bhmadams
I'm seeking assistance with some ongoing issues with my Volkswagen. Here’s a summary of what has happened:
The left headlight was cracked and water damaged the modules, which prompted me to begin repairs. I replaced the cracked left headlight with an exact match. Additionally, I replaced the following modules, which were also exact matches to what I previously had:
8V0 907 399 B LIGHT-CONTROL-MODULE-MAX
7PP.941.572.AB LED LEIMO MAX
After replacing the headlight and modules, I attempted to recode and reprogram the new modules using VCDS. However, I have been encountering several errors, including issues accessing the BCM (Body Control Module) and adapting the left headlight module.
This is also giving an ERROR code and will not let me see the long code: 0 - 5Q0 937 087 AS - BCM PQ37BOSCH 034 0243
Any ideas on what I could be missing? Thanks in advance.
Sunday,20,October,2024,12:13:01:62394
VCDS Version: 24.7.1.0 (x64) HEX-NET CB: 0.4643.4
VIN: 3VV4B7AX5JM015514 License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 36 39 3C 42 44
47 4B 52 5F 6C 6D 75 A5 BB BC CA D6 D7
VIN: 3VV4B7AX5JM015514 Mileage: 102128km-63459miles
01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 29-Left Light -- Status: Malfunction 0010 2B-Steer. Col. Lock -- Status: OK 0000 36-Seat Mem. Drvr -- Status: Malfunction 0010 39-Right Light -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 47-Sound System -- Status: OK 0000 4B-Multifunc. Module -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 75-Telematics -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: OK 0000 BB-Door Rear Drv -- Status: OK 0000 BC-Door Rear Pass -- Status: OK 0000 CA-Sunroof -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: Malfunction 0010 D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DGUA) Labels:. 06L-907-115-V1.clb
Part No SW: 5NA 907 115 K HW: 06L 907 309 B
Component: R4 2.0l TFSI H30 0004
Revision: 1DH30000 CVN: A6B5901D
Coding: 012A00122466010FB4000000000000000000000000000000
Shop #: WSC 03325 444 00000
ASAM Dataset: EV_ECM20TFS0115NA907115K 001004
ROD: EV_ECM20TFS0115NA907115K.rod
VCID: 46C045CDF95457A6B1-8012
VINID: 0E698448746815A7400451411078365EA2
Readiness: 1010 1101
Address 02: Auto Trans (J217) Labels: 09P-927-749-V1.clb
Part No SW: 09G 927 158 DT HW: 09G 927 158
Component: AISIN AQ8 206 3698
CVN: 2408AAFC
Coding: 0002000100000000000000000000000000000000
Shop #: WSC 00066 790 00447
ROD: EV_TCMAQ450031_VW37.rod
VCID: 085C8BF5B3C081D683-805C
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 51517000000673
Coding: 0BFA6BA454211B71C57C0301A2C749D0D62AD8A3C045927C38415058C2AA4200002864121A1C230935351919323200
Shop #: WSC 01383 790 50316
VCID: 77BEF809CE3EFE2EFA-8022
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0442319791 Dataset Number: V03935260TY 0001
Coding: 132C2C0723
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E302D2DA1840F66F9-806A
Subsystem 1 - Part No SW: 3G0 962 243 A HW: 3G0 962 243 A
Component: GEB.F.Heckoef H17 0903
Serial number: 98166045
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NN 907 044 K HW: 5NN 907 044 K
Component: AC Automat H35 R552
Revision: 20K08000 Serial number: 00000D00012223
Coding: 00020024200118001105010C1211140E
ASAM Dataset: EV_ACClimaPrehVW37X 002025
VCID: 54E46F853F08F5363F-8000
Humidity sensor: exterior:
Part No SW: 5Q0 937 087 AS HW: 5Q0 937 087 AP
Component: BCM PQ37BOSCH 034 0243
Revision: -------- Serial number: C8640306170046 Dataset Number: V03935295SK 0001
ROD: EV_BCMBOSCH_018.rod
VCID: 0C54B7E5A7B8EDF6A7-8058
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 170616 034 0373
Serial number: 17061521054330
Component: RLHS 042 0105
Serial number: S9Y17M04D26H18M54S19
Coding: 00A8DD
Humidity sensor: interior:
566550 - Databus
[LCM links - unplausibler Datensatz]
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 11:59:31
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: operated
Voltage: 13.2 V
Outside temperature: 24.0 °C
Copy
568086 - Databus
[LCM links - Blinker defekt]
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 11:59:31
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 13.2 V
Copy
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617125 Dataset Number: V03935265MW 0001
Coding: 0471655811
VCID: 4BD674F9E236AACE6E-801E
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Dataset Number: V03935265DD 0001
Coding: 320000C158FF8728749C8145304097
ROD: EV_ACCMRRCONTIVW376_002_VW37.rod
Part No SW: 5Q0 959 655 AG HW: 5Q0 959 655 AG
Component: AirbagVW21 004 0336
Serial number: 003NUM05KYHP Dataset Number: V03935261SZ 0001
Coding: 8CCCFC00000000005000001AC20800000065
VCID: 054282C184D29CBEF8-8050
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000007DLNH+
Coding: 303352
Subsystem 2 - Part No SW: ----------- HW: 480 002 005 17
Serial number: 35700000000A2C401427
Subsystem 3 - Part No SW: ----------- HW: 480 002 005 17
Serial number: 358000000002D0B8942M
Subsystem 4 - Part No SW: ----------- HW: 480 401 805 17
Serial number: 3510001AD25A698423C8
Subsystem 5 - Part No SW: ----------- HW: 480 401 805 17
Serial number: 3520001C72502B26C43Y
Subsystem 6 - Part No SW: ----------- HW: 480 403 005 17
Serial number: 3550001A525DA8B41636
Subsystem 7 - Part No SW: ----------- HW: 480 403 005 17
Component: FrontSensor_P 000 6149
Serial number: 3560001A525DA8B2169B
Part No SW: 5Q0 953 507 JF HW: 5Q0 953 549 D
Component: Lenks. Modul 004 0140
Revision: -------- Serial number: 22051704401338
Coding: 0C10
ROD: EV_SMLSKLOMQB_018_VW37.rod
VCID: 03469CD98AE6A28ED6-8056
Part No SW: 5NA 920 891 B HW: 5NA 920 891 B
Component: KOMBI 407 3193
Coding: 0BA4041AEF88CF0502886B0B54010000A0000000
VCID: 43C65CD9CA66628E96-8016
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 30061700840490 Dataset Number: V03935258SJ 0001
Coding: 030500347F085900FB07225A1E0F00010001070000000000000000000000
GVL: 01D63C000800060040DC80008002C80010000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 33260C199AC6D20E06-8066
Generator:
Subsystem 2 - Part No SW: 5NN 959 442 A HW: 5NN 959 442 A
Serial number: 1401700535500095BO2B
Coding: 2E0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 7256073804
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Serial number: HA1-00030.03.17 Dataset Number: v1260x015G0 0000
Coding: 0101
VCID: 4AD871FDED4CB3C655-801E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45C242C1C4525CBEB8-8010
0019 - Headlamp Type
C119F 00 [00001001] - Implausible
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 09:54:08
0658 - Sensor for Swivel Module Position
C11F6 29 [00001001] - Signal Implausible
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 09:54:09
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000120779003
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71AAC611A05AA01E34-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0021
Serial number: Y0006QCU12426
Coding: 0010000000000500018280808080000000008101000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
VCID: 3C342725B7981D76D7-8068
9655636 - Motor for Seat Fore/Aft Adjustment
B1355 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 10:07:59
9655892 - Motor for Seat Backrest Adjustment
B1356 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 10:07:59
9655380 - Motor for seat height adjustment
B1354 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 10:07:59
9655124 - Motor for Seat Tilt Adjustment
B1353 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 10:07:59
9654868 - Motor for Lumbar Support Fore/Aft Adjustment
B1352 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 10:07:59
10489856 - No Basic Setting
B2010 00 [00001001] - -
[keine oder falsche Grundeinstellung/Adaption]
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 10:07:59
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0445093252 Dataset Number: V03935258DF 0001
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D322A21AC82147EE0-8068
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0444196628
Coding: 020111
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0032
Serial number: 5028717100266 Dataset Number: V03935259YZ 0001
Coding: 003F1B205200028000000000
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 47DE48C9FE5E4EAE4A-8012
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0001716731 Dataset Number: V03935253WG 0001
Coding: 01000011004001
ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
VCID: 40CC53D5DB7079968B-8014
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Revision: 00000001 Serial number: VWZ8Z1HBA03L07$ Dataset Number: V03935265HV 0001
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
VCID: 6D92DA61BC6244FE10-8038
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 04061700840679 Dataset Number: V03935260VN 0001
Coding: 0000000501001D5200210F01090000000000000000000000000000000000
VCID: 72A8C91DA55C9B06CD-8026
66678 - Databus
U1123 00 [10001001] - Received Error Message
[LCM_Datensatz_Fehler_L received error value]
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 09:54:08
66824 - Databus
[LCM_DKL_L_defekt_Fehler received error value]
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 09:54:09
66881 - Databus
[LED_L_falsch_codiert received error value]
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 09:54:08
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0032
Serial number: 6028717000096 Dataset Number: V03935259Z0001
Coding: 003F13205E00028000000000
ROD: EV_DCUPasseSideEWMAXKLO.rod
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 851 0842
Serial number: Dataset Number: V03935264UK 0001
Coding: 027306020000000051220002001808001F0500E401200405C6
ROD: EV_MUStd4CDELP_VW26.rod
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHT1782308
Subsystem 2 - Part No SW: 3G0 919 866 BH HW: -----------
Component: NAR 2017/18 --- 0620
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 09:54:46
Voltage terminal 30: 14.6 V
SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
SDARS_tuner_status_2-Audio Signal: available.
SDARS_tuner_status_2-Antenna current: 107 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
Copy
Part No SW: 5Q0 907 556 B HW: 5Q0 907 556
Component: Areaview 2 H13 0607
Serial number: C854707JG013941 Dataset Number: V03935265JZ 0001
Coding: 01230601A20F20000000400C
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
VCID: 383C3B3583A0315633-806C
Part No SW: 5Q0 959 107 M HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0261
Revision: -------- Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Dataset Number: V03935260AS 0001
Coding: 0A28
Shop #: WSC 00066 790 00443
VCID: 42C859DDD57C6B869D-8016
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0570
Dataset Number: V03935263QC 0001
Coding: 02230602C2823A037F1E06020000
ROD: EV_OCULowMQB.rod
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 10051711P12491 Dataset Number: V03935265PJ 0001
Coding: 0003070601020201002213548150490084000E200120
Address BB: Door Rear Drv
Part No SW: 5Q4 959 595 E HW: 5Q4 959 595 B
Component: TSG HBFS 012 0032
Serial number: 0000253664445 Dataset Number: V03935262CX 0001
Coding: 002011200101028000000000
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
ROD: EV_DCURearPasseMAXKLO.rod
VCID: 49DA4EF1E84AB8DE5C-801C
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 013 0005
Dataset Number: V03935262KL 0001
Coding: 00804073260C
ROD: EV_SunRoofCONTIAU736_006.rod
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
Dataset Number: 8W0909471A 0005
VCID: 1660D58DE974272601-8042
Reset counter: 229
Mileage: 102128 km
Date: 2024.10.20
Time: 10:03:47
Component: LED1R H09 0003
End----------(Elapsed Time: 02:15, VBatt start/end: 13.3V/13.3V)-----------
