Maps 2014 AUDI A3 Limousine (8VS, 8VM) S3 quattro, 2.0 TFSI
Maps
Gaz@VDS
Lincolnshire, UK
C?ID=592224
AutoScan: WAUZZZ8V8F1029358
Sunday,20,October,2024,15:40:40:49859
Dealer/Shop Name: VDS
VIN: WAUZZZ8V8F1029358   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 47 52 55
          57 5F 6C A9 BB BC
VIN: WAUZZZ8V8F1029358   Mileage: 91836km-57064miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CJXF)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---    CVN: 3675C1CE
   Coding: 0A1D00322466010B3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259A 001006
   ROD: EV_ECM20TFS0208V0906259A.rod
   VCID: 3E22E73820FB99CA6D7-806A
   VINID: 9D196AAAA2262160400890C5200542629A
21388 - Valve for Exhaust Flap 1 (N321)
          P3019 00 {00101111} - Open Circuit
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:50
                    Engine RPM: 1629.00 /min
                    Normed load value: 69.8 %
                    Coolant temperature: 31 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.480 V
                    Engine: operating status: PL
                    STATE_LS_SAE{1}: OL_CDN
                    T_AST_SAE: 1 s
                    MAP_MES_SAE: 102 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 45.312500 %
                    FUP_H_SAE: 6880.0 kPa
21399 - Valve for Exhaust Flap 2 (N322)
          P3023 00 {00101111} - Open Circuit
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:50
                    T_AST_SAE: 1 s
14961 - Oxygen (Lambda) Sensor B1 S1
          P0133 00 {11101101} - Response too Slow
                    Mileage: 90112 km
                    Date: 2024.08.29
                    Time: 15:58:14
                    Engine RPM: 1527.50 /min
                    Normed load value: 24.7 %
                    Vehicle speed: 50 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 13.242 V
                    STATE_LS_SAE{1}: CL
                    FAC_LAM_LIM{1}: 0.723 %
                    Lambda probes actual: bank1: 0.9922
                    TEG_DYN_LS_UP{1}: 531.0375 °C
                    Lambda probe ageing: bank 1: dynamic factor: 1.6768
                    TTIP_MES_LS_UP{1}: 785.0000 °C
15072 - Engine Start Blocked by Immobilizer
          P1570 00 {00100000} - -
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4932
   Revision: 05852204    Serial number: TFK01405121372 CVN: 0000BC3B
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1F1C3ABC8731F0C2461-804A
10657 - RPM Signal from ECU
          P0726 00 {00000010} - Implausible Signal
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 61394000000457
   Coding: 31F193A254222A75017A070541CB698CC92A5480E08296F6F84150880608
   ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
   VCID: 46D28FD8782BC10A257-8012
   Revision: 00021000    Serial number: 0336423852 Dataset Number: 8V0909577C  0009
   Coding: 030C0C
   VCID: 3A2AEB283CD3B5EA51F-806E
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000339139
   Coding: 03100014110000011000000000001500
   VCID: 3334C60C1BB944A2929-8066
   Humidity sensor: exterior:
   Serial number: 82680137000000000001
   Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
   Component: BCM MQBAB HNA H18 0134
   Serial number: 01011414200476 Dataset Number: 8V0909514G  0079
   Coding: 07151C46C24106FD01804004B11807A80800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7AAA2B287C5375EA11F-802E
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140503  041 0585
   Serial number:         140512201738
   Coding: 0A47F7
   Serial number: 22694962
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
   Serial number: 28 03 2014  00000702
   Serial number: 000000000ZY141181MJA
   Serial number: 00000000000029946206
   Sunroof control module:
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO3007321X
   Coding: 901E00
16650 - Bulb 2 for Rear Left Turn Signal
          B12CE 15 {00001000} - Open or Short to Plus
                    Reset counter: 214
                    Mileage: 91180 km
                    Date: 2024.09.29
                    Time: 15:47:38
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 13.2 V
                    Outside temperature: 13.5 °C
204290 - Remote key 1
          B1479 18 {00001000} - Current Too Low
                    Reset counter: 215
                    Mileage: 90326 km
                    Date: 2024.09.07
                    Time: 14:42:43
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.0 V
                    Outside temperature: 27.0 °C
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 {00001000} - Alert Emergency Activation Stage 1
                    Reset counter: 238
                    Mileage: 91730 km
                    Date: 2024.10.16
                    Time: 19:16:41
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.5 V
                    Outside temperature: 14.5 °C
721416 - Switch for Sunroof
          B13C4 29 {00001000} - Signal Implausible
                    Reset counter: 218
                    Mileage: 90098 km
                    Date: 2024.08.29
                    Time: 15:24:54
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.9 V
                    Outside temperature: 18.0 °C
721420 - Switch for Sunroof
          B13C4 01 {00001000} - Electrical Failure
                    Reset counter: 218
                    Mileage: 90098 km
                    Date: 2024.08.29
                    Time: 15:24:54
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.9 V
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331414502175 Dataset Number: 8V0909526D  0038
   Coding: 0070150011
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 42DA93C85403FD2A09F-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 M    HW: 5Q0 907 567 M
   Component: ACC3          H10 0398
   Serial number: 20051403070391 Dataset Number: 8V0909863C  0013
   Coding: 023E1301FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 45D088D4452DCA122CD-8010
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 C    HW: 8V0 907 376 B
   Component: DAEMPFUNGS-SG H08 0066
   Serial number:       120514000 Dataset Number: 8V0909554C  0012
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
   VCID: 41D89CC45105E632105-8014
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Serial number: 003MMR01FLG+ Dataset Number: 8V0909602D  0008
   Coding: 98FCC000000000005C54000000C800000065
   VCID: 005E59C01A8F2F3A5FB-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 002 805 14
   Serial number: 357670000008F124EF01
   Subsystem 2 - Part No SW: -----------    HW: 480 002 805 14
   Serial number: 358670000009F124EF03
   Subsystem 3 - Part No SW: -----------    HW: 480 402 205 14
   Serial number: 3516502A7142B1D1313-
   Subsystem 4 - Part No SW: -----------    HW: 480 400 805 14
   Serial number: 3526502B1157E9E231FK
   Subsystem 5 - Part No SW: -----------    HW: 480 401 504 14
   Serial number: 3556502A31529DF4239G
   Part No SW: 8V0 953 521 CR    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 02061408490315
   Coding: E018
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 0C467DF026C77B5A333-8058
   Part No SW: 8V0 920 871 G    HW: 8V0 920 871 G
   Component: KOMBI         H02 4291
   Coding: 278D181A3E80AE000181E8001000000000000000
   Shop #: WSC 12345 123 61029
   VCID: 40DE99C05A0FEF3A1FB-8014
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 21051410801424 Dataset Number: 8V0909515E  0055
   Coding: 030100042F085A005B0002789C0B00000001010000000000000000000000
   GVL: 01D43C1000000600400C90000002CC0000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_011.rod
   Generator:
   Serial number: 8710083603
8782081 - ROD - Unknown Error Code
          - 00 {00001001}
                    Reset counter: 200
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:34
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00012.05.14 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   Revision: 00000000    Serial number: 14000129799002
   Coding: 5D00000000000000
   VCID: 3436C5101EB7439A8B3-8060
   Serial number: 16051401101961 Dataset Number: 8V0909872E  0030
   Coding: 005D1E205C01040000001003
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Dataset Number: 8V0909852G  0018
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3530F81415CD5A92BCD-8060
   Part No SW: 8V0 035 465 D    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0420
   Serial number: AUZ8ZAEN900CSED Dataset Number: 8V0909510B  0016
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 3928F42439D5BEF2585-806C
   Serial number: 24051402090421 Dataset Number: 8V0909873E  0029
   Coding: 005D16205E01040000001003
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 3FDC9A3C27F190C2661-806A
65558 - Heated Exterior Mirror
          B11F8 14 {00001001} - Open or Short to Ground
                    Reset counter: 147
                    Mileage: 90480 km
                    Date: 2024.09.15
                    Time: 07:46:59
   Component: AFS-ECU       H01 0091
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865J  0037
   Coding: 01A600002B200200
   Subsystem 1 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7530
   Coding: E00100
   Subsystem 2 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7530
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7040
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7040
   Coding: E00100
5545009 - LED Headlamp Power Output Stage; Left
          B149C 31 {00001000} - No Signal
                    Reset counter: 233
                    Mileage: 90281 km
                    Date: 2024.09.05
                    Time: 17:14:30
5544753 - LED Headlamp Power Output Stage; Right
          B149B 31 {00001000} - No Signal
                    Reset counter: 229
                    Mileage: 91254 km
                    Date: 2024.10.04
                    Time: 14:06:50
Address 57: TV Tuner (R78)       Labels:| 8V0-919-DTV-V1.clb
   Part No SW: 8V0 919 129 A    HW: 8V0 919 129
   Component: JP-DTV        H10 0990
   Coding: 01011C0000000100000000
   ASAM Dataset: EV_TVMELC 001033
   ROD: EV_TVMELC_VW37.rod
   Part No SW: 8V0 035 034 J    HW: 8V0 035 034
   Component: MU-H-N-EU     H42 0404
   Serial number: K5F AW7CC016ZZ Dataset Number: 8V2909545E  0040
   Coding: 017301010000000021110102000A02102F000226010001007E
   ASAM Dataset: EV_MUHig6C3AW7 001115
   ROD: EV_MUHig6C3AW7.rod
   VCID: 372CF21C0FC1A882AE1-8062
   Subsystem 1 - Part No SW: V03 959 802 SS    HW: -----------
   Component: ECE 2023/2024  --- 0330
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9EY2011Q1
   Subsystem 3 - Part No SW: 8V0 919 614 AA    HW: 8V0 919 614 AA
   Component: ControlUnit_H  H81 0816
   Serial number: C1000017051400020064
   Compact disc data bank:
   Component: Gracenote  --- 2008
1598 - Data Set Implausible
          B2012 00 {00001001} - -
          {Control module (data record download) - implausible data record for visible MMI system languages}
                    Reset counter: 120
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:37
                    Voltage terminal 30: 12.4 V
          U1014 00 {00001001} - -
                    Reset counter: 120
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:38
          B201A 00 {00001001} - -
          {Check software version management}
                    Fault Frequency: 39
                    Reset counter: 200
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:39
                    Status_Software_Version_Management-module_name: MFC1H37xA/HRAS
          B2000 87 {00001001} - Missing Message
                    Reset counter: 120
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:48
                    Voltage terminal 30: 12.2 V
                    Software module: status-SW_Status_Consistency: 00 00 03
                    Software module: status-SW_Status_Device: Dsp
   Dataset Number: 8V0909460C  0016
   Coding: 027300060201000300
   ROD: EV_2CamSysRearPASE_AU37.rod
   VCID: 303EC900EAAF7FBAEFB-8064
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 140513200182
   VCID: 7DA020346D7D42D234D-8028
0006 - Actuator for Structural Accoustics
          P193A 00 {00001001} - Open Circuit
                    Fault Frequency: 11
                    Reset counter: 200
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:34
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0025
   Serial number: 22051402091104 Dataset Number: 8V0909897C  0017
   Coding: 004D16204001040000001002
   ROD: EV_DCURearDriveMAXKLO.rod
   Component: TSG HBFS      020 0025
   Serial number: 22051402091102 Dataset Number: 8V0909896C  0017
   ROD: EV_DCURearPasseMAXKLO.rod
End----------(Elapsed Time: 14:54, VBatt start/end: 11.9V/14.7V)-----------
blockmap-01-8V0-906-259-A_WAUZZZ8V8F1029358-20241020-1527.CSV
;SW:8V0-906-259-A   HW:06K-907-425-B ---  Engine
;Component:2.0l R4 TFSI  H13 0004, Coding:0A1D00322466010B3004
;EV_ECM20TFS0208V0906259A,001006,EV_ECM20TFS0208V0906259A.rod
;Sunday,20,October,2024,15:27:49:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 3E22E73820FB99CA6D7-806A
Group,Description,Actual
IDE00018,Voltage terminal 15,14.238, V
IDE00019,Voltage terminal 30,14.589, V
IDE00021,Engine RPM,766, /min
IDE00025,Coolant temperature,74, °C
IDE00078,Time since engine start,125, s
IDE00083,Throttle valve position (absolute),12.2, %
IDE00084,Absolute load value,18, %
IDE00085,Normed load value,17.3, %
IDE00086,Accelerator pedal position,14.5, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00102,Control Module temperature,34.0, °C
IDE00148,Mean injection time,1.0, ms
IDE00149,Ignition angle of current cylinder: actual value,4.50, °
IDE00150,Pressure in brake servo unit,1.150, bar
IDE00151,Oil fill level,68, mm
IDE00155,Ignition timing angle retard cylinder 1,0.00, °
IDE00156,Ignition timing angle retard cylinder 2,0.00, °
IDE00157,Ignition timing angle retard cylinder 3,0.00, °
IDE00158,Ignition timing angle retard cylinder 4,0.00, °
IDE00167,Exhaust temperature 1 bank 1,214.6, °C
IDE00172,A/C compressor torque,0.00, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,0.0, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,0.0, °
IDE00178,Camshaft adjustment intake bank 1: specified value,15.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,14.7, °
IDE00182,Camshaft adaptation intake bank 1: phase position,1.1, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-0.3, °
IDE00186,Fuel low pressure: actual value,5.010, bar
IDE00187,Coolant temperature at engine start,57.7, °C
IDE00188,Fuel high-pressure: actual value,45.9, bar
IDE00189,Activation of fuel pump electronics,54.44, %
IDE00190,Charge air pressure: specified value,0.798, bar
IDE00191,Charge air pressure: actual value,1.002, bar
IDE00192,Coolant temperature at radiator outlet: actual value,22.1, °C
IDE00193,Coolant temperature at engine outlet: specified value,75.0, °C
IDE00194,Coolant temperature at radiator output: specified value,-48.0, °C
IDE00195,Coolant temperature difference between engine and radiator,51.7, °C
IDE00196,Engine oil temperature,59.0, °C
IDE00199,Mean engine air mass,9, kg/h
IDE00200,Average vehicle speed,0.00, km/h
IDE00201,High fuel pressure: specified value,50.0, bar
IDE00202,Low fuel pressure: specified value,5.000, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00348,Intake air temperature,32, °C
IDE00349,Throttle valve position: normed,2.0, %
IDE00350,Air mass: specified value,10, kg/h
IDE00355,Cruise Control System (CCS): status,passive,
IDE00357,Fuel temperature,58.5, °C
IDE00358,Limitation: torque,426.2, Nm
IDE00371,Fuel consumption,0.89, l/h
IDE00375,Generator: load signal,45.18, %
IDE00380,Coolant fan 1: activation,10.16, %
IDE00381,Coolant fan 2: activation,0.00, %
IDE00392,Accelerator pedal: sensor voltage 1,0.728, V
IDE00393,Accelerator pedal: sensor voltage 2,0.386, V
IDE00396,Charge air pressure actuator: acknowledgment,3.589, V
IDE00400,Intake manifold Runner Control (IMRC): activation,100.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,100.00, %
IDE00404,Throttle valve: activation,13.98, %
IDE00405,Crankshaft speed (RPM),747, /min
IDE00406,Camshaft RPM,707, /min
IDE00407,Rail pressure regulation: status,Control operation,
IDE00408,Engine mount 1,not active,
IDE00409,Engine mount 2,not active,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,00,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416,Starter control: terminal 50 feedback,01,
IDE00417,Starter control: shut-off conditions 1,00 01,
IDE00451,Currently running routine,Unknown (0)
IDE00472,Mean injection quantity,8, mg/stroke
IDE00474,Ambient air pressure,100, kPa abs
IDE00476,Fuel Metering Valve,0.00, %
IDE00477,Torque request: sum of auxiliary aggregate,7.2, Nm
IDE00478,Engine-drag torque,10.6, Nm
IDE00482,Limitation: torque of clutch protection,1024.0, Nm
IDE00495,Calculated oil temperature,60.0, °C
IDE00496,Oil pressure switch valve activation,Low pressure,
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00556,Outside temperature,15, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.998 Lambda / -0.023 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.200, V
IDE00582,Specified value of equivalence ratio,0.989, Lambda
IDE00583,Throttle valve specified value,2.0, %
IDE00584,Distance driven since erasing DTC memory,1794, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,1539, km
IDE00588,Fuel tank fill level,100.0, %
IDE00589,Fuel pressure,4470, kPa rel
IDE00592,Status of oxygen sensor control,Closed loop,  / using O2 sensors
IDE00593,Ignition timing adjustment cylinder 1,2.5, Degrees
IDE00594,Absolute intake pressure,30, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,0.0, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00603,Number of driving cycles since erasing DTC memory,80,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,7.1, %
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE01076-MAS00109,Time since ignition off-Hours,0, H
IDE01076-MAS00110,Time since ignition off-Minutes,0, min
IDE01076-MAS00111,Time since ignition off-Seconds,0, s
IDE01098,Test of knock sensors: short trip result,Test not started,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.000,
IDE01266,Coolant shut-off valve,closed,
IDE01369,Intake manifold runner control (IMRC): offset closed,0.004, V
IDE01377,Throttle valve adapter: actual value,2.4, °
IDE01378,Fuel high pressure: control deviation,4.3, bar
IDE01385,Wear index,0.00000070,
IDE01405-MAS05513,Starter activation: status-Bit 0,OK,
IDE01405-MAS05514,Starter activation: status-Bit 1,Before starter activation,
IDE01405-MAS05515,Starter activation: status-Bit 2,After starter activation,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01649,Throttle valve position 1,0.615, V
IDE01650,Throttle valve position 2,13, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test not started,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test not started,
IDE01670,Short trip status for oil pressure control,Test not started,
IDE01671,Starter control: clutch switch,depressed,
IDE01672,Starter control: automatic start,not possible,
IDE01673-MAS05513,Starter control: readiness bits-Bit 0,Mechanical test of starter complete,
IDE01673-MAS05514,Starter control: readiness bits-Bit 1,Test of starter relay switching contacts not complete,
IDE01673-MAS05515,Starter control: readiness bits-Bit 2,Test of starter relay activation complete,
IDE01673-MAS05516,Starter control: readiness bits-Bit 3,Test of terminal 50R return measuring line completed,
IDE01673-MAS05517,Starter control: readiness bits-Bit 4,Test of starter request double injection complete,
IDE01673-MAS05518,Starter control: readiness bits-Bit 5,Test of PN signal not complete,
IDE01673-MAS05519,Starter control: readiness bits-Bit 6,Test of interlock switch complete,
IDE01673-MAS05520,Starter control: readiness bits-Bit 7,Test of clutch pedal switch complete,
IDE01677,Result: oxygen sensor test operational readiness B1 downstream CAT,Test not started,
IDE01683-MAS05304,Valve stroke switch of AVS from small to large-Cylinder 1,switched,
IDE01683-MAS05305,Valve stroke switch of AVS from small to large-Cylinder 2,switched,
IDE01683-MAS05306,Valve stroke switch of AVS from small to large-Cylinder 3,switched,
IDE01683-MAS05307,Valve stroke switch of AVS from small to large-Cylinder 4,switched,
IDE01683-MAS05308,Valve stroke switch of AVS from small to large-Cylinder 5,switched,
IDE01683-MAS05309,Valve stroke switch of AVS from small to large-Cylinder 6,switched,
IDE01683-MAS05310,Valve stroke switch of AVS from small to large-Cylinder 7,switched,
IDE01683-MAS05311,Valve stroke switch of AVS from small to large-Cylinder 8,switched,
IDE01684-MAS05304,Valve stroke switch of AVS from large to small-Cylinder 1,switched,
IDE01684-MAS05305,Valve stroke switch of AVS from large to small-Cylinder 2,switched,
IDE01684-MAS05306,Valve stroke switch of AVS from large to small-Cylinder 3,switched,
IDE01684-MAS05307,Valve stroke switch of AVS from large to small-Cylinder 4,switched,
IDE01684-MAS05308,Valve stroke switch of AVS from large to small-Cylinder 5,switched,
IDE01684-MAS05309,Valve stroke switch of AVS from large to small-Cylinder 6,switched,
IDE01684-MAS05310,Valve stroke switch of AVS from large to small-Cylinder 7,switched,
IDE01684-MAS05311,Valve stroke switch of AVS from large to small-Cylinder 8,switched,
IDE01685,Result of test of valve stroke switch AVS,Test not started,
IDE01773,Misfire totalizer,3,
IDE01774,Status misfire recognition,not active,
IDE01776,Misfires per 1000 revolutions of cylinder 2,3,
IDE01870,Oxygen sensor after catalytic converter: operating status,Bank 1: sensor 1 OK,
IDE01873,Test of catalytic converter: measured value,1.992,
IDE01874,Test of catalytic converter: result,Test not started,
IDE01876,Adaptation of loss torque,1.3, Nm
IDE01878,Adaptation of throttle valve,Test of closing springs ended,
IDE01880,Accelerator pedal position 2,15.3, %
IDE01881,Adaptation of kick-down shifting point,4.126, V
IDE01884,Camshaft adjustment intake bank 1: activation,36.38, %
IDE01886,Number of high pressure incursions,0,
IDE01894,Charge press. ctrl.: adapt. higher than max. threshold,1.37, %
IDE01895,Charge pressure control: less than min. threshold adaptation,0.00, %
IDE01901,Lost torque adaptation: idle,3.2, Nm
IDE01905,Average of ignition timing angle delay adjustment,18.75, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,-0.37, °
IDE01912,Oxygen sensor B1: sensor 1: specified value,0,
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,1280,
IDE01922,Vehicle distance driven,91836, km
IDE01923,Control module distance driven,91681, km
IDE01924,Load shift flaps: actual value,closed,
IDE01925,Load shift flaps: specified value,closed,
IDE01926,Adaptation of intake manifold runner flaps,Cancel: prerequisites have not been met,
IDE01928,Close cam shaft angle at quantity control valve,0.4, °
IDE01929,Open cam shaft angle at quantity control valve,0.0, °
IDE01931,High pressure pump injection volume control deviation,-4, mg/stroke
IDE01932,High pressure pump injection volume,-4, mg/stroke
IDE01975,Numb.of misfir.: cylinder 1,0,
IDE01976,Numb.of misfir.: cylinder 2,3,
IDE01977,Numb.of misfir.: cylinder 3,0,
IDE01978,Numb.of misfir.: cylinder 4,0,
IDE01986,Contact for tank leak test,Open,
IDE02116,Exhaust gas temperature before catalytic converter,329.6, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02229,Exhaust gas temperature sensor 1,1110.0, °C
IDE02756,Number of manual engine starts,2327,
IDE02757,Number of automatic engine starts,1582,
IDE03108,Result of test of oxygen sensors bank 1,Test not started,
IDE03189-MAS00106,Number of prevented stop processes (statistics)-Year,2000,
IDE03189-MAS00106,Number of prevented stop processes (statistics)-Year,2064,
IDE03189-MAS00107,Number of prevented stop processes (statistics)-Month,13,
IDE03189-MAS00107,Number of prevented stop processes (statistics)-Month,0,
IDE03189-MAS00107,Number of prevented stop processes (statistics)-Month,9,
IDE03189-MAS00108,Number of prevented stop processes (statistics)-Day,0,
IDE03189-MAS00108,Number of prevented stop processes (statistics)-Day,17,
IDE03189-MAS00108,Number of prevented stop processes (statistics)-Day,19,
IDE03189-MAS00108,Number of prevented stop processes (statistics)-Day,11,
IDE03189-MAS00109,Number of prevented stop processes (statistics)-Hours,0,
IDE03189-MAS00109,Number of prevented stop processes (statistics)-Hours,10,
IDE03189-MAS00109,Number of prevented stop processes (statistics)-Hours,1,
IDE03189-MAS00109,Number of prevented stop processes (statistics)-Hours,26,
IDE03189-MAS00110,Number of prevented stop processes (statistics)-Minutes,0,
IDE03189-MAS00110,Number of prevented stop processes (statistics)-Minutes,31,
IDE03189-MAS00110,Number of prevented stop processes (statistics)-Minutes,24,
IDE03189-MAS00110,Number of prevented stop processes (statistics)-Minutes,23,
IDE03189-MAS00111,Number of prevented stop processes (statistics)-Seconds,21,
IDE03189-MAS00111,Number of prevented stop processes (statistics)-Seconds,55,
IDE03189-MAS00111,Number of prevented stop processes (statistics)-Seconds,54,
IDE03189-MAS00111,Number of prevented stop processes (statistics)-Seconds,0,
IDE03189-ENG102773,Number of prevented stop processes (statistics)-Brake vacuum,1,
IDE03189-ENG159504,Number of prevented stop processes (statistics)-Bremsunterdruck km Stand,86056, km
IDE03189-ENG159468,Number of prevented stop processes (statistics)-Bremsunterdruck Zähler,1,
IDE03189-ENG159389,Number of prevented stop processes (statistics)-Gemischadaption km Stand,91813, km
IDE03189-ENG159510,Number of prevented stop processes (statistics)-Gemischadaption Zähler,1488,
IDE03189-ENG102617,Number of prevented stop processes (statistics)-Mixture adaptation,4,
IDE03189-ENG98900,Number of prevented stop processes (statistics)-Poor start detection,3,
IDE03189-ENG102190,Number of prevented stop processes (statistics)-Regeneration Mode,5,
IDE03189-ENG159385,Number of prevented stop processes (statistics)-Regenerationsbetrieb km Stand,0, km
IDE03189-ENG159392,Number of prevented stop processes (statistics)-Regenerationsbetrieb Zähler,0,
IDE03189-ENG159558,Number of prevented stop processes (statistics)-Schlechtstarterkennung km Stand,0, km
IDE03189-ENG159461,Number of prevented stop processes (statistics)-Schlechtstarterkennung Zähler,0,
IDE03189-ENG98917,Number of prevented stop processes (statistics)-Sporadic function prevention,2,
IDE03189-ENG159349,Number of prevented stop processes (statistics)-Sporadische Funktionsverhinderung km Stand,91777, km
IDE03189-ENG159450,Number of prevented stop processes (statistics)-Sporadische Funktionsverhinderung Zähler,78,
IDE03189-ENG99013,Number of prevented stop processes (statistics)-Umgebungsluftdichte,0,
IDE03189-ENG159435,Number of prevented stop processes (statistics)-Umgebungsluftdichte km Stand,0, km
IDE03189-ENG159516,Number of prevented stop processes (statistics)-Umgebungsluftdichte Zähler,0,
IDE03190-MAS00106,Number of requested start processes (statistics)-Year,2000,
IDE03190-MAS00106,Number of requested start processes (statistics)-Year,2064,
IDE03190-MAS00107,Number of requested start processes (statistics)-Month,0,
IDE03190-MAS00107,Number of requested start processes (statistics)-Month,9,
IDE03190-MAS00108,Number of requested start processes (statistics)-Day,0,
IDE03190-MAS00108,Number of requested start processes (statistics)-Day,15,
IDE03190-MAS00109,Number of requested start processes (statistics)-Hours,0,
IDE03190-MAS00109,Number of requested start processes (statistics)-Hours,17,
IDE03190-MAS00110,Number of requested start processes (statistics)-Minutes,62,
IDE03190-MAS00110,Number of requested start processes (statistics)-Minutes,0,
IDE03190-MAS00111,Number of requested start processes (statistics)-Seconds,47,
IDE03190-MAS00111,Number of requested start processes (statistics)-Seconds,0,
IDE03190-ENG102773,Number of requested start processes (statistics)-Brake vacuum,2,
IDE03190-ENG159504,Number of requested start processes (statistics)-Bremsunterdruck km Stand,77184, km
IDE03190-ENG159468,Number of requested start processes (statistics)-Bremsunterdruck Zähler,7,
IDE03190-ENG102966,Number of requested start processes (statistics)-Motortemperatur zu groß,1,
IDE03190-ENG159419,Number of requested start processes (statistics)-Motortemperatur zu groß-km Stand,0, km
IDE03190-ENG159340,Number of requested start processes (statistics)-Motortemperatur zu groß-Zähler,0,
IDE03190-ENG101832,Number of requested start processes (statistics)-Motortemperatur zu klein,0,
IDE03190-ENG159365,Number of requested start processes (statistics)-Motortemperatur zu klein-km Stand,0, km
IDE03190-ENG159380,Number of requested start processes (statistics)-Motortemperatur zu klein-Zähler,0,
IDE03190-ENG159438,Number of requested start processes (statistics)-Wegfahrsperre fordert Wiederholstart,3,
IDE03190-ENG159456,Number of requested start processes (statistics)-Wegfahrsperre km Stand,0, km
IDE03190-ENG159547,Number of requested start processes (statistics)-Wegfahrsperre Zähler,0,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,-179.96, °
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.498, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.484, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.776, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.204, V
IDE03267,Intake air temperature: unconditioned voltage,1.851, V
IDE03276,Charge air pressure sensor: unconditioned voltage,1.611, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,4.023, V
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03361,Driver intention torque,23.2, Nm
IDE03362,Requested transmission torque,1024.0, Nm
IDE03375,Adaptation status of neutral position sensor,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3.448, V
IDE03582,Temperature sensor for engine temperature management,76.5, °C
IDE03583-MAS04416,Engine shut-down overrides-Sporadic function prevention,OFF,
IDE03583-MAS04417,Engine shut-down overrides-Poor start detection,OFF,
IDE03583-MAS04590,Engine shut-down overrides-Mixture adaptation,OFF,
IDE03583-MAS06089,Engine shut-down overrides-Brake vacuum,OFF,
IDE03583-MAS06602,Engine shut-down overrides-Engine temperature,OFF,
IDE03583-MAS06603,Engine shut-down overrides-Ambient pressure,OFF,
IDE03583-MAS06604,Engine shut-down overrides-Start/stop sensors:,OFF,
IDE03583-MAS06605,Engine shut-down overrides-Regeneration Mode,OFF,
IDE03584-MAS04369,Engine starting requirements-Engine temperature too high,OFF,
IDE03584-MAS04370,Engine starting requirements-Engine temperature too low,OFF,
IDE03584-MAS06606,Engine starting requirements-Brake under pressure too low,OFF,
IDE03584-MAS06607,Engine starting requirements-SCR System requires restart,OFF,
IDE03584,Engine starting requirements,OFF,
IDE03584-ENG154330,Engine starting requirements-Reserved_5,OFF,
IDE03584-ENG154188,Engine starting requirements-Reserved_6,OFF,
IDE03584-ENG154256,Engine starting requirements-Reserved_7,OFF,
IDE03585,System status for the start/stop function master,active: no release by coordinator,
IDE03586-ENG104146,Starting requirements for active participants-LF_STATE_STST_ST_REQ_ECU,0,
IDE03587-ENG102054,Stopping requirements for active participants-LF_STATE_STST_STOP_INH_ECU,8,
IDE03588-ENG101611,System malfunctions for active participants start/stop-LF_STATE_STST_ERR_ECU,0,
IDE03589-ENG118109,Error status for start-stop related sensors-Sensor_1,OFF,
IDE03589-ENG118110,Error status for start-stop related sensors-Sensor_2,On,
IDE03589-ENG118111,Error status for start-stop related sensors-Sensor_3,On,
IDE03589-ENG118112,Error status for start-stop related sensors-Sensor_4,OFF,
IDE03589-ENG118113,Error status for start-stop related sensors-Sensor_5,OFF,
IDE03589-ENG118114,Error status for start-stop related sensors-Sensor_6,OFF,
IDE03589-ENG118115,Error status for start-stop related sensors-Sensor_7,OFF,
IDE03589-ENG118116,Error status for start-stop related sensors-Sensor_8,OFF,
IDE03692-MAS05513,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,Test of camshaft adjustment bank 2 outlet not complete,
IDE03692-MAS05514,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1,Test of camshaft adjustment bank 1 outlet complete,
IDE03692-MAS05515,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2,Test of camshaft adjustment bank 2 intake not complete,
IDE03692-MAS05516,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3,Test of camshaft adjustment bank 1 intake complete,
IDE03692-MAS05517,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4,Test of knock sensor 4 not complete,
IDE03692-MAS05518,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5,Test of knock sensor 3 not complete,
IDE03692-MAS05519,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6,Test of knock sensor 2 not complete,
IDE03692-MAS05520,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7,Test of knock sensor 1 complete,
IDE03693-MAS05513,Monitoring status of additional Onboard Diagnosis-Bit 0,Test of brake light switch not complete,
IDE03693-MAS05514,Monitoring status of additional Onboard Diagnosis-Bit 1,Test of clutch switch not complete,
IDE03693-MAS05515,Monitoring status of additional Onboard Diagnosis-Bit 2,Test of idle control not complete,
IDE03693-MAS05516,Monitoring status of additional Onboard Diagnosis-Bit 3,Test of coolant temperature sensor not complete,
IDE03693-MAS05517,Monitoring status of additional Onboard Diagnosis-Bit 4,Test of throttle valve potentiometer not complete,
IDE03693-MAS05518,Monitoring status of additional Onboard Diagnosis-Bit 5,Thermostat testing not completed,
IDE03693-MAS05519,Monitoring status of additional Onboard Diagnosis-Bit 6,Test of charge pressure control complete,
IDE03693-MAS05520,Monitoring status of additional Onboard Diagnosis-Bit 7,Test of CCS switch not complete,
IDE03693-MAS05521,Monitoring status of additional Onboard Diagnosis-Bit 8,Test of oxygen adaptation bank 1 complete,
IDE03711,Mass flow through throttle valve,7, kg/h
IDE03767,Engine status,Idle,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,9.14, %
IDE03806,Oxygen sensor bank 1 sensor 1: status,1,
IDE03807,O2 Sensor B1-S2: Status,1,
IDE03816,Exhaust flap bank 1,Open,
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,328, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,35.55, %
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,306, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,30.47, %
IDE03832,Oxygen sensor B1: sensor 2: response time,0, ms
IDE03834,Oxygen sensor bank 1 sensor 2: response time filtered,0, ms
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test not started,
IDE03892,Fuel high pressure sensor: unconditioned voltage,1.141, V
IDE03918,Engine reverse rotation recognition,not detected,
IDE03919,Oxygen regulation operability and status,On,
IDE03920,Oxygen adaptation status,Condition not met,
IDE03921,Mixture adaptation factor at partial load,1.98, %
IDE03922,Mixture adaptation factor at idle speed,-2.34, %
IDE03923,Adaptive long-term value of mix. condition after cat. conv,0.00000,
IDE03924,Relay for reserve coolant pump: status,not activated,
IDE03928,Counter for fuel entry in oil,0,
IDE03930,Charge pressure actuator: operating status,Operating mode,
IDE03931,Charge pressure actuator: actual position,1.40, %
IDE03932,Charge pressure actuator: specified position,0.00, %
IDE03933,Charge pressure actuator: specified value,0.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3.638, V
IDE03935,Charge air pressure actuator: adaptation for upper stop,0.870, V
IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.98, %
IDE03957,Throttle valve angle: specified value,2.2, °
IDE03963,Low fuel pressure adaptation value for EFP,154, mbar
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,91.80, %
IDE04002,Charge air pressure control,BP_A act:99.8, kPa
IDE04405,Mixture variation in adapted part load range 1,3.30, %
IDE04409,Intake manifold pressure: corrected,0.295, bar
IDE04410,Intake manifold pressure: specified value,0.305, bar
IDE04412,Pressure upstream of throttle valve: corrected,1.002, bar
IDE04415,Oxygen sensor control factor with with pre-control correction,2.56, %
IDE04491,Temperature Sensor for Fuel Tank Leak Diagnostic,0, °C
IDE04629,AVS operating condition,Test runs,
IDE04630,AVS valve stroke position: current,AVS Stroke,
IDE04632-MAS05304,AVS error status of last switch-over standard stroke direction-Cylinder 1,OK,
IDE04632-MAS05305,AVS error status of last switch-over standard stroke direction-Cylinder 2,OK,
IDE04632-MAS05306,AVS error status of last switch-over standard stroke direction-Cylinder 3,OK,
IDE04632-MAS05307,AVS error status of last switch-over standard stroke direction-Cylinder 4,OK,
IDE04632-MAS05308,AVS error status of last switch-over standard stroke direction-Cylinder 5,OK,
IDE04632-MAS05309,AVS error status of last switch-over standard stroke direction-Cylinder 6,OK,
IDE04632-MAS05310,AVS error status of last switch-over standard stroke direction-Cylinder 7,OK,
IDE04632-MAS05311,AVS error status of last switch-over standard stroke direction-Cylinder 8,OK,
IDE04633-MAS05304,AVS error status of last switch-over AVS stroke direction-Cylinder 1,OK,
IDE04633-MAS05305,AVS error status of last switch-over AVS stroke direction-Cylinder 2,OK,
IDE04633-MAS05306,AVS error status of last switch-over AVS stroke direction-Cylinder 3,OK,
IDE04633-MAS05307,AVS error status of last switch-over AVS stroke direction-Cylinder 4,OK,
IDE04633-MAS05308,AVS error status of last switch-over AVS stroke direction-Cylinder 5,OK,
IDE04633-MAS05309,AVS error status of last switch-over AVS stroke direction-Cylinder 6,OK,
IDE04633-MAS05310,AVS error status of last switch-over AVS stroke direction-Cylinder 7,OK,
IDE04633-MAS05311,AVS error status of last switch-over AVS stroke direction-Cylinder 8,OK,
IDE04634,AVS switch-over meter for reg activation of curr. drive cycle,0,
IDE04635,AVS switch-over meter: total,34275,
IDE04636,AVS overflow meter for all switch-overs,3,
IDE04637,Engine temperature control actuator,99.75, %
IDE04638,Transmission coolant valve,closed,
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,0,
IDE04680,Oxygen sensor 1 bank 1: voltage raw value O2 signal,1.963, V
IDE04713,Active brake system status,Not operated,
IDE04814,Transmission oil cooler valve,Open,
IDE04937,Sensor for engine block temperature: raw value,-48.0, °C
IDE05140,Intake manifold pressure raw value,0.296, bar
IDE05259,Gear position sensor: raw value,0.00, %
IDE05260,Gear position sensor: current value,Intermediate position,
IDE05261,Gear position sensor: last valid value,Neutral,
IDE05262,Gear position sensor: gear position valid,invalid,
IDE05310,Charge air pressure control valve position: target value,0.00, %
IDE05311,Charge air pressure control valve position: actual value,1.40, %
IDE05312,Charge air pressure control valve uncond voltage sensor,3.5889, V
IDE05313,Charge air pressure control valve activation pulse duty factor,-9.77, %
IDE05314-ENG112584,Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ{0},00000000 ,
IDE05315,Charge air pressure control valve voltage: position closed,3.6377, V
IDE05316,Charge air pressure control valve voltage: position open,0.8701, V
IDE05317-ENG112583,Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC{0},00000000 ,
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,0.000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,0.000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,0.000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,0.000,
IDE05593,Secondary air injection sensor 1,0.375, bar
IDE05622-ENG125277,Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL,0,
IDE06006,Idle speed specified value,760, /min
IDE06192,Knock sensor: cylinder 2: voltage,0.411, V
IDE06193,Knock sensor: cylinder 3: voltage,0.375, V
IDE06194,Knock sensor: cylinder 4: voltage,0.428, V
IDE06195,Knock sensor: cylinder 1: voltage,0.414, V
IDE06296-ENG104200,Activation of oxygen control after main cat-Lambda probe 2: bank 1: status,00000000 ,
IDE06386,Oil level: static measurement,0, mm
IDE06387,Oil level: last valid dynamic value,7, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,15, mm
IDE06390,Oil level: minimum value,-1, mm
IDE06391,Oil temperature sensor 2,49.0, °C
IDE06392,Oil temperature sensor 2: raw value,49.000, V
IDE06393,Oil level: dynamic average value,7, mm
IDE06394,Sensor 1 for secondary air pressure: unconditioned voltage,0.000, V
IDE06395,Fuel low pressure sensor: unconditioned voltage,2.047, V
IDE06396,Coolant temperature at engine outlet: unconditioned voltage,1.274, V
IDE06397,Temperature sensor for engine temp. management: target value,92.3, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,1.273, V
IDE06399,Manifold absolute pressure sensor: unconditioned voltage,0.679, V
IDE06567,Frequency counter deactivate start/stop function,3048,
IDE06568,Stop prevention by driver frequency counter,6318,
IDE06569,Frequency counter vehicle standstill,18353,
IDE06573,Long-term adaptation of intake manifold injection,1.98, %
IDE06574,Long-term adaptation of intake manifold injection in idle,-0.19, mg/stroke
IDE06610,Frequency counter vehicle standstill with stop,1881,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,Yes,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,No,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC with Stop & Go,
IDE06707,CCS Switch,ACC operating unit,
IDE06709,ACC variants (coding),ACC with braking until standstill / Stop & Go,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06726,Timing deviation after chain replacement: intake bank 1,-0.31, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,-3.06, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,1.00, °
IDE06736,Timing deviation: current value exhaust bank 1,-0.56, °
IDE07001,Piston-cooling jets: activation,On,
IDE07002,Exhaust flap: activation,90.00, %
IDE07003-ENG123034,Exhaust flap bank 2: activation-PWM_EF{1},90.002, %
IDE07019,Number of ignitions direct injection,23394542,
IDE07020,Number of ignitions intake manifold injection,53293876,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,3,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07026,Misfires per 1000 revolutions of cyl. 4 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,9.072e+009, J
IDE07031,Oil pressure switch for piston-cooling jets: status,Open,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07548,Engine temp. mangmt. actuator: specified value of angle,133.75, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,134.16, °
IDE07550,Engine temp. management actuator: raw value,2151,
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Adaptation successfully finished,
IDE07553,Engine temperature management actuator: after-run stop,3960,
IDE07554,Engine temperature management actuator: stop open,138,
IDE07564,Required torque adjustment by idling regulator,1.6, Nm
IDE07571,Engine torque,13.1, Nm
IDE07572,High pressure regulation: adaptation value,-10.00, mg
IDE07574,Long-term fuel trim bank 1 at idle,-0.19, mg/stroke
IDE07575,Driver intention torque,6.0, Nm
IDE07576,Lost torque adaptation driving mode,7.2, Nm
IDE07577,Lost torque adaptation A/C compressor and driving mode,0.4, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Set,Not operated,
IDE07598-MAS00326,Cruise control switch actuation-Resume,Not operated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,Not operated,
IDE07598-MAS02310,Cruise control switch actuation-DELAY,Not operated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,Not operated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,operated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,Not operated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,operated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,Not operated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07599-MAS01505,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off,No,
IDE07599-MAS03849,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal,No,
IDE07599-MAS04795,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off,No,
IDE07599-MAS05135,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected,No,
IDE07599-MAS05136,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control,No,
IDE07599-MAS05190,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated,Yes,
IDE07599-MAS05192,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking,No,
IDE07599-MAS05196,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error,No,
IDE07599-MAS05814,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error,No,
IDE07599-MAS05815,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error,No,
IDE07599-MAS05816,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error,No,
IDE07599-MAS05817,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation,No,
IDE07599-MAS05818,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible,No,
IDE07599-MAS05819,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking,No,
IDE07599-MAS05820,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error,No,
IDE07599-MAS05821,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak,No,
IDE07599-MAS05822,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available,No,
IDE07599-MAS05823,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization,No,
IDE07599-MAS05824,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation,No,
IDE07599-MAS05825,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault,No,
IDE07599-MAS05826,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault,No,
IDE07599-MAS05827,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met,No,
IDE07599-MAS05828,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature,No,
IDE07599-MAS05829,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault,No,
IDE07599-MAS05830,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component,No,
IDE07599-MAS05831,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component,No,
IDE07599-MAS05832,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error,No,
IDE07599-MAS05833,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error,No,
IDE07599-MAS05834,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault,No,
IDE07599-MAS05835,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault,No,
IDE07599-MAS05836,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error,No,
IDE07599-MAS05837,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error,No,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07901,Error counter bad fuel,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,Not operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,Not operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,Not operated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07945-MAS00334,Status of intermittent monitoring-Catalytic converter monitoring,completed successfully,
IDE07945-MAS00335,Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature,completed successfully,
IDE07945-MAS00336,Status of intermittent monitoring-Monitoring of tank ventilation system,completed successfully,
IDE07945-MAS00337,Status of intermittent monitoring-Monitoring of secondary air system,completed successfully,
IDE07945-MAS00338,Status of intermittent monitoring-Monitoring of A/C system refrigerant,completed successfully,
IDE07945-MAS00339,Status of intermittent monitoring-Monitoring of oxygen sensor,completed successfully,
IDE07945-MAS00340,Status of intermittent monitoring-Monitoring of oxygen sensor heater,completed successfully,
IDE07945-MAS00341,Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR),not completed successfully,
IDE08071-ENG119931,Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1,0,
IDE08072-ENG119932,Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2,0,
IDE08073-ENG119933,Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3,0,
IDE08074-ENG119934,Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4,0,
IDE08075-ENG119935,Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5,0,
IDE08495,Activation radiator shutter result,0.00, %
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.694, V
ENG102981,AC compressor: speed increase,00000001 ,
ENG103860,AC request: speed increase,00000000 ,
ENG103042,Accelerator pedal sender: learned end stop,4.126, V
ENG103719,Accelerator position,0.00, %
ENG101488,ACF: load,0.00000,
ENG103474,Activation of oil pressure switching valve,00000001 ,
ENG103323,Additional water pump,00000001 ,
ENG101828,Air mass,6.31, kg/h
ENG104264,Alternator load,600, W
ENG103910,Ambient temperature,13.50, °C
ENG112539,AR_THR_AD_ADD_MMV,-0.0295, cm²
ENG98377,As,none,
ENG103165,Battery voltage,14.6, V
ENG102002,CAM_OFS_IVVT_IN{1},0.000, °
ENG112540,CAM_PHA_ENG{GES_EX}{CBK_1},0.000, °
ENG112541,CAM_PHA_ENG{GES_IN}{CBK_1},14.234, °
ENG101169,CAM_PHA_OFS_MAF{IN}{1},0.000, °
ENG112542,CAM_SP_IND_VCP{EX_1},0.000, °
ENG112543,CAM_SP_IND_VCP{IN_1},15.000, °
ENG112544,CAM_VCP{EX_1},0.000, °
ENG112545,CAM_VCP{IN_1},14.484, °
ENG103849,Cat. ageing: bank 1: actual,1.992,
ENG101785,Cat. temperature: bank 1,164.2875, °C
ENG102214,CPU_LOAD,57.5, %
ENG112546,CRK_BEG_VVL_DIAG{1},0.000, °
ENG112547,CRK_BEG_VVL_DIAG{2},0.000, °
ENG112548,CRK_BEG_VVL_DIAG{3},0.000, °
ENG112549,CRK_BEG_VVL_DIAG{4},0.000, °
ENG112550,CRK_END_VVL_DIAG{1},0.000, °
ENG112551,CRK_END_VVL_DIAG{2},0.000, °
ENG112552,CRK_END_VVL_DIAG{3},0.000, °
ENG112553,CRK_END_VVL_DIAG{4},0.000, °
ENG125189,CTR_CAM_IN_SP_PI_DET_REQ{0},1,
ENG125190,CTR_CAM_IN_SP_PI_DET_REQ{1},8,
ENG125191,CTR_CAM_IN_SP_PI_DET_REQ{2},1,
ENG125192,CTR_CAM_IN_SP_PI_DET_REQ{3},1,
ENG101127,CTR_CDN_OBD_RBM,681,
ENG114826,CTR_EDGE_CAM_EX{1},46,
ENG114827,CTR_EDGE_CAM_IN{1},49,
ENG100536,CTR_IGK_CYC_RBM,2390,
ENG125193,CTR_LAMB_SP_PI_REQ{0},1,
ENG125194,CTR_LAMB_SP_PI_REQ{1},8,
ENG125195,CTR_LAMB_SP_PI_REQ{2},1,
ENG125196,CTR_LAMB_SP_PI_REQ{3},1,
ENG112554,CTR_MIS_DC_MMV_CYL_SAE{0},2,
ENG112555,CTR_MIS_DC_MMV_CYL_SAE{1},1,
ENG112556,CTR_MIS_DC_MMV_CYL_SAE{2},1,
ENG112557,CTR_MIS_DC_MMV_CYL_SAE{3},3,
ENG112558,CTR_MIS_TOT_NVMY_SAE,12040,
ENG125197,CTR_REQ_IV_OFF_PI_FAST{0},0,
ENG125198,CTR_REQ_IV_OFF_PI_FAST{1},0,
ENG125199,CTR_REQ_IV_OFF_PI_FAST{2},0,
ENG125200,CTR_REQ_IV_OFF_PI_FAST{3},0,
ENG125201,CTR_REQ_IV_OFF_PI_SLOW{0},0,
ENG125202,CTR_REQ_IV_OFF_PI_SLOW{1},0,
ENG125203,CTR_REQ_IV_OFF_PI_SLOW{2},0,
ENG125204,CTR_REQ_IV_OFF_PI_SLOW{3},0,
ENG100764,CTR_SUM_SRV_INTL,1373.00,
ENG125205,CTR_TQI_POW_MAX_PI_REQ{0},0,
ENG125206,CTR_TQI_POW_MAX_PI_REQ{1},2,
ENG125207,CTR_TQI_POW_MAX_PI_REQ{2},0,
ENG125208,CTR_TQI_POW_MAX_PI_REQ{3},0,
ENG119929,CTR_VLD_CAT_GAP_AFL{1},0,
ENG119930,CTR_VLD_CAT_GAP_AFR{1},0,
ENG99428,CTR_VLFT_1_SWI_NOT{0},0,
ENG103626,CTR_VLFT_1_SWI_NOT{1},0,
ENG100809,CTR_VLFT_1_SWI_NOT{2},0,
ENG99336,CTR_VLFT_1_SWI_NOT{3},0,
ENG103025,CTR_VLFT_STND_SWI_NOT{0},0,
ENG100017,CTR_VLFT_STND_SWI_NOT{1},0,
ENG100438,CTR_VLFT_STND_SWI_NOT{2},0,
ENG100736,CTR_VLFT_STND_SWI_NOT{3},0,
ENG112559,CTR_VVL_LIH_ACT,1,
ENG101271,CTR_VVL_LIH_DEAC,0,
ENG100551,CTR_VVL_SWI_DC,0,
ENG99561,CTR_VVL_SWI_H,3,
ENG101173,CTR_VVL_SWI_L,34275,
ENG99084,Cycle flags: (completed cycles): cat: lambda probe heater,9,
ENG100943,Cycle flags: (completed cycles): lambda probes: EGR,0,
ENG99495,Cycle flags: (completed tests): lambda adaption:,136,
ENG103597,Cycle flags:(completed cycles):lambda probes:sec.air sys.,24,
ENG101652,Cylinder shut-off: cylinder suppression,00000000 ,
ENG102657,DIAG_INST{0},EF_EL_OC_0,
ENG99120,DIAG_INST{1},EF_EL_OC_1,
ENG103260,DIAG_INST{2},DYN_LS_UP_1,
ENG99710,DIAG_INST{3},NO_ERROR,
ENG102667,DIAG_INST{4},NO_ERROR,
ENG102739,DIAG_INST{5},NO_ERROR,
ENG100162,DIAG_INST{6},NO_ERROR,
ENG99103,DIAG_INST{7},NO_ERROR,
ENG99261,DIAG_INST{8},NO_ERROR,
ENG103622,DIAG_INST{9},NO_ERROR,
ENG112560,DIST_ACT_MIL_SAE,1539, km
ENG112561,DIST_DTC_CLR_SAE,1794, km
ENG103766,DIST_ENG_RUN_IN,91679704.9, m
ENG100531,DIST_ST,9.16806e+007, m
ENG100131,ECU_STATE,SYN_ENG_IGK_ON,
ENG103712,EFPPWM_MIN_AD,0.000, %
ENG104044,Engine load,6.640625, %
ENG102494,Engine speed: actual,768, /min
ENG102783,Engine: operating status,IS,
ENG101147,ENVD_0_CRU_ACT_MON,0,
ENG102968,ENVD_0_GS_INC_MON,0,
ENG103667,ENVD_0_MON,0,
ENG100777,ENVD_0_MON_3,0,
ENG99438,ENVD_0_N_MAX_MON,0,
ENG110406,ENVD_0_STST_MON,0,
ENG100658,ENVD_0_TQI_MON,0,
ENG102106,ENVD_1_CRU_ACT_MON,0,
ENG103210,ENVD_1_GS_INC_MON,0,
ENG99424,ENVD_1_MON,0,
ENG100344,ENVD_1_MON_3,0,
ENG100092,ENVD_1_N_MAX_MON,0,
ENG110407,ENVD_1_STST_MON,0,
ENG99136,ENVD_1_TQI_MON,0,
ENG103816,ENVD_2_CRU_ACT_MON,0,
ENG100080,ENVD_2_GS_INC_MON,0,
ENG99790,ENVD_2_MON,0,
ENG100541,ENVD_2_MON_3,0,
ENG103232,ENVD_2_N_MAX_MON,0,
ENG110408,ENVD_2_STST_MON,0,
ENG101780,ENVD_2_TQI_MON,0,
ENG103490,ENVD_3_CRU_ACT_MON,0,
ENG102482,ENVD_3_GS_INC_MON,0,
ENG99455,ENVD_3_MON,0,
ENG101268,ENVD_3_MON_3,0,
ENG100841,ENVD_3_N_MAX_MON,0,
ENG110409,ENVD_3_STST_MON,0,
ENG99810,ENVD_3_TQI_MON,0,
ENG99752,Error flags: (completed cycles): cat: lambda probe heater,0,
ENG101275,Error flags: (completed cycles): lambda probes: EGR,0,
ENG104132,Error flags: (completed cycles): lambda probes:sec.air sys.,16,
ENG101942,ESI (extended service intervals) oil warning threshold,55.0625, mm
ENG112562,FAC_AR_THR_AD,0.000, %
ENG104194,FAC_H_RNG_LAM_AD{1},0.000, %
ENG104151,FAC_L_RNG_LAM_AD{1},3.299, %
ENG100298,FAC_LAM_CP,0.006, %
ENG100108,FAC_LAM_LIM{1},-0.008, %
ENG99722,FAC_LAM_TCO_A{1},0.000, %
ENG103521,FAC_LAM_TCO_B{1},0.000, %
ENG103641,FAC_LAM_TCO_C{1},0.000, %
ENG101578,FAC_LAM_TCO_D{1},0.000, %
ENG100685,FAC_LAM_TCO_E{1},0.000, %
ENG103307,FAC_MAF_MAX,0.17261,
ENG99791,FAC_SLOP_IV{1},0.00000,
ENG102306,FAC_TPS_1_SAE,12.109375, %
ENG102292,FAC_TPS_1_SAE,12.109375, %
ENG99630,Fan control relay: fan run-on,2,
ENG101437,Fan request from air conditioner,0.0, %
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG104248,Fuel consumption signal,47210, µl
ENG101667,Fuel pump: adaption value,0.000, %
ENG100969,Fuel pump: fuel pressure: I-controller,0.000, %
ENG100250,Fuel regulating valve: duty cycle,0.000, %
ENG101692,Fuel supply system: high-pressure regulator,3284.5, hPa
ENG114828,FUP_EFP_MES,5004.24, hPa
ENG103553,FUP_EFP_ST_H,0, hPa
ENG101056,FUP_EFP_ST_L,0, hPa
ENG99950,FUP_EFP_STOP_H,0, hPa
ENG100784,FUP_EFP_STOP_L,0, hPa
ENG102108,FUP_H,46731.0, hPa
ENG112563,FUP_H_SAE,4580.0, kPa
ENG103368,Gearbox -CAN bus messages,126847,
ENG102883,Gearbox: status,00000000 ,
ENG99170,Height correction,999.74, hPa
ENG103575,High-pressure system: regulator,4.75, mg
ENG103879,High-pressure system: regulator: mobile part,0.00, mg
ENG102603,High-pressure system: status,VCV_OPEN,
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,0.5, Nm
ENG101946,Idling stabilisation: operating status,00000000 ,
ENG100345,IGA_ADJ_KNK{0},0.000, °
ENG103593,IGA_ADJ_KNK{1},0.000, °
ENG103360,IGA_ADJ_KNK{2},0.000, °
ENG99404,IGA_ADJ_KNK{3},0.000, °
ENG100425,IGA_IGC{0},2.250, °
ENG101655,IGA_IGC{1},3.375, °
ENG100410,IGA_IGC{2},3.000, °
ENG100407,IGA_IGC{3},1.500, °
ENG112564,IGA_IGC_SAE,-1.5, °
ENG101741,Intake air temperature,31.50, °C
ENG125209,KNKS_ERR_REL{0},0.0195, V
ENG99741,LAMB_DELTA_AD_LAM_ADJ{1},0.00000,
ENG102085,LAMB_DELTA_AD_O2L_CAT{1},0.00000,
ENG99601,LAMB_DELTA_I_LAM_ADJ{1},0.00000,
ENG112565,LAMB_DELTA_SUM_LAM_ADJ_AD{1},0.00000,
ENG99674,Lambda controller: bank 1 (averaged value),-0.041, %
ENG101381,Lambda probe 1: bank 1: status,00000001 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000000 ,
ENG101336,Lambda probe 2: bank 1: status,00000000 ,
ENG99661,Lambda probe ageing: bank 1: dynamic factor,0.0000,
ENG101869,Lambda probe ageing: bank 1: probe 1: short trip result,226.9750, °C
ENG100478,Lambda probe correction: duty cycle offset: bank 1,0.00000,
ENG103776,Lambda probe heater: bank 1: probe 2: short trip result,00000000 ,
ENG102380,Lambda probe heater: resistance: bank 1: probe 2,333, Ohm
ENG99353,Lambda probe voltage: bank 1: probe 1 (broadband probe),1.958, V
ENG102763,Lambda probes actual: bank1,0.9893,
ENG104114,Lambda probes specified: bank1,0.9922,
ENG112566,LF_DPS_CYC_ERR_RAW_BSW{1},16384,
ENG112567,LF_DPS_CYC_ERR_RAW_BSW{2},16384,
ENG112568,LF_DPS_CYC_ERR_VLD_BSW{1},65535,
ENG112569,LF_DPS_CYC_ERR_VLD_BSW{2},65535,
ENG112570,LF_DPS_INI_ERR_RAW_BSW{1},0,
ENG112571,LF_DPS_INI_ERR_RAW_BSW{2},0,
ENG112572,LF_IV_ERR_RAW_BSW{0},0,
ENG112573,LF_IV_ERR_RAW_BSW{1},0,
ENG112574,LF_IV_ERR_RAW_BSW{2},0,
ENG112575,LF_IV_ERR_RAW_BSW{3},0,
ENG112576,LF_IV_ERR_VLD_BSW{0},8191,
ENG112577,LF_IV_ERR_VLD_BSW{1},8191,
ENG112578,LF_IV_ERR_VLD_BSW{2},8191,
ENG112579,LF_IV_ERR_VLD_BSW{3},8191,
ENG101645,LF_VVL_DIAG_SWI_NOT,0,
ENG122701,LMVDes_st_Mod_Out_VW,3,
ENG122702,LMVDes_v_Max_Man_Lim_VW,511.992, km/h
ENG122703,LMVLim_v_Auth_Max_Out_VW,319.9922, km/h
ENG100402,LOIL_SUM_SRV_INTL,8970.12500, mm
ENG99162,LV_ACC_RED_CMD,00000000 ,
ENG102235,LV_ATB_ACT_1,00000000 ,
ENG102541,LV_ATB_ACT_2,00000000 ,
ENG114829,LV_BPA_LIH_REQ{0},0,
ENG99095,LV_CAN_HOOD_SWI,00000000 ,
ENG103049,LV_EFPPWM_AD_STOP,00000000 ,
ENG101712,LV_ENG_RUN_IN,00000000 ,
ENG100267,LV_ENG_RUN_IN_EXT_ADJ,00000000 ,
ENG103319,LV_ERR_VLFT_1_SWI{1},00000000 ,
ENG103549,LV_ERR_VLFT_1_SWI{2},00000000 ,
ENG103191,LV_ERR_VLFT_1_SWI{3},00000000 ,
ENG101989,LV_ERR_VLFT_1_SWI{4},00000000 ,
ENG102313,LV_ERR_VLFT_STND_SWI{1},00000000 ,
ENG103044,LV_ERR_VLFT_STND_SWI{2},00000000 ,
ENG103443,LV_ERR_VLFT_STND_SWI{3},00000000 ,
ENG100487,LV_ERR_VLFT_STND_SWI{4},00000000 ,
ENG103773,LV_INH_STR_RLY,00000000 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,00000000 ,
ENG103908,LV_LOIL_L_WARN_TMP,00000000 ,
ENG103716,LV_POIL_SWI_H,00000000 ,
ENG100912,LV_POIL_SWI_L,00000001 ,
ENG112586,LV_PWR_RLY{0},00000001 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,0,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG112587,LV_VCP_AD_END,00000001 ,
ENG102523,MAF,109.39, mg/stroke
ENG99288,MAF_DIF_CAM_OFS_AD_SQ_TOT,0.000, kg²/h²
ENG112588,MAP_MES_SAE,30, kPa
ENG103501,MASS_SA_REL{0},0.000,
ENG100896,MASS_SA_REL_21_PHA,0.000,
ENG103045,MASS_SA_REL_22_PHA,0.000,
ENG103346,MFF_ADD_LAM_AD{1},0.06, mg/stroke
ENG101360,Misfire detection active,00000001 ,
ENG102335,Misfires all cylinders per 1000 rpm,3,
ENG112590,N_TOOTH,768, /min
ENG107737-ENG112538,NC_NR_DIAG_RBM-NC Value,139,
ENG126111,NL_PRE{0},0.16136, V
ENG126112,NL_PRE{1},0.33333, V
ENG126113,NL_PRE{2},0.16441, V
ENG126114,NL_PRE{3},0.17685, V
ENG112589,NR_CYL_FIRST_VVL_SWI,0,
ENG99776,NR_CYL_VVL_H_ACK,0,
ENG99870,O2L_1_MAX_BAS_AD_CAT{1},0.00000, g
ENG104137,O2L_1_MAX_BAS_AD_CAT_DIAG{1},1.19999, g
ENG119936,O2L_MAX_CAT_GAP_AFL_MV{1},0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV{1},0.00000, g
ENG99157,PRS_SA_DIF,0.00, hPa
ENG112591,PSN_EDGE_REL_AD_CAM_EX{1}{1},-0.5000, °
ENG112592,PSN_EDGE_REL_AD_CAM_IN{1}{1},2.6250, °
ENG114830,PSN_EDGE_REL_AD_CAM_SAVE_EX{1}{1},-0.5000, °
ENG114831,PSN_EDGE_REL_AD_CAM_SAVE_EX{1}{2},-1.1250, °
ENG114832,PSN_EDGE_REL_AD_CAM_SAVE_IN{1}{1},2.6250, °
ENG114833,PSN_EDGE_REL_AD_CAM_SAVE_IN{1}{2},1.0625, °
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG112593,PWM_ACT_VCP{EX_1},90.002, %
ENG112594,PWM_ACT_VCP{IN_1},90.002, %
ENG101350,PWM_ETC,-15.976, %
ENG112595,PWM_HLD_VCP{EX_1},9.143, %
ENG112596,PWM_HLD_VCP{IN_1},36.340, %
ENG112597,PWM_PAS_VCP{EX_1},9.143, %
ENG112598,PWM_PAS_VCP{IN_1},9.143, %
ENG101201,Radiator fan 1: run-on: status,600W,
ENG102359,Radiator fan 2: run-on: status,NO_ECF,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV{1},0.0000000,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV{1},0.0000000,
ENG102377,Ready and error flags,0,
ENG112599,RVC_AV,134.16, °
ENG112601,RVC_SP,133.75, °
ENG112600,RVCPWM,0.000, %
ENG103248,SEG_AD_MMV_ER{0},0.0000,
ENG101135,SEG_AD_MMV_ER{1},-0.7412,
ENG99078,SEG_AD_MMV_ER{2},-0.0243,
ENG103257,SEG_AD_MMV_ER{3},-0.6983,
ENG102511,SEG_AD_MMV_ER_H{0},0.0000,
ENG103258,SEG_AD_MMV_ER_H{1},-1.1108,
ENG99291,SEG_AD_MMV_ER_H{2},-0.1490,
ENG99954,SEG_AD_MMV_ER_H{3},-1.0717,
ENG100568,SEG_AD_MMV_ER_L{0},0.0000,
ENG100601,SEG_AD_MMV_ER_L{1},-0.7412,
ENG102668,SEG_AD_MMV_ER_L{2},-0.0243,
ENG101232,SEG_AD_MMV_ER_L{3},-0.6983,
ENG101561,SEG_AD_MMV_ER_MID{0},0.0000,
ENG102964,SEG_AD_MMV_ER_MID{1},-0.7791,
ENG100890,SEG_AD_MMV_ER_MID{2},-0.0584,
ENG99793,SEG_AD_MMV_ER_MID{3},-0.7396,
ENG103381,Shut-off time,0.30, s
ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,0, %
ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,0, %
ENG102971,Start adaption: temperature adaption factor 1,1.000000,
ENG102489,Start adaption: temperature adaption factor 2,1.000000,
ENG100723,Start adaption: temperature adaption factor 3,1.000000,
ENG100919,Starter control: interlock switch,00000000 ,
ENG100800,Starter: start relay 1,00000000 ,
ENG99979,Starter: start relay 2,00000000 ,
ENG102033,STATE_BPA{0},OPM,
ENG102127,STATE_COMC_NVLD,Wait,
ENG112602,STATE_CRK_STST,CRK_STST_ACQ_SHO_LEVEL,
ENG114834,STATE_CRU_OFF_IRR_CUS,0,
ENG114835,STATE_CRU_OFF_REV_CUS,17317952,
ENG112603,STATE_EOL_VVL,DEAC,
ENG110434,STATE_ERR_ABC_PRED,18,
ENG112604,STATE_GEAR_SENS_RAW,0,
ENG112605,STATE_LS_SAE{1},CL,
ENG104238,STATE_NVLD,INI,
ENG112606,STATE_PWM_VCP{EX_1},HLD,
ENG112607,STATE_PWM_VCP{IN_1},ACT,
ENG101078,STATE_READY_OBD_1,7,
ENG100369,STATE_READY_OBD_3,0,
ENG100342,STATE_REQ_NVLD,NO_REQ,
ENG109090,STATE_SW_MVB,SC8H6510 CBH0090,
ENG112608,STATE_VCP,ACT_ADAPT,
ENG114836,STATE_VCV_CLOSE_SL,OFF,
ENG103723,STATE_VVL_MNG,VVL_L,
ENG112609,T_ACT_MIL_SAE,2783, min
ENG112494,T_AST_SAE,182, s
ENG104148,T_COOL_LOIL,538.0, ms
ENG112613,T_DTC_CLR_SAE,3400, min
ENG102790,T_EFP_MEM_H,0.00, s
ENG102123,T_EFP_MEM_L,0.00, s
ENG109299,T_ES,0, min
ENG112615,T_ES_CNT,0,
ENG112616,T_ES_DC,97, min
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG112636,T_SWI_VVL_ACR,67.2, ms
ENG101325,T_TEMP_SIG_LOIL,49.9, ms
ENG99126,T_VS_TOL_LOCK,0, min
ENG102048,Tank breather valve: duty cycle,40.625000, %
ENG101339,Tank breather valve: short trip result,1.5143, kg/h
ENG100439,Tank level,00000000 ,
ENG112610,TCO_1_FIRST_ST,58, °C
ENG112611,TCO_1_ST,58, °C
ENG112612,TCO_1_SYS,81, °C
ENG103434,TCO_A_LAM_AD_WUP{1},-5.25, °C
ENG100381,TCO_B_LAM_AD_WUP{1},9.75, °C
ENG101581,TCO_C_LAM_AD_WUP{1},24.75, °C
ENG100354,TCO_D_LAM_AD_WUP{1},35.25, °C
ENG101973,TCO_E_LAM_AD_WUP{1},45.00, °C
ENG100390,TCO_MIN_INTER_LAM_AD_WUP{1},81.00, °C
ENG100853,TCO_MIN_LAM_AD_WUP{1},50.25, °C
ENG102279,TCS/ESP: specified torque,18.53, Nm
ENG99857,TCS: status,00000000 ,
ENG110436,TEG_DYN_LS_DOWN{1},131.7250, °C
ENG110437,TEG_DYN_LS_UP{1},333.9750, °C
ENG101941,TEMP_CAT_STAT_MDL{1},302.4125, °C
ENG112614,TEMP_CAT_UP_1_SAE,250.5, °C
ENG114837,TFPA,60, °C
ENG114838,TFU_HPP,59.25, °C
ENG99608,Throttle valve adjuster: adaption status,ST_CHK_END,
ENG101411,Throttle valve angle,1.962, °
ENG102845,Throttle valve deviation,-0.154, %
ENG126115,TI_1_MES_MPI{0},4.092, ms
ENG126116,TI_1_MES_MPI{1},3.856, ms
ENG126117,TI_1_MES_MPI{2},3.900, ms
ENG126118,TI_1_MES_MPI{3},3.928, ms
ENG126119,TI_MES_4{PLS_1}{0},0.000, ms
ENG126120,TI_MES_4{PLS_1}{1},0.000, ms
ENG126121,TI_MES_4{PLS_1}{2},0.000, ms
ENG126122,TI_MES_4{PLS_1}{3},0.000, ms
ENG126123,TI_MES_4{PLS_2}{0},0.000, ms
ENG126124,TI_MES_4{PLS_2}{1},0.000, ms
ENG126125,TI_MES_4{PLS_2}{2},0.000, ms
ENG126126,TI_MES_4{PLS_2}{3},0.000, ms
ENG126127,TI_MES_4{PLS_3}{0},0.000, ms
ENG126128,TI_MES_4{PLS_3}{1},0.000, ms
ENG126129,TI_MES_4{PLS_3}{2},0.000, ms
ENG126130,TI_MES_4{PLS_3}{3},0.000, ms
ENG125276,TIG_MES_SAE{IM},33, °C
ENG103351,Time since engine start,187.8, s
ENG112634,TLTS_MES{TCE},81.766, °C
ENG112635,TMAG_VCP,62, °C
ENG110444,TPS_AD_CDN_MIS,0,
ENG114839,TPS_ETC,2.064, °
ENG99274,TPS_SP,1.991, °
ENG103021,TQ_CONV,4.00, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG102329,TTIP_MES_LS_UP{1},785.0000, °C
ENG100355,V_FUP_EFP_MV,2.017, V
ENG100739,V_PVS_1_BAS,0.7373, V
ENG114840,V_PVS_KD,0.000, V
ENG103201,VCV_CLOSE_RNG,0.0, °
ENG102311,Vehicle speed: filtered,0.000, km/h
ENG122704,VLCAvl_st_Pt_VW,4,
ENG122705,VLCReq_st_Dem_VW,2,
ENG112639,VLS_DOWN_SAE{1},0.240, V
ENG101929,VP_TPS_1,0.5957, V
ENG102985,VP_TPS_2,4.3945, V
ENG100421,VP_TPS_AD_EL_BOL_1,0.4980, V
ENG103444,VP_TPS_AD_EL_BOL_2,4.4844, V
ENG101674,VP_TPS_AD_LIH_1,0.7764, V
ENG99507,VP_TPS_AD_LIH_2,4.2041, V
Elapsed Time: 01:03
blockmap-02-0D9-300-012-L_WAUZZZ8V8F1029358-20241020-1529.CSV
;SW:0D9-300-012-L   HW:02E-927-770-AQ ---  Auto Trans
;Component:DQ250-6A MQB  H52 4932, Coding:0014
;EV_TCMDQ250021,001001,EV_TCMDQ250021.rod
;Sunday,20,October,2024,15:29:00:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 1F1C3ABC8731F0C2461-804A
Group,Description,Actual
IDE00018,Voltage terminal 15,14.0, V
IDE00019,Voltage terminal 30,14.4, V
IDE00021,Engine RPM,761, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,764, /min
IDE00024-ENG98981,ATF temperature-Transmission fluid temperature,47, °C
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0.00, km/h
IDE00086,Accelerator pedal position,0.0, %
IDE00091-ENG101172,Status of starter lock-Status Engine Starter Lock,Activating,
IDE00094,Kick-down status,OFF,
IDE00095-ENG101643,Status of selector lever lock-Status Shift Lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00102-ENG102028,Control Module temperature-Control modul temperature,49, °C
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,600, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,0,
IDE00323-ENG140165,Security Access: Number of invalid keys-Counter Value,0,
IDE00451-ENG103018,Currently running routine-Current Test Routine,0,
IDE00872-ENG102188,Current of main pressure valve-Oil Pressure Actual Current,808.7, mA
IDE01588-ENG101855,Driving direction-M015 SvnNAbRichtung,not known,
IDE02221,Engine torque: qualification,valid,
IDE02713-ENG98471,Brake lamp switch-Brake Light Switch,Not operated,
IDE02714,Brake test switch,Not operated,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02719-ENG99606,Selector lever position made plausible-Shift Position Plausible,P,
IDE02720-ENG103810,Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1,0, /min
IDE02721-ENG100916,Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2,0, /min
IDE02722-ENG101964,Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1,0, /min
IDE02723-ENG100382,Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2,0, /min
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged,
IDE02790-ENG104124,Specified torque clutch 1-Clutch 1 Commanded Torque,-600.00, Nm
IDE02796-ENG103463,Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value,0.0, mA
IDE02797-ENG100730,Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value,0.7, mA
IDE02800-ENG100171,Specified torque clutch 2-Clutch 2 Commanded Torque,-600.00, Nm
IDE02805-ENG99237,Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value,0.0, mA
IDE02806-ENG103118,Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value,0.2, mA
IDE02862-ENG103213,Production data transmission-Aggregatekennzeichnung (Getriebe),006,
IDE02862-ENG103083,Production data transmission-Baudatum,140527,
IDE02862-ENG104019,Production data transmission-Getriebekennbuchstabe,QSP,
IDE02862-ENG99175,Production data transmission-Kassel,K,
IDE02862-ENG101707,Production data transmission-Kennung der Montagelinie,000,
IDE02862-ENG103830,Production data transmission-Lfd.-Nr,0886,
IDE02864-ENG99505,Actual position of gear positioner A-Gearpositioner A Actual Position,-0.26, mm
IDE02865-ENG104121,AD value 1 of actual position of gear actuator A-Gearpositioner A Actual Position AD Value 1,2062,
IDE02870-ENG120871,Duty cycle of gear Solen.val. A-Gearpositioner_A_Valve_Duty_Factor,0.0, %
IDE02872-ENG102218,Actual position of gear adjuster B-Gearpositioner B Actual Position,-7.98, mm
IDE02873-ENG101728,AD value 1 of actual position of gear actuator B-Gearpositioner B Actual Position AD Value 1,1005,
IDE02878-ENG120875,Pulse duty factor of gear Solen.val. B-Gearpositioner_B_Valve_Duty_Factor,0.0, %
IDE02880-ENG103036,Actual position of gear positioner C-Gearpositioner C Actual Position,-0.41, mm
IDE02881-ENG99453,AD value 1 of actual position of gear actuator C-Gearpositioner C Actual Position AD Value 1,2042,
IDE02886-ENG120879,Pulse duty factor of gear Solen.val. C-Gearpositioner_C_Valve_Duty_Factor,0.0, %
IDE02888-ENG103826,Actual position of gear positioner D-Gearpositioner D Actual Position,-8.30, mm
IDE02889-ENG100525,AD value 1 of actual position of gear actuator D-Gearpositioner D Actual Position AD Value 1,1042,
IDE02894-ENG120883,Duty cycle of gear Solen.val. D-Gearpositioner_D_Valve_Duty_Factor,0.0, %
IDE03008-ENG122550,Stop process prevented-GE_StartStopp_Info,Stop release,
IDE03008-ENG122551,Stop process prevented-MO_StartStopp_Status,1,
IDE03008-ENG122546,Stop process prevented-Stopp-Verbot-Grund 1,not active,
IDE03008-ENG122547,Stop process prevented-Stopp-Verbot-Grund 2,not active,
IDE03008-ENG122548,Stop process prevented-Stopp-Verbot-Grund 3,not active,
IDE03008-ENG122549,Stop process prevented-Stopp-Verbot-Grund 4,not active,
IDE03008-ENG122552,Stop process prevented-Stopp-Verbot-Grund 5,not active,
IDE03008-ENG122553,Stop process prevented-Stopp-Verbot-Grund 6,not active,
IDE03008-ENG122554,Stop process prevented-Stopp-Verbot-Grund 8,not active,
IDE03171-ENG102987,Driving strategy transmission mileage-Q002 Total Driving Time,90396.3, km
IDE03172-ENG100789,Driving Strategy Percentage Driving in D or S w/Cruise-Q003 Driving Time Ecological,28, %
IDE03173-ENG103567,Driving Strategy Percentage Driving in S w/o cruise-Q004 Driving Time Sporty,21, %
IDE03174-ENG100415,Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual,2, %
IDE03180-ENG103176,Number of standard trips-General Denominator,933,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,3526,
IDE03182-ENG120927,Lower adapted clutch point K1 from Kiss point adaptation-lower_Adapted_Clutchpoint_K1_Of_Kisspoint_Adaption,0.255, A
IDE03183-ENG120930,Lower adapted clutch point K2 from Kiss point adaptation-lower_Adapted_Clutchpoint_K2_Of_Kisspoint_Adaption,0.240, A
IDE03184-ENG120928,Upper adapted clutch point K1 from micro slip adaptation-Upper_Adapted_Clutchpoint_K1_Of_Microslip_Adaption,0.825, A
IDE03185-ENG120929,Upper adapted clutch point K2 from micro slip adaptation-Upper_Adapted_Clutchpoint_K2_Of_Microslip_Adaption,0.775, A
IDE03189-ENG110524,Number of prevented stop processes (statistics)-Basic setting,not active,
IDE03189-ENG159578,Number of prevented stop processes (statistics)-Demontagestellung,not active,
IDE03189-ENG159577,Number of prevented stop processes (statistics)-Drucksensorausfall,not active,
IDE03189-ENG159579,Number of prevented stop processes (statistics)-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE03189-ENG110508,Number of prevented stop processes (statistics)-km-Stand des letzten Stoppverbots,86728.0, km
IDE03189-ENG159710,Number of prevented stop processes (statistics)-Motorstoppverbote Anzahl Stoppverbote,48,
IDE03189-ENG110525,Number of prevented stop processes (statistics)-Stop prohibition via application,not active,
IDE03189-ENG159576,Number of prevented stop processes (statistics)-Temperaturbedingung,not active,
IDE03189-ENG122385,Number of prevented stop processes (statistics)-unsortierte Gangsteller im Stand,active,
IDE04612-ENG101246,Clutch temperature air / splash oil-Centrifugal oil temperature,47, °C
IDE04805-IDE02955,Driving profile selection-System status,not_available,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,will be performed.,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE04805-MAS01448,Driving profile selection-Target value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05987-ENG110524,Engine stop prohibitions-Basic setting,not active,
IDE05987-ENG159578,Engine stop prohibitions-Demontagestellung,not active,
IDE05987-ENG159577,Engine stop prohibitions-Drucksensorausfall,not active,
IDE05987-ENG159579,Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE05987-ENG110508,Engine stop prohibitions-km-Stand des letzten Stoppverbots,86728.0, km
IDE05987-ENG159710,Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote,48,
IDE05987-ENG110525,Engine stop prohibitions-Stop prohibition via application,not active,
IDE05987-ENG159576,Engine stop prohibitions-Temperaturbedingung,not active,
IDE05987-ENG122385,Engine stop prohibitions-unsortierte Gangsteller im Stand,active,
IDE05988-ENG110505,Pressure of clutch 2: actual value-Clutch_2_actual_value,0.02, bar
IDE05989-ENG110503,Pressure of clutch 1: actual value-Clutch_1_actual_value,0.09, bar
IDE06425,Dynamometer mode: functional,not activated,
IDE80001-ENG100467,Analysis 1-Snapshot 1 Failure ID,65535,
IDE80002-ENG102386,Analysis 2-Snapshot 1 Mileage,0, km
IDE80003-ENG101467,Analysis 3-Snapshot 1 Counter,0,
IDE80005-ENG103330,Analysis 5-Snapshot 1 Shift Position Plausible,Malfunction,
IDE80007-ENG101090,Analysis 7-Snapshot 1  Commanded Gear,GANG N,
IDE80008-ENG100048,Analysis 8-Snapshot 1 Preselection Gear,GANG N,
IDE80009-ENG102100,Analysis 9-Snapshot 1 Transmission Input Speed,0, /min
IDE80010-ENG101565,Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1,0, /min
IDE80011-ENG100379,Analysis 11-Snapshot 1 Transmission Speed Shaft 1,0, /min
IDE80012-ENG103459,Analysis 12-Snapshot 1 Transmission Speed Shaft 2,0, /min
IDE80021-ENG102762,Analysis 21-Snapshot 1 Clutch 1 Actual Pressure,0.0, bar
IDE80022-ENG100347,Analysis 22-Snapshot 1 Clutch 2 Actual Pressure,0.0, bar
IDE80023-ENG99119,Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value,0, mA
IDE80024-ENG101123,Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value,0, mA
IDE80025-ENG103611,Analysis 25-Snapshot 1 Accelerator Pedal Position,0.0, %
IDE80026-ENG101503,Analysis 26-Snapshot 1 Engine torque,-50, Nm
IDE80029-ENG103070,Analysis 29-Snapshot 1 Voltage Terminal 15,0.0, V
IDE80031-ENG102899,Analysis 31-Snapshot 1 Transmission Fluid Temperature,-60, °C
IDE80033-ENG103098,Analysis 33-Snapshot 2 Failure ID,65535,
IDE80034-ENG101047,Analysis 34-Snapshot 2 Mileage,0, km
IDE80035-ENG99915,Analysis 35-Snapshot 2 Counter,0,
IDE80037-ENG99369,Analysis 37-Snapshot 2 Shift Position Plausible,Malfunction,
IDE80039-ENG101369,Analysis 39-Snapshot 2  Commanded Gear,GANG N,
IDE80040-ENG103638,Analysis 40-Snapshot 2 Preselection Gear,GANG N,
IDE80041-ENG103367,Analysis 41-Snapshot 2 Transmission Input Speed,0, /min
IDE80042-ENG102476,Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1,0, /min
IDE80043-ENG102699,Analysis 43-Snapshot 2 Transmission Speed Shaft 1,0, /min
IDE80044-ENG101900,Analysis 44-Snapshot 2 Transmission Speed Shaft 2,0, /min
IDE80053-ENG102973,Analysis 53-Snapshot 2 Clutch 1 Actual Pressure,0.0, bar
IDE80054-ENG100122,Analysis 54-Snapshot 2 Clutch 2 Actual Pressure,0.0, bar
IDE80055-ENG103189,Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value,0, mA
IDE80056-ENG103616,Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value,0, mA
IDE80057-ENG102447,Analysis 57-Snapshot 2 Accelerator Pedal Position,0.0, %
IDE80058-ENG103198,Analysis 58-Snapshot 2 Engine torque,-50, Nm
IDE80061-ENG101449,Analysis 61-Snapshot 2 Voltage Terminal 15,0.0, V
IDE80063-ENG104157,Analysis 63-Snapshot 2 Transmission Fluid Temperature,-60, °C
IDE80065-ENG122555,Analysis 65-Snapshot 1 Weg Gangsteller 1-3,0,
IDE80065-ENG122556,Analysis 65-Snapshot 1 Weg Gangsteller 2-4,0,
IDE80065-ENG122557,Analysis 65-Snapshot 1 Weg Gangsteller 5-N,0,
IDE80065-ENG122558,Analysis 65-Snapshot 1 Weg Gangsteller 6-R,0,
IDE80066-ENG122559,Analysis 66-Snapshot 2 Weg Gangsteller 1-3,0,
IDE80066-ENG122560,Analysis 66-Snapshot 2 Weg Gangsteller 2-4,0,
IDE80066-ENG122561,Analysis 66-Snapshot 2 Weg Gangsteller 5-N,0,
IDE80066-ENG122562,Analysis 66-Snapshot 2 Weg Gangsteller 6-R,0,
IDE80071-ENG127839,Analysis 71-FID event memory entry 1,FF FF,
IDE80071-ENG127848,Analysis 71-FID event memory entry 10,FF FF,
IDE80071-ENG127849,Analysis 71-FID event memory entry 11,FF FF,
IDE80071-ENG127850,Analysis 71-FID event memory entry 12,FF FF,
IDE80071-ENG127840,Analysis 71-FID event memory entry 2,FF FF,
IDE80071-ENG127841,Analysis 71-FID event memory entry 3,FF FF,
IDE80071-ENG127842,Analysis 71-FID event memory entry 4,FF FF,
IDE80071-ENG127843,Analysis 71-FID event memory entry 5,FF FF,
IDE80071-ENG127844,Analysis 71-FID event memory entry 6,FF FF,
IDE80071-ENG127845,Analysis 71-FID event memory entry 7,FF FF,
IDE80071-ENG127846,Analysis 71-FID event memory entry 8,FF FF,
IDE80071-ENG127847,Analysis 71-FID event memory entry 9,FF FF,
IDE80296-ENG127853,Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter,7040,
IDE80298-ENG127880,Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter,6148,
IDE80302-ENG122492,Selector lever information-Datenstand,15,
IDE80302-ENG111628,Selector lever information-Part Number,8V2713023G     ,
IDE80302-ENG98856,Selector lever information-Programmability,0 ,
IDE80302-ENG122491,Selector lever information-Programm-Stand,VL ,
IDE80303-ENG127833,Overall software description-Software full name,F49M,
IDE80304-ENG120779,Mechatronics identification DQ250-Änderungsstand BorgWarner,058,
IDE80304-ENG120778,Mechatronics identification DQ250-Mechatronik-Identifikation,Q20K2257 ,
IDE80305-ENG125922,Parameter set description-Data set name,0D9300012L_4932_RcJG            ,
IDE80312-ENG122524,CAN bus installation information-ACC_06,Unknown,
IDE80312-ENG122528,CAN bus installation information-BEM_05,installed,
IDE80312-ENG113024,CAN bus installation information-Charisma_01,installed,
IDE80312-ENG122522,CAN bus installation information-EPB_01,installed,
IDE80312-ENG122525,CAN bus installation information-GRA_ACC_01,installed,
IDE80312-ENG122511,CAN bus installation information-TSK_06,installed,
ENG120958,Abbruchcode,GSA_ABBRUCH_CODE_OK,
ENG122365-ENG104207,Abschaltpfadtest Fehlerursache aus dem SCM-Bit 0,Abschalten ENA erfolgreich,
ENG122365-ENG102209,Abschaltpfadtest Fehlerursache aus dem SCM-Bit 1,Abschalten WDA erfolgreich,
ENG122365-ENG99197,Abschaltpfadtest Fehlerursache aus dem SCM-Bit 2,EInschalten Endstufen erfolgreich,
ENG122365-ENG102937,Abschaltpfadtest Fehlerursache aus dem SCM-Bit 3,Keine Unterspannung im Abschaltpfadtest,
ENG122363,Abschaltpfadtest Maximaler AD-Wert im Off-Fall,327,
ENG122364,Abschaltpfadtest Minimaler AD-Wert im On-Fall,506,
ENG120920,Abtriebsdrehzahl CAN,0, /min
ENG98625-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,OK,
ENG100091,Ambient temperature,14, °C
ENG120963,Anzahl der Überschreitungen der zulässigen Schleuderöltemperatur,0,
ENG120964,Anzahl der Warnungen aufgrund erhöhter Schleuderöltemperatur,0,
ENG122366,Anzahl der wegen Unterspannung abgebrochenen Abschaltpfadtests,39372,
ENG120970,Anzahl Ereignisse auf K1,0,
ENG120972,Anzahl Ereignisse auf K2,0,
ENG98482-ENG99180,Checksum of flash-Calibration Checksumme,6F 5E C6 98,
ENG98482-ENG100495,Checksum of flash-Cboot Checksumme,0E 5C CC 72,
ENG98482-ENG100117,Checksum of flash-Checksumme ECU + CAL,00 00 BC 3B,
ENG98482-ENG102221,Checksum of flash-ECU Checksumme,6E 53 C6 11,
ENG110530,Clutch 1 adaption kiss point part 1 fault counter,0,
ENG110536,Clutch 2 adaption kiss point part 1 fault counter,0,
ENG99212,Common highside 1 specified condition,Common Highside soll eingeschaltet werden,
ENG99878,Common highside 2 specified condition,Common Highside soll eingeschaltet werden,
ENG103403,Converter Loss Torque,4.6, Nm
ENG100625,Coolant temperature,85, °C
ENG98602,Driver intention torque,5.0, Nm
ENG100746,Driving strategy: sport factor,0.0, %
ENG120931,Eingelegtposition Seite A: Gangsteller 1-3,0.00, %
ENG120932,Eingelegtposition Seite A: Gangsteller 2-4,0.00, %
ENG120933,Eingelegtposition Seite A: Gangsteller 5-N,0.00, %
ENG120934,Eingelegtposition Seite A: Gangsteller 6-R,0.00, %
ENG120943,Eingelegtposition Seite B: Gangsteller 1-3,0.00, %
ENG120944,Eingelegtposition Seite B: Gangsteller 2-4,0.00, %
ENG120945,Eingelegtposition Seite B: Gangsteller 5-N,0.00, %
ENG120946,Eingelegtposition Seite B: Gangsteller 6-R,0.00, %
ENG101251,Empty,Empty,
ENG98756,Engine torque,6.0, Nm
ENG104230,Engine torque loss,-19.0, Nm
ENG123019-ENG99024,Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission,0.0, km/h
ENG120799,Gangsteller A Adaption Flags,00 1F,
ENG120808,Gangsteller B Adaption Flags,00 1F,
ENG120817,Gangsteller C Adaption Flags,00 15,
ENG120826,Gangsteller D Adaption Flags,00 1F,
ENG121005,Gangsteller Synchronposition G1 (Prozent),54.89, %
ENG121006,Gangsteller Synchronposition G2 (Prozent),45.17, %
ENG121007,Gangsteller Synchronposition G3 (Prozent),44.99, %
ENG121008,Gangsteller Synchronposition G4 (Prozent),54.87, %
ENG121009,Gangsteller Synchronposition G5 (Prozent),53.51, %
ENG121010,Gangsteller Synchronposition G6 (Prozent),54.11, %
ENG121011,Gangsteller Synchronposition GR (Prozent),46.75, %
ENG120961,Gangsteller_Index,GS_13,
ENG120962,Gangsteller_Seite,Neutrallage,
ENG120957,Gangstellerposition zum Zeitpunkt eines Abbruchs,Neutral,
ENG120969,Gefahrene km seit letztem Ereignis auf K1,220, km
ENG120971,Gefahrene km seit letztem Ereignis auf K2,220, km
ENG99720,Height info,994, mbar
ENG98604,Hill factor driving strategy,0.0, %
ENG99596,Indicated engine torque without external interventions,24.0, Nm
ENG99582,Intake air temperature,1, °C
ENG122357-ENG122524,Kommunikationsstatus Datenbus 1 MQB-ACC_06,Unknown,
ENG122357-ENG122528,Kommunikationsstatus Datenbus 1 MQB-BEM_05,received,
ENG122357-ENG113024,Kommunikationsstatus Datenbus 1 MQB-Charisma_01,received,
ENG122357-ENG122523,Kommunikationsstatus Datenbus 1 MQB-Diagnose_01,received,
ENG122357-ENG122522,Kommunikationsstatus Datenbus 1 MQB-EPB_01,received,
ENG122357-ENG122513,Kommunikationsstatus Datenbus 1 MQB-ESP_02,received,
ENG122357-ENG122514,Kommunikationsstatus Datenbus 1 MQB-ESP_05,received,
ENG122357-ENG110808,Kommunikationsstatus Datenbus 1 MQB-ESP_07,received,
ENG122357-ENG122515,Kommunikationsstatus Datenbus 1 MQB-ESP_10,Unknown,
ENG122357-ENG122516,Kommunikationsstatus Datenbus 1 MQB-ESP_19,received,
ENG122357-ENG122517,Kommunikationsstatus Datenbus 1 MQB-ESP_20,received,
ENG122357-ENG122518,Kommunikationsstatus Datenbus 1 MQB-ESP_21,received,
ENG122357-ENG122519,Kommunikationsstatus Datenbus 1 MQB-Gateway_72,received,
ENG122357-ENG122520,Kommunikationsstatus Datenbus 1 MQB-Gateway_74,received,
ENG122357-ENG122525,Kommunikationsstatus Datenbus 1 MQB-GRA_ACC_01,received,
ENG122357-ENG131312,Kommunikationsstatus Datenbus 1 MQB-Klemmen_Status_01,received,
ENG122357-ENG110802,Kommunikationsstatus Datenbus 1 MQB-Kombi_01,received,
ENG122357-ENG122521,Kommunikationsstatus Datenbus 1 MQB-Kombi_02,received,
ENG122357-ENG110799,Kommunikationsstatus Datenbus 1 MQB-LWI_01,received,
ENG122357-ENG122512,Kommunikationsstatus Datenbus 1 MQB-Motor_04,received,
ENG122357-ENG122502,Kommunikationsstatus Datenbus 1 MQB-Motor_07,received,
ENG122357-ENG122503,Kommunikationsstatus Datenbus 1 MQB-Motor_11,received,
ENG122357-ENG122504,Kommunikationsstatus Datenbus 1 MQB-Motor_12,received,
ENG122357-ENG122505,Kommunikationsstatus Datenbus 1 MQB-Motor_14,received,
ENG122357-ENG122506,Kommunikationsstatus Datenbus 1 MQB-Motor_16,received,
ENG122357-ENG122507,Kommunikationsstatus Datenbus 1 MQB-Motor_17,received,
ENG122357-ENG122529,Kommunikationsstatus Datenbus 1 MQB-Motor_18,received,
ENG122357-ENG122508,Kommunikationsstatus Datenbus 1 MQB-Motor_20,received,
ENG122357-ENG122509,Kommunikationsstatus Datenbus 1 MQB-Motor_26,Unknown,
ENG122357-ENG137653,Kommunikationsstatus Datenbus 1 MQB-Motor_35,Unknown,
ENG122357-ENG122510,Kommunikationsstatus Datenbus 1 MQB-Motor_Code_01,received,
ENG122357-ENG122526,Kommunikationsstatus Datenbus 1 MQB-OBD_01,received,
ENG122357-ENG122511,Kommunikationsstatus Datenbus 1 MQB-TSK_06,received,
ENG122357-ENG122527,Kommunikationsstatus Datenbus 1 MQB-Waehlhebel_03,received,
ENG126632,Korrekturwerte Hauptdruckadaption,0.95, bar
ENG121002,Korrekturwerte Hauptdruckadaption: großer Druck auf K1,0.95, bar
ENG121004,Korrekturwerte Hauptdruckadaption: großer Druck auf K2,0.95, bar
ENG121001,Korrekturwerte Hauptdruckadaption: kleiner Druck auf K1,0.95, bar
ENG121003,Korrekturwerte Hauptdruckadaption: kleiner Druck auf K2,0.90, bar
ENG99297,Kupplung 1 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl,0,
ENG100826,Kupplung 2 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl,0,
ENG120965,Kupplungsadaptionswerte: IKp0 fuer K1,255, mA
ENG120966,Kupplungsadaptionswerte: IKp0 fuer K2,240, mA
ENG120967,Kupplungsadaptionswerte: unterer Strompunkt Adaption K1,215, mA
ENG120968,Kupplungsadaptionswerte: unterer Strompunkt Adaption K2,225, mA
ENG110556-ENG110541,Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung,3,
ENG110556-ENG110542,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß,0,
ENG110556-ENG110543,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein,12,
ENG110556-ENG120771,Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen,144617,
ENG110557-ENG110545,Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung,0,
ENG110557-ENG110546,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß,0,
ENG110557-ENG110547,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein,1,
ENG110557-ENG110544,Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen,80849,
ENG120996,Maximale Spannung an UH1,9.1, V
ENG120998,Maximale Spannung an UH2,5.0, V
ENG120995,Minimale Spannung an UH1,0.2, V
ENG120997,Minimale Spannung an UH2,4.9, V
ENG111613-ENG101555,Motordrehmoment Begrenzung-Engine torque limitation,408.0, Nm
ENG120939,Neutralposition: Gangsteller 1-3,49.94, %
ENG120940,Neutralposition: Gangsteller 2-4,49.78, %
ENG120941,Neutralposition: Gangsteller 5-N,49.68, %
ENG120942,Neutralposition: Gangsteller 6-R,50.78, %
ENG120993,Oberer adaptierter Kupplungspunkt K1 aus Makroschlupfadaption,825, mA
ENG120994,Oberer adaptierter Kupplungspunkt K2 aus Makroschlupfadaption,775, mA
ENG105329-ENG101124,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1),2864.2, H
ENG105329-ENG100216,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2),91.6, H
ENG105329-ENG103067,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3),0.1, H
ENG105329-ENG101168,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4),0.0, H
ENG105329-ENG104150,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5),0.0, H
ENG105329-ENG100130,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6),0.0, H
ENG120987,Ratio FID 256,100.0, %
ENG120989,Ratio FID 257,100.0, %
ENG120988,Ratio FID 330,100.0, %
ENG120990,Ratio FID 333,100.0, %
ENG120975,Ratio FID 52,100.0, %
ENG120976,Ratio FID 53,100.0, %
ENG120977,Ratio FID 54,100.0, %
ENG120978,Ratio FID 55,100.0, %
ENG120986,Ratio FID 56,100.0, %
ENG120973,Ratio FID 57,100.0, %
ENG120974,Ratio FID 58,100.0, %
ENG120979,Ratio FID 78,100.0, %
ENG120980,Ratio FID 79,100.0, %
ENG120981,Ratio FID 80,100.0, %
ENG120982,Ratio FID 81,100.0, %
ENG120983,Ratio FID 82,100.0, %
ENG120984,Ratio FID 83,100.0, %
ENG120985,Ratio FID 84,100.0, %
ENG100188,Reached maximum temperature control module,112, °C
ENG123020-ENG102793,Rollwiderstand-Road Resistance,0.0, %
ENG102748,Selector lever error flags,00 00,
ENG122375-ENG122573,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag,ABS-Flag nicht gesetzt,
ENG122375-ENG122571,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag,ASR-Flag nicht gesetzt,
ENG122375-ENG122570,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag,CHS1 oder CHS2 oder beide ausgeschaltet,
ENG122375-ENG122574,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag,EDS-Flag nicht gesetzt,
ENG122375-ENG122575,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag,FDR-Flag nicht gesetzt,
ENG122375-ENG122563,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag,GV1-Flag nicht gesetzt,
ENG122375-ENG122564,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag,GV2-Flag nicht gesetzt,
ENG122375-ENG122565,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag,GV3-Flag nicht gesetzt,
ENG122375-ENG122566,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag,GV4-Flag nicht gesetzt,
ENG122375-ENG122569,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag,MPX-Flag nicht gesetzt,
ENG122375-ENG122572,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag,MSR-Flag nicht gesetzt,
ENG122375-ENG122567,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag,SV1-Flag nicht gesetzt,
ENG122375-ENG122568,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag,SV2-Flag nicht gesetzt,
ENG122375-ENG122576,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag,Tipp-Gasse-Flag nicht gesetzt,
ENG122375-ENG122578,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag,Tipp-hoch-Flag nicht gesetzt,
ENG122375-ENG122577,Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag,Tipp-runter-Flag nicht gesetzt,
ENG122369,Snapshot 1 Iststrom Hauptdruckventil,0, mA
ENG122367,Snapshot 1 Kupplungszustand,New,
ENG122371,Snapshot 1 unterer Strompunkt Adaption K1,0, mA
ENG122372,Snapshot 1 unterer Strompunkt Adaption K2,0, mA
ENG122376-ENG122573,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag,ABS-Flag nicht gesetzt,
ENG122376-ENG122571,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag,ASR-Flag nicht gesetzt,
ENG122376-ENG122570,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag,CHS1 oder CHS2 oder beide ausgeschaltet,
ENG122376-ENG122574,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag,EDS-Flag nicht gesetzt,
ENG122376-ENG122575,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag,FDR-Flag nicht gesetzt,
ENG122376-ENG122563,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag,GV1-Flag nicht gesetzt,
ENG122376-ENG122564,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag,GV2-Flag nicht gesetzt,
ENG122376-ENG122565,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag,GV3-Flag nicht gesetzt,
ENG122376-ENG122566,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag,GV4-Flag nicht gesetzt,
ENG122376-ENG122569,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag,MPX-Flag nicht gesetzt,
ENG122376-ENG122572,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag,MSR-Flag nicht gesetzt,
ENG122376-ENG122567,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag,SV1-Flag nicht gesetzt,
ENG122376-ENG122568,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag,SV2-Flag nicht gesetzt,
ENG122376-ENG122576,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag,Tipp-Gasse-Flag nicht gesetzt,
ENG122376-ENG122578,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag,Tipp-hoch-Flag nicht gesetzt,
ENG122376-ENG122577,Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag,Tipp-runter-Flag nicht gesetzt,
ENG122370,Snapshot 2 Iststrom Hauptdruckventil,0, mA
ENG122368,Snapshot 2 Kupplungszustand,New,
ENG122373,Snapshot 2 unterer Strompunkt Adaption K1,0, mA
ENG122374,Snapshot 2 unterer Strompunkt Adaption K2,0, mA
ENG120921,Sollgang der Fahrstrategie, R,
ENG101057,Specified idle speed,760, /min
ENG100803,Speed: output,0, /min
ENG122358-ENG122550,Start Stopp Statusinformationen aktuell-GE_StartStopp_Info,Stop release,
ENG122358-ENG122551,Start Stopp Statusinformationen aktuell-MO_StartStopp_Status,1,
ENG122358-ENG122500,Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 1,48,
ENG122358-ENG122501,Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 2,0,
ENG122358-ENG122546,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 1,not active,
ENG122358-ENG122547,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 2,not active,
ENG122358-ENG122548,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 3,not active,
ENG122358-ENG122549,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 4,not active,
ENG122358-ENG122552,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 5,not active,
ENG122358-ENG122553,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 6,not active,
ENG122358-ENG122554,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 8,not active,
ENG120924,Strom oberer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption,1000, mA
ENG120926,Strom oberer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption,1000, mA
ENG120923,Strom unterer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption,215, mA
ENG120925,Strom unterer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption,225, mA
ENG120935,Synchronposition Seite A: Gangsteller 1-3,44.99, %
ENG120936,Synchronposition Seite A: Gangsteller 2-4,45.17, %
ENG120937,Synchronposition Seite A: Gangsteller 5-N,49.66, %
ENG120938,Synchronposition Seite A: Gangsteller 6-R,46.75, %
ENG120947,Synchronposition Seite B: Gangsteller 1-3,54.89, %
ENG120948,Synchronposition Seite B: Gangsteller 2-4,54.87, %
ENG120949,Synchronposition Seite B: Gangsteller 5-N,53.51, %
ENG120950,Synchronposition Seite B: Gangsteller 6-R,54.11, %
ENG120999,Tastverhältnis Sicherheitsventil 1,18.0, %
ENG121000,Tastverhältnis Sicherheitsventil 2,18.0, %
ENG120991,Unterer adaptierter Kupplungspunkt K1 aus Mikroschlupfadaption,255, mA
ENG120992,Unterer adaptierter Kupplungspunkt K2 aus Mikroschlupfadaption,250, mA
ENG120960,Unterzustand Gangstelleradaption,Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX,
ENG120956,Unterzustand Gangstelleradaption zum Zeitpunkt eines Abbruchs,Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX,
ENG101346,Version info driving strategy,Temic,
ENG109005,Voltage Common Highside 1,14.4, V
ENG99955,Voltage Common Highside 2,14.3, V
ENG120922,Vorwahlgang der Fahrstrategie, 2,
ENG120952,Zählerstände der Hauptdruckadaption:Abbruchzähler auf K1,0,
ENG120954,Zählerstände der Hauptdruckadaption:Abbruchzähler auf K2,0,
ENG120951,Zählerstände der Hauptdruckadaption:Erfolgszähler auf K1,3323,
ENG120953,Zählerstände der Hauptdruckadaption:Erfolgszähler auf K2,2457,
ENG120959,Zustand Gangstelleradaption,Synchron_GSA_AUS,
ENG120955,Zustand Gangstelleradaption zum Zeitpunkt eines Abbruchs,Synchron_GSA_AUS,
Elapsed Time: 00:22
blockmap-03-5Q0-907-379-M_WAUZZZ8V8F1029358-20241020-1529.CSV
;SW:5Q0-907-379-M   HW:5Q0-907-379-H ---  ABS Brakes
;Component:ESC           H31 0571, Coding:31F193A254222A75017A070541CB698CC92A5480E08296F6F84150880608
;EV_Brake1UDSContiMK100IPB,033001,EV_Brake1UDSContiMK100IPB_033_VW48.rod
;Sunday,20,October,2024,15:29:28:49859
;VCID: 46D28FD8782BC10A257-8012
IDE00609-MAS01156,Communication status of data bus 1-Communication status,|Control module,Communication status|Engine Electronics
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator pedal position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,Malfunction,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,Open,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,8V29358,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency braking display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,-0.09375, m/s²
IDE02492,Start/Stop Function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,Not available due to specific system,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,Not available due to specific system,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll back detection,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll back detection,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,4,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,81,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,2,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll back detection,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,61,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,0,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,6,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll back detection,0,
IDE03127,Prevented stop processes (ring memory),0,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03127,Prevented stop processes (ring memory),Emerg.brake,
IDE03127,Prevented stop processes (ring memory),AUTO HOLD slippage recognition,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2019,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2126,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,14,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,8,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,9,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,2,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,14,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,19,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,30,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,21,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,62,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,4,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,42,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,55,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,44,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,58,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,62,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,53,
IDE03128,Requested start processes (ring memory),AUTO HOLD slippage recognition,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Freescale,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,19,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.005, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,14.544, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-984, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.00, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,0.000, V
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,0.000, V
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Malfunction,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,Malfunction,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,Malfunction,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04442-IDE02955,Vacuum sensor-System status,Not available due to specific system,
IDE04442,Vacuum sensor,-984, mbar
IDE04442-ENG159801,Vacuum sensor-calender week,10,
IDE04442-ENG118177,Vacuum sensor-error codes,0,
IDE04442-ENG98729,Vacuum sensor-Manufacturer code,0,
IDE04442-ENG118176,Vacuum sensor-manufacturer type,2,
IDE04442-ENG159802,Vacuum sensor-serial number ID 1,265,
IDE04442-ENG159803,Vacuum sensor-serial number ID 2,2575,
IDE04442-ENG159804,Vacuum sensor-serial number ID 3,387,
IDE04442-ENG99063,Vacuum sensor-Year,14,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,-0.39240, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,0.03924, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.39240, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.00000, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,-0.092, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,3.981, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,3.981, °
IDE04446-IDE01599,Hill descent control-Incline,0, %
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not available due to specific system,
IDE04452-IDE03664,Brake system button-Button for driving program,Not available due to specific system,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not available due to specific system,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE02955,Brake disk drying-System status,available.,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,90350, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MQ8RAM00087,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,completed successfully,
IDE04461-MAS01481,Internal measured values-Temperature in control module,42, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TS7BAD00007,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not detected,
IDE04508-IDE02955,Hydraulic brake booster-System status,Not available due to specific system,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,-984, mbar
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.00, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,Malfunction,
IDE04644-IDE02955,Roll-over protection-System status,Not available due to specific system,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,available.,
IDE04645-IDE03493,Electromechanical parking brake-Driver's door status,activated,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,activated,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04646-IDE02657,Electromechanical parking brake: parking brake motors-Cut-off current: left: reached,0.00, A
IDE04646-IDE02658,Electromechanical parking brake: parking brake motors-Cut-off current: right: reached,0.00, A
IDE04646-IDE04496,Electromechanical parking brake: parking brake motors-Left parking brake motor: status,closed,
IDE04646-IDE04497,Electromechanical parking brake: parking brake motors-Right parking brake motor: status,closed,
IDE04646-IDE04506,Electromechanical parking brake: parking brake motors-Calculated left rear brake temperature,14.0, °C
IDE04646-IDE04507,Electromechanical parking brake: parking brake motors-Calculated right rear brake temperature,14.0, °C
IDE04646-IDE04647,Electromechanical parking brake: parking brake motors-Left parking brake motor: current,0.00, A
IDE04646-IDE04648,Electromechanical parking brake: parking brake motors-Right parking brake motor: current,0.00, A
IDE04646-IDE05048,Electromechanical parking brake: parking brake motors-Left parking brake motor: actuation counter,746,
IDE04646-IDE05049,Electromechanical parking brake: parking brake motors-Right parking brake motor: actuation counter,746,
IDE04765-IDE02955,Counter steer support-System status,available.,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,91616, km
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,On,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,available.,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04871-IDE01599,Dynamic starting assist-Incline,0, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),-2, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire Pressure Monitoring System (TPMS)-System status,Not available due to specific system,
IDE04939-IDE04248,Tire Pressure Monitoring System (TPMS)-Left front tire pressure diffusion indicator,0,
IDE04939-IDE04249,Tire Pressure Monitoring System (TPMS)-Right front tire pressure diffusion indicator,0,
IDE04939-IDE04250,Tire Pressure Monitoring System (TPMS)-Left rear tire pressure diffusion indicator,0,
IDE04939-IDE04251,Tire Pressure Monitoring System (TPMS)-Right rear tire pressure diffusion indicator,0,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,0, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,0, km
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,0, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,0, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,0, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS04544,Tire Pressure Monitoring System (TPMS)-Left front flat tire indicator,0,
IDE04939-MAS04545,Tire Pressure Monitoring System (TPMS)-Right front flat tire indicator,0,
IDE04939-MAS04546,Tire Pressure Monitoring System (TPMS)-Left rear flat tire indicator,0,
IDE04939-MAS04547,Tire Pressure Monitoring System (TPMS)-Right rear flat tire indicator,0,
IDE05712-IDE02955,AUTO HOLD-System status,Not available due to specific system,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,valid,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,OFF,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,272205,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,2288933,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,18334,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,35346,
IDE80101,Analysis 101,A3 32 38 35 31 35 34 31 31 32 31 33 30 30 30 30 36 31 34 35 31 39 30 30 31 43 39 2F 02 0A 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,90.6192, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,92.5722, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,90.6192, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,11036,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,92.5722, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,10055,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,92.5722, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,5885,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,94.5252, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,4606,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,available.,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,14.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,14.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,14.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,14.0, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake lamp switch,Not operated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,available.,
MAS00121-MAS01854,Electronic Differential Lock-Right front,available.,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,available.,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,available.,
MAS00210-IDE80007,Parking Brake-Analysis 7,63568, km
MAS00210-IDE80008,Parking Brake-Analysis 8,91836, km
MAS00210-IDE80009,Parking Brake-Analysis 9,0, km
MAS00210-IDE80010,Parking Brake-Analysis 10,37113, km
MAS00210-IDE80011,Parking Brake-Analysis 11,91836, km
MAS00210-IDE80012,Parking Brake-Analysis 12,AF 0A 51 10 02 00,
MAS00210-ENG167752,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG167753,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG167754,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG167755,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG167756,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG167757,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,available.,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, %
MAS02138-IDE02955,Hill-start assistant-System status,available.,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,Open,
MAS02138-MAS03095,Hill-start assistant-Function status,Condition not met,
MAS02426-MAS00580,Text display in instrument cluster-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument cluster-Text,0,
MAS02672-IDE02955,Start-stop-System status,available.,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
Elapsed Time: 00:10
blockmap-05-5Q0-959-435-A_WAUZZZ8V8F1029358-20241020-1529.CSV
;SW:5Q0-959-435-A   HW:5Q0-959-435 ---  Acc/Start Auth.
;Component:VWKESSYMQB    021 0604, Coding:030C0C
;EV_KessyHellaMQBAB,002011,EV_KessyHellaMQBAB_002.rod
;Sunday,20,October,2024,15:29:56:49859
;VCID: 3A2AEB283CD3B5EA51F-806E
IDE00019,Voltage terminal 30,14.679, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE02406,Key number of last identified ID sensor,ID sensor 1,
IDE02407,Status of vehicle locking,Vehicle unlocked,
IDE02408-MAS00218,Individual door locking: status-Driver door,Open,
IDE02408-MAS00219,Individual door locking: status-Front Passenger Door,closed,
IDE02408-MAS00220,Individual door locking: status-Left rear door,closed,
IDE02408-MAS00221,Individual door locking: status-Right rear door,closed,
IDE02409,ID-sensor 1 authentication: status,No response,
IDE02410,ID-sensor 2 authentication: status,No response,
IDE02411,ID-sensor 3 authentication: status,No response,
IDE02412,ID-sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,193,
IDE02419,Proximity sensor frt.pass. door: number of triggers,78,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,FF,
IDE02422-MAS01483,Driver door handle: version information-Software version,FF,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,FF,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,FF,
IDE02423-MAS01483,ass. door handle: version information-Software version,FF,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,FF,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,FF,
IDE02424-MAS01483,Left rear door handle: version information-Software version,FF,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,FF,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,FF,
IDE02425-MAS01483,Right rear door handle: version information-Software version,FF,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,FF,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,Yes,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,No,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,Yes,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,No,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,Yes,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,No,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,Yes,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,No,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,No,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,No,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72h-Signaling counter driver door,||0|,
IDE02483,72-hour signaling counter frt.pass. door,||0|,
IDE02484,72h-Signaling counter left rear door,||0|,
IDE02485,72h-Signaling counter right rear door,||0|,
IDE02486,Data logger triggering,not activated,
IDE02495-MAS00976,Service-Key: Number of activations-Counter,930,
IDE02496-MAS00976,Service-Key: Number of Timeouts-Counter,14,
IDE02497-MAS00976,Service-Key: Number of incomplete messages-Counter,2,
IDE03008-MAS05971,Stop process prevented-Missing from ECM,0,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,0,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,0,
IDE03008-MAS06119,Stop process prevented-CAN Signal: read coil operation is set,0,
IDE03010-MAS05971,Number of prevented stop processes-Missing from ECM,60,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,4,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,2257,
IDE03010-MAS06119,Number of prevented stop processes-CAN Signal: read coil operation is set,16,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2024,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,10,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,17,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,19,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,16,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,13,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,19,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,2,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,33,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,45,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,36,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,28,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,21,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,47,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,6,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,50,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,59,
IDE03127,Prevented stop processes (ring memory),2,
IDE04042-ENG151577,ID sensor history data-Scan 1 Origin,Passive Service Key,
IDE04042-ENG104152,ID sensor history data-Scan 1 Single Scan,Interior with trunk,
IDE04042-ENG151484,ID sensor history data-Scan 1 Trigger,Service key,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,00,
IDE04042-ENG151507,ID sensor history data-Scan 2 Origin,Passive Go,
IDE04042-ENG99359,ID sensor history data-Scan 2 Single Scan,Interior with trunk,
IDE04042-ENG151474,ID sensor history data-Scan 2 Trigger,Go authentication request,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,62,
IDE04042-ENG151555,ID sensor history data-Scan 3 Origin,Passive Go,
IDE04042-ENG102354,ID sensor history data-Scan 3 Single Scan,Interior with trunk,
IDE04042-ENG151486,ID sensor history data-Scan 3 Trigger,Go ID request,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,52,
IDE05204,Manufacturer production data door handle drivers door,FF FF FF FF FF,
IDE05205,Manufacturer production data door handle front pass.door,FF FF FF FF FF,
IDE05206,Manufacturer production data door handle left rear,00 00 00 00 00,
IDE05207,Manufacturer production data door handle right rear,00 00 00 00 00,
IDE07359,Dimming of starter button lighting,58 00,
ENG120048,Overtemperaturecounter for ADRIMA,0,
Elapsed Time: 00:09
blockmap-08-8V0-820-043-D_WAUZZZ8V8F1029358-20241020-1530.CSV
;SW:8V0-820-043-D   HW:8V0-820-043-D ---  Auto HVAC
;Component:AC Automat    H13 0052, Coding:03100014110000011000000000001500
;EV_AirCondiFrontVaAU37X,008020,EV_AirCondiFrontVaAU37X_008.rod
;Sunday,20,October,2024,15:30:35:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 3334C60C1BB944A2929-8066
Group,Description,Actual
IDE00019,Voltage terminal 30,14.5, V
IDE00021,Engine RPM,758.00, /min
IDE00025,Coolant temperature,94, °C
IDE00198,Refrigerant pressure,6.0, bar
IDE00767-MAS05494,No. of unscheduled ECU resets-Cause 1,1,
IDE00767-MAS05495,No. of unscheduled ECU resets-Cause 2,24,
IDE00767-MAS05496,No. of unscheduled ECU resets-Cause 3,0,
IDE00767-MAS05497,No. of unscheduled ECU resets-Cause 4,0,
IDE00767-MAS05498,No. of unscheduled ECU resets-Cause 5,0,
IDE00767-MAS05499,No. of unscheduled ECU resets-Cause 6,0,
IDE00767-MAS05793,No. of unscheduled ECU resets-Cause 7,0,
IDE00767-MAS05794,No. of unscheduled ECU resets-Cause 8,0,
IDE00965,Compressor shut-off condition,AC button off,
IDE00966,Compressor current: actual value,0.000, A
IDE00967,Compressor current: specified value,0.000, A
IDE00968,Compressor speed,900, /min
IDE00969,Compressor load,0.5, Nm
IDE00970,Coolant fan activation: actual value,10.0, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside temperature,15, °C
IDE00974,Outside air temperature internally calculated,15, °C
IDE00976,Left front vent temperature,21.5, °C
IDE00977,Right front vent temperature,22.5, °C
IDE00981,Footwell vent temperature,22.5, °C
IDE00982,Temperature downstream of evaporator,21.8, °C
IDE00983,Inside temperature,22.2, °C
IDE00984,Sun intensity left,70, W/m²
IDE00985,Sun intensity right,70, W/m²
IDE00987,Blower voltage: specified value,4.0, V
IDE00989,Blower status,active,
IDE00994,Actual value for fresh air/recirculation air flow flap,67.0, %
IDE00994,Actual value for fresh air/recirculation air flow flap,639,
IDE00995,Fresh air/recirculating air/back pressure door specified value,642,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,179,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,864,
IDE00998,Left temperature flap - actual value,0.0, %
IDE00998,Left temperature flap - actual value,101,
IDE00999,Temperature door left - Specified value,99,
IDE01040,Left Temperature Control Door - cold stop,99,
IDE01041,Left temperature flap: warm stop,908,
IDE01042,Right temperature flap: actual value,105,
IDE01042,Right temperature flap: actual value,0.0, %
IDE01043,Temperature door right - Specified value,106,
IDE01044,Right temperature flap: cold stop,106,
IDE01045,Right temperature flap: warm stop,916,
IDE01050,Front air distribution flap: actual value,314,
IDE01050,Front air distribution flap: actual value,75.0, %
IDE01051,Air distribution door front - Specified value,313,
IDE01052,Front air distribution flap: air outlet stop,932,
IDE01053,Front air distribution flap: footwell air outlet stop,107,
IDE01054,Defroster flap: actual value,929,
IDE01054,Defroster flap: actual value,100.0, %
IDE01055,Defrost door - Specified value,930,
IDE01056,Defroster flap: stop open,930,
IDE01057,Defroster flap: stop closed,60,
IDE01063,Status of recirculation air,Fresh air,
IDE01066,Convertible top status,Measuring value not available,
IDE01076,Time since ignition off,97, min
IDE01217-MAS01447,Left heated seat stage-Act.val.,0,
IDE01217-MAS01448,Left heated seat stage-Target value,0,
IDE01218-MAS01447,Right heated seat stage-Act.val.,0,
IDE01218-MAS01448,Right heated seat stage-Target value,0,
IDE01226,Blower voltage: actual value,4.0, V
IDE01227,Blower current,1.25, A
IDE01232,Supply voltage for external components,4.9, V
IDE01264,Remaining time of parking heater/ventilation operation,0, s
IDE01287,Counter of compressor switch-offs,0,
IDE01419,Compressor shut-off condition: last,Shut-off from Engine Control Module (ECM) via CAN,
IDE01420,Compressor shut-off requirement: penultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01421,Compressor shut-off requirement: antepenultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01433,Air quality status,Clean air,
IDE01442-MAS01533,Pressing a button-Defrost,Not operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,Not operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,Not operated,
IDE01442-MAS01550,Pressing a button-AC,Not operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,Not operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,Not operated,
IDE01442-MAS01560,Pressing a button-OFF,Not operated,
IDE01442-MAS02015,Pressing a button-AUTO,Not operated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,Not operated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,Not operated,
IDE01442-MAS03832,Pressing a button-Air distribution up,Not operated,
IDE01442-MAS04621,Pressing a button-Left head area heater,Not operated,
IDE01442-MAS04648,Pressing a button-Right head area heater,Not operated,
IDE01443,Left push-and-rotary knob counter,0,
IDE01444,Right push-and-rotary knob counter,0,
IDE01449-IDE01011,Personalization 1 for climate control-Data record,active,
IDE01449-MAS01533,Personalization 1 for climate control-Defrost,0,
IDE01449-MAS01534,Personalization 1 for climate control-Recirculating air,0,
IDE01449-MAS01550,Personalization 1 for climate control-AC,0,
IDE01449-MAS01552,Personalization 1 for climate control-Left specified temperature,20.0, °C
IDE01449-MAS01553,Personalization 1 for climate control-Right specified temperature,20.0, °C
IDE01449-MAS01554,Personalization 1 for climate control-Left heated seat,0,
IDE01449-MAS01555,Personalization 1 for climate control-Left seat ventilation,not installed,
IDE01449-MAS01556,Personalization 1 for climate control-Right heated seat,0,
IDE01449-MAS01557,Personalization 1 for climate control-Right seat ventilation,not installed,
IDE01449-MAS01560,Personalization 1 for climate control-OFF,0,
IDE01449-MAS01562,Personalization 1 for climate control-Air quality sensor,1,
IDE01449-MAS01563,Personalization 1 for climate control-Auxiliary Air Heater,not installed,
IDE01449-MAS01566,Personalization 1 for climate control-Style,0,
IDE01449-MAS01567,Personalization 1 for climate control-Synchronization,0,
IDE01449-MAS02015,Personalization 1 for climate control-AUTO,0,
IDE01449-MAS02804,Personalization 1 for climate control-Manual fan speed increase,11,
IDE01449-MAS03830,Personalization 1 for climate control-Footwell air distribution,1,
IDE01449-MAS03831,Personalization 1 for climate control-Upper body vent air distribution,1,
IDE01449-MAS03832,Personalization 1 for climate control-Air distribution up,1,
IDE01449-MAS04620,Personalization 1 for climate control-Fan setting: absolute,1,
IDE01449-MAS04621,Personalization 1 for climate control-Left head area heater,not installed,
IDE01449-MAS04648,Personalization 1 for climate control-Right head area heater,not installed,
IDE01449-MAS06077,Personalization 1 for climate control-Manual blower stage during defrost active,5,
IDE01449-MAS06366,Personalization 1 for climate control-Display blower levels,1,
IDE01449-ENG122610,Personalization 1 for climate control-Test_Program_Blower_Step_Absolut,2,
IDE01449-ENG122611,Personalization 1 for climate control-Test_Program_Manual fan speed increase,11,
IDE01450-IDE01011,Personalization 2 for climate control-Data record,not active,
IDE01450-MAS01533,Personalization 2 for climate control-Defrost,0,
IDE01450-MAS01534,Personalization 2 for climate control-Recirculating air,0,
IDE01450-MAS01550,Personalization 2 for climate control-AC,1,
IDE01450-MAS01552,Personalization 2 for climate control-Left specified temperature,22.0, °C
IDE01450-MAS01553,Personalization 2 for climate control-Right specified temperature,22.0, °C
IDE01450-MAS01554,Personalization 2 for climate control-Left heated seat,0,
IDE01450-MAS01555,Personalization 2 for climate control-Left seat ventilation,not installed,
IDE01450-MAS01556,Personalization 2 for climate control-Right heated seat,2,
IDE01450-MAS01557,Personalization 2 for climate control-Right seat ventilation,not installed,
IDE01450-MAS01560,Personalization 2 for climate control-OFF,0,
IDE01450-MAS01562,Personalization 2 for climate control-Air quality sensor,1,
IDE01450-MAS01563,Personalization 2 for climate control-Auxiliary Air Heater,not installed,
IDE01450-MAS01566,Personalization 2 for climate control-Style,1,
IDE01450-MAS01567,Personalization 2 for climate control-Synchronization,1,
IDE01450-MAS02015,Personalization 2 for climate control-AUTO,1,
IDE01450-MAS02804,Personalization 2 for climate control-Manual fan speed increase,11,
IDE01450-MAS03830,Personalization 2 for climate control-Footwell air distribution,0,
IDE01450-MAS03831,Personalization 2 for climate control-Upper body vent air distribution,0,
IDE01450-MAS03832,Personalization 2 for climate control-Air distribution up,0,
IDE01450-MAS04620,Personalization 2 for climate control-Fan setting: absolute,1,
IDE01450-MAS04621,Personalization 2 for climate control-Left head area heater,not installed,
IDE01450-MAS04648,Personalization 2 for climate control-Right head area heater,not installed,
IDE01450-MAS06077,Personalization 2 for climate control-Manual blower stage during defrost active,10,
IDE01450-MAS06366,Personalization 2 for climate control-Display blower levels,0,
IDE01450-ENG122610,Personalization 2 for climate control-Test_Program_Blower_Step_Absolut,14,
IDE01450-ENG122611,Personalization 2 for climate control-Test_Program_Manual fan speed increase,11,
IDE01451-IDE01011,Personalization 3 for climate control-Data record,not active,
IDE01451-MAS01533,Personalization 3 for climate control-Defrost,0,
IDE01451-MAS01534,Personalization 3 for climate control-Recirculating air,0,
IDE01451-MAS01550,Personalization 3 for climate control-AC,1,
IDE01451-MAS01552,Personalization 3 for climate control-Left specified temperature,22.0, °C
IDE01451-MAS01553,Personalization 3 for climate control-Right specified temperature,22.0, °C
IDE01451-MAS01554,Personalization 3 for climate control-Left heated seat,0,
IDE01451-MAS01555,Personalization 3 for climate control-Left seat ventilation,not installed,
IDE01451-MAS01556,Personalization 3 for climate control-Right heated seat,0,
IDE01451-MAS01557,Personalization 3 for climate control-Right seat ventilation,not installed,
IDE01451-MAS01560,Personalization 3 for climate control-OFF,0,
IDE01451-MAS01562,Personalization 3 for climate control-Air quality sensor,0,
IDE01451-MAS01563,Personalization 3 for climate control-Auxiliary Air Heater,not installed,
IDE01451-MAS01566,Personalization 3 for climate control-Style,2,
IDE01451-MAS01567,Personalization 3 for climate control-Synchronization,0,
IDE01451-MAS02015,Personalization 3 for climate control-AUTO,1,
IDE01451-MAS02804,Personalization 3 for climate control-Manual fan speed increase,11,
IDE01451-MAS03830,Personalization 3 for climate control-Footwell air distribution,0,
IDE01451-MAS03831,Personalization 3 for climate control-Upper body vent air distribution,0,
IDE01451-MAS03832,Personalization 3 for climate control-Air distribution up,0,
IDE01451-MAS04620,Personalization 3 for climate control-Fan setting: absolute,1,
IDE01451-MAS04621,Personalization 3 for climate control-Left head area heater,not installed,
IDE01451-MAS04648,Personalization 3 for climate control-Right head area heater,not installed,
IDE01451-MAS06077,Personalization 3 for climate control-Manual blower stage during defrost active,10,
IDE01451-MAS06366,Personalization 3 for climate control-Display blower levels,0,
IDE01451-ENG122610,Personalization 3 for climate control-Test_Program_Blower_Step_Absolut,14,
IDE01451-ENG122611,Personalization 3 for climate control-Test_Program_Manual fan speed increase,11,
IDE01452-IDE01011,Personalization 4 for climate control-Data record,not active,
IDE01452-MAS01533,Personalization 4 for climate control-Defrost,0,
IDE01452-MAS01534,Personalization 4 for climate control-Recirculating air,0,
IDE01452-MAS01550,Personalization 4 for climate control-AC,0,
IDE01452-MAS01552,Personalization 4 for climate control-Left specified temperature,22.0, °C
IDE01452-MAS01553,Personalization 4 for climate control-Right specified temperature,22.0, °C
IDE01452-MAS01554,Personalization 4 for climate control-Left heated seat,0,
IDE01452-MAS01555,Personalization 4 for climate control-Left seat ventilation,not installed,
IDE01452-MAS01556,Personalization 4 for climate control-Right heated seat,0,
IDE01452-MAS01557,Personalization 4 for climate control-Right seat ventilation,not installed,
IDE01452-MAS01560,Personalization 4 for climate control-OFF,0,
IDE01452-MAS01562,Personalization 4 for climate control-Air quality sensor,0,
IDE01452-MAS01563,Personalization 4 for climate control-Auxiliary Air Heater,not installed,
IDE01452-MAS01566,Personalization 4 for climate control-Style,2,
IDE01452-MAS01567,Personalization 4 for climate control-Synchronization,0,
IDE01452-MAS02015,Personalization 4 for climate control-AUTO,1,
IDE01452-MAS02804,Personalization 4 for climate control-Manual fan speed increase,11,
IDE01452-MAS03830,Personalization 4 for climate control-Footwell air distribution,0,
IDE01452-MAS03831,Personalization 4 for climate control-Upper body vent air distribution,0,
IDE01452-MAS03832,Personalization 4 for climate control-Air distribution up,0,
IDE01452-MAS04620,Personalization 4 for climate control-Fan setting: absolute,1,
IDE01452-MAS04621,Personalization 4 for climate control-Left head area heater,not installed,
IDE01452-MAS04648,Personalization 4 for climate control-Right head area heater,not installed,
IDE01452-MAS06077,Personalization 4 for climate control-Manual blower stage during defrost active,10,
IDE01452-MAS06366,Personalization 4 for climate control-Display blower levels,0,
IDE01452-ENG122610,Personalization 4 for climate control-Test_Program_Blower_Step_Absolut,14,
IDE01452-ENG122611,Personalization 4 for climate control-Test_Program_Manual fan speed increase,11,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE03008-IDE80251,Stop process prevented-Head area heater,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Blowout temperature difference to specifications,not active,
IDE03009-IDE80251,Start process requested-Head area heater,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS02802,Start process requested-Interior temperature difference to specifications,not active,
IDE03009-MAS02803,Start process requested-Blowout temperature difference to specifications,not active,
IDE03009-MAS03904,Start process requested-Maximum permissible stop duration reached,not active,
IDE03009-MAS04353,Start process requested-Fogging hazard (humidity sensor),not active,
IDE03009-MAS04354,Start process requested-Interior comfort humidity too high (humidity sensor),not active,
IDE03009-MAS05047,Start process requested-Maximum cooling and heating set,not active,
IDE03010-IDE80251,Number of prevented stop processes-Head area heater,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,80,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,317,
IDE03010-MAS02803,Number of prevented stop processes-Blowout temperature difference to specifications,659,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),13,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),130,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,178,
IDE03011-IDE80251,Number of requested start processes-Head area heater,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,1,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Blowout temperature difference to specifications,11,
IDE03011-MAS03904,Number of requested start processes-Maximum permissible stop duration reached,14,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,16,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,14,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,51,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,37,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,46,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,31,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,20,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,18,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,22,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,13,
IDE03127,Prevented stop processes (ring memory),Blowout temperature difference to specifications,
IDE03127,Prevented stop processes (ring memory),Fogging hazard (humidity sensor),
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2022,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,6,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,5,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,7,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,5,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,30,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,11,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,12,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,15,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,18,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,10,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,57,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,2,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,30,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,33,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,5,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,41,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,11,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,22,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,24,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,1,
IDE03128,Requested start processes (ring memory),Blowout temperature difference to specifications,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,253, s
IDE04312-MAS00084,System run time-Terminal 15 on,253, s
IDE04797,Center push-and-rotary knob counter,0,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE04805-MAS03559,Driving profile selection-System status 1,1,
IDE04805-MAS03917,Driving profile selection-Driver's request,0,
IDE04805-MAS05471,Driving profile selection-Efficiency,Efficiency mode not active,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,216,
IDE06091-MAS04647,Humidity sensor: interior-Dew point,13.5, °C
IDE06091,Humidity sensor: interior,-36.0, °C
IDE06091,Humidity sensor: interior,not installed,
IDE06091,Humidity sensor: interior,Unknown (572)
IDE06091-ENG122608,Humidity sensor: interior-Test_Program_relative_humidity,76.5, %
IDE06091-ENG122607,Humidity sensor: interior-Test_Program_sensor_temperature,17.5, °C
IDE06091-ENG122606,Humidity sensor: interior-Test_Program_windshield_temperature,17.6, °C
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,21.8, °C
IDE06163-MAS04629,Humidity sensor: exterior-Sensor temperature,26.9, °C
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,0.0, %
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,16.3, °C
IDE06163-ENG122609,Humidity sensor: exterior-Test_Program_Air temperature,21.8, °C
IDE06163-ENG122608,Humidity sensor: exterior-Test_Program_relative_humidity,52.0, %
IDE06163-ENG122607,Humidity sensor: exterior-Test_Program_sensor_temperature,26.9, °C
IDE06219-IDE01011,Personalization 1 for climate control: top open-Data record,not active,
IDE06219-MAS01533,Personalization 1 for climate control: top open-Defrost,0,
IDE06219-MAS01534,Personalization 1 for climate control: top open-Recirculating air,0,
IDE06219-MAS01550,Personalization 1 for climate control: top open-AC,0,
IDE06219-MAS01552,Personalization 1 for climate control: top open-Left specified temperature,22.0, °C
IDE06219-MAS01553,Personalization 1 for climate control: top open-Right specified temperature,22.0, °C
IDE06219-MAS01554,Personalization 1 for climate control: top open-Left heated seat,0,
IDE06219-MAS01555,Personalization 1 for climate control: top open-Left seat ventilation,not installed,
IDE06219-MAS01556,Personalization 1 for climate control: top open-Right heated seat,0,
IDE06219-MAS01557,Personalization 1 for climate control: top open-Right seat ventilation,not installed,
IDE06219-MAS01560,Personalization 1 for climate control: top open-OFF,0,
IDE06219-MAS01562,Personalization 1 for climate control: top open-Air quality sensor,0,
IDE06219-MAS01563,Personalization 1 for climate control: top open-Auxiliary Air Heater,not installed,
IDE06219-MAS01566,Personalization 1 for climate control: top open-Style,2,
IDE06219-MAS01567,Personalization 1 for climate control: top open-Synchronization,0,
IDE06219-MAS02015,Personalization 1 for climate control: top open-AUTO,1,
IDE06219-MAS02804,Personalization 1 for climate control: top open-Manual fan speed increase,11,
IDE06219-MAS03830,Personalization 1 for climate control: top open-Footwell air distribution,0,
IDE06219-MAS03831,Personalization 1 for climate control: top open-Upper body vent air distribution,0,
IDE06219-MAS03832,Personalization 1 for climate control: top open-Air distribution up,0,
IDE06219-MAS04620,Personalization 1 for climate control: top open-Fan setting: absolute,1,
IDE06219-MAS04621,Personalization 1 for climate control: top open-Left head area heater,not installed,
IDE06219-MAS04648,Personalization 1 for climate control: top open-Right head area heater,not installed,
IDE06219-MAS06077,Personalization 1 for climate control: top open-Manual blower stage during defrost active,5,
IDE06219-MAS06366,Personalization 1 for climate control: top open-Display blower levels,0,
IDE06219-ENG122610,Personalization 1 for climate control: top open-Test_Program_Blower_Step_Absolut,14,
IDE06219-ENG122611,Personalization 1 for climate control: top open-Test_Program_Manual fan speed increase,11,
IDE06220-IDE01011,Personalization 2 for climate control: top open-Data record,not active,
IDE06220-MAS01533,Personalization 2 for climate control: top open-Defrost,0,
IDE06220-MAS01534,Personalization 2 for climate control: top open-Recirculating air,0,
IDE06220-MAS01550,Personalization 2 for climate control: top open-AC,0,
IDE06220-MAS01552,Personalization 2 for climate control: top open-Left specified temperature,22.0, °C
IDE06220-MAS01553,Personalization 2 for climate control: top open-Right specified temperature,22.0, °C
IDE06220-MAS01554,Personalization 2 for climate control: top open-Left heated seat,0,
IDE06220-MAS01555,Personalization 2 for climate control: top open-Left seat ventilation,not installed,
IDE06220-MAS01556,Personalization 2 for climate control: top open-Right heated seat,2,
IDE06220-MAS01557,Personalization 2 for climate control: top open-Right seat ventilation,not installed,
IDE06220-MAS01560,Personalization 2 for climate control: top open-OFF,0,
IDE06220-MAS01562,Personalization 2 for climate control: top open-Air quality sensor,0,
IDE06220-MAS01563,Personalization 2 for climate control: top open-Auxiliary Air Heater,not installed,
IDE06220-MAS01566,Personalization 2 for climate control: top open-Style,2,
IDE06220-MAS01567,Personalization 2 for climate control: top open-Synchronization,0,
IDE06220-MAS02015,Personalization 2 for climate control: top open-AUTO,1,
IDE06220-MAS02804,Personalization 2 for climate control: top open-Manual fan speed increase,11,
IDE06220-MAS03830,Personalization 2 for climate control: top open-Footwell air distribution,0,
IDE06220-MAS03831,Personalization 2 for climate control: top open-Upper body vent air distribution,0,
IDE06220-MAS03832,Personalization 2 for climate control: top open-Air distribution up,0,
IDE06220-MAS04620,Personalization 2 for climate control: top open-Fan setting: absolute,1,
IDE06220-MAS04621,Personalization 2 for climate control: top open-Left head area heater,not installed,
IDE06220-MAS04648,Personalization 2 for climate control: top open-Right head area heater,not installed,
IDE06220-MAS06077,Personalization 2 for climate control: top open-Manual blower stage during defrost active,10,
IDE06220-MAS06366,Personalization 2 for climate control: top open-Display blower levels,0,
IDE06220-ENG122610,Personalization 2 for climate control: top open-Test_Program_Blower_Step_Absolut,14,
IDE06220-ENG122611,Personalization 2 for climate control: top open-Test_Program_Manual fan speed increase,11,
IDE06221-IDE01011,Personalization 3 for climate control: top open-Data record,not active,
IDE06221-MAS01533,Personalization 3 for climate control: top open-Defrost,0,
IDE06221-MAS01534,Personalization 3 for climate control: top open-Recirculating air,0,
IDE06221-MAS01550,Personalization 3 for climate control: top open-AC,0,
IDE06221-MAS01552,Personalization 3 for climate control: top open-Left specified temperature,22.0, °C
IDE06221-MAS01553,Personalization 3 for climate control: top open-Right specified temperature,22.0, °C
IDE06221-MAS01554,Personalization 3 for climate control: top open-Left heated seat,0,
IDE06221-MAS01555,Personalization 3 for climate control: top open-Left seat ventilation,not installed,
IDE06221-MAS01556,Personalization 3 for climate control: top open-Right heated seat,0,
IDE06221-MAS01557,Personalization 3 for climate control: top open-Right seat ventilation,not installed,
IDE06221-MAS01560,Personalization 3 for climate control: top open-OFF,0,
IDE06221-MAS01562,Personalization 3 for climate control: top open-Air quality sensor,0,
IDE06221-MAS01563,Personalization 3 for climate control: top open-Auxiliary Air Heater,not installed,
IDE06221-MAS01566,Personalization 3 for climate control: top open-Style,2,
IDE06221-MAS01567,Personalization 3 for climate control: top open-Synchronization,0,
IDE06221-MAS02015,Personalization 3 for climate control: top open-AUTO,1,
IDE06221-MAS02804,Personalization 3 for climate control: top open-Manual fan speed increase,11,
IDE06221-MAS03830,Personalization 3 for climate control: top open-Footwell air distribution,0,
IDE06221-MAS03831,Personalization 3 for climate control: top open-Upper body vent air distribution,0,
IDE06221-MAS03832,Personalization 3 for climate control: top open-Air distribution up,0,
IDE06221-MAS04620,Personalization 3 for climate control: top open-Fan setting: absolute,1,
IDE06221-MAS04621,Personalization 3 for climate control: top open-Left head area heater,not installed,
IDE06221-MAS04648,Personalization 3 for climate control: top open-Right head area heater,not installed,
IDE06221-MAS06077,Personalization 3 for climate control: top open-Manual blower stage during defrost active,10,
IDE06221-MAS06366,Personalization 3 for climate control: top open-Display blower levels,0,
IDE06221-ENG122610,Personalization 3 for climate control: top open-Test_Program_Blower_Step_Absolut,14,
IDE06221-ENG122611,Personalization 3 for climate control: top open-Test_Program_Manual fan speed increase,11,
IDE06222-IDE01011,Personalization 4 for climate control: top open-Data record,not active,
IDE06222-MAS01533,Personalization 4 for climate control: top open-Defrost,0,
IDE06222-MAS01534,Personalization 4 for climate control: top open-Recirculating air,0,
IDE06222-MAS01550,Personalization 4 for climate control: top open-AC,0,
IDE06222-MAS01552,Personalization 4 for climate control: top open-Left specified temperature,22.0, °C
IDE06222-MAS01553,Personalization 4 for climate control: top open-Right specified temperature,22.0, °C
IDE06222-MAS01554,Personalization 4 for climate control: top open-Left heated seat,0,
IDE06222-MAS01555,Personalization 4 for climate control: top open-Left seat ventilation,not installed,
IDE06222-MAS01556,Personalization 4 for climate control: top open-Right heated seat,0,
IDE06222-MAS01557,Personalization 4 for climate control: top open-Right seat ventilation,not installed,
IDE06222-MAS01560,Personalization 4 for climate control: top open-OFF,0,
IDE06222-MAS01562,Personalization 4 for climate control: top open-Air quality sensor,0,
IDE06222-MAS01563,Personalization 4 for climate control: top open-Auxiliary Air Heater,not installed,
IDE06222-MAS01566,Personalization 4 for climate control: top open-Style,2,
IDE06222-MAS01567,Personalization 4 for climate control: top open-Synchronization,0,
IDE06222-MAS02015,Personalization 4 for climate control: top open-AUTO,1,
IDE06222-MAS02804,Personalization 4 for climate control: top open-Manual fan speed increase,11,
IDE06222-MAS03830,Personalization 4 for climate control: top open-Footwell air distribution,0,
IDE06222-MAS03831,Personalization 4 for climate control: top open-Upper body vent air distribution,0,
IDE06222-MAS03832,Personalization 4 for climate control: top open-Air distribution up,0,
IDE06222-MAS04620,Personalization 4 for climate control: top open-Fan setting: absolute,1,
IDE06222-MAS04621,Personalization 4 for climate control: top open-Left head area heater,not installed,
IDE06222-MAS04648,Personalization 4 for climate control: top open-Right head area heater,not installed,
IDE06222-MAS06077,Personalization 4 for climate control: top open-Manual blower stage during defrost active,10,
IDE06222-MAS06366,Personalization 4 for climate control: top open-Display blower levels,0,
IDE06222-ENG122610,Personalization 4 for climate control: top open-Test_Program_Blower_Step_Absolut,14,
IDE06222-ENG122611,Personalization 4 for climate control: top open-Test_Program_Manual fan speed increase,11,
IDE06234-MAS01447,Auxiliary heater: in stages-Act.val.,0,
IDE06234-MAS01448,Auxiliary heater: in stages-Target value,0,
IDE06279-IDE00707,Parking heater: customer setting-Operating mode,Comfort function,
IDE06279-MAS00106,Parking heater: customer setting-Year,2000,
IDE06279-MAS00107,Parking heater: customer setting-Month,1,
IDE06279-MAS00108,Parking heater: customer setting-Day,1,
IDE06279-MAS00109,Parking heater: customer setting-Hours,0,
IDE06279-MAS00110,Parking heater: customer setting-Minutes,0,
IDE06279-MAS01379,Parking heater: customer setting-Operating time,0, min
IDE06279,Parking heater: customer setting,Time 2,
IDE06279,Parking heater: customer setting,Time 3,
IDE06279,Parking heater: customer setting,not active,
IDE06279,Parking heater: customer setting,Time 1,
IDE06545,Blower voltage for production routines,7, V
IDE06546,Interior specified temperature for production routines,22, °C
IDE06547,Air distribution for production routines,Air distribution upper body vents and footwell,
IDE06593,Air recirculation for production routines,Recirculating air,
IDE06750-IDE01011,Last customer settings-Data record,active,
IDE06750-MAS01533,Last customer settings-Defrost,0,
IDE06750-MAS01534,Last customer settings-Recirculating air,0,
IDE06750-MAS01550,Last customer settings-AC,0,
IDE06750-MAS01552,Last customer settings-Left specified temperature,20.0, °C
IDE06750-MAS01553,Last customer settings-Right specified temperature,20.0, °C
IDE06750-MAS01554,Last customer settings-Left heated seat,0,
IDE06750-MAS01555,Last customer settings-Left seat ventilation,not installed,
IDE06750-MAS01556,Last customer settings-Right heated seat,0,
IDE06750-MAS01557,Last customer settings-Right seat ventilation,not installed,
IDE06750-MAS01560,Last customer settings-OFF,0,
IDE06750-MAS01562,Last customer settings-Air quality sensor,1,
IDE06750-MAS01563,Last customer settings-Auxiliary Air Heater,not installed,
IDE06750-MAS01566,Last customer settings-Style,0,
IDE06750-MAS01567,Last customer settings-Synchronization,0,
IDE06750-MAS02015,Last customer settings-AUTO,0,
IDE06750-MAS02804,Last customer settings-Manual fan speed increase,11,
IDE06750-MAS03830,Last customer settings-Footwell air distribution,1,
IDE06750-MAS03831,Last customer settings-Upper body vent air distribution,1,
IDE06750-MAS03832,Last customer settings-Air distribution up,1,
IDE06750-MAS04620,Last customer settings-Fan setting: absolute,1,
IDE06750-MAS04621,Last customer settings-Left head area heater,not installed,
IDE06750-MAS04648,Last customer settings-Right head area heater,not installed,
IDE06750-MAS06077,Last customer settings-Manual blower stage during defrost active,5,
IDE06750-MAS06366,Last customer settings-Display blower levels,1,
IDE06750-ENG122610,Last customer settings-Test_Program_Blower_Step_Absolut,2,
IDE06750-ENG122611,Last customer settings-Test_Program_Manual fan speed increase,11,
IDE06926-MAS00106,History memory: reset counter-Year,2024,
IDE06926-MAS00107,History memory: reset counter-Month,8,
IDE06926-MAS00107,History memory: reset counter-Month,2,
IDE06926-MAS00108,History memory: reset counter-Day,26,
IDE06926-MAS00108,History memory: reset counter-Day,27,
IDE06926-MAS00109,History memory: reset counter-Hours,14,
IDE06926-MAS00109,History memory: reset counter-Hours,0,
IDE06926-MAS00109,History memory: reset counter-Hours,15,
IDE06926-MAS00110,History memory: reset counter-Minutes,1,
IDE06926-MAS00110,History memory: reset counter-Minutes,53,
IDE06926-MAS00110,History memory: reset counter-Minutes,51,
IDE06926-MAS00110,History memory: reset counter-Minutes,15,
IDE06926-MAS00111,History memory: reset counter-Seconds,32,
IDE06926-MAS00111,History memory: reset counter-Seconds,46,
IDE06926-MAS00111,History memory: reset counter-Seconds,27,
IDE06926-MAS00111,History memory: reset counter-Seconds,50,
IDE06926-MAS00111,History memory: reset counter-Seconds,40,
IDE06926,History memory: reset counter,Cause 2,
IDE07953-MAS01447,Left heated head area stage-Act.val.,0,
IDE07953-MAS01448,Left heated head area stage-Target value,0,
IDE07954-MAS01447,Right heated head area stage-Act.val.,0,
IDE07954-MAS01448,Right heated head area stage-Target value,0,
MAS00464-MAS00106,Standard - ambient data 1-Year,2024,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,19,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,30,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,39,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,201,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,91836, km
Elapsed Time: 00:16
blockmap-09-5Q0-937-085-AC_WAUZZZ8V8F1029358-20241020-1531.CSV
;SW:5Q0-937-085-AC   HW:5Q0-937-085-AC ---  Cent. Elect.
;Component:BCM MQBAB HNA H18 0134, Coding:07151C46C24106FD01804004B11807A80800000000000000000000000000
;EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
;Sunday,20,October,2024,15:31:22:49859
;VCID: 7AAA2B287C5375EA11F-802E
IDE00550,Identification of parameterization,20 24,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,Measuring value not available,
IDE00973,Outside temperature,15.00, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01537-IDE04742,Front windshield heater-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Front windshield heater-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Front windshield heater-Activation,not coded/not installed,
IDE01943,Turn signal lamp,|Connector number,Connector terminal number
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote control lock switch,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,closed,
IDE02092-MAS02447,Tailgate condition-Release,Enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,closed,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not active,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,No,
IDE02515,Low beam,|Connector number,Connector terminal number
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-ENG147367,Terminal signals and start release-Status_Terminal_15_BCM,active,
IDE02588-ENG147366,Terminal signals and start release-terminal_15_2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not coded/not installed,
IDE02711,Rear wiper,not coded/not installed,
IDE02743,High Beam,Write only channel,
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE05533,Activation current-Heater for nozzles,0, mA
IDE02857-IDE06012,Activation current-Background lighting,0, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02957,Ambient lighting,|Channel,Connector number
IDE03111,Interior lighting,Write only channel,
IDE03310,Brake lamp,|Connector number,Connector terminal number
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,20.00, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,21.50, °C
IDE03504,Personalized settings,|profile,Comfort opening
IDE03638,Stationary cornering lamp,Write only channel,
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04925,Daytime running lights,Write only channel,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,22.50, %
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS03638,Front wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,163300,
IDE05323,Fog lamp,Write only channel,
IDE05434,Rear entry light,Write only channel,
IDE05533,Heater for nozzles,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not active,
IDE05719-MAS02341,Window washer system-Rear window washer system,not coded/not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,Not operated,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not coded/not installed,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,Not operated,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE05730,Luggage compartment light,Write only channel,
IDE05739,Footwell lamp,|Connector number,Connector terminal number
IDE05742-IDE02515,Light switch position-Low beam,Not operated,
IDE05742-IDE05323,Light switch position-Fog lamp,Not operated,
IDE05742-IDE07956,Light switch position-redundant signal line,Position lamps,
IDE05742-MAS00063,Light switch position-OFF,Not operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,operated,
IDE05742-MAS03835,Light switch position-Position lamps,Not operated,
IDE05742-MAS03836,Light switch position-Rear fog lamp,Not operated,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not active,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,No,
IDE05824-MAS04583,DWA Vehicle inclination sensor: angle-Reference angle: X-axis,-19.40, °
IDE05824-MAS04584,DWA Vehicle inclination sensor: angle-Reference angle: Y-axis,17.40, °
IDE05824-MAS04585,DWA Vehicle inclination sensor: angle-Reference angle: Z-axis,Implausible,
IDE05824-MAS04586,DWA Vehicle inclination sensor: angle-Angle difference: X-axis,0.00, °
IDE05824-MAS04587,DWA Vehicle inclination sensor: angle-Angle difference: Y-axis,0.00, °
IDE05824-MAS04588,DWA Vehicle inclination sensor: angle-Angle difference: Z-axis,Implausible,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,Not operated,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not active,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded/not installed,
IDE05828-MAS06608,DWA History data for alarm triggering-Cause for last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06609,DWA History data for alarm triggering-Cause for second-to-last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06610,DWA History data for alarm triggering-Cause for third-to-last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06611,DWA History data for alarm triggering-Cause for fourth-to-last alarm activation,Alarm trigger by battery monitor,
IDE05828-MAS06613,DWA History data for alarm triggering-Number of alarm activations,29,
IDE05829,Rear spoiler history data,|Spoiler_Activation_Trigger,Spoiler_Activation_Trigger_Date
IDE05830-MAS02282,Rear Spoiler-Position,not coded/not installed,
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05832,DWA Number of alarms triggered in anti-theft warn.system sensor,25,
IDE05833,Anti-theft warning system: history data,|Cause for alarm activation,Odometer reading
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,4400, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,4608, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE05839,Parking lamps,|Connector number,Connector terminal number
IDE05841,Central locking history data,|Control-section / cause,Operating dir.
IDE05842,Comfort function history data,|Control-section / cause,Operating command
IDE06012,Background lighting,Write only channel,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,17.6, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,18.0, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,76.5, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,13.2, °C
IDE06096-IDE03111,Interior lights-Interior lighting,100, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,88.00, %
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,0.00, %
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,75.00, %
IDE06096-MAS01634,Interior lights-Supply voltage,100.00, %
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,0, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06470,Periphery lighting,Write only channel,
IDE06507-IDE01164,Button in center console-Parking aid button,not coded/not installed,
IDE06507-IDE02322,Button in center console-Parking aid indicator light,not coded/not installed,
IDE06507-IDE03664,Button in center console-Button for driving program,not coded/not installed,
IDE06507-IDE04806,Button in center console-Driving profile selection button,Not operated,
IDE06507-IDE05037,Button in center console-Driving program indicator lamp,not coded/not installed,
IDE06507-IDE05532,Button in center console-Indicator light in button for start/stop mode,OFF,
IDE06507-IDE05572,Button in center console-Button for start-stop operation,Not operated,
IDE06507-IDE05575,Button in center console-Indicator lamp in the driving profile selection button,OFF,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lamps,not coded/not installed,
IDE06644-MAS00145,Vehicle positioning system-Starter lock,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Position lamps,not coded/not installed,
IDE06695,Energy management: last critical state,|negative charge balance,Number of critical operation cycles
IDE06864,Daytime running lamps,|Connector number,Connector terminal number
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,0, %
IDE07344-MAS02447,Sunroof shade-Release,active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Not operated,
IDE07345,Sunroof front closed position switch,Not operated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,closed,
IDE07346,Sunroof shade switches,Not operated,
IDE08125-MAS01458,Left head area heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08125-MAS06652,Left head area heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left head area heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right head area heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right head area heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right head area heater-Indicator light for head area heater,not coded/not installed,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,6, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,4, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,714, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,720, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,30, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,20, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,1, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,91, mA
IDE09596-ENG147409,LED bar LIN slave-Blinkfrequenz,0.00, Hz
IDE09596-ENG147277,LED bar LIN slave-Brightness,0,
IDE09734-ENG147407,LED bar LIN master-Filterzeit Anpassung,not coded/not installed,
IDE09734-ENG147406,LED bar LIN master-Filterzeit Umgebungshelligkeit,not coded/not installed,
IDE09734-ENG147410,LED bar LIN master-Kombi Fototransistorwert gefiltert,0.00,
IDE09734-ENG147405,LED bar LIN master-Lockout time,not coded/not installed,
IDE09734-ENG147413,LED bar LIN master-Plausiblitaet Kombi Fototransisor gefiltert zu RLS Sensorwert berechnet: gefiltert,not coded/not installed,
IDE09734-ENG147411,LED bar LIN master-RLS Sensorwert berechnet: gefiltert,0,
IDE09734-ENG147414,LED bar LIN master-Zaehler fuer unplausible Sensorwerte,0,
IDE09734-ENG147412,LED bar LIN master-Zustand_LEDLeiste,not coded/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,14.55, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,14.55, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,14.55, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,14.55, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Terminal 30 power supply-Supply voltage for seat heater,14.55, V
MAS00043-MAS00362,Terminal 30 power supply-Battery voltage,5.00, V
MAS00043-MAS07472,Terminal 30 power supply-Battery voltage BEM,14.65, V
MAS00043-MAS07473,Terminal 30 power supply-Test voltage rear window defogger,0.32, V
MAS00043-MAS07474,Terminal 30 power supply-Test voltage windshield defogger,0.00, V
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,OFF,
MAS00829-MAS00244,Access/start authorization-Prompt wire,operated,
MAS00829-MAS01763,Access/start authorization-Signal Strength,-45,
MAS00829-MAS07866,Access/start authorization-Duration: last awakening wire actua.,5, ms
MAS01281,Back-up lamp,|Connector number,Connector terminal number
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,Not operated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge level,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in catch area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heating,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,Enabling stage 3,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,Enabling stage 3,
MAS01490-MAS01564,Energy management-Front windshield heater,Enabled,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,47,
MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,36,
MAS01490-MAS06551,Energy management-Seat ventilation,Enabled,
MAS01490-MAS06552,Energy management-Front seat heating,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,0,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance driving,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Adapted,
MAS01597-MAS02282,Sunroof-Position,0, %
MAS01597-MAS02447,Sunroof-Release,active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,standardized,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835,Position lamps,|Connector number,Connector terminal number
MAS03836,Rear fog lamp,|Connector number,Connector terminal number
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,not coded/not installed,
MAS08228-MAS04121,Light sensor-Voltage,not coded/not installed,
ENG116910,Control unit internal measured value (supplier),00,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,2,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
ENG126653,Personalized_Account_Key_History,|Key number,Account
ENG126652-MAS03692,Personalized_key__Setting-Key 1,16,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,16,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,16,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,16,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,16,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,16,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,16,
ENG126654,Personalized_Signals,|Perso_Steuerung,Perso_Konto
ENG147110-ENG147400,UGDO_Control_Button-Status_Button_1,not coded/not installed,
ENG147110-ENG147401,UGDO_Control_Button-Status_Button_2,not coded/not installed,
ENG147110-ENG147402,UGDO_Control_Button-Status_Button_3,not coded/not installed,
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,Not operated,
ENG116907-MAS00063,Zusaetzliche Umgebungsdaten-OFF,Not operated,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside temperature,15.00, °C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,operated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Position lamps,Not operated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,14.50, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,Not operated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,Not operated,
ENG116907-ENG124952,Zusaetzliche Umgebungsdaten-last_wakeup,gueltiges Funktelegramm,
ENG116907-ENG115838,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN),OFF,
ENG116907-ENG115837,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW),OFF,
Elapsed Time: 00:34
blockmap-10-5Q0-919-294-J_WAUZZZ8V8F1029358-20241020-1533.CSV
;SW:5Q0-919-294-J   HW:5Q0-919-294-A ---  Park/Steer Assist
;Component:PARKHILFE 8K  H03 0051, Coding:0070150011
;EV_EPHVA18AU3700000,002024,EV_EPHVA18AU3700000_VW26.rod
;Sunday,20,October,2024,15:33:46:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 42DA93C85403FD2A09F-8016
Group,Description,Actual
IDE00018,Voltage terminal 15,14.7, V
IDE00325,Diagnostic mode,OBD-diagnostic mode,
IDE00767,No. of unscheduled ECU resets,14,
IDE00957-MAS01632,Resulting distance of front sensors-Status,infinite,
IDE00958-MAS01632,Resulting distance of rear sensors-Status,infinite,
IDE00973,Outside temperature,-42.50, °
IDE00974,Outside air temperature internally calculated,-43.00, °
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,infinite,
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,infinite,
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,Malfunction,
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,Malfunction,
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,Malfunction,
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,Malfunction,
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,Malfunction,
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,Malfunction,
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,Malfunction,
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,Malfunction,
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Rear parking aid buzzer: volume,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 4,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Front parking aid buzzer: volume,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 6,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01164,Parking aid button,Not operated,
IDE01165,Park assist activation tone,On,
IDE01166,Supply voltage for park assist sensor,13.5, V
IDE01169,Audio lowering request,Yes,
IDE01171,Convertible factory setting offset for volume level 1,not installed,
IDE01172,Factory setting for increment for convertible volume levels,not installed,
IDE01173,Factory setting: audio lowering,Yes,
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,not activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,not activated,
IDE01411-MAS01426,Personalization 1 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01411-MAS01428,Personalization 1 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,Parking aid active,
IDE01411-MAS12843,Personalization 1 for park assist-Maneuvering brake function,not activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,not activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01412-MAS01428,Personalization 2 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 3,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,not active,
IDE01412-MAS12843,Personalization 2 for park assist-Maneuvering brake function,not activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,not activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01413-MAS01428,Personalization 3 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12843,Personalization 3 for park assist-Maneuvering brake function,not activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,not activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01414-MAS01428,Personalization 4 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12843,Personalization 4 for park assist-Maneuvering brake function,not activated,
IDE01588,Driving direction,forward,
IDE01632,System status of parking aid,not active,
IDE01633,Cause for parking aid shut-off,Terminal 15 off,
IDE03782,Switch-off speed for parking assist,10, km/h
IDE03784,Temporary function limitation due to environmental influences,No,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,33,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,42,
MAS01426,Rear parking aid buzzer: volume,Stage 4,
MAS01427,Speaker frequency for rear park assist,Stage 4,
MAS01428,Front parking aid buzzer: volume,Stage 4,
MAS01429,Speaker frequency for front park assist,Stage 6,
ENG113995,Dimming_Signal_Terminal_58xd_pdc_pla,0, %
Elapsed Time: 00:07
blockmap-13-5Q0-907-567-M_WAUZZZ8V8F1029358-20241020-1534.CSV
;SW:5Q0-907-567-M   HW:5Q0-907-567-M ---  Auto Dist. Reg
;Component:ACC3          H10 0398, Coding:023E1301FE0309
;EV_ACCBoschMQB,001024,EV_ACCBoschMQB_AU37.rod
;Sunday,20,October,2024,15:34:02:49859
;VCID: 45D088D4452DCA122CD-8010
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,14.5, V
IDE00102,Control Module temperature,20, °C
IDE01784,Misalignment angle,-0.40, °
IDE01785,Vertical angle deviation,0.587891, °
IDE01786,Horizontal angle deviation,0.249023, °
IDE01787,Radar status,On,
IDE01788,Heated lens control signal,0.00, %
IDE02290-MAS01466,Adjustment screw 1-Direction of rotation,none,
IDE02290-MAS02559,Adjustment screw 1-Rotations,0.00,
IDE02291-MAS01466,Adjustment screw 2-Direction of rotation,none,
IDE02291-MAS02559,Adjustment screw 2-Rotations,0.00,
IDE02523,Adjustment angle - fast algorithms,-0.47, °
IDE03203,Alignment instructions,Set mirror in posit 1 and start measurement,
IDE04805-IDE02955,Driving profile selection-System status,available.,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,will be performed.,
IDE04805-MAS01447,Driving profile selection-Act.val.,03,
IDE04805-MAS01448,Driving profile selection-Target value,03,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE07584,Counter for internal faults,0,
ENG119268-MAS01632,Status ACC System-Status,ACC_Off_MainSwitch_Off,
Elapsed Time: 00:06
blockmap-14-8V0-907-376-C_WAUZZZ8V8F1029358-20241020-1534.CSV
;SW:8V0-907-376-C   HW:8V0-907-376-B ---  Susp. Elect.
;Component:DAEMPFUNGS-SG H08 0066, Coding:
;EV_AudiMagneRide,002003,EV_AudiMagneRide.rod
;Sunday,20,October,2024,15:34:15:49859
;VCID: 41D89CC45105E632105-8014
IDE00019,Voltage terminal 30,14.7, V
IDE00102-MAS05627,Control Module temperature-Activation front axle,24, °C
IDE00102-MAS05628,Control Module temperature-Activation rear axle,24, °C
IDE00767-MAS01478,No. of unscheduled ECU resets-insufficient voltage,98,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE00773,Terminal 15 status via CAN,Terminal 15 on,
IDE03055-MAS00816,Currently set shock absorber code-normal,active,
IDE03055-MAS01439,Currently set shock absorber code-reduced,not active,
IDE03055-MAS05624,Currently set shock absorber code-Constant current,not active,
IDE03055-MAS05625,Currently set shock absorber code-without current,not active,
IDE03055-MAS05626,Currently set shock absorber code-Damping test,not active,
IDE04434,Damping adjustment indicator lamp,OFF,
IDE04805-MAS05375,Driving profile selection-Driving profile,will be performed.,
IDE04805-MAS05629,Driving profile selection-Driving profile: specified value,3,
IDE04805-MAS05630,Driving profile selection-Driving profile: actual value,3,
IDE04805-MAS05631,Driving profile selection-System status,available.,
IDE04805-MAS13138,Driving profile selection-Driving profile: actual value in the RAM,0,
IDE05437,Outside air temperature via CAN,15.0, °C
IDE06425,Dynamometer mode: functional,0,
IDE07141-MAS01853,Wire resistance-Left front,0.64, Ohm
IDE07141-MAS01854,Wire resistance-Right front,0.76, Ohm
IDE07141-MAS01855,Wire resistance-Left rear,0.62, Ohm
IDE07141-MAS01856,Wire resistance-Right rear,0.54, Ohm
IDE07142,Time since terminal 15 off,5897, s
IDE07143-MAS03096,Vehicle level sensor: supply voltage-Voltage 1,5.0, V
IDE07143-MAS03097,Vehicle level sensor: supply voltage-Voltage 2,5.0, V
IDE07144,ESP automatic engagement,not activated,
IDE07146-MAS01853,Dampening adjustment valve: resistance-Left front,1.94, Ohm
IDE07146-MAS01854,Dampening adjustment valve: resistance-Right front,2.08, Ohm
IDE07146-MAS01855,Dampening adjustment valve: resistance-Left rear,1.96, Ohm
IDE07146-MAS01856,Dampening adjustment valve: resistance-Right rear,1.82, Ohm
IDE07147-MAS01853,Dampening adjustment: current Highside-Left front,-3, mA
IDE07147-MAS01854,Dampening adjustment: current Highside-Right front,3, mA
IDE07147-MAS01855,Dampening adjustment: current Highside-Left rear,0, mA
IDE07147-MAS01856,Dampening adjustment: current Highside-Right rear,3, mA
IDE07148-MAS01853,Dampening adjustment valve: current Lowside-Left front,0, mA
IDE07148-MAS01854,Dampening adjustment valve: current Lowside-Right front,3, mA
IDE07148-MAS01855,Dampening adjustment valve: current Lowside-Left rear,0, mA
IDE07148-MAS01856,Dampening adjustment valve: current Lowside-Right rear,3, mA
IDE07149-MAS01853,Vehicle level sensor: frequency-Left front,810, Hz
IDE07149-MAS01854,Vehicle level sensor: frequency-Right front,800, Hz
IDE07149-MAS01855,Vehicle level sensor: frequency-Left rear,790, Hz
IDE07149-MAS01856,Vehicle level sensor: frequency-Right rear,810, Hz
IDE07150-MAS01853,Dampening adjustment valve: temperature-Left front,20, °C
IDE07150-MAS01854,Dampening adjustment valve: temperature-Right front,26, °C
IDE07150-MAS01855,Dampening adjustment valve: temperature-Left rear,27, °C
IDE07150-MAS01856,Dampening adjustment valve: temperature-Right rear,16, °C
IDE07150-MAS05618,Dampening adjustment valve: temperature-Front left: calculated,27, °C
IDE07150-MAS05619,Dampening adjustment valve: temperature-Front right: calculated,25, °C
IDE07150-MAS05620,Dampening adjustment valve: temperature-Rear left: calculated,25, °C
IDE07150-MAS05621,Dampening adjustment valve: temperature-Rear right: calculated,23, °C
IDE07151-MAS01853,Vehicle level sensor: raw value-Left front,86.0, %
IDE07151-MAS01854,Vehicle level sensor: raw value-Right front,17.2, %
IDE07151-MAS01855,Vehicle level sensor: raw value-Left rear,37.6, %
IDE07151-MAS01856,Vehicle level sensor: raw value-Right rear,60.0, %
IDE07152,Fall-back level,00 00 00 00,
IDE07153,End-of-line Status,0F,
IDE07154,ESP status,0,
IDE07162,Dampening adjustment valve: Temperature at terminal 15 on,14, °C
IDE07177-MAS01632,Status Output DTM damper front left-Status,not active,
IDE07177-MAS05584,Status Output DTM damper front left-Result,Unknown status,
IDE07178-MAS01632,Status Output DTM damper front right-Status,not active,
IDE07178-MAS05584,Status Output DTM damper front right-Result,Unknown status,
IDE07179-MAS01632,Status Output DTM damper rear left-Status,not active,
IDE07179-MAS05584,Status Output DTM damper rear left-Result,Unknown status,
IDE07180-MAS01632,Status Output DTM damper rear right-Status,not active,
IDE07180-MAS05584,Status Output DTM damper rear right-Result,Unknown status,
IDE07187-MAS01853,Level control system sensor-Left front,317, mm
IDE07187-MAS01854,Level control system sensor-Right front,295, mm
IDE07187-MAS01855,Level control system sensor-Left rear,331, mm
IDE07187-MAS01856,Level control system sensor-Right rear,331, mm
IDE07187-MAS05610,Level control system sensor-Calibration,calibrated,
IDE08127-MAS01853,Vehicle level sensor: offset-Left front,26.8, %
IDE08127-MAS01854,Vehicle level sensor: offset-Right front,51.2, %
IDE08127-MAS01855,Vehicle level sensor: offset-Left rear,4.4, %
IDE08127-MAS01856,Vehicle level sensor: offset-Right rear,72.8, %
Elapsed Time: 00:05
blockmap-15-5Q0-959-655-AB_WAUZZZ8V8F1029358-20241020-1534.CSV
;SW:5Q0-959-655-AB   HW:5Q0-959-655-AB ---  Airbags
;Component:AirbagVW20    014 0385, Coding:98FCC000000000005C54000000C800000065
;EV_AirbaVW20SMEVW37X,002130,EV_AirbaVW20SMEVW37X_VW37.rod
;Sunday,20,October,2024,15:34:27:49859
;VCID: 005E59C01A8F2F3A5FB-8054
IDE00821,Seat belt switch 2nd row driver's side,not connected,
IDE00822,Safety belt switch 2nd row frt.passenger side,not connected,
IDE00823,Seat belt switch 2nd row center,not connected,
IDE00824,Seat belt switch 3rd row driver's side,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,3.0, Ohm
IDE01100,Passenger side airbag igniter ohm value,2.2, Ohm
IDE01102,Driver thorax airbag igniter ohm value,2.5, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.5, Ohm
IDE01104,driver side rear airbag igniter ohm value,2.5, Ohm
IDE01105,Ft. pass.side rear airbag igniter ohm value,2.6, Ohm
IDE01106,Driver side head curtain airbag igniter ohm value,2.4, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.4, Ohm
IDE01108,Driver side knee airbag igniter ohm value,2.3, Ohm
IDE01110,Driver side belt tensioner igniter ohm value,2.4, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.4, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,no measured value present,
IDE01117,Passenger side rear belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,Too Small,
IDE01194,Frt.pass. belt tensioner ohm value,Too Small,
IDE01195,Front passenger side seat occupancy detection: Ohm value,456.0, Ohm
IDE01197,Key switch contact 1 ohm value,too large,
IDE01198,Key switch contact 2 ohm value,too large,
IDE01200,Driver seat position sensor current value,0.0, mA
IDE01201,Frt.pass. seat position sensor current value,0.0, mA
IDE01205,Safety belt switch 2nd row driver side ohm value,0.0, Ohm
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,0.0, Ohm
IDE01207,Safety belt switch center 2nd row ohm value,0.0, Ohm
IDE01208,Seat belt switch 3rd row driver side ohm value,too large,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,too large,
IDE01357,Left pedestrian protection igniter,cannot be measured currently,
IDE01358,Right pedestrian protection igniter,cannot be measured currently,
IDE01555,Number of frontal crashes,0,
IDE01634,Pedestrian protection trigger: driver side ohmic value,no measured value present,
IDE01635,Pedestrian protection trigger: frt.pass. side ohmic value,no measured value present,
IDE02852,Battery Interrupt Igniter High-Voltage Battery,Unknown (6)
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,no measured value present,
MAS00001,Driver airbag igniter,correct,
MAS00003,Front passenger airbag igniter,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,correct,
MAS00008,Passenger side rear thorax airbag igniter,correct,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,correct,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,cannot be measured currently,
MAS00020,Passenger side rear seat belt tensioner igniter,cannot be measured currently,
MAS00022,Battery Interrupt Igniter,cannot be measured currently,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,On,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,not installed,
MAS00036,Seat position sensor: front passenger side,not installed,
MAS00044,Terminal 15 power supply,14.6, V
MAS01634,Supply voltage,correct,
Elapsed Time: 00:11
blockmap-16-8V0-953-521-CR_WAUZZZ8V8F1029358-20241020-1534.CSV
;SW:8V0-953-521-CR   HW:5Q0-953-549-C ---  Steering wheel
;Component:Lenks. Modul  002 0110, Coding:E018
;EV_SMLSKLOMQB,017001,EV_SMLSKLOMQB_010_VW37.rod
;Sunday,20,October,2024,15:34:48:49859
;VCID: 0C467DF026C77B5A333-8058
IDE00329-MAS00232,Buttons for multi-function display-MFI button UP,not coded/not installed,
IDE00329-MAS00233,Buttons for multi-function display-MFI button DOWN,not coded/not installed,
IDE00329-MAS00234,Buttons for multi-function display-MFI button RESET / OK,not coded/not installed,
IDE00329-MAS00236,Buttons for multi-function display-MFI buttons: number 3/4,not coded/not installed,
IDE00329-MAS00688,Buttons for multi-function display-Multi-function display,not coded/not installed,
IDE00333,Driver assistance systems button,not coded/not installed,
IDE00333-MAS00243,Driver assistance systems button-Buttons for driver assistance systems: status,not coded/not installed,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,On,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Distance Regulation,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,not coded/not installed,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,6 Position operating unit,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,On,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,Not operated,
IDE02694-MAS01288,Horn operation-Horn,Not operated,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Intermittent operation,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 4,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,Not operated,
IDE02696-IDE02711,Rear wiping: rear washing-Rear wiper,not coded/not installed,
IDE02696-MAS02341,Rear wiping: rear washing-Rear window washer system,not coded/not installed,
IDE02743,High Beam,Not operated,
IDE02744-MAS01632,Steering wheel heating-Status,OFF,
IDE02744-MAS04136,Steering wheel heating-Current,0.00, A
IDE02744-MAS09022,Steering wheel heating-PWM value,0, %
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,-50, °C
MAS09606-MAS09607,SMLS p locked-Switch p locked,Engaged and locked,
MAS09606-MAS09608,SMLS p locked-SMLS p locked plausibility,Implausible,
ENG120506-ENG100300,CCS_in_indic-lever-E: Blinkerhebel GRA Cancel,Not operated,
ENG120506-ENG103377,CCS_in_indic-lever-E: Blinkerhebel GRA Fehler,No malfunction detected,
ENG120506-ENG103714,CCS_in_indic-lever-E: Blinkerhebel GRA OFF,Not operated,
ENG120506-ENG102330,CCS_in_indic-lever-E: Blinkerhebel GRA ON,Not operated,
ENG120506-ENG120475,CCS_in_indic-lever-E: Blinkerhebel GRA Speedlimiter,OFF,
ENG120506-ENG103991,CCS_in_indic-lever-E: Blinkerhebel GRA Tip Resume/Plus,Not operated,
ENG120506-ENG100605,CCS_in_indic-lever-E: Blinkerhebel GRA Tip Set/Minus,Not operated,
ENG120506-ENG120476,CCS_in_indic-lever-E: GRA_E_A,OFF,
ENG120507-ENG100163,CCS_in_third_lever-E: 3.ter Hebel ADR Fehler,No malfunction detected,
ENG120507-ENG99937,CCS_in_third_lever-E: 3.ter Hebel ADR Minus,Not operated,
ENG120507-ENG101800,CCS_in_third_lever-E: 3.ter Hebel ADR Plus,Not operated,
ENG120507-ENG101234,CCS_in_third_lever-E: 3.ter Hebel GRA Cancel,Not operated,
ENG120507-ENG103820,CCS_in_third_lever-E: 3.ter Hebel GRA Fehler,No malfunction detected,
ENG120507-ENG99143,CCS_in_third_lever-E: 3.ter Hebel GRA OFF,Not operated,
ENG120507-ENG100333,CCS_in_third_lever-E: 3.ter Hebel GRA ON,operated,
ENG120507-ENG101903,CCS_in_third_lever-E: 3.ter Hebel GRA Resume,Not operated,
ENG120507-ENG101230,CCS_in_third_lever-E: 3.ter Hebel GRA Set,Not operated,
ENG120507-ENG126425,CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Beschleunigen,Not operated,
ENG120507-ENG126426,CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Verzögern,Not operated,
ENG120507-ENG120477,CCS_in_third_lever-E: 3.ter Hebel GRA Tip Beschleunigen,Not operated,
ENG120507-ENG120478,CCS_in_third_lever-E: 3.ter Hebel GRA Tip Verzögern,Not operated,
ENG120507-ENG120476,CCS_in_third_lever-E: GRA_E_A,On,
ENG126424-ENG126428,LRH-LRH_current,0.00, A
ENG126424-ENG126430,LRH-LRH_level,low,
ENG126424-ENG126429,LRH-LRH_status,OFF,
ENG126424-ENG126427,LRH-LRH_temperature_NTC,205, °C
Elapsed Time: 00:02
blockmap-17-8V0-920-871-G_WAUZZZ8V8F1029358-20241020-1525.CSV
;SW:8V0-920-871-G   HW:8V0-920-871-G ---  Instruments
;Component:KOMBI         H02 4291, Coding:278D181A3E80AE000181E8001000000000000000
;EV_DashBoardVDDMQBAB,009040,EV_DashBoardVDDMQBAB_009_VW26.rod
;Sunday,20,October,2024,15:25:49:49859
;VCID: 40DE99C05A0FEF3A1FB-8014
IDE00019,Voltage terminal 30,13.8, V
IDE00021,Engine RPM,783.00, /min
IDE00025,Coolant temperature,65.25, °C
IDE00196,Engine oil temperature,39, °C
IDE00301,Mileage,91836, km
IDE00310,Outside temperature,15.0, °C
IDE00316-IDE00500,Time-Hour,15, H
IDE00316-IDE00501,Time-Minute,25, min
IDE00316-MAS00111,Time-Seconds,39, s
IDE00317-IDE00502,Date-Year,2024, yr
IDE00317-IDE00503,Date-Month,10, Months
IDE00317-IDE00504,Date-Day,19, d
IDE00510,ESI: distance driven from inspection,6117, km
IDE00511,ESI: time from inspection,192, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,365, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,21000, km
IDE00520,Photo transistor,95,
IDE00695,ESI: service exceedance in km,1110, km
IDE00696,ESI: service exceedance in days,29, d
IDE00697,ESI: remaining distance,-1110, km
IDE00698,ESI: remaining running time,-12, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,3696, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,1965, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2005, mm
IDE00935,ESI: Theoretical service interval,14500, km
IDE01076,Time since ignition off,5897, s
IDE01153,SIA: maximum value of distance to service,5000, km
IDE01154,SIA: maximum value of time to service,180, d
IDE01985-MAS06854,FAZIT identification test sum-Version,02,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,67 F6 64 E8,
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,14.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,CA,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,3366,
IDE03349,FIX:Max. distance driven until next mileage-related inspection,3000, km
IDE03350,FIX: Maximum time until next time-dependent inspection,890, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,6100, km
IDE03352,FIX: Time since last time-dependent inspection,192, d
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assist,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Traffic sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,14.6, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,55.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,57.0, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,16.1, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,10.3, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,55.0, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,57.0, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,9.4, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,13.5, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,55.0, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,57.0, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,13.1, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,10.6, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,55.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,57.0, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,12.1, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,91800,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,91500,
IDE03472-MAS06155,Volume after refueling-Third to last distance,91200,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,91000,
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,79, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,53, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,2, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,1, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,1168,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,2333,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,871,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,2424,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,55.0, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,77, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,52, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,21.0, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,36.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,21.1, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,36.1, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,57.0, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,57.0, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,57.0, l
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00000, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.04,
IDE03474-ENG101623,Calculated volume-reference_volume,56.1, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,3,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0049992,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,15, H
IDE03477-IDE00501,GPS time-Minute,25, min
IDE03477-IDE00501,GPS time-Minute,15, min
IDE03477-IDE00502,GPS time-Year,2024, yr
IDE03477-IDE00503,GPS time-Month,10, Months
IDE03477-IDE00504,GPS time-Day,20, d
IDE03477-MAS00111,GPS time-Seconds,54, s
IDE03477-MAS00111,GPS time-Seconds,22, s
IDE03477-MAS03493,GPS time-last synchronization year,2024, yr
IDE03506,Distance: high resolution,05 79 4F EF,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 9F,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 1B,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 1B,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 9F,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,4F F0 01 FF,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,0F F0 24 6F,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,8F F0 24 6F,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,CF F0 01 FF,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,CF F0 03 6C,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,4F F0 03 6C,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,0F F0 4F 6B,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,8F F0 4F 6B,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,CF F0 04 D9,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,4F F0 04 D9,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,0F F0 74 13,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,8F F0 74 13,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,8F F0 A1 C6,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,CF F0 06 26,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,4F F0 06 D2,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,0F F0 AE D3,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,CF F0 06 D2,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,8F F0 AE D3,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,6F F0 06 D2,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,2F F0 AE D3,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,4F F0 06 D2,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,0F F0 AE D3,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,4F F0 07 B1,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,0F F0 D5 70,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,CF F0 08 3E,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,4F F0 08 44,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,0F F0 E3 60,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,8F F0 E3 60,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,CF F0 09 07,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,6F F0 09 07,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,2F F1 02 C8,
IDE03913-MAS01393,Service -interval- display: history 3-Block 4,4F F0 09 C5,
IDE03913-MAS01394,Service -interval- display: history 3-Block 5,8F F1 11 AE,
IDE03913-MAS01395,Service -interval- display: history 3-Block 6,CF F0 09 C5,
IDE03913-MAS01396,Service -interval- display: history 3-Block 7,8F F1 11 AE,
IDE03913-MAS01397,Service -interval- display: history 3-Block 8,CF F0 09 C5,
IDE03913-MAS01398,Service -interval- display: history 3-Block 9,0F F1 13 11,
IDE03913-MAS01399,Service -interval- display: history 3-Block 10,4F F0 0A 49,
IDE03913-MAS01400,Service -interval- display: history 3-Block 11,0F F1 1A 04,
IDE03913-MAS01401,Service -interval- display: history 3-Block 12,8F F1 1A 04,
IDE03913-MAS01402,Service -interval- display: history 3-Block 13,CF F0 0A 49,
IDE03913-MAS01403,Service -interval- display: history 3-Block 14,8F F1 1A 04,
IDE03913-MAS01404,Service -interval- display: history 3-Block 15,CF F0 0A 49,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,4F F0 0A 49,
IDE03914-MAS01390,Service -interval- display: history 4-Block 1,0F F1 1A 04,
IDE03914-MAS01391,Service -interval- display: history 4-Block 2,BF F1 25 BC,
IDE03914-MAS01392,Service -interval- display: history 4-Block 3,3F F1 2D 8C,
IDE03914-MAS01393,Service -interval- display: history 4-Block 4,0F F1 4C 46,
IDE03914-MAS01394,Service -interval- display: history 4-Block 5,4F F0 0C 57,
IDE03914-MAS01395,Service -interval- display: history 4-Block 6,8F F1 4C 46,
IDE03914-MAS01396,Service -interval- display: history 4-Block 7,CF F0 0C 57,
IDE03914-MAS01397,Service -interval- display: history 4-Block 8,4F F0 0C 57,
IDE03914-MAS01398,Service -interval- display: history 4-Block 9,0F F1 4C 46,
IDE03914-MAS01399,Service -interval- display: history 4-Block 10,7F F0 0D 0C,
IDE03914-MAS01400,Service -interval- display: history 4-Block 11,4F F0 0D AF,
IDE03914-MAS01401,Service -interval- display: history 4-Block 12,0F F1 4E D7,
IDE03914-MAS01402,Service -interval- display: history 4-Block 13,8F F1 4E D7,
IDE03914-MAS01403,Service -interval- display: history 4-Block 14,CF F0 0D AF,
IDE03914-MAS01404,Service -interval- display: history 4-Block 15,4F F0 0D AF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,0F F1 4E D7,
IDE05931,FIX: Reset value for next mileage-dependent inspection,30000, km
IDE05932,FIX: Reset value for next time-dependent inspections,0, d
IDE09552-IDE07944,Vehicle configuration 2-electronic brake booster,Correct coding,
IDE09552-MAS06008,Vehicle configuration 2-Internal noise sound actuator,Correct coding,
IDE09552-MAS08940,Vehicle configuration 2-Collision warning,Correct coding,
ENG124477-MAS06854,Adapted_transponders_checksum-Version,01,
ENG124477-MAS06855,Adapted_transponders_checksum-Test sum,6B EA F5 C2,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,37, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,57, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,64, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,72, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,41, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,active,
ENG119883,ESI_mileage_per_day,31, km
ENG106922,Immobilizer - Challenge,3E D2 98 FE,
ENG99439,Instrument_recorder,02 02 93 00 4D 51 42 41 55 31 34 53 31 43 00 00 00 00 00 00 01 00 93 00 1E 00 00 00 CF 00 00 00 00 80 00 00 79 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 01 5B 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 0A 0C 0C 0A FF FF FF FF FF FF 00 00 1E 00 93 00 CF 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 03 FF FF 00 00 00 00 E0 20 A8 2C 00 00 D1 04 00 00 7F FB,
ENG107920-ENG100914,onboard_computer-current_consumption,300.0,
ENG107920-ENG119788,onboard_computer-range_average_consumption,12.1, l/100km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,12.1, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,10.1, l/100km
ENG107920-ENG119791,onboard_computer-range_display_value,426, km
ENG107920-ENG119792,onboard_computer-range_R,432,
ENG107920-ENG112418,onboard_computer-total_range_gas,426, km
ENG124505-ENG100914,onboard_computer_cng-current_consumption,0.0,
ENG124505-ENG119788,onboard_computer_cng-range_average_consumption,6.0,
ENG124505-ENG119789,onboard_computer_cng-range_average_consumption_high,6.0,
ENG124505-ENG119790,onboard_computer_cng-range_average_consumption_low,6.0,
ENG124505-ENG119791,onboard_computer_cng-range_display_value,0, km
ENG124505-ENG119792,onboard_computer_cng-range_R,0,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,128,
ENG103405,read_out_measured_value_block,91,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,0,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,1,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Start_Delay,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG119808,Service_Key_Pointer-Write_Pointer_Adr_159,0,
ENG108929-ENG119809,Service_Key_Pointer-Write_Pointer_Adr_191,0,
ENG108929-ENG119810,Service_Key_Pointer-Write_Pointer_Adr_223,0,
ENG100879-ENG118224,State Blocking Time-blocking_time,00 00 00 00 00 00,
ENG103899-ENG99298,State of Immobilizer-State,02 01 03 18 02 00 00 00 01 00,
ENG103284-ENG118223,State of Immobilizer Slaves-ELV_State,F8,
ENG103284-ENG118222,State of Immobilizer Slaves-GSG_State,F8,
ENG103284-ENG118217,State of Immobilizer Slaves-Immobilizer_State,00,
ENG103284-ENG118216,State of Immobilizer Slaves-key_state,1C,
ENG103284-ENG118218,State of Immobilizer Slaves-MSG_1_State,F8,
ENG103284-ENG118219,State of Immobilizer Slaves-MSG_2_State,00,
ENG103284-ENG118220,State of Immobilizer Slaves-MSG_3_State,00,
ENG103284-ENG118221,State of Immobilizer Slaves-MSG_4_State,00,
ENG103284-ENG151847,State of Immobilizer Slaves-OCU_state,00,
ENG103284-ENG151848,State of Immobilizer Slaves-VTS_state,00,
ENG109576,Transponder ID Key 1,08 0D D2 81,
ENG109577,Transponder ID Key 2,08 0D D4 EE,
Elapsed Time: 00:13
blockmap-19-5Q0-907-530-T_WAUZZZ8V8F1029358-20241020-1526.CSV
;SW:5Q0-907-530-T   HW:5Q0-907-530-M ---  CAN Gateway
;Component:GW MQB High   212 2186, Coding:030100042F085A005B0002789C0B00000001010000000000000000000000
;EV_GatewConti,011017,EV_GatewConti_011.rod
;Sunday,20,October,2024,15:26:46:49859
IDE00019,Voltage terminal 30,14.4, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00056,History data 1,|Life Cycle Data String|2024-09-30-16:44*00.0*02*03403***
2024-09-27-16:35*00.0*02**
2024-08-25-16:43*16.1*02**
2024-08-28-12:45*01.0*02*02781***
2024-08-28-11:34*02.1*02**
2024-08-28-09:27*17.4*02**
2023-02-13-22:03*24.0*02*00163***
2023-02-13-12:12*09.8*02**
2023-02-13-12:07*02.2*02**|,
IDE00057,History data 2,|Life Cycle Data String|2023-04-04-16:29*000*054*+00.00*0-0-0-0-0-0-0*0*02*06053**
2023-03-29-15:30*092*056*-00.21*0-0-0-0-0-0-0*0*02**
2023-03-07-19:12*018*045*-00.21*0-0-0-0-0-0-0*0*02**
2023-03-06-02:17*035*045*-00.14*0-0-0-0-0-0-0*0*02**
2023-03-04-23:23*014*041*-00.21*0-0-0-0-0-0-0*0*02**|,
IDE00058,History data 3,|Life Cycle Data String|2024-08-28-12:48*1*0*022*000*0-0-0-0-1-0-0*0*0*00.0*00.0**
2024-08-28-11:43*3*0*022*000*0-0-0-0-0-0-0*1*0*00.0*00.0**
2024-08-28-11:41*1*0*029*003*0-0-0-0-0-0-0*1*0*00.0*00.0**
2024-08-28-11:36*2*0*018*000*0-0-0-0-1-0-0*0*0*00.0*00.0**
2024-08-28-11:35*1*0*019*000*0-0-0-0-1-0-0*0*0*00.0*00.0**
2024-08-28-09:28*3*0*019*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2024-08-28-09:27*1*0*019*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2024-08-27-15:55*3*0*020*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2024-08-27-15:55*2*0*020*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2024-08-27-15:54*1*0*021*000*0-0-0-0-1-0-0*1*0*00.0*00.0**|,
IDE00059,History data 4,|Life Cycle Data String|2017-12-09-16:15*02*069*BA2*17060881GN*09656*06502*0043*0000*0000**
2014-06-16-21:39*01*069*VAO*140523N0VL*09901*04401*0002*0000*0000**
IDE00060,History data 5,|Life Cycle Data String|2024-08-27-13:34*2*+00.00*09.50*006*08*-03.6*06502*09621*090042*0-0-0-0-1-0-0*1*1*1*00.0*00.0*034.4*04*01*02*01*11**
2024-01-13-17:12*3*+00.00*11.93*000*06*-18.5*06502*09597*085710*0-0-0-0-0-0-0*0*0*0*00.0*00.0*742.3*03*00*02*00*11**
2023-05-02-10:08*3*+00.00*13.16*000*27*-00.2*06502*09650*085057*0-0-0-0-0-0-0*0*0*0*00.0*00.0*000.0*02*00*02*00*10**|,
IDE00061,History data 6,|Life Cycle Data String|2024-10-19-13:18*038*+14*+000.9*00.40*0.00*000**
2024-10-19-13:13*036*+13*+000.2*00.00*0.00*000**
2024-10-19-12:59*036*+13*+000.4*00.10*0.00*000**
2024-10-18-14:41*033*+18*+000.3*00.10*0.00*000**
2024-10-18-14:31*034*+18*+000.2*00.00*0.00*000**
2024-10-17-18:34*042*+30*+001.1*01.00*0.00*000**
2024-10-17-16:08*041*+22*+000.9*00.70*0.00*000**
2024-10-17-15:37*041*+20*+000.4*00.20*0.00*000**
2024-10-17-15:18*042*+19*+000.4*00.10*0.00*000**
2024-10-17-14:36*041*+17*+000.3*00.10*0.00*000**|,
IDE00062,History data 7,|Life Cycle Data String|2024-10-19-13:47*031*-000.7*001.5*00.0*00.0**
2024-10-19-13:15*033*-000.5*000.0*00.0*00.0**
2024-10-19-13:11*036*-000.2*000.0*00.0*00.0**
2024-10-18-14:49*033*-000.8*022.1*00.0*00.0**
2024-10-18-14:34*033*-000.2*000.1*00.0*00.0**
2024-10-17-19:37*030*-000.9*018.9*00.0*00.0**
2024-10-17-16:51*034*-000.5*001.7*00.0*00.0**
2024-10-17-15:50*039*-000.5*000.2*00.0*00.0**
2024-10-17-15:29*037*-000.4*000.1*00.0*00.0**
2024-10-17-14:48*036*-000.3*000.4*00.0*00.0**|,
IDE00063,History data 8,|Life Cycle Data String|2024-08-28-12:46*1*02*00*25*09*-------------:--*02**
2024-04-11-05:35*4*01*00*25*09*2024-04-11-16:00*02**
2023-10-18-13:10*4*01*00*25*08*2023-10-18-00:00*02**|,
IDE00064,History data 9,|Life Cycle Data String|2017-12-27-17:19*086*092*087*039*04509*12.60*-05*05*02*03.20*01958*00000**
2024-10-05-17:00*067*070*084*042*06502*12.60*+30*07*02*03.40*65535*00005**
2024-09-09-18:27*075*073*079*042*06502*12.50*+16*06*02*03.35*65535*00005**
2024-08-12-16:29*067*070*076*038*06502*12.50*+36*07*02*03.55*65535*00005**
2024-07-15-16:22*070*072*073*033*06502*12.40*+23*07*02*03.45*65535*00005**
2024-06-17-16:18*066*072*071*034*06502*12.40*+27*07*02*03.45*65535*00005**
2024-05-20-15:58*069*075*080*041*06502*12.50*+30*06*02*03.40*65535*00005**
2024-04-25-15:15*068*073*092*044*06502*12.70*+12*06*02*03.55*65535*00005**
2024-04-08-14:55*064*074*033*006*06502*11.90*+12*06*02*12.70*65535*00005**
2024-03-10-20:46*065*074*036*006*06502*11.90*+08*06*02*12.70*65535*00005**
2024-02-07-19:32*065*074*028*000*06502*11.80*+06*06*02*03.45*65535*00005**
2024-01-05-17:22*064*074*039*006*06502*11.90*+05*06*02*03.45*65535*00005**|,
IDE00065,History data 10,|Life Cycle Data String|2024-08-28-11:38*1*001.3*00239*0*000.0*00019*00.00*0000258**
IDE00066,History data 11,|Life Cycle Data String|2024-10-19-13:47*000*000*000*000*0000*028*00.0*00.0*086*038*086*038*01*00664*00830*03004*04328*10159**
2024-10-17-18:51*000*000*000*045*0521*062*00.4*00.9*087*039*090*042*01**
2024-10-17-16:12*000*000*000*039*0829*043*00.4*00.9*085*038*086*041*01**
2024-10-17-15:40*000*000*000*010*0162*013*00.2*00.3*085*040*085*041*01**
2024-10-17-15:22*000*000*000*006*0125*010*00.1*00.2*084*039*084*042*01**|,
IDE00067,History data 12,|Life Cycle Data String|2024-10-19-13:46*0-0-0-1-0-0-0-0**
2024-10-19-13:33*0-0-0-1-0-0-0-0**
2024-10-19-13:15*0-0-0-1-0-0-0-0**
2024-10-19-13:14*0-0-0-1-0-0-0-0**
2024-10-19-13:10*0-0-0-1-0-0-0-0**
00524*00000*00003*05803*00000*00009*00359*00000**
2023-04-03-09:58*0-0-0-0-0-1-0-0**
2023-03-23-13:41*0-0-0-0-0-1-0-0**
2023-03-20-12:05*0-0-0-0-0-1-0-0**
2022-12-15-18:47*0-0-0-0-0-1-0-0**
2022-11-09-18:12*0-0-0-0-0-1-0-0**
00000*00000*00001*00006*00000*00014*00000*00000**
2024-10-19-13:18*1*079*033*+13*07*025*-15.87*10.8*1**
2024-10-16-17:21*1*077*036*+28*07*025*-20.40*12.1*1**
2024-10-15-16:31*1*082*035*+17*07*025*+25.47*11.2*1**
2024-10-14-15:35*1*082*036*+16*07*025*-20.36*11.9*1**
2024-10-13-15:38*1*087*038*+22*07*025*-20.34*12.0*1**
00406*00010*00000**|,
IDE00068,History data 13,|Life Cycle Data String|2024-08-13-15:21*0-1-0-0-0*000.0*00013**
2024-08-28-11:38*0-1-0-0-0*000.0**
2024-08-27-13:31*1-1-0-1-0*000.0**|,
IDE00071,History data 16,|Life Cycle Data String|       0091836km**
03170*03908*04673*00245*00060**
32283*02142*00065*00025**
56970*01181*00012*00004**
04532*03533*01307*02194**
06560*03242*01764**
00000*00000*00000*00000**
06819*00029*00005**
00025*00008*00000**
00184*00014*00002**
02799*02041*01730*01562*01439*01373*02247*01604*00978*01402*00000**|,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,0,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,none,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,0,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,0,
IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,6,
IDE01459,Energy management heat output control status,Stage 1,
IDE01803,History data 17,|Life Cycle Data String|-------------:--*--.-*-----*-----**
2024-08-28-12:45*3*000*02.2*022*001*027*000*023**
2024-08-28-11:37*3*000*02.2*055*001*002**
2024-08-28-11:34*3*000*02.2*019*000*000**
2024-08-28-09:27*3*000*02.2*019*000*000**
2024-08-27-16:03*3*000*02.2*020*000*000**|,
IDE01804,History data 18,|Life Cycle Data String|-------------:--*---*---*--*---*-*---*---*-----**
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.7, H
IDE01807-MAS00106,History data 21-Year,2021,
IDE01807-MAS00107,History data 21-Month,10,
IDE01807-MAS00108,History data 21-Day,1,
IDE01807-MAS00109,History data 21-Hours,9, H
IDE01807-MAS00110,History data 21-Minutes,0, min
IDE01807-MAS14375,History data 21-Cycle counter,9039,
IDE01807-MAS14376,History data 21-ECU 1,Node_0x01 $--,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.7, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Node_0x-- $-- (empty entry),
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03175,History data 22-Extended data bus,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01816-IDE07142,History data 30-Time since terminal 15 off,143.8, H
IDE01816-MAS00106,History data 30-Year,2021,
IDE01816-MAS00107,History data 30-Month,8,
IDE01816-MAS00108,History data 30-Day,9,
IDE01816-MAS00109,History data 30-Hours,21, H
IDE01816-MAS00110,History data 30-Minutes,31, min
IDE01816-MAS14375,History data 30-Cycle counter,8889,
IDE01816-ENG151642,History data 30-Bus_1,Data bus diagnostics,
IDE01816-ENG151644,History data 30-Bus_2,Unknown,
IDE01816-ENG151646,History data 30-Bus_3,Unknown,
IDE01816-ENG151648,History data 30-Bus_4,Unknown,
IDE01816-ENG151650,History data 30-Bus_5,Unknown,
IDE01816-ENG151643,History data 30-Bus_Active_Time_1,142.5, H
IDE01816-ENG151645,History data 30-Bus_Active_Time_2,0.0, H
IDE01816-ENG151647,History data 30-Bus_Active_Time_3,0.0, H
IDE01816-ENG151649,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG151651,History data 30-Bus_Active_Time_5,0.0, H
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2014,
IDE01823-MAS00107,History data 37-Month,6,
IDE01823-MAS00108,History data 37-Day,17,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,58, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,12089,
IDE01823-MAS14429,History data 37-Time in current cycle,0.0, H
IDE01827,Specified generator voltage,14.8, V
IDE01828,Generator DF Signal,45.175, %
IDE01829,Generator exciter current,2.750, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,electrically OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,Generator recognition 75-140A,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,0,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01834,Battery voltage,14.618, V
IDE01836,Battery current,7.609, A
IDE01837,Temperature of battery sensor,25, °C
IDE01838,Battery temperature,20, °C
IDE01839,Battery charge level,76, %
IDE01841,Battery internal resistance,7.2, mOhm
IDE01842,Usable battery charge,33, Ah
IDE01843,Battery voltage at rest,12.5, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shut-off stage,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.2, Ah
IDE01849,Previous journey duration,0.0, H
IDE01852,Static current measurement: result,Initialization,
IDE01853,Static current measurement: status,Measurement end,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,27.6, A
IDE01948,Battery internal resistance not normed,7.0, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,3E 63 15 A9,
IDE01985-ENG99027,FAZIT identification test sum-Version,1,
IDE02578-IDE05118,Play protection status-Counter for function calls,0,
IDE02578-MAS02040,Play protection status-Anti-play protection,not active,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS02193,Stop process prevented-Outside temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03009-MAS01478,Start process requested-insufficient voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer/component current too high,not active,
IDE03009-MAS04055,Start process requested-Withdrawable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery state of charge too low,not active,
IDE03009-MAS04058,Start process requested-Standing time timed out,not active,
IDE03009-MAS06003,Start process requested-Charge contingency,not active,
IDE03009-MAS06004,Start process requested-Special start request,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,759,
IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,3,
IDE03010-MAS02193,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer/component current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Withdrawable battery charge too low,10,
IDE03010-MAS04056,Number of prevented stop processes-Battery state of charge too low,973,
IDE03010-MAS04062,Number of prevented stop processes-Possible standing time too short,6699,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
IDE03011-MAS01478,Number of requested start processes-insufficient voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer/component current too high,0,
IDE03011-MAS04055,Number of requested start processes-Withdrawable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery state of charge too low,3,
IDE03011-MAS04058,Number of requested start processes-Standing time timed out,35,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,10,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2024,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,10,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,17,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,19,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,19,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,13,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,20,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,10,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,19,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,46,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,33,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,42,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,20,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,30,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,32,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,57,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,Possible standing time too short,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,Possible standing time too short,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,Possible standing time too short,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,Possible standing time too short,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,Possible standing time too short,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2023,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2019,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,4,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,9,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,14,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,3,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,14,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,9,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,34,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,58,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,13,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,21,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,no measured value present,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,no measured value present,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,no measured value present,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,Charge contingency,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,Standing time timed out,
IDE03212,Start/stop conditions,Stop prohibition: no start request,
IDE03213,Start/stop enable,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05583-IDE02766,Break recommendation-Malfunction status,No malfunction,
IDE05583-MAS03095,Break recommendation-Function status,Initialization,
IDE05583-MAS04622,Break recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Break recommendation-Icon deactivated,No,
IDE05740-MAS05371,Driving profile selection: system status-Superimposition profile 1,not engaged,
IDE05740-MAS05372,Driving profile selection: system status-Superimposition profile 2,not engaged,
IDE05740-MAS05373,Driving profile selection: system status-Superimposition profile 3,not engaged,
IDE05740-MAS05374,Driving profile selection: system status-Superimposition profile 4,not engaged,
IDE05740-MAS05375,Driving profile selection: system status-Driving profile,engaged,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05814,Individualization characteristic,9D AE 80 51 48,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,Report error,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,3,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,Internal noise sound actuator,
IDE06007-MAS00106,Driving profile history data 1-Year,2024,
IDE06007-MAS00107,Driving profile history data 1-Month,7,
IDE06007-MAS00108,Driving profile history data 1-Day,4,
IDE06007-MAS00109,Driving profile history data 1-Hours,15,
IDE06007-MAS00110,Driving profile history data 1-Minutes,37,
IDE06007-MAS00111,Driving profile history data 1-Seconds,40,
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,88946, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Not available,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,Wrong switch-over,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,3,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,Transmission Control Module (TCM),
IDE06008-MAS00106,Driving profile history data 2-Year,2024,
IDE06008-MAS00107,Driving profile history data 2-Month,6,
IDE06008-MAS00108,Driving profile history data 2-Day,26,
IDE06008-MAS00109,Driving profile history data 2-Hours,17,
IDE06008-MAS00110,Driving profile history data 2-Minutes,53,
IDE06008-MAS00111,Driving profile history data 2-Seconds,19,
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,88796, km
IDE06008-MAS03095,Driving profile history data 2-Function status,available.,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,Refused switch-over,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,Reversible seat belt tensioner,
IDE06009-MAS00106,Driving profile history data 3-Year,2024,
IDE06009-MAS00107,Driving profile history data 3-Month,6,
IDE06009-MAS00108,Driving profile history data 3-Day,26,
IDE06009-MAS00109,Driving profile history data 3-Hours,17,
IDE06009-MAS00110,Driving profile history data 3-Minutes,45,
IDE06009-MAS00111,Driving profile history data 3-Seconds,36,
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,88795, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Not available,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,Refused switch-over,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,0,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,Headlight activation,
IDE06010-MAS00106,Driving profile history data 4-Year,2024,
IDE06010-MAS00107,Driving profile history data 4-Month,6,
IDE06010-MAS00108,Driving profile history data 4-Day,26,
IDE06010-MAS00109,Driving profile history data 4-Hours,17,
IDE06010-MAS00110,Driving profile history data 4-Minutes,45,
IDE06010-MAS00111,Driving profile history data 4-Seconds,36,
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,88795, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Not available,
IDE06011,Selected driving profile,Dynamic,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,10804,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,15308,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,25545,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,56163,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,58912,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,166732,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,166732,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,166732,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
IDE06230-MAS00106,Break recommend.: last message-Year,2019,
IDE06230-MAS00107,Break recommend.: last message-Month,9,
IDE06230-MAS00108,Break recommend.: last message-Day,10,
IDE06230-MAS00109,Break recommend.: last message-Hours,18,
IDE06230-MAS00110,Break recommend.: last message-Minutes,48,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,valid,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,Stage 1,
IDE06468-MAS06315,Battery model-estimated battery temperature,0, °C
IDE06468-MAS06316,Battery model-estimated battery ambient temperature,0,
IDE06468-MAS06317,Battery model-Specification rated battery voltage from BTM,12.0, V
IDE06468-MAS06318,Battery model-Determined parking time,0, s
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,1,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,2,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,3,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
IDE07427-IDE04447,Status: driving profile selection for power steering-Function status,engaged,
IDE07427-IDE06260,Status: driving profile selection for power steering-ID number,5,
IDE07427-MAS01156,Status: driving profile selection for power steering-Communication status,OK,
IDE07427-MAS01447,Status: driving profile selection for power steering-Act.val.,3,
IDE07428-IDE04447,Status: driving profile selection for damping adjustment-Function status,engaged,
IDE07428-IDE06260,Status: driving profile selection for damping adjustment-ID number,7,
IDE07428-MAS01156,Status: driving profile selection for damping adjustment-Communication status,OK,
IDE07428-MAS01447,Status: driving profile selection for damping adjustment-Act.val.,3,
IDE07429-IDE04447,Status: driving profile selection for A/C-Function status,engaged,
IDE07429-IDE06260,Status: driving profile selection for A/C-ID number,8,
IDE07429-MAS01156,Status: driving profile selection for A/C-Communication status,OK,
IDE07429-MAS01447,Status: driving profile selection for A/C-Act.val.,2,
IDE07430-IDE04447,Status: driving profile selection for adaptive cruise control-Function status,engaged,
IDE07430-IDE06260,Status: driving profile selection for adaptive cruise control-ID number,9,
IDE07430-MAS01156,Status: driving profile selection for adaptive cruise control-Communication status,OK,
IDE07430-MAS01447,Status: driving profile selection for adaptive cruise control-Act.val.,3,
IDE07431-IDE04447,Status: driving mode selection for AFS & headlamp range control-Function status,Not available,
IDE07431-IDE06260,Status: driving mode selection for AFS & headlamp range control-ID number,11,
IDE07431-MAS01156,Status: driving mode selection for AFS & headlamp range control-Communication status,OK,
IDE07431-MAS01447,Status: driving mode selection for AFS & headlamp range control-Act.val.,0,
IDE07432-IDE04447,Status: driving profile selection for structure-borne noise-Function status,Not available,
IDE07432-IDE06260,Status: driving profile selection for structure-borne noise-ID number,10,
IDE07432-MAS01156,Status: driving profile selection for structure-borne noise-Communication status,OK,
IDE07432-MAS01447,Status: driving profile selection for structure-borne noise-Act.val.,3,
IDE07433-IDE04447,Status: driving profile selection for ambient lighting-Function status,engaged,
IDE07433-IDE06260,Status: driving profile selection for ambient lighting-ID number,0,
IDE07433-MAS01156,Status: driving profile selection for ambient lighting-Communication status,OK,
IDE07433-MAS01447,Status: driving profile selection for ambient lighting-Act.val.,0,
IDE07434-IDE04447,Status: driving profile selection for belt tensioner-Function status,Not available,
IDE07434-IDE06260,Status: driving profile selection for belt tensioner-ID number,14,
IDE07434-MAS01156,Status: driving profile selection for belt tensioner-Communication status,OK,
IDE07434-MAS01447,Status: driving profile selection for belt tensioner-Act.val.,0,
IDE07436-IDE04447,Status: driving profile selection for free-running hub-Function status,Not available,
IDE07436-IDE06260,Status: driving profile selection for free-running hub-ID number,18,
IDE07436-MAS01156,Status: driving profile selection for free-running hub-Communication status,OK,
IDE07436-MAS01447,Status: driving profile selection for free-running hub-Act.val.,0,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,Request by Engine Control Module,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,not active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop mode,Phase 1,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stop time,Not permitted,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,25, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,14.6, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,14.3, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,14.3, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,0, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,0, A
IDE07637,Current charge contingent for feedback,0.0, As
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,active,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07639-MAS06342,Methods for support of high voltage side-Operating range support request,no request,
IDE07639-MAS06343,Methods for support of high voltage side-Voltage decrease range extension,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,8.70,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,3.25, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,3.35, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,1016, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,1016, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,13648.2, Ah
IDE07681-MAS06087,Battery total charging throughput-Entire energy throughput,13924.6, Ah
IDE07873-MAS06193,Driving mode selection activated profiles-Profile 1,Comfort,
IDE07873-MAS06194,Driving mode selection activated profiles-Profile 2,AUTO,
IDE07873-MAS06195,Driving mode selection activated profiles-Profile 3,Dynamic,
IDE07873-MAS06196,Driving mode selection activated profiles-Profile 4,ECONOMY,
IDE07873-MAS06197,Driving mode selection activated profiles-Profile 5,INDIVIDUAL,
IDE07873-MAS06198,Driving mode selection activated profiles-Profile 6,Not Used,
IDE07873-MAS06199,Driving mode selection activated profiles-Profile 7,Not Used,
IDE07873-MAS06200,Driving mode selection activated profiles-Profile 8,Not Used,
IDE07873-MAS08875,Driving mode selection activated profiles-Profile 9,Not Used,
IDE07873-MAS08876,Driving mode selection activated profiles-Profile 10,Not Used,
IDE07873-MAS08877,Driving mode selection activated profiles-Profile 11,Not Used,
IDE07873-MAS08878,Driving mode selection activated profiles-Profile 12,Not Used,
IDE07907,Bus communication,active,
IDE08346-MAS06117,Generator Analysis-Specified voltage,14.8, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,14.7, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.1, V
IDE08346-MAS06866,Generator Analysis-Generator speed,741, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,40, °C
IDE08347,adapted battery capacity,89, Ah
IDE08354-IDE04447,Status: driv.profile select. for front axle differential lock-Function status,engaged,
IDE08354-IDE06260,Status: driv.profile select. for front axle differential lock-ID number,0,
IDE08354-MAS01156,Status: driv.profile select. for front axle differential lock-Communication status,Timeout,
IDE08354-MAS01447,Status: driv.profile select. for front axle differential lock-Act.val.,0,
IDE08355-IDE04447,Status: driving profile selection for external noise actuator-Function status,engaged,
IDE08355-IDE06260,Status: driving profile selection for external noise actuator-ID number,0,
IDE08355-MAS01156,Status: driving profile selection for external noise actuator-Communication status,Timeout,
IDE08355-MAS01447,Status: driving profile selection for external noise actuator-Act.val.,0,
IDE08680-MAS03173,Allocation data bus identifier-Powertrain data bus,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Extended data bus,15,
IDE08680-MAS03177,Allocation data bus identifier-Infotainment data bus,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Powertrain data bus,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Extended data bus,OK,
IDE08681-MAS03177,Data bus defect error-Infotainment data bus,OK,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Powertrain data bus,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Extended data bus,OK,
IDE08682-MAS03177,Data bus single wire err.-Infotainment data bus,OK,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Powertrain data bus,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Extended data bus,OK,
IDE08683-MAS03177,Data bus TimeOut error-Infotainment data bus,OK,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT271901,Allocation LIN system number-Generator,00 1D,
IDE08684-SFT271921,Allocation LIN system number-Multifunction steering wheel control module,00 31,
IDE08684-SFT271927,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT271977,Allocation LIN system number-Inverter for electrical outlet,00 69,
IDE08684-SFT271986,Allocation LIN system number-Analog clock,00 72,
IDE08684-SFT272175,Allocation LIN system number-Control head driving profile,00 00,
IDE08684-SFT272190,Allocation LIN system number-Steering Wheel Touch Recognition Control Module,00 00,
IDE08685-SFT271901,Status LIN user-Generator,active,
IDE08685-SFT271921,Status LIN user-Multifunction steering wheel control module,active,
IDE08685-SFT271927,Status LIN user-Battery Monitoring Control Module,active,
IDE08685-SFT271977,Status LIN user-Inverter for electrical outlet,not active,
IDE08685-SFT271986,Status LIN user-Analog clock,not active,
IDE08685-SFT272175,Status LIN user-Control head driving profile,not active,
IDE08685-SFT272190,Status LIN user-Steering Wheel Touch Recognition Control Module,not active,
IDE08687-IDE04447,Status: driving profile select. for brake ctrl. sys.-Function status,engaged,
IDE08687-IDE06260,Status: driving profile select. for brake ctrl. sys.-ID number,0,
IDE08687-MAS01156,Status: driving profile select. for brake ctrl. sys.-Communication status,OK,
IDE08687-MAS01447,Status: driving profile select. for brake ctrl. sys.-Act.val.,2,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08796-IDE04447,Status: driving profile selec. for hill descent control-Function status,engaged,
IDE08796-IDE06260,Status: driving profile selec. for hill descent control-ID number,0,
IDE08796-MAS01156,Status: driving profile selec. for hill descent control-Communication status,OK,
IDE08796-MAS01447,Status: driving profile selec. for hill descent control-Act.val.,2,
IDE08797-IDE04447,Status: drive profile for area view-Function status,engaged,
IDE08797-IDE06260,Status: drive profile for area view-ID number,0,
IDE08797-MAS01156,Status: drive profile for area view-Communication status,Timeout,
IDE08797-MAS01447,Status: drive profile for area view-Act.val.,0,
IDE08799-IDE04447,Status: driv. profile selec. for rear spoiler-Function status,engaged,
IDE08799-IDE06260,Status: driv. profile selec. for rear spoiler-ID number,0,
IDE08799-MAS01156,Status: driv. profile selec. for rear spoiler-Communication status,OK,
IDE08799-MAS01447,Status: driv. profile selec. for rear spoiler-Act.val.,0,
IDE08804-IDE04447,Status: driv. profile selec. for ctr. differential-Function status,engaged,
IDE08804-IDE06260,Status: driv. profile selec. for ctr. differential-ID number,0,
IDE08804-MAS01156,Status: driv. profile selec. for ctr. differential-Communication status,OK,
IDE08804-MAS01447,Status: driv. profile selec. for ctr. differential-Act.val.,0,
IDE09561,Static current last LIN sleep phase,-3.401, A
IDE09562,Range extension counter: stage 2,0,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,Initialization,
IDE10737-IDE04447,Status: driving profile selection for range calculation-Function status,engaged,
IDE10737-IDE06260,Status: driving profile selection for range calculation-ID number,53,
IDE10737-MAS01156,Status: driving profile selection for range calculation-Communication status,Timeout,
IDE10737-MAS01447,Status: driving profile selection for range calculation-Act.val.,0,
IDE10738-IDE04447,Status driving profile selection for electronic brake booster-Function status,engaged,
IDE10738-IDE06260,Status driving profile selection for electronic brake booster-ID number,0,
IDE10738-MAS01156,Status driving profile selection for electronic brake booster-Communication status,Timeout,
IDE10738-MAS01447,Status driving profile selection for electronic brake booster-Act.val.,0,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,Not available,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,32,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
MAS00464-MAS00106,Standard - ambient data 1-Year,2024,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,19,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,27,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,3,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,200,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,91836, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,1,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,Audi,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,8,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine running,Engine running,
MAS04447-MAS03023,Engine running status-Driving mode,Driving mode,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
ENG125880-ENG125901,AGW_Status-AGW_relative_brightness,0, %
ENG125880-ENG125902,AGW_Status-AGW_state_fading,no_fading,
ENG125880-ENG125900,AGW_Status-AGW_warning_level_priorisation,0,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG137111,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG137112,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG152042,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG137110,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,not active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG137108,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG118749,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Overlay_1,not detected,
ENG118786-ENG118750,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Overlay_2,not detected,
ENG118786-ENG118751,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Overlay_3,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118786-ENG118745,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Overlay_Button_1,Not operated,
ENG118786-ENG118746,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Overlay_Button_2,Not operated,
ENG118786-ENG118747,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Overlay_Button_3,Not operated,
ENG118787-ENG118757,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_IVB,0,
ENG118787-ENG118756,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_QS,0,
ENG118787-ENG118759,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_IVB,Timeout,
ENG118787-ENG118758,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_QS,OK,
ENG118787-ENG118755,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_IVB,engaged,
ENG118787-ENG118754,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_QS,not engaged,
ENG118787-ENG118753,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_IVB,0,
ENG118787-ENG118752,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_QS,0,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,2,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,Emergency running mode,
ENG137076-ENG118763,EM_battery_analog_monitoring-actual_difference_voltage,0.000, V
ENG137076-ENG118760,EM_battery_analog_monitoring-battery_analog_voltage,0.0, V
ENG137076-ENG118765,EM_battery_analog_monitoring-battery_off_counter,0,
ENG137076-ENG118764,EM_battery_analog_monitoring-battery_off_status_intern,connected,
ENG137076-ENG118761,EM_battery_analog_monitoring-battery_voltage_filtered,13.5, V
ENG137076-ENG118762,EM_battery_analog_monitoring-voltage_difference,0.00, V
ENG106123,EM_blAlternator On,On,
ENG106124,EM_blAlternator Valid,Yes,
ENG106140,EM_Current_Control_Recu,not active,
ENG118437,EM_IAlternatorReserve,59.0, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,600, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,70, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,64, %
ENG106157,EM_RecuMode_Engine,Acc.,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,1,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,1,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,1,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,1,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,0,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,1,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,1,
ENG118780-ENG118446,EM_Recuperation_Precondition-energy_performance,1,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,1,
ENG118780-ENG118444,EM_Recuperation_Precondition-generator_workload,1,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,1,
ENG118780-ENG102605,EM_Recuperation_Precondition-outside_temperature,1,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,1,
ENG118781-ENG118677,EM_Recuperation_Restriction-adaption_target_voltage,0,
ENG118781-ENG118678,EM_Recuperation_Restriction-adaption_voltage_low_beam_light,0,
ENG118781-ENG118671,EM_Recuperation_Restriction-component_protection_BDM,0,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118676,EM_Recuperation_Restriction-emergency_start,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,1,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG125889,Gateway app. software identification-software_version_agw,1021,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,0721,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,1711,
ENG118782-ENG137098,Gateway app. software identification-software_version_ehr,----,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,1204,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,2348,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0440,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,----,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,0122,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,1016,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,----,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0510,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0100,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7110,
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60006,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60005,
Elapsed Time: 00:31
blockmap-22-0CQ-907-554-D_WAUZZZ8V8F1029358-20241020-1535.CSV
;SW:0CQ-907-554-D   HW:0CQ-907-554-D ---  AWD
;Component:Haldex4Motion H52 7076, Coding:0001
;EV_AllWheelContrHA1VW37X,002001,EV_AllWheelContrHA1VW37X_002_VW36.rod
;Sunday,20,October,2024,15:35:21:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 46D28FD8782BC10A257-8012
Group,Description,Actual
IDE00019,Voltage terminal 30,14.6, V
IDE00102,Control Module temperature,20, °C
IDE00920,Front left wheel speed,0.0, km/h
IDE00921,Wheel speed: right front,0.0, km/h
IDE00922,Left rear wheel speed,0.0, km/h
IDE00923,Right rear wheel speed,0.0, km/h
IDE01617,Clutch temperature,20.20, °C
IDE02271-IDE02384,CAN output signal(s) status-Status of event memory,not active,
IDE02271-MAS01464,CAN output signal(s) status-Emergency running mode,not active,
IDE02271-MAS01480,CAN output signal(s) status-excessive temperature,not active,
IDE02404,Checksum calculation,27 5C 22 BF,
IDE04502-MAS04730,Haldex clutch: status-Degree of blockage,0.00, %
IDE05609,Cooling fin temperature,17.90, °C
IDE05610,Duration of overtemperature,0, min
IDE05707,Haldex clutch pump: current,1.089, A
IDE05708,Haldex clutch pump: PWM signal,12, %
IDE05710,Haldex clutch pump: voltage,1.8, V
IDE06111,Axle speed deltas,0.0, km/h
IDE06425,Dynamometer mode: functional,not activated,
IDE80003-ENG119372,Analysis 3-Exeedance_Intergral_1_traction_slip_controller,0,
IDE80003-ENG119373,Analysis 3-Exeedance_Intergral_2_extreme_slip_event,0,
IDE80003-ENG119374,Analysis 3-Undercut_Integral_3_differential_lock_too_far_closed,0,
IDE80004-ENG119372,Analysis 4-Exeedance_Intergral_1_traction_slip_controller,0,
IDE80004-ENG119373,Analysis 4-Exeedance_Intergral_2_extreme_slip_event,0,
IDE80004-ENG119374,Analysis 4-Undercut_Integral_3_differential_lock_too_far_closed,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,35,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,12,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,201,
MAS03129,Reset counter,26,
ENG119394-ENG119379,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_EEPROM,1234,
ENG119394-ENG119380,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_Last_Measurement,0,
ENG119394-ENG119378,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Pressure_EEPROM,1,
ENG119394-ENG119381,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_EEPROM,2210,
ENG119394-ENG119382,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_Last_Measurement,0,
ENG119394-ENG119384,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_EEPROM,3491,
ENG119394-ENG119385,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_Interpolation,0,
ENG119394-ENG119383,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Pressure_EEPROM,15,
ENG119394-ENG119386,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_EEPROM,4692,
ENG119394-ENG119387,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_Interpolation,0,
ENG119394-ENG119389,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_EEPROM,9485,
ENG119394-ENG119390,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_Last_Measurement,0,
ENG119394-ENG119388,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Pressure_EEPROM,35,
ENG119394-ENG119391,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_EEPROM,7202,
ENG119394-ENG119392,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_Last_Measurement,0,
ENG119394-ENG119377,Pump_Calibration_Values-Series_Number_Pump,4601034,
ENG119394-ENG119376,Pump_Calibration_Values-Temperature_Value_at_Calibration,28, °C
ENG119375,Upper Limit of Temperature Duration,0, min
Elapsed Time: 00:03
blockmap-2B-5Q0-905-861-A_WAUZZZ8V8F1029358-20241020-1535.CSV
;SW:5Q0-905-861-A   HW:5Q0-905-861-A ---  Steer. Col. Lock
;Component:ELV-MQBA      H01 0120, Coding:5D00000000000000
;EV_ELVMarquMQB,004111,EV_ELVMarquMQB_004_VW37.rod
;Sunday,20,October,2024,15:35:29:49859
;VCID: 3436C5101EB7439A8B3-8060
IDE00019,Voltage terminal 30,14.600, V
IDE00021,Engine RPM,766.00, /min
IDE00021-MAS02248,Engine RPM-Signal state,valid,
IDE00075-MAS02248,Vehicle speed-Signal state,valid,
IDE01766-MAS03714,Distance impulses-Left front wheel,0,
IDE01766-MAS03715,Distance impulses-Right front wheel,2,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS05509,Distance impulses-Left front wheel signal state,valid,
IDE01766-MAS05510,Distance impulses-Right front wheel signal state,valid,
IDE01766-MAS05511,Distance impulses-Left rear wheel signal state,valid,
IDE01766-MAS05512,Distance impulses-Right rear wheel signal state,valid,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02571-MAS05507,Terminal 50: line status-Actual value engine control module,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,Not operated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,Not operated,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,Not operated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02578,Play protection status,not activated,
IDE02579,Park selector lever position,Engaged and locked,
IDE02580,Number of unlocks,10655,
IDE02581-MAS02312,Drive train uncoupling-Powertrain (engine),decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake lamp switch,OFF,
IDE02582-MAS02248,Brake activation: switch status-Signal state,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,OFF,
IDE02586-MAS02398,ID sensor authenticated in vehicle-ID sensor 1,No,
IDE02586-MAS02399,ID sensor authenticated in vehicle-ID sensor 2,No,
IDE02586-MAS02400,ID sensor authenticated in vehicle-ID sensor 3,No,
IDE02586-MAS02401,ID sensor authenticated in vehicle-ID sensor 4,No,
IDE02587,ID sensor search: status,not active,
IDE02589-MAS02255,Rotary latch status-Status of rotary latch in driver door,Open,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02682-MAS02250,Disengage starter-Disengage request,Yes,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03527-IDE00660,CAN signals-Drive readiness,not active,
IDE03527-IDE03410,CAN signals-Yellow warning lamp,not active,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine RPM,Condition not met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02578,Locking requirements-Play protection status,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-IDE07029,Locking requirements-Terminal status via CAN,Condition not met,
IDE06746-MAS02349,Locking requirements-Learn mode,Condition met,
IDE07028,Time until shut-off terminal S,4.14e+006, ms
IDE08440,Recommendation energy management,no restriction,
IDE09068-IDE00020,Status: automatic terminal shut-off-Terminal 15 status,Condition met,
IDE09068-IDE00021,Status: automatic terminal shut-off-Engine RPM,Condition not met,
IDE09068-IDE00325,Status: automatic terminal shut-off-Diagnostic mode,Condition not met,
IDE09068-IDE02579,Status: automatic terminal shut-off-Park selector lever position,Not coded,
IDE09068-IDE06983,Status: automatic terminal shut-off-Diesel emissions re-treatment: status,Condition met,
IDE09068-IDE08099,Status: automatic terminal shut-off-Status engine speed,Condition met,
IDE09068-IDE08440,Status: automatic terminal shut-off-Recommendation energy management,Condition not met,
IDE09068-MAS06473,Status: automatic terminal shut-off-Status vehicle standstill,Condition met,
IDE09068-MAS08076,Status: automatic terminal shut-off-Exiting the vehicle,Condition not met,
IDE09068-MAS08788,Status: automatic terminal shut-off-Driving Cycle,Condition not met,
IDE09068-MAS08789,Status: automatic terminal shut-off-Valid distance impulses,Condition met,
IDE09068-MAS08790,Status: automatic terminal shut-off-Driver absence,Condition met,
MAS00025,Driver seat belt switch,not connected,
MAS01493,Engine running,active,
MAS03129,Reset counter,8,
MAS03607,Engine stop active in Start/Stop mode,not active,
MAS05104,Driver request: start engine,not active,
MAS09771,Driver information comfort switching,No switch-off,
ENG111213-ENG111202,Activated_Fault_Reactions-CoCo permanent reset,No,
ENG111213-ENG111201,Activated_Fault_Reactions-KL50 disabled,No,
ENG111213-ENG111200,Activated_Fault_Reactions-Locking disabled / Clamp change up disabled,No,
ENG125217,Active_requirement_light_lag,not activated,
ENG120012-ENG100326,CAN Message CLS_02-Can State,active,
ENG120012-ENG119946,CAN Message CLS_02-Time to Timeout ZV_02,1960, ms
ENG120012-ENG119966,CAN Message CLS_02-ZV_gesafet_extern_soll,0,
ENG120012-ENG119965,CAN Message CLS_02-ZV_verriegelt_extern_soll,0,
ENG120020-ENG119995,CAN Message ESCL_01-ELV_Anf_Klemme_15,1,
ENG120020-ENG119996,CAN Message ESCL_01-ELV_Anf_Klemme_50,0,
ENG120020-ENG119994,CAN Message ESCL_01-ELV_Anf_Klemme_S,1,
ENG120020-ENG120001,CAN Message ESCL_01-ELV_Anlernmodus,0,
ENG120020-ENG119998,CAN Message ESCL_01-ELV_Entriegelt,1,
ENG120020-ENG120000,CAN Message ESCL_01-ELV_Lebenszustand,1,
ENG120020-ENG120003,CAN Message ESCL_01-ELV_LED_Gelb,0,
ENG120020-ENG120002,CAN Message ESCL_01-ELV_LED_Rot,0,
ENG120020-ENG120009,CAN Message ESCL_01-ELV_P_verriegelt,0,
ENG120020-ENG120007,CAN Message ESCL_01-ELV_Txt_Defekt,0,
ENG120020-ENG120005,CAN Message ESCL_01-ELV_Txt_Lkg_Bewegen,0,
ENG120020-ENG120008,CAN Message ESCL_01-ELV_Txt_P_Gang,0,
ENG120020-ENG120004,CAN Message ESCL_01-ELV_Txt_Panikabschaltung,0,
ENG120020-ENG120006,CAN Message ESCL_01-ELV_Txt_Werkstatt,0,
ENG120020-ENG119997,CAN Message ESCL_01-ELV_Verriegelt,0,
ENG120020-ENG119999,CAN Message ESCL_01-ELV_ZAT_betaetigt,0,
ENG120016-ENG100326,CAN Message ESP_10-Can State,active,
ENG120016-ENG119984,CAN Message ESP_10-ESP_10_BZ,13,
ENG120016-ENG119985,CAN Message ESP_10-ESP_10_CRC,150,
ENG120016-ENG119993,CAN Message ESP_10-ESP_QBit_Wegimpuls_HL,0,
ENG120016-ENG119992,CAN Message ESP_10-ESP_QBit_Wegimpuls_HR,0,
ENG120016-ENG119990,CAN Message ESP_10-ESP_QBit_Wegimpuls_VL,0,
ENG120016-ENG119991,CAN Message ESP_10-ESP_QBit_Wegimpuls_VR,0,
ENG120016-ENG119989,CAN Message ESP_10-ESP_Wegimpuls_HL,0,
ENG120016-ENG119988,CAN Message ESP_10-ESP_Wegimpuls_HR,0,
ENG120016-ENG119986,CAN Message ESP_10-ESP_Wegimpuls_VL,0,
ENG120016-ENG119987,CAN Message ESP_10-ESP_Wegimpuls_VR,2,
ENG120016-ENG119951,CAN Message ESP_10-Time to Timeout ESP_10,1820, ms
ENG120014-ENG100326,CAN Message Gateway_71-Can State,active,
ENG120014-ENG119687,CAN Message Gateway_71-ESP_21_alt,0,
ENG120014-ENG119968,CAN Message Gateway_71-ESP_QBit_v_Signal,0,
ENG120014-ENG119967,CAN Message Gateway_71-ESP_v_Signal,0.00, km/h
ENG120014-ENG119947,CAN Message Gateway_71-Time to Timeout Gateway_71,920, ms
ENG120019-ENG100326,CAN Message Gateway_73-Can State,active,
ENG120019-ENG119976,CAN Message Gateway_73-MO_Drehzahl_01,761.00, /min
ENG120019-ENG119977,CAN Message Gateway_73-MO_QBit_Drehzahl_01,0,
ENG120019-ENG119684,CAN Message Gateway_73-Motor_12_alt,0,
ENG120019-ENG119948,CAN Message Gateway_73-Time to Timeout Gateway_73,500, ms
ENG120015-ENG100326,CAN Message Kessy_04-Can State,active,
ENG120015-ENG119978,CAN Message Kessy_04-KY_ID_Geber 1_im_Fzg,0,
ENG120015-ENG119979,CAN Message Kessy_04-KY_ID_Geber 2_im_Fzg,0,
ENG120015-ENG119980,CAN Message Kessy_04-KY_ID_Geber 3_im_Fzg,0,
ENG120015-ENG119981,CAN Message Kessy_04-KY_ID_Geber 4_im_Fzg,0,
ENG120015-ENG119982,CAN Message Kessy_04-KY_ID_Geber_Suche,0,
ENG120015-ENG119950,CAN Message Kessy_04-Time to Timeout Kessy_04,1820, ms
ENG120013-ENG100326,CAN Message Motor_14-Can State,active,
ENG120013-ENG119969,CAN Message Motor_14-MO_Aussp_Anlass,1,
ENG120013-ENG119970,CAN Message Motor_14-MO_BLS,0,
ENG120013-ENG119971,CAN Message Motor_14-MO_Fahrer_bremst,0,
ENG120013-ENG119975,CAN Message Motor_14-MO_HYB_Fahrbereitschaft,0,
ENG120013-ENG119973,CAN Message Motor_14-MO_Interlock,1,
ENG120013-ENG119681,CAN Message Motor_14-MO_Kl_50,0,
ENG120013-ENG119972,CAN Message Motor_14-MO_Qbit_Fahrer_bremst,0,
ENG120013-ENG119974,CAN Message Motor_14-MO_StartStopp_Motorstopp,0,
ENG120013-ENG119949,CAN Message Motor_14-Time to Timeout Motor_14,920, ms
ENG120010-ENG100326,CAN Message term._Status_01-Can State,active,
ENG120010-ENG119944,CAN Message term._Status_01-Time to Timeout Klemmen_Status_01,980, ms
ENG120010-ENG119680,CAN Message term._Status_01-ZAS_Kl_15,1,
ENG120010-ENG119679,CAN Message term._Status_01-ZAS_Kl_S,1,
ENG120011-ENG100326,CAN Message TSG_FT_01-Can State,active,
ENG120011-ENG119964,CAN Message TSG_FT_01-FT_Tuer_geoeffnet,1,
ENG120011-ENG119945,CAN Message TSG_FT_01-Time to Timeout TSG_FT_01,940, ms
ENG120018-ENG100326,CAN Message WFS_01-Can State,active,
ENG120018-ENG119952,CAN Message WFS_01-Time to Timeout WFS_01,1940, ms
ENG120018-ENG119983,CAN Message WFS_01-WFS_Schluessel_Ist,2,
ENG111214-ENG119959,CAN Request-Clamp generation,active,
ENG111214-ENG119958,CAN Request-Diagnostic connection,active,
ENG111214-ENG119961,CAN Request-Immobilizer authentication,not active,
ENG111214-ENG119960,CAN Request-Move,not active,
ENG111215-ENG119959,CAN Request-Clamp generation,active,
ENG111215-ENG119958,CAN Request-Diagnostic connection,active,
ENG111215-ENG119961,CAN Request-Immobilizer authentication,not active,
ENG111215-ENG119960,CAN Request-Move,not active,
ENG111211-ENG111203,Endposition_Button_Blocked_Contact-Button Blocked Contact 1,Not operated,
ENG111211-ENG111204,Endposition_Button_Blocked_Contact-Button Blocked Contact 2,operated,
ENG111217-ENG111209,Endposition_Button_Unlocked_Contact-Button Unlocked Contact 1,operated,
ENG111217-ENG111210,Endposition_Button_Unlocked_Contact-Button Unlocked Contact 2,Not operated,
ENG111212-ENG111184,Errorcounter-AD-Converter corrupt,0,
ENG111212-ENG111176,Errorcounter-CoCo RAM-Check,0,
ENG111212-ENG111177,Errorcounter-CoCo ROM-Check,0,
ENG111212-ENG111194,Errorcounter-CPU-Test CoCo,0,
ENG111212-ENG111192,Errorcounter-CPU-Test HaCo,0,
ENG111212-ENG111186,Errorcounter-Enable CoCo incorrect active KL15,0,
ENG111212-ENG111187,Errorcounter-Enable CoCo incorrect active locking,0,
ENG111212-ENG111178,Errorcounter-Endposition locked not reached,0,
ENG111212-ENG111181,Errorcounter-Endposition switches implausible,0,
ENG111212-ENG119957,Errorcounter-Error clamp15: - Steeringlock isn't unlock,0,
ENG111212-ENG111185,Errorcounter-HaCo CoCo communication disturbed,0,
ENG111212-ENG111175,Errorcounter-HaCo EEPROM-Check,0,
ENG111212-ENG111173,Errorcounter-HaCo RAM-Check,0,
ENG111212-ENG111174,Errorcounter-HaCo ROM-Check,0,
ENG111212-ENG111196,Errorcounter-KL15 ELV locked,0,
ENG111212-ENG111188,Errorcounter-No CoCo enable KL15,0,
ENG111212-ENG111189,Errorcounter-No CoCo enable locking,0,
ENG111212-ENG111182,Errorcounter-Particle,0,
ENG111212-ENG111195,Errorcounter-Program sequence CoCo,0,
ENG111212-ENG111193,Errorcounter-Program sequence HaCo,0,
ENG111212-ENG111190,Errorcounter-Reset HaCo CoCo failed,0,
ENG111212-ENG111191,Errorcounter-Reset SBC HaCo failed,0,
ENG111212-ENG119956,Errorcounter-Return address,5A A5 C3 3C,
ENG111212-ENG111183,Errorcounter-SBC-Error,0,
ENG111212-ENG111197,Errorcounter-SDA-Error,0,
ENG111212-ENG111179,Errorcounter-Shortcut motor driver highside,0,
ENG111212-ENG111180,Errorcounter-Shortcut motor driver lowside,0,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2023,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2024,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2022,
ENG125220-MAS00107,History last automatic terminal switch off-Month,8,
ENG125220-MAS00107,History last automatic terminal switch off-Month,12,
ENG125220-MAS00107,History last automatic terminal switch off-Month,1,
ENG125220-MAS00108,History last automatic terminal switch off-Day,11,
ENG125220-MAS00108,History last automatic terminal switch off-Day,27,
ENG125220-MAS00108,History last automatic terminal switch off-Day,28,
ENG125220-MAS00108,History last automatic terminal switch off-Day,19,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,15,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,21,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,9,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,11,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,55,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,19,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,3,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,36,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,41,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,47,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,22,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,42,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,53,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,7,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,90042, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,90042, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,90042, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,83571, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,83349, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Energy management,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Energy management,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG111218-ENG98599,Last reset reason-external,WAKEUP_SST1,
ENG111218-ENG98656,Last reset reason-internal,NOT_INTERNAL,
ENG125219-ENG125224,Status_Selective_catalytic_reduction-Count_engine_start,OK,
ENG125219-ENG125223,Status_Selective_catalytic_reduction-Selective_catalytic_reduction_install,not installed,
ENG125218,Suppression_ignition_message,not activated,
ENG120017-ENG100326,Timeout CAN Messages-Can State,active,
ENG120017-ENG119953,Timeout CAN Messages-Time to Timeout Diagnose_01,4520, ms
ENG120017-ENG119951,Timeout CAN Messages-Time to Timeout ESP_10,2000, ms
ENG120017-ENG119947,Timeout CAN Messages-Time to Timeout Gateway_71,960, ms
ENG120017-ENG119948,Timeout CAN Messages-Time to Timeout Gateway_73,480, ms
ENG120017-ENG119950,Timeout CAN Messages-Time to Timeout Kessy_04,1940, ms
ENG120017-ENG119944,Timeout CAN Messages-Time to Timeout Klemmen_Status_01,1000, ms
ENG120017-ENG119949,Timeout CAN Messages-Time to Timeout Motor_14,920, ms
ENG120017-ENG119954,Timeout CAN Messages-Time to Timeout Systeminfo_01,4060, ms
ENG120017-ENG119945,Timeout CAN Messages-Time to Timeout TSG_FT_01,980, ms
ENG120017-ENG119952,Timeout CAN Messages-Time to Timeout WFS_01,1900, ms
ENG120017-ENG119946,Timeout CAN Messages-Time to Timeout ZV_02,1900, ms
Elapsed Time: 00:08
blockmap-42-5Q0-959-593-B_WAUZZZ8V8F1029358-20241020-1535.CSV
;SW:5Q0-959-593-B   HW:5Q0-959-593-B ---  Door Elect, Driver
;Component:TSG FS        020 0025, Coding:005D1E205C01040000001003
;EV_DCUDriveSideEWMAXKLO,006003,EV_DCUDriveSideEWMAXKLO.rod
;Sunday,20,October,2024,15:35:41:49859
;VCID: 40DE99C05A0FEF3A1FB-8014
IDE01766-MAS02248,Distance impulses-Signal state,OK,
IDE02262,synchronous mirror adjustment,not installed,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,14.5, V
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not_active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,Not operated,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04411,Child safety button,Not operated,
IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
IDE04539-MAS02228,Mirror memory-X coordinate,255, %
IDE04539-MAS02229,Mirror memory-Y coordinate,255, %
IDE04539-MAS02476,Mirror memory-installed,not installed,
IDE04540,Mirror adjustment (X/Y direction),Position center,
IDE04580,Dimming of inside door handle lighting,100, %
IDE04581,Dimming for interior ambient lighting,255, %
IDE04586,Mirror fold-in activation,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,55, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,Not operated,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.0, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,100, %
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.5, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.5, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.5, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.5, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.5, %
IDE07110-MAS01632,Recognition of motor variant for window regul.-Status,not detected,
IDE07110-MAS04606,Recognition of motor variant for window regul.-Parameter set,15,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,14, °C
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,54,
MAS01872,Rear lid remote control lock switch,Not operated,
MAS02101,Child safety lock,active,
MAS06010,Ambient light,255, %
Elapsed Time: 00:38
blockmap-44-3Q0-909-144-F_WAUZZZ8V8F1029358-20241020-1536.CSV
;SW:3Q0-909-144-F   HW:3Q0-909-144-F ---  Steering Assist
;Component:EPS_MQB_ZFLS  503 5043, Coding:8103
;EV_SteerAssisMQB,010031,EV_SteerAssisMQB_010.rod
;Sunday,20,October,2024,15:36:35:49859
;VCID: 3530F81415CD5A92BCD-8060
IDE00018,Voltage terminal 15,14.56, V
IDE00019,Voltage terminal 30,14.61, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine RPM,762, /min
IDE00102,Control Module temperature,33.0, °C
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,HA,
IDE00550-MAS01078,Identification of parameterization-Vehicle model,G0,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,61,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,12,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A0,
IDE02006-IDE02955,Lane assist-System status,Function cannot be performed,
IDE02006-IDE04227,Lane assist-Directional stab. asst w/ pwr steering asst: steering status,31.999, Nm
IDE02006-MAS03095,Lane assist-Function status,not activated,
IDE02006-MAS03368,Lane assist-Steering wheel vibration,not active,
IDE02202,End stage temperature,23.0, °C
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02955,System status,Driving mode,
IDE03682-IDE04457,motor position sensor-Electric motor speed,0, /min
IDE03682-MAS02961,motor position sensor-Engine angle,95.7, °
IDE03682-MAS03083,motor position sensor-Cosine signal,0.531, V
IDE03682-MAS03211,motor position sensor-Sine signal,1.678, V
IDE03682-MAS05053,motor position sensor-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,-100, %
IDE03725-MAS03001,Steering Assistance-Mode,automatic,
IDE03725-MAS03095,Steering Assistance-Function status,activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,4095.9, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,4088.9, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not activated,
IDE03735,Steering torque,-0.038, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736,Steering torque 2,-0.038, Nm
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,-0.3, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,-0.3, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active default-Restoring force: setpoint,0, N
IDE04183,Steering assistance: target engine torque,-0.006, Nm
IDE04184,Steering assistance: engine output,100.000, %
IDE04185,Terminal 30 voltage filtered,14.56, V
IDE04187,Steering torque: raw value 1,64.844, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-55.469, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,64.844, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-55.469, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.39, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.39, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.39, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,0.0, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,-0.4, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,0.4, A
IDE04194,Steering assistance: electromotor power,0.00, W
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,5.6, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,0.1, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,160.99, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
IDE04459,Steering angle sensor: offset index mark mechanical middle,0.23, mm
IDE04460,Steering angle sensor: offset straight line running,5.2, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,1,
IDE04511,Steering angle sensor external via CAN: angle,Measuring value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measuring value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,Function cannot be performed,
IDE04765-MAS03095,Counter steer support-Function status,activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine RPM,No,
IDE04787,Hybrid status,not active,
IDE04805-IDE02955,Driving profile selection-System status,operational,
IDE04805-MAS01447,Driving profile selection-Act.val.,3,
IDE04805-MAS01448,Driving profile selection-Target value,3,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05155,Power steering current consumption,-0.06, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,80.73, mm
IDE05162-MAS01850,Software end stop-Right,-80.26, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,841366,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,59996,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,75716,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,61240,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,52186,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,51561,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,44684,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,42101,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,36595,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,33282,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,28671,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,25142,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,22502,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,18613,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,17245,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,13475,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,12123,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,842903,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,75802,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,9252,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,2,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,5319377,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,3,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,87328,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,863,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,5298328,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,40238,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,126309,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,22726,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,43995,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,10489,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,24529,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,4601,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,12281,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,1973,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,5260,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,1264,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,1950,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,1215,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,1516,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,1077,
IDE05994-ENG120739,Engine specified torque load-above_10_kilo_newton,1632,
IDE05994-ENG120718,Engine specified torque load-below_-10_kilo_newton,1258,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,520356,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,15593,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,1454528,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,2047601,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,2399585,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,2306856,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,1603198,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,426150,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,23460,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,668,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,590500,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,13171966,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,72060,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,8321,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adaptation value,0.120, Nm
IDE06678-MAS03095,Pull compensation-Function status,not activated,
IDE07399,Engine type,2,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Control active,Condition met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,36,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,30,
MAS00976-IDE80003,Counter-Analysis 3,2866542606,
MAS00976-IDE80004,Counter-Analysis 4,548,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
Elapsed Time: 00:07
blockmap-47-8V0-035-465-D_WAUZZZ8V8F1029358-20241020-1536.CSV
;SW:8V0-035-465-D   HW:8V0-035-465 ---  Sound System
;Component:MIBAMP1ALPINE H11 0420, Coding:01030300AAAA2AAA01
;EV_AMPMst16C1ALPI,004024,EV_AMPMst16C1ALPI_004_AU37.rod
;Sunday,20,October,2024,15:36:48:49859
;VCID: 3928F42439D5BEF2585-806C
IDE00017,System abbreviation,J525 ,
IDE00020,Terminal 15 status,On,
IDE00021,Engine RPM,765.00, /min
IDE00050-IDE01000,Number of programming attempts-Bootloader,2,
IDE00050-IDE01001,Number of programming attempts-Application,2,
IDE00668-MAS03231,Microphone voltage consumption-Microphone 1,3.00, mA
IDE00668-MAS03232,Microphone voltage consumption-Microphone 2,25.50, mA
IDE00721-IDE01000,Maximum number of possible update programming-Bootloader,1024,
IDE00721-IDE01001,Maximum number of possible update programming-Application,1024,
IDE00767,No. of unscheduled ECU resets,7, counts
IDE00916-ENG117404,Speaker status-loudspeaker_channel_1,Condition not met,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Condition not met,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Condition not met,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measuring value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Condition not met,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Condition not met,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Condition not met,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Condition not met,
IDE00916-ENG117405,Speaker status-loudspeaker_channel_2,Condition not met,
IDE00916-ENG117406,Speaker status-loudspeaker_channel_3,Condition not met,
IDE00916-ENG117407,Speaker status-loudspeaker_channel_4,Condition not met,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Condition not met,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Condition not met,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Condition not met,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Condition not met,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Condition not met,
IDE01351,Terminal 75 status,On,
IDE01716,Terminal 50 status,OFF,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Infotainment data bus,No,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,Yes,
IDE03404,AUTOSAR Standard application software identification,|Standard software module,Software manufacturer ID
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,47,
IDE03880-MAS03425,MOST address-Physical address,04 00,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,11, min
IDE04317-MAS00108,Total system run time-Day,121, d
IDE04317-MAS00109,Total system run time-Hours,12, H
IDE04317-MAS00110,Total system run time-Minutes,52, min
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Infotainment data bus,No,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,Yes,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,1.0, dB
IDE04649-MAS01968,Activation for housing fan-Fan,OFF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE05704-MAS02646,Key for digital transmission protection (DTCP)-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,0,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,0,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE06055,Invalid authentication (DTCP),57,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,42,
MAS03121,Ring break diagnostic line status,Supply voltage,
MAS04266-MAS01424,Temperature sensor 1-max.value,79, °C
MAS04266-MAS01425,Temperature sensor 1-min.value,4, °C
MAS04266-MAS02238,Temperature sensor 1-Up-to-date,48, °C
MAS04267-MAS01424,Temperature sensor 2-max.value,101, °C
MAS04267-MAS01425,Temperature sensor 2-min.value,-21, °C
MAS04267-MAS02238,Temperature sensor 2-Up-to-date,37, °C
MAS04268-MAS01424,Temperature sensor 3-max.value,85, °C
MAS04268-MAS01425,Temperature sensor 3-min.value,-21, °C
MAS04268-MAS02238,Temperature sensor 3-Up-to-date,37, °C
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,dont care,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,34, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,24, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,10, Months
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,19, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,15, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,25, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,0, s
ENG117873-ENG101364,Theft_protection_error_counter-Theft Protection Error Counter,00 00,
Elapsed Time: 00:07
blockmap-52-5Q0-959-592-B_WAUZZZ8V8F1029358-20241020-1537.CSV
;SW:5Q0-959-592-B   HW:5Q0-959-592-B ---  Door Elect, Pass.
;Component:TSG BFS       020 0025, Coding:005D16205E01040000001003
;EV_DCUPasseSideEWMAXKLO,006003,EV_DCUPasseSideEWMAXKLO.rod
;Sunday,20,October,2024,15:37:00:49859
;VCID: 3FDC9A3C27F190C2661-806A
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,14.6, V
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,46, %
IDE04539-MAS02229,Mirror memory-Y coordinate,56, %
IDE04539-MAS02476,Mirror memory-installed,installed,
IDE05726,Dimmer terminal 58xd,53, %
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.0, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Idle condition,
IDE06872,Front passenger power window button,Not operated,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.5, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.5, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.5, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.5, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.5, %
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,14, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
MAS00464-MAS00106,Standard - ambient data 1-Year,2024,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,19,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,37,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,13,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,91836, km
Elapsed Time: 00:37
blockmap-55-7P6-907-357-C_WAUZZZ8V8F1029358-20241020-1537.CSV
;SW:7P6-907-357-C   HW:7P6-907-357-B ---  Headlight Range
;Component:AFS-ECU       H01 0091, Coding:01A600002B200200
;EV_HeadlRegulAFSMQBMLB,001001,EV_HeadlRegulAFSMQBMLB_AU37.rod
;Sunday,20,October,2024,15:37:54:49859
IDE00018,Voltage terminal 15,14.570, V
IDE00326,Steering wheel angle,4.8, °
IDE01232,Supply voltage for external components,0.000, V
IDE01714,Status reverse gear,OFF,
IDE01943,Turn signal lamp,Not operated,
IDE01946,ESP intervention,not_activated,
IDE02389,Ambient brightness,1890, lx
IDE02486,Data logger triggering,not_activated,
IDE02515,Low beam,OFF,
IDE02743,High Beam,OFF,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03602,Left front level control system sensor,-0.01, %
IDE03604,Left rear level control system sensor,37.60, %
IDE03616,Motor status,On,
IDE03620,Front jounce travel,-44.2, mm
IDE03621,Rear jounce travel,-46.2, mm
IDE03622,Left headlight beam adjusting motor: status,No malfunction,
IDE03623,Right headlight beam adjusting motor: status,No malfunction,
IDE03624,Left dynamic AFS light motor: specified value,0.000, °
IDE03625,Right dynamic AFS light motor: specified value,0.000, °
IDE03626,Left dynamic AFS light motor: status,No malfunction,
IDE03627,Right dynamic AFS light motor: status,No malfunction,
IDE03628,Adjusting motor for variable left front lighting: status,No malfunction,
IDE03629,Adjusting motor for variable right front lighting: status,No malfunction,
IDE03630,Left headlight beam adjusting motor: specified value,-1.32, %
IDE03631,Right headlight beam adjusting motor: specified value,-1.32, %
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638-IDE03717,Stationary cornering lamp-Dim static left AFS light,0.0, %
IDE03638-IDE03718,Stationary cornering lamp-Dim static right AFS light,0.0, %
IDE03640,Dynamic AFS light,On,
IDE03669,Status of light distribution,not activated,
IDE03727,Variable left front lighting specified position,10.00, %
IDE03728,Variable right front lighting specified position,10.00, %
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adapt. value (zero pos),24.40, %
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),46.00, %
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,00,
IDE04805-MAS01448,Driving profile selection-Target value,00,
IDE06696-MAS00758,Headlamp power output stage supply voltage-Left Headlamp Power Output Stage,14.6, V
IDE06696-MAS00759,Headlamp power output stage supply voltage-Right Headlamp Power Output Stage,14.6, V
IDE08511-MAS07079,LED-headlamp: temperatures-Power output stage left,19, °C
IDE08511-MAS07080,LED-headlamp: temperatures-Power output stage right,27, °C
IDE08511-MAS07091,LED-headlamp: temperatures-Light left: channel 1 master,20, °C
IDE08511-MAS07092,LED-headlamp: temperatures-Light right: channel 1 master,27, °C
IDE08511-MAS07093,LED-headlamp: temperatures-Light left: channel 1 master 2,Temperature being detected / no temperature sensor installed,
IDE08511-MAS07094,LED-headlamp: temperatures-Light right: channel 1 master 2,Temperature being detected / no temperature sensor installed,
IDE08511-MAS07095,LED-headlamp: temperatures-Light left: channel 1 slave,Temperature being detected / no temperature sensor installed,
IDE08511-MAS07096,LED-headlamp: temperatures-Light right: channel 1 slave,Temperature being detected / no temperature sensor installed,
IDE08511-MAS07097,LED-headlamp: temperatures-Light left: channel 2 master,20, °C
IDE08511-MAS07098,LED-headlamp: temperatures-Light right: channel 2 master,27, °C
IDE08511-MAS07099,LED-headlamp: temperatures-Light left: channel 2 slave,20, °C
IDE08511-MAS07100,LED-headlamp: temperatures-Light right: channel 2 slave,26, °C
IDE08511-MAS07101,LED-headlamp: temperatures-Light left: channel 3 master,20, °C
IDE08511-MAS07102,LED-headlamp: temperatures-Light right: channel 3 master,26, °C
IDE08511-MAS07103,LED-headlamp: temperatures-Light left: channel 3 slave,Temperature being detected / no temperature sensor installed,
IDE08511-MAS07104,LED-headlamp: temperatures-Light right: channel 3 slave,Temperature being detected / no temperature sensor installed,
IDE08513-MAS07081,Supply voltages power output stage for LED-light-Power output stage left: terminal 15,14.5, V
IDE08513-MAS07082,Supply voltages power output stage for LED-light-Power output stage right: terminal 15,14.5, V
IDE08513-MAS07083,Supply voltages power output stage for LED-light-Power output stage left: terminal 56a,14.5, V
IDE08513-MAS07084,Supply voltages power output stage for LED-light-Power output stage right: terminal 56a,14.5, V
IDE08513-MAS07085,Supply voltages power output stage for LED-light-Power output stage left: terminal 56b,Voltage being detected / voltage not requested,
IDE08513-MAS07086,Supply voltages power output stage for LED-light-Power output stage right: terminal 56b,Voltage being detected / voltage not requested,
IDE08513-MAS07087,Supply voltages power output stage for LED-light-Power output stage left: daytime running light,Voltage being detected / voltage not requested,
IDE08513-MAS07088,Supply voltages power output stage for LED-light-Power output stage right: daytime running light,Voltage being detected / voltage not requested,
IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lamps,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE09060-MAS08254,LED headlamp: over-temperature protection-Headlamp left,not active,
IDE09060-MAS08255,LED headlamp: over-temperature protection-Right headlamp,not active,
IDE09069-MAS07091,LED headlamp: currents-Light left: channel 1 master,0, mA
IDE09069-MAS07092,LED headlamp: currents-Light right: channel 1 master,0, mA
IDE09069-MAS07093,LED headlamp: currents-Light left: channel 1 master 2,0, mA
IDE09069-MAS07094,LED headlamp: currents-Light right: channel 1 master 2,0, mA
IDE09069-MAS07095,LED headlamp: currents-Light left: channel 1 slave,0, mA
IDE09069-MAS07096,LED headlamp: currents-Light right: channel 1 slave,0, mA
IDE09069-MAS07097,LED headlamp: currents-Light left: channel 2 master,0, mA
IDE09069-MAS07098,LED headlamp: currents-Light right: channel 2 master,0, mA
IDE09069-MAS07099,LED headlamp: currents-Light left: channel 2 slave,0, mA
IDE09069-MAS07100,LED headlamp: currents-Light right: channel 2 slave,0, mA
IDE09069-MAS07101,LED headlamp: currents-Light left: channel 3 master,0, mA
IDE09069-MAS07102,LED headlamp: currents-Light right: channel 3 master,0, mA
IDE09069-MAS07103,LED headlamp: currents-Light left: channel 3 slave,0, mA
IDE09069-MAS07104,LED headlamp: currents-Light right: channel 3 slave,0, mA
IDE80001,Analysis 1,00 37 83 31 12 00 02 14 15 10 07 48 FF FF FF FF FF FF FF FF FF FF FF FF,
IDE80259-MAS07091,LED headlamp: currents 2-Light left: channel 1 master,0, mA
IDE80259-MAS07092,LED headlamp: currents 2-Light right: channel 1 master,0, mA
IDE80259-MAS07093,LED headlamp: currents 2-Light left: channel 1 master 2,0, mA
IDE80259-MAS07094,LED headlamp: currents 2-Light right: channel 1 master 2,0, mA
IDE80259-MAS07095,LED headlamp: currents 2-Light left: channel 1 slave,0, mA
IDE80259-MAS07096,LED headlamp: currents 2-Light right: channel 1 slave,0, mA
IDE80259-MAS07097,LED headlamp: currents 2-Light left: channel 2 master,0, mA
IDE80259-MAS07098,LED headlamp: currents 2-Light right: channel 2 master,0, mA
IDE80259-MAS07099,LED headlamp: currents 2-Light left: channel 2 slave,0, mA
IDE80259-MAS07100,LED headlamp: currents 2-Light right: channel 2 slave,0, mA
IDE80259-MAS07101,LED headlamp: currents 2-Light left: channel 3 master,0, mA
IDE80259-MAS07102,LED headlamp: currents 2-Light right: channel 3 master,0, mA
IDE80259-MAS07103,LED headlamp: currents 2-Light left: channel 3 slave,0, mA
IDE80259-MAS07104,LED headlamp: currents 2-Light right: channel 3 slave,0, mA
ENG101323,Headlight leveling control state,static,
ENG107365,Left dynamic cornering light value,32.00, °
ENG103737,Left headlight leveling control value,-132.0, mm
ENG107367,Left light distribution value,204.60, %
ENG108468,Right dynamic cornering light value,32.00, °
ENG102296,Right headlight leveling control value,-132.0, mm
ENG108470,Right light distribution value,204.60, %
Elapsed Time: 00:06
blockmap-57-8V0-919-129-A_WAUZZZ8V8F1029358-20241020-1538.CSV
;SW:8V0-919-129-A   HW:8V0-919-129 ---  TV Tuner
;Component:JP-DTV        H10 0990, Coding:01011C0000000100000000
;EV_TVMELC,001033,EV_TVMELC_VW37.rod
;Sunday,20,October,2024,15:38:06:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 3E22E73820FB99CA6D7-806A
Group,Description,Actual
IDE00019,Voltage terminal 30,14.4, V
IDE00767,No. of unscheduled ECU resets,0, counts
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,57,
IDE03880-MAS03425,MOST address-Physical address,04 01,
IDE04317-MAS00108,Total system run time-Day,116, d
IDE04317-MAS00109,Total system run time-Hours,16, H
IDE04317-MAS00110,Total system run time-Minutes,20, min
IDE06055,Invalid authentication (DTCP),5F,
IDE07938,Cause of system start,Optical data bus,
IDE07939,Last cause of system start,Optical data bus,
IDE08128,Antenna inputs,3,
IDE08129-MAS05807,Country setting TV-Norm-Coding,Japan,
IDE08129-MAS06596,Country setting TV-Norm-chosen in MMI,Japan,
IDE08129-MAS06597,Country setting TV-Norm-previously chosen MMI,Japan,
IDE08144-MAS01632,Card reader for TV-Status,Only free reception,
IDE08144-MAS01634,Card reader for TV-Supply voltage,5.0, V
IDE08144-MAS01991,Card reader for TV-Card reader,OK,
IDE08144-MAS04136,Card reader for TV-Current,5, mA
IDE08144-MAS06681,Card reader for TV-Number of mating cycles,0,
IDE08144-MAS06682,Card reader for TV-Card reader initialisation year,2014,
IDE08144-MAS06683,Card reader for TV-Card reader initialisation month,3,
IDE08144-MAS06684,Card reader for TV-Card reader initialisation day,25,
IDE08144-MAS06685,Card reader for TV-Initialisation ID,00005750590676858307       ,
IDE08144-MAS06686,Card reader for TV-Decoder card ID,00005750590676858307       ,
IDE08144-MAS06687,Card reader for TV-Conditions of use accepted,Yes,
IDE08145-MAS01808,Connection status antenna 1-Antenna current,68, mA
IDE08145-MAS06666,Connection status antenna 1-TV tuner to impedance converter,electrically OK,
IDE08145-MAS06667,Connection status antenna 1-Impedance converter to antenna,electrically OK,
IDE08145-MAS06668,Connection status antenna 1-Phantom voltage,8.6, V
IDE08145-MAS06669,Connection status antenna 1-level,28,
IDE08146-MAS01808,Connection status antenna 2-Antenna current,64, mA
IDE08146-MAS06666,Connection status antenna 2-TV tuner to impedance converter,electrically OK,
IDE08146-MAS06667,Connection status antenna 2-Impedance converter to antenna,electrically OK,
IDE08146-MAS06668,Connection status antenna 2-Phantom voltage,8.6, V
IDE08146-MAS06669,Connection status antenna 2-level,33,
IDE08147-MAS01808,Connection status antenna 3-Antenna current,64, mA
IDE08147-MAS06666,Connection status antenna 3-TV tuner to impedance converter,electrically OK,
IDE08147-MAS06667,Connection status antenna 3-Impedance converter to antenna,electrically OK,
IDE08147-MAS06668,Connection status antenna 3-Phantom voltage,8.6, V
IDE08147-MAS06669,Connection status antenna 3-level,0,
IDE08148-MAS01632,Tuner 1: Status-Status,On,
IDE08148-MAS06669,Tuner 1: Status-level,30,
IDE08148-MAS06670,Tuner 1: Status-Channel,013,
IDE08149-MAS01632,Tuner 2: Status-Status,On,
IDE08149-MAS06669,Tuner 2: Status-level,33,
IDE08149-MAS06670,Tuner 2: Status-Channel,013,
IDE08150-MAS01632,Tuner 3: Status-Status,On,
IDE08150-MAS06669,Tuner 3: Status-level,0,
IDE08150-MAS06670,Tuner 3: Status-Channel,023,
IDE08151-MAS01632,Video connection to terminal device-Status,Not available,
IDE08151-MAS06669,Video connection to terminal device-level,255,
IDE08152-MAS01632,Video connection to rear seat entertainment-Status,Not available,
IDE08152-MAS06669,Video connection to rear seat entertainment-level,255,
IDE08153-MAS06671,Audio connection to rear seat entertainment-Status RSE left,no measured value present,
IDE08153-MAS06672,Audio connection to rear seat entertainment-Status RSE right,no measured value present,
IDE08154,Video signal from external source,not installed,
IDE08211-MAS00106,History data control module reset-Year,2000,
IDE08211-MAS00107,History data control module reset-Month,0,
IDE08211-MAS00108,History data control module reset-Day,0,
IDE08211-MAS00109,History data control module reset-Hours,31,
IDE08211-MAS00110,History data control module reset-Minutes,63,
IDE08211-MAS00111,History data control module reset-Seconds,63,
IDE08211-MAS06734,History data control module reset-last cause of reset,FF,
IDE08211-MAS06735,History data control module reset-second-to last cause of reset,FF,
IDE08211-MAS06736,History data control module reset-third-to-last cause of reset,FF,
IDE08510,Information data,01 00 06 12 00 53 06 10 0F 14 03 1E 24 1A 00 8B 00 00 00 00 01 00 01 40 40 44 4D 00 0E 0D FF 00 0E 0D FF 00 00 00 03 40 00 00 44 01 30 00 00 C0 C0 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 42 00 0D 00 26 00 00 01 01 FF FF 00 00 FF FF 00 00 FF FF FF FF 00 00 00 63 00 63 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 06 10 0F 14 01 1E 24 1A 00 8B 00 00 00 00 01 00 01 40 40 44 4D 00 0E 0D FF 00 0E 0D FF 00 00 00 03 40 00 00 44 01 30 00 00 C0 C0 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 42 00 0D 00 23 00 00 01 01 FF FF 00 00 FF FF 00 00 FF FF FF FF 00 00 00 63 00 63 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5A 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 53 9F 0A AB 20 00 00 00 00 14 53 9F 0A CB 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 06 12 13 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5A 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 53 9F 0A AB 20 00 00 00 00 14 53 9F 0A CB 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 06 10 0F 14 1F 1E 24 1A 00 8B 00 00 00 01 00 00 01 40 40 44 4D 00 0E 0D 00 00 00 00 D7 00 00 00 4F 04 00 00 62 24 D7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 06 10 0F 14 21 1E 24 1A 00 8B 00 00 00 01 00 00 01 40 40 44 4D 00 0E 0D FF 00 0E 0D FF 00 00 00 03 40 00 00 44 01 20 00 00 B0 80 00 00 00 00 00 00 00 00 00 00 00 00 0E 00 00 42 00 0D 00 29 00 00 01 06 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 63 00 63 00 4F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 20 00 D2 04 63 EF F2 14 04 63 EF F2 14 04 63 EF F2 15 04 63 EF F2 15 04 63 EF F2 15 04 63 EF F2 16 04 63 EF F2 16 04 63 EF F2 16 20 01 46 A2 00 14 63 EF F4 07 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 04 63 EF F5 FC 04 63 EF F5 FC 04 63 EF F5 FC 04 63 EF F5 FC 04 63 EF F5 FC 04 63 EF F5 FD 04 63 EF F5 FD 04 63 EF F5 FD 04 63 EF F5 FD 04 63 EF F5 FD 04 63 EF F5 FD 04 63 EF F5 FE 04 63 EF F5 FE 04 63 EF F5 FE 04 63 EF F5 FE 00 53 02 11 15 2F 2F 15 3B F8 00 97 00 00 00 00 00 00 01 40 40 43 4D 00 0E 0D FF 00 0E 0D FF 00 00 00 03 42 00 00 44 01 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 0E 00 00 42 00 11 00 1A 77 00 01 01 00 00 00 00 02 1E 00 00 01 2C 01 DA 00 00 00 48 00 49 00 00 00 00 02 01 01 04 00 02 01 02 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 02 11 15 2F 2B 15 3B F8 00 9A 00 00 00 00 00 00 01 40 40 44 4D 00 0E 0D FF 00 0E 0D FF 00 00 00 03 42 00 00 44 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0E 00 00 42 00 11 00 18 77 66 01 01 00 00 FF FF 00 AB FF FF 00 15 00 10 FF FF 00 49 00 47 00 63 00 00 02 01 01 04 00 02 01 03 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 04 63 EF F1 63 04 63 EF F1 63 04 63 EF F1 63 04 63 EF F1 63 04 63 EF F1 63 04 63 EF F1 63 04 63 EF F1 64 04 63 EF F1 64 04 63 EF F1 64 04 63 EF F1 64 04 63 EF F1 64 04 63 EF F1 64 04 63 EF F1 7B 04 63 EF F1 7B 04 63 EF F1 7C 04 63 EF F1 7C 04 63 EF F1 7E 04 63 EF F1 8D 04 63 EF F1 8D 04 63 EF F1 8D 04 63 EF F1 8D 04 63 EF F1 8E 04 63 EF F1 BF 04 63 EF F1 BF 04 63 EF F1 C1 04 63 EF F2 10 04 63 EF F2 10 04 63 EF F2 10 00 53 02 11 15 2F 2D 15 3B F8 00 97 00 00 00 00 00 00 01 40 40 43 4D 00 0E 0D FF 00 0E 0D FF 00 00 00 03 42 00 00 44 01 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 0E 00 00 42 00 11 00 18 77 66 01 01 00 00 00 00 05 74 01 0D 00 2B 00 1A 00 21 00 48 00 48 00 45 00 00 02 01 01 04 00 02 01 03 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D7 00 00 00 4F 04 00 00 62 24 D7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D7 00 00 00 1E 03 00 00 62 24 D7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE08784-MAS03991,Reception level antenna-Reception level antenna 1,255, dB
IDE08784-MAS04344,Reception level antenna-Reception level antenna 2,255, dB
IDE08784-MAS07641,Reception level antenna-Duration hours,0, H
IDE08784-MAS07642,Reception level antenna-Dur. minutes,0, min
IDE08784-MAS07643,Reception level antenna-Duration seconds,0, s
IDE08784-MAS07644,Reception level antenna-Reception level antenna 3,255, dB
IDE08784-MAS07645,Reception level antenna-Avge. value reception level antenna 1,255, dB
IDE08784-MAS07646,Reception level antenna-Avge. value reception level antenna 2,255, dB
IDE08784-MAS07647,Reception level antenna-Avge. value reception level antenna 3,255, dB
MAS00464-MAS00110,Standard - ambient data 1-Minutes,38,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,0,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,201,
MAS04266-MAS01424,Temperature sensor 1-max.value,59, °C
MAS04266-MAS01425,Temperature sensor 1-min.value,-8, °C
MAS04266-MAS02238,Temperature sensor 1-Up-to-date,28, °C
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
Elapsed Time: 00:07
blockmap-5F-8V0-035-034-J_WAUZZZ8V8F1029358-20241020-1538.CSV
;SW:8V0-035-034-J   HW:8V0-035-034 ---  Information Electr.
;Component:MU-H-N-EU     H42 0404, Coding:017301010000000021110102000A02102F000226010001007E
;EV_MUHig6C3AW7,001115,EV_MUHig6C3AW7.rod
;Sunday,20,October,2024,15:38:24:49859
;VCID: 372CF21C0FC1A882AE1-8062
IDE00019,Voltage terminal 30,14.8, V
IDE00655-MAS01424,Temperature of processor circuit board-max.value,65, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,-15, °C
IDE00655-MAS02238,Temperature of processor circuit board-Up-to-date,43, °C
IDE00668-MAS03231,Microphone voltage consumption-Microphone 1,5.00, mA
IDE00767,No. of unscheduled ECU resets,6, counts
IDE00916-IDE02127,Speaker status-Left front speaker,Measuring value not available,
IDE00916-IDE02128,Speaker status-Right front speaker,Measuring value not available,
IDE00916-IDE02129,Speaker status-Left rear speaker,Measuring value not available,
IDE00916-IDE02130,Speaker status-Right rear speaker,Measuring value not available,
IDE00916-MAS01198,Speaker status-Center speaker,Measuring value not available,
IDE00916-MAS01201,Speaker status-Subwoofer speaker,Measuring value not available,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measuring value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measuring value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measuring value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measuring value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measuring value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measuring value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measuring value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measuring value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measuring value not available,
IDE01442-MAS06123,Pressing a button-Eject button,Not operated,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,14,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,9,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,64, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,35, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,50, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,30, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,electrically OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,255, mA
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,Not available,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE01992-ENG147302,Installation list: current installations-ECU present Bit 0,not installed,
IDE01992-ENG151629,Installation list: current installations-ECU present Bit 0 Main_Unit,installed,
IDE01992-ENG176482,Installation list: current installations-ECU present Bit 1,not installed,
IDE01992-ENG151628,Installation list: current installations-ECU present Bit 1 reserved,not installed,
IDE01992-ENG152005,Installation list: current installations-ECU present Bit 10 SmartControlCarrier2,not installed,
IDE01992-ENG152004,Installation list: current installations-ECU present Bit 11 WirelessCharger1,not installed,
IDE01992-ENG152003,Installation list: current installations-ECU present Bit 12 WirelessCharger2,not installed,
IDE01992-ENG152002,Installation list: current installations-ECU present Bit 13 Multimedia Operating Unit,not installed,
IDE01992-ENG152001,Installation list: current installations-ECU present Bit 14 Head-up Display,not installed,
IDE01992-ENG152022,Installation list: current installations-ECU present Bit 15,not installed,
IDE01992-ENG176468,Installation list: current installations-ECU present Bit 2,not installed,
IDE01992-ENG151627,Installation list: current installations-ECU present Bit 2 Sound_System,installed,
IDE01992-ENG176474,Installation list: current installations-ECU present Bit 3,not installed,
IDE01992-ENG151626,Installation list: current installations-ECU present Bit 3 TV_Tuner,installed,
IDE01992-ENG176502,Installation list: current installations-ECU present Bit 4,not installed,
IDE01992-ENG151625,Installation list: current installations-ECU present Bit 4 DVD_Changer,not installed,
IDE01992-ENG176449,Installation list: current installations-ECU present Bit 5,not installed,
IDE01992-ENG151624,Installation list: current installations-ECU present Bit 5 RearSeatEntertainment,not installed,
IDE01992-ENG152746,Installation list: current installations-ECU present Bit 6,not installed,
IDE01992-ENG151991,Installation list: current installations-ECU present Bit 6 MOST Kombi-Display,not installed,
IDE01992-ENG147289,Installation list: current installations-ECU present Bit 7,not installed,
IDE01992-ENG151990,Installation list: current installations-ECU present Bit 7 SmartDisplayCarrier1,not installed,
IDE01992-ENG152007,Installation list: current installations-ECU present Bit 8 SmartDisplayCarrier2,not installed,
IDE01992-ENG152006,Installation list: current installations-ECU present Bit 9 SmartControlCarrier1,not installed,
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,98, mA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,180.6, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,15,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,13,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,14,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,22,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,49, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,48, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,48, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,47, dBµV
IDE02384-ENG147282,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG151635,Status of event memory-ECU Dtc Bit 0 Main_Unit,Malfunction,
IDE02384-ENG176424,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG151634,Status of event memory-ECU Dtc Bit 1 reserved,OK,
IDE02384-ENG151996,Status of event memory-ECU Dtc Bit 10 SmartControlCarrier2,OK,
IDE02384-ENG151995,Status of event memory-ECU Dtc Bit 11 WirelessCharger1,OK,
IDE02384-ENG151994,Status of event memory-ECU Dtc Bit 12 WirelessCharger2,OK,
IDE02384-ENG151993,Status of event memory-ECU Dtc Bit 13 Multimedia Operating Unit,OK,
IDE02384-ENG151992,Status of event memory-ECU Dtc Bit 14 Head-up Display,OK,
IDE02384-ENG152021,Status of event memory-ECU Dtc Bit 15,OK,
IDE02384-ENG176458,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG151633,Status of event memory-ECU Dtc Bit 2 Sound_System,OK,
IDE02384-ENG176476,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG151632,Status of event memory-ECU Dtc Bit 3 TV_Tuner,OK,
IDE02384-ENG176459,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG151631,Status of event memory-ECU Dtc Bit 4 DVD_Changer,OK,
IDE02384-ENG176512,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG151630,Status of event memory-ECU Dtc Bit 5 Rear_Seat_Entertainment,OK,
IDE02384-ENG152743,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG152017,Status of event memory-ECU Dtc Bit 6 MOST Kombi-Display,OK,
IDE02384-ENG147299,Status of event memory-ECU Dtc Bit 7,OK,
IDE02384-ENG152016,Status of event memory-ECU Dtc Bit 7 SmartDisplayCarrier1,OK,
IDE02384-ENG151998,Status of event memory-ECU Dtc Bit 8 SmartDisplayCarrier2,OK,
IDE02384-ENG151997,Status of event memory-ECU Dtc Bit 9 SmartControlCarrier1,OK,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE03150-ENG147328,Readiness for bus sleep mode-Sleep Bit 0,Bus sleep mode,
IDE03150-ENG151641,Readiness for bus sleep mode-Sleep Bit 0 Main_Unit,End busstat,
IDE03150-ENG176564,Readiness for bus sleep mode-Sleep Bit 1,Bus sleep mode,
IDE03150-ENG151640,Readiness for bus sleep mode-Sleep Bit 1 reserved,Bus sleep mode,
IDE03150-ENG152013,Readiness for bus sleep mode-Sleep Bit 10 SmartControlCarrier2,Bus sleep mode,
IDE03150-ENG152012,Readiness for bus sleep mode-Sleep Bit 11 WirelessCharger1,Bus sleep mode,
IDE03150-ENG152011,Readiness for bus sleep mode-Sleep Bit 12 WirelessCharger2,Bus sleep mode,
IDE03150-ENG152010,Readiness for bus sleep mode-Sleep Bit 13 Bedienteil vorne,Bus sleep mode,
IDE03150-ENG152009,Readiness for bus sleep mode-Sleep Bit 14 Head-up Display,Bus sleep mode,
IDE03150-ENG152008,Readiness for bus sleep mode-Sleep Bit 15,Bus sleep mode,
IDE03150-ENG176563,Readiness for bus sleep mode-Sleep Bit 2,Bus sleep mode,
IDE03150-ENG151639,Readiness for bus sleep mode-Sleep Bit 2 Sound_System,End busstat,
IDE03150-ENG176562,Readiness for bus sleep mode-Sleep Bit 3,Bus sleep mode,
IDE03150-ENG151638,Readiness for bus sleep mode-Sleep Bit 3 TV_Tuner,End busstat,
IDE03150-ENG176561,Readiness for bus sleep mode-Sleep Bit 4,Bus sleep mode,
IDE03150-ENG151637,Readiness for bus sleep mode-Sleep Bit 4 DVD_Changer,Bus sleep mode,
IDE03150-ENG176560,Readiness for bus sleep mode-Sleep Bit 5,Bus sleep mode,
IDE03150-ENG151636,Readiness for bus sleep mode-Sleep Bit 5 RearSeatEntertainment,Bus sleep mode,
IDE03150-ENG152747,Readiness for bus sleep mode-Sleep Bit 6,Bus sleep mode,
IDE03150-ENG152000,Readiness for bus sleep mode-Sleep Bit 6 MOST Kombi-Display,Bus sleep mode,
IDE03150-ENG147327,Readiness for bus sleep mode-Sleep Bit 7,Bus sleep mode,
IDE03150-ENG151999,Readiness for bus sleep mode-Sleep Bit 7 SmartDisplayCarrier1,Bus sleep mode,
IDE03150-ENG152015,Readiness for bus sleep mode-Sleep Bit 8 SmartDisplayCarrier2,Bus sleep mode,
IDE03150-ENG152014,Readiness for bus sleep mode-Sleep Bit 9 SmartControlCarrier1,Bus sleep mode,
IDE03151-ENG117815,TP CAN identifier-ECUs TP-CAN-Identifier,|ECU TP-CAN-Identifier-Request Bit 0,ECU TP-CAN-Identifier-Response Bit 0|1907
IDE03477-MAS00106,GPS time-Year,2024,
IDE03477-MAS00107,GPS time-Month,10,
IDE03477-MAS00108,GPS time-Day,20,
IDE03477-MAS00109,GPS time-Hours,14,
IDE03477-MAS00110,GPS time-Minutes,38,
IDE03477-MAS00111,GPS time-Seconds,32,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,5F,
IDE04312-MAS00110,System run time-Minutes,13, min
IDE04317-MAS00108,Total system run time-Day,132, d
IDE04317-MAS00109,Total system run time-Hours,18, H
IDE04317-MAS00110,Total system run time-Minutes,31, min
IDE04329,Status of all SWaP functions,|ID number,Release code for a SWaP function
IDE04334-MAS02643,Public key for SWaP function-Key,9A 49 9B 04 8B AE BF AC 83 3F DE 81 BA 80 30 93 05 B6 6F ED 54 59 C3 8F 60 F6 10 A9 AA 5A 19 10 05 17 05 8F EA 49 D3 75 E3 F9 E1 54 4E 17 EE C9 C3 C1 DD 7D 30 16 DE B1 55 45 FD 9E 18 00 51 22 D6 A1 33 10 95 C0 DD CF 43 A1 C2 FE C0 BC AA 1C FE 48 49 25 89 9E DD 71 B0 D4 08 CF 16 BF 10 E2 E1 BC 70 A3 52 F2 E6 54 0B 60 05 5A A7 52 EC 4A 83 65 F7 68 19 66 F4 D5 46 C7 38 B1 6B 5A 1F 13 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-ENG117822,Bus identification-BusIdentifier,|Bus Identifier|Busmaster|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|,
IDE04344-ENG103664,Control module assignment-ECU IDs,|ECU ID,ECM name|5F
IDE04484,Regional codes,FE FF,
IDE04484,Regional codes,Not available,
IDE04484-MAS01632,Regional codes-Status,not active,
IDE04484-MAS03230,Regional codes-Optical drive,0,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Bluetooth,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04542-MAS03621,Status of active media source at output 2-Video codec,--------------------,
IDE04542-MAS03622,Status of active media source at output 2-Horizontal video resolution,65535,
IDE04542-MAS03623,Status of active media source at output 2-Vertical video resolution,65535,
IDE04542-MAS03778,Status of active media source at output 2-Active media source,Not available,
IDE04542-MAS03783,Status of active media source at output 2-Video Bitrate,65535, kbps
IDE04542-MAS03784,Status of active media source at output 2-Audio Bitrate,Not available,
IDE04542-MAS03785,Status of active media source at output 2-Digital rights management (DRM),Not available,
IDE04542-MAS03786,Status of active media source at output 2-Audio Codec,--------------------,
IDE04542-MAS03787,Status of active media source at output 2-Image format,--------------------,
IDE04542-MAS03788,Status of active media source at output 2-Horizontal image resolution,65535,
IDE04542-MAS03789,Status of active media source at output 2-Vertical image resolution,65535,
IDE04542-MAS03793,Status of active media source at output 2-Color depth,65535, bit
IDE04543-MAS00866,Authorization level for protection of minors-system origin,0,
IDE04543-MAS03778,Authorization level for protection of minors-Active media source,255,
IDE04544,Media type in optical drive,Audio CD,
IDE04545-IDE01588,Vehicle status-Driving direction,Measuring value not available,
IDE04545-IDE01714,Vehicle status-Status reverse gear,not selected,
IDE04545-IDE01766,Vehicle status-Distance impulses,65535,
IDE04545-IDE03684,Vehicle status-Vehicle stopped,Measuring value not available,
IDE04546-IDE00301,Calibration of navigation-Mileage,0.000, mm
IDE04546-MAS03647,Calibration of navigation-Calibration condition,complete,
IDE04547,Traffic information,OFF,
IDE04605-MAS01779,Navigation: Corrected position-Length,000ø19'08,6" W
IDE04605-MAS01780,Navigation: Corrected position-Width,053ø37'11,3" N
IDE04607-IDE03661,Angle of turn sensor for navigation-Rotation rate,0.0, °/s
IDE04607-ENG117452,Angle of turn sensor for navigation-gyro_sensor_x_acceleration,1.84, m/s²
IDE04607-ENG117453,Angle of turn sensor for navigation-gyro_sensor_y_acceleration,0.18, m/s²
IDE04607-ENG117454,Angle of turn sensor for navigation-gyro_sensor_z_acceleration,-10.06, m/s²
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04748,Counter for microphone over control,0,
IDE04750-MAS03876,SIM card-active SIM card,Not available,
IDE04750-MAS03877,SIM card-SIM ID,---------------,
IDE04750-MAS03878,SIM card-SIM IMSI,---------------,
IDE04750-MAS13882,SIM card-SIM card in main unit: status,Not available,
IDE04750-MAS13883,SIM card-SIM card in handset1 for telephone: status,Not available,
IDE04750-MAS13884,SIM card-SIM card in handset 2 for telephone: status,Not available,
IDE04750-MAS13885,SIM card-SIM card in mobile telephone: status,Not available,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth: device address,00 17 CA DB 43 4F,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05277-MAS04210,Available changes in regional codes-Available changes DVD,5,
IDE05277-MAS04211,Available changes in regional codes-Available changes Blue-Ray,4,
IDE05277-MAS04285,Available changes in regional codes-Regional codes DVD,2,
IDE05277-MAS04286,Available changes in regional codes-Blue-ray regional codes,1,
IDE05430,Telephone serial number,355816050110212,
IDE05432-IDE07365,Mechanics of display unit 1 for multimedia system-Limit switch for display open,operated,
IDE05432-IDE07366,Mechanics of display unit 1 for multimedia system-Limit switch for display close,Not operated,
IDE05432-MAS01458,Mechanics of display unit 1 for multimedia system-Operating condition,Open,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2127,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,15,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,0,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,31,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,63,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,63,
IDE05596-MAS00106,Last time GPS position outside map-Year,2127,
IDE05596-MAS00107,Last time GPS position outside map-Month,15,
IDE05596-MAS00108,Last time GPS position outside map-Day,0,
IDE05596-MAS00109,Last time GPS position outside map-Hours,31,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,63,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,63,
IDE05597-IDE03615,Bluetooth: Paired device 1-Variant,$·%Ä
Richard's S24samsungSM-S921B
NOT AVAILABLE
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth: device address,24 24 B7 25 04 C4,
IDE05597-MAS01483,Bluetooth: Paired device 1-Software version,$·%Ä
NOT AVAILABLE
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),24 24,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),24 24,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,$·%Ä
NOT AVAILABLE
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,Richard's S24
samsung
SM-S921B
NOT AVAILABLE
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,24 24,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,24 24,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,24 24,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,24 24,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,24 24,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,24 24,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,24 24,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,24 24,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,24 24,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,24 24,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,24 24,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,24 24,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,24 24,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,24 24,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,24 24,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,24 24,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,24 24,
IDE05598-IDE03615,Bluetooth: Paired device 2-Variant,iâ
Galaxy S23samsungSM-S911B
NOT AVAILABLEÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth: device address,DC 69 E2 8D 9D 90,
IDE05598-MAS01483,Bluetooth: Paired device 2-Software version,iâ
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),DC 69,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),DC 69,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,iâ
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,Galaxy S23
samsung
SM-S911B
NOT AVAILABLE
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,DC 69,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,DC 69,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,DC 69,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,DC 69,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,DC 69,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,DC 69,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,DC 69,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,DC 69,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,DC 69,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,DC 69,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,DC 69,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,DC 69,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,DC 69,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,DC 69,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,DC 69,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,DC 69,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,DC 69,
IDE05599-IDE03615,Bluetooth: Paired device 3-Variant,ÿ°-#Galaxy A05ssamsungSM-A057G
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth: device address,60 FF 12 B0 2D 23,
IDE05599-MAS01483,Bluetooth: Paired device 3-Software version,ÿ°-#Galaxy A05ssamsungSM-A057G
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),60 FF,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),60 FF,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,ÿ°-#Galaxy A05ssamsungSM-A057G
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,Galaxy A05s
samsung
SM-A057G
NOT AVAILABLE
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,60 FF,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,60 FF,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,60 FF,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,60 FF,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,60 FF,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,60 FF,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,60 FF,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,60 FF,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,60 FF,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,60 FF,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,60 FF,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,60 FF,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,60 FF,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,60 FF,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,60 FF,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,60 FF,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,60 FF,
IDE05600-IDE03615,Bluetooth: Paired device 4-Variant,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth: device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Software version,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Variant,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth: device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Software version,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,-1,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,23196823764169316,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,Not available,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05704-MAS02646,Key for digital transmission protection (DTCP)-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,0,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,0,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,67.55, %
IDE05814,Individualization characteristic,48 DF 63 B7 11,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,5,
IDE06055,Invalid authentication (DTCP),47,
IDE06425,Dynamometer mode: functional,not activated,
IDE06516-MAS01424,Temperature: optical drive-max.value,54, °C
IDE06516-MAS01425,Temperature: optical drive-min.value,-6, °C
IDE06516-MAS02238,Temperature: optical drive-Up-to-date,34, °C
IDE06517-MAS01424,Temperature: audio amplifier-max.value,61, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,-18, °C
IDE06517-MAS02238,Temperature: audio amplifier-Up-to-date,30, °C
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,59, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-21, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Up-to-date,37, °C
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,67, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,0, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Up-to-date,46, °C
IDE06522-MAS01424,Temperature of phone unit-max.value,53, °C
IDE06522-MAS01425,Temperature of phone unit-min.value,1, °C
IDE06522-MAS02238,Temperature of phone unit-Up-to-date,34, °C
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07364,GPS reception status,GPS data available,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE08530-MAS00106,Connection status online basic services-Year,2000.0, yr
IDE08530-MAS00107,Connection status online basic services-Month,0, Months
IDE08530-MAS00108,Connection status online basic services-Day,0, d
IDE08530-MAS00109,Connection status online basic services-Hours,0, H
IDE08530-MAS00110,Connection status online basic services-Minutes,0, min
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,0,
IDE08530-ENG151979,Connection status online basic services-Server_HTTP_Status_Code_Textual,Service deactivated,
IDE08531-MAS00106,Connection status online license services-Year,2000.0, yr
IDE08531-MAS00107,Connection status online license services-Month,0, Months
IDE08531-MAS00108,Connection status online license services-Day,0, d
IDE08531-MAS00109,Connection status online license services-Hours,0, H
IDE08531-MAS00110,Connection status online license services-Minutes,0, min
IDE08531-MAS07132,Connection status online license services-Code status,0,
IDE08531-MAS07134,Connection status online license services-ID services,0,
IDE08531-MAS07135,Connection status online license services-Activation status,No expiry,
IDE08531-MAS07136,Connection status online license services-Exp. year,0, yr
IDE08531-MAS07137,Connection status online license services-Exp. month,0, Months
IDE08531-MAS07138,Connection status online license services-Exp. day,0, d
IDE08531-ENG151979,Connection status online license services-Server_HTTP_Status_Code_Textual,not defined,
IDE10600-MAS01632,Status of the navigation database-Status,valid,
IDE10600-ENG126194,Status of the navigation database-nav_db_module,|Country Code,Region Code
MAS00464-MAS00111,Standard - ambient data 1-Seconds,35,
MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
MAS00778-IDE03619,Multimedia System 1-System condition,On,
MAS00778-IDE05228,Multimedia System 1-Operating hour counter,2905, H
MAS00778-MAS00110,Multimedia System 1-Minutes,6, min
MAS00778-MAS00362,Multimedia System 1-Battery voltage,14.6, V
MAS00778-MAS02200,Multimedia System 1-Highest measured temperature,76, °C
MAS00778-MAS02201,Multimedia System 1-Temperature,35, °C
MAS00778-MAS03691,Multimedia System 1-Dimming,42, %
MAS00837-MAS01632,Telephone Transceiver-Status,Unknown,
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,1,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,3,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,105.8, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,35, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,30, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,0,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,no tuned IBOC Audio Service,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,44, dBµV
MAS01991-IDE00010,Card reader-Serial number,FF FF FF FF,
MAS01991-IDE01001,Card reader-Application,--,
MAS01991-MAS01632,Card reader-Status,not connected,
MAS01991-MAS03159,Card reader-Manufacturer,FF,
MAS01991-MAS03375,Card reader-Major version,15,
MAS01991-MAS03376,Card reader-Minor version,15,
MAS01991-MAS03959,Card reader-Write-protection,Not available,
MAS01991-MAS04388,Card reader-Card type,-----,
MAS01991-MAS13476,Card reader-Manufacturing date: month,15, Months
MAS01991-MAS13477,Card reader-Manufacturing date: year,2255, yr
MAS03121,Ring break diagnostic line status,Supply voltage,
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, Months
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS03781-MAS03794,Interface for external multimedia devices-Adapter cable,not connected,
MAS03781-MAS03795,Interface for external multimedia devices-Adapter voltage,772,
MAS03782-ENG117422,WLAN-IP_Address,192.168.001.001                        ,
MAS03782-ENG117423,WLAN-IP_Subnetmask,255.255.255.000                        ,
MAS03782-ENG117421,WLAN-MAC_Address,00 17 CA D6 43 4F,
MAS04324-MAS04326,Bluetooth: connected devices-Device name,23196823764169316,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,Hands free profile (HFP),
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,23196823764169316,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,Hands free profile (HFP),
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,ERROR,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,8,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,8,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,0, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,24, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,10, Months
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,19, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,15, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,16, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,4, s
ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,359, °
ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
ENG117855-ENG117392,System_Character_Recognition-touchpanel_information,
Elapsed Time: 00:27
blockmap-6C-5Q0-907-441-A_WAUZZZ8V8F1029358-20241020-1539.CSV
;SW:5Q0-907-441-A   HW:5Q0-907-441-A ---  Back-up Cam.
;Component:MQB RVC Mid   H07 0140, Coding:027300060201000300
;EV_2CamSysRearPASE,006016,EV_2CamSysRearPASE_AU37.rod
;Sunday,20,October,2024,15:39:32:49859
;VCID: 303EC900EAAF7FBAEFB-8064
IDE00019,Voltage terminal 30,14.56, V
IDE00303-MAS00222,Status: doors/lids 1-Rear lid,closed,
IDE00303-MAS00223,Status: doors/lids 1-Hood,closed,
IDE00303-MAS01374,Status: doors/lids 1-Trailer,detected,
IDE00924-MAS02983,Steering angle-Steering wheel angle,4.900, °
IDE00924,Steering angle,0.300, °
IDE01164,Parking aid button,Not available,
IDE01714,Status reverse gear,not selected,
IDE02322,Parking aid indicator light,Not available,
IDE03619,System condition,passive,
IDE04515,Supply voltage for camera,6.09, V
IDE06449-MAS05746,Camera system calibration-Rearview camera calibration status,Calibration ended,
IDE06449-MAS05747,Camera system calibration-Side camera calibration status,not coded/not installed,
IDE06449-MAS05748,Camera system calibration-Rearview camera calibration progress,0, %
IDE06449-MAS05749,Camera system calibration-Side camera calibration progress,0, %
IDE06449-MAS05750,Camera system calibration-Rearview camera calibration repeat attempts,0,
IDE06449-MAS05751,Camera system calibration-Side camera calibration repeat attempts,0,
IDE06449-MAS05753,Camera system calibration-Cause of rearview camera calibration error,No malfunction,
IDE06449-MAS05754,Camera system calibration-Cause of side camera calibration error,Calibration not yet performed,
IDE06449-MAS05802,Camera system calibration-Side camera calibration resumption,No resumption,
IDE06449-MAS05803,Camera system calibration-Rearview camera calibration resumption,No resumption,
IDE07199-IDE00787,Calculation of runtime data for assistance line representation-Cause for cancellation,No malfunction,
IDE07199-MAS01632,Calculation of runtime data for assistance line representation-Status,completed,
IDE07199-MAS04389,Calculation of runtime data for assistance line representation-Number of repeat attempts,0,
IDE07199-MAS05634,Calculation of runtime data for assistance line representation-Progress,0, %
IDE07402,External activation,Not available,
MAS00464-MAS00106,Standard - ambient data 1-Year,2024,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,19,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,39,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,22,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,201, counts
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,91836, km
ENG119197-ENG119070,camera_calibration_parameters-Cam0 Calibration Result judgment,00 00 E0 40 00 00 E0 40 00 00 E0 40 00 00 20 41 00 00 20 41 00 00 A0 41 00 00 A0 40,
ENG119197-ENG119060,camera_calibration_parameters-Cam0 Changing default data - Ground to Camera Z,0.00, mm
ENG119197-ENG119061,camera_calibration_parameters-Cam0 Changing default data - Ground to wheel arch Z,0.00, mm
ENG119197-ENG119068,camera_calibration_parameters-Cam0 division counts horizontal,5,
ENG119197-ENG119069,camera_calibration_parameters-Cam0 division counts vertical,4,
ENG119197-ENG119062,camera_calibration_parameters-Cam0 Fixed value input - Ground to Camera Z,0.00, mm
ENG119197-ENG119063,camera_calibration_parameters-Cam0 Fixed value input - Ground to wheel arch Z,675.90, mm
ENG119197-ENG119067,camera_calibration_parameters-Cam0 height of marker,45.40, mm
ENG119197-ENG119064,camera_calibration_parameters-Cam0 Marker size Full-size or Half-size,half size,
ENG119197-ENG119058,camera_calibration_parameters-Cam0 Transversal position front axle,-4.00, mm
ENG119197-ENG119059,camera_calibration_parameters-Cam0 Transversal position rear axle,-1.30, mm
ENG119197-ENG119065,camera_calibration_parameters-Cam0 X direction of marker red ribbon,4180.00, mm
ENG119197-ENG119066,camera_calibration_parameters-Cam0 Y direction of marker,0.00, mm
ENG119197-ENG119083,camera_calibration_parameters-Cam1 Calibration Result judgment,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG119197-ENG119073,camera_calibration_parameters-Cam1 Changing default data - Ground to Camera Z,0.00, mm
ENG119197-ENG119074,camera_calibration_parameters-Cam1 Changing default data - Ground to wheel arch Z,0.00, mm
ENG119197-ENG119081,camera_calibration_parameters-Cam1 division counts horizontal,0,
ENG119197-ENG119082,camera_calibration_parameters-Cam1 division counts vertical,0,
ENG119197-ENG119075,camera_calibration_parameters-Cam1 Fixed value input - Ground to Camera Z,0.00, mm
ENG119197-ENG119076,camera_calibration_parameters-Cam1 Fixed value input - Ground to wheel arch Z,0.00, mm
ENG119197-ENG119080,camera_calibration_parameters-Cam1 height of marker,0.00, mm
ENG119197-ENG119077,camera_calibration_parameters-Cam1 Marker size Full-size or Half-size,full size,
ENG119197-ENG119071,camera_calibration_parameters-Cam1 Transversal position front axle,0.00, mm
ENG119197-ENG119072,camera_calibration_parameters-Cam1 Transversal position rear axle,0.00, mm
ENG119197-ENG119078,camera_calibration_parameters-Cam1 X direction of marker red ribbon,0.00, mm
ENG119197-ENG119079,camera_calibration_parameters-Cam1 Y direction of marker,0.00, mm
ENG119196-ENG119090,camera_calibration_tolerance-RV_Calibration_Result,0.16, px
ENG119196-ENG119084,camera_calibration_tolerance-RV_Calibration_Tolerance_alpha,-1.85, °
ENG119196-ENG119085,camera_calibration_tolerance-RV_Calibration_Tolerance_beta,-1.68, °
ENG119196-ENG119086,camera_calibration_tolerance-RV_Calibration_Tolerance_gamma,0.45, °
ENG119196-ENG119087,camera_calibration_tolerance-RV_Calibration_Tolerance_x,-1.74, mm
ENG119196-ENG119088,camera_calibration_tolerance-RV_Calibration_Tolerance_y,1.51, mm
ENG119196-ENG119089,camera_calibration_tolerance-RV_Calibration_Tolerance_z,0.00, mm
ENG119196-ENG119097,camera_calibration_tolerance-SV_Calibration_Result,0.00, px
ENG119196-ENG119091,camera_calibration_tolerance-SV_Calibration_Tolerance_alpha,0.00, °
ENG119196-ENG119092,camera_calibration_tolerance-SV_Calibration_Tolerance_beta,0.00, °
ENG119196-ENG119093,camera_calibration_tolerance-SV_Calibration_Tolerance_gamma,0.00, °
ENG119196-ENG119094,camera_calibration_tolerance-SV_Calibration_Tolerance_x,0.00, mm
ENG119196-ENG119095,camera_calibration_tolerance-SV_Calibration_Tolerance_y,0.00, mm
ENG119196-ENG119096,camera_calibration_tolerance-SV_Calibration_Tolerance_z,0.00, mm
Elapsed Time: 00:03
blockmap-A9-8V0-907-159_WAUZZZ8V8F1029358-20241020-1539.CSV
;SW:8V0-907-159   HW:4H0-907-159-A ---  Struct. Borne Sound
;Component:SAS-GEN 2     H06 0012, Coding:
;EV_SoundActuaGen2AU64X,003010,EV_SoundActuaGen2AU64X_003_VW37.rod
;Sunday,20,October,2024,15:39:46:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 7DA020346D7D42D234D-8028
Group,Description,Actual
IDE00030,Status of actuator test,canceled,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,3,
IDE04805-MAS01448,Driving profile selection-Target value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
Elapsed Time: 00:00
blockmap-BB-5Q0-959-395-B_WAUZZZ8V8F1029358-20241020-1539.CSV
;SW:5Q0-959-395-B   HW:5Q0-959-395-B ---  Door Rear Drv
;Component:TSG HFS       020 0025, Coding:004D16204001040000001002
;EV_DCURearDriveMINKLO,006003,EV_DCURearDriveMAXKLO.rod
;Sunday,20,October,2024,15:39:54:49859
;VCID: 40DE99C05A0FEF3A1FB-8014
IDE01766-MAS02248,Distance impulses-Signal state,OK,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,14.6, V
IDE04580,Dimming of inside door handle lighting,100, %
IDE04581,Dimming for interior ambient lighting,255, %
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,Not operated,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05726,Dimmer terminal 58xd,47, %
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.0, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,0, A
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,0, %
IDE06621,Driver side rear power window button,Not operated,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,127.5, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.5, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.5, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.5, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.5, %
IDE06940,Rear window regulator child lock: driver side,active,
IDE07110-MAS01632,Recognition of motor variant for window regul.-Status,not detected,
IDE07110-MAS04606,Recognition of motor variant for window regul.-Parameter set,15,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,15, °C
IDE07415,Comfort function for rear window regulator: driver side,not active,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,50,
MAS06010,Ambient light,255, %
Elapsed Time: 00:09
blockmap-BC-5Q0-959-395-B_WAUZZZ8V8F1029358-20241020-1540.CSV
;SW:5Q0-959-395-B   HW:5Q0-959-395-B ---  Door Rear Pass
;Component:TSG HBFS      020 0025, Coding:004D16204001040000001002
;EV_DCURearPasseMINKLO,006003,EV_DCURearPasseMAXKLO.rod
;Sunday,20,October,2024,15:40:12:49859
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,14.5, V
IDE02266,Passenger side rear power window button,Not operated,
IDE05726,Dimmer terminal 58xd,43, %
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,Not operated,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.0, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,0, A
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06941,Rear window regulator child lock: frt.pass. side,active,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,14, °C
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,127.5, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.5, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.5, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.5, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.5, %
MAS00464-MAS00110,Standard - ambient data 1-Minutes,40,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,7,
Elapsed Time: 00:08
blockmap-OBD_WAUZZZ8V8F1029358-20241020-1540.CSV
;33-OBD2
;Sunday,20,October,2024,15:40:27:49859
03,Fuel system 1/2 status,Closed loop
04,Calculated load value,17.3 %,17.3 %
05,Engine coolant temperature,92 °C,92 °C
06,Short Term Trim - Bank 1,0.0 %
07,Long Term Trim - Bank 1,-5.5 %
0B,Intake Manifold Absolute Pressure,30 kPa abs
0C,Engine RPM,765 /min,764 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,1.5 Degrees
0F,Intake air temperature,35 °C
11,Absolute Throttle Position,11.8 %
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.790 V
1C,OBD Requirements Met,Euro-OBD
1F,Time since engine start,886 s
21,Distance travelled with MIL on,1539 km
23,Fuel Rail Press (rel),13230 kPa rel
2E,Commanded Evaporative Purge,38.4 %
2F,Fuel Level Input,100.0 %
30,Warm-ups since DTC cleared,81
31,Distance since DTC cleared,1794 km
33,Barometric pressure,100 kPa abs
34,Bank 1 Sensor 1 Status,0.990 Lambda,-0.043 mA
3C,B1S1 Cat. Temp.,296.1 °C
42,Control module voltage,14.609 V,14.100 V
43,Absolute Load Value,18 %
44,Commanded Equivalence Ratio,0.991 Lambda
45,Relative Throttle Position,1.6 %
46,Ambient Air Temp,15 °C
47,Absolute Throttle Position B,12 %
49,Accelerator Pedal Position D,14.5 %,14.5 %
4A,Accelerator Pedal Position E,14.9 %
4C,Commanded Throttle Actuator Control,1.6 %
51,Fuel type,Gasoline
56,Long term sec. O2 trim bank 1/3,0.0 %
70,Boost Press Ctrl A/B,BP_A act:99.8 kPa
Type 02 - VIN : WAUZZZ8V8F1029358 (Address E8)
Type 04 - Calibration ID : 8V0259A 0004BECK (Address E8)
Type 04 - Calibration ID : 0D9300012L  4932 (Address E9)
Type 06 - Calibration Verification Number : 3675C1CE (Address E8)
Type 06 - Calibration Verification Number : 0000BC3B (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 681
    Ignition cycle count : 2390
         Catalyst monitor bank 1 : 67 / 119
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 719 / 681
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 1276 / 666
         AIR monitor : 0 / 0
         EVAP monitor : 0 / 0
         Secondary O2 Sensor monitor bank 1 : 60 / 119
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Gaz@VDS
Lincolnshire, UK
C?ID=592224
AutoScan: WAUZZZ8V8F1029358
Sunday,20,October,2024,15:40:40:49859
Dealer/Shop Name: VDS
VIN: WAUZZZ8V8F1029358   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 47 52 55
          57 5F 6C A9 BB BC
VIN: WAUZZZ8V8F1029358   Mileage: 91836km-57064miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CJXF)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---    CVN: 3675C1CE
   Coding: 0A1D00322466010B3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259A 001006
   ROD: EV_ECM20TFS0208V0906259A.rod
   VCID: 3E22E73820FB99CA6D7-806A
   VINID: 9D196AAAA2262160400890C5200542629A
21388 - Valve for Exhaust Flap 1 (N321)
          P3019 00 {00101111} - Open Circuit
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:50
                    Engine RPM: 1629.00 /min
                    Normed load value: 69.8 %
                    Coolant temperature: 31 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.480 V
                    Engine: operating status: PL
                    STATE_LS_SAE{1}: OL_CDN
                    T_AST_SAE: 1 s
                    MAP_MES_SAE: 102 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 45.312500 %
                    FUP_H_SAE: 6880.0 kPa
21399 - Valve for Exhaust Flap 2 (N322)
          P3023 00 {00101111} - Open Circuit
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:50
                    T_AST_SAE: 1 s
14961 - Oxygen (Lambda) Sensor B1 S1
          P0133 00 {11101101} - Response too Slow
                    Mileage: 90112 km
                    Date: 2024.08.29
                    Time: 15:58:14
                    Engine RPM: 1527.50 /min
                    Normed load value: 24.7 %
                    Vehicle speed: 50 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 13.242 V
                    STATE_LS_SAE{1}: CL
                    FAC_LAM_LIM{1}: 0.723 %
                    Lambda probes actual: bank1: 0.9922
                    TEG_DYN_LS_UP{1}: 531.0375 °C
                    Lambda probe ageing: bank 1: dynamic factor: 1.6768
                    TTIP_MES_LS_UP{1}: 785.0000 °C
15072 - Engine Start Blocked by Immobilizer
          P1570 00 {00100000} - -
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4932
   Revision: 05852204    Serial number: TFK01405121372 CVN: 0000BC3B
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1F1C3ABC8731F0C2461-804A
10657 - RPM Signal from ECU
          P0726 00 {00000010} - Implausible Signal
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 61394000000457
   Coding: 31F193A254222A75017A070541CB698CC92A5480E08296F6F84150880608
   ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
   VCID: 46D28FD8782BC10A257-8012
   Revision: 00021000    Serial number: 0336423852 Dataset Number: 8V0909577C  0009
   Coding: 030C0C
   VCID: 3A2AEB283CD3B5EA51F-806E
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000339139
   Coding: 03100014110000011000000000001500
   VCID: 3334C60C1BB944A2929-8066
   Humidity sensor: exterior:
   Serial number: 82680137000000000001
   Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
   Component: BCM MQBAB HNA H18 0134
   Serial number: 01011414200476 Dataset Number: 8V0909514G  0079
   Coding: 07151C46C24106FD01804004B11807A80800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7AAA2B287C5375EA11F-802E
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140503  041 0585
   Serial number:         140512201738
   Coding: 0A47F7
   Serial number: 22694962
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
   Serial number: 28 03 2014  00000702
   Serial number: 000000000ZY141181MJA
   Serial number: 00000000000029946206
   Sunroof control module:
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO3007321X
   Coding: 901E00
16650 - Bulb 2 for Rear Left Turn Signal
          B12CE 15 {00001000} - Open or Short to Plus
                    Reset counter: 214
                    Mileage: 91180 km
                    Date: 2024.09.29
                    Time: 15:47:38
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 13.2 V
                    Outside temperature: 13.5 °C
204290 - Remote key 1
          B1479 18 {00001000} - Current Too Low
                    Reset counter: 215
                    Mileage: 90326 km
                    Date: 2024.09.07
                    Time: 14:42:43
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.0 V
                    Outside temperature: 27.0 °C
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 {00001000} - Alert Emergency Activation Stage 1
                    Reset counter: 238
                    Mileage: 91730 km
                    Date: 2024.10.16
                    Time: 19:16:41
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.5 V
                    Outside temperature: 14.5 °C
721416 - Switch for Sunroof
          B13C4 29 {00001000} - Signal Implausible
                    Reset counter: 218
                    Mileage: 90098 km
                    Date: 2024.08.29
                    Time: 15:24:54
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.9 V
                    Outside temperature: 18.0 °C
721420 - Switch for Sunroof
          B13C4 01 {00001000} - Electrical Failure
                    Reset counter: 218
                    Mileage: 90098 km
                    Date: 2024.08.29
                    Time: 15:24:54
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.9 V
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331414502175 Dataset Number: 8V0909526D  0038
   Coding: 0070150011
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 42DA93C85403FD2A09F-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 M    HW: 5Q0 907 567 M
   Component: ACC3          H10 0398
   Serial number: 20051403070391 Dataset Number: 8V0909863C  0013
   Coding: 023E1301FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 45D088D4452DCA122CD-8010
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 C    HW: 8V0 907 376 B
   Component: DAEMPFUNGS-SG H08 0066
   Serial number:       120514000 Dataset Number: 8V0909554C  0012
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
   VCID: 41D89CC45105E632105-8014
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Serial number: 003MMR01FLG+ Dataset Number: 8V0909602D  0008
   Coding: 98FCC000000000005C54000000C800000065
   VCID: 005E59C01A8F2F3A5FB-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 002 805 14
   Serial number: 357670000008F124EF01
   Subsystem 2 - Part No SW: -----------    HW: 480 002 805 14
   Serial number: 358670000009F124EF03
   Subsystem 3 - Part No SW: -----------    HW: 480 402 205 14
   Serial number: 3516502A7142B1D1313-
   Subsystem 4 - Part No SW: -----------    HW: 480 400 805 14
   Serial number: 3526502B1157E9E231FK
   Subsystem 5 - Part No SW: -----------    HW: 480 401 504 14
   Serial number: 3556502A31529DF4239G
   Part No SW: 8V0 953 521 CR    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 02061408490315
   Coding: E018
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 0C467DF026C77B5A333-8058
   Part No SW: 8V0 920 871 G    HW: 8V0 920 871 G
   Component: KOMBI         H02 4291
   Coding: 278D181A3E80AE000181E8001000000000000000
   Shop #: WSC 12345 123 61029
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 21051410801424 Dataset Number: 8V0909515E  0055
   Coding: 030100042F085A005B0002789C0B00000001010000000000000000000000
   GVL: 01D43C1000000600400C90000002CC0000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_011.rod
   Generator:
   Serial number: 8710083603
8782081 - ROD - Unknown Error Code
          - 00 {00001001}
                    Reset counter: 200
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:34
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00012.05.14 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   Revision: 00000000    Serial number: 14000129799002
   Coding: 5D00000000000000
   VCID: 3436C5101EB7439A8B3-8060
   Serial number: 16051401101961 Dataset Number: 8V0909872E  0030
   Coding: 005D1E205C01040000001003
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Dataset Number: 8V0909852G  0018
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3530F81415CD5A92BCD-8060
   Part No SW: 8V0 035 465 D    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0420
   Serial number: AUZ8ZAEN900CSED Dataset Number: 8V0909510B  0016
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 3928F42439D5BEF2585-806C
   Serial number: 24051402090421 Dataset Number: 8V0909873E  0029
   Coding: 005D16205E01040000001003
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 3FDC9A3C27F190C2661-806A
65558 - Heated Exterior Mirror
          B11F8 14 {00001001} - Open or Short to Ground
                    Reset counter: 147
                    Mileage: 90480 km
                    Date: 2024.09.15
                    Time: 07:46:59
   Component: AFS-ECU       H01 0091
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865J  0037
   Coding: 01A600002B200200
   Subsystem 1 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7530
   Coding: E00100
   Subsystem 2 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7530
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7040
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7040
   Coding: E00100
5545009 - LED Headlamp Power Output Stage; Left
          B149C 31 {00001000} - No Signal
                    Reset counter: 233
                    Mileage: 90281 km
                    Date: 2024.09.05
                    Time: 17:14:30
5544753 - LED Headlamp Power Output Stage; Right
          B149B 31 {00001000} - No Signal
                    Reset counter: 229
                    Mileage: 91254 km
                    Date: 2024.10.04
                    Time: 14:06:50
Address 57: TV Tuner (R78)       Labels:| 8V0-919-DTV-V1.clb
   Part No SW: 8V0 919 129 A    HW: 8V0 919 129
   Component: JP-DTV        H10 0990
   Coding: 01011C0000000100000000
   ASAM Dataset: EV_TVMELC 001033
   ROD: EV_TVMELC_VW37.rod
   Part No SW: 8V0 035 034 J    HW: 8V0 035 034
   Component: MU-H-N-EU     H42 0404
   Serial number: K5F AW7CC016ZZ Dataset Number: 8V2909545E  0040
   Coding: 017301010000000021110102000A02102F000226010001007E
   ASAM Dataset: EV_MUHig6C3AW7 001115
   ROD: EV_MUHig6C3AW7.rod
   VCID: 372CF21C0FC1A882AE1-8062
   Subsystem 1 - Part No SW: V03 959 802 SS    HW: -----------
   Component: ECE 2023/2024  --- 0330
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9EY2011Q1
   Subsystem 3 - Part No SW: 8V0 919 614 AA    HW: 8V0 919 614 AA
   Component: ControlUnit_H  H81 0816
   Serial number: C1000017051400020064
   Compact disc data bank:
   Component: Gracenote  --- 2008
1598 - Data Set Implausible
          B2012 00 {00001001} - -
          {Control module (data record download) - implausible data record for visible MMI system languages}
                    Reset counter: 120
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:37
                    Voltage terminal 30: 12.4 V
          U1014 00 {00001001} - -
                    Reset counter: 120
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:38
          B201A 00 {00001001} - -
          {Check software version management}
                    Fault Frequency: 39
                    Reset counter: 200
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:39
                    Status_Software_Version_Management-module_name: MFC1H37xA/HRAS
          B2000 87 {00001001} - Missing Message
                    Reset counter: 120
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:48
                    Voltage terminal 30: 12.2 V
                    Software module: status-SW_Status_Consistency: 00 00 03
                    Software module: status-SW_Status_Device: Dsp
   Dataset Number: 8V0909460C  0016
   Coding: 027300060201000300
   ROD: EV_2CamSysRearPASE_AU37.rod
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 140513200182
0006 - Actuator for Structural Accoustics
          P193A 00 {00001001} - Open Circuit
                    Fault Frequency: 11
                    Reset counter: 200
                    Mileage: 90042 km
                    Date: 2024.08.28
                    Time: 12:48:34
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0025
   Serial number: 22051402091104 Dataset Number: 8V0909897C  0017
   Coding: 004D16204001040000001002
   ROD: EV_DCURearDriveMAXKLO.rod
   Component: TSG HBFS      020 0025
   Serial number: 22051402091102 Dataset Number: 8V0909896C  0017
   ROD: EV_DCURearPasseMAXKLO.rod
End----------(Elapsed Time: 14:54, VBatt start/end: 11.9V/14.7V)-----------
adpmap-01-8V0-906-259-A_WAUZZZ8V8F1029358-20241020-1528.CSV
;SW:8V0-906-259-A   HW:06K-907-425-B ---  Engine
;Component:2.0l R4 TFSI  H13 0004, Coding:0A1D00322466010B3004
;EV_ECM20TFS0208V0906259A,001006,EV_ECM20TFS0208V0906259A.rod
;Sunday,20,October,2024,15:28:53:49859
;VCID: 3E22E73820FB99CA6D7-806A
IDE00259-Idle RPM correction,0 /min,1
IDE01945-Engine run-in oil pressure,not active ,1
IDE04158-Activation of start/stop function,active ,1
IDE06726-Timing deviation after chain replacement: intake bank 1,-0.31 °,2
IDE06728-Timing deviation after chain replacement: exhaust bank 1,-3.06 °,2
IDE06730-Timing deviation after other repairs: intake bank 1,0.00 °,2
IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 °,2
IDE06734-Timing deviation: current value intake bank 1,1.00 °,2
IDE06736-Timing deviation: current value exhaust bank 1,-0.56 °,2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1,3 ,1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,5 ,1
IDE06742-Chain elongation: initial values valid: intake bank 1,active ,1
IDE06744-Chain elongation: initial values valid: exhaust bank 1,active ,1
Elapsed Time: 00:04
adpmap-02-0D9-300-012-L_WAUZZZ8V8F1029358-20241020-1529.CSV
;SW:0D9-300-012-L   HW:02E-927-770-AQ ---  Auto Trans
;Component:DQ250-6A MQB  H52 4932, Coding:0014
;EV_TCMDQ250021,001001,EV_TCMDQ250021.rod
;Sunday,20,October,2024,15:29:23:49859
;VCID: 1F1C3ABC8731F0C2461-804A
Elapsed Time: 00:00
adpmap-03-5Q0-907-379-M_WAUZZZ8V8F1029358-20241020-1529.CSV
;SW:5Q0-907-379-M   HW:5Q0-907-379-H ---  ABS Brakes
;Component:ESC           H31 0571, Coding:31F193A254222A75017A070541CB698CC92A5480E08296F6F84150880608
;EV_Brake1UDSContiMK100IPB,033001,EV_Brake1UDSContiMK100IPB_033_VW48.rod
;Sunday,20,October,2024,15:29:39:49859
;VCID: 46D28FD8782BC10A257-8012
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE03493-Driver's door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Weak ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-IDE05287-Electromechanical parking brake-Automatic application,activated ,2
IDE04645-MAS05667-Electromechanical parking brake-Driver presence recognition via brake pedal,not activated ,2
IDE04765-Counter steer support,Medium ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire Pressure Monitoring System (TPMS),2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake Boost,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05337-Starting vibration reduction,Strong ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,2 ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS07300-Monitoring infotainment control unit,Security access required,1
MAS08145-Hill-start assistant: increase threshold,6 %,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,2
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,2
ENG118148-Developer_Function_1,0 ,1
ENG122612-Developer_Function_100,Security access required,1
ENG122613-Developer_Function_101,Security access required,1
ENG122614-Developer_Function_102,Security access required,1
ENG122615-Developer_Function_103,Security access required,1
ENG122616-Developer_Function_104,Security access required,1
ENG122617-Developer_Function_105,Security access required,1
ENG122618-Developer_Function_108,Security access required,1
ENG125054-Developer_Function_110,Security access required,1
ENG118149-Developer_Function_2,Security access required,1
ENG118200-Developer_Function_3,Security access required,1
ENG118201-Developer_Function_4,Security access required,1
ENG118202-fill_and_bleed_information,Security access required,1
Elapsed Time: 00:13
adpmap-05-5Q0-959-435-A_WAUZZZ8V8F1029358-20241020-1530.CSV
;SW:5Q0-959-435-A   HW:5Q0-959-435 ---  Acc/Start Auth.
;Component:VWKESSYMQB    021 0604, Coding:030C0C
;EV_KessyHellaMQBAB,002011,EV_KessyHellaMQBAB_002.rod
;Sunday,20,October,2024,15:30:05:49859
;VCID: 3A2AEB283CD3B5EA51F-806E
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105803-ENG120037-DeveloperCoding: Key Minder (Byte 1)-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG105803-ENG101923-DeveloperCoding: Key Minder (Byte 1)-Retry handling big car / expanded search,activated ,1
ENG105803-ENG100928-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening,not activated ,1
ENG105803-ENG99649-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG105803-ENG99417-DeveloperCoding: Key Minder (Byte 1)-Softtouch mounted,installed ,1
ENG105804-ENG99123-DeveloperCoding: Key Minder (Byte 2)-Inhibit ID-transmitter for passive go,activated ,1
ENG105804-ENG102581-DeveloperCoding: Key Minder (Byte 2)-Lock prevention tailgate,not activated ,1
ENG105804-ENG101018-DeveloperCoding: Key Minder (Byte 2)-No locking with ID-transmitter last used interior,activated ,1
ENG105804-ENG103451-DeveloperCoding: Key Minder (Byte 2)-Re-open after passive comfort closing,activated ,1
ENG105804-ENG99711-DeveloperCoding: Key Minder (Byte 2)-Re-open last handling,ZV entriegeln ,1
ENG105804-ENG103237-DeveloperCoding: Key Minder (Byte 2)-Re-open tailgate,activated ,1
ENG105804-ENG104103-DeveloperCoding: Key Minder (Byte 2)-Send numbers of ID-transmitters interior (ELV-Scan),not activated ,1
ENG105807-ENG121989-DeveloperCoding: Passiv Entry Exit (Byte 1)-Impairment Entry / Exit key on low battery,not activated ,1
ENG105807-ENG125240-DeveloperCoding: Passiv Entry Exit (Byte 1)-lf_crc,not activated ,1
ENG105807-ENG99763-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: access door not open,activated ,1
ENG105807-ENG103722-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: all doors not open,not activated ,1
ENG105808-ENG155267-DeveloperCoding: Passiv Entry Exit (Byte 2)-lf_shutdown,not activated ,1
ENG105808-ENG155268-DeveloperCoding: Passiv Entry Exit (Byte 2)-lf_shutdown_gotrigger,not activated ,1
ENG105808-ENG148905-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry at door locked/safed OR ZV safed,activated ,1
ENG105808-ENG123039-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit,activated ,1
ENG105808-ENG103289-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG105808-ENG103620-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: retry with antennastep 1,not activated ,1
ENG105808-ENG103529-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry: second control concept,not activated ,1
ENG105809-ENG114300-DeveloperCoding: Passiv Go-Change Go antenna at every request,not activated ,1
ENG105809-ENG114299-DeveloperCoding: Passiv Go-Change Go antenna during retry challenge,activated ,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG148896-DeveloperCoding: Proximity Sensor-Easy Trunk,not activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,Fahrertürgriff wird nicht abgeschaltet ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",Fehlerspeichereintrag wird nicht unterdrueckt ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG148895-DeveloperCoding: Search lights-ZAT active during clamp 58xt on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG105810-ENG120039-DeveloperCoding: Sonstiges-Backdoor TSG,not installed ,1
ENG105810-ENG103075-DeveloperCoding: Sonstiges-Battery manager mounted,activated ,1
ENG105810-ENG102728-DeveloperCoding: Sonstiges-Diagnostic: service 86 - response on event,not activated ,1
ENG105810-ENG98656-DeveloperCoding: Sonstiges-internal,not activated ,1
ENG105810-ENG102591-DeveloperCoding: Sonstiges-Response extension for scan procedure,not activated ,1
ENG105810-ENG99430-DeveloperCoding: Sonstiges-Scan Procedure: Timeoutcontrol active,activated ,1
ENG105810-ENG104010-DeveloperCoding: Sonstiges-Use default antenna data,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,installed ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,Right hand steering ,1
ENG105825-Diagnostic: wait time after power on,3000 ms,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG98656-internal,0 B,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,4 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,14 B,1
ENG107595-MCTX settling phase,10 B,1
ENG108165-Passive Entry Exit: control by pulling the door handle during active DSL (timeout),2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,210 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,1000 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG108580-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Go),190 ms,1
ENG108581-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Kombi),700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
Elapsed Time: 00:25
adpmap-08-8V0-820-043-D_WAUZZZ8V8F1029358-20241020-1530.CSV
;SW:8V0-820-043-D   HW:8V0-820-043-D ---  Auto HVAC
;Component:AC Automat    H13 0052, Coding:03100014110000011000000000001500
;EV_AirCondiFrontVaAU37X,008020,EV_AirCondiFrontVaAU37X_008.rod
;Sunday,20,October,2024,15:30:52:49859
;VCID: 3334C60C1BB944A2929-8066
IDE01476-Store air recirculation setting with terminal 15 OFF,Matching coding ,1
IDE01479-Gear ratio of engine - A/C compressor,0.00 ,1
IDE01482-After-run of parking heater or parking ventilation,not activated ,1
IDE01483-Blower voltage with voice control,not activated ,1
IDE01488-Auxiliary heating retrofit without CAN,not installed ,1
IDE01490-Fresh air blower voltage offset,Default ,1
IDE01491-Offset for temperature in summer mode,Default ,1
IDE01492-Offset for temperature in winter mode,Default ,1
IDE01493-Sensitivity of air quality sensor,Little ,1
IDE01495-After-run time of auxiliary heater with air conditioner off,120 s,1
IDE01500-Reduction of window condensation with high humidity,Matching coding ,1
IDE01503-Running time of basic setting for compressor break-in,120 s,1
IDE01505-Tolerance range for basic setting of flap end stops,15 °,1
IDE01506-Tolerance range for flap end stops,10 °,1
IDE01536-Post heating of auxiliary heating,10 min,1
IDE02371-Time until seat heating performance is reduced from stage 3 to stage 2,10 min,1
IDE02372-Time until seat heating performance is reduced from stage 2 to stage 1,0 min,1
IDE03252-Window condensation parameter for start/stop function,5 ,1
IDE03253-A/C comfort parameter for start/stop function,5 ,1
IDE04074-Driving program,Matching coding ,1
IDE06544-Speed shut-off threshold for compressor break-in (engine speed),1800 /min,1
IDE06545-Blower voltage for production routines,7 V,1
IDE06547-Air distribution for production routines,Air distribution upper body vents and footwell ,1
IDE06593-Air recirculation for production routines,Recirculating air ,1
IDE07106-Application characteristics,Matching coding ,1
IDE07108-A/C styles,Matching coding ,1
IDE07398-Blower logic with manual adjustment,Matching coding ,1
IDE07951-Time until head area heater performance is reduced from stage 3 to stage 2,0 min,1
IDE07952-Time until head area heater performance is reduced from stage 2 to stage 1,0 min,1
IDE10278-Behavior of compressor during moderate outside temperatures,deactivate in Eco mode ,1
IDE80006-Analysis 6,not activated ,1
IDE80007-Analysis 7,00 00 ,2
IDE80008-Analysis 8,activated ,1
IDE80009-Analysis 9,not activated ,1
IDE80011-Analysis 11,not activated ,1
Elapsed Time: 00:10
adpmap-09-5Q0-937-085-AC_WAUZZZ8V8F1029358-20241020-1531.CSV
;SW:5Q0-937-085-AC   HW:5Q0-937-085-AC ---  Cent. Elect.
;Component:BCM MQBAB HNA H18 0134, Coding:07151C46C24106FD01804004B11807A80800000000000000000000000000
;EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
;Sunday,20,October,2024,15:31:56:49859
;VCID: 7AAA2B287C5375EA11F-802E
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8 ,12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,not active ,12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,active ,12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,1000 ms,12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,1000 ms,12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,1000 ms,12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,1000 ms,12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1000 ms,12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,active ,12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,12
IDE01550-Service position,133.30 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,active ,4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,4
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken,not active ,8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW,not active ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,not active ,8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,-0.25 °,14
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,50.00 %/s,14
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,OFF ,14
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.00 km/h,14
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.00 °C,14
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.00 °C,14
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,90 °,14
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.00 °C,14
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,30 °,14
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,32.00 km/h,14
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,OFF ,14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,SMLS ,8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.25 ,8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,1.00 %,8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,separate ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,not active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,60 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,6400 lx,8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,20 seconds ,8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,60 seconds ,8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
IDE04927-ENG126845-Window heater-FSH Automatik,not active ,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,4
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,4
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,driver door contact thatcham ,4
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,4
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,1 Alarm ,4
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,4
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,keine verzoegerung ,4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,8
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8
IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active ,8
IDE05142-ENG115755-Access control-Notschließfunktion,not active ,8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,nur wenn freigegeben ,8
IDE05142-ENG115758-Access control-Valet Parking,not active ,8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,active ,8
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,00 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,00 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,08 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,18 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,09 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,19 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1C ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,48 ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,4C ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,00 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,00 ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,minimize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,minimize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,127 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,127 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,0 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,0 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,30 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,80 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,80 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,100 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,30 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,100 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,100 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,100 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,100 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,100 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,100 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,100 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,30 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,80 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,80 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,30 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,100 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,100 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,127 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,127 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,85 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,85 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,10 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,10 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,100 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,100 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,00 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,00 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,41 ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,42 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,2B ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,2D ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,2F ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,02 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,03 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,04 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,05 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,06 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,03 ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,04 ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,not active ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,not active ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,38 - LED Blinkleuchten ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,38 - LED Blinkleuchten ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,39 - LED Bremsleuchten ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,39 - LED Bremsleuchten ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,8 - allgemeine Glühlampe 12W ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,8 - allgemeine Glühlampe 12W ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,46 - LED Kleinleistung ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,5 - LED Abblendlicht ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,5 - LED Abblendlicht ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,46 - LED Kleinleistung ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,46 - LED Kleinleistung ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,only_if_closed ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,0 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,0 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,2 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,4 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,8 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,26 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,26 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,8 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,45 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,45 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,45 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,45 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,45 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,46 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,9 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,30 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,30 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,30 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,10 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,8 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,8 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,0 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,0 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,0 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,3 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,5 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,3 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,5 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,3 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,5 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,30 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,9 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,10 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,30 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,30 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,30 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,30 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,30 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,9 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,10 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,20 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,20 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,6 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,7 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,6 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,7 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE05822-Anti-theft alarm system vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 09 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 FF F6 06 00 0F 1E 00 85 0F 32 F7 64 23 45 21 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 FF F6 56 00 0F 1E 00 86 28 32 F7 65 0F 43 21 57 1B 03 32 3F 3A 69 58 93 0D 09 A3 03 F5 F6 26 00 0F 19 00 88 0F 2D F7 68 1E 45 21 57 1B 03 22 3F 3A 69 58 93 0C 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 66 23 45 21 57 9B 23 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 20 24 2B 3F ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,20.00 °C,24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,19.00 °C,24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,28.00 °C,24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,27.50 °C,24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,41.00 °C,24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,40.50 °C,24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,50.00 °C,24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,49.00 °C,24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,63.00 °C,24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,62.50 °C,24
IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschalten,not active ,8
IDE06096-ENG116597-Interior lights-KL30G ohne PWM,active ,8
IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampe,not active ,8
IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschalten,active ,8
IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert,50 %,8
IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei Tag,Daytime running lamps ,4
IDE06864-ENG115832-Daytime running lamps-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active ,4
IDE06864-ENG116592-Daytime running lamps-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,4
IDE06864-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,4
IDE06864-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4
IDE06864-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO,active ,4
IDE06864-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
IDE06864-ENG115733-Daytime running lamps-Tagfahrlichtkontrollleuchte,not active ,4
IDE06864-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
IDE07356-Position during interval mode,21.69 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,not active ,8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,not active ,8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,active ,8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,active ,8
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,not active ,8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active ,8
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not active ,8
IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active ,8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active ,8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,not active ,8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,8
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,8
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,8
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,8
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,8
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,8
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,8
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,8
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,8
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,8
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,8
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,8
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,8
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,8
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,8
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,8
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,8
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,8
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,8
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,8
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,8
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,8
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,500 ms,8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,800 ms,8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,not installed ,8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,not installed ,8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE09377-IDE00761-Multi contour seat driver's side-Run-on time,No Response From Subnet Component,4
IDE09377-IDE03006-Multi contour seat driver's side-Running time of massage function,No Response From Subnet Component,4
IDE09377-IDE03007-Multi contour seat driver's side-Component location,No Response From Subnet Component,4
IDE09377-IDE03099-Multi contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,4
IDE09377-IDE03100-Multi contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,4
IDE09378-IDE00761-Multicontour seat passenger side-Run-on time,No Response From Subnet Component,4
IDE09378-IDE03006-Multicontour seat passenger side-Running time of massage function,No Response From Subnet Component,4
IDE09378-IDE03007-Multicontour seat passenger side-Component location,No Response From Subnet Component,4
IDE09378-IDE03099-Multicontour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,4
IDE09378-IDE03100-Multicontour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,4
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,4
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,4
IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,installed ,2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,installed ,2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,installed ,2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
IDE09733-ENG147405-LED bar setting values-Lockout time,0 s,10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE10298-Alternating park position 1,18.69 °,2
IDE10299-Alternating park position 2,21.69 °,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
MAS05055-lower turn position,27.69 °,2
MAS05056-upper turn position,166.30 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht,No Response From Subnet Component,60
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten,No Response From Subnet Component,60
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3,No Response From Subnet Component,60
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne,No Response From Subnet Component,60
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung,No Response From Subnet Component,60
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0,No Response From Subnet Component,60
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1,No Response From Subnet Component,60
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10,No Response From Subnet Component,60
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2,No Response From Subnet Component,60
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3,No Response From Subnet Component,60
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4,No Response From Subnet Component,60
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5,No Response From Subnet Component,60
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6,No Response From Subnet Component,60
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7,No Response From Subnet Component,60
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8,No Response From Subnet Component,60
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9,No Response From Subnet Component,60
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0,No Response From Subnet Component,60
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1,No Response From Subnet Component,60
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10,No Response From Subnet Component,60
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2,No Response From Subnet Component,60
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3,No Response From Subnet Component,60
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4,No Response From Subnet Component,60
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5,No Response From Subnet Component,60
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6,No Response From Subnet Component,60
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7,No Response From Subnet Component,60
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8,No Response From Subnet Component,60
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9,No Response From Subnet Component,60
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,60
ENG125611-ENG125702-Blower_1_Backrest_Left-Read_Coding_Pin,No Response From Subnet Component,60
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,60
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,60
ENG125612-ENG125702-Blower_1_Backrest_Right-Read_Coding_Pin,No Response From Subnet Component,60
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,60
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,60
ENG125609-ENG125702-Blower_1_Cushion_Left-Read_Coding_Pin,No Response From Subnet Component,60
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,60
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,60
ENG125610-ENG125702-Blower_1_Cushion_Right-Read_Coding_Pin,No Response From Subnet Component,60
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,60
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,11
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,11
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,11
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,11
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,11
ENG125594-ENG125682-Driver_failure_detection_multi-contour_seat-s_GrobleckerkennungDauer,No Response From Subnet Component,11
ENG125594-ENG125680-Driver_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,11
ENG125594-ENG125681-Driver_failure_detection_multi-contour_seat-s_Leckageerkennung,No Response From Subnet Component,11
ENG125594-ENG125678-Driver_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,No Response From Subnet Component,11
ENG125594-ENG125679-Driver_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,No Response From Subnet Component,11
ENG125588-ENG125667-Driver_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125666-Driver_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125668-Driver_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125673-Driver_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125672-Driver_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125674-Driver_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125670-Driver_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125669-Driver_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125671-Driver_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125676-Driver_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125675-Driver_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125677-Driver_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125664-Driver_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125663-Driver_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125665-Driver_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125667-Driver_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125666-Driver_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125668-Driver_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125673-Driver_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125672-Driver_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125674-Driver_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125670-Driver_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125669-Driver_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125671-Driver_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125676-Driver_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125675-Driver_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125677-Driver_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125664-Driver_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125663-Driver_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125665-Driver_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125667-Driver_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125666-Driver_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125668-Driver_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125673-Driver_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125672-Driver_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125674-Driver_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125670-Driver_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125669-Driver_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125671-Driver_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125676-Driver_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125675-Driver_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125677-Driver_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125664-Driver_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125663-Driver_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125665-Driver_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125667-Driver_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125666-Driver_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125668-Driver_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125673-Driver_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125672-Driver_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125674-Driver_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125670-Driver_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125669-Driver_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125671-Driver_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125676-Driver_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125675-Driver_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125677-Driver_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125664-Driver_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125663-Driver_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125665-Driver_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125667-Driver_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125666-Driver_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125668-Driver_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125673-Driver_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125672-Driver_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125674-Driver_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125670-Driver_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125669-Driver_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125671-Driver_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125676-Driver_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125675-Driver_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125677-Driver_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125664-Driver_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125663-Driver_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125665-Driver_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125667-Driver_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125666-Driver_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125668-Driver_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125673-Driver_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125672-Driver_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125674-Driver_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125670-Driver_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125669-Driver_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125671-Driver_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125676-Driver_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125675-Driver_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125677-Driver_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125664-Driver_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125663-Driver_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125665-Driver_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125596-ENG125687-Driver_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,11
ENG125596-ENG125689-Driver_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,No Response From Subnet Component,11
ENG125596-ENG125685-Driver_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,No Response From Subnet Component,11
ENG125596-ENG125688-Driver_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,11
ENG125596-ENG125686-Driver_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,11
ENG125595-ENG125684-Driver_pressure_values_multi-contour_seat_driver-s_DruckschwelleNachlauf,No Response From Subnet Component,11
ENG125595-ENG126855-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_m,No Response From Subnet Component,11
ENG125595-ENG126854-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_o,No Response From Subnet Component,11
ENG125595-ENG126856-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_u,No Response From Subnet Component,11
ENG125595-ENG126857-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,11
ENG125595-ENG126863-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,11
ENG125595-ENG126862-Driver_pressure_values_multi-contour_seat_driver-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,11
ENG125595-ENG126859-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_m,No Response From Subnet Component,11
ENG125595-ENG126858-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_o,No Response From Subnet Component,11
ENG125595-ENG126860-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_u,No Response From Subnet Component,11
ENG125595-ENG126864-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_Massage,No Response From Subnet Component,11
ENG125595-ENG126861-Driver_pressure_values_multi-contour_seat_driver-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,11
ENG125595-ENG125683-Driver_pressure_values_multi-contour_seat_driver-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,11
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,100.00 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,95.00 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,80.00 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,40.00 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,20.00 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,10.00 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,5.00 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,3.00 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,1.00 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,100 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,150 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,6.00 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,6.00 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,16.00 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,30.00 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,60.00 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.00 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
ENG126651-ENG115658-Kennlinie Abdimmen-x0,No Response From Subnet Component,10
ENG126651-ENG101574-Kennlinie Abdimmen-X1,No Response From Subnet Component,10
ENG126651-ENG115664-Kennlinie Abdimmen-x10,No Response From Subnet Component,10
ENG126651-ENG99557-Kennlinie Abdimmen-X2,No Response From Subnet Component,10
ENG126651-ENG102140-Kennlinie Abdimmen-X3,No Response From Subnet Component,10
ENG126651-ENG102936-Kennlinie Abdimmen-X4,No Response From Subnet Component,10
ENG126651-ENG103548-Kennlinie Abdimmen-X5,No Response From Subnet Component,10
ENG126651-ENG113992-Kennlinie Abdimmen-X6,No Response From Subnet Component,10
ENG126651-ENG115661-Kennlinie Abdimmen-x7,No Response From Subnet Component,10
ENG126651-ENG115662-Kennlinie Abdimmen-x8,No Response From Subnet Component,10
ENG126651-ENG115663-Kennlinie Abdimmen-x9,No Response From Subnet Component,10
ENG126651-ENG115659-Kennlinie Abdimmen-y0,No Response From Subnet Component,10
ENG126651-ENG99777-Kennlinie Abdimmen-Y1,No Response From Subnet Component,10
ENG126651-ENG115668-Kennlinie Abdimmen-y10,No Response From Subnet Component,10
ENG126651-ENG100480-Kennlinie Abdimmen-Y2,No Response From Subnet Component,10
ENG126651-ENG100773-Kennlinie Abdimmen-Y3,No Response From Subnet Component,10
ENG126651-ENG100631-Kennlinie Abdimmen-Y4,No Response From Subnet Component,10
ENG126651-ENG102174-Kennlinie Abdimmen-Y5,No Response From Subnet Component,10
ENG126651-ENG113993-Kennlinie Abdimmen-Y6,No Response From Subnet Component,10
ENG126651-ENG115665-Kennlinie Abdimmen-y7,No Response From Subnet Component,10
ENG126651-ENG115666-Kennlinie Abdimmen-y8,No Response From Subnet Component,10
ENG126651-ENG115667-Kennlinie Abdimmen-y9,No Response From Subnet Component,10
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links Dunkelphase ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,08 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,38 - LED Blinkleuchten ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Blinken links Dunkelphase ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,42 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,18 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,38 - LED Blinkleuchten ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Blinken rechts Dunkelphase ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links Dunkelphase ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts Dunkelphase ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts Dunkelphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,39 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,39 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,80 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,80 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,37 - allgemeine LED bis 12W ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,80 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,80 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,37 - allgemeine LED bis 12W ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Parking light right ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100 ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,8 - allgemeine Glühlampe 12W ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,8 - allgemeine Glühlampe 12W ,16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,30 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,30 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,85 ,16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,10 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Coming Home oder Leaving Home aktiv ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Daytime running lamps ,16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,Blinken links aktiv (beide Phasen) ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100 ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 1 ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 1 ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 1 ,16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,30 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,30 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,85 ,16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,10 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Coming Home oder Leaving Home aktiv ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Daytime running lamps ,16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,100 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,100 ,16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,100 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,48 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lamps ,16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Coming Home oder Leaving Home aktiv ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,Blinken links aktiv (beide Phasen) ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,100 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,100 ,16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,100 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lamps ,16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Coming Home oder Leaving Home aktiv ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,Blinken rechts aktiv (beide Phasen) ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,03 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,46 - LED Kleinleistung ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Ambientelicht 1 ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,04 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,46 - LED Kleinleistung ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Ambientelicht 2 ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
ENG125607-ENG126865-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,12
ENG125607-ENG126867-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,12
ENG125607-ENG126866-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,12
ENG125607-ENG126868-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,12
ENG125607-ENG125690-Passenger_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,12
ENG125604-ENG125693-Passenger_failure_detection_multi-contour_seat-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,12
ENG125604-ENG125680-Passenger_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,12
ENG125604-ENG125681-Passenger_failure_detection_multi-contour_seat-s_Leckageerkennung,No Response From Subnet Component,12
ENG125604-ENG125678-Passenger_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,No Response From Subnet Component,12
ENG125604-ENG125679-Passenger_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,No Response From Subnet Component,12
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,No Response From Subnet Component,12
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,No Response From Subnet Component,12
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125667-Passenger_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125666-Passenger_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125668-Passenger_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125673-Passenger_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125672-Passenger_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125674-Passenger_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125670-Passenger_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125669-Passenger_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125671-Passenger_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125676-Passenger_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125675-Passenger_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125677-Passenger_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125664-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125663-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125665-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125606-ENG125687-Passenger_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,12
ENG125606-ENG125689-Passenger_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,No Response From Subnet Component,12
ENG125606-ENG125685-Passenger_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,No Response From Subnet Component,12
ENG125606-ENG125688-Passenger_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,12
ENG125606-ENG125686-Passenger_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,12
ENG125605-ENG126871-Passenger_pressure_values_multi-contour_seat-s_Druckschwelle_Nachlauf,No Response From Subnet Component,12
ENG125605-ENG126855-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_m,No Response From Subnet Component,12
ENG125605-ENG126854-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_o,No Response From Subnet Component,12
ENG125605-ENG126856-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_u,No Response From Subnet Component,12
ENG125605-ENG126857-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,12
ENG125605-ENG126863-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,12
ENG125605-ENG126870-Passenger_pressure_values_multi-contour_seat-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,12
ENG125605-ENG126859-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_m,No Response From Subnet Component,12
ENG125605-ENG126858-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_o,No Response From Subnet Component,12
ENG125605-ENG126860-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_u,No Response From Subnet Component,12
ENG125605-ENG126864-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Massage,No Response From Subnet Component,12
ENG125605-ENG126869-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,12
ENG125605-ENG125683-Passenger_pressure_values_multi-contour_seat-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,12
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
ENG125614-Reset_Blower_1_Backrest_Left,No Response From Subnet Component,8
ENG125615-Reset_Blower_1_Backrest_Right,No Response From Subnet Component,8
ENG125613-Reset_Blower_1_Cushion_Left,No Response From Subnet Component,8
ENG125616-Reset_Blower_1_Cushion_Right,No Response From Subnet Component,8
Elapsed Time: 01:47
adpmap-10-5Q0-919-294-J_WAUZZZ8V8F1029358-20241020-1533.CSV
;SW:5Q0-919-294-J   HW:5Q0-919-294-A ---  Park/Steer Assist
;Component:PARKHILFE 8K  H03 0051, Coding:0070150011
;EV_EPHVA18AU3700000,002024,EV_EPHVA18AU3700000_VW26.rod
;Sunday,20,October,2024,15:33:54:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 42DA93C85403FD2A09F-8016
IDE01169-Audio lowering request,On ,1
IDE03782-Switch-off speed for parking assist,10 km/h,1
MAS01426-Rear parking aid buzzer: volume,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 4 ,1
MAS01428-Front parking aid buzzer: volume,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 6 ,1
Elapsed Time: 00:05
adpmap-13-5Q0-907-567-M_WAUZZZ8V8F1029358-20241020-1534.CSV
;SW:5Q0-907-567-M   HW:5Q0-907-567-M ---  Auto Dist. Reg
;Component:ACC3          H10 0398, Coding:023E1301FE0309
;EV_ACCBoschMQB,001024,EV_ACCBoschMQB_AU37.rod
;Sunday,20,October,2024,15:34:09:49859
;VCID: 45D088D4452DCA122CD-8010
IDE00056-History data 1,On ,1
IDE00820-Activating and deactivating all development messages,OFF ,1
IDE00899-Option for presetting of time gap,OFF ,1
IDE01795-Heated lens,On ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE07570-Multiple assignment of buttons in multi-function steering wheel,OFF ,1
IDE07977-Plausibilization of activation of emergency brake function,On ,1
IDE07978-Avoidance for impermissible passing process,On ,1
Elapsed Time: 00:03
adpmap-14-8V0-907-376-C_WAUZZZ8V8F1029358-20241020-1534.CSV
;SW:8V0-907-376-C   HW:8V0-907-376-B ---  Susp. Elect.
;Component:DAEMPFUNGS-SG H08 0066, Coding:
;EV_AudiMagneRide,002003,EV_AudiMagneRide.rod
;Sunday,20,October,2024,15:34:20:49859
;VCID: 41D89CC45105E632105-8014
IDE00820-ENG119636-Activating and deactivating all development messages-DEV_Unit_0103,not activated ,4
IDE00820-ENG119637-Activating and deactivating all development messages-DEV_Unit_0104,not activated ,4
IDE00820-ENG110578-Activating and deactivating all development messages-S_100,not activated ,4
IDE00820-ENG110579-Activating and deactivating all development messages-S_101,not activated ,4
IDE00820-ENG110580-Activating and deactivating all development messages-S_102,not activated ,4
IDE00820-ENG119638-Activating and deactivating all development messages-Set_internal_fault_code,00 00 00 ,4
IDE00820-ENG99057-Activating and deactivating all development messages-XCP,Development ,4
IDE04891-IDE02001-Adapting high values-Body height left front wheel house edge,364 mm,8
IDE04891-IDE02002-Adapting high values-Body height right front wheel house edge,365 mm,8
IDE04891-IDE02003-Adapting high values-Body height left rear wheel house edge,353 mm,8
IDE04891-IDE02004-Adapting high values-Body height right rear wheel house edge,354 mm,8
ENG119639-Enable Constant current on all dampers,not activated ,1
ENG119640-Enable Damper test mode,not activated ,1
Elapsed Time: 00:01
adpmap-15-5Q0-959-655-AB_WAUZZZ8V8F1029358-20241020-1534.CSV
;SW:5Q0-959-655-AB   HW:5Q0-959-655-AB ---  Airbags
;Component:AirbagVW20    014 0385, Coding:98FCC000000000005C54000000C800000065
;EV_AirbaVW20SMEVW37X,002130,EV_AirbaVW20SMEVW37X_VW37.rod
;Sunday,20,October,2024,15:34:39:49859
;VCID: 005E59C01A8F2F3A5FB-8054
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,18
MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,not defined ,8
MAS00975-MAS00003-Airbag adaptations-Front passenger airbag igniter,activated ,8
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,activated ,8
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,8
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch not parameterized ,8
Elapsed Time: 00:03
adpmap-16-8V0-953-521-CR_WAUZZZ8V8F1029358-20241020-1534.CSV
;SW:8V0-953-521-CR   HW:5Q0-953-549-C ---  Steering wheel
;Component:Lenks. Modul  002 0110, Coding:E018
;EV_SMLSKLOMQB,017001,EV_SMLSKLOMQB_010_VW37.rod
;Sunday,20,October,2024,15:34:50:49859
;VCID: 0C467DF026C77B5A333-8058
ENG126411-p_k_i,0.300 %/s,1
ENG126415-p_k_i_offset,5 K,1
ENG126410-p_k_p,10.0 %,1
ENG126419-p_leistung_lrh,110 W,1
ENG126417-p_n_fehler_p_verriegelt,250 ,1
ENG120504-p_s_NWDF_spg,00000000  ,1
ENG102189-p_t_blinker_entprellen,40 ms,1
ENG102332-p_t_blinker_err_el_kurzschluss,200 ms,1
ENG104011-p_t_blinker_err_el_unterbrechung,1000 ms,1
ENG120503-p_t_blinker_err_fernlicht_haengt_aus,5000 ms,1
ENG120502-p_t_blinker_err_fernlicht_haengt_ein,300 s,1
ENG104185-p_t_blinker_err_gra_haengt_aus,5000 ms,1
ENG100988-p_t_blinker_err_gra_haengt_ein,300 s,1
ENG103202-p_t_blinker_err_lichthupe_haengt_aus,5000 ms,1
ENG100154-p_t_blinker_err_lichthupe_haengt_ein,300 s,1
ENG100923-p_t_blinker_err_unplausibel,200 ms,1
ENG103471-p_t_blinker_gra_entprellen,40 ms,1
ENG101294-p_t_blinker_sperrzeit,100 ms,1
ENG127114-p_t_entprellung_p_unplausibel,400 ms,1
ENG104033-p_t_entprellzeit_ueberspannung,90000 ms,1
ENG101392-p_t_entprellzeit_unterspannung,90000 ms,1
ENG102689-p_t_fas_entprellen,40 ms,1
ENG120505-p_t_gra_ea_error,200 ms,1
ENG101014-p_t_grahebel_entprellen,40 ms,1
ENG104117-p_t_grahebel_err_el_kurzschluss,200 ms,1
ENG102950-p_t_grahebel_err_el_unterbrechung,1000 ms,1
ENG103784-p_t_grahebel_err_gra_haengt_aus,5000 ms,1
ENG102546-p_t_grahebel_err_gra_haengt_ein,300 s,1
ENG103536-p_t_grahebel_err_unplausibel,200 ms,1
ENG126416-p_t_grenze_v,10 km/h,1
ENG99436-p_t_hupe_entprellen,40 ms,1
ENG102496-p_t_hupe_err_hinweis,2000 ms,1
ENG101071-p_t_hupe_err_hupe_haengt_aus,5000 ms,1
ENG101518-p_t_hupe_err_hupe_haengt_ein,60 s,1
ENG101702-p_t_hupe_indien_entprellen,500 ms,1
ENG126421-p_t_lrh_kurzschluss_entprellen,200 ms,1
ENG126422-p_t_lrh_unterbrechung_entprellen,1000 ms,1
ENG103999-p_t_p_verriegelt_entprellen,40 ms,1
ENG126412-p_t_soll_0,33 °C,1
ENG126413-p_t_soll_1,37 °C,1
ENG126414-p_t_soll_2,41 °C,1
ENG100796-p_t_spannung_obere_schwelle,16.5 V,1
ENG102338-p_t_spannung_untere_schwelle,8.5 V,1
ENG100559-p_t_wischer_entprellen,40 ms,1
ENG103039-p_t_wischer_err_el_kurzschluss,200 ms,1
ENG101343-p_t_wischer_err_el_unterbrechung,1000 ms,1
ENG108143-p_t_wischer_err_intervallpoti_haengt_aus,5000 ms,1
ENG102443-p_t_wischer_err_intervallpoti_haengt_ein,300 s,1
ENG101059-p_t_wischer_err_mfa_haengt_aus,5000 ms,1
ENG100346-p_t_wischer_err_mfa_haengt_ein,300 s,1
ENG103464-p_t_wischer_err_waschen_haengt_aus,5000 ms,1
ENG100423-p_t_wischer_err_waschen_haengt_ein,300 s,1
ENG99933-p_t_wischer_err_wischen_haengt_aus,5000 ms,1
ENG102586-p_t_wischer_err_wischen_haengt_ein,300 s,1
ENG101592-p_t_wischer_intervall_entprellen,40 ms,1
ENG103607-p_t_wischer_winterstellung,60 s,1
ENG126423-p_temp_lenkradheizung_aus,45 °C,1
ENG126420-p_zeit_temperatur_statisch_lrh,300 s,1
Elapsed Time: 00:26
adpmap-17-8V0-920-871-G_WAUZZZ8V8F1029358-20241020-1526.CSV
;SW:8V0-920-871-G   HW:8V0-920-871-G ---  Instruments
;Component:KOMBI         H02 4291, Coding:278D181A3E80AE000181E8001000000000000000
;EV_DashBoardVDDMQBAB,009040,EV_DashBoardVDDMQBAB_009_VW26.rod
;Sunday,20,October,2024,15:26:02:49859
;VCID: 40DE99C05A0FEF3A1FB-8014
IDE00295-Oil temperature display,Conditions not correct or request sequence error,4
IDE00301-Mileage,91836 km,3
IDE00342-ESI: Resetting ESI,Warning active ,1
IDE00343-Language variant,English ,1
IDE00500-Hour,15 H,1
IDE00501-Minute,25 min,1
IDE00502-Year,2024 yr,2
IDE00503-Month,10 Months,1
IDE00504-Day,19 d,1
IDE00510-ESI: distance driven from inspection,6117 km,3
IDE00511-ESI: time from inspection,192 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,365 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00518-ESI: thermal load,21000 km,2
IDE00819-Day counter,3696 d,2
IDE01153-SIA: maximum value of distance to service,5000 km,2
IDE01154-SIA: maximum value of time to service,180 d,2
IDE02489-Display depiction,Not available ,1
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.8 l,5
IDE03329-Driving profiled for range remaining,12.1 l/100km,2
IDE03346-IDE00301-Units adjusted-Mileage,miles ,3
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
IDE03346-MAS03032-Units adjusted-Volume,gallons (UK) ,3
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (UK) ,3
IDE03348-MAS01456-Speed warning-Speed,15 ,2
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
IDE03349-FIX:Max. distance driven until next mileage-related inspection,3000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,890 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,6100 km,2
IDE03352-FIX: Time since last time-dependent inspection,192 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,0 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,Unknown (2),1
IDE07221-Cylinder shut-off,Readout ,1
IDE08140-Driving profiled for range remaining CNG,6.0 kg/100 km,2
IDE08247-Driving profile for range remaining LPG,10.0 l/100km,2
MAS03555-Lap counter,Readout ,1
MAS03685-Digital speedometer,Readout ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,50 l,1
ENG119880-ENG101574-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X1,00 ,12
ENG119880-ENG99557-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X2,0A ,12
ENG119880-ENG102140-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X3,64 ,12
ENG119880-ENG102936-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X4,96 ,12
ENG119880-ENG103548-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X5,DC ,12
ENG119880-ENG113992-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X6,FD ,12
ENG119880-ENG99777-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y1,02 ,12
ENG119880-ENG100480-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y2,02 ,12
ENG119880-ENG100773-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y3,10 ,12
ENG119880-ENG100631-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y4,1E ,12
ENG119880-ENG102174-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y5,3C ,12
ENG119880-ENG113993-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y6,64 ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,03 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,03 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,10 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,1E ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,3C ,12
ENG119881-ENG101574-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X1,00 ,12
ENG119881-ENG99557-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X2,0A ,12
ENG119881-ENG102140-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X3,64 ,12
ENG119881-ENG102936-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X4,96 ,12
ENG119881-ENG103548-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X5,DC ,12
ENG119881-ENG113992-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X6,FD ,12
ENG119881-ENG99777-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y1,02 ,12
ENG119881-ENG100480-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y2,02 ,12
ENG119881-ENG100773-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y3,10 ,12
ENG119881-ENG100631-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y4,1E ,12
ENG119881-ENG102174-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y5,3C ,12
ENG119881-ENG113993-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y6,64 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,6E ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,82 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,AA ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,05 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,14 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,50 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,64 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,96 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,04 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,04 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,40 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,52 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,5F ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,64 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,96 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,08 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,08 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,64 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,64 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,64 ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,64 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,96 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,0A ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,0A ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,32 ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,5F ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,64 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,64 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,96 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,03 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,03 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,19 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,28 ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46 ,12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64 ,12
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
ENG119882-init_fuel_algorithm,No ,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,30 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,0 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,0 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.50 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
Elapsed Time: 00:27
adpmap-19-5Q0-907-530-T_WAUZZZ8V8F1029358-20241020-1527.CSV
;SW:5Q0-907-530-T   HW:5Q0-907-530-M ---  CAN Gateway
;Component:GW MQB High   212 2186, Coding:030100042F085A005B0002789C0B00000001010000000000000000000000
;EV_GatewConti,011017,EV_GatewConti_011.rod
;Sunday,20,October,2024,15:27:18:49859
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V,2
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V,2
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01996-SFT00001-Installation list: specified installations-Engine Electronics,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brake electronics,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Climate Control Module,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Distance Regulation,coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Damping Electronics,coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering column electronics systems,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Instrument cluster,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface,1 ,32
IDE01996-SFT00032-Installation list: specified installations-High beam assistant,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery management 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics,coded ,32
IDE01996-SFT00038-Installation list: specified installations-Convertible top operation,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering column lock,coded ,32
IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane change assistance,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-A/C compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Power steering,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Electric drive,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlamp range control,coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Trip recorder,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS),Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Rear view camera system,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking aid,coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systems,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone control module,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator,coded ,32
IDE01996-SFT00183-Installation list: specified installations-Interface for access/start system,coded ,32
IDE01996-SFT00187-Installation list: specified installations-Rear drivers side door electronics,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Rear passenger side door electronics,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High-voltage battery charging management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Left rear sliding door,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Right rear sliding door,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-High-voltage battery charger,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Sunroof control module,Not coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter generator,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE02200-Component protection showroom mode,not active ,1
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,69 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,BA2 ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,17060881GN ,15
IDE03903-Production process data 1,FF CA ,2
IDE04159-Deactivation of start/stop function,Mode not active ,1
IDE06425-MAS06026-Dynamometer mode: functional-Activation stages,not activated ,1
IDE06425-MAS06277-Dynamometer mode: functional-Malfunction states,No malfunction ,1
IDE06541-Distance left for deactivation of transport mode,100 ,1
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),not activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,not activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,not activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,not activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,Unknown (3),4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,not activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Unknown (3),4
IDE08348-Start/stop start voltage limit,12.0 V,1
IDE10735-Number requests autonomous recharging,9 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,not activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,not activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,not activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,not activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,not activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,not activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,not activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,not activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,not activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,not activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,not activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,not activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,not activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,not activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,not activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,not activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,not activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,not activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,not activated ,3
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %,10
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold,100 ,10
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In,0 ms,10
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms,10
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out,0 ms,10
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms,10
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay,0 ms,10
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence,0 ms,10
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness,active ,3
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,active ,3
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,active ,3
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,120 ,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,500 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,3000 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Battery reports,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-State of Charge (SOC),Mode not active ,4
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C,2
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C,2
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Electronics,activated ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Electronics,activated ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brake electronics,not activated ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat adjustment: passenger's side,activated ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Climate Control Module,activated ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Electronic central electric,activated ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,activated ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player 1,activated ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Distance Regulation,activated ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Damping Electronics,activated ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not activated ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering column electronics systems,activated ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Instrument cluster,activated ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary/parking heating,activated ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Data Bus OBD Interface,activated ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,activated ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High beam assistant,activated ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery management 2,activated ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All-wheel drive electronics,activated ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,activated ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Convertible top operation,activated ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering column lock,activated ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,activated ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Differential lock electronics,activated ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat adjustment: driver side,activated ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane change assistance,activated ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,activated ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-A/C compressor,activated ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Driver's door electronics,activated ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Power steering,activated ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,activated ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module,activated ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Electric drive,activated ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Passenger's door electronics,activated ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlamp range control,activated ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,activated ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,activated ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information electronics 1,activated ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Trip recorder,activated ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring System (TPMS),activated ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,activated ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Rear view camera system,activated ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Rear lid electronics,activated ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Emergency call module and communication unit,activated ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking aid,activated ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery control additional memory 1,activated ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head-Up-Display,activated ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Hybrid Battery Management,activated ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front sensor for drivers assistant systems,activated ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone control module,activated ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuator,activated ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Interface for access/start system,activated ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Rear drivers side door electronics,activated ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Rear passenger side door electronics,activated ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High-voltage battery charging management,activated ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Left rear sliding door,activated ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Right rear sliding door,activated ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,activated ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,activated ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-High-voltage battery charger,activated ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Sunroof control module,activated ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter generator,activated ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,activated ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,activated ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,activated ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,activated ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,activated ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,activated ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,activated ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,activated ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,activated ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,activated ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,activated ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,activated ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,activated ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,activated ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,activated ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,activated ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,activated ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,activated ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,activated ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,activated ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,activated ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,activated ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,activated ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,activated ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,activated ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,activated ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,activated ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,activated ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,activated ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,activated ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,activated ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,activated ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,activated ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,activated ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,activated ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,activated ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,activated ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,activated ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,activated ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,activated ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,activated ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,activated ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,activated ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,activated ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,activated ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,activated ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,activated ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,activated ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,activated ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,activated ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,activated ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,activated ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,activated ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,activated ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,activated ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,activated ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,activated ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,activated ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,activated ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,activated ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,activated ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,activated ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,activated ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,activated ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,activated ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,activated ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,activated ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,activated ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,activated ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,activated ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,activated ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,activated ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,activated ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,activated ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,activated ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,activated ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,activated ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,activated ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,activated ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,activated ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,activated ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,activated ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,activated ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,activated ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,activated ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,activated ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,activated ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,activated ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,activated ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,activated ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,activated ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,activated ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,activated ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,activated ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,activated ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,activated ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,activated ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,activated ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,activated ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,activated ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,activated ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,activated ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,activated ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,activated ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,activated ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,activated ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,activated ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,activated ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,activated ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,activated ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,activated ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,activated ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,activated ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,activated ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,activated ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,activated ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,activated ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,activated ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,activated ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,activated ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,activated ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,activated ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,activated ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,activated ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,activated ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,activated ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,activated ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,activated ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,activated ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,activated ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,activated ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,activated ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,activated ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,activated ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,activated ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,activated ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,activated ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,activated ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,activated ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,activated ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,activated ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,activated ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,activated ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,activated ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,activated ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,activated ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,activated ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,activated ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,activated ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,activated ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,activated ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,activated ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,activated ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,activated ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,activated ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,activated ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,activated ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,activated ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,activated ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,activated ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,activated ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,activated ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,activated ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,activated ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,activated ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,activated ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,activated ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,activated ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,activated ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,activated ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,activated ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,activated ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,activated ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,activated ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,activated ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,activated ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,activated ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,activated ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,activated ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,activated ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,activated ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,activated ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,activated ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,activated ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,activated ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,activated ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,activated ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,activated ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,activated ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,activated ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,activated ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,activated ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,activated ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Powertrain data bus ,2
ENG137065-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137066-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137067-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137068-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137069-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137070-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137071-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137072-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137073-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137074-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG118779-IDE02583-Multi_function_steering_wheel_control_module Coding Value-Steering wheel Tiptronic switch,Service not supported,12
ENG118779-MAS06614-Multi_function_steering_wheel_control_module Coding Value-Variant,Service not supported,12
ENG118779-MAS09758-Multi_function_steering_wheel_control_module Coding Value-Temperature sensor,Service not supported,12
ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1,Service not supported,12
ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2,Service not supported,12
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,5
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,5
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,5
Elapsed Time: 00:24
adpmap-22-0CQ-907-554-D_WAUZZZ8V8F1029358-20241020-1535.CSV
;SW:0CQ-907-554-D   HW:0CQ-907-554-D ---  AWD
;Component:Haldex4Motion H52 7076, Coding:0001
;EV_AllWheelContrHA1VW37X,002001,EV_AllWheelContrHA1VW37X_002_VW36.rod
;Sunday,20,October,2024,15:35:24:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 46D28FD8782BC10A257-8012
IDE07843-MAS06099-Acoustic measure: gasoline-Acoustic measure: anti droning,1700 ,2
IDE07843-MAS06100-Acoustic measure: gasoline-Acoustic measure: anti impact wrench,1150 ,2
IDE07844-MAS06099-Acoustic measure: diesel-Acoustic measure: anti droning,2000 ,2
IDE07844-MAS06100-Acoustic measure: diesel-Acoustic measure: anti impact wrench,1300 ,2
MAS06098-Acoustic measure: wiring logic,Standard ,1
Elapsed Time: 00:01
adpmap-2B-5Q0-905-861-A_WAUZZZ8V8F1029358-20241020-1535.CSV
;SW:5Q0-905-861-A   HW:5Q0-905-861-A ---  Steer. Col. Lock
;Component:ELV-MQBA      H01 0120, Coding:5D00000000000000
;EV_ELVMarquMQB,004111,EV_ELVMarquMQB_004_VW37.rod
;Sunday,20,October,2024,15:35:37:49859
;VCID: 3436C5101EB7439A8B3-8060
Elapsed Time: 00:01
adpmap-42-5Q0-959-593-B_WAUZZZ8V8F1029358-20241020-1536.CSV
;SW:5Q0-959-593-B   HW:5Q0-959-593-B ---  Door Elect, Driver
;Component:TSG FS        020 0025, Coding:005D1E205C01040000001003
;EV_DCUDriveSideEWMAXKLO,006003,EV_DCUDriveSideEWMAXKLO.rod
;Sunday,20,October,2024,15:36:20:49859
;VCID: 40DE99C05A0FEF3A1FB-8014
IDE00001-Production mode,00000000 00000000 00000000  ,3
IDE02332-Deactivate production mode,00000000 00000000 00000000  ,3
ENG117304-Patch_Code_Driver_Side_Rear,No Response From Subnet Component,3
ENG117299-Reversing_Threshold_Driver_Side_Rear,No Response From Subnet Component,1
ENG117302-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1,No Response From Subnet Component,1
ENG117303-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2,No Response From Subnet Component,1
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,No Response From Subnet Component,1
Elapsed Time: 00:12
adpmap-44-3Q0-909-144-F_WAUZZZ8V8F1029358-20241020-1536.CSV
;SW:3Q0-909-144-F   HW:3Q0-909-144-F ---  Steering Assist
;Component:EPS_MQB_ZFLS  503 5043, Coding:8103
;EV_SteerAssisMQB,010031,EV_SteerAssisMQB_010.rod
;Sunday,20,October,2024,15:36:42:49859
;VCID: 3530F81415CD5A92BCD-8060
IDE03724-Straight line running,active ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE09571-RPM monitoring,active ,1
Elapsed Time: 00:02
adpmap-47-8V0-035-465-D_WAUZZZ8V8F1029358-20241020-1536.CSV
;SW:8V0-035-465-D   HW:8V0-035-465 ---  Sound System
;Component:MIBAMP1ALPINE H11 0420, Coding:01030300AAAA2AAA01
;EV_AMPMst16C1ALPI,004024,EV_AMPMst16C1ALPI_004_AU37.rod
;Sunday,20,October,2024,15:36:56:49859
;VCID: 3928F42439D5BEF2585-806C
IDE02475-MAS03001-Acoustic check of loudspeakers-Mode,manual ,49
IDE02475-ENG117360-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02475-ENG117361-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,60 ,49
IDE02475-ENG117378-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02475-ENG117379-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,60 ,49
IDE02475-ENG117380-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02475-ENG117381-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,60 ,49
IDE02475-ENG117382-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02475-ENG117383-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,60 ,49
IDE02475-ENG117384-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02475-ENG117385-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,60 ,49
IDE02475-ENG117386-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02475-ENG117387-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,60 ,49
IDE02475-ENG117388-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02475-ENG117389-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,60 ,49
IDE02475-ENG117390-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02475-ENG117391-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,60 ,49
IDE02475-ENG117362-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02475-ENG117363-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,60 ,49
IDE02475-ENG117364-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02475-ENG117365-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,60 ,49
IDE02475-ENG117366-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02475-ENG117367-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,60 ,49
IDE02475-ENG117368-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02475-ENG117369-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,60 ,49
IDE02475-ENG117370-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02475-ENG117371-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,60 ,49
IDE02475-ENG117372-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02475-ENG117373-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,60 ,49
IDE02475-ENG117374-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02475-ENG117375-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,60 ,49
IDE02475-ENG117376-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02475-ENG117377-Acoustic check of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,60 ,49
MAS02809-MAS02870-Check tone frequency-High note frequency range,6000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,800 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
Elapsed Time: 00:01
adpmap-52-5Q0-959-592-B_WAUZZZ8V8F1029358-20241020-1537.CSV
;SW:5Q0-959-592-B   HW:5Q0-959-592-B ---  Door Elect, Pass.
;Component:TSG BFS       020 0025, Coding:005D16205E01040000001003
;EV_DCUPasseSideEWMAXKLO,006003,EV_DCUPasseSideEWMAXKLO.rod
;Sunday,20,October,2024,15:37:38:49859
;VCID: 3FDC9A3C27F190C2661-806A
ENG117308-Patch_Code_Passenger_Side_Rear,No Response From Subnet Component,3
ENG117300-Reversing_Threshold_Passenger_Side_Rear,No Response From Subnet Component,1
ENG117306-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1,No Response From Subnet Component,1
ENG117307-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2,No Response From Subnet Component,1
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,No Response From Subnet Component,1
Elapsed Time: 00:12
adpmap-55-7P6-907-357-C_WAUZZZ8V8F1029358-20241020-1538.CSV
;SW:7P6-907-357-C   HW:7P6-907-357-B ---  Headlight Range
;Component:AFS-ECU       H01 0091, Coding:01A600002B200200
;EV_HeadlRegulAFSMQBMLB,001001,EV_HeadlRegulAFSMQBMLB_AU37.rod
;Sunday,20,October,2024,15:38:01:49859
IDE03641-Presentation run dynamic AFS light,active ,1
ENG100660-PWM to Level Scaling Factor Front,3.30 mm/%,2
ENG103748-PWM to Level Scaling Factor Rear,5.50 mm/%,2
ENG103979-Reference_Run_Start_Condition,Engine start ,1
Elapsed Time: 00:02
adpmap-57-8V0-919-129-A_WAUZZZ8V8F1029358-20241020-1538.CSV
;SW:8V0-919-129-A   HW:8V0-919-129 ---  TV Tuner
;Component:JP-DTV        H10 0990, Coding:01011C0000000100000000
;EV_TVMELC,001033,EV_TVMELC_VW37.rod
;Sunday,20,October,2024,15:38:14:49859
;VCID: 3E22E73820FB99CA6D7-806A
IDE08118-Image frequency Slide-Show,20 s,1
IDE09093-Measurement: reception level,not activated ,1
ENG124511-ENG124527-Error_bit_mask-aerial_1_for_TV_open_circuit_or_short_circuit_to_B+,masked_on ,6
ENG124511-ENG124528-Error_bit_mask-aerial_1_for_TV_short_to_ground,masked_on ,6
ENG124511-ENG124530-Error_bit_mask-aerial_2_for_TV_open_circuit_or_short_circuit_to_B+,masked_on ,6
ENG124511-ENG124531-Error_bit_mask-aerial_2_for_TV_short_to_ground,masked_on ,6
ENG124511-ENG124533-Error_bit_mask-aerial_3_for_TV_open_circuit_or_short_circuit_to_B+,masked_on ,6
ENG124511-ENG124534-Error_bit_mask-aerial_3_for_TV_short_to_ground,masked_on ,6
ENG124511-ENG124541-Error_bit_mask-card_reader_no_signal_communication,masked_on ,6
ENG124511-ENG124540-Error_bit_mask-card_reader_short_to_ground,masked_on ,6
ENG124511-ENG125918-Error_bit_mask-component_protection_active_0xEA6100(1),masked_on ,6
ENG124511-ENG125919-Error_bit_mask-component_protection_active_0xEA6200(2),masked_on ,6
ENG124511-ENG125920-Error_bit_mask-component_protection_active_0xEA6300(3),masked_on ,6
ENG124511-ENG125921-Error_bit_mask-component_protection_active_0xEA6400(4),masked_on ,6
ENG124511-ENG124524-Error_bit_mask-component_protection_no_or_incorrect_basic_setting,masked_on ,6
ENG124511-ENG124529-Error_bit_mask-connection_between_impedance_converter_TV_1_and_window_antenna_open_circuit,masked_on ,6
ENG124511-ENG124532-Error_bit_mask-connection_between_impedance_converter_TV_2_and_window_antenna_open_circuit,masked_on ,6
ENG124511-ENG124535-Error_bit_mask-connection_between_impedance_converter_TV_3_and_window_antenna_open_circuit,masked_on ,6
ENG124511-ENG127171-Error_bit_mask-control_unit_defect_channel_decoder_communication_error,masked_on ,6
ENG124511-ENG124521-Error_bit_mask-control_unit_defect_data_flash_error,masked_on ,6
ENG124511-ENG124543-Error_bit_mask-control_unit_defect_INIC_communication_error,masked_on ,6
ENG124511-ENG124544-Error_bit_mask-control_unit_defect_MPEG_communication_error,masked_on ,6
ENG124511-ENG127172-Error_bit_mask-control_unit_defect_Nagra-IC_communication_error,masked_on ,6
ENG124511-ENG124520-Error_bit_mask-control_unit_defect_program_flash_error,masked_on ,6
ENG124511-ENG142139-Error_bit_mask-control_unit_defect_RENESAS-MCU_communication_error,masked_on ,6
ENG124511-ENG124542-Error_bit_mask-control_unit_defect_VC_communication_error,masked_on ,6
ENG124511-ENG124519-Error_bit_mask-control_unit_incorrectly_coded,masked_on ,6
ENG124511-ENG124518-Error_bit_mask-control_unit_not_coded,masked_on ,6
ENG124511-ENG124526-Error_bit_mask-DTCP_device_certificate_authentication_error,masked_on ,6
ENG124511-ENG129318-Error_bit_mask-DTCP_device_certificate_authentication_error_0x47,masked_on ,6
ENG124511-ENG129319-Error_bit_mask-DTCP_device_certificate_authentication_error_0x5F,masked_on ,6
ENG124511-ENG129320-Error_bit_mask-DTCP_device_certificate_authentication_error_0x7F,masked_on ,6
ENG124511-ENG124525-Error_bit_mask-DTCP_signature_authentication_error,masked_on ,6
ENG124511-ENG129315-Error_bit_mask-DTCP_signature_authentication_error_0x47,masked_on ,6
ENG124511-ENG129316-Error_bit_mask-DTCP_signature_authentication_error_0x5F,masked_on ,6
ENG124511-ENG129317-Error_bit_mask-DTCP_signature_authentication_error_0x7F,masked_on ,6
ENG124511-ENG124522-Error_bit_mask-function_limitation_due_to_excessive_temperature,masked_on ,6
ENG124511-ENG124523-Error_bit_mask-function_restriction_due_to_low_temperature,masked_on ,6
ENG124511-ENG125253-Error_bit_mask-internal_communication_interruption(MPEG),masked_on ,6
ENG124511-ENG125252-Error_bit_mask-internal_communication_interruption(V850),masked_on ,6
ENG124511-ENG108288-Error_bit_mask-production_mode_active,masked_on ,6
ENG124511-ENG124517-Error_bit_mask-supply_voltage_lower_limit_exceeded,masked_on ,6
ENG124511-ENG124516-Error_bit_mask-supply_voltage_upper_limit_exceeded,masked_on ,6
ENG124511-ENG124536-Error_bit_mask-video_line_for_end_device_open_load,masked_on ,6
ENG124511-ENG124537-Error_bit_mask-video_line_for_end_device_short_circuit_to_ground,masked_on ,6
ENG124511-ENG124538-Error_bit_mask-video_line_for_rear_seat_unit_open_load,masked_on ,6
ENG124511-ENG124539-Error_bit_mask-video_line_for_rear_seat_unit_short_circuit_to_ground,masked_on ,6
ENG124510-Video_audio_encryption,activated_dtla_key ,1
Elapsed Time: 00:03
adpmap-5F-8V0-035-034-J_WAUZZZ8V8F1029358-20241020-1538.CSV
;SW:8V0-035-034-J   HW:8V0-035-034 ---  Information Electr.
;Component:MU-H-N-EU     H42 0404, Coding:017301010000000021110102000A02102F000226010001007E
;EV_MUHig6C3AW7,001115,EV_MUHig6C3AW7.rod
;Sunday,20,October,2024,15:38:51:49859
;VCID: 372CF21C0FC1A882AE1-8062
IDE00346-Summertime-automatic,none ,1
IDE00759-Base volume of speech output,50 %,1
IDE00768-Country identification: country of sale,JP ,2
IDE00769-Call number 1 for info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF ,1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF ,1
IDE00845-Wheel circumference,0 mm,2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,No ,3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner,Yes ,3
IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,Yes ,3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
IDE01996-SFT271943-Installation list: specified installations-Multimedia system control head,No ,3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8,No ,3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1,No ,3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2,No ,3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1,No ,3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2,No ,3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,No ,3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
IDE02121-CD eject button,Enabled ,1
IDE02330-Call number 2 for info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,49
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,35 ,49
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,85 ,49
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,85 ,49
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,85 ,49
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,85 ,49
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,85 ,49
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,85 ,49
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,85 ,49
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,16 ,49
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,16 ,49
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,35 ,49
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,85 ,49
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,85 ,49
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,85 ,49
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,85 ,49
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,85 ,49
IDE02502-Confirmation of installation change,72 6D ,2
IDE02506-MAS03229-Copy multimedia data-Data carrier,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,On ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,OFF ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,locked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,OFF ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,not installed ,30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,not installed ,30
IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,On ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,On ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,not installed ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,On ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,OFF ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,locked ,30
IDE03471-ENG137647-Vehicle configuration-UOTA,OFF ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE03580-Country recognition for mobile network,0 ,2
IDE03581-ENG117690-Vehicle function list CAN-Adaptive_key_msg_bus,Terminal 15 ,8
IDE03581-ENG117691-Vehicle function list CAN-Adaptive_key_school,available. ,8
IDE03581-ENG117688-Vehicle function list CAN-Driving_school,Not available ,8
IDE03581-ENG117689-Vehicle function list CAN-Driving_school_msg_bus,Comfort data bus ,8
IDE03581-ENG107608-Vehicle function list CAN-MFL,available. ,8
IDE03581-ENG117681-Vehicle function list CAN-MFL_msg_bus,Terminal 15 ,8
IDE03581-ENG117683-Vehicle function list CAN-Oil_level,Not available ,8
IDE03581-ENG117684-Vehicle function list CAN-Oil_level_msg_bus,Comfort data bus ,8
IDE03581-ENG117685-Vehicle function list CAN-PDC_audio_lowering,available. ,8
IDE03581-ENG117686-Vehicle function list CAN-PDC_audio_lowering_msg_bus,Terminal 15 ,8
IDE03581-ENG98994-Vehicle function list CAN-Trailer,Not available ,8
IDE03581-ENG117682-Vehicle function list CAN-Trailer_msg_bus,Comfort data bus ,8
IDE03581-ENG99892-Vehicle function list CAN-VIN,available. ,8
IDE03581-ENG117687-Vehicle function list CAN-VIN_msg_bus,Terminal 15 ,8
IDE03902-Automatic ring break diagnostic,No automatic start ,1
IDE04292-Roadside assistance mode,Corresponding setting in MMI ,1
IDE04294-Number attempted dialing attempts for roadside assistance,3 ,1
IDE04298-MAS01779-Vehicle dimensions-Length,26129 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,43015 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,34053 mm,6
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,activated ,40
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,40
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,40
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,40
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,40
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,activated ,40
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,40
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,40
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,activated ,40
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,40
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,40
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,40
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,40
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,40
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,40
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,40
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,40
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,40
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,40
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,40
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,40
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,40
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,40
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,40
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,40
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,40
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,40
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,40
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,40
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,40
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,40
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,40
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,40
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,40
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,40
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,40
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,40
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,40
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,not activated ,40
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,40
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,40
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,40
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,40
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,40
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,40
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,not activated ,40
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,40
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,40
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,not activated ,40
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,40
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,not activated ,40
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,40
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,40
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,not activated ,40
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,40
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,40
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,40
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,40
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,40
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,40
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,40
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,40
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,40
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,40
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,40
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,activated ,40
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,40
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,40
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,40
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,40
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,40
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,40
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,40
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,40
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,40
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,40
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,40
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,40
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,40
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,40
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,not activated ,40
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,40
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,40
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,not activated ,40
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,40
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,40
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,40
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,40
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,40
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,40
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,not activated ,40
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,40
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,40
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,not activated ,40
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,40
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,40
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,40
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,40
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,40
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,40
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,40
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,40
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,40
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,40
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,40
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,40
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,40
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,40
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,40
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,40
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,not activated ,40
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,40
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,40
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,40
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,40
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,activated ,40
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,40
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,40
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,activated ,40
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,40
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,40
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,40
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,40
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,40
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,40
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,not activated ,40
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,40
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,40
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,40
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,40
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,40
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,40
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,40
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,not activated ,40
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,40
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,not activated ,40
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,40
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,40
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,not activated ,40
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,40
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,40
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,40
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,40
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,40
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,40
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,not activated ,40
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,40
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,40
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,not activated ,40
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,40
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,40
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,40
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,40
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,not activated ,40
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,40
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,40
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,40
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,40
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,40
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,40
IDE04300-ENG117511-Vehicle menu operation-menu_display_side_assistant,not activated ,40
IDE04300-ENG117515-Vehicle menu operation-menu_display_side_assistant_after_disclaimer,not activated ,40
IDE04300-ENG117512-Vehicle menu operation-menu_display_side_assistant_clamp_15_off,not activated ,40
IDE04300-ENG117513-Vehicle menu operation-menu_display_side_assistant_over_threshold_high,not activated ,40
IDE04300-ENG117514-Vehicle menu operation-menu_display_side_assistant_standstill,not activated ,40
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,40
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,40
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,40
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,40
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,40
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,40
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,40
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,40
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,40
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,40
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,40
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,40
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,40
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,40
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,40
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,40
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,40
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,40
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,40
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,40
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,40
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,40
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,40
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,40
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,40
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,not activated ,40
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,40
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,40
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,not activated ,40
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,40
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,40
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,40
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,40
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,40
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,40
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,activated ,53
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Terminal 15 ,53
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,53
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,Comfort data bus ,53
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,53
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,Comfort data bus ,53
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,53
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,Comfort data bus ,53
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,53
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,53
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,53
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Comfort data bus ,53
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,not activated ,53
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Comfort data bus ,53
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,53
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Terminal 15 ,53
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,activated ,53
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Terminal 15 ,53
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,53
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,Comfort data bus ,53
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,53
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,Terminal 15 ,53
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,53
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,Comfort data bus ,53
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,53
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,53
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,53
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,Comfort data bus ,53
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,53
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,53
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,not activated ,53
IDE04307-ENG125040-Vehicle function list BAP-Ecall_msg_bus_0x33,Comfort data bus ,53
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,53
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Terminal 15 ,53
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,53
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,Comfort data bus ,53
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,53
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Comfort data bus ,53
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,53
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Terminal 15 ,53
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,not activated ,53
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Comfort data bus ,53
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,53
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Terminal 15 ,53
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,activated ,53
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,Infotainment data bus ,53
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,not activated ,53
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,53
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,53
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,Comfort data bus ,53
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,53
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,53
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,53
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,Comfort data bus ,53
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,53
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Comfort data bus ,53
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,53
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Terminal 15 ,53
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,53
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,Comfort data bus ,53
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,53
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,53
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,not activated ,53
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Comfort data bus ,53
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,not activated ,53
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Comfort data bus ,53
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,not activated ,53
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Comfort data bus ,53
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,53
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,Comfort data bus ,53
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,53
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Terminal 15 ,53
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,activated ,53
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,Terminal 15 ,53
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,53
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Terminal 15 ,53
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,53
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Terminal 15 ,53
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,1 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04521-Sporadic ring break detection,optical ,1
IDE04522-Awakening ability on optical databus,On ,1
IDE04549-Telephone data service,On ,1
IDE04550-Bluetooth: Sniff mode,On ,1
IDE05111-Fee-based traffic information (TMC),32783 ,2
IDE05112-MAS02228-Image position-X coordinate,0 ,2
IDE05112-MAS02229-Image position-Y coordinate,0 ,2
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,8 dB,6
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,6
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,6
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,6
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,6
IDE09570-ENG117700-Vehicle function list BAP: extension-ACC_0x05,activated ,64
IDE09570-ENG117701-Vehicle function list BAP: extension-ACC_0x05_msg_bus,Terminal 15 ,64
IDE09570-ENG117702-Vehicle function list BAP: extension-air_suspension_0x06,not activated ,64
IDE09570-ENG117703-Vehicle function list BAP: extension-air_suspension_0x06_msg_bus,Comfort data bus ,64
IDE09570-ENG117764-Vehicle function list BAP: extension-Amplifier_0x2D,not activated ,64
IDE09570-ENG117765-Vehicle function list BAP: extension-Amplifier_0x2D_msg_bus,Comfort data bus ,64
IDE09570-ENG122334-Vehicle function list BAP: extension-Angle_Of_Slope_0x24,not activated ,64
IDE09570-ENG122335-Vehicle function list BAP: extension-Angle_Of_Slope_0x24_msg_bus,Comfort data bus ,64
IDE09570-ENG117696-Vehicle function list BAP: extension-auxilary_heating_0x03,not activated ,64
IDE09570-ENG117697-Vehicle function list BAP: extension-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
IDE09570-ENG117744-Vehicle function list BAP: extension-AWV_0x1B,activated ,64
IDE09570-ENG117745-Vehicle function list BAP: extension-AWV_0x1B_msg_bus,Terminal 15 ,64
IDE09570-ENG122336-Vehicle function list BAP: extension-Battery_Management_0x25,not activated ,64
IDE09570-ENG122337-Vehicle function list BAP: extension-Battery_Management_0x25_msg_bus,Comfort data bus ,64
IDE09570-ENG117758-Vehicle function list BAP: extension-BCmE_0x23,not activated ,64
IDE09570-ENG117759-Vehicle function list BAP: extension-BCmE_0x23_msg_bus,Comfort data bus ,64
IDE09570-ENG117760-Vehicle function list BAP: extension-Brake_0x26,not activated ,64
IDE09570-ENG117761-Vehicle function list BAP: extension-Brake_0x26_msg_bus,Comfort data bus ,64
IDE09570-ENG117717-Vehicle function list BAP: extension-central_locking_0x0D,activated ,64
IDE09570-ENG117716-Vehicle function list BAP: extension-central_locking_0x0D_msg_bus,Terminal 15 ,64
IDE09570-ENG117736-Vehicle function list BAP: extension-charisma_0x17,activated ,64
IDE09570-ENG117737-Vehicle function list BAP: extension-charisma_0x17_msg_bus,Terminal 15 ,64
IDE09570-ENG117734-Vehicle function list BAP: extension-clima_slave_2_0x16,not activated ,64
IDE09570-ENG117735-Vehicle function list BAP: extension-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
IDE09570-ENG117692-Vehicle function list BAP: extension-climatic_master_0x01,activated ,64
IDE09570-ENG117693-Vehicle function list BAP: extension-climatic_master_0x01_msg_bus,Terminal 15 ,64
IDE09570-ENG117694-Vehicle function list BAP: extension-climatic_slave_0x02,not activated ,64
IDE09570-ENG117695-Vehicle function list BAP: extension-climatic_slave_0x02_msg_bus,Comfort data bus ,64
IDE09570-ENG117724-Vehicle function list BAP: extension-clock_0x11,activated ,64
IDE09570-ENG117725-Vehicle function list BAP: extension-clock_0x11_msg_bus,Comfort data bus ,64
IDE09570-ENG117732-Vehicle function list BAP: extension-compass_0x15,not activated ,64
IDE09570-ENG117733-Vehicle function list BAP: extension-compass_0x15_msg_bus,Comfort data bus ,64
IDE09570-ENG117722-Vehicle function list BAP: extension-driver_seat_0x10,not activated ,64
IDE09570-ENG117723-Vehicle function list BAP: extension-driver_seat_0x10_msg_bus,Comfort data bus ,64
IDE09570-ENG117708-Vehicle function list BAP: extension-exterieur_light_0x09,activated ,64
IDE09570-ENG117709-Vehicle function list BAP: extension-exterieur_light_0x09_msg_bus,Terminal 15 ,64
IDE09570-ENG117698-Vehicle function list BAP: extension-headup_displ_0x04,not activated ,64
IDE09570-ENG117699-Vehicle function list BAP: extension-headup_displ_0x04_msg_bus,Comfort data bus ,64
IDE09570-ENG117746-Vehicle function list BAP: extension-Hybrid_0x1D,not activated ,64
IDE09570-ENG117747-Vehicle function list BAP: extension-Hybrid_0x1D_msg_bus,Comfort data bus ,64
IDE09570-ENG117706-Vehicle function list BAP: extension-interieur_light_0x08,activated ,64
IDE09570-ENG117707-Vehicle function list BAP: extension-interieur_light_0x08_msg_bus,Terminal 15 ,64
IDE09570-ENG117740-Vehicle function list BAP: extension-LDW_HCA_0x19,not activated ,64
IDE09570-ENG117741-Vehicle function list BAP: extension-LDW_HCA_0x19_msg_bus,Comfort data bus ,64
IDE09570-ENG117720-Vehicle function list BAP: extension-MFA_0x0F,activated ,64
IDE09570-ENG117721-Vehicle function list BAP: extension-MFA_0x0F_msg_bus,Terminal 15 ,64
IDE09570-ENG117767-Vehicle function list BAP: extension-MFL_Jocker_0x34,activated ,64
IDE09570-ENG117766-Vehicle function list BAP: extension-MFL_Jocker_msg_bus_0x34,Infotainment data bus ,64
IDE09570-ENG117719-Vehicle function list BAP: extension-mirror_0x0E,not activated ,64
IDE09570-ENG117718-Vehicle function list BAP: extension-mirror_0x0E_msg_bus,Comfort data bus ,64
IDE09570-ENG117738-Vehicle function list BAP: extension-Night_Vision_0x18,not activated ,64
IDE09570-ENG117739-Vehicle function list BAP: extension-Night_Vision_0x18_msg_bus,Comfort data bus ,64
IDE09570-ENG117710-Vehicle function list BAP: extension-parking_assist_0x0A,activated ,64
IDE09570-ENG117711-Vehicle function list BAP: extension-parking_assist_0x0A_msg_bus,Terminal 15 ,64
IDE09570-ENG117752-Vehicle function list BAP: extension-Passenger_Seat_0x20,not activated ,64
IDE09570-ENG117753-Vehicle function list BAP: extension-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
IDE09570-ENG122333-Vehicle function list BAP: extension-Range_Data_0x39,not activated ,64
IDE09570-ENG125827-Vehicle function list BAP: extension-Range_Data_msg_bus_0x39,Comfort data bus ,64
IDE09570-ENG122327-Vehicle function list BAP: extension-RearSeatEntertainment_0x2E,not activated ,64
IDE09570-ENG122328-Vehicle function list BAP: extension-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
IDE09570-ENG117750-Vehicle function list BAP: extension-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
IDE09570-ENG117751-Vehicle function list BAP: extension-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Comfort data bus ,64
IDE09570-ENG117726-Vehicle function list BAP: extension-service_interval_display_0x12,activated ,64
IDE09570-ENG117727-Vehicle function list BAP: extension-service_interval_display_0x12_msg_bus,Terminal 15 ,64
IDE09570-ENG117748-Vehicle function list BAP: extension-SideView_0x1E,not activated ,64
IDE09570-ENG117749-Vehicle function list BAP: extension-SideView_0x1E_msg_bus,Comfort data bus ,64
IDE09570-ENG122329-Vehicle function list BAP: extension-Special_Functions_0x35,not activated ,64
IDE09570-ENG122330-Vehicle function list BAP: extension-Special_Functions_msg_bus_0x35,Comfort data bus ,64
IDE09570-ENG117762-Vehicle function list BAP: extension-Start_Stop_reasons_0x27,not activated ,64
IDE09570-ENG117763-Vehicle function list BAP: extension-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,64
IDE09570-ENG117742-Vehicle function list BAP: extension-SWA_0x1A,not activated ,64
IDE09570-ENG117743-Vehicle function list BAP: extension-SWA_0x1A_msg_bus,Comfort data bus ,64
IDE09570-ENG117704-Vehicle function list BAP: extension-tire_pressure_system_0x07,not activated ,64
IDE09570-ENG117705-Vehicle function list BAP: extension-tire_pressure_system_0x07_msg_bus,Comfort data bus ,64
IDE09570-ENG117754-Vehicle function list BAP: extension-traffic_sign_recognition_0x21,not activated ,64
IDE09570-ENG117755-Vehicle function list BAP: extension-traffic_sign_recognition_0x21_msg_bus,Comfort data bus ,64
IDE09570-ENG122331-Vehicle function list BAP: extension-Trailer_Assistant_0x36,not activated ,64
IDE09570-ENG122332-Vehicle function list BAP: extension-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
IDE09570-ENG122325-Vehicle function list BAP: extension-TV_tuner_0x2C,not activated ,64
IDE09570-ENG122326-Vehicle function list BAP: extension-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
IDE09570-ENG117730-Vehicle function list BAP: extension-UGDO_0x14,not activated ,64
IDE09570-ENG117731-Vehicle function list BAP: extension-UGDO_0x14_msg_bus,Comfort data bus ,64
IDE09570-ENG117728-Vehicle function list BAP: extension-unit_master_0x13,activated ,64
IDE09570-ENG117729-Vehicle function list BAP: extension-unit_master_0x13_msg_bus,Terminal 15 ,64
IDE09570-ENG117712-Vehicle function list BAP: extension-VPS_0x0B,activated ,64
IDE09570-ENG117713-Vehicle function list BAP: extension-VPS_0x0B_msg_bus,Terminal 15 ,64
IDE09570-ENG117756-Vehicle function list BAP: extension-weariness_rcognition_0x22,activated ,64
IDE09570-ENG117757-Vehicle function list BAP: extension-weariness_rcognition_0x22_msg_bus,Terminal 15 ,64
IDE09570-ENG117714-Vehicle function list BAP: extension-wiper_comfort_0x0C,activated ,64
IDE09570-ENG117715-Vehicle function list BAP: extension-wiper_comfort_0x0C_msg_bus,Terminal 15 ,64
IDE10480-MAS10741-Interface for external media: activation-Connection 1,not activated ,4
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
MAS00951-Bluetooth,On ,1
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS03690-Telephone,Data & language service active ,1
MAS03782-WLAN,On ,1
ENG117918-ENG117811-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_On_Off,On ,4
ENG117918-ENG117813-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_Time,150.00 ms,4
ENG117918-ENG117810-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_On_Off,On ,4
ENG117918-ENG117812-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_Time,150.00 ms,4
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,activated ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,not activated ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1,0 ,12
ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2,10 ,12
ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3,100 ,12
ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4,150 ,12
ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5,220 ,12
ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6,253 ,12
ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1,0 %,12
ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2,6 %,12
ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3,16 %,12
ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4,30 %,12
ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5,60 %,12
ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6,100 %,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,4 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,11 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,30 %,12
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,10 %,1
ENG117910-Set_Remote_Test_Channel_Scanning,Conditions not correct or request sequence error,1
ENG117908-Shift_Remote_Test_Frequency_AM,Conditions not correct or request sequence error,1
ENG117907-Shift_Remote_Test_Frequency_FM,Conditions not correct or request sequence error,1
ENG117906-Shift_Remote_Test_Volume,Conditions not correct or request sequence error,1
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
Elapsed Time: 00:37
adpmap-6C-5Q0-907-441-A_WAUZZZ8V8F1029358-20241020-1539.CSV
;SW:5Q0-907-441-A   HW:5Q0-907-441-A ---  Back-up Cam.
;Component:MQB RVC Mid   H07 0140, Coding:027300060201000300
;EV_2CamSysRearPASE,006016,EV_2CamSysRearPASE_AU37.rod
;Sunday,20,October,2024,15:39:35:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 303EC900EAAF7FBAEFB-8064
Elapsed Time: 00:08
adpmap-A9-8V0-907-159_WAUZZZ8V8F1029358-20241020-1539.CSV
;SW:8V0-907-159   HW:4H0-907-159-A ---  Struct. Borne Sound
;Component:SAS-GEN 2     H06 0012, Coding:
;EV_SoundActuaGen2AU64X,003010,EV_SoundActuaGen2AU64X_003_VW37.rod
;Sunday,20,October,2024,15:39:47:49859
;VCID: 7DA020346D7D42D234D-8028
IDE04472-Volume of structure-borne noise actuator,100.0 %,1
Elapsed Time: 00:00
adpmap-BB-5Q0-959-395-B_WAUZZZ8V8F1029358-20241020-1540.CSV
;SW:5Q0-959-395-B   HW:5Q0-959-395-B ---  Door Rear Drv
;Component:TSG HFS       020 0025, Coding:004D16204001040000001002
;EV_DCURearDriveMINKLO,006003,EV_DCURearDriveMAXKLO.rod
;Sunday,20,October,2024,15:40:04:49859
;VCID: 40DE99C05A0FEF3A1FB-8014
IDE00001-Production mode,00000000 00000000 00000000  ,3
IDE02332-Deactivate production mode,00000000 00000000 00000000  ,3
Elapsed Time: 00:01
adpmap-BC-5Q0-959-395-B_WAUZZZ8V8F1029358-20241020-1540.CSV
;SW:5Q0-959-395-B   HW:5Q0-959-395-B ---  Door Rear Pass
;Component:TSG HBFS      020 0025, Coding:004D16204001040000001002
;EV_DCURearPasseMINKLO,006003,EV_DCURearPasseMAXKLO.rod
;Sunday,20,October,2024,15:40:21:49859
Elapsed Time: 00:01
