any assistance would be greatly appreciated. Mechatronics unit replaced, due to no communication with engine control unit car. Car would start some time when cleared DCT but would not shift
After replace mechatronics unit engine star fine but upon execution of basic setting and 004 obtain start engine basic settings default 0025.
Tuesday,22,October,2024,00:18:45:25254
Dealer/Shop Name: Elite Automotive
VIN: WAUZZZ8V1E1007636   License Plate: JOHN
Mileage: 120260km-74726mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 57 5F 6C
VIN: WAUZZZ8V1E1007636   Mileage: 120260km-74726miles
Address 01: Engine (J623-CXSA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 CF    HW: 04E 907 309 A
   Component: 1.4l R4 TSI   H08 5669
   Revision: WAH08---    CVN: B8994C34
   Coding: 02250032236401083000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM14TFS01104E906016CF 002003
   ROD: EV_ECM14TFS01104E906016CF.rod
   VCID: 688E617262F5F12AF7B-803C
   VINID: 9D196AAAA2260550400071831871BEE90A
Readiness: 1110 0001
   Part No SW: 0CW 300 045 M    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H45 4530
   Revision: 00045014    Serial number: CU502101175464 CVN: 0000048F
   Shop #: WSC 04940 001 00001
   ROD: EV_TCMDQ200021.rod
   VCID: 43D496DE3B13F272029-8016
21210 - Gear Selector 3
          P176C 00 [00001000] - Cannot be Regulated
                    Mileage: 120260 km
                    Date: 2024.10.21
                    Time: 23:55:33
                    Engine RPM: 10559.75 /min
                    Engine torque: 920 Nm
                    Vehicle speed: 255 km/h
                    Control Module temperature: 215 °C
                    CURRENT pressure: -10.0 bar
                    selected gear: GANG_6
                    Driving position: N
                    Accelerator pedal position: 100.0 %
                    DTC memory status: 65280
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 61333000000596
   Coding: 13F18AA224201273017D060341C929C851244880608294F2F82150080508
   ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
   VCID: 7CA62D22066D4D8A033-8028
   Revision: 00021000    Serial number: 0194122228 Dataset Number: 8V0909577C  0009
   Coding: 030C0C
   VCID: 3A2AEB3A4CD9B3BA51F-806E
   Part No SW: 8V0 820 043     HW: 8V0 820 043
   Component: AC Automat    H13 0032
   Revision: 20024000    Serial number: 00000000148387
   Coding: 03100004110000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   VCID: 6FBC0A6E471B2612B61-803A
   Humidity sensor: exterior:
   Serial number: 3658CAC6000000000001
   Part No SW: 5Q0 937 085 Q    HW: 5Q0 937 085 Q
   Component: BCM MQBAB HNA H14 0112
   Serial number: 00011325200933 Dataset Number: 8V0909514C  0063
   Coding: 07011A42C24122FD41A04004001807080800000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 47CC82CE0F2BDE52DE1-8012
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 130802  041 0585
   Serial number:         130816031613
   Coding: 0A47F7
   Serial number: 21700616
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 23 05 2013  00000332
          B1263 01 [00001000] - Electrical Failure
                    Reset counter: 149
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 12.6 V
                    Outside temperature: 30.0 °C
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231323502897 Dataset Number: 8V0909526C  0034
   Coding: 0070150051
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 3B24EE3E43E38AB24A9-806E
13637426 - Databus
                    Reset counter: 149
                    Mileage: 120260 km
                    Date: 2024.10.19
                    Time: 16:37:23
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H04 0150
   Serial number: 12081376511016 Dataset Number: 8V1909863A  0006
   Coding: 023C1101FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   VCID: 3530F80665C75CC2BCD-8060
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 149
                    Mileage: 120260 km
                    Date: 2024.10.19
                    Time: 16:37:23
                    Control Module temperature: 52 °C
                    Voltage terminal 15: 11.6 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 149
                    Mileage: 120260 km
                    Date: 2024.10.19
                    Time: 16:37:23
1078 - Databus
          [FAULT_CIS_SAS_INIT]
                    Reset counter: 149
                    Mileage: 120260 km
                    Date: 2024.10.19
                    Time: 16:37:23
1050 - Transmission in Limp Mode
          P305B 00 [00001000] - -
                    Reset counter: 150
                    Mileage: 120260 km
                    Date: 2024.10.21
                    Time: 23:28:19
                    Control Module temperature: 44 °C
                    Voltage terminal 15: 13.4 V
1043 - Automatic Distance Control
          B10E7 F0 [00001000] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 149
                    Mileage: 120260 km
                    Date: 2024.10.19
                    Time: 16:37:23
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Serial number: 003MMR006ZUG Dataset Number: 8V0909602D  0006
   Coding: 98FCC000000000005C54000000C800000065
   VCID: 005E59D26A85296A5FB-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 002 908 13
   Serial number: 35767000000D88ECDD0N
   Subsystem 2 - Part No SW: -----------    HW: 480 002 908 13
   Serial number: 35867000000F68ECDD0O
   Subsystem 3 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3516502A51088B10C24+
   Subsystem 4 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3526502AD1088B14D2CK
   Subsystem 5 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3556502BB10EDE43A2CZ
   Part No SW: 8V0 953 521 AD    HW: 5Q0 953 549
   Revision: --------    Serial number: 19071308491677 Dataset Number: ----------
   Coding: E018
   ROD: EV_SMLSKLOMQB_009.rod
   Part No SW: 8V0 920 870 J    HW: 8V0 920 870 J
   Component: KOMBI         H03 2212
   Coding: 278419182E80000C0F80E800000000
   VCID: 42DA93DA2409FB7A09F-8016
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2147
   Revision: --------    Serial number: 09091310800952 Dataset Number: 8V0909515C  0044
   Coding: 030100042B0864005B000258180B00000001000000000000000000000000
   GVL: 01543C0000000600400C90000002C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 009011
   ROD: EV_GatewConti_009.rod
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 B    HW: 8U0 951 528 B
   Serial number: 04 09 2013  A1249909
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051045613
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000184909002
   Coding: 0900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73B4061E2B3302F2529-8026
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 14091304081508 Dataset Number: 8V0909872D  0025
   Coding: 00101E205C01040000001003
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 3FDC9A2E57FB9692661-806A
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000476142
   Coding: 0D0000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Dataset Number: 8V0909852F  0015
   Coding: 01
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D20E0265DF7848274D-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 13091306071317 Dataset Number: 8V0909873D  0024
   Coding: 001016205E01040000001003
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 3E22E72A50F19F9A6D7-806A
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000611735
   Coding: 150000
589843 - Window Regulator; Front Passenger Side
          B1320 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 108
                    Mileage: 120260 km
                    Date: 2024.10.20
                    Time: 12:32:00
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865F  0032
   Coding: 019E000001000000
   VCID: 75B0380625471CC27CD-8020
Address 57: TV Tuner (R78)       Labels:| 8V0-919-DTV-V1.clb
   Part No SW: 8V0 919 129 K    HW: 8V0 919 129
   Component: JP-DTV        H09 1380
   Coding: 01011C0000000100000000
   ASAM Dataset: EV_TVMELC 001033
   ROD: EV_TVMELC_VW37.rod
   VCID: 48CE81F20235D12AD7B-801C
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 034 E    HW: 8V0 035 034
   Component: MU-H-TN-JP    H41 0271
   Serial number: K5F AW73X0074I Dataset Number: 8V2909545C  0027
   Coding: 01730106FF00000021330001001200102F000126010001007E
   ASAM Dataset: EV_MUHig4CAW7 001060
   ROD: EV_MUHig4CAW7.rod
   VCID: 323AC31A94A94BFA99F-8066
   Subsystem 1 - Part No SW: V03 959 800 ET    HW: -----------
   Component: JPN 2013/2014  --- 7127
   Multimedia System 1:
   Subsystem 2 - Part No SW: 8V0 919 604 A    HW: 8V0 919 604 A
   Component: DU High  H49 0014
   Serial number: AUZ8Z9DG500DYC
   Control module for chip card reader:
   Subsystem 3 - Part No SW: 8V0 919 813     HW: 8V0 919 813
   Component: DSRC UNIT  H04 0001
   Serial number: 502020007102
   Traffic data antenna:
   Subsystem 4 - Part No SW: 8V0 035 504 A    HW: 8V0 035 504 A
   Component: VICS Antenna  H03 0001
   Serial number: 503050009504
   Subsystem 5 - Part No SW: 8V0 919 614 G    HW: 8V0 919 614 G
   Component: ControlUnit_H  H74 0764
   Serial number: C1000003071300020202
   Compact disc data bank:
   Subsystem 6 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 2006
1024 - Interface for External Media Devices (MEDIA-IN)
          B1288 13 [00001001] - Open Circuit
                    Reset counter: 106
                    Mileage: 120260 km
                    Date: 2024.10.19
                    Time: 16:37:26
                    Voltage terminal 30: 11.9 V
   Part No SW: 5Q0 907 441     HW: 5Q0 907 441
   Component: MQB RVC Mid   H06 0120
   Dataset Number: 8V0909460C  0016
   Coding: 027300060201000300
   ROD: EV_2CamSysRearPASE_AU37.rod
End----------(Elapsed Time: 01:30, VBatt start/end: 12.3V/12.2V)-----------
Dr Sheldon
Windsor UK
C?ID=334979
Fix that first - Basic Settings will NOT do that for you !!
Where di the Mechatronic come from ??
Is it fitted Correctly ??
Is the gearbox Broken Internally ??
Fuhrer69
Cayman Islands
C?ID=592574
Thanks much for your response... Part was source from retailer in Europe, I sent my old part and they replace part..I reach out to their technical support, they told me to reset align fork and try again I'm in the process of getting that done, will post update.
Fuhrer69
Cayman Islands
C?ID=592574
I have since remove mechatronics unit align shift fork to neutral position adjust shifter actuator to 25mm ambient temperature 38C execute basic setting basic setting fail. Code in TCM P1701... The mechatronics unit is part of the component protect list and will need to be adapted to the immobilizer... Question Can VCDS perform this service!
Westbury, UK
Component Protection removal requires online access to the VAG servers, so needs to be done by either a dealer or an independent with online access.
Fuhrer69
Cayman Islands
C?ID=592574
Ok, thanks i appreciate the the feedback
