Maps 2024 CUPRA FORMENTOR (KM7, KMP) 1.5 TS DPCA
Maps
Gaz@VDS
Lincolnshire, UK
C?ID=592224
AutoScan: VSSZZZKM2RR140480
Sunday,20,October,2024,15:17:36:49859
Dealer/Shop Name: VDS
VIN: VSSZZZKM2RR140480   License Plate:
Chassis Type: KM-SE38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 42 44 52 5F 6C 75
          A5 BB BC D6 D7 811E 811F 8120 8121 C002 C003
VIN: VSSZZZKM2RR140480   Mileage: 1626km-1010miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DPCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 012 H    HW: 05E 907 309 D
   Component: R4 1.5l TFS   H20 0956
   Revision: 8AH20000    CVN: D99C9D74
   Coding: 012500322364150830080000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906012H 002003
   ROD: EV_ECM15TFS01105E906012H.rod
   VCID: 24163550AE57D31A1B3-8070
   VINID: 9A38EAAAA6DD0A2881100108002F21CBE1
23765 - Control unit for information electronics 1
          U1054 00 {00100000} - No Communication
          {Information electronics control module 1No Communication}
                    Reset counter: 32
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
                    Engine RPM: 912.50 /min
                    Normed load value: 28.2 %
                    Coolant temperature: 85 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 13.240 V
                    Unlearning counter according OBD: 32
                    Outside temperature: 20 °C
                    Absolute intake pressure: 36 kPa abs
                    Engine torque: 31.1 Nm
                    Fuel: tank fill level: 16.0 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0GC 906 556 D    HW: 0GC 300 048 J
   Component: GSG DQ381     H06 4161
   CVN: 0A547824
   ASAM Dataset: EV_TCMDQ381062 001001
   ROD: EV_TCMDQ381062_VW38.rod
   VCID: 3D20E0342DFD82D274D-8068
   Subsystem 1 - Part No SW: 5WA 713 033 CD    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20240419000092187590
   Subsystem 2 - Part No SW: 5FA 713 059 B    HW: 5FA 713 059 B
   Component: ZSB_SB_Mono    H03 0014
   Serial number: 92478XDR01676
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810700006553203
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 CF    HW: 5WA 614 517 N
   Component: ESC           H13 0135
   Serial number: 61204000011313  Dataset Number: V03935398JX 0002 CVN: BCB3764D
   Coding: 34042C994224426C527BA00805C365A62DB458F58AC8670821BCA431018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013058
   ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
   VCID: 0E4277F850DB494ADD7-805A SFD
33015 - Switch for Electric Parking Brake
          C100C 29 {00100000} - Signal Implausible
          {Switch_disturbance_failure}
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 Q    HW: 5WA 959 436 Q
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935364NR 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004_VW38.rod
   VCID: 629A7348F4C39D2A29F-8036
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 727 BC    HW: 5WA 907 727 BC
   Component: Climatronic   H02 0462
   Coding: 000100010011020010100010101011110000112100200000000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005069
   ROD: EV_ACClimaBHBVW38X_SE38.rod
   VCID: 127A638844E3ADAAF9F-8046
   Subsystem 1 - Part No SW: 11A 907 049     HW: 11A 907 049
   Component: E265 KPH       H02 0183
   Serial number: G07S26.04.2400972287
   Interior temperature sensor:
   Subsystem 2 - Part No SW: 5WA 907 527     HW: 5WA 907 527
   Component: E857           H01 0103
   Serial number: 00001200424081920514
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 {01100000} - -
                    Reset counter: 35
                    Mileage: 200 km
                    Date: 2024.10.03
                    Time: 08:26:26
                    Voltage terminal 30: 12.20 V
                    Compressor shut-off condition: Engine running time too short: engine start not detected by CAN
   Part No SW: 5WA 937 086 BS    HW: 5WA 937 086 BA
   Component: BCM37w_M1134 0183
   Serial number: BXJ53F170524940 Dataset Number: V03935381UV 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_AU38.rod
   VCID: 2314364CAB59D422629-8076 SFD
   Subsystem 1 - Part No SW: 5FH 955 113 B    HW: 5FH 955 113 B
   Component: FWISCHER_MYJT  067 0053
   Serial number: 907453F0302411104119
   Component: G397_RLFSS     H06 0004
   Serial number: 23477547X81A955555B0
   Subsystem 3 - Part No SW: 5H0 941 193 AG    HW: 5H0 941 193 AG
   Component: LiSi           H04 0513
   Serial number: RRB71511052400027134
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA    004 0007
   Serial number: 00000000000004497130
   Subsystem 5 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA    005 0403
   Serial number: 0000000000000JQG4V00
   Subsystem 6 - Part No SW: 5H0 959 561 BM    HW: 5H0 959 561 BM
   Component: -VW----LINDA-  504 0831
   Serial number: MW3LND03052400013114
   Steering Column Switch:
   Subsystem 7 - Part No SW: 5Q1 953 507 GA    HW: 5Q1 953 549 F
   Serial number: 00000008052408491731
   left tail lamp 1:
   left tail lamp 2:
   Right rear tail lamp 1:
   Part No SW: 5WA 919 298 B    HW: 5WA 919 298
   Component: PLA 12 Kanal  H05 0578
   Serial number: 000023042495580 Dataset Number: V03935347TP 0003
   Coding: 8300022011
   ASAM Dataset: EV_EPHBO2CVW3800000 002028
   ROD: EV_EPHBO2CVW3800000_VW38.rod
   VCID: 55F05894B58D7A925CD-8000
1080304 - Parking Sensor(s); Rear
          B107B F0 {00101000} - Function Limitation due to External Factors
                    Reset counter: 14
                    Mileage: 1443 km
                    Date: 2024.10.18
                    Time: 17:20:11
1113328 - Parking Sensor(s); Front
          B10FC F0 {00101000} - Function Limitation due to External Factors
          {Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse}
                    Reset counter: 14
                    Mileage: 1443 km
                    Date: 2024.10.18
                    Time: 17:20:27
   Part No SW: 5WA 907 572 C    HW: 5WA 907 572 A
   Component: ACC BOSCH MQB H45 0461
   Dataset Number: V03935382KT 0001
   Coding: 0A03007D407740451247400000D00004AE4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4EC2B7F8905B094A9D7-801A
8 Faults Found:
1127 - Databus
          U1121 00 {00101000} - Missing Message
          {FAULT_TIMEOUT_PSD_04}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
1218 - Databus
          {FAULT_TIMEOUT_PSD_05}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
1219 - Databus
          {FAULT_TIMEOUT_PSD_06}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
1396 - Sensor for Automatic Distance Control
          C110B F0 {00101000} - Limited Visibility
          {FAULT_SENSOR_NO_FREE_SIGHT}
                    Reset counter: 1
                    Mileage: 159 km
1538 - Sensor for Automatic Distance Control
          {FAULT_SENSOR_BLINDNESS}
                    Reset counter: 1
                    Mileage: 157 km
                    Date: 2024.10.01
                    Time: 17:50:00
1592 - Sensor for Automatic Distance Control
          C110B F0 {01101100} - Limited Visibility
          {FAULT_SENSOR_NO_FREE_SIGHT_TIMESTAMP}
                    Reset counter: 1
                    Mileage: 159 km
                    Date: 2024.10.01
                    Time: 17:51:49
209054 - Databus
          U1123 00 {00101000} - Received Error Message
          {FAULT_BV_BLINDNESS_ERROR}
                    Reset counter: 39
                    Mileage: 1538 km
                    Date: 2024.10.19
                    Time: 18:05:57
2425 - Databus
          U1122 00 {00101000} - Implausible Message
          {FAULT_SENSORFUSION_INPUT_CAMERA_NOT_AVAILABLE}
                    Reset counter: 39
                    Mileage: 1539 km
                    Date: 2024.10.19
                    Time: 18:05:58
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 FB    HW: 1EA 959 655 FB
   Component: VW40Airbag    011 0185
   Serial number: Y124MuE0265     Dataset Number: V03935420UA 0001
   Coding: 88CC008000C0C000000000000000000051540000205400004000F68000930065
   Shop #: WSC 00049 770 00210
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001016
   ROD: EV_AirbaVW40ALVVW38X_VW41.rod
   VCID: 06524FD838AB010A657-8052 SFD
   Subsystem 1 - Part No SW: -----------    HW: 440 003 004 24
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ0000004B09CBE6S
   Subsystem 2 - Part No SW: -----------    HW: 440 001 405 24
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ0000003F561AE6K
   Subsystem 3 - Part No SW: -----------    HW: 440 001 505 24
   Component: SideSensor_Pr  00B 0149
   Serial number: 352CJB0CF73712C3300V
   Subsystem 4 - Part No SW: -----------    HW: 440 001 505 24
   Component: SideSensor_Dr  00B 0149
   Serial number: 351CJAECF7371A86A00E
   Subsystem 5 - Part No SW: -----------    HW: 440 002 404 24
   Component: FrontSensor_P  00B 014A
   Serial number: 356CJA8CE3DA4848700H
   Subsystem 6 - Part No SW: -----------    HW: 440 002 404 24
   Component: FrontSensor_D  00B 014A
   Serial number: 355ckA8CE3DA4848B00L
   Part No SW: 5FA 920 790 C    HW: 5FA 920 790 C
   Component: KOMBI         311 7360
   Coding: 242C04416B940600018162032000080800300400
   ASAM Dataset: EV_DashBoardVDDMQB37W 003035
   ROD: EV_DashBoardVDDMQB37W_003_VW49.rod
   VCID: 3A2AEB283CD3B5EA51F-806E SFD
16777018 - Control unit for information electronics 1
          U1054 00 {00001000} - No Communication
          {Audio_0x31 communication error bap_error_timeout heartbeat}
                    Fault Frequency: 8
                    Reset counter: 95
                    Mileage: 177 km
                    Date: 2024.10.01
                    Time: 18:27:01
16777020 - Control unit for information electronics 1
          {TEL_0x28 communication error bap_error_timeout heartbeat}
                    Fault Frequency: 56
                    Reset counter: 95
                    Mileage: 251 km
                    Date: 2024.10.03
                    Time: 16:14:10
16777022 - Control unit for information electronics 1
          {NAV_SD_0x32 communication error bap_error_timeout heartbeat}
                    Reset counter: 95
                    Mileage: 251 km
                    Date: 2024.10.03
                    Time: 16:14:10
   Part No SW: 5WA 907 530 AB    HW: 5WA 907 530 L
   Component: GW2020 High   778 7105
   Revision: --------    Serial number: 771049110024124 Dataset Number: V03935370TJ 0002
   Coding: 0000808D0F00000000000000012303135101610B02000300030100000001010000000000000000000000000000000000
   GVL: 3D0000000208409C80008002C800004004004000004000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 006012
   ROD: EV_GatewMQB2020_006_VW38.rod
   VCID: 084E41E032BF177A17B-805C SFD
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5WA 915 181 D    HW: 5WA 915 181 D
   Component: J367-BDMConti  H04 1070
   Serial number: 76407104002405040591
   Subsystem 3 - Part No SW: 5FA 919 719 H    HW: 5FA 919 719 H
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440059128240174
2175091 - Control unit for information electronics 1
          U1054 00 {00101000} - No Communication
          {Information_electronics_control_module_1_no_communication}
          B184C 00 {00100000} - -
          {Unlock_protection_of_vehicle_diagnosis_active}
8466689 - VKMS
          B18B0 F0 {00100000} - Missing Adaptation
          {VKMS_new_download_container_required_due_to_vehicle_change}
   Part No SW: 5WA 909 059 AB    HW: 3Q0 909 059 C
   Component: EBKV          H09 0372
   Serial number: BPA085150424013 Dataset Number: V03935358NG 0001
   Coding: 1002C500740000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: 107E69804AEF5FBACFB-8044 SFD
107008 - No Communication with Transmission Control Module
          U0101 00 {00101000} - -
          {ComScl_Getriebe_11_Timeout}
                    Reset counter: 7
                    Mileage: 1199 km
                    Date: 2024.10.16
                    Time: 14:21:50
107024 - Transmission Control Module
          U14E4 00 {00100000} - Received Malfunction Value
          {Scl_Getriebe_11_GE_Fahrstufe_Error}
1024368 - Brake Booster
          C1187 F6 {00101000} - Function Limitation due to External Brake Pressure Build-Up
          {ActiveRestrictionDetected}
                    Fault Frequency: 19
                    Reset counter: 36
                    Mileage: 279 km
                    Date: 2024.10.05
                    Time: 10:24:40
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 24000128905015
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 323AC308E4A34DAA99F-8066
   Part No SW: 5WA 959 760 H    HW: 5WA 959 760 H
   Component: MEM-FS        009 0362
   Serial number: 2450301KA03057
   Coding: 01789A000000A0408803010101010000000000212100000000000000215000
   Shop #: WSC 00049 770 00068
   VCID: 59E854A4D9955EF2785-800C
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        015 0912
   Serial number: 0000528601453  Dataset Number: V03935382ZB 0002
   Coding: 00351020D201020000001000
   Shop #: WSC 00049 770 00185
   VCID: 52FAA38884636DAAB9F-8006
   Subsystem 1 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000081548028
   Coding: 3D0000
   Part No SW: 5WA 907 145 G    HW: 5WA 907 145 C
   Component: BASGEN1MQB37  502 1040
   Serial number: 03732975 Dataset Number: V03935356Z  0002
   Coding: 0000000000000001000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       015 0912
   Serial number: 0000528674110  Dataset Number: V03935382ZC 0002
   Coding: 00351020DE01020000001000
   VCID: 51F8AC84816516B2805-8004
   Subsystem 1 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000081506352
   Coding: 250000
   Part No SW: 5FA 035 862 R    HW: 5FA 035 862
   Component: MU-O-ND-EU    H67 1969
   Serial number: WG8LGM100524000 Dataset Number: V03935423GB 0001
   Coding: 43161008000100000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_SE38.rod
   VCID: 46D28FD8782BC10A257-8012 SFD
   Subsystem 1 - Part No SW: 5FA 919 606 C    HW: 5FA 919 606 C
   Component: ABT_W_12       H46 6091
   Serial number: APUFP201052400040097
   Subsystem 2 - Part No SW: V03 959 820 GB    HW: -----------
   Component: EUR 2023/24    --- 9085
12316 - Clock Syncronization Failure
          U138F 00 {00001000} - -
                    Fault Frequency: 9
                    Reset counter: 33
                    Mileage: 59 km
                    Date: 2024.09.30
                    Time: 15:24:25
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H31 0364
   Serial number: FCLK20260424010 Dataset Number: V03935373WX 0001
   Coding: 04033200843000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010026
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   Part No SW: 5WA 035 284 F    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H14 0144
   Serial number: 0000000405VIFW0 Dataset Number: V03935357XP 0001
   Coding: 043160009068A8209005460061402E07
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 49C884E469352E72C85-801C SFD
7248 - Function Restricted due to Missing Message(s)
          U1111 00 {00001000} - -
          {InfotainmentSettings (0x50) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful}
                    Reset counter: 38
                    Mileage: 1541 km
                    Date: 2024.10.20
                    Time: 09:34:51
                    Voltage terminal 30: 11.8 V
   Part No SW: 5WA 980 653 D    HW: 5WA 980 653
   Component: MQB MFK 3.0   H12 3405
   Serial number: EB7590903241310 Dataset Number: V03935413PS 0001
   Coding: 000309082148C040409E00801020002000018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005055
   ROD: EV_MFK3ValeoMQB_005_AU38.rod
   VCID: 50FEA9808A6F1FBA8FB-8004
1122664 - Databus
          U1121 00 {00001000} - Missing Message
          {TIMEOUT_PSD_04}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
1122672 - Databus
          {Timeout_PSD_06}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
1122665 - Databus
          {Timeout_PSD_05}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
   Part No SW: 992 941 571 AG    HW: 992 941 571 A
   Component: LED1L         H17 9104
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 678C625C1FE1F802FE1-8032
   Component: LED1R         H17 9104
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 F    HW: 5WA 962 133 F
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
   VCID: 4BC4BEEC63493C62FA9-801E
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----------(Elapsed Time: 20:40, VBatt start/end: 12.1V/14.5V)-----------
blockmap-01-05E-906-012-H_VSSZZZKM2RR140480-20241020-1459.CSV
;SW:05E-906-012-H   HW:05E-907-309-D ---  Engine
;Component:R4 1.5l TFS   H20 0956, Coding:012500322364150830080000000000000000000000000000
;EV_ECM15TFS01105E906012H,002003,EV_ECM15TFS01105E906012H.rod
;Sunday,20,October,2024,14:59:44:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 24163550AE57D31A1B3-8070
Group,Description,Actual
IDE00019,Voltage terminal 30,12.060, V
IDE00020-ENG188621,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine RPM,0, /min
IDE00025,Coolant temperature,60, °C
IDE00078,Time since engine start,0, s
IDE00083,Throttle valve position (absolute),16.5, %
IDE00084,Absolute load value,0, %
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator pedal position,14.9, %
IDE00090-ENG188621,selected gear-Bits 0-7,0,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00100,Engine torque,0.0, Nm
IDE00102,Control Module temperature,30.6, °C
IDE00148,Mean injection time,0.0000, ms
IDE00151,Oil fill level,61.820, mm
IDE00155,Ignition timing angle retard cylinder 1,0.0, °
IDE00156,Ignition timing angle retard cylinder 2,0.0, °
IDE00157,Ignition timing angle retard cylinder 3,0.0, °
IDE00158,Ignition timing angle retard cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,187.4, °C
IDE00172,A/C compressor torque,0.0, Nm
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-26.38, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-25.00, °
IDE00178,Camshaft adjustment intake bank 1: specified value,20.55, °
IDE00179,Camshaft adjustment intake bank 1: actual value,22.00, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.00, °
IDE00187,Coolant temperature at engine start,59.9, °C
IDE00188,Fuel high-pressure: actual value,9.046, MPa
IDE00190,Charge air pressure: specified value,1279.61, hPa
IDE00191,Charge air pressure: actual value,995.47, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,23.6, °C
IDE00194,Coolant temperature at radiator output: specified value,105.0, °C
IDE00196,Engine oil temperature,48.4, °C
IDE00201,High fuel pressure: specified value,15.000, MPa
IDE00202,Low fuel pressure: specified value,500.0, kPa
IDE00304,Fuel level,38.00, l
IDE00348,Intake air temperature,38, °C
IDE00349,Throttle valve position: normed,5.9, %
IDE00350,Air mass: specified value,0.0, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_WAIT,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,1,
IDE00355-ENG188621,Cruise Control System (CCS): status-Bits 0-7,6,
IDE00357,Fuel temperature,59.3, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00371,Fuel consumption,0.00, l/h
IDE00375,Generator: load signal,0.02, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,748.4, mV
IDE00393,Accelerator pedal: sensor voltage 2,373.4, mV
IDE00394,Camshaft position: start of phase window,37.27, °
IDE00406,Camshaft RPM,0.0, /min
IDE00412-ENG188621,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG188621,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG188621,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG188621,Starter control: terminal 50 feedback-Bits 0-7,4,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00419,Exhaust gas temperature before particle filter,41.6, °C
IDE00434,Particle filter: soot mass calculated,1, mg
IDE00436,Particle filter: kilometers since last regeneration,1622200, m
IDE00443-ENG188621,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00451,Currently running routine,Unknown (0)
IDE00474,Ambient air pressure,99, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
IDE00496-ENG188621,Oil pressure switch valve activation-Bits 0-7,1,
IDE00541,Acceleration,0.000, m/s²
IDE00554,Absolute vapor pressure in tank ventilation system,99765, kPa abs
IDE00556,Outside temperature,16, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.012 Lambda / -0.004 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.460, V
IDE00582,Specified value of equivalence ratio,1.999, Lambda
IDE00583,Throttle valve specified value,0.0, %
IDE00584,Distance driven since erasing DTC memory,1615, km
IDE00588,Fuel tank fill level,75.7, %
IDE00592,Status of oxygen sensor control,Engine off,
IDE00593,Ignition timing adjustment cylinder 1,0.0, Degrees
IDE00594,Absolute intake pressure,99, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,-100.0, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00603,Number of driving cycles since erasing DTC memory,45,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00738,Oxygen sensor test: bank 1: delta lambda,0.00000,
IDE00773,Terminal 15 status via CAN,1,
IDE00950-ENG188621,A/C compressor status-Bits 0-7,0,
IDE01378,Fuel high pressure: control deviation,0.0000, MPa
IDE01385-ENG188621,Wear index-Bits 0-7,0,
IDE01386-ENG188621,Soot index-Bits 0-7,0,
IDE01405-ENG188621,Starter activation: status-Bits 0-7,2,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.460, V
IDE01650,Throttle valve position 2,16, %
IDE01774,Status misfire recognition,False result,
IDE01774-ENG127289,Status misfire recognition-Test_Program_B TRUE UBYTE,0,
IDE01775-ENG188621,Misfires per 1000 revolutions of cylinder 1-Bits 0-7,0,
IDE01776-ENG188621,Misfires per 1000 revolutions of cylinder 2-Bits 0-7,0,
IDE01777-ENG188621,Misfires per 1000 revolutions of cylinder 3-Bits 0-7,0,
IDE01778-ENG188621,Misfires per 1000 revolutions of cylinder 4-Bits 0-7,0,
IDE01869,Long-term fuel trim bank 1 at idle,-1.22, %
IDE01873,Test of catalytic converter: measured value,6.9675,
IDE01876,Adaptation of loss torque,0.0, Nm
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator pedal position 2,14.9, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01888,Cold start enrichment: adaptation area 1,1.086,
IDE01889,Cold start enrichment: adaptation area 2,1.086,
IDE01890,Cold start enrichment: adaptation area 3,1.086,
IDE01891,Cold start enrichment: adaptation area 4,1.086,
IDE01892,Cold start enrichment: adaptation area 5,1.086,
IDE01893,Fuel pump: specified value,3.999, %
IDE01899,Load value: corrected specified value,7.34, %
IDE01901,Lost torque adaptation: idle,1.8, Nm
IDE01902,Lost torque adaptation A/C compressor,-2.1, Nm
IDE01903,Lost torque adaptation driving mode,0.1, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,-2.5, Nm
IDE01912,Oxygen sensor B1: sensor 1: specified value,1.0000,
IDE01922,Vehicle distance driven,1626, km
IDE01923,Control module distance driven,1622250, m
IDE01928,Close cam shaft angle at quantity control valve,0.0, °
IDE01929,Open cam shaft angle at quantity control valve,0.0, °
IDE01930,High pressure regulation: adaptation value,0.024, MPa
IDE01932,High pressure pump injection volume,0.00, mm³
IDE01975-ENG188621,Numb.of misfir.: cylinder 1-Bits 0-7,1,
IDE01976-ENG188621,Numb.of misfir.: cylinder 2-Bits 0-7,0,
IDE01976-ENG188621,Numb.of misfir.: cylinder 2-Bits 0-7,194,
IDE01977-ENG188621,Numb.of misfir.: cylinder 3-Bits 0-7,229,
IDE01977-ENG188621,Numb.of misfir.: cylinder 3-Bits 0-7,0,
IDE01978-ENG188621,Numb.of misfir.: cylinder 4-Bits 0-7,0,
IDE01978-ENG188621,Numb.of misfir.: cylinder 4-Bits 0-7,202,
IDE02117,Relative load value,0.00, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.12, MPa
IDE02540-ENG188621,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02742,Oil pressure actual value,101.9, kPa
IDE02756,Number of manual engine starts,163,
IDE02757,Number of automatic engine starts,159,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,not active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,15,
IDE03010-MAS01627,Number of prevented stop processes-Steering,30,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,58,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,3,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery performance too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,68,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,33,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,3,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,5,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery performance too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,9,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.520, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.476, V
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03375-ENG188621,Adaptation status of neutral position sensor-Bits 0-7,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3417.4, mV
IDE03393-ENG188621,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver's door status-Dsplb Drv Door Act Opn,1,
IDE03584-ENG188621,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,All releases are present,
IDE03586-ENG188621,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stopping requirements for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping requirements for active participants-Air Conditioning,active,
IDE03587-MAS00127,Stopping requirements for active participants-brakes,not active,
IDE03587-MAS00506,Stopping requirements for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping requirements for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping requirements for active participants-Transmission,not active,
IDE03587-MAS01106,Stopping requirements for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping requirements for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping requirements for active participants-Steering,not active,
IDE03587-MAS02237,Stopping requirements for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping requirements for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping requirements for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping requirements for active participants-Motor,active,
IDE03587-MAS06709,Stopping requirements for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping requirements for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping requirements for active participants-Front sensor for drivers assistant systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-Air Conditioning,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for drivers assistant systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication malfunction,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,-0.394, m/s²
IDE03711,Mass flow through throttle valve,0.0, kg/h
IDE03767,Engine status,COENG_READY,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,1,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.000, %
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,0.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,0.0, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,0.000, %
IDE03932,Charge pressure actuator: specified position,21.19, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3142.8, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.03381,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE04000,Intake air temperature sensor,IAT 11:35 °C / IAT 12:37 °C,
IDE04002,Charge air pressure control,BP_A act:99.4, kPa
IDE04008,Fuel consumption per hour,0.00, L/h
IDE04010,Engine torque: normalized,0.0, %
IDE04011,Nominal torque,250, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:8920/--- kPa,
IDE04044,Charge pressure control valve,WG_A cmd/act:---/21 % / WG_B cmd/act:---/--- %,
IDE04045,Exhaust gas pressure,EP1:99.14, kPa
IDE04083,Coolant temperatures,ECT 1:59 °C / ECT 2:58 °C,
IDE04110,Additional inputs and outputs,GEAR_RCMD: N,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,1876.6, mV
IDE04278,Bypass valve f high press turboch turbine inlet: target value,0.00, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,21.06, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,0.00, %
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,2,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,0,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,695.4, mV
IDE04410,Intake manifold pressure: specified value,1279.61, hPa
IDE04604,Accelerator pedal travel,0.00, %
IDE04629,AVS operating condition,0,
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04670,Crankshaft signal evaluation: status,EPMHCRS_WAITSIG,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,1,
IDE04693,Increasing desired torque intervention of ESP,-98271.2, Nm
IDE04695-ENG137752,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG137752,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04887,Powertrain target torque,-699.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,-23.4, Nm
IDE04937,Sensor for engine block temperature: raw value,59.8, °C
IDE05135,Status of compressor release,Correct result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,1,
IDE05138,Shut-off timer: last engine shut-off time,3279, s
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,EVAP valve diagnosis ratio of pressure difference,0.00,
IDE05215,EVAP valve diagnosis result correlation factor,0.00,
IDE05240-ENG188621,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG188621,A/C compressor release status-Bits 0-7,0,
IDE05332-ENG188621,Heat request from heater to thermal management-Bits 0-7,0,
IDE05442,Roadway slope angle acceleration interface: calculated,-0.0397, rad
IDE05444,Air filling: specified value,15.40, %
IDE05449,O2 sensor 2: B1: internal resistance limit,131070, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00293,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,-273.15, °C
IDE05470,Cat converter oxygen storage capacity,528.6, mg
IDE05474,Main cat converter OSC age correction factor,0.89063,
IDE05479,Misfire recognition reference moment,0.000, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05484,Servo pump desired actual torque for idle control,0.0, Nm
IDE05485-ENG188621,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05497,Adaptation value of the charge pressure control,0.00, hPa
IDE05761-ENG121419,Nominal operating condition: partial engine operation-Bhmbs,0,
IDE05762-ENG121418,Engine operating status partial engine operation-Bhmb,0,
IDE05767,Number of switch-overs during partial engine operation,0,
IDE05928,Fuel consumption since DTC memory last erased,8.774, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,0,
IDE05950,Charge pressure control adaptation value 1,19.6875, hPa
IDE05951,Charge pressure control adaptation value 2,-11.25, hPa
IDE05952,Charge pressure control adaptation value 3,0, hPa
IDE06014,Charge pressure control adaptation value 0,14.0625, hPa
IDE06020,Intake air temperature in intake manifold bank raw value,38.2, °C
IDE06021,Intake air temperature before throttle valve: raw value,35.7, °C
IDE06039,Required RPM at idle speed,1400.0, /min
IDE06040,High fuel pressure: regulator output value,0.0000, MPa
IDE06041-ENG188621,PDTC drive cycle conditions status-Bits 0-7,0,
IDE06045-ENG188621,Output diagnostic test status-Bits 0-7,0,
IDE06049,Pressure in brake booster: raw value,997, hPa
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06112-ENG188621,Test of cylinder deactivation-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,0.0625000, V*ms
IDE06193,Knock sensor: cylinder 3: voltage,0.0625000, V*ms
IDE06194,Knock sensor: cylinder 4: voltage,0.0625000, V*ms
IDE06195,Knock sensor: cylinder 1: voltage,0.0625000, V*ms
IDE06198-ENG188621,Tank vent valve: diagnostic status-Bits 0-7,32,
IDE06255,Vehicle lateral acceleration,0.03, g
IDE06256,Vehicle lateral acceleration: raw value,0.03, g
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,-0.406, m/s²
IDE06567,Frequency counter deactivate start/stop function,280,
IDE06568,Stop prevention by driver frequency counter,223,
IDE06569,Frequency counter vehicle standstill,862,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,47.9, °C
IDE06610,Frequency counter vehicle standstill with stop,177,
IDE06702-ENG188621,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06703-ENG188621,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG188621,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,32,
IDE06706-ENG188621,ACC variants-Bits 0-7,2,
IDE06707-ENG188621,CCS Switch-Bits 0-7,2,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,1,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG188621,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG188621,Cruise control system: permanent deactivation-Bits 0-7,0,
IDE06711-ENG188621,Cruise control system: temporary deactivation-Bits 0-7,0,
IDE06758,Air mass since engine start,0.0000, kg
IDE06799-ENG188621,A/C compressor status: HW input-Bits 0-7,0,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06828,Coolant recirc. pump 2: spec. value,10.00, %
IDE06944,A/C compressor: load current: act. value,1023.97, A
IDE06946-ENG188621,Brake actuated status-Bits 0-7,0,
IDE06956-ENG188621,Driver-side belt buckle status-Bits 0-7,2,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,not active,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,available.,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Not available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,0.0, %
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,available.,
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,Not available,
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,0, min
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,0, km
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,available.,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,0,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,212,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,4,
IDE07051-ENG188621,Engaged gear: raw signal-Bits 0-7,0,
IDE07076,AVS valve stroke position intake,0,
IDE07077,AVS valve stroke position: exhaust,0,
IDE07078,AVS result of last switch-over: intake,10,
IDE07079,AVS result of last switch-over: exhaust,10,
IDE07164,Number injections,0,
IDE07224-ENG188621,Overrun cut-off-Bits 0-7,0,
IDE07233-ENG188621,Bit string for status of oil level-Bits 0-7,0,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG188621,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07548,Engine temp. mangmt. actuator: specified value of angle,64.59, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,64.69, %
IDE07550,Engine temp. management actuator: raw value,3043.8, mV
IDE07620-ENG188621,Status momentary default during stability intervention-Bits 0-7,0,
IDE07693,Maximum supply pressure low-pressure fuel pump,0.0, kPa
IDE07697,System test status of fuel supply,32,
IDE07796-ENG188621,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07904-ENG188621,Brake test switch status-Bits 0-7,0,
IDE07905-ENG188621,Brake light switch status-Bits 0-7,0,
IDE07906-ENG188621,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,0.00, %
IDE07963-ENG188621,Cam piece counter position malfunction-Bits 0-7,0,
IDE08353-ENG188621,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE08353-ENG188621,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE09307-ENG188621,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG188621,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG188621,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG188621,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG188621,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG188621,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG188621,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG188621,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09319-ENG188621,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG188621,Pre-ignition action counter fill level limit-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,0.09, g
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09925-ENG188621,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG188621,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-1.45, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,-1.36, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,0.62, °
IDE09932,Intake camshaft B1: adaptation value sensor tolerance,1.19, °
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10063-MAS00666,Engine oil level: current value-Warning,0,
IDE10063-MAS00900,Engine oil level: current value-Oil level,8.2, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,1498, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,1487, km
IDE10063-MAS09807,Engine oil level: current value-Qualification,7,
IDE10063-ENG137751,Engine oil level: current value-OilLvlDisp_stTstPrcd_VW,3,
IDE10064-MAS00666,Engine oil level: history 1-Warning,0,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,0.0, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,0, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,0, km
IDE10064-MAS09807,Engine oil level: history 1-Qualification,0,
IDE10064-ENG137751,Engine oil level: history 1-OilLvlDisp_stTstPrcd_VW,0,
IDE10065-MAS00666,Engine oil level: history 2-Warning,0,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,0.0, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,0, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,0, km
IDE10065-MAS09807,Engine oil level: history 2-Qualification,0,
IDE10065-ENG137751,Engine oil level: history 2-OilLvlDisp_stTstPrcd_VW,0,
IDE10066-MAS00666,Engine oil level: history 3-Warning,0,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,0.0, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,0, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,0, km
IDE10066-MAS09807,Engine oil level: history 3-Qualification,0,
IDE10066-ENG137751,Engine oil level: history 3-OilLvlDisp_stTstPrcd_VW,0,
IDE10067-MAS00666,Engine oil level: history 4-Warning,0,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,0.0, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,0, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,0, km
IDE10067-MAS09807,Engine oil level: history 4-Qualification,0,
IDE10067-ENG137751,Engine oil level: history 4-OilLvlDisp_stTstPrcd_VW,0,
IDE10068-MAS00666,Engine oil level: history 5-Warning,0,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,0.0, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,0, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,0, km
IDE10068-MAS09807,Engine oil level: history 5-Qualification,0,
IDE10068-ENG137751,Engine oil level: history 5-OilLvlDisp_stTstPrcd_VW,0,
IDE10069-MAS00666,Engine oil level: history 6-Warning,0,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,0.0, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,0, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,0, km
IDE10069-MAS09807,Engine oil level: history 6-Qualification,0,
IDE10069-ENG137751,Engine oil level: history 6-OilLvlDisp_stTstPrcd_VW,0,
IDE10070-MAS00666,Engine oil level: history 7-Warning,0,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,0.0, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,0, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,0, km
IDE10070-MAS09807,Engine oil level: history 7-Qualification,0,
IDE10070-ENG137751,Engine oil level: history 7-OilLvlDisp_stTstPrcd_VW,0,
IDE10071-MAS00666,Engine oil level: history 8-Warning,0,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,0.0, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,0, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,0, km
IDE10071-MAS09807,Engine oil level: history 8-Qualification,0,
IDE10071-ENG137751,Engine oil level: history 8-OilLvlDisp_stTstPrcd_VW,0,
IDE10072-MAS00666,Engine oil level: history 9-Warning,0,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,0.0, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,0, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,0, km
IDE10072-MAS09807,Engine oil level: history 9-Qualification,0,
IDE10072-ENG137751,Engine oil level: history 9-OilLvlDisp_stTstPrcd_VW,0,
IDE10302,Time since engine start,0.0, s
IDE10303,Integrated air masse at first engine start,0.0000, kg
IDE10560-ENG188621,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10580,Engine oil level: test method 1,53.6, %
IDE10581,Engine oil level: test method 2,56.8, %
IDE10582,Engine oil level: test method 3,62.0, %
IDE10633,Clutch protection function: reduced torque,3267.7, Nm
IDE10634,Clutch protection function: slip speed of the clutch,0.0, 1/min/s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,210.0, kPa
IDE10670,O2 sensor befor CAT: filter time constant changeover rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,50, ml/mm
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989,Immobilizer: historic data,|Year,Month
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,23,
IDE11116,Start/stop driver request: counter internal-motor restart,9,
IDE11203,Oil pressure setpoint,199.7, kPa
IDE11267,Oil level: max. value: relative,69.2, %
IDE11268,Oil level: min. value: relative,53.1, %
IDE11302-ENG188621,Engine oil level: test method 1 qualification-Bits 0-7,8,
IDE11303-ENG188621,Engine oil level: test method 3 qualification-Bits 0-7,3,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,0,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,200,
IDE11330,Oil press. control valve: activation pulse duty factor,59.15, %
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometers,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometers,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometers,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometers,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometers,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometers,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometers,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometers,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometers,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometers,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11541-ENG188621,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function prevention,active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Air system diagnosis,not active,
IDE11577-MAS04870,Stop process prevented 2-Thermostat testing not completed,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,active,
IDE11577-MAS06604,Stop process prevented 2-Start/stop sensors:,not active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration Mode,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-DTC memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Learning function active,not active,
IDE11577-MAS13644,Stop process prevented 2-Engine protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel gelling protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust treatment diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in start system,not active,
IDE11929,I share of PID control of fully variable oil pump,0.00, %
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,0.00000,
IDE12044-ENG188621,Crankshaft Position adapt.: write attempt counter-Bits 0-7,1,
IDE12074-ENG188621,Position adapt. of intake camshaft bank 1: counter-Bits 0-7,1,
IDE12077-ENG188621,Position adapt. of outlet camshaft bank 1: counter-Bits 0-7,1,
IDE12078-ENG188621,Position adapt. of camshafts cyl: individual bank 1: counter-Bits 0-7,1,
IDE12105,Temperature sensor for cylinder block: uncond. voltage value,1941.2, mV
IDE12106,Temperature sensor for cylinder block,58.1, °C
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,21.68, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,20.72, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,15.56, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,21.98, %
IDE12210,Particle filter: water mass,0.0, g
IDE12355,ESI: consumption equivalent of the engine control module,0.00000000,
IDE12460,Low pressure procedure: pressure regulation valve open,0.00, kPa
IDE12461,Pressure regulator valve pulse duty factor,0.00, %
IDE12462,Pressure regulator valve opening pressure,0.0, kPa
IDE12463,Pressure regulator valve minimum pulse duty factor,False result,
IDE12463-ENG127289,Pressure regulator valve minimum pulse duty factor-Test_Program_B TRUE UBYTE,0,
IDE12464,Rail pressure at end of test,0.000, MPa
IDE12468-ENG188621,Login counter of the simulation interface-Bits 0-7,0,
IDE12748,Oil level: amount added MIN to MAX,1000, ml
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,10072, mg
IDE13086,Particle filter: maximum soot build-up reached,13446, mg
IDE13087,Particle filter: maximum ash build-up reached,30, g
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,8388608,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13945,Mixture variations without lambda controller interference,0.00000,
IDE14152,Oil level: maximum value: compensated,20.136, mm
IDE14153,Oil level: minimum value: compensated,42.408, mm
IDE14534,Knock control: error status,0,
IDE14753,Particulate filter: loading stage,0,
IDE14755,Particulate filter: blockage ratio calculated: relative,0.0,
IDE14756,Particulate filter: blockage ratio calculated: absolute,0.0,
IDE14761,Particulate filter: oil ash load calculated,0.0, %
IDE14763,Particulate filter: water load,0.0, %
IDE14767,Particulate filter: soot load calculated,0.0, %
IDE80106,Analysis 106,00 03 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 54 00 00 00 00 00 00 20 C4 08 08 00 85 00 00 00 00 00 00 00 00,
MAS15845,Fuel: tank fill level,38.0, l
MAS15866,High pressure buildup gradient during pressure limitation valve opening test,0.000, MPa/revolution
MAS15883,Maximum fuel high-pressure with extended value range,0.000, MPa
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,61.0, °C
MAS16222,Heated oxygen sensor bank 1 probe 1: status 2G,False result,
MAS16222-ENG127289,Heated oxygen sensor bank 1 probe 1: status 2G-Test_Program_B TRUE UBYTE,0,
MAS16223,Heated oxygen sensor bank 1 probe 2: status 2G,False result,
MAS16223-ENG127289,Heated oxygen sensor bank 1 probe 2: status 2G-Test_Program_B TRUE UBYTE,0,
MAS16287,High pressure buildup process with engine of: extended range,0.000, MPa/s
MAS16299,Heated oxygen sensor 1 probe 1: status dew point end,False result,
MAS16299-ENG127289,Heated oxygen sensor 1 probe 1: status dew point end-Test_Program_B TRUE UBYTE,0,
MAS16300,Heated oxygen sensor 1 probe 2: status dew point end,False result,
MAS16300-ENG127289,Heated oxygen sensor 1 probe 2: status dew point end-Test_Program_B TRUE UBYTE,0,
MAS16534-ENG188621,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16534-ENG188621,A/C compressor info: switch-off status-Bits 0-7,1,
MAS16688,Throttle 1: bank 1: diagnostic value normed: leak detection,0.0000,
MAS16834,Particle filter threshold rate of blockage calculated,3.0000,
MAS16835,Particle filter rate of blockage calculated,0.9984,
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
MAS17031,Radiator shutter 1: actual position,255, %
MAS17032,Radiator shutter 2: actual position,255, %
MAS17060,Characteristics cooling module 1: end stage activation,0.00, %
MAS17189,Exhaust pressure sensor 1: raw value,992.2, hPa
MAS17191,Characteristics cooling module: target position,64.59, %
MAS17192,Characteristics cooling module: upper mechanical stop,4502.4, mV
MAS17193,Characteristics cooling module: lower mechanical stop,512.8, mV
ENG119898,Actual_section_of_standard_test,0,
ENG157506-ENG188621,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG157507-ENG188621,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG157508-ENG188621,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG157509-ENG188621,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG188621,AVS_counter_error_debonce-Bits 0-7,0,
ENG121429-ENG188621,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG188621,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG188621,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG126402-ENG188621,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG168741,DTEV r p In Mnf Mes Estim,0.00,
ENG247045,Engine Exhaust Flow Rate,0.0, kg/h
ENG151174,Engine Friction - Percent Torque,9.0, %
ENG157850,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG157851,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG157852,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
ENG247046-ENG186450,Fuel Rate-Engine Fuel Rate,0.00, g/s
ENG247046-ENG247209,Fuel Rate-Vehicle Fuel Rate,0.00, g/s
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month
ENG127733,Life_cycle_data_system_failure,|Year,Month
ENG158050-ENG188621,Mo XEMM st EMM Alrms Idx0-Bits 0-7,0,
ENG158051-ENG188621,Mo XEMM st EMM Alrms Idx1-Bits 0-7,0,
ENG158052-ENG188621,Mo XEMM st EMM Alrms Idx2-Bits 0-7,0,
ENG158155,Rba Io Sig Rtc st Diag Stop Count er,255,
ENG139760,Thr Vlv u Sens1 B1,0.833, V
ENG139761,Thr Vlv u Sens2 B1,4.164, V
ENG247047-ENG247196,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG247047-ENG247180,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG247047-ENG247177,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG247047-ENG247188,Transmission Actual Gear-Transmission Actual Gear Status Supported,available.,
ENG247048,Vehicle Odometer,1626.7, km
ENG158334,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG158335,Virtual_SigXSet_TiEngOff_tiDiagRef,143, s
ENG158336,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,3070, s
ENG158337,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8385537, s
ENG158338,Virtual_SigXSet_TiOff_tiStrtEnd_Off,3308, s
Elapsed Time: 00:49
blockmap-02-0GC-906-556-D_VSSZZZKM2RR140480-20241020-1500.CSV
;SW:0GC-906-556-D   HW:0GC-300-048-J ---  Auto Trans
;Component:GSG DQ381     H06 4161, Coding:0014
;EV_TCMDQ381062,001001,EV_TCMDQ381062_VW38.rod
;Sunday,20,October,2024,15:00:40:49859
;VCID: 3D20E0342DFD82D274D-8068
IDE00018,Voltage terminal 15,11.9, V
IDE00019,Voltage terminal 30,11.8, V
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,0, /min
IDE00023,Transmission output speed,0, /min
IDE00024-ENG98981,ATF temperature-Transmission fluid temperature,53, °C
IDE00025,Coolant temperature,59, °C
IDE00086,Accelerator pedal position,0.0, %
IDE00091-ENG101172,Status of starter lock-Status Engine Starter Lock,Activating,
IDE00094,Kick-down status,OFF,
IDE00095-ENG101643,Status of selector lever lock-Status Shift Lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00101-ENG103259,Engine specified torque during transmission intervention-Calculated engine preset torque,1045.0, Nm
IDE00102-ENG102028,Control Module temperature-Control modul temperature,53, °C
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,0,
IDE00323-ENG140165,Security Access: Number of invalid keys-Counter Value,0,
IDE00872-ENG102188,Current of main pressure valve-Oil Pressure Actual Current,1199.0, mA
IDE00970-ENG114816,Coolant fan activation: actual value-Radiator fan activation actual value,10.0, %
IDE00972,Idle speed increase,OFF,
IDE01588-ENG101855,Driving direction-M015 SvnNAbRichtung,not known,
IDE01716-ENG103234,Terminal 50 status-Status terminal 50,OFF,
IDE02211,Brake pressure,0.00, bar
IDE02221,Engine torque: qualification,valid,
IDE02713-ENG98471,Brake lamp switch-Brake Light Switch,Not operated,
IDE02714,Brake test switch,Not operated,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,via CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02719-ENG99606,Selector lever position made plausible-Shift Position Plausible,P,
IDE02720-ENG103810,Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1,0, /min
IDE02721-ENG100916,Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2,0, /min
IDE02722-ENG101964,Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1,0, /min
IDE02723-ENG100382,Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2,0, /min
IDE02724,Direction of rotation shaft 1,not known,
IDE02725,Direction of rotation shaft 2,not known,
IDE02726-ENG100799,E-Pump: power supply-Voltage Supply Electric Motor,11.8, V
IDE02727-ENG99192,Shift Lock Solenoid Specified Status-Shift Lock Desired State,active,
IDE02728-ENG101668,Shift lock indicator lamp-Indicator Light Shift Lock,Indicator lamp off,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged,
IDE02738-ENG100412,Selector lever illumination-Display Shift Lighting,P,
IDE02740-ENG99750,Temperature of friction lining for clutch 1-Temperatur_Friction_Lining_Clutch_1,53, °C
IDE02741-ENG102724,Temperature of friction lining for clutch 2-Temperatur_Friction_Lining_Clutch_2,53, °C
IDE02742,Oil pressure actual value,0.21, bar
IDE02775-ENG101304,Status of basic setting data-State Of Basic Adjustmentdata,valid,
IDE02776-ENG102757,Pressure of partial transmission 1 specified value-Pressure Transmission Part 1 Commanded Value,2.50, bar
IDE02777-ENG101539,Pressure of partial transmission 1 actual value-Pressure Transmission Part 1 Actual Value,0.21, bar
IDE02779-ENG100646,Pressure of partial transmission 2 specified value-Pressure Transmission Part 2 Commanded Value,2.50, bar
IDE02780-ENG103741,Pressure of partial transmission 2 actual value-Pressure Transmission Part 2 Actual Value,0.21, bar
IDE02782-ENG103418,Current of valve for partial transmission 1 specified value-Current Valve Transmission Part 1 Commanded Value,390.7, mA
IDE02783-ENG99260,Current of valve for partial transmission 1 actual value-Current Valve Transmission Part 1 Actual Value,391.0, mA
IDE02786-ENG101222,Current of valve for partial transmission 2 specified value-Current Valve Transmission Part 2 Commanded Value,396.1, mA
IDE02787-ENG101614,Current of valve for partial transmission 2 actual value-Current Valve Transmission Part 2 Actual Value,396.0, mA
IDE02790-ENG104124,Specified torque clutch 1-Clutch 1 Commanded Torque,-100.00, Nm
IDE02791-ENG101742,Actual torque clutch 1-Clutch 1 Actual Torque,-100.00, Nm
IDE02792-ENG101464,Specified position clutch 1-Clutch 1 Commanded Position,0.00, bar
IDE02793-ENG102450,Actual position clutch 1-Clutch 1 Actual Position,0.00, bar
IDE02796-ENG103463,Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value,50.0, mA
IDE02797-ENG100730,Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value,51.0, mA
IDE02800-ENG100171,Specified torque clutch 2-Clutch 2 Commanded Torque,-100.00, Nm
IDE02802-ENG102780,Actual position clutch 2-Clutch 2 Actual Position,0.00, bar
IDE02805-ENG99237,Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value,50.0, mA
IDE02806-ENG103118,Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value,50.0, mA
IDE02820,Transmission mileage,1617.9, km
IDE02821-ENG101653,Pressure Supply Specified Pressure/Threshold 1-Pressure Supply Commanded Value Threshold 1,0.21, bar
IDE02824-ENG99279,Main status of abort code basic setting-Basic Settings Main Status,0,
IDE02825-ENG100313,Substatus of abort code basic setting-Basic Settings Sub Status,0,
IDE02827-ENG103491,Installation information steering wheel paddles-Application Info Steering Paddels,59,
IDE02828-ENG103640,Installation information brakes-Application Info Breaksystem,59,
IDE02829-ENG103127,Installation information steering column module-Application Info Steering Modul,59,
IDE02830-ENG100103,Installation information gateway-Application Info Gateway,59,
IDE02858-ENG100590,Status of basic setting data: gear selector-State Of Basic Adjustmentdata Gearpositioner,Valid basic calibration,
IDE02859-ENG99797,Status of basic setting data for clutch-State Of Basic Adjustmentdata Clutch,Valid EOL,
IDE02861-ENG103083,Mechatronic identification-Baudatum,240520,
IDE02861-ENG98675,Mechatronic identification-Construction version,N5,
IDE02861-ENG99175,Mechatronic identification-Kassel,K,
IDE02861-ENG104192,Mechatronic identification-Kennung der Mechatronik-Montagelinie,D15,
IDE02861-ENG103830,Mechatronic identification-Lfd.-Nr,7227,
IDE02861-ENG103525,Mechatronic identification-Teilenummer (3 letzten + Index),0GCH_,
IDE02862-ENG103213,Production data transmission-Aggregatekennzeichnung (Getriebe),006,
IDE02862-ENG103083,Production data transmission-Baudatum,240520,
IDE02862-ENG104019,Production data transmission-Getriebekennbuchstabe,VDK,
IDE02862-ENG99175,Production data transmission-Kassel,K,
IDE02862-ENG101707,Production data transmission-Kennung der Montagelinie,D08,
IDE02862-ENG103830,Production data transmission-Lfd.-Nr,1892,
IDE02864-ENG99505,Actual position of gear positioner A-Gearpositioner A Actual Position,-10.25, mm
IDE02865-ENG104121,AD value 1 of actual position of gear actuator A-Gearpositioner A Actual Position AD Value 1,2885,
IDE02867-ENG103746,Specified current of gear Solen.val. A-Gearpositioner A Valve Commanded Current,0.0, mA
IDE02868-ENG102455,Actual current of gear Solen.val. A-Gearpositioner A Valve Actual Current,0.0, mA
IDE02872-ENG102218,Actual position of gear adjuster B-Gearpositioner B Actual Position,-0.01, mm
IDE02873-ENG101728,AD value 1 of actual position of gear actuator B-Gearpositioner B Actual Position AD Value 1,2052,
IDE02875-ENG101174,Specified current of gear Solen.val. B-Gearpositioner B Valve Commanded Current,0.0, mA
IDE02876-ENG99266,Actual current of gear Solen.val. B-Gearpositioner B Valve Actual Current,0.0, mA
IDE02880-ENG103036,Actual position of gear positioner C-Gearpositioner C Actual Position,-0.05, mm
IDE02881-ENG99453,AD value 1 of actual position of gear actuator C-Gearpositioner C Actual Position AD Value 1,2053,
IDE02883-ENG103740,Specified current of gear Solen.val. C-Gearpositioner C Valve Commanded Current,0.0, mA
IDE02884-ENG99821,Actual current of gear Solen.val. C-Gearpositioner C Valve Actual Current,0.0, mA
IDE02888-ENG103826,Actual position of gear positioner D-Gearpositioner D Actual Position,-9.43, mm
IDE02889-ENG100525,AD value 1 of actual position of gear actuator D-Gearpositioner D Actual Position AD Value 1,1104,
IDE02891-ENG101968,Specified current of gear Solen.val. D-Gearpositioner D Valve Commanded Current,830.5, mA
IDE02892-ENG99541,Actual current of gear Solen.val. D-Gearpositioner D Valve Actual Current,831.0, mA
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03107-ENG126246,Kilometers at last basic setting-Kilometer At Last Basic Adjustment,0, km
IDE03152-ENG104154,Neutral due to driver registr. proced. cond.: cause-Driver Registration Procedure Condition Cause,00 00,
IDE03153-ENG102498,Driver logon procedure: number of activations-Driver Registration Procedure Activation Counter,1,
IDE03155-ENG99516,GE clutch data: Status-GE Clutch Data Status,Test stand data valid,
IDE03156-ENG102903,Last change to GE clutch data: odometer reading-Last Changing GE Clutch Data Km,0, km
IDE03160-ENG100046,Remaining Clutch Quick Adaptations Kiss Point-Remaining Clutch Fastadaption Kisspoint,0,
IDE03163-ENG103608,Protect. function temp. clutch 1 warn. level 1 number-Protective Function Temperature Clutch 1 Warning 1 Numbers,0,
IDE03164-ENG101576,Protect. function temp. clutch 1 warn. level 2 number-Protective Function Temperature Clutch 1 Warning 2 Numbers,0,
IDE03165-ENG102133,Protective function temp. clutch 1 protect. level 1 number-Protective Function Temperature Clutch 1 Protection 1 Numbers,0,
IDE03167-ENG102425,Protect. function temp. clutch 2 warn. level 1 number-Protective Function Temperature Clutch 2 Warning 1 Numbers,0,
IDE03168-ENG100182,Protect. function temp. clutch 2 warn. level 2 number-Protective Function Temperature Clutch 2 Warning 2 Numbers,0,
IDE03169-ENG104175,Protective function temp. clutch 2 protect. level 1 number-Protective Function Temperature Clutch 2 Protection 1 Numbers,0,
IDE03172,Driving Strategy Percentage Driving in D or S w/Cruise,0, %
IDE03173,Driving Strategy Percentage Driving in S w/o cruise,0, %
IDE03174,Driving strategy driving portions in Tiptronic,0, %
IDE03180-ENG103176,Number of standard trips-General Denominator,30,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,133,
IDE03397-ENG252486,Status of selector lever lock-Selector_lever_shiftlock_status,Selector lever lock not installed,
IDE04612-ENG101246,Clutch temperature air / splash oil-Centrifugal oil temperature,0, °C
IDE05303-ENG99893,Actual torque clutch 2-Clutch 2 Actual Torque,-100.00, Nm
IDE05987-ENG110524,Engine stop prohibitions-Basic setting,not active,
IDE05987-ENG159578,Engine stop prohibitions-Demontagestellung,not active,
IDE05987-ENG159577,Engine stop prohibitions-Drucksensorausfall,not active,
IDE05987-ENG159579,Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE05987-ENG110508,Engine stop prohibitions-km-Stand des letzten Stoppverbots,0.0, km
IDE05987-ENG159710,Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote,0,
IDE05987-ENG110525,Engine stop prohibitions-Stop prohibition via application,not active,
IDE05987-ENG159576,Engine stop prohibitions-Temperaturbedingung,not active,
IDE05987-ENG122385,Engine stop prohibitions-unsortierte Gangsteller im Stand,not active,
IDE05988-ENG110505,Pressure of clutch 2: actual value-Clutch_2_actual_value,0.00, bar
IDE05989-ENG110503,Pressure of clutch 1: actual value-Clutch_1_actual_value,0.01, bar
IDE05990-ENG110506,Pressure of clutch 2: specified value-Clutch_2_commanded_value,0.00, bar
IDE05991-ENG110504,Pressure of clutch 1: specified value-Clutch_1_commanded_value,0.00, bar
IDE06241-ENG120892,Uneven road surface recognition: total driving portion-Drivingpart_of_roug_road_detection_total,0.0, %
IDE06243-ENG120894,Longest active distance with uneven road surface recognition-Longest_active_mileage_of_rough_road_detection,0, km
IDE06425,Dynamometer mode: functional,not activated,
IDE10300-ENG252451,OBD Driving Cycle detected-OBD_Driving_Cycle_set_once,not active,
IDE11135-ENG127823,Capacity protection function: clutch 2 number-Protective_Function_Capacity_Clutch_2_Numbers,0,
IDE11136-ENG127822,Capacity protection function: clutch 1 number-Protective_Function_Capacity_Clutch_1_Numbers,0,
IDE12712-ENG167245,Mileage at last initialization clutch friction coefficient model-Mileage of setting resetting gearbox mileage,0.0, km
IDE12713-ENG167207,Clutch friction coefficient model mileage-Gearbox mileage,1617.9, km
IDE13738-ENG167750,Function test auxiliary hydraulic pump for transmission oil status-Cancellation reason,Do not cancel,
IDE13738-ENG167870,Function test auxiliary hydraulic pump for transmission oil status-Hauptdruck,0.00, bar
IDE13738-ENG101241,Function test auxiliary hydraulic pump for transmission oil status-Speed,0, /min
IDE13947-ENG167877,Mileage since last activation: uneven road surface recognition-Kilometer_at_last_ activation_rough_road_detection,655340, km
IDE14615-MAS18568,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 1,-10.52, mm
IDE14615-MAS18569,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 2,-10.63, mm
IDE14615-MAS18570,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 3,10.64, mm
IDE14615-MAS18571,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 4,9.54, mm
IDE14615-MAS18572,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 5,9.11, mm
IDE14615-MAS18573,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 6,8.74, mm
IDE14615-MAS18574,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 7,-9.01, mm
IDE14615-MAS18575,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear R,-9.91, mm
IDE14616-MAS18576,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 1,-3.07, mm
IDE14616-MAS18577,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 2,-2.57, mm
IDE14616-MAS18578,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 3,2.07, mm
IDE14616-MAS18579,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 4,1.95, mm
IDE14616-MAS18580,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 5,1.68, mm
IDE14616-MAS18581,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 6,1.70, mm
IDE14616-MAS18582,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 7,-1.48, mm
IDE14616-MAS18583,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear R,-1.78, mm
IDE14617-MAS18584,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator A,-0.31, mm
IDE14617-MAS18585,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator B,-0.19, mm
IDE14617-MAS18586,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator C,-0.03, mm
IDE14617-MAS18587,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator D,-0.01, mm
IDE14962-MAS00966,Selector lever data-Manufacturer index location,KM7-MK1,
IDE14962-MAS00968,Selector lever data-Day of manufacture,23.04.24,
IDE14962-MAS00969,Selector lever data-Manufacturer- test stand number,2446,
IDE14962-MAS00970,Selector lever data-Running manufacturer number,429B,
IDE14962-MAS12659,Selector lever data-VW/Audi part numbers of sub-bus users,5WA713041L ,
IDE14962-MAS12660,Selector lever data-Hardware version number of sub-bus users,H04,
IDE14962-MAS12661,Selector lever data-Software version number of sub-bus users,0016,
IDE14962-MAS12662,Selector lever data-Hardware part number of sub-bus users,5WA713041  ,
IDE14962-MAS12663,Selector lever data-Series number of sub-bus users,YB075XDN1429B       ,
IDE14962-MAS13422,Selector lever data-System description of sub bus participant,SB_mono      ,
IDE15365-ENG252483,Selector lever: driver's intended gear selection-Selector_lever_driver_command_of_driving_position,Not operated,
IDE15366-ENG252485,Selector lever P button status-Selector_lever_P_button_status,Not operated,
IDE15368-ENG252487,Selector lever unlock button status-Selector_lever_unlock_key_status,not installed,
IDE15370-ENG252481,Electrical parking lock raw value position-Parking_lock_actuator_raw_position,3, %
IDE15371-ENG252477,Electrical parking lock: current power consumption-Parking_lock_actuator_actual_current_consumption,0.0, A
IDE15372-ENG252479,Electrical parking lock position-Parking_lock_actuator_position,P selected,
IDE15408-ENG252484,Selector lever holding magnet status-Selector_lever_holding_magnet_status,stops,
IDE15409-ENG252478,Electrical parking lock output stage temperature-Parking_lock_actuator_output_stage_temperature,29, °C
IDE15410-ENG252480,Q-bit electrical parking lock-Parking_lock_actuator_qualification_bit,valid value,
IDE15411-ENG252488,Selector lever variant-Selector_lever_variant,Monostable 2x2 roller segment,
IDE15412-ENG252482,Electrical parking lock voltage-Parking_lock_actuator_voltage,12, V
IDE15789-ENG255239,Seed allocation-Provided_seed_value,0F 9B 76 5A,
IDE80001-ENG100467,Analysis 1-Snapshot 1 Failure ID,65535,
IDE80002-ENG102386,Analysis 2-Snapshot 1 Mileage,0, km
IDE80003-ENG101467,Analysis 3-Snapshot 1 Counter,0,
IDE80004-ENG110548,Analysis 4-Snapshot 1 Oil Pressure Actual Value,-10.0, bar
IDE80005-ENG103330,Analysis 5-Snapshot 1 Shift Position Plausible,P,
IDE80006-ENG99650,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80006-ENG102000,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80007-ENG101090,Analysis 7-Snapshot 1  Commanded Gear,GANG N,
IDE80008-ENG100048,Analysis 8-Snapshot 1 Preselection Gear,GANG N,
IDE80009-ENG102100,Analysis 9-Snapshot 1 Transmission Input Speed,0, /min
IDE80010-ENG101565,Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1,0, /min
IDE80011-ENG100379,Analysis 11-Snapshot 1 Transmission Speed Shaft 1,0, /min
IDE80012-ENG103459,Analysis 12-Snapshot 1 Transmission Speed Shaft 2,0, /min
IDE80013-ENG264658,Analysis 13-Snapshot 1 Gearpositioner A Actual Position,-20.48, mm
IDE80014-ENG264659,Analysis 14-Snapshot 1 Gearpositioner B Actual Position,-20.48, mm
IDE80015-ENG264660,Analysis 15-Snapshot 1 Gearpositioner C Actual Position,-20.48, mm
IDE80016-ENG264661,Analysis 16-Snapshot 1 Gearpositioner D Actual Position,-20.48, mm
IDE80017-ENG99158,Analysis 17-Snapshot 1 Gearpositioner A Valve Actual Current,0, mA
IDE80018-ENG101917,Analysis 18-Snapshot 1 Gearpositioner B Valve Actual Current,0, mA
IDE80019-ENG102153,Analysis 19-Snapshot 1 Gearpositioner C Valve Actual Current,0, mA
IDE80020-ENG100002,Analysis 20-Snapshot 1 Gearpositioner D Valve Actual Current,0, mA
IDE80021-ENG102762,Analysis 21-Snapshot 1 Clutch 1 Actual Pressure,0.0, bar
IDE80022-ENG100347,Analysis 22-Snapshot 1 Clutch 2 Actual Pressure,0.0, bar
IDE80023-ENG99119,Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value,0, mA
IDE80024-ENG101123,Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value,0, mA
IDE80025-ENG103611,Analysis 25-Snapshot 1 Accelerator Pedal Position,0.0, %
IDE80026-ENG101503,Analysis 26-Snapshot 1 Engine torque,-50, Nm
IDE80027-ENG101521,Analysis 27-Snapshot 1 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80028-ENG103949,Analysis 28-Snapshot 1 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80029-ENG103070,Analysis 29-Snapshot 1 Voltage Terminal 15,0.0, V
IDE80030-ENG101050,Analysis 30-Snapshot 1 Voltage Supply Electric Motor,0.0, V
IDE80031-ENG102899,Analysis 31-Snapshot 1 Transmission Fluid Temperature,-60, °C
IDE80032-ENG99872,Analysis 32-Snapshot 1 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80033-ENG103098,Analysis 33-Snapshot 2 Failure ID,233,
IDE80034-ENG101047,Analysis 34-Snapshot 2 Mileage,0, km
IDE80035-ENG99915,Analysis 35-Snapshot 2 Counter,1,
IDE80036-ENG110549,Analysis 36-Snapshot 2 Oil Pressure Actual Value,0.0, bar
IDE80037-ENG99369,Analysis 37-Snapshot 2 Shift Position Plausible,P,
IDE80038-ENG99350,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Fahrzeugzustand,SYSTEM_RUNTER,
IDE80038-ENG102372,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Kupplungshauptzustand,Neutral,
IDE80039-ENG101369,Analysis 39-Snapshot 2  Commanded Gear,GANG_1,
IDE80040-ENG103638,Analysis 40-Snapshot 2 Preselection Gear,GANG N,
IDE80041-ENG103367,Analysis 41-Snapshot 2 Transmission Input Speed,192, /min
IDE80042-ENG102476,Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1,0, /min
IDE80043-ENG102699,Analysis 43-Snapshot 2 Transmission Speed Shaft 1,0, /min
IDE80044-ENG101900,Analysis 44-Snapshot 2 Transmission Speed Shaft 2,192, /min
IDE80045-ENG100935,Analysis 45-Snapshot 2 Gearpositioner A Actual Position,-10.24, mm
IDE80046-ENG102046,Analysis 46-Snapshot 2 Gearpositioner B Actual Position,0.00, mm
IDE80047-ENG100712,Analysis 47-Snapshot 2 Gearpositioner C Actual Position,0.00, mm
IDE80048-ENG101670,Analysis 48-Snapshot 2 Gearpositioner D Actual Position,0.00, mm
IDE80049-ENG102288,Analysis 49-Snapshot 2 Gearpositioner A Valve Actual Current,0, mA
IDE80050-ENG103952,Analysis 50-Snapshot 2 Gearpositioner B Valve Actual Current,0, mA
IDE80051-ENG99664,Analysis 51-Snapshot 2 Gearpositioner C Valve Actual Current,0, mA
IDE80052-ENG100255,Analysis 52-Snapshot 2 Gearpositioner D Valve Actual Current,0, mA
IDE80053-ENG102973,Analysis 53-Snapshot 2 Clutch 1 Actual Pressure,0.0, bar
IDE80054-ENG100122,Analysis 54-Snapshot 2 Clutch 2 Actual Pressure,0.0, bar
IDE80055-ENG103189,Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value,0, mA
IDE80056-ENG103616,Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value,0, mA
IDE80057-ENG102447,Analysis 57-Snapshot 2 Accelerator Pedal Position,0.0, %
IDE80058-ENG103198,Analysis 58-Snapshot 2 Engine torque,-32, Nm
IDE80059-ENG100322,Analysis 59-Snapshot 2 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80060-ENG99335,Analysis 60-Snapshot 2 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80061-ENG101449,Analysis 61-Snapshot 2 Voltage Terminal 15,0.0, V
IDE80062-ENG99916,Analysis 62-Snapshot 2 Voltage Supply Electric Motor,12.2, V
IDE80063-ENG104157,Analysis 63-Snapshot 2 Transmission Fluid Temperature,25, °C
IDE80064-ENG101948,Analysis 64-Snapshot 2 Maximum Temperature Clutch 1 Clutch 2,34, °C
IDE80071-ENG127839,Analysis 71-FID event memory entry 1,65535,
IDE80071-ENG127848,Analysis 71-FID event memory entry 10,65535,
IDE80071-ENG127849,Analysis 71-FID event memory entry 11,65535,
IDE80071-ENG127850,Analysis 71-FID event memory entry 12,65535,
IDE80071-ENG127840,Analysis 71-FID event memory entry 2,65535,
IDE80071-ENG127841,Analysis 71-FID event memory entry 3,65535,
IDE80071-ENG127842,Analysis 71-FID event memory entry 4,65535,
IDE80071-ENG127843,Analysis 71-FID event memory entry 5,65535,
IDE80071-ENG127844,Analysis 71-FID event memory entry 6,65535,
IDE80071-ENG127845,Analysis 71-FID event memory entry 7,65535,
IDE80071-ENG127846,Analysis 71-FID event memory entry 8,65535,
IDE80071-ENG127847,Analysis 71-FID event memory entry 9,65535,
IDE80072-ENG127830,Analysis 72-Temperature hybrid time in range 0,0.0, s
IDE80073-ENG127869,Analysis 73-Temperature hybrid time in range 1,53474.1, s
IDE80074-ENG127870,Analysis 74-Temperature hybrid time in range 2,78764.3, s
IDE80075-ENG127871,Analysis 75-Temperature hybrid time in range 3,1836.4, s
IDE80076-ENG127872,Analysis 76-Temperature hybrid time in range 4,0.0, s
IDE80077-ENG127873,Analysis 77-Temperature hybrid time in range 5,0.0, s
IDE80080-ENG127878,Analysis 80-Temperature hybrid maximum,102, °C
IDE80081-ENG114824,Analysis 81-Clutch 1 temperature time in range 0,60489.8, s
IDE80082-ENG114820,Analysis 82-Clutch 1 temperature time in range 1,72727.1, s
IDE80083-ENG114814,Analysis 83-Clutch 1 temperature time in range 2,849.1, s
IDE80084-ENG114813,Analysis 84-Clutch 1 temperature time in range 3,9.3, s
IDE80088-ENG111618,Analysis 88-Clutch 1 temperature maximum,158, °C
IDE80089-ENG114807,Analysis 89-Clutch 2 temperature time in range 0,68635.3, s
IDE80090-ENG114811,Analysis 90-Clutch 2 temperature time in range 1,65225.0, s
IDE80091-ENG114805,Analysis 91-Clutch 2 temperature time in range 2,203.5, s
IDE80092-ENG114817,Analysis 92-Clutch 2 temperature time in range 3,11.8, s
IDE80096-ENG111619,Analysis 96-Clutch 2 temperature maximum,170, °C
IDE80101-ENG102219,Analysis 101-Betriebszeit Motor (Drehzahlbereich 1),20.1, H
IDE80101-ENG103682,Analysis 101-Betriebszeit Motor (Drehzahlbereich 2),7.1, H
IDE80101-ENG101200,Analysis 101-Betriebszeit Motor (Drehzahlbereich 3),0.4, H
IDE80101-ENG100226,Analysis 101-Betriebszeit Motor (Drehzahlbereich 4),0.2, H
IDE80101-ENG102223,Analysis 101-Betriebszeit Motor (Drehzahlbereich 5),0.0, H
IDE80102-ENG102381,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 1-Gang,731,
IDE80102-ENG99964,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 2-Gang,1250,
IDE80102-ENG100231,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 3-Gang,2118,
IDE80102-ENG104160,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 4-Gang,2068,
IDE80102-ENG102663,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 5-Gang,1727,
IDE80102-ENG99465,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 6-Gang,1237,
IDE80102-ENG103205,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 7-Gang,582,
IDE80102-ENG103678,Analysis 102-Anzahl erfolgreiche Einlegevorgänge R-Gang,227,
IDE80103-ENG103574,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 1-Gang,0,
IDE80103-ENG103754,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 2-Gang,0,
IDE80103-ENG99560,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 3-Gang,0,
IDE80103-ENG101116,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 4-Gang,0,
IDE80103-ENG99083,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 5-Gang,0,
IDE80103-ENG99508,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 6-Gang,0,
IDE80103-ENG101966,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 7-Gang,0,
IDE80103-ENG103519,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge R-Gang,0,
IDE80104-ENG100464,Analysis 104-Anzahl Gangspringer 1-Gang,0,
IDE80104-ENG103518,Analysis 104-Anzahl Gangspringer 2-Gang,0,
IDE80104-ENG101484,Analysis 104-Anzahl Gangspringer 3-Gang,0,
IDE80104-ENG102434,Analysis 104-Anzahl Gangspringer 4-Gang,0,
IDE80104-ENG100828,Analysis 104-Anzahl Gangspringer 5-Gang,0,
IDE80104-ENG99747,Analysis 104-Anzahl Gangspringer 6-Gang,0,
IDE80104-ENG102967,Analysis 104-Anzahl Gangspringer 7-Gang,0,
IDE80104-ENG100893,Analysis 104-Anzahl Gangspringer R-Gang,0,
IDE80105-ENG100707,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 1),16.8, H
IDE80105-ENG101697,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 2),20.2, H
IDE80105-ENG100556,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 3),0.2, H
IDE80105-ENG100205,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 4),0.0, H
IDE80106-ENG103428,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 1),19.1, H
IDE80106-ENG101321,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 2),18.1, H
IDE80106-ENG100639,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 3),0.1, H
IDE80106-ENG103433,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 4),0.0, H
IDE80107-ENG101291,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 1),5.5, H
IDE80107-ENG104169,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 2),3.7, H
IDE80107-ENG100021,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 3),0.4, H
IDE80107-ENG101292,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 4),0.0, H
IDE80107-ENG99418,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 5),0.0, H
IDE80108-ENG99240,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 1),3.3, H
IDE80108-ENG99973,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 2),1.6, H
IDE80108-ENG103238,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 3),0.3, H
IDE80108-ENG101007,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 4),0.0, H
IDE80108-ENG101190,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 5),0.0, H
IDE80117-MAS02330,Analysis 117-SPECIFIED condition,OFF,
IDE80117-MAS02331,Analysis 117-ACTUAL condition,OFF,
IDE80118-ENG167269,Analysis 118-Snapshot 1 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80119-ENG167272,Analysis 119-Snapshot 1 auxiliary transmission fluid pump motor electronics temperature,-40, °C
IDE80120-ENG167271,Analysis 120-Snapshot 1 auxiliary transmission fluid pump motor current,0, mA
IDE80121-ENG161275,Analysis 121-GOP current limitation failure status,OFF,
IDE80121-ENG161276,Analysis 121-GOP rotor position sensor failure status,OFF,
IDE80122-ENG167275,Analysis 122-Snapshot 1 auxiliary transmission fluid pump motor voltage terminal 30,0.0, V
IDE80123-ENG167270,Analysis 123-Snapshot 1 auxiliary transmission fluid pump motor commanded speed demand estimation,0, /min
IDE80124-ENG167273,Analysis 124-Snapshot 1 auxiliary transmission fluid pump motor oil pressure,0.00, bar
IDE80125-MAS02330,Analysis 125-SPECIFIED condition,OFF,
IDE80125-MAS02331,Analysis 125-ACTUAL condition,OFF,
IDE80126-ENG167276,Analysis 126-Snapshot 2 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80127-ENG167278,Analysis 127-Snapshot 2 auxiliary transmission fluid pump motor electronics temperature,24, °C
IDE80128-ENG167277,Analysis 128-Snapshot 2 auxiliary transmission fluid pump motor current,0, mA
IDE80129-ENG161275,Analysis 129-GOP current limitation failure status,OFF,
IDE80129-ENG161276,Analysis 129-GOP rotor position sensor failure status,OFF,
IDE80130-ENG167280,Analysis 130-Snapshot 2 auxiliary transmission fluid pump motor voltage terminal 30,12.5, V
IDE80131-ENG167276,Analysis 131-Snapshot 2 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80132-ENG167279,Analysis 132-Snapshot 2 auxiliary transmission fluid pump motor oil pressure,0.00, bar
IDE80133-ENG167274,Analysis 133-Snapshot 1 auxiliary transmission fluid pump motor valve actual current,0, mA
IDE80134-ENG167274,Analysis 134-Snapshot 1 auxiliary transmission fluid pump motor valve actual current,0, mA
IDE80137-ENG167891,Analysis 137-Mode A FID event memory entry 1,65535,
IDE80137-ENG167892,Analysis 137-Mode A FID event memory entry 2,65535,
IDE80137-ENG167893,Analysis 137-Mode A FID event memory entry 3,65535,
IDE80137-ENG167894,Analysis 137-Mode A FID event memory entry 4,65535,
IDE80276-ENG127854,Current vehicle odometer reading-Current vehicle mileage,1626, km
IDE80277-ENG127828,Neutral due to driver's workplace oper: veh odom.read.-Driver registration procedure condition vehicle mileage,0, km
IDE80278-ENG127882,Driver logon procedure: vehicle odometer reading-Driver registration procedure vehicle mileage,1300, km
IDE80279-ENG127826,Driver logon procedure: cause-Driver registration procedure cause,512,
IDE80280-ENG127827,Driver logon procedure: wave-Driver registration procedure shaft,0,
IDE80282-ENG114823,Clutch 1 Adaption basic charac. point 0 moment-Clutch 1 adaption basic characteristic point 0 torque,0.0, Nm
IDE80283-ENG114819,Clutch 1 Adaption basic charac. point 1 moment-Clutch 1 adaption basic characteristic point 1 torque,100.0, Nm
IDE80284-ENG114822,Clutch 1 Adaption basic charac. point 2 moment-Clutch 1 adaption basic characteristic point 2 torque,420.0, Nm
IDE80285-ENG114815,Clutch 1 Adaption basic charac. point 3 moment-Clutch 1 adaption basic characteristic point 3 torque,500.0, Nm
IDE80287-ENG127832,Clutch 1 Friction value correction factor-Clutch 1 frictional correction factor,100.0, %
IDE80288-ENG114818,Clutch 1 Characteristic line shift-Clutch 1 characteristic shift,0.00, mm
IDE80289-ENG114806,Clutch 2 Adaption basic charac. point 0 moment-Clutch 2 adaption basic characteristic point 0 torque,0.0, Nm
IDE80290-ENG114810,Clutch 2 Adaption basic charac. point 1 moment-Clutch 2 adaption basic characteristic point 1 torque,100.0, Nm
IDE80291-ENG114821,Clutch 2 Adaption basic charac. point 2 moment-Clutch 2 adaption basic characteristic point 2 torque,420.0, Nm
IDE80292-ENG114809,Clutch 2 Adaption basic charac. point 3 moment-Clutch 2 adaption basic characteristic point 3 torque,500.0, Nm
IDE80294-ENG127876,Clutch 2 Friction value correction factor-Clutch 2 frictional correction factor,100.0, %
IDE80295-ENG114808,Clutch 2 Characteristic line shift-Clutch 2 characteristic shift,0.00, mm
IDE80296-ENG127853,Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter,27,
IDE80297-ENG127883,Clutch 1 Adaption kiss point part 1: vehicle odometer reading-Clutch 1 adaption part 1 vehicle mileage,1610, km
IDE80298-ENG127880,Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter,51,
IDE80299-ENG127884,Clutch 2 Adaption kiss point part 1: vehicle odometer reading-Clutch 2 adaption part 1 vehicle mileage,1620, km
IDE80303-ENG127833,Overall software description-Software full name,L41,
IDE80305-ENG125922,Parameter set description-Data set name,FL_0GC906556D_4161_JV1VDK,
IDE80307-ENG127879,Clutch 1 Adaption kiss point part 1: remaining fast adaptations-Clutch 1 adaption part 1 remaining fastadaptions,0,
IDE80308-ENG127881,Clutch 2 Adaption kiss point part 1: remaining fast adaptations-Clutch 2 adaption part 1 remaining fastadaptions,0,
ENG102069,Accelerator Pedal Position D,14.9, %
ENG98625-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,OK,
ENG100091,Ambient temperature,15, °C
ENG157549,Anzahl Launch Control Anfahrt,0,
ENG157501-ENG130284,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157501-ENG130285,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157501-ENG130286,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157501-ENG130287,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157501-ENG161272,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 1,00 00 00 00,
ENG157501-ENG167224,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 2,0,
ENG157501-ENG167225,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 3,0,
ENG157501-ENG161273,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 4,0,
ENG157501-ENG161274,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 5,0,
ENG157501-ENG167226,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 6,0,
ENG157501-ENG130283,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Gesamt-Software-Version,
ENG157501-ENG160009,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Häufigkeit,0,
ENG157501-ENG130295,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 15-Spannung,51.0, V
ENG157501-ENG130296,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 30-Spannung,51.0, V
ENG157501-ENG130297,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Mechatroniktemperatur,215, °C
ENG157501-ENG98689,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Odometer reading,655350, km
ENG157501-ENG130291,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Quelle,0,
ENG157501-ENG112343,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Status,0,
ENG157501-ENG130293,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Typ,0,
ENG157501-ENG130300,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Status des Eintrags,FF,
ENG157501-ENG130299,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157502-ENG130284,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157502-ENG130285,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157502-ENG130286,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157502-ENG130287,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157502-ENG161272,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 1,00 00 00 00,
ENG157502-ENG167224,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 2,0,
ENG157502-ENG167225,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 3,0,
ENG157502-ENG161273,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 4,0,
ENG157502-ENG161274,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 5,0,
ENG157502-ENG167226,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 6,0,
ENG157502-ENG130283,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Gesamt-Software-Version,
ENG157502-ENG160009,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Häufigkeit,0,
ENG157502-ENG130295,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 15-Spannung,51.0, V
ENG157502-ENG130296,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 30-Spannung,51.0, V
ENG157502-ENG130297,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Mechatroniktemperatur,215, °C
ENG157502-ENG98689,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Odometer reading,655350, km
ENG157502-ENG130291,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Quelle,0,
ENG157502-ENG112343,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Status,0,
ENG157502-ENG130293,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Typ,0,
ENG157502-ENG130300,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Status des Eintrags,FF,
ENG157502-ENG130299,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157503-ENG130284,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157503-ENG130285,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157503-ENG130286,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157503-ENG130287,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157503-ENG161272,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 1,00 00 00 00,
ENG157503-ENG167224,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 2,0,
ENG157503-ENG167225,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 3,0,
ENG157503-ENG161273,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 4,0,
ENG157503-ENG161274,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 5,0,
ENG157503-ENG167226,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 6,0,
ENG157503-ENG130283,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Gesamt-Software-Version,
ENG157503-ENG160009,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Häufigkeit,0,
ENG157503-ENG130295,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 15-Spannung,51.0, V
ENG157503-ENG130296,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 30-Spannung,51.0, V
ENG157503-ENG130297,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Mechatroniktemperatur,215, °C
ENG157503-ENG98689,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Odometer reading,655350, km
ENG157503-ENG130291,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Quelle,0,
ENG157503-ENG112343,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Status,0,
ENG157503-ENG130293,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Typ,0,
ENG157503-ENG130300,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Status des Eintrags,FF,
ENG157503-ENG130299,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157504-ENG130284,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157504-ENG130285,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157504-ENG130286,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157504-ENG130287,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157504-ENG161272,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 1,00 00 00 00,
ENG157504-ENG167224,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 2,0,
ENG157504-ENG167225,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 3,0,
ENG157504-ENG161273,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 4,0,
ENG157504-ENG161274,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 5,0,
ENG157504-ENG167226,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 6,0,
ENG157504-ENG130283,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Gesamt-Software-Version,
ENG157504-ENG160009,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Häufigkeit,0,
ENG157504-ENG130295,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 15-Spannung,51.0, V
ENG157504-ENG130296,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 30-Spannung,51.0, V
ENG157504-ENG130297,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Mechatroniktemperatur,215, °C
ENG157504-ENG98689,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Odometer reading,655350, km
ENG157504-ENG130291,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Quelle,0,
ENG157504-ENG112343,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Status,0,
ENG157504-ENG130293,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Typ,0,
ENG157504-ENG130300,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Status des Eintrags,FF,
ENG157504-ENG130299,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157505-ENG130284,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157505-ENG130285,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157505-ENG130286,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157505-ENG130287,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157505-ENG161272,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 1,00 00 00 00,
ENG157505-ENG167224,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 2,0,
ENG157505-ENG167225,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 3,0,
ENG157505-ENG161273,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 4,0,
ENG157505-ENG161274,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 5,0,
ENG157505-ENG167226,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 6,0,
ENG157505-ENG130283,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Gesamt-Software-Version,
ENG157505-ENG160009,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Häufigkeit,0,
ENG157505-ENG130295,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 15-Spannung,51.0, V
ENG157505-ENG130296,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 30-Spannung,51.0, V
ENG157505-ENG130297,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Mechatroniktemperatur,215, °C
ENG157505-ENG98689,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Odometer reading,655350, km
ENG157505-ENG130291,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Quelle,0,
ENG157505-ENG112343,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Status,0,
ENG157505-ENG130293,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Typ,0,
ENG157505-ENG130300,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Status des Eintrags,FF,
ENG157505-ENG130299,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Uds-Lesestatus des Eintrages,1,
ENG101413,Calibration Identifications,0GC906556D++4161,
ENG103147,Calibration Verification Numbers (checksum),0A 54 78 24,
ENG99187,CAN version,0,
ENG98482-ENG99180,Checksum of flash-Calibration Checksumme,AA F1 E5 0F,
ENG98482-ENG100495,Checksum of flash-Cboot Checksumme,31 4F 7D 3D,
ENG98482-ENG100117,Checksum of flash-Checksumme ECU + CAL,0A 54 78 24,
ENG98482-ENG102221,Checksum of flash-ECU Checksumme,5F 62 93 15,
ENG101012,Clutch 1 adaption basic characteristic point 0 position,2.48, bar
ENG102187,Clutch 1 adaption basic characteristic point 1 position,4.44, bar
ENG99501,Clutch 1 adaption basic characteristic point 2 position,11.77, bar
ENG99792,Clutch 1 adaption basic characteristic point 3 position,14.00, bar
ENG103827,Clutch 1 adaption basic characteristic range 1 quick adaptions remaining km,0, km
ENG99333,Clutch 1 adaption basic characteristic range 2 quick adaptions remaining km,0, km
ENG102537,Clutch 1 adaption basic characteristic range 3 quick adaptions remaining km,0, km
ENG110529,Clutch 1 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110528,Clutch 1 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110530,Clutch 1 adaption kiss point part 1 fault counter,0,
ENG104250,Clutch 2 adaption basic characteristic point 0 position,2.54, bar
ENG100941,Clutch 2 adaption basic characteristic point 1 position,4.44, bar
ENG99957,Clutch 2 adaption basic characteristic point 2 position,11.75, bar
ENG99481,Clutch 2 adaption basic characteristic point 3 position,14.00, bar
ENG102732,Clutch 2 adaption basic characteristic range 1 quick adaptions remaining km,0, km
ENG101931,Clutch 2 adaption basic characteristic range 2 quick adaptions remaining km,0, km
ENG100136,Clutch 2 adaption basic characteristic range 3 quick adaptions remaining km,0, km
ENG110535,Clutch 2 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110534,Clutch 2 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110536,Clutch 2 adaption kiss point part 1 fault counter,0,
ENG102882,Clutch adaptation kiss-point fast adaptation remaining km tr,0, km
ENG103186,Clutch center central plate temperature,53, °C
ENG107241-ENG103334,Coefficient vmd_k_Clutch_1C0-Koeffizient,43.721,
ENG107242-ENG103334,Coefficient vmd_k_Clutch_1C1-Koeffizient,67.671,
ENG107243-ENG103334,Coefficient vmd_k_Clutch_1C2-Koeffizient,-50.845,
ENG107244-ENG103334,Coefficient vmd_k_Clutch_1C3-Koeffizient,43.344,
ENG107245-ENG103334,Coefficient vmd_k_Clutch_2C0-Koeffizient,56.006,
ENG107246-ENG103334,Coefficient vmd_k_Clutch_2C1-Koeffizient,67.552,
ENG107247-ENG103334,Coefficient vmd_k_Clutch_2C2-Koeffizient,-68.677,
ENG107248-ENG103334,Coefficient vmd_k_Clutch_2C3-Koeffizient,41.994,
ENG107249-ENG103334,Coefficient vmd_k_Cool_C0-Koeffizient,790.313,
ENG107250-ENG103334,Coefficient vmd_k_Cool_C1-Koeffizient,306.434,
ENG107251-ENG103334,Coefficient vmd_k_Cool_C2-Koeffizient,0.366,
ENG107252-ENG103334,Coefficient vmd_k_Cool_C3-Koeffizient,-20.929,
ENG107253-ENG103334,Coefficient vmd_k_Cool_C4-Koeffizient,-1.506,
ENG107254-ENG103334,Coefficient vmd_k_Cool_Qmax-Koeffizient,25.477,
ENG107255-ENG103334,Coefficient vmd_k_CutOff_ OddC0-Koeffizient,144.573,
ENG107256-ENG103334,Coefficient vmd_k_CutOff_ OddC1-Koeffizient,-0.082,
ENG107257-ENG103334,Coefficient vmd_k_CutOff_ OddC2-Koeffizient,22.314,
ENG107258-ENG103334,Coefficient vmd_k_CutOff_Even_C0-Koeffizient,204.484,
ENG107259-ENG103334,Coefficient vmd_k_CutOff_Even_C1-Koeffizient,-0.098,
ENG107260-ENG103334,Coefficient vmd_k_CutOff_Even_C2-Koeffizient,37.805,
ENG107261-ENG103334,Coefficient vmd_k_CutOff_Even_C3-Koeffizient,0.095,
ENG107262-ENG103334,Coefficient vmd_k_CutOff_Even_C4-Koeffizient,18.208,
ENG107263-ENG103334,Coefficient vmd_k_CutOff_OddC3-Koeffizient,0.360,
ENG107264-ENG103334,Coefficient vmd_k_CutOff_OddC4-Koeffizient,74.305,
ENG107265-ENG103334,Coefficient vmd_k_FlwC0_Even_ABw-Koeffizient,732.326,
ENG107266-ENG103334,Coefficient vmd_k_FlwC0_Even_AFw-Koeffizient,929.883,
ENG107267-ENG103334,Coefficient vmd_k_FlwC0_Even_BBw-Koeffizient,697.358,
ENG107268-ENG103334,Coefficient vmd_k_FlwC0_Even_BFw-Koeffizient,930.944,
ENG107269-ENG103334,Coefficient vmd_k_FlwC0_OddABw-Koeffizient,743.779,
ENG107270-ENG103334,Coefficient vmd_k_FlwC0_OddAFw-Koeffizient,895.944,
ENG107271-ENG103334,Coefficient vmd_k_FlwC0_OddBBw-Koeffizient,716.848,
ENG107272-ENG103334,Coefficient vmd_k_FlwC0_OddBFw-Koeffizient,936.904,
ENG107273-ENG103334,Coefficient vmd_k_FlwC1_Even_ABw-Koeffizient,31.814,
ENG107274-ENG103334,Coefficient vmd_k_FlwC1_Even_AFw-Koeffizient,61.766,
ENG107275-ENG103334,Coefficient vmd_k_FlwC1_Even_BBw-Koeffizient,45.219,
ENG107276-ENG103334,Coefficient vmd_k_FlwC1_Even_BFw-Koeffizient,59.344,
ENG107277-ENG103334,Coefficient vmd_k_FlwC1_OddABw-Koeffizient,25.934,
ENG107278-ENG103334,Coefficient vmd_k_FlwC1_OddAFw-Koeffizient,46.909,
ENG107279-ENG103334,Coefficient vmd_k_FlwC1_OddBBw-Koeffizient,36.058,
ENG107280-ENG103334,Coefficient vmd_k_FlwC1_OddBFw-Koeffizient,63.641,
ENG107281-ENG103334,Coefficient vmd_k_FlwC2_Even_ABw-Koeffizient,9.316,
ENG107282-ENG103334,Coefficient vmd_k_FlwC2_Even_AFw-Koeffizient,8.190,
ENG107283-ENG103334,Coefficient vmd_k_FlwC2_Even_BBw-Koeffizient,16.305,
ENG107284-ENG103334,Coefficient vmd_k_FlwC2_Even_BFw-Koeffizient,8.425,
ENG107285-ENG103334,Coefficient vmd_k_FlwC2_OddABw-Koeffizient,10.686,
ENG107286-ENG103334,Coefficient vmd_k_FlwC2_OddAFw-Koeffizient,7.125,
ENG107287-ENG103334,Coefficient vmd_k_FlwC2_OddBBw-Koeffizient,10.816,
ENG107288-ENG103334,Coefficient vmd_k_FlwC2_OddBFw-Koeffizient,13.862,
ENG107289-ENG103334,Coefficient vmd_k_FlwC3_Even_ABw-Koeffizient,-24.716,
ENG107290-ENG103334,Coefficient vmd_k_FlwC3_Even_AFw-Koeffizient,-0.312,
ENG107291-ENG103334,Coefficient vmd_k_FlwC3_Even_BBw-Koeffizient,11.673,
ENG107292-ENG103334,Coefficient vmd_k_FlwC3_Even_BFw-Koeffizient,6.741,
ENG107293-ENG103334,Coefficient vmd_k_FlwC3_OddABw-Koeffizient,-44.746,
ENG107294-ENG103334,Coefficient vmd_k_FlwC3_OddAFw-Koeffizient,38.481,
ENG107295-ENG103334,Coefficient vmd_k_FlwC3_OddBBw-Koeffizient,-9.996,
ENG107296-ENG103334,Coefficient vmd_k_FlwC3_OddBFw-Koeffizient,-21.416,
ENG107297-ENG103334,Coefficient vmd_k_Line_C0-Koeffizient,-5.136,
ENG107298-ENG103334,Coefficient vmd_k_Line_C1-Koeffizient,1163.865,
ENG107299-ENG103334,Coefficient vmd_k_Line_C2-Koeffizient,-40.344,
ENG107300-ENG103334,Coefficient vmd_k_Line_C3-Koeffizient,0.020,
ENG107301-ENG103334,Coefficient vmd_k_Line_C4-Koeffizient,1.000,
ENG99212,Common highside 1 specified condition,Common Highside soll eingeschaltet werden,
ENG99878,Common highside 2 specified condition,Common Highside soll eingeschaltet werden,
ENG102274,Control Module Voltage,11.900, V
ENG103403,Converter Loss Torque,2.1, Nm
ENG100625,Coolant temperature,59, °C
ENG157510-ENG167264,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet,27.0, mJ
ENG157510-ENG167265,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet HR,326848.0, J
ENG157510-ENG167266,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet,27.0, mJ
ENG157510-ENG167267,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet HR,326848.0, J
ENG157510-ENG161282,Daten des Lebensdauermodells der K1-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG157511-ENG167264,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet,21.0, mJ
ENG157511-ENG167265,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet HR,98907.4, J
ENG157511-ENG167266,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet,21.0, mJ
ENG157511-ENG167267,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet HR,98907.4, J
ENG157511-ENG161282,Daten des Lebensdauermodells der K2-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG104016,Designation VWDQ-Lib,L40G01,
ENG98602,Driver intention torque,-23.0, Nm
ENG100746,Driving strategy: sport factor,0.0, %
ENG100152-ENG104003,ECUNAME-ECU,TCM,
ENG100152,ECUNAME,TransmisCtrl,
ENG101251,Empty,Empty,
ENG98756,Engine torque,0.0, Nm
ENG104230,Engine torque loss,23.0, Nm
ENG106287-ENG104036,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 1,158, °C
ENG106287-ENG103379,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 2,170, °C
ENG123019-ENG99024,Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission,0.0, km/h
ENG100414,Gangsteller A Adaption Neutralposition,-0.4, mm
ENG100089,Gangsteller B Adaption Neutralposition,0.1, mm
ENG103055,Gangsteller C Adaption Neutralposition,-0.2, mm
ENG101354,Gangsteller D Adaption Neutralposition,0.1, mm
ENG110510,Gear actuator adaption engaged position G1,-8.4, mm
ENG110511,Gear actuator adaption engaged position G2,-8.9, mm
ENG110512,Gear actuator adaption engaged position G3,9.7, mm
ENG99484,Gear actuator adaption engaged position G4,10.1, mm
ENG110513,Gear actuator adaption engaged position G5,8.4, mm
ENG110514,Gear actuator adaption engaged position G6,9.1, mm
ENG110515,Gear actuator adaption engaged position G7,-9.7, mm
ENG110516,Gear actuator adaption engaged position GR,-10.1, mm
ENG110517,Gear actuator adaption synchro position G1,-2.5, mm
ENG110518,Gear actuator adaption synchro position G2,-2.0, mm
ENG110519,Gear actuator adaption synchro position G3,1.7, mm
ENG99198,Gear actuator adaption synchro position G4,2.2, mm
ENG110520,Gear actuator adaption synchro position G5,1.4, mm
ENG110521,Gear actuator adaption synchro position G6,2.0, mm
ENG110522,Gear actuator adaption synchro position G7,-1.7, mm
ENG110523,Gear actuator adaption synchro position GR,-1.7, mm
ENG157514-ENG161285,Gear_ratio_control-Status 1-Gang,Übersetzung i.O.,
ENG157514-ENG161286,Gear_ratio_control-Status 2-Gang,Übersetzung i.O.,
ENG157514-ENG161287,Gear_ratio_control-Status 3-Gang,Übersetzung i.O.,
ENG157514-ENG161288,Gear_ratio_control-Status 4-Gang,Übersetzung i.O.,
ENG157514-ENG161289,Gear_ratio_control-Status 5-Gang,Übersetzung i.O.,
ENG157514-ENG161290,Gear_ratio_control-Status 6-Gang,Übersetzung i.O.,
ENG157514-ENG161291,Gear_ratio_control-Status 7-Gang,Übersetzung i.O.,
ENG157514-ENG161292,Gear_ratio_control-Status R-Gang,Übersetzung i.O.,
ENG157514-ENG167281,Gear_ratio_control-Übersetzung 1-Gang,15.407,
ENG157514-ENG167282,Gear_ratio_control-Übersetzung 2-Gang,10.132,
ENG157514-ENG167283,Gear_ratio_control-Übersetzung 3-Gang,6.995,
ENG157514-ENG167284,Gear_ratio_control-Übersetzung 4-Gang,5.009,
ENG157514-ENG167285,Gear_ratio_control-Übersetzung 5-Gang,3.821,
ENG157514-ENG167286,Gear_ratio_control-Übersetzung 6-Gang,3.148,
ENG157514-ENG167287,Gear_ratio_control-Übersetzung 7-Gang,2.421,
ENG157514-ENG167288,Gear_ratio_control-Übersetzung R-Gang,14.042,
ENG157515-ENG167227,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Endlage Seite_A,7.7, mm
ENG157515-ENG167228,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Endlage Seite_B,-76.8, mm
ENG157515-ENG167229,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167230,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167231,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Endlage Seite_A,7.7, mm
ENG157515-ENG167232,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Endlage Seite_B,-76.8, mm
ENG157515-ENG167233,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167234,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167235,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Endlage Seite_A,7.7, mm
ENG157515-ENG167236,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Endlage Seite_B,-76.8, mm
ENG157515-ENG167237,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167238,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167239,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Endlage Seite_A,7.7, mm
ENG157515-ENG167240,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Endlage Seite_B,-76.8, mm
ENG157515-ENG167241,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167242,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167246,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Endlage Seite_A,79.3, mm
ENG157515-ENG167247,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Endlage Seite_B,-5.1, mm
ENG157515-ENG167248,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167249,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Synchronlage Seite_B,51.2, mm
ENG157515-ENG167250,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Endlage Seite_A,79.3, mm
ENG157515-ENG167251,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Endlage Seite_B,-5.1, mm
ENG157515-ENG167252,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167253,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Synchronlage Seite_B,51.2, mm
ENG157515-ENG167254,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Endlage Seite_A,79.3, mm
ENG157515-ENG167255,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Endlage Seite_B,-5.1, mm
ENG157515-ENG167256,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167257,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Synchronlage Seite_B,51.2, mm
ENG157515-ENG167258,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Endlage Seite_A,79.3, mm
ENG157515-ENG167259,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Endlage Seite_B,-5.1, mm
ENG157515-ENG167260,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167261,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Synchronlage Seite_B,51.2, mm
ENG157516-ENG167243,Grenzwertvorgaben der Grundeinmessung Kupplung-Max-Wert des Kisspoints Kupplung_1,240.6, bar
ENG157516-ENG167244,Grenzwertvorgaben der Grundeinmessung Kupplung-Max-Wert des Kisspoints Kupplung_2,240.6, bar
ENG157516-ENG167262,Grenzwertvorgaben der Grundeinmessung Kupplung-Min-Wert des Kisspoints Kupplung_1,307.2, bar
ENG157516-ENG167263,Grenzwertvorgaben der Grundeinmessung Kupplung-Min-Wert des Kisspoints Kupplung_2,281.6, bar
ENG99720,Height info,993, mbar
ENG98604,Hill factor driving strategy,0.0, %
ENG99596,Indicated engine torque without external interventions,0.0, Nm
ENG99582,Intake air temperature,38, °C
ENG252350,Kupplung 1 Adaption Kupplungsendlage (KEL) geschlossen,15.00, bar
ENG252349,Kupplung 1 Adaption Kupplungsendlage (KEL) offen,0.00, bar
ENG110538,Kupplung 2 Adaption Kupplungsendlage (KEL) geschlossen,15.00, bar
ENG110539,Kupplung 2 Adaption Kupplungsendlage (KEL) offen,0.00, bar
ENG110556-ENG110541,Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung,10,
ENG110556-ENG110542,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß,0,
ENG110556-ENG110543,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein,471,
ENG110556-ENG120771,Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen,341,
ENG110557-ENG110545,Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung,1,
ENG110557-ENG110546,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß,0,
ENG110557-ENG110547,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein,402,
ENG110557-ENG110544,Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen,816,
ENG107605-ENG103083,Mechatronics-ID_Dev.-Baudatum,240520,
ENG107605-ENG98675,Mechatronics-ID_Dev.-Construction version,N5,
ENG107605-ENG99175,Mechatronics-ID_Dev.-Kassel,K,
ENG107605-ENG104192,Mechatronics-ID_Dev.-Kennung der Mechatronik-Montagelinie,D15,
ENG107605-ENG103830,Mechatronics-ID_Dev.-Lfd.-Nr,7227,
ENG107605-ENG103525,Mechatronics-ID_Dev.-Teilenummer (3 letzten + Index),0GCH_,
ENG111613-ENG101555,Motordrehmoment Begrenzung-Engine torque limitation,0.0, Nm
ENG104079,Odometer state: last chng GE clutch mov press. char. curve,4294967295, km
ENG105329-ENG101124,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1),0.0, H
ENG105329-ENG100216,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2),14.9, H
ENG105329-ENG103067,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3),21.9, H
ENG105329-ENG101168,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4),0.5, H
ENG105329-ENG104150,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5),0.0, H
ENG105329-ENG100130,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6),0.0, H
ENG100188,Reached maximum temperature control module,102, °C
ENG123020-ENG102793,Rollwiderstand-Road Resistance,0.0, %
ENG103000,Run time complete system,37.2518, H
ENG100909,Snapshot 1 Info current ECM3 error 0,0,
ENG100722,Snapshot 1 Info current ECM3 error 1,0,
ENG103157,Snapshot 1 Info old ECM3 error 0,0,
ENG99098,Snapshot 1 Info old ECM3 error 1,0,
ENG102200,Snapshot 2 Info current ECM3 error 0,0,
ENG101765,Snapshot 2 Info current ECM3 error 1,0,
ENG101738,Snapshot 2 Info old ECM3 error 0,0,
ENG101881,Snapshot 2 Info old ECM3 error 1,0,
ENG263113-ENG263203,Snapshot_1_TCM_DQ381-Accelerator_Pedal_Position,0.0, %
ENG263113-ENG263225,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_actual_speed,0, /min
ENG263113-ENG263226,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_commanded_speed_demand_estimation,0, /min
ENG263113-ENG263227,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_current,0, mA
ENG263113-ENG263228,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_electronics_temperature,-40, °C
ENG263113-ENG263787,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_current_limitation_failure_status,OFF,
ENG263113-ENG263788,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_rotor_position_sensor_failure_status,OFF,
ENG263113-ENG263230,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_oil_pressure,0.00, bar
ENG263113-ENG263789,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_actual_mode,OFF,
ENG263113-ENG263790,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_commanded_mode,OFF,
ENG263113-ENG263233,Snapshot_1_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_voltage_terminal_30,0.0, V
ENG263113-ENG263236,Snapshot_1_TCM_DQ381-Clutch_1/2_maximum_temperature,-60, °C
ENG263113-ENG129747,Snapshot_1_TCM_DQ381-Clutch_1_actual_pressure,0.0, bar
ENG263113-ENG263237,Snapshot_1_TCM_DQ381-Clutch_1_current_valve_actual_value,0, mA
ENG263113-ENG129748,Snapshot_1_TCM_DQ381-Clutch_2_actual_pressure,0.0, bar
ENG263113-ENG263238,Snapshot_1_TCM_DQ381-Clutch_2_current_valve_actual_value,0, mA
ENG263113-ENG263792,Snapshot_1_TCM_DQ381-Clutch_cooling_current_valve,0, mA
ENG263113-ENG263239,Snapshot_1_TCM_DQ381-Clutch_main_condition,New,
ENG263113-ENG263240,Snapshot_1_TCM_DQ381-Commanded_gear,GANG N,
ENG263113-ENG98516,Snapshot_1_TCM_DQ381-Counter,0,
ENG263113-ENG263805,Snapshot_1_TCM_DQ381-Electric_pump_cooling_current_valve,0, mA
ENG263113-ENG263218,Snapshot_1_TCM_DQ381-Engine_torque,-50, Nm
ENG263113-ENG263254,Snapshot_1_TCM_DQ381-Failure_ID,65535,
ENG263113-ENG263257,Snapshot_1_TCM_DQ381-Freewheeling_status,Freilauf inaktiv aber möglich,
ENG263113-ENG263206,Snapshot_1_TCM_DQ381-Gearpositioner_A_Actual_Position,-20.48, mm
ENG263113-ENG263207,Snapshot_1_TCM_DQ381-Gearpositioner_A_Valve_Actual_Current,0, mA
ENG263113-ENG263208,Snapshot_1_TCM_DQ381-Gearpositioner_B_Actual_Position,-20.48, mm
ENG263113-ENG263209,Snapshot_1_TCM_DQ381-Gearpositioner_B_Valve_Actual_Current,0, mA
ENG263113-ENG263210,Snapshot_1_TCM_DQ381-Gearpositioner_C_Actual_Position,-20.48, mm
ENG263113-ENG263211,Snapshot_1_TCM_DQ381-Gearpositioner_C_Valve_Actual_Current,0, mA
ENG263113-ENG263212,Snapshot_1_TCM_DQ381-Gearpositioner_D_Actual_Position,-20.48, mm
ENG263113-ENG263213,Snapshot_1_TCM_DQ381-Gearpositioner_D_Valve_Actual_Current,0, mA
ENG263113-ENG263260,Snapshot_1_TCM_DQ381-Information_actual_ECM3_error_0,0,
ENG263113-ENG263261,Snapshot_1_TCM_DQ381-Information_actual_ECM3_error_1,0,
ENG263113-ENG263262,Snapshot_1_TCM_DQ381-Information_old_ECM3_error_0,0,
ENG263113-ENG263263,Snapshot_1_TCM_DQ381-Information_old_ECM3_error_1,0,
ENG263113-ENG263836,Snapshot_1_TCM_DQ381-Main_pressure_/_accumulator_current_valve,0, mA
ENG263113-ENG103063,Snapshot_1_TCM_DQ381-Mileage,0, km
ENG263113-ENG263217,Snapshot_1_TCM_DQ381-Oil_Pressure_Actual_Value,-10.0, bar
ENG263113-ENG263286,Snapshot_1_TCM_DQ381-Preselection_gear,GANG N,
ENG263113-ENG263214,Snapshot_1_TCM_DQ381-Shift_Position_Plausible,P,
ENG263113-ENG263309,Snapshot_1_TCM_DQ381-Transmission_fluid_temperature,-60, °C
ENG263113-ENG263310,Snapshot_1_TCM_DQ381-Transmission_input_speed,0, /min
ENG263113-ENG263215,Snapshot_1_TCM_DQ381-Transmission_Output_Speed,0, /min
ENG263113-ENG263311,Snapshot_1_TCM_DQ381-Transmission_part_1_current_valve_actual_value,0, mA
ENG263113-ENG263312,Snapshot_1_TCM_DQ381-Transmission_part_2_current_valve_actual_value,0, mA
ENG263113-ENG263313,Snapshot_1_TCM_DQ381-Transmission_speed_shaft_1,0, /min
ENG263113-ENG263314,Snapshot_1_TCM_DQ381-Transmission_speed_shaft_2,0, /min
ENG263113-ENG263315,Snapshot_1_TCM_DQ381-Vehicle_condition,New,
ENG263113-ENG263216,Snapshot_1_TCM_DQ381-Voltage_Supply_Electric_Motor,0.0, V
ENG263113-ENG263202,Snapshot_1_TCM_DQ381-Voltage_Terminal_15,0.0, V
ENG263116-ENG263203,Snapshot_2_TCM_DQ381-Accelerator_Pedal_Position,0.0, %
ENG263116-ENG263225,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_actual_speed,0, /min
ENG263116-ENG263226,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_commanded_speed_demand_estimation,0, /min
ENG263116-ENG263227,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_current,0, mA
ENG263116-ENG263228,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_electronics_temperature,24, °C
ENG263116-ENG263787,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_current_limitation_failure_status,OFF,
ENG263116-ENG263788,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_rotor_position_sensor_failure_status,OFF,
ENG263116-ENG263230,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_oil_pressure,0.00, bar
ENG263116-ENG263789,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_actual_mode,OFF,
ENG263116-ENG263790,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_commanded_mode,OFF,
ENG263116-ENG263233,Snapshot_2_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_voltage_terminal_30,12.5, V
ENG263116-ENG263236,Snapshot_2_TCM_DQ381-Clutch_1/2_maximum_temperature,34, °C
ENG263116-ENG129747,Snapshot_2_TCM_DQ381-Clutch_1_actual_pressure,0.0, bar
ENG263116-ENG263237,Snapshot_2_TCM_DQ381-Clutch_1_current_valve_actual_value,0, mA
ENG263116-ENG129748,Snapshot_2_TCM_DQ381-Clutch_2_actual_pressure,0.0, bar
ENG263116-ENG263238,Snapshot_2_TCM_DQ381-Clutch_2_current_valve_actual_value,0, mA
ENG263116-ENG263792,Snapshot_2_TCM_DQ381-Clutch_cooling_current_valve,1200, mA
ENG263116-ENG263239,Snapshot_2_TCM_DQ381-Clutch_main_condition,Neutral,
ENG263116-ENG263240,Snapshot_2_TCM_DQ381-Commanded_gear,GANG_1,
ENG263116-ENG98516,Snapshot_2_TCM_DQ381-Counter,1,
ENG263116-ENG263805,Snapshot_2_TCM_DQ381-Electric_pump_cooling_current_valve,0, mA
ENG263116-ENG263218,Snapshot_2_TCM_DQ381-Engine_torque,-32, Nm
ENG263116-ENG263254,Snapshot_2_TCM_DQ381-Failure_ID,233,
ENG263116-ENG263257,Snapshot_2_TCM_DQ381-Freewheeling_status,Freilauf inaktiv aber möglich,
ENG263116-ENG263206,Snapshot_2_TCM_DQ381-Gearpositioner_A_Actual_Position,-10.24, mm
ENG263116-ENG263207,Snapshot_2_TCM_DQ381-Gearpositioner_A_Valve_Actual_Current,0, mA
ENG263116-ENG263208,Snapshot_2_TCM_DQ381-Gearpositioner_B_Actual_Position,0.00, mm
ENG263116-ENG263209,Snapshot_2_TCM_DQ381-Gearpositioner_B_Valve_Actual_Current,0, mA
ENG263116-ENG263210,Snapshot_2_TCM_DQ381-Gearpositioner_C_Actual_Position,0.00, mm
ENG263116-ENG263211,Snapshot_2_TCM_DQ381-Gearpositioner_C_Valve_Actual_Current,0, mA
ENG263116-ENG263212,Snapshot_2_TCM_DQ381-Gearpositioner_D_Actual_Position,0.00, mm
ENG263116-ENG263213,Snapshot_2_TCM_DQ381-Gearpositioner_D_Valve_Actual_Current,0, mA
ENG263116-ENG263260,Snapshot_2_TCM_DQ381-Information_actual_ECM3_error_0,0,
ENG263116-ENG263261,Snapshot_2_TCM_DQ381-Information_actual_ECM3_error_1,0,
ENG263116-ENG263262,Snapshot_2_TCM_DQ381-Information_old_ECM3_error_0,0,
ENG263116-ENG263263,Snapshot_2_TCM_DQ381-Information_old_ECM3_error_1,0,
ENG263116-ENG263836,Snapshot_2_TCM_DQ381-Main_pressure_/_accumulator_current_valve,980, mA
ENG263116-ENG103063,Snapshot_2_TCM_DQ381-Mileage,0, km
ENG263116-ENG263217,Snapshot_2_TCM_DQ381-Oil_Pressure_Actual_Value,0.0, bar
ENG263116-ENG263286,Snapshot_2_TCM_DQ381-Preselection_gear,GANG N,
ENG263116-ENG263214,Snapshot_2_TCM_DQ381-Shift_Position_Plausible,P,
ENG263116-ENG263309,Snapshot_2_TCM_DQ381-Transmission_fluid_temperature,25, °C
ENG263116-ENG263310,Snapshot_2_TCM_DQ381-Transmission_input_speed,192, /min
ENG263116-ENG263215,Snapshot_2_TCM_DQ381-Transmission_Output_Speed,0, /min
ENG263116-ENG263311,Snapshot_2_TCM_DQ381-Transmission_part_1_current_valve_actual_value,0, mA
ENG263116-ENG263312,Snapshot_2_TCM_DQ381-Transmission_part_2_current_valve_actual_value,0, mA
ENG263116-ENG263313,Snapshot_2_TCM_DQ381-Transmission_speed_shaft_1,0, /min
ENG263116-ENG263314,Snapshot_2_TCM_DQ381-Transmission_speed_shaft_2,192, /min
ENG263116-ENG263315,Snapshot_2_TCM_DQ381-Vehicle_condition,SYSTEM_RUNTER,
ENG263116-ENG263216,Snapshot_2_TCM_DQ381-Voltage_Supply_Electric_Motor,12.2, V
ENG263116-ENG263202,Snapshot_2_TCM_DQ381-Voltage_Terminal_15,0.0, V
ENG263119-ENG263203,Snapshot_3_TCM_DQ381-Accelerator_Pedal_Position,0.0, %
ENG263119-ENG263225,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_actual_speed,0, /min
ENG263119-ENG263226,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_commanded_speed_demand_estimation,0, /min
ENG263119-ENG263227,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_current,0, mA
ENG263119-ENG263228,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_electronics_temperature,28, °C
ENG263119-ENG263787,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_current_limitation_failure_status,OFF,
ENG263119-ENG263788,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_rotor_position_sensor_failure_status,OFF,
ENG263119-ENG263230,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_oil_pressure,0.00, bar
ENG263119-ENG263789,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_actual_mode,OFF,
ENG263119-ENG263790,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_commanded_mode,OFF,
ENG263119-ENG263233,Snapshot_3_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_voltage_terminal_30,13.0, V
ENG263119-ENG263236,Snapshot_3_TCM_DQ381-Clutch_1/2_maximum_temperature,32, °C
ENG263119-ENG129747,Snapshot_3_TCM_DQ381-Clutch_1_actual_pressure,0.0, bar
ENG263119-ENG263237,Snapshot_3_TCM_DQ381-Clutch_1_current_valve_actual_value,0, mA
ENG263119-ENG129748,Snapshot_3_TCM_DQ381-Clutch_2_actual_pressure,0.0, bar
ENG263119-ENG263238,Snapshot_3_TCM_DQ381-Clutch_2_current_valve_actual_value,0, mA
ENG263119-ENG263792,Snapshot_3_TCM_DQ381-Clutch_cooling_current_valve,0, mA
ENG263119-ENG263239,Snapshot_3_TCM_DQ381-Clutch_main_condition,Neutral,
ENG263119-ENG263240,Snapshot_3_TCM_DQ381-Commanded_gear,GANG_1,
ENG263119-ENG98516,Snapshot_3_TCM_DQ381-Counter,2,
ENG263119-ENG263805,Snapshot_3_TCM_DQ381-Electric_pump_cooling_current_valve,0, mA
ENG263119-ENG263218,Snapshot_3_TCM_DQ381-Engine_torque,-24, Nm
ENG263119-ENG263254,Snapshot_3_TCM_DQ381-Failure_ID,233,
ENG263119-ENG263257,Snapshot_3_TCM_DQ381-Freewheeling_status,Freilauf inaktiv aber möglich,
ENG263119-ENG263206,Snapshot_3_TCM_DQ381-Gearpositioner_A_Actual_Position,-10.24, mm
ENG263119-ENG263207,Snapshot_3_TCM_DQ381-Gearpositioner_A_Valve_Actual_Current,0, mA
ENG263119-ENG263208,Snapshot_3_TCM_DQ381-Gearpositioner_B_Actual_Position,-9.92, mm
ENG263119-ENG263209,Snapshot_3_TCM_DQ381-Gearpositioner_B_Valve_Actual_Current,0, mA
ENG263119-ENG263210,Snapshot_3_TCM_DQ381-Gearpositioner_C_Actual_Position,0.00, mm
ENG263119-ENG263211,Snapshot_3_TCM_DQ381-Gearpositioner_C_Valve_Actual_Current,0, mA
ENG263119-ENG263212,Snapshot_3_TCM_DQ381-Gearpositioner_D_Actual_Position,0.00, mm
ENG263119-ENG263213,Snapshot_3_TCM_DQ381-Gearpositioner_D_Valve_Actual_Current,0, mA
ENG263119-ENG263260,Snapshot_3_TCM_DQ381-Information_actual_ECM3_error_0,0,
ENG263119-ENG263261,Snapshot_3_TCM_DQ381-Information_actual_ECM3_error_1,0,
ENG263119-ENG263262,Snapshot_3_TCM_DQ381-Information_old_ECM3_error_0,0,
ENG263119-ENG263263,Snapshot_3_TCM_DQ381-Information_old_ECM3_error_1,0,
ENG263119-ENG263836,Snapshot_3_TCM_DQ381-Main_pressure_/_accumulator_current_valve,0, mA
ENG263119-ENG103063,Snapshot_3_TCM_DQ381-Mileage,0, km
ENG263119-ENG263217,Snapshot_3_TCM_DQ381-Oil_Pressure_Actual_Value,0.5, bar
ENG263119-ENG263286,Snapshot_3_TCM_DQ381-Preselection_gear,GANG_2,
ENG263119-ENG263214,Snapshot_3_TCM_DQ381-Shift_Position_Plausible,P,
ENG263119-ENG263309,Snapshot_3_TCM_DQ381-Transmission_fluid_temperature,31, °C
ENG263119-ENG263310,Snapshot_3_TCM_DQ381-Transmission_input_speed,0, /min
ENG263119-ENG263215,Snapshot_3_TCM_DQ381-Transmission_Output_Speed,0, /min
ENG263119-ENG263311,Snapshot_3_TCM_DQ381-Transmission_part_1_current_valve_actual_value,0, mA
ENG263119-ENG263312,Snapshot_3_TCM_DQ381-Transmission_part_2_current_valve_actual_value,0, mA
ENG263119-ENG263313,Snapshot_3_TCM_DQ381-Transmission_speed_shaft_1,0, /min
ENG263119-ENG263314,Snapshot_3_TCM_DQ381-Transmission_speed_shaft_2,0, /min
ENG263119-ENG263315,Snapshot_3_TCM_DQ381-Vehicle_condition,SYSTEM_RUNTER,
ENG263119-ENG263216,Snapshot_3_TCM_DQ381-Voltage_Supply_Electric_Motor,12.8, V
ENG263119-ENG263202,Snapshot_3_TCM_DQ381-Voltage_Terminal_15,0.1, V
ENG263122-ENG263203,Snapshot_4_TCM_DQ381-Accelerator_Pedal_Position,0.0, %
ENG263122-ENG263225,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_actual_speed,0, /min
ENG263122-ENG263226,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_commanded_speed_demand_estimation,0, /min
ENG263122-ENG263227,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_current,0, mA
ENG263122-ENG263228,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_electronics_temperature,36, °C
ENG263122-ENG263787,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_current_limitation_failure_status,OFF,
ENG263122-ENG263788,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_GOP_rotor_position_sensor_failure_status,OFF,
ENG263122-ENG263230,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_oil_pressure,0.00, bar
ENG263122-ENG263789,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_actual_mode,OFF,
ENG263122-ENG263790,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_status_commanded_mode,OFF,
ENG263122-ENG263233,Snapshot_4_TCM_DQ381-Auxiliary_transmission_fluid_pump_motor_voltage_terminal_30,13.0, V
ENG263122-ENG263236,Snapshot_4_TCM_DQ381-Clutch_1/2_maximum_temperature,60, °C
ENG263122-ENG129747,Snapshot_4_TCM_DQ381-Clutch_1_actual_pressure,0.0, bar
ENG263122-ENG263237,Snapshot_4_TCM_DQ381-Clutch_1_current_valve_actual_value,0, mA
ENG263122-ENG129748,Snapshot_4_TCM_DQ381-Clutch_2_actual_pressure,0.0, bar
ENG263122-ENG263238,Snapshot_4_TCM_DQ381-Clutch_2_current_valve_actual_value,0, mA
ENG263122-ENG263792,Snapshot_4_TCM_DQ381-Clutch_cooling_current_valve,0, mA
ENG263122-ENG263239,Snapshot_4_TCM_DQ381-Clutch_main_condition,Neutral,
ENG263122-ENG263240,Snapshot_4_TCM_DQ381-Commanded_gear,GANG_1,
ENG263122-ENG98516,Snapshot_4_TCM_DQ381-Counter,3,
ENG263122-ENG263805,Snapshot_4_TCM_DQ381-Electric_pump_cooling_current_valve,0, mA
ENG263122-ENG263218,Snapshot_4_TCM_DQ381-Engine_torque,-20, Nm
ENG263122-ENG263254,Snapshot_4_TCM_DQ381-Failure_ID,233,
ENG263122-ENG263257,Snapshot_4_TCM_DQ381-Freewheeling_status,Freilauf inaktiv aber möglich,
ENG263122-ENG263206,Snapshot_4_TCM_DQ381-Gearpositioner_A_Actual_Position,-10.24, mm
ENG263122-ENG263207,Snapshot_4_TCM_DQ381-Gearpositioner_A_Valve_Actual_Current,0, mA
ENG263122-ENG263208,Snapshot_4_TCM_DQ381-Gearpositioner_B_Actual_Position,-9.92, mm
ENG263122-ENG263209,Snapshot_4_TCM_DQ381-Gearpositioner_B_Valve_Actual_Current,0, mA
ENG263122-ENG263210,Snapshot_4_TCM_DQ381-Gearpositioner_C_Actual_Position,0.00, mm
ENG263122-ENG263211,Snapshot_4_TCM_DQ381-Gearpositioner_C_Valve_Actual_Current,0, mA
ENG263122-ENG263212,Snapshot_4_TCM_DQ381-Gearpositioner_D_Actual_Position,0.00, mm
ENG263122-ENG263213,Snapshot_4_TCM_DQ381-Gearpositioner_D_Valve_Actual_Current,0, mA
ENG263122-ENG263260,Snapshot_4_TCM_DQ381-Information_actual_ECM3_error_0,0,
ENG263122-ENG263261,Snapshot_4_TCM_DQ381-Information_actual_ECM3_error_1,0,
ENG263122-ENG263262,Snapshot_4_TCM_DQ381-Information_old_ECM3_error_0,0,
ENG263122-ENG263263,Snapshot_4_TCM_DQ381-Information_old_ECM3_error_1,0,
ENG263122-ENG263836,Snapshot_4_TCM_DQ381-Main_pressure_/_accumulator_current_valve,0, mA
ENG263122-ENG103063,Snapshot_4_TCM_DQ381-Mileage,0, km
ENG263122-ENG263217,Snapshot_4_TCM_DQ381-Oil_Pressure_Actual_Value,0.0, bar
ENG263122-ENG263286,Snapshot_4_TCM_DQ381-Preselection_gear,GANG_2,
ENG263122-ENG263214,Snapshot_4_TCM_DQ381-Shift_Position_Plausible,P,
ENG263122-ENG263309,Snapshot_4_TCM_DQ381-Transmission_fluid_temperature,52, °C
ENG263122-ENG263310,Snapshot_4_TCM_DQ381-Transmission_input_speed,0, /min
ENG263122-ENG263215,Snapshot_4_TCM_DQ381-Transmission_Output_Speed,0, /min
ENG263122-ENG263311,Snapshot_4_TCM_DQ381-Transmission_part_1_current_valve_actual_value,0, mA
ENG263122-ENG263312,Snapshot_4_TCM_DQ381-Transmission_part_2_current_valve_actual_value,0, mA
ENG263122-ENG263313,Snapshot_4_TCM_DQ381-Transmission_speed_shaft_1,0, /min
ENG263122-ENG263314,Snapshot_4_TCM_DQ381-Transmission_speed_shaft_2,0, /min
ENG263122-ENG263315,Snapshot_4_TCM_DQ381-Vehicle_condition,Follow-up,
ENG263122-ENG263216,Snapshot_4_TCM_DQ381-Voltage_Supply_Electric_Motor,12.8, V
ENG263122-ENG263202,Snapshot_4_TCM_DQ381-Voltage_Terminal_15,0.1, V
ENG101057,Specified idle speed,1400, /min
ENG100803,Speed: output,0, /min
ENG106780-ENG103213,Transmission-ID_Dev.-Aggregatekennzeichnung (Getriebe),006,
ENG106780-ENG103083,Transmission-ID_Dev.-Baudatum,240520,
ENG106780-ENG104019,Transmission-ID_Dev.-Getriebekennbuchstabe,VDK,
ENG106780-ENG99175,Transmission-ID_Dev.-Kassel,K,
ENG106780-ENG101707,Transmission-ID_Dev.-Kennung der Montagelinie,D08,
ENG106780-ENG103830,Transmission-ID_Dev.-Lfd.-Nr,1892,
ENG103964,Veh. odometer state: last change of GE gear selector data,0, km
ENG109959-ENG101914,vmd_i_FlwVlvCurMin_mA_EvenA-vmd i FlwVlvCurMin mA EvenA,498,
ENG109960-ENG104144,vmd_i_FlwVlvCurMin_mA_EvenB-vmd i FlwVlvCurMin mA EvenB,498,
ENG109961-ENG101870,vmd_i_FlwVlvCurMin_mA_OddA-vmd i FlwVlvCurMin mA OddA,491,
ENG109962-ENG102688,vmd_i_FlwVlvCurMin_mA_OddB-vmd i FlwVlvCurMin mA OddB,512,
ENG109963-ENG103264,vmd_i_NulFlw_mA_Even_ABw-vmd i NulFlw mA Even ABw,749,
ENG109964-ENG100102,vmd_i_NulFlw_mA_Even_AFw-vmd i NulFlw mA Even AFw,911,
ENG109965-ENG103659,vmd_i_NulFlw_mA_Even_BBw-vmd i NulFlw mA Even BBw,749,
ENG109966-ENG100519,vmd_i_NulFlw_mA_Even_BFw-vmd i NulFlw mA Even BFw,912,
ENG109967-ENG99410,vmd_i_NulFlw_mA_OddABw-vmd i NulFlw mA OddABw,756,
ENG109968-ENG99443,vmd_i_NulFlw_mA_OddAFw-vmd i NulFlw mA OddAFw,892,
ENG109969-ENG100167,vmd_i_NulFlw_mA_OddBBw-vmd i NulFlw mA OddBBw,745,
ENG109970-ENG99387,vmd_i_NulFlw_mA_OddBFw-vmd i NulFlw mA OddBFw,887,
ENG109971-ENG103334,vmd_k_Line_PmaxKoeffizient vmd_k_Line_Pmax-Koeffizient,25.169,
ENG109005,Voltage Common Highside 1,11.8, V
ENG99955,Voltage Common Highside 2,11.8, V
Elapsed Time: 00:44
blockmap-03-5WA-614-517-CF_VSSZZZKM2RR140480-20241020-1501.CSV
;SW:5WA-614-517-CF   HW:5WA-614-517-N ---  ABS Brakes
;Component:ESC           H13 0135, Coding:34042C994224426C527BA00805C365A62DB458F58AC8670821BCA431018FF100002814
;EV_Brake1ESCEPBMQB37W,013058,EV_Brake1ESCEPBMQB37W_013_AU38.rod
;Sunday,20,October,2024,15:01:30:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 0E4277F850DB494ADD7-805A
Group,Description,Actual
IDE00019,Voltage terminal 30,12.070, V
IDE00021,Engine RPM,0, /min
IDE00025,Coolant temperature,59.0, °C
IDE00085,Normed load value,0, %
IDE00086,Accelerator pedal position,14.9, %
IDE00097,OBD - requirements for which this vehicle is designed,EOBD,
IDE00601-ENG161107,Monitoring status since erasing DTC memory-MIL_Status,OFF,
IDE00601-ENG161129,Monitoring status since erasing DTC memory-Number_of_errors_Mode$03,0,
IDE00601-ENG161142,Monitoring status since erasing DTC memory-Readiness_State,00000000 ,
IDE00601-ENG161227,Monitoring status since erasing DTC memory-Supported_Info,00000000 ,
IDE00601-ENG161228,Monitoring status since erasing DTC memory-Supported_Info_Readiness,00000100 ,
IDE00602-ENG161054,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_continous_diagnostics,00000100 ,
IDE00602-ENG161055,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_non_continous_diagnostics,00000000 ,
IDE00602-ENG161141,Monitoring status in current driving cycle-Readiness_Code,00000000 ,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,KM2RR140480,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE02070,CAN output signal(s) status-Wake-up cause,Bus communication,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,OFF,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,On,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS01299,Stop process prevented-Offroad,not active,
IDE03008-MAS01478,Stop process prevented-insufficient voltage,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll back detection,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,17,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS01299,Number of prevented stop processes-Offroad,0,
IDE03010-MAS01478,Number of prevented stop processes-insufficient voltage,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll back detection,4,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,9,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,955,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,18,
IDE03011-MAS04515,Number of requested start processes-Roll back detection,4,
IDE03310,Brake lamp,OFF,
IDE03310-MAS01167,Brake lamp-Actuation time,0 s,
IDE03310-ENG170421,Brake lamp-IoReached Status,Output diagnostic test not active,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,4.9, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,12.0, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,12.0, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,11.9, V
IDE03680-MAS01468,Supply voltages-Terminal 15,On,
IDE04082-MAS00580,Instrument cluster text output-Electromechanical parking brake text 1,0,
IDE04082-MAS03359,Instrument cluster text output-Text,0,
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.00, bar
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.00, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,Malfunction,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,forward,
IDE04425-MAS09580,Left front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.00, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,Malfunction,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,forward,
IDE04426-MAS09580,Right front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.00, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04427-MAS09580,Left rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.00, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-MAS09580,Right rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,-0.00981, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,-0.21582, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,0.29430, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,-0.37500, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,0.143, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,-6.475, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,-6.475, °
IDE04446-IDE14988,Hill descent control-Incline,3, %
IDE04446-MAS01299,Hill descent control-Offroad,Off-road deactivated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04446-MAS05585,Hill descent control-Standby,not active,
IDE04446-MAS12601,Hill descent control-HDC intervention,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not operated,
IDE04452-IDE03664,Brake system button-Button for driving program,Not available due to specific system,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,1608, km
IDE04461-MAS01481,Internal measured values-Temperature in control module,37.1, °C
IDE04461-MAS10973,Internal measured values-Hardware reset,5,
IDE04461-MAS10974,Internal measured values-Software reset,106,
IDE04461-MAS15830,Internal measured values-Data block description,Block 2,
IDE04461-MAS17870,Internal measured values-Number of resets,0,
IDE04461-ENG264503,Internal measured values-C1 Idle Task,42, %
IDE04461-ENG264509,Internal measured values-Ct mainloop,40, %
IDE04461-ENG264510,Internal measured values-Ct prc task,53, %
IDE04461-ENG264511,Internal measured values-Ct valve task,53, %
IDE04461-ENG126445,Internal measured values-Idle Task,32, %
IDE04461-ENG264549,Internal measured values-Idp Task,33, %
IDE04461-ENG264551,Internal measured values-Ipb main task,15, %
IDE04461-ENG264552,Internal measured values-Ipb safety task,75, %
IDE04461-ENG264663,Internal measured values-Task BAP 10ms,44, %
IDE04461-ENG264664,Internal measured values-Task C0 Com task 5ms AsilD,0, %
IDE04461-ENG264665,Internal measured values-Task C1 10ms AsilB,39, %
IDE04461-ENG264666,Internal measured values-Task C1 1ms AsilB,36, %
IDE04461-ENG264667,Internal measured values-Task Com task1 5ms AsilD,41, %
IDE04461-ENG264668,Internal measured values-Task Com task1 5ms Qm,47, %
IDE04461-ENG264669,Internal measured values-Task Com task2 5ms Qm,14, %
IDE04461-ENG264670,Internal measured values-Task mFDR 5ms_AsilD,59, %
IDE04461-ENG264671,Internal measured values-Task mFDR 5ms_Qm,64, %
IDE04461-ENG264672,Internal measured values-Task TPI 20ms,50, %
IDE04508-IDE02955,Hydraulic brake booster-System status,available.,
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04644-IDE02955,Roll-over protection-System status,available.,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,not activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,available.,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,not activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,0, m/s²
IDE04765-IDE02955,Counter steer support-System status,Not available due to specific system,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,0, km
IDE04772,Indicator light in the button for electromech. parking brake,On,
IDE04772-MAS01167,Indicator light in the button for electromech. parking brake-Actuation time,Without time limit,
IDE04772-ENG170421,Indicator light in the button for electromech. parking brake-IoReached Status,Output diagnostic test not active,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04939-IDE02763,Tire Pressure Monitoring System (TPMS)-System malfunction lamp: status,OFF,
IDE04939-IDE02765,Tire Pressure Monitoring System (TPMS)-Pressure warning lamp: status,OFF,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,7, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,0, km
IDE04939-IDE09286,Tire Pressure Monitoring System (TPMS)-Software version of tire monitoring display,R1906A26,
IDE04939-IDE09287,Tire Pressure Monitoring System (TPMS)-Param. set version tire press monitoring display,0,
IDE04939-IDE09288,Tire Pressure Monitoring System (TPMS)-Param. set tire press monitor display: checksum,48,
IDE04939-IDE09289,Tire Pressure Monitoring System (TPMS)-Tire press monitor.display: diagnosis status,00 00 05 50 05 40 00 44 00 40,
IDE04939-IDE11039,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: le. frt,253,
IDE04939-IDE11040,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast pres.loss: ri. frt.,253,
IDE04939-IDE11041,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.:counter for fast press. loss: le. rr.,253,
IDE04939-IDE11042,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: ri. rr.,253,
IDE04939-IDE11043,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. frt,239,
IDE04939-IDE11044,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. frt.,239,
IDE04939-IDE11045,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. rr.,239,
IDE04939-IDE11046,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. rr.,239,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2024,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2000,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,5,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,0,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,9,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,28,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,0,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,10,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,11,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,0,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,7,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,12,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,42,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,0,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,45,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,44,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,40,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,12,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,35,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,0,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,23,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,26,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,18,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,14,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,5,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,45,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,46,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,8,
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,0, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,0, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,0, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS14292,Tire Pressure Monitoring System (TPMS)-Analysis data of latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14293,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14294,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14295,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest programming,00 00 00 00 00 00 00 00 00 00,
IDE04939-MAS14296,Tire Pressure Monitoring System (TPMS)-Analysis data of the latest warning,02 25 00 00 00 00 98 99 A9 22,
IDE04939-MAS14297,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest warning,02 25 00 00 00 00 98 99 A9 22,
IDE04939-MAS14298,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest warning,02 25 00 00 00 00 98 99 A9 22,
IDE04939-MAS14299,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest warning,02 25 00 00 00 00 98 99 A9 22,
IDE04939-MAS18039,Tire Pressure Monitoring System (TPMS)-Odometer reading at fifth most recent configuration,0, km
IDE04939-MAS18041,Tire Pressure Monitoring System (TPMS)-Analysis data from fifth most recent configuration,00 00 00 00 00 00 00 00 00 00,
IDE04939-MAS18042,Tire Pressure Monitoring System (TPMS)-Temperature at time of most recent warning,24, °C
IDE04939-MAS18066,Tire Pressure Monitoring System (TPMS)-Temperature at time of second to last warning,24, °C
IDE04939-MAS18067,Tire Pressure Monitoring System (TPMS)-Temperature at time of third most recent warning,24, °C
IDE04939-MAS18069,Tire Pressure Monitoring System (TPMS)-Temperature at time of fourth most recent warning,24, °C
IDE04939-MAS18070,Tire Pressure Monitoring System (TPMS)-Odometer reading of fifth most recent warning,0, km
IDE04939-MAS18072,Tire Pressure Monitoring System (TPMS)-Temperature at time of fifth most recent warning,24, °C
IDE04939-MAS18073,Tire Pressure Monitoring System (TPMS)-Analysis data of fifth most recent warning,02 25 00 00 00 00 00 00 00 10,
IDE04939-MAS18074,Tire Pressure Monitoring System (TPMS)-Tire control display parameter set info,195,
IDE04939-MAS18076,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during most recent warning,24, °C
IDE04939-MAS18077,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during second most recent warning,24, °C
IDE04939-MAS18078,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during third most recent warning,24, °C
IDE04939-MAS18079,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fourth most recent warning,24, °C
IDE04939-MAS18080,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fifth most recent warning,24, °C
IDE04939-ENG135557,Tire Pressure Monitoring System (TPMS)-RKA_Config_Info,0,
IDE05053,Right parking brake motor: close gradually,Open,
IDE05053-MAS01167,Right parking brake motor: close gradually-Actuation time,Without time limit,
IDE05053-ENG170421,Right parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05054,Left parking brake motor: close gradually,Open,
IDE05054-MAS01167,Left parking brake motor: close gradually-Actuation time,Without time limit,
IDE05054-ENG170421,Left parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05333,Indicator light in AUTO HOLD button,OFF,
IDE05333-MAS01167,Indicator light in AUTO HOLD button-Actuation time,Without time limit,
IDE05333-ENG170421,Indicator light in AUTO HOLD button-IoReached Status,Output diagnostic test not active,
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06422-ENG103176,IUMPR_1-General Denominator,30,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,161,
IDE06422-ENG100120,IUMPR_1-Milage,1560,
IDE06422-ENG101622,IUMPR_1-Record Number,41,
IDE06423-ENG101817,IUMPR_2-Denominator,30,
IDE06423-ENG103772,IUMPR_2-DFCC Value,00 8B,
IDE06423-ENG99150,IUMPR_2-Numerator,124,
IDE06423-ENG101622,IUMPR_2-Record Number,1,
IDE06424-ENG101817,IUMPR_3-Denominator,30,
IDE06424-ENG103772,IUMPR_3-DFCC Value,10 BD,
IDE06424-ENG99150,IUMPR_3-Numerator,124,
IDE06424-ENG101622,IUMPR_3-Record Number,2,
IDE07183,Parking brake motors: close incrementally,Open,
IDE07183-MAS01167,Parking brake motors: close incrementally-Actuation time,Without time limit,
IDE07183-ENG170421,Parking brake motors: close incrementally-IoReached Status,Output diagnostic test not active,
IDE10300,OBD Driving Cycle detected,not active,
IDE13239-IDE04947,Wheel loose detection-Odometer reading of last warning,0, km
IDE13239-MAS00106,Wheel loose detection-Year,2000,
IDE13239-MAS00107,Wheel loose detection-Month,0,
IDE13239-MAS00108,Wheel loose detection-Day,0,
IDE13239-MAS00109,Wheel loose detection-Hours,0,
IDE13239-MAS00110,Wheel loose detection-Minutes,0,
IDE13239-MAS00111,Wheel loose detection-Seconds,0,
IDE13239-MAS04541,Wheel loose detection-Odometer reading of next-to-last warning,0, km
IDE13239-MAS04542,Wheel loose detection-Odometer reading of third-to-last warning,0, km
IDE13239-MAS16487,Wheel loose detection-Wheels affected by the latest warning,no warning,
IDE13239-MAS16489,Wheel loose detection-Wheels affected by the penultimate warning,no warning,
IDE13239-MAS16491,Wheel loose detection-Wheels affected by the third last warning,no warning,
IDE14227-IDE02955,modular vehicle dynamic controller-System status,available.,
IDE14227-MAS18085,modular vehicle dynamic controller-Electronic Stability Program function status,mFDR_not_active_by_failure,
IDE14227-MAS18086,modular vehicle dynamic controller-Dynamic Chassis Control function status,mFDR_active_DCC_controlled,
IDE14227-MAS18087,modular vehicle dynamic controller-Haldex function status,mFDR_active_haldex_not_configured,
IDE14227-MAS18088,modular vehicle dynamic controller-Min Haldex target locking rate,0.0, %
IDE14227-MAS18089,modular vehicle dynamic controller-Max Haldex target locking rate,50.0, %
IDE14227-ENG264561,modular vehicle dynamic controller-mFDR Sollfaktor DCC HL,100, %
IDE14227-ENG264562,modular vehicle dynamic controller-mFDR Sollfaktor DCC HR,100, %
IDE14227-ENG264563,modular vehicle dynamic controller-mFDR Sollfaktor DCC VL,100, %
IDE14227-ENG264564,modular vehicle dynamic controller-mFDR Sollfaktor DCC VR,100, %
IDE14479-IDE02657,Parking brake system status-Cut-off current: left: reached,0.00, A
IDE14479-IDE02658,Parking brake system status-Cut-off current: right: reached,0.00, A
IDE14479-IDE04496,Parking brake system status-Left parking brake motor: status,closed,
IDE14479-IDE04497,Parking brake system status-Right parking brake motor: status,closed,
IDE14479-IDE04506,Parking brake system status-Calculated left rear brake temperature,49.0, °C
IDE14479-IDE04507,Parking brake system status-Calculated right rear brake temperature,49.0, °C
IDE14479-IDE04647,Parking brake system status-Left parking brake motor: current,0.00, A
IDE14479-IDE04648,Parking brake system status-Right parking brake motor: current,0.00, A
IDE14479-IDE05048,Parking brake system status-Left parking brake motor: actuation counter,164,
IDE14479-IDE05049,Parking brake system status-Right parking brake motor: actuation counter,164,
IDE14623,Commutation test status,not active,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,15.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,15.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,15.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,15.0, °C
MAS00121-MAS01853,Electronic Differential Lock-Left front,available.,
MAS00121-MAS01854,Electronic Differential Lock-Right front,available.,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Not available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Not available,
MAS00464-MAS00106,Standard - ambient data 1-Year,2024,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,20,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,28,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,1626, km
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Not open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Not available due to specific system,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,Open,
MAS02138-MAS03095,Hill-start assistant-Function status,Condition not met,
MAS02286-MAS01167,Hydraulic pump-Actuation time,0 s,
MAS02286-MAS06857,Hydraulic pump-Speed,0, /min
MAS02286-ENG170421,Hydraulic pump-IoReached Status,Output diagnostic test not active,
MAS02426-MAS01167,Text display in instrument cluster-Actuation time,Without time limit,
MAS02426,Text display in instrument cluster,0,
MAS02426-ENG170421,Text display in instrument cluster-IoReached Status,Output diagnostic test not active,
MAS04012-IDE03297,Intake valves-Left front ABS inlet valve,OFF,
MAS04012-IDE03299,Intake valves-Right front ABS inlet valve,OFF,
MAS04012-IDE03301,Intake valves-left rear ABS intake valve,OFF,
MAS04012-IDE03303,Intake valves-right rear ABS intake valve,OFF,
MAS04012-MAS01167,Intake valves-Actuation time,0 s,
MAS04012-ENG170421,Intake valves-IoReached Status,Output diagnostic test not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG101413,Calibration Identifications,5WA517CF01350610,
ENG99697-ENG110852,Calibration Verification Numbers-Calibration Verification Number,BC B3 76 4D,
ENG100152,ECUNAME,BSCM-BrakeSystem,
ENG264445,Entwicklermesswert_08,|VZM_function_request,VZM_Participant
ENG264447-ENG135743,Entwicklermesswert_11-Left_Brake_Full_Clamping_Force,164,
ENG264447-ENG135741,Entwicklermesswert_11-Right_Brake_Full_Clamping_Force,164,
ENG264448,Entwicklermesswert_12,40081D,
ENG264449-ENG135765,Entwicklermesswert_13-Input_Signal_A_Belt_Error,No malfunction,
ENG264449-ENG135764,Entwicklermesswert_13-Input_Signal_A_Belt_Status,not selected,
ENG264449-ENG135767,Entwicklermesswert_13-Input_Signal_B_Door_Error,No malfunction,
ENG264449-ENG135766,Entwicklermesswert_13-Input_Signal_B_Door_Status,Open,
ENG264450-MAS01167,Entwicklerstellglied_01_status-Actuation time,0 s,
ENG264450-MAS11641,Entwicklerstellglied_01_status-OBD lamp,OFF,
ENG264450-ENG170421,Entwicklerstellglied_01_status-IoReached Status,Output diagnostic test not active,
Elapsed Time: 00:15
blockmap-05-5WA-959-436-Q_VSSZZZKM2RR140480-20241020-1502.CSV
;SW:5WA-959-436-Q   HW:5WA-959-436-Q ---  Acc/Start Auth.
;Component:Kessy IOBOX   100 0725, Coding:
;EV_Kessy37w,004024,EV_Kessy37w_004_VW38.rod
;Sunday,20,October,2024,15:02:03:49859
;VCID: 629A7348F4C39D2A29F-8036
IDE00019,Voltage terminal 30,12.067, V
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,366,
IDE02419,Proximity sensor frt.pass. door: number of triggers,222,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,33,
IDE02422-MAS01483,Driver door handle: version information-Software version,49,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,36,
IDE02422,Driver door handle: version information,2F 00 05 BE 1C,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,33,
IDE02423-MAS01483,ass. door handle: version information-Software version,49,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,36,
IDE02423,ass. door handle: version information,2F 00 05 54 A5,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,0,
IDE02424-MAS01483,Left rear door handle: version information-Software version,0,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,0,
IDE02424,Left rear door handle: version information,00 00 00 00 00,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,0,
IDE02425-MAS01483,Right rear door handle: version information-Software version,0,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,0,
IDE02425,Right rear door handle: version information,00 00 00 00 00,
IDE02466,Play protection activation counter driver door,0,
IDE02466,Play protection activation counter driver door,not active,
IDE02467,Play protection activation counter frt.pass. door,not active,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,not active,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,not active,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72h-Signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02486,Data logger triggering,not initialized,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.0, V
IDE07359,Dimming of starter button lighting,1213,
IDE14837-MAS19401,Outer door handle switch: status-Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19402,Outer door handle switch: status-Front Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19403,Outer door handle switch: status-Rear Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19404,Outer door handle switch: status-Rear Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19612,Outer door handle switch: status-Rear Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19613,Outer door handle switch: status-Tank Exterior Door Handle Switch: status,Not operated,
IDE14924-MAS00218,Status of release conditions Passive Entry-Driver door,not enabled,
IDE14924-MAS00219,Status of release conditions Passive Entry-Front Passenger Door,not enabled,
IDE14924-MAS00220,Status of release conditions Passive Entry-Left rear door,not enabled,
IDE14924-MAS00221,Status of release conditions Passive Entry-Right rear door,not enabled,
IDE14924-MAS19581,Status of release conditions Passive Entry-Rear,not enabled,
IDE14924-MAS19611,Status of release conditions Passive Entry-Tank,not enabled,
IDE14925-MAS00218,Status of release conditions Passive Exit-Driver door,not enabled,
IDE14925-MAS00219,Status of release conditions Passive Exit-Front Passenger Door,Enabled,
IDE14925-MAS00220,Status of release conditions Passive Exit-Left rear door,not enabled,
IDE14925-MAS00221,Status of release conditions Passive Exit-Right rear door,not enabled,
IDE14925-MAS19581,Status of release conditions Passive Exit-Rear,not enabled,
IDE14925-MAS19611,Status of release conditions Passive Exit-Tank,not enabled,
IDE14926,Status of release conditions for key search,Key search: release activated,
IDE14927-MAS19605,History of range limiter for automatic functions-Reduction level,|Level_of_reduction,Year
IDE14928-MAS00080,Sensor for control section-Coding information,Not coded,
IDE14928-MAS02176,Sensor for control section-Approach to the inside,not active,
IDE14928-MAS02177,Sensor for control section-Actuation to the inside,not active,
IDE14928-MAS02178,Sensor for control section-Approach to the outside,not active,
IDE14928-MAS02179,Sensor for control section-Actuation to the outside,not active,
IDE14928-MAS02451,Sensor for control section-Pulling actuation: outside door handle,not active,
IDE14929-MAS00080,Sensor for fuel filler flap control section-Coding information,Not coded,
IDE14929-MAS02176,Sensor for fuel filler flap control section-Approach to the inside,not active,
IDE14929-MAS02177,Sensor for fuel filler flap control section-Actuation to the inside,not active,
IDE14929-MAS02178,Sensor for fuel filler flap control section-Approach to the outside,not active,
IDE14929-MAS02179,Sensor for fuel filler flap control section-Actuation to the outside,not active,
IDE14929-MAS02451,Sensor for fuel filler flap control section-Pulling actuation: outside door handle,not active,
IDE14930,Sensor fuel filler flap control section: number of triggers,0,
IDE14931,Sensor control section trunk: number of triggers,0,
IDE14932,Fuel filler flap control section: play protection,not active,
IDE14932,Fuel filler flap control section: play protection,0,
IDE14933,Trunk control section: play protection counter,0,
IDE14933,Trunk control section: play protection counter,not active,
IDE14934-MAS01482,Trunk control section: version information-Hardware version,0,
IDE14934-MAS01483,Trunk control section: version information-Software version,0,
IDE14934-MAS04065,Trunk control section: version information-EEPROM,0,
IDE14934,Trunk control section: version information,00 00 00 00 00,
IDE14935-MAS01482,Fuel filler cap control section: version information-Hardware version,0,
IDE14935-MAS01483,Fuel filler cap control section: version information-Software version,0,
IDE14935-MAS04065,Fuel filler cap control section: version information-EEPROM,0,
IDE14935,Fuel filler cap control section: version information,00 00 00 00 00,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,Power_On_Reset,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,Power_On_Reset,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,Software_Request_Flashbootloader,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,Unexpected_Watchdog_Reset,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,Power_On_Reset,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,Power_On_Reset,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,Power_On_Reset,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,Default,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Default,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,Power_On_Reset,
ENG254757-MAS00106,Lf_antenna_eight_detune_counter-Year,2000,
ENG254757-MAS00107,Lf_antenna_eight_detune_counter-Month,0,
ENG254757-MAS00108,Lf_antenna_eight_detune_counter-Day,0,
ENG254757-MAS00109,Lf_antenna_eight_detune_counter-Hours,0,
ENG254757-MAS00110,Lf_antenna_eight_detune_counter-Minutes,0,
ENG254757-MAS00111,Lf_antenna_eight_detune_counter-Seconds,0,
ENG254757-ENG255615,Lf_antenna_eight_detune_counter-Detune_counter,0,
ENG254758-MAS00106,Lf_antenna_five_detune_counter-Year,2000,
ENG254758-MAS00107,Lf_antenna_five_detune_counter-Month,0,
ENG254758-MAS00108,Lf_antenna_five_detune_counter-Day,0,
ENG254758-MAS00109,Lf_antenna_five_detune_counter-Hours,0,
ENG254758-MAS00110,Lf_antenna_five_detune_counter-Minutes,0,
ENG254758-MAS00111,Lf_antenna_five_detune_counter-Seconds,0,
ENG254758-ENG255615,Lf_antenna_five_detune_counter-Detune_counter,0,
ENG254759-MAS00106,Lf_antenna_four_detune_counter-Year,2000,
ENG254759-MAS00107,Lf_antenna_four_detune_counter-Month,0,
ENG254759-MAS00108,Lf_antenna_four_detune_counter-Day,0,
ENG254759-MAS00109,Lf_antenna_four_detune_counter-Hours,0,
ENG254759-MAS00110,Lf_antenna_four_detune_counter-Minutes,0,
ENG254759-MAS00111,Lf_antenna_four_detune_counter-Seconds,0,
ENG254759-ENG255615,Lf_antenna_four_detune_counter-Detune_counter,0,
ENG254760-MAS00106,Lf_antenna_one_detune_counter-Year,2000,
ENG254760-MAS00107,Lf_antenna_one_detune_counter-Month,0,
ENG254760-MAS00108,Lf_antenna_one_detune_counter-Day,0,
ENG254760-MAS00109,Lf_antenna_one_detune_counter-Hours,0,
ENG254760-MAS00110,Lf_antenna_one_detune_counter-Minutes,0,
ENG254760-MAS00111,Lf_antenna_one_detune_counter-Seconds,0,
ENG254760-ENG255615,Lf_antenna_one_detune_counter-Detune_counter,0,
ENG254761-MAS00106,Lf_antenna_seven_detune_counter-Year,2000,
ENG254761-MAS00107,Lf_antenna_seven_detune_counter-Month,0,
ENG254761-MAS00108,Lf_antenna_seven_detune_counter-Day,0,
ENG254761-MAS00109,Lf_antenna_seven_detune_counter-Hours,0,
ENG254761-MAS00110,Lf_antenna_seven_detune_counter-Minutes,0,
ENG254761-MAS00111,Lf_antenna_seven_detune_counter-Seconds,0,
ENG254761-ENG255615,Lf_antenna_seven_detune_counter-Detune_counter,0,
ENG254762-MAS00106,Lf_antenna_six_detune_counter-Year,2000,
ENG254762-MAS00107,Lf_antenna_six_detune_counter-Month,0,
ENG254762-MAS00108,Lf_antenna_six_detune_counter-Day,0,
ENG254762-MAS00109,Lf_antenna_six_detune_counter-Hours,0,
ENG254762-MAS00110,Lf_antenna_six_detune_counter-Minutes,0,
ENG254762-MAS00111,Lf_antenna_six_detune_counter-Seconds,0,
ENG254762-ENG255615,Lf_antenna_six_detune_counter-Detune_counter,0,
ENG254763-MAS00106,Lf_antenna_three_detune_counter-Year,2000,
ENG254763-MAS00107,Lf_antenna_three_detune_counter-Month,0,
ENG254763-MAS00108,Lf_antenna_three_detune_counter-Day,0,
ENG254763-MAS00109,Lf_antenna_three_detune_counter-Hours,0,
ENG254763-MAS00110,Lf_antenna_three_detune_counter-Minutes,0,
ENG254763-MAS00111,Lf_antenna_three_detune_counter-Seconds,0,
ENG254763-ENG255615,Lf_antenna_three_detune_counter-Detune_counter,0,
ENG254764-MAS00106,Lf_antenna_two_detune_counter-Year,2000,
ENG254764-MAS00107,Lf_antenna_two_detune_counter-Month,0,
ENG254764-MAS00108,Lf_antenna_two_detune_counter-Day,0,
ENG254764-MAS00109,Lf_antenna_two_detune_counter-Hours,0,
ENG254764-MAS00110,Lf_antenna_two_detune_counter-Minutes,0,
ENG254764-MAS00111,Lf_antenna_two_detune_counter-Seconds,0,
ENG254764-ENG255615,Lf_antenna_two_detune_counter-Detune_counter,0,
ENG254789-MAS00106,Over_temperature_counter_lf_driver-Year,2000,
ENG254789-MAS00107,Over_temperature_counter_lf_driver-Month,0,
ENG254789-MAS00108,Over_temperature_counter_lf_driver-Day,0,
ENG254789-MAS00109,Over_temperature_counter_lf_driver-Hours,0,
ENG254789-MAS00110,Over_temperature_counter_lf_driver-Minutes,0,
ENG254789-MAS00111,Over_temperature_counter_lf_driver-Seconds,0,
ENG254789-ENG256116,Over_temperature_counter_lf_driver-Over_temperature_counter,0, counts
ENG108452,Reset_counter,8,
ENG254855-MAS19582,WUP_measurement_historie-Learned wake pattern,0,
ENG254855-MAS19582,WUP_measurement_historie-Learned wake pattern,2161937893,
ENG254855-MAS19582,WUP_measurement_historie-Learned wake pattern,2006232112,
ENG254855-ENG103063,WUP_measurement_historie-Mileage,0, km
ENG254855-ENG103063,WUP_measurement_historie-Mileage,16777215, km
Elapsed Time: 00:07
blockmap-08-5WA-907-727-BC_VSSZZZKM2RR140480-20241020-1502.CSV
;SW:5WA-907-727-BC   HW:5WA-907-727-BC ---  Auto HVAC
;Component:Climatronic   H02 0462, Coding:000100010011020010100010101011110000112100200000000000000000
;EV_ACClimaBHBVW38X,005069,EV_ACClimaBHBVW38X_SE38.rod
;Sunday,20,October,2024,15:02:20:49859
;VCID: 127A638844E3ADAAF9F-8046
IDE00019,Voltage terminal 30,11.90, V
IDE00021,Engine RPM,0.0, /min
IDE00025,Coolant temperature,58.00, °C
IDE00085,Normed load value,0.000, %
IDE00097,OBD - requirements for which this vehicle is designed,0,
IDE00198,Refrigerant pressure,5.60, bar
IDE00323,Security Access: Number of invalid keys,1,
IDE00323-ENG127697,Security Access: Number of invalid keys-Counter_2,0,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not active,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not active,
IDE00445,Unlearning counter according OBD,0,
IDE00601,Monitoring status since erasing DTC memory,65281,
IDE00602,Monitoring status in current driving cycle,65281,
IDE00965,Compressor shut-off condition,Engine running time too short: engine start not detected by CAN,
IDE00966,Compressor current: actual value,0.0, A
IDE00967,Compressor current: specified value,0.0, A
IDE00968,Compressor speed,0.0, /min
IDE00969,Compressor load,0.0, Nm
IDE00970,Coolant fan activation: actual value,10.00, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside temperature,16.00, °C
IDE00974,Outside air temperature internally calculated,15.50, °C
IDE00976,Left front vent temperature,22.00, °C
IDE00977,Right front vent temperature,21.00, °C
IDE00981,Footwell vent temperature,20.0, °C
IDE00982,Temperature downstream of evaporator,16.00, °C
IDE00983,Inside temperature,23.20, °C
IDE00984,Sun intensity left,50.00, W/m²
IDE00985,Sun intensity right,50.00, W/m²
IDE00987,Blower voltage: specified value,3.90, V
IDE00989,Blower status,active,
IDE00994,Actual value for fresh air/recirculation air flow flap,160,
IDE00994,Actual value for fresh air/recirculation air flow flap,68.0, %
IDE00995,Fresh air/recirculating air/back pressure door specified value,159,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,43,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,215,
IDE00998,Left temperature flap - actual value,92.0, %
IDE00998,Left temperature flap - actual value,212,
IDE00999,Temperature door left - Specified value,213,
IDE01040,Left Temperature Control Door - cold stop,28,
IDE01041,Left temperature flap: warm stop,228,
IDE01042,Right temperature flap: actual value,211,
IDE01042,Right temperature flap: actual value,91.5, %
IDE01043,Temperature door right - Specified value,212,
IDE01044,Right temperature flap: cold stop,27,
IDE01045,Right temperature flap: warm stop,228,
IDE01050,Front air distribution flap: actual value,192,
IDE01050,Front air distribution flap: actual value,80.0, %
IDE01051,Air distribution door front - Specified value,193,
IDE01052,Front air distribution flap: air outlet stop,25,
IDE01053,Front air distribution flap: footwell air outlet stop,233,
IDE01054,Defroster flap: actual value,233,
IDE01054,Defroster flap: actual value,100.0, %
IDE01055,Defrost door - Specified value,237,
IDE01056,Defroster flap: stop open,27,
IDE01057,Defroster flap: stop closed,232,
IDE01063,Status of recirculation air,recirc. due to back pressure portion,
IDE01065,Rear vent temperature,22.00, °C
IDE01069,Rear blower voltage: specified value,0.0, V
IDE01076,Time since ignition off,51, min
IDE01088,Rear temperature flap: actual value,182,
IDE01088,Rear temperature flap: actual value,74.5, %
IDE01089,Rear temperature flap: specified value,183,
IDE01090,Rear temperature flap: cold stop,21,
IDE01091,Rear temperature flap: warm stop,237,
IDE01226,Blower voltage: actual value,3.90, V
IDE01227,Blower current,0.75, A
IDE01232,Supply voltage for external components,4.9, V
IDE01264,Remaining time of parking heater/ventilation operation,10, s
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,2,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,2,
IDE01419,Compressor shut-off condition: last,Shut-off from Engine Control Module (ECM) via CAN,
IDE01420,Compressor shut-off requirement: penultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01421,Compressor shut-off requirement: antepenultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01433,Air quality status,not installed,
IDE01442-MAS01533,Pressing a button-Defrost,Not operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,Not operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,Not operated,
IDE01442-MAS01550,Pressing a button-AC,operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,Not operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,Not operated,
IDE01442-MAS01560,Pressing a button-OFF,Not operated,
IDE01442-MAS01564,Pressing a button-Front windshield heater,Not operated,
IDE01442-MAS01577,Pressing a button-Parking heater,operated,
IDE01442-MAS02015,Pressing a button-AUTO,Not operated,
IDE01442-MAS02192,Pressing a button-SYNC,Not operated,
IDE01442-MAS03196,Pressing a button-Menu,Not operated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,Not operated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,Not operated,
IDE01442-MAS03832,Pressing a button-Air distribution up,Not operated,
IDE01442-MAS04605,Pressing a button-AC MAX,Not operated,
IDE01448,Actual value of heated front window,not coded/not installed,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,not coded/not installed,
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,not coded/not installed,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,OFF,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,not coded/not installed,
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,20.40, °C
IDE01540-MAS07052,Left front heated seat-Setting,OFF,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,9.57, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,0.00, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,not coded/not installed,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,not coded/not installed,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not coded/not installed,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not coded/not installed,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,not coded/not installed,
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.30, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,not coded/not installed,
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,not coded/not installed,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,OFF,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,not coded/not installed,
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,21.10, °C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,9.27, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0.00, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,not coded/not installed,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,not coded/not installed,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not coded/not installed,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded/not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,not coded/not installed,
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,OFF,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,OFF,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,Unknown (210)
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),0, mA
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),0, mA
IDE01694-MAS01767,Left rear heated seat-Left rear seat heater stage,0,
IDE01694-MAS01768,Left rear heated seat-Left rear seat heater specified temperature,-50.0, °C
IDE01694-MAS01769,Left rear heated seat-Left rear seat heater actual temperature,-50.0, °C
IDE01694-MAS01770,Left rear heated seat-Left rear seat heater current,0.00, A
IDE01695-MAS01771,Right rear heated seat-Right rear seat heater stage,0,
IDE01695-MAS01772,Right rear heated seat-Right rear seat heater specified temperature,-50.0, °C
IDE01695-MAS01773,Right rear heated seat-Right rear seat heater actual temperature,-50.0, °C
IDE01695-MAS01774,Right rear heated seat-Right rear seat heater current,0.00, A
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,Not available,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,OFF,
IDE03008-IDE80251,Stop process prevented-Head area heater,not active,
IDE03008-MAS01564,Stop process prevented-Front windshield heater,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Blowout temperature difference to specifications,active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxil. heat mode,not active,
IDE03008-MAS05046,Stop process prevented-Evaporator temperature difference to specifications,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03010-IDE80251,Number of prevented stop processes-Head area heater,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Front windshield heater,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,0,
IDE03010-MAS02803,Number of prevented stop processes-Blowout temperature difference to specifications,0,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxil. heat mode,0,
IDE03010-MAS05046,Number of prevented stop processes-Evaporator temperature difference to specifications,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,0,
IDE03011-IDE80251,Number of requested start processes-Head area heater,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Front windshield heater,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Blowout temperature difference to specifications,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS03904,Number of requested start processes-Maximum permissible stop duration reached,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxil. heat mode,0,
IDE03011-MAS05046,Number of requested start processes-Evaporator temperature difference to specifications,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,0, s
IDE04312-MAS00084,System run time-Terminal 15 on,253, s
IDE05533,Heater for nozzles,not coded/not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,19.50, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,19.00, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,75.50, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,15.50, °C
IDE06233-MAS01632,Auxiliary heater: controlled-Status,Unknown (210)
IDE06233-MAS03746,Auxiliary heater: controlled-Current: actual value,10,
IDE06233-MAS04625,Auxiliary heater: controlled-Power: actual value,2420.00,
IDE06233-MAS04626,Auxiliary heater: controlled-Power: target value,0.00,
IDE06234-IDE01270,Auxiliary heater: in stages-Enabling for auxiliary heater operation,No enabling,
IDE06234-MAS01447,Auxiliary heater: in stages-Act.val.,0,
IDE06234-MAS01448,Auxiliary heater: in stages-Target value,0,
IDE06234-MAS04992,Auxiliary heater: in stages-Specified value for control,0,
IDE06235,Potentiometer for rear vent temperature,0.0, Nm
IDE06307-MAS00106,Stop prevention history data-Year,2000, yr
IDE06307-MAS00107,Stop prevention history data-Month,0, Months
IDE06307-MAS00108,Stop prevention history data-Day,0, d
IDE06307-MAS00109,Stop prevention history data-Hours,0, H
IDE06307-MAS00110,Stop prevention history data-Minutes,0, min
IDE06307-MAS00111,Stop prevention history data-Seconds,0, s
IDE06307-MAS01517,Stop prevention history data-Defrost active,not active,
IDE06307-MAS01564,Stop prevention history data-Front windshield heater,not active,
IDE06307-MAS02802,Stop prevention history data-Interior temperature difference to specifications,not active,
IDE06307-MAS02803,Stop prevention history data-Blowout temperature difference to specifications,not active,
IDE06307-MAS02804,Stop prevention history data-Manual fan speed increase,not active,
IDE06307-MAS04353,Stop prevention history data-Fogging hazard (humidity sensor),not active,
IDE06307-MAS04354,Stop prevention history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06307-MAS05009,Stop prevention history data-A/C request: auxil. heat mode,not active,
IDE06307-MAS05046,Stop prevention history data-Evaporator temperature difference to specifications,not active,
IDE06307-MAS05047,Stop prevention history data-Maximum cooling and heating set,not active,
IDE06307-MAS06551,Stop prevention history data-Seat ventilation,not active,
IDE06307-MAS09538,Stop prevention history data-max A/C,not active,
IDE06308-MAS00106,Start request history data-Year,2000, yr
IDE06308-MAS00107,Start request history data-Month,0, Months
IDE06308-MAS00108,Start request history data-Day,0, d
IDE06308-MAS00109,Start request history data-Hours,0, H
IDE06308-MAS00110,Start request history data-Minutes,0, min
IDE06308-MAS00111,Start request history data-Seconds,0, s
IDE06308-MAS01517,Start request history data-Defrost active,not active,
IDE06308-MAS01564,Start request history data-Front windshield heater,not active,
IDE06308-MAS02802,Start request history data-Interior temperature difference to specifications,not active,
IDE06308-MAS02803,Start request history data-Blowout temperature difference to specifications,not active,
IDE06308-MAS02804,Start request history data-Manual fan speed increase,not active,
IDE06308-MAS03904,Start request history data-Maximum permissible stop duration reached,not active,
IDE06308-MAS04353,Start request history data-Fogging hazard (humidity sensor),not active,
IDE06308-MAS04354,Start request history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06308-MAS05009,Start request history data-A/C request: auxil. heat mode,not active,
IDE06308-MAS05046,Start request history data-Evaporator temperature difference to specifications,not active,
IDE06308-MAS05047,Start request history data-Maximum cooling and heating set,not active,
IDE06308-MAS06551,Start request history data-Seat ventilation,not active,
IDE06308-MAS09538,Start request history data-max A/C,not active,
IDE06545,Blower voltage for production routines,6.0, V
IDE06546,Interior specified temperature for production routines,22, °C
IDE06547,Air distribution for production routines,No effect,
IDE06593,Air recirculation for production routines,No effect,
IDE07991-MAS04446,A/C clutch-Relay activation status,not active,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,OFF,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,OFF,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Parallel activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Parallel activation of backrest and seat cushion,
IDE09189-IDE09201,HV heater temperature-Intake temperature,Malfunction,
IDE09189-IDE09202,HV heater temperature-Exhaust Temperature,Malfunction,
IDE10300,OBD Driving Cycle detected,Unknown (255)
IDE11383-IDE01233,Compressor: system monitor-Compressor motor current,Initialization,
IDE11383-MAS05976,Compressor: system monitor-A/C compressor: inverter temperature,128.00, °C
IDE11383-MAS05978,Compressor: system monitor-High voltage supply voltage,Initialization,
IDE11383-MAS05979,Compressor: system monitor-A/C compressor: start-up monitor,Malfunction,
IDE11383-MAS12656,Compressor: system monitor-A/C compressor: Inverter temperature status,Sensor test running,
IDE11455-MAS11114,Range consumption forecast-Time to transition from dynamic to steady-state operation,240, min
IDE11455-MAS11115,Range consumption forecast-Change in the prediction initiated by customer action,202,
IDE11455-MAS11116,Range consumption forecast-Dynamic power for heating/cooling,650020.00, W
IDE11455-MAS11117,Range consumption forecast-Steady-state power for heating/cooling,650020.00, W
IDE11455-MAS11118,Range consumption forecast-Consumption for heating and cooling of the components,65002, Ws
IDE11455-MAS11119,Range consumption forecast-Overflow-bit component consumption,Unknown (202)
IDE11455-MAS11120,Range consumption forecast-Consumption for heating and cooling of the interior,65002, Ws
IDE11455-MAS13274,Range consumption forecast-Overflow-bit interior consumption,Unknown (202)
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,0.00, W/m²
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,not coded/not installed,
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,23.000, °C
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,not coded/not installed,
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,not coded/not installed,
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,not coded/not installed,
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,not coded/not installed,
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,not coded/not installed,
IDE11795,Supply voltage 2 for external components,4.9, V
IDE11836,Query of the supported PIDs (0x01 - 0x20),2551709713,
IDE11837,Query of the supported PIDs (0x21 - 0x40),1,
IDE11838,Query of the supported PIDs (0x41 - 0x60),3296722944,
IDE11839,Query of the supported InfoTypes (0x01 - 0x20),339738624,
IDE12141-MAS00106,History memory: parking heater-Year,2000, yr
IDE12141-MAS00107,History memory: parking heater-Month,0, Months
IDE12141-MAS00108,History memory: parking heater-Day,0, d
IDE12141-MAS00109,History memory: parking heater-Hours,0, H
IDE12141-MAS00110,History memory: parking heater-Minutes,0, min
IDE12141-MAS00111,History memory: parking heater-Seconds,0, s
IDE12141-MAS02526,History memory: parking heater-Activation,Unknown (0)
IDE12141-MAS04390,History memory: parking heater-Active source,Unknown (0)
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,not active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load management,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside air temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14625,A/C compressor initial running in: interruption conditions-High-voltage vehicle electrical system,not active,
IDE12500-MAS14626,A/C compressor initial running in: interruption conditions-High-voltage current limitations,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
IDE13845,Production mode status,not active,
IDE14095,Wiper park position heater,not coded/not installed,
IDE14804-MAS19258,A/C Compressor compatibility monitor-Activated numbers of error screen in climate control module,Malfunction,
IDE14804-MAS19259,A/C Compressor compatibility monitor-Number of A/C Compressor error display from last routine,255,
IDE14804-MAS19260,A/C Compressor compatibility monitor-Number of error display for A/C Compressor: actual value,255,
IDE14804-MAS19261,A/C Compressor compatibility monitor-Activated error display in climate control module: status,Not qualified,
IDE14804-MAS19262,A/C Compressor compatibility monitor-Number of disrupted standard comparisons,0,
IDE80001,Analysis 1,0,
IDE80001,Analysis 1,Malfunction,
IDE80001,Analysis 1,65280,
IDE80002,Analysis 2,Malfunction,
IDE80002,Analysis 2,0,
IDE80002,Analysis 2,65280,
IDE80003,Analysis 3,0,
IDE80003,Analysis 3,Malfunction,
IDE80003,Analysis 3,65280,
IDE80101-IDE80001,Analysis 101-Analysis 1,FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80101-IDE80002,Analysis 101-Analysis 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80101-IDE80003,Analysis 101-Analysis 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80101-IDE80004,Analysis 101-Analysis 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80101-IDE80005,Analysis 101-Analysis 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00194,---,Initialization,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,1,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,26,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,57,
MAS11295,Refrigerant temperature,3200.2, °C
MAS11297-MAS01379,Standstilll A/C: customer setting-Operating time,10, min
MAS11298,Standstilll A/C remaining run time,0, s
Elapsed Time: 00:18
blockmap-09-5WA-937-086-BS_VSSZZZKM2RR140480-20241020-1503.CSV
;SW:5WA-937-086-BS   HW:5WA-937-086-BA ---  Cent. Elect.
;Component:BCM37w_M1134 0183, Coding:
;EV_BCM37w,007001,EV_BCM37w_007_AU38.rod
;Sunday,20,October,2024,15:03:12:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 2314364CAB59D422629-8076
Group,Description,Actual
IDE00001,Production mode,not active,
IDE00301,Mileage,1626, km
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,none,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Initialization,
IDE00973,Outside temperature,16.0, °C
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,active,
IDE01992-SFT00183,Installation list: current installations-Interface for access/start system,active,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,active,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,active,
IDE01992-SFT33031,Installation list: current installations-Antenna module,not active,
IDE01992-SFT33054,Installation list: current installations-Burglary Protection Control Module FL,active,
IDE01992-SFT33055,Installation list: current installations-Burglary Protection Control Module FR,active,
IDE01992-SFT33056,Installation list: current installations-Burglary Protection Control Module RL,active,
IDE01992-SFT33057,Installation list: current installations-Burglary Protection Control Module RR,active,
IDE01992-SFT33058,Installation list: current installations-Burglary Protection Control Module interior,not active,
IDE01996-SFT00009,Installation list: specified installations-Electronic central electric,active,
IDE01996-SFT00183,Installation list: specified installations-Interface for access/start system,active,
IDE01996-SFT00214,Installation list: specified installations-Light Control Left 2,active,
IDE01996-SFT00215,Installation list: specified installations-Light Control Right 2,active,
IDE01996-SFT33031,Installation list: specified installations-Antenna module,not active,
IDE01996-SFT33054,Installation list: specified installations-Burglary Protection Control Module FL,active,
IDE01996-SFT33055,Installation list: specified installations-Burglary Protection Control Module FR,active,
IDE01996-SFT33056,Installation list: specified installations-Burglary Protection Control Module RL,active,
IDE01996-SFT33057,Installation list: specified installations-Burglary Protection Control Module RR,active,
IDE01996-SFT33058,Installation list: specified installations-Burglary Protection Control Module interior,not active,
IDE02711-IDE05228,Rear wiper-Operating hour counter,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE02711-MAS01632,Rear wiper-Status,not active,
IDE02711-MAS20299,Rear wiper-Wiper level: steering column switch module,switched off,
IDE02711-MAS20300,Rear wiper-Actual wiper level,not active,
IDE02745-IDE00096,Ignition Switch Key Lock Solenoid-Selector lever position,Selector lever in position P,
IDE02745-MAS08205,Ignition Switch Key Lock Solenoid-CAN ESP valid speed,Qualified,
IDE02745-MAS08206,Ignition Switch Key Lock Solenoid-CAN ESP speed,0.00, km/h
IDE02857-IDE03111,Activation current-Interior lighting,1, mA
IDE02857-IDE06012,Activation current-Background lighting,0, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,Measuring value not available,
IDE02857-ENG126436,Activation current-signal_horn,Measuring value not available,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,not ready for sleep,
IDE03150-SFT00183,Readiness for bus sleep mode-Interface for access/start system,not ready for sleep,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,Ready For Sleep,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,Ready For Sleep,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna module,Ready For Sleep,
IDE03150-SFT33054,Readiness for bus sleep mode-Burglary Protection Control Module FL,not ready for sleep,
IDE03150-SFT33055,Readiness for bus sleep mode-Burglary Protection Control Module FR,not ready for sleep,
IDE03150-SFT33056,Readiness for bus sleep mode-Burglary Protection Control Module RL,not ready for sleep,
IDE03150-SFT33057,Readiness for bus sleep mode-Burglary Protection Control Module RR,not ready for sleep,
IDE03150-SFT33058,Readiness for bus sleep mode-Burglary Protection Control Module interior,Ready For Sleep,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE05742,Expanded freeze frame conditions-Light switch position,automatic,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,16.0, °C
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.1, V
IDE04347-MAS09388,Expanded freeze frame conditions-Engine run,OFF,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04639,Last wake-up cause,Radio telegram: valid,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,22.0, %
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS01364,Front wiper module-Stage 1,not active,
IDE05045-MAS01365,Front wiper module-Stage 2,not active,
IDE05045-MAS03638,Front wiper module-Wipe speed,0 revolutions per minute,
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,10800,
IDE05045-MAS05878,Front wiper module-Stage,not coded/not installed,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not coded/not installed,
IDE05834-MAS00214,Driver info-Brake pad wear,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,not coded/not installed,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,7600, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,1824, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,19.7, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,19.5, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,76.0, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,15.6, °C
IDE06507-MAS13127,Button in center console-Status of button 1,not coded/not installed,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,not coded/not installed,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded/not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded/not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE08211-MAS03129,History data control module reset-Reset counter,0,
IDE08211,History data control module reset,|last cause of reset,Year
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,1C,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,F8,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,F8,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,Yes,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,Yes,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,0,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,0,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,0,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,0,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,0,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,0,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,0,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,32 D2 6D B1,
IDE08240,Transponder ID Key 2,5C A3 6D B1,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,00 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00,
IDE08251-MAS11095,Configuration immobilizer-Cause,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,03 89 A4 1C,
IDE08343,Immobilizer Challenge,A7 A4 4B CF,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,28, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,28, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07893,Operating current: light driver-Conn. pin 26,32, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS20146,Operating current: light driver-Conn. pin 35,0, mA
IDE08949-MAS20147,Operating current: light driver-Conn. pin 36,0, mA
IDE08949-MAS20148,Operating current: light driver-Conn. pin 37,0, mA
IDE08949-MAS20149,Operating current: light driver-Conn. pin 38,0, mA
IDE08949-MAS20150,Operating current: light driver-Conn. pin 39,0, mA
IDE08949-MAS20151,Operating current: light driver-Conn. pin 40,0, mA
IDE08949-MAS20152,Operating current: light driver-Conn. pin 41,0, mA
IDE08949-MAS21233,Operating current: light driver-Conn. pin 42,0, mA
IDE08949-MAS21234,Operating current: light driver-Conn. pin 43,0, mA
IDE08949-MAS21235,Operating current: light driver-Conn. pin 45,0, mA
IDE08949-MAS21236,Operating current: light driver-Conn. pin 44,142, mA
IDE10345-IDE00673,Roof electronics control module: button-Information Service Button -E450-,Not operated,
IDE10345-MAS08884,Roof electronics control module: button-Sunroof button,Not operated,
IDE10345-MAS08932,Roof electronics control module: button-Sunroof shade button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,50, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,60, W/m²
IDE11551-MAS03619,Status of identification data query on LIN-Bus-complete,Yes,
IDE11551-MAS11095,Status of identification data query on LIN-Bus-Cause,Terminal 15 on,
IDE11551-MAS12667,Status of identification data query on LIN-Bus-Specified installation of sub-bus users,10,
IDE11551-MAS12668,Status of identification data query on LIN-Bus-Actual installation of sub-bus users,12,
IDE11727-MAS13125,Function of the central console button-Function of button 1,not coded/not installed,
IDE11727-MAS13128,Function of the central console button-Indicator lamp button 1,installed,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13131,Function of the central console button-Indicator lamp button 2,installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded/not installed,
IDE11727-MAS13134,Function of the central console button-Indicator lamp button 3,installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11727-MAS13136,Function of the central console button-Indicator lamp button 4,installed,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,0,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,FB 1A 14 D8,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,Not operated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 1,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE13750-IDE01351,Input signals: control of terminal-Terminal 75 status,On,
IDE13750-IDE01715,Input signals: control of terminal-Status terminal S,not coded/not installed,
IDE13750-IDE01716,Input signals: control of terminal-Terminal 50 status,OFF,
IDE13750-IDE02572,Input signals: control of terminal-Starter button: status,not active,
IDE13750-IDE13954,Input signals: control of terminal-Starter button: status redundant,not active,
IDE13750-MAS12787,Input signals: control of terminal-Terminal 15 ignition switch signal 1,not coded/not installed,
IDE13750-MAS12788,Input signals: control of terminal-Terminal 15 ignition switch signal 2,not coded/not installed,
IDE13750-MAS17227,Input signals: control of terminal-Starter button: error status,No malfunction detected,
IDE13750-MAS17233,Input signals: control of terminal-Terminal start command,not coded/not installed,
IDE13751-IDE00020,Output signals: control of terminal-Terminal 15 status,active,
IDE13751-IDE00773,Output signals: control of terminal-Terminal 15 status via CAN,active,
IDE13751-IDE06027,Output signals: control of terminal-Terminal S status via CAN,active,
IDE13751-ENG256402,Output signals: control of terminal-Status_Terminal_Startwunsch_BCM,not active,
IDE13751-ENG255221,Output signals: control of terminal-Terminal_50_CAN,not active,
IDE13752-IDE09059,Electrical Steering Column Lock-Request terminal release,not active,
IDE13752-MAS06711,Electrical Steering Column Lock-Terminal release,active,
IDE13752-MAS17234,Electrical Steering Column Lock-Steering column lock locked,not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,VSSZZZKM2RR140480,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE13956-IDE00075,Key position replication: input signals-Vehicle speed,0.00, km/h
IDE13956-IDE01715,Key position replication: input signals-Status terminal S,On,
IDE13956-IDE80258,Key position replication: input signals-Immobilizer status,Electronic steering locking device not installed,
IDE13956-MAS01493,Key position replication: input signals-Engine running,not active,
IDE13956-MAS02248,Key position replication: input signals-Signal state,valid,
IDE13956-MAS03607,Key position replication: input signals-Engine stop active in Start/Stop mode,not active,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS05104,Key position replication: input signals-Driver request: start engine,not active,
IDE13956-MAS06711,Key position replication: input signals-Terminal release,not active,
IDE13956-MAS06793,Key position replication: input signals-Number of adapted keys,2,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-MAS08136,Key position replication: input signals-Enabling Steering Column Lock,Condition not met,
IDE13956,Key position replication: input signals,0, s
IDE13956-ENG255532,Key position replication: input signals-clampcoordinator_approval,On,
IDE13956-ENG255625,Key position replication: input signals-diag_trigger_clampcoordinator_intern,OFF,
IDE13956-ENG256242,Key position replication: input signals-Powertrain_activation_permitted,Yes,
IDE13956-ENG129033,Key position replication: input signals-s_anf_klemmenfreigabe_wfs,not requested,
IDE13956-ENG126972,Key position replication: input signals-s_klemmenfreigabe_wfs,No enabling,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG256549,Key position replication: input signals-trigger_clampcoordinator_intern_for_ignition_off,OFF,
IDE13956-ENG256550,Key position replication: input signals-trigger_clampkoordinator_intern_for_ignition_on,OFF,
IDE13956-ENG256551,Key position replication: input signals-Trigger_terminal_15_shutoff,No,
IDE13956-ENG129038,Key position replication: input signals-Valid_time_control_section_diagnostics,0, s
IDE14238-MAS02282,Wiper arm position-Position,0.0, °
IDE14238-MAS19580,Wiper arm position-Alternating park position,Alternating park position 1,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 07,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 20 9A 17 E9 9B 45 D8,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 07,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14958-SFT00002,Recognized actual fitting list: adapt-Transmission Electronics,detected,
IDE14958-SFT00005,Recognized actual fitting list: adapt-Access/start authorization,detected,
IDE14958-SFT00006,Recognized actual fitting list: adapt-Seat adjustment: passenger's side,not detected,
IDE14958-SFT00008,Recognized actual fitting list: adapt-Climate Control Module,detected,
IDE14958-SFT00023,Recognized actual fitting list: adapt-Instrument cluster,detected,
IDE14958-SFT00025,Recognized actual fitting list: adapt-Data Bus OBD Interface,detected,
IDE14958-SFT00038,Recognized actual fitting list: adapt-Convertible top operation,not detected,
IDE14958-SFT00043,Recognized actual fitting list: adapt-Steering column lock,detected,
IDE14958-SFT00054,Recognized actual fitting list: adapt-Seat adjustment: driver side,detected,
IDE14958-SFT00061,Recognized actual fitting list: adapt-Special Function,not detected,
IDE14958-SFT00096,Recognized actual fitting list: adapt-Trip recorder,not detected,
IDE14958-SFT00105,Recognized actual fitting list: adapt-Trailer Function,not detected,
IDE14958-SFT00106,Recognized actual fitting list: adapt-Automatic door: rear driver side,not detected,
IDE14958-SFT00109,Recognized actual fitting list: adapt-Rear lid electronics,not detected,
IDE14958-SFT00122,Recognized actual fitting list: adapt-Automatic door: rear passenger side,not detected,
IDE14958-SFT00165,Recognized actual fitting list: adapt-Front sensor for drivers assistant systems,detected,
IDE14958-SFT00202,Recognized actual fitting list: adapt-Sunroof control module,not detected,
IDE14958-SFT00214,Recognized actual fitting list: adapt-Light Control Left 2,detected,
IDE14958-SFT00215,Recognized actual fitting list: adapt-Light Control Right 2,detected,
IDE14958-SFT33031,Recognized actual fitting list: adapt-Antenna module,not detected,
IDE14958-SFT33054,Recognized actual fitting list: adapt-Burglary Protection Control Module FL,detected,
IDE14958-SFT33055,Recognized actual fitting list: adapt-Burglary Protection Control Module FR,detected,
IDE14958-SFT33056,Recognized actual fitting list: adapt-Burglary Protection Control Module RL,detected,
IDE14958-SFT33057,Recognized actual fitting list: adapt-Burglary Protection Control Module RR,detected,
IDE14958-SFT33058,Recognized actual fitting list: adapt-Burglary Protection Control Module interior,not detected,
IDE14958-SFT271890,Recognized actual fitting list: adapt-Driver door control module,detected,
IDE14958-SFT271891,Recognized actual fitting list: adapt-Front passenger door control module,detected,
IDE14958-SFT271948,Recognized actual fitting list: adapt-Rear Driver Side Door Control Module,detected,
IDE14958-SFT271949,Recognized actual fitting list: adapt-Rear Passenger Door Control Module,detected,
IDE14958-SFT272107,Recognized actual fitting list: adapt-Antenna for short-range communication,not detected,
IDE14958-SFT272139,Recognized actual fitting list: adapt-Antenna 2 for short-range communication,not detected,
IDE14959,Tailgate opening: reason for non-availability,No release by access control,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 41,
IDE14993,Software composition list identification data,|Software Composition ID,System designation
IDE15048-ENG255825,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_CAN,none,
IDE15048-ENG255826,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_SR,none,
IDE15048-ENG255827,Output signals: terminal coordinator-KST_Request_Clamp_15,none,
IDE15048-ENG255828,Output signals: terminal coordinator-KST_Specialstate_Request_CAN,Initialization,
IDE15048-ENG255829,Output signals: terminal coordinator-KST_Specialstate_Request_SR,Initialization,
IDE15048-ENG255830,Output signals: terminal coordinator-KST_Specialstate_Status_CAN,Initialization,
IDE15048-ENG255831,Output signals: terminal coordinator-KST_Specialstate_Status_SR,Initialization,
IDE15049-IDE09065,Input signals: terminal coordinator-Status: remote start,Initialization,
IDE15049-MAS20292,Input signals: terminal coordinator-Key position reproduction: status,Initialization,
IDE15049-MAS20294,Input signals: terminal coordinator-Key position reproduction: terminal query,none,
IDE15049-MAS20297,Input signals: terminal coordinator-Key position replication: immobilizer request,none,
IDE15049-MAS20298,Input signals: terminal coordinator-Terminal 15 via diagnostic: query status,Initialization,
IDE15049-ENG263759,Input signals: terminal coordinator-AAA_Request_Clamp_15,none,
IDE15049-ENG263760,Input signals: terminal coordinator-AAA_Request_Immobiliser_Level,none,
IDE15049-ENG263761,Input signals: terminal coordinator-AAA_Request_Status,Initialization,
IDE15049-ENG263762,Input signals: terminal coordinator-MWS_Request_Clamp_15,none,
IDE15049-ENG263763,Input signals: terminal coordinator-MWS_Request_Immobiliser_Level,none,
IDE15049-ENG263764,Input signals: terminal coordinator-MWS_Request_Status,Initialization,
IDE15049-ENG263765,Input signals: terminal coordinator-PHP_Request_Clamp_15,none,
IDE15049-ENG263766,Input signals: terminal coordinator-PHP_Request_Immobiliser_Level,none,
IDE15049-ENG263767,Input signals: terminal coordinator-PHP_Request_Status,Initialization,
IDE15049-ENG263768,Input signals: terminal coordinator-RPA_Request_Clamp_15,none,
IDE15049-ENG263769,Input signals: terminal coordinator-RPA_Request_Immobiliser_Level,none,
IDE15049-ENG263770,Input signals: terminal coordinator-RPA_Request_Status,Initialization,
IDE15049-ENG263771,Input signals: terminal coordinator-RST_Request_Clamp_15,none,
IDE15049-ENG263772,Input signals: terminal coordinator-RST_Request_Immobiliser_Level,none,
IDE15049-ENG263773,Input signals: terminal coordinator-RWK_Request_Clamp_15,none,
IDE15049-ENG263774,Input signals: terminal coordinator-RWK_Request_Immobiliser_Level,none,
IDE15049-ENG263775,Input signals: terminal coordinator-RWK_Request_Status,Initialization,
IDE15049-ENG263776,Input signals: terminal coordinator-ZAS_Request_Clamp_15,none,
IDE15049-ENG263777,Input signals: terminal coordinator-ZAS_Request_Immobiliser_Level,none,
IDE15049-ENG263778,Input signals: terminal coordinator-ZAS_Request_Status,Initialization,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,12.05, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,12.05, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,12.05, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,12.05, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,16.55, V
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,73,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS06797,Immobilizer-Status configuration,15 00,
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-ENG299121,Immobilizer-Configuration_status_(interpreted),|Configuration Kessy coded,Configuration E vehicle
MAS00464-MAS00106,Standard - ambient data 1-Year,2024,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,20,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,42,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,1626, km
MAS12666-SFT271873,SubSystemNodeAddress of sub bus participant-Wiper motor control module,0x0001,
MAS12666-SFT271874,SubSystemNodeAddress of sub bus participant-Rain/Light Recognition Sensor,0x0002,
MAS12666-SFT271875,SubSystemNodeAddress of sub bus participant-Light switch,0x0003,
MAS12666-SFT271876,SubSystemNodeAddress of sub bus participant-Garage door opener control module,0x0004,
MAS12666-SFT271894,SubSystemNodeAddress of sub bus participant-Anti-theft alarm system sensor,0x0016,
MAS12666-SFT271896,SubSystemNodeAddress of sub bus participant-Alarm horn,0x0018,
MAS12666-SFT271909,SubSystemNodeAddress of sub bus participant-left tail lamp 1,0x0025,
MAS12666-SFT271910,SubSystemNodeAddress of sub bus participant-Roof electronics control module,0x0026,
MAS12666-SFT271947,SubSystemNodeAddress of sub bus participant-Humidity sensor: interior,0x004B,
MAS12666-SFT271950,SubSystemNodeAddress of sub bus participant-Rear lid opener control module,0x004E,
MAS12666-SFT271966,SubSystemNodeAddress of sub bus participant-Left head area heater,0x005E,
MAS12666-SFT271967,SubSystemNodeAddress of sub bus participant-Right head area heater,0x005F,
MAS12666-SFT272009,SubSystemNodeAddress of sub bus participant-Steering Column Switch,0x0089,
MAS12666-SFT272014,SubSystemNodeAddress of sub bus participant-Control head for driving and comfort functions,0x008E,
MAS12666-SFT272057,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat driver side,0x00B9,
MAS12666-SFT272061,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat passenger side,0x00BD,
MAS12666-SFT272065,SubSystemNodeAddress of sub bus participant-Blower 1 for left front backrest,0x00C1,
MAS12666-SFT272067,SubSystemNodeAddress of sub bus participant-Blower 1 for left front seat cushion,0x00C3,
MAS12666-SFT272069,SubSystemNodeAddress of sub bus participant-Blower 1 for right front backrest,0x00C5,
MAS12666-SFT272071,SubSystemNodeAddress of sub bus participant-Blower 1 for right front seat cushion,0x00C7,
MAS12666-SFT272107,SubSystemNodeAddress of sub bus participant-Antenna for short-range communication,0x00EB,
MAS12666-SFT272121,SubSystemNodeAddress of sub bus participant-Control unit 2 for driving and convenience functions,0x00F9,
MAS12666-SFT272139,SubSystemNodeAddress of sub bus participant-Antenna 2 for short-range communication,0x010B,
MAS12666-SFT272142,SubSystemNodeAddress of sub bus participant-left tail lamp 2,0x010E,
MAS12666-SFT272143,SubSystemNodeAddress of sub bus participant-Right rear tail lamp 1,0x010F,
MAS12666-SFT272144,SubSystemNodeAddress of sub bus participant-Right rear tail lamp 2,0x0110,
MAS12666-SFT272221,SubSystemNodeAddress of sub bus participant-Radio receiver for remote start,0x015D,
MAS12666-SFT272238,SubSystemNodeAddress of sub bus participant-Wiper motor control unit 2,0x016E,
MAS12666-SFT272272,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear driver side,0x0190,
MAS12666-SFT272286,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear passenger side,0x019E,
MAS12667-SFT271873,Specified installation of sub-bus users-Wiper motor control module,available.,
MAS12667-SFT271874,Specified installation of sub-bus users-Rain/Light Recognition Sensor,available.,
MAS12667-SFT271875,Specified installation of sub-bus users-Light switch,available.,
MAS12667-SFT271876,Specified installation of sub-bus users-Garage door opener control module,Not available,
MAS12667-SFT271894,Specified installation of sub-bus users-Anti-theft alarm system sensor,available.,
MAS12667-SFT271896,Specified installation of sub-bus users-Alarm horn,available.,
MAS12667-SFT271909,Specified installation of sub-bus users-left tail lamp 1,available.,
MAS12667-SFT271910,Specified installation of sub-bus users-Roof electronics control module,available.,
MAS12667-SFT271947,Specified installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12667-SFT271950,Specified installation of sub-bus users-Rear lid opener control module,Not available,
MAS12667-SFT271966,Specified installation of sub-bus users-Left head area heater,Not available,
MAS12667-SFT271967,Specified installation of sub-bus users-Right head area heater,Not available,
MAS12667-SFT272009,Specified installation of sub-bus users-Steering Column Switch,available.,
MAS12667-SFT272014,Specified installation of sub-bus users-Control head for driving and comfort functions,Not available,
MAS12667-SFT272057,Specified installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12667-SFT272061,Specified installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12667-SFT272065,Specified installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12667-SFT272067,Specified installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12667-SFT272069,Specified installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12667-SFT272071,Specified installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12667-SFT272107,Specified installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12667-SFT272121,Specified installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12667-SFT272139,Specified installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12667-SFT272142,Specified installation of sub-bus users-left tail lamp 2,available.,
MAS12667-SFT272143,Specified installation of sub-bus users-Right rear tail lamp 1,available.,
MAS12667-SFT272144,Specified installation of sub-bus users-Right rear tail lamp 2,Not available,
MAS12667-SFT272221,Specified installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12667-SFT272238,Specified installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12667-SFT272272,Specified installation of sub-bus users-Virtual pedal door opening: rear driver side,Not available,
MAS12667-SFT272286,Specified installation of sub-bus users-Virtual pedal door opening: rear passenger side,Not available,
MAS12668-SFT271873,Actual installation of sub-bus users-Wiper motor control module,available.,
MAS12668-SFT271874,Actual installation of sub-bus users-Rain/Light Recognition Sensor,available.,
MAS12668-SFT271875,Actual installation of sub-bus users-Light switch,available.,
MAS12668-SFT271876,Actual installation of sub-bus users-Garage door opener control module,Not available,
MAS12668-SFT271894,Actual installation of sub-bus users-Anti-theft alarm system sensor,available.,
MAS12668-SFT271896,Actual installation of sub-bus users-Alarm horn,available.,
MAS12668-SFT271909,Actual installation of sub-bus users-left tail lamp 1,available.,
MAS12668-SFT271910,Actual installation of sub-bus users-Roof electronics control module,available.,
MAS12668-SFT271947,Actual installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12668-SFT271950,Actual installation of sub-bus users-Rear lid opener control module,Not available,
MAS12668-SFT271966,Actual installation of sub-bus users-Left head area heater,Not available,
MAS12668-SFT271967,Actual installation of sub-bus users-Right head area heater,Not available,
MAS12668-SFT272009,Actual installation of sub-bus users-Steering Column Switch,available.,
MAS12668-SFT272014,Actual installation of sub-bus users-Control head for driving and comfort functions,Not available,
MAS12668-SFT272057,Actual installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12668-SFT272061,Actual installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12668-SFT272065,Actual installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12668-SFT272067,Actual installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12668-SFT272069,Actual installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12668-SFT272071,Actual installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12668-SFT272107,Actual installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12668-SFT272121,Actual installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12668-SFT272139,Actual installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12668-SFT272142,Actual installation of sub-bus users-left tail lamp 2,available.,
MAS12668-SFT272143,Actual installation of sub-bus users-Right rear tail lamp 1,available.,
MAS12668-SFT272144,Actual installation of sub-bus users-Right rear tail lamp 2,available.,
MAS12668-SFT272221,Actual installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12668-SFT272238,Actual installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12668-SFT272272,Actual installation of sub-bus users-Virtual pedal door opening: rear driver side,Not available,
MAS12668-SFT272286,Actual installation of sub-bus users-Virtual pedal door opening: rear passenger side,Not available,
MAS12669-SFT271873,Bus identification of sub-bus users-Wiper motor control module,Local data bus,
MAS12669-SFT271874,Bus identification of sub-bus users-Rain/Light Recognition Sensor,Local data bus,
MAS12669-SFT271875,Bus identification of sub-bus users-Light switch,Local data bus,
MAS12669-SFT271876,Bus identification of sub-bus users-Garage door opener control module,Local data bus 4,
MAS12669-SFT271894,Bus identification of sub-bus users-Anti-theft alarm system sensor,Local data bus 3,
MAS12669-SFT271896,Bus identification of sub-bus users-Alarm horn,Local data bus 2,
MAS12669-SFT271909,Bus identification of sub-bus users-left tail lamp 1,Local data bus 8,
MAS12669-SFT271910,Bus identification of sub-bus users-Roof electronics control module,Local data bus 3,
MAS12669-SFT271947,Bus identification of sub-bus users-Humidity sensor: interior,Local data bus,
MAS12669-SFT271950,Bus identification of sub-bus users-Rear lid opener control module,Local data bus 8,
MAS12669-SFT271966,Bus identification of sub-bus users-Left head area heater,Local data bus 4,
MAS12669-SFT271967,Bus identification of sub-bus users-Right head area heater,Local data bus 4,
MAS12669-SFT272009,Bus identification of sub-bus users-Steering Column Switch,Local data bus 6,
MAS12669-SFT272014,Bus identification of sub-bus users-Control head for driving and comfort functions,Local data bus,
MAS12669-SFT272057,Bus identification of sub-bus users-Valve block 1 in front seat driver side,Local data bus 4,
MAS12669-SFT272061,Bus identification of sub-bus users-Valve block 1 in front seat passenger side,Local data bus 4,
MAS12669-SFT272065,Bus identification of sub-bus users-Blower 1 for left front backrest,Local data bus 4,
MAS12669-SFT272067,Bus identification of sub-bus users-Blower 1 for left front seat cushion,Local data bus 4,
MAS12669-SFT272069,Bus identification of sub-bus users-Blower 1 for right front backrest,Local data bus 4,
MAS12669-SFT272071,Bus identification of sub-bus users-Blower 1 for right front seat cushion,Local data bus 4,
MAS12669-SFT272107,Bus identification of sub-bus users-Antenna for short-range communication,Data bus subCAN 1,
MAS12669-SFT272121,Bus identification of sub-bus users-Control unit 2 for driving and convenience functions,Local data bus 11,
MAS12669-SFT272139,Bus identification of sub-bus users-Antenna 2 for short-range communication,Data bus subCAN 1,
MAS12669-SFT272142,Bus identification of sub-bus users-left tail lamp 2,Local data bus 8,
MAS12669-SFT272143,Bus identification of sub-bus users-Right rear tail lamp 1,Local data bus 8,
MAS12669-SFT272144,Bus identification of sub-bus users-Right rear tail lamp 2,Local data bus 8,
MAS12669-SFT272221,Bus identification of sub-bus users-Radio receiver for remote start,Local data bus 6,
MAS12669-SFT272238,Bus identification of sub-bus users-Wiper motor control unit 2,Local data bus,
MAS12669-SFT272272,Bus identification of sub-bus users-Virtual pedal door opening: rear driver side,Local data bus 4,
MAS12669-SFT272286,Bus identification of sub-bus users-Virtual pedal door opening: rear passenger side,Local data bus 4,
MAS13141,Test voltage,0.00, V
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,available.,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0E 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,available.,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18843,SE references from last used digital key devices,|Secure_element_reference_state,Secure_element_reference
MAS18919-MAS17454,Engine hood contacts-Engine hood contact 2,not active,
MAS18919-MAS18918,Engine hood contacts-Engine hood contact 1,not active,
MAS25323,Ambient lighting: error locations,not installed,
ENG277599-MAS18508,ASIL_relevante_RDIDs-Number of nodes,41,
ENG277599,ASIL_relevante_RDIDs,|Adapted values/adaptation,Status of adaptation|0A 72
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
ENG263729,Dataset_download_written_rdids,|Data set ID,Number
ENG286564,Easy_open_HBFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG286565,Easy_open_HFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,11, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,21, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,5.1677, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,10800,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,58445,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,3,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG179902,Function_On_Demand_Freischalt_ID_Status_Dev,|ID number,Authentication
ENG286616,Last_LIN_Message_BCM_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286617,Last_LIN_Message_BCM_VIP_HFS,00 00 00 00 00 00 00 00,
ENG121906,Last_LIN_Message_Kessy,00 00 03 00 00 00 00 00,
ENG121907,Last_LIN_Message_LIN,00 00 00 00 00 00 00 00,
ENG286618,Last_LIN_Message_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286619,Last_LIN_Message_VIP_HFS,00 00 00 00 00 00 00 00,
ENG116804-ENG122179,Light sensor parameter-1_rb_E2_Sensor_Error1_g,0,
ENG116804-ENG122180,Light sensor parameter-2_rb_E2_Sensor_Error2_g,0,
ENG116804-ENG122181,Light sensor parameter-3_rb_E2_Sensor_Error3_g,0,
ENG116804-ENG122182,Light sensor parameter-4_rb_E2_Sensor_Error4_g,0,
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,NotActive,
ENG116804-ENG121664,Light sensor parameter-night_mode,NotActive,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,NotActive,
ENG116804-ENG121666,Light sensor parameter-rain_mode,NotActive,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,135,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,135,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,90,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,68,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG121677,Light sensor parameter-rb_LIN_CHECKSUMERROR_COUNTER_g,0,
ENG116804-ENG122178,Light sensor parameter-rb_LIN_FRAMING_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG122177,Light sensor parameter-rb_LIN_OVER_TFRAMEMAX_COUNTER_g,0,
ENG116804-ENG122176,Light sensor parameter-rb_LIN_OVER_THEADERMAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,186,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,542,
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,180,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,397,
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,174,
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,0,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,NotActive,
ENG116909-ENG107391,LIN activity-LIN 1,Communication,
ENG116909-ENG256023,LIN activity-LIN 10,not coded/not installed,
ENG116909-ENG256024,LIN activity-LIN 11,not coded/not installed,
ENG116909-ENG256025,LIN activity-LIN 12,not coded/not installed,
ENG116909-ENG256026,LIN activity-LIN 13,not coded/not installed,
ENG116909-ENG256027,LIN activity-LIN 14,not coded/not installed,
ENG116909-ENG107392,LIN activity-LIN 2,Communication,
ENG116909-ENG114948,LIN activity-LIN 3,Communication,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,Communication,
ENG116909-ENG114951,LIN activity-LIN 6,Communication,
ENG116909-ENG256030,LIN activity-LIN 7,not coded/not installed,
ENG116909-ENG256031,LIN activity-LIN 8,Communication,
ENG116909-ENG256032,LIN activity-LIN 9,not coded/not installed,
ENG122922-ENG121684,misc_wiper_values_1-wiper_counter_block,0,
ENG122922-ENG121680,misc_wiper_values_1-wiper_counter_cycles,10800,
ENG122922-ENG121681,misc_wiper_values_1-wiper_counter_operating_h,44.3422, H
ENG122922-ENG121682,misc_wiper_values_1-wiper_errors,00000000 00000000 ,
ENG122922-ENG121683,misc_wiper_values_1-wiper_speed_real,30, /min
ENG122924-ENG115787,misc_wiper_values_2-wiper_angle,655.22, °
ENG122924-ENG115788,misc_wiper_values_2-wiper_angle_corr_OWL,124.23, °
ENG122924-ENG115789,misc_wiper_values_2-wiper_angle_corr_UWL,0.01, °
ENG122924-ENG115790,misc_wiper_values_2-wiper_power_supply_Ubat,12.09, V
ENG254795,Personalized_Signals_2_0,|Current profile slot number for customization,Customization control command
ENG116792,Power up history,|Funktionsanforderung|10|10|10|10|1|10|1|9|10|1|,
ENG116805-ENG121648,Rain sensor parameter-rb_CloseTypeStandby_g,0,
ENG116805-ENG121657,Rain sensor parameter-rb_Errorflags_g,0,
ENG116805-ENG121651,Rain sensor parameter-rb_HumTemp_ErrorCode_g,0,
ENG116805-ENG121656,Rain sensor parameter-rb_Max_WDGFastTaskCounter_g,141,
ENG116805-ENG121655,Rain sensor parameter-rb_Min_WDGFastTaskCounter_g,139,
ENG116805-ENG121653,Rain sensor parameter-rb_NoCommunicationCounter,0,
ENG116805-ENG121641,Rain sensor parameter-rb_PotiStageFromBox_g,0,
ENG116805-ENG121642,Rain sensor parameter-rb_PWM_Voltage_g,146,
ENG116805-ENG121652,Rain sensor parameter-rb_StaticNoCommunicationCounter,0,
ENG116805-ENG121654,Rain sensor parameter-rb_SupplyVoltage_mg,149,
ENG116805-ENG121640,Rain sensor parameter-rub_Empf_Faktor,2,
ENG116805-ENG121639,Rain sensor parameter-rub_Int_Speicher,0,
ENG116805-ENG121645,Rain sensor parameter-rub_LengthCounter,94,
ENG116805-ENG121643,Rain sensor parameter-rub_Nachwisch_Count,0,
ENG116805-ENG121638,Rain sensor parameter-rub_Ovr_Speicher,0,
ENG116805-ENG121646,Rain sensor parameter-rub_PulseCounter,101,
ENG116805-ENG121647,Rain sensor parameter-rub_SignalIntegral_g,245,
ENG116805-ENG121644,Rain sensor parameter-ruw_StX_Speicher,1,
ENG116805-ENG121650,Rain sensor parameter-rw_HumiTicks_g,42720,
ENG116805-ENG121649,Rain sensor parameter-rw_TempTicks_g,-34.06, °C
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,22, s
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Incline,-0.06, km/(hs)
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0, s
ENG122923-ENG115672,shadow_error_table-wiper_error_1_code,34,
ENG122923-ENG115673,shadow_error_table-wiper_error_1_count,3,
ENG122923-ENG115677,shadow_error_table-wiper_error_1_data_ec4,64,
ENG122923-ENG115678,shadow_error_table-wiper_error_1_data_ec5,12,
ENG122923-ENG115676,shadow_error_table-wiper_error_1_power_supply,13.3, V
ENG122923-ENG115675,shadow_error_table-wiper_error_1_temp,17, °C
ENG122923-ENG115674,shadow_error_table-wiper_error_1_timestamp,19.4922, min
ENG122923-ENG256664,shadow_error_table-wiper_error_10_code,0,
ENG122923-ENG256665,shadow_error_table-wiper_error_10_count,0,
ENG122923-ENG256666,shadow_error_table-wiper_error_10_data_ec4,0,
ENG122923-ENG256667,shadow_error_table-wiper_error_10_data_ec5,0,
ENG122923-ENG256668,shadow_error_table-wiper_error_10_power_supply,0.0, V
ENG122923-ENG256669,shadow_error_table-wiper_error_10_temp,0, °C
ENG122923-ENG256671,shadow_error_table-wiper_error_10_timestamp,0.0000, min
ENG122923-ENG115679,shadow_error_table-wiper_error_2_code,29,
ENG122923-ENG115680,shadow_error_table-wiper_error_2_count,3,
ENG122923-ENG115684,shadow_error_table-wiper_error_2_data_ec4,192,
ENG122923-ENG115685,shadow_error_table-wiper_error_2_data_ec5,5,
ENG122923-ENG115683,shadow_error_table-wiper_error_2_power_supply,9.5, V
ENG122923-ENG115682,shadow_error_table-wiper_error_2_temp,11, °C
ENG122923-ENG115681,shadow_error_table-wiper_error_2_timestamp,15.6604, min
ENG122923-ENG115686,shadow_error_table-wiper_error_3_code,27,
ENG122923-ENG115687,shadow_error_table-wiper_error_3_count,1,
ENG122923-ENG115691,shadow_error_table-wiper_error_3_data_ec4,11,
ENG122923-ENG115692,shadow_error_table-wiper_error_3_data_ec5,0,
ENG122923-ENG115690,shadow_error_table-wiper_error_3_power_supply,10.2, V
ENG122923-ENG115689,shadow_error_table-wiper_error_3_temp,10, °C
ENG122923-ENG115688,shadow_error_table-wiper_error_3_timestamp,15.6604, min
ENG122923-ENG115693,shadow_error_table-wiper_error_4_code,51,
ENG122923-ENG115694,shadow_error_table-wiper_error_4_count,5,
ENG122923-ENG115698,shadow_error_table-wiper_error_4_data_ec4,255,
ENG122923-ENG115699,shadow_error_table-wiper_error_4_data_ec5,0,
ENG122923-ENG115697,shadow_error_table-wiper_error_4_power_supply,12.2, V
ENG122923-ENG115695,shadow_error_table-wiper_error_4_temp,22, °C
ENG122923-ENG115696,shadow_error_table-wiper_error_4_timestamp,0.8330, min
ENG122923-ENG115700,shadow_error_table-wiper_error_5_code,31,
ENG122923-ENG115701,shadow_error_table-wiper_error_5_count,1,
ENG122923-ENG115705,shadow_error_table-wiper_error_5_data_ec4,80,
ENG122923-ENG115706,shadow_error_table-wiper_error_5_data_ec5,255,
ENG122923-ENG115704,shadow_error_table-wiper_error_5_power_supply,13.6, V
ENG122923-ENG115703,shadow_error_table-wiper_error_5_temp,15, °C
ENG122923-ENG115702,shadow_error_table-wiper_error_5_timestamp,0.0000, min
ENG122923-ENG256676,shadow_error_table-wiper_error_6_code,0,
ENG122923-ENG256677,shadow_error_table-wiper_error_6_count,0,
ENG122923-ENG256678,shadow_error_table-wiper_error_6_data_ec4,0,
ENG122923-ENG256679,shadow_error_table-wiper_error_6_data_ec5,0,
ENG122923-ENG256680,shadow_error_table-wiper_error_6_power_supply,0.0, V
ENG122923-ENG256681,shadow_error_table-wiper_error_6_temp,0, °C
ENG122923-ENG256683,shadow_error_table-wiper_error_6_timestamp,0.0000, min
ENG122923-ENG256684,shadow_error_table-wiper_error_7_code,0,
ENG122923-ENG256685,shadow_error_table-wiper_error_7_count,0,
ENG122923-ENG256686,shadow_error_table-wiper_error_7_data_ec4,0,
ENG122923-ENG256687,shadow_error_table-wiper_error_7_data_ec5,0,
ENG122923-ENG256688,shadow_error_table-wiper_error_7_power_supply,0.0, V
ENG122923-ENG256689,shadow_error_table-wiper_error_7_temp,0, °C
ENG122923-ENG256691,shadow_error_table-wiper_error_7_timestamp,0.0000, min
ENG122923-ENG256692,shadow_error_table-wiper_error_8_code,0,
ENG122923-ENG256693,shadow_error_table-wiper_error_8_count,0,
ENG122923-ENG256694,shadow_error_table-wiper_error_8_data_ec4,0,
ENG122923-ENG256695,shadow_error_table-wiper_error_8_data_ec5,0,
ENG122923-ENG256696,shadow_error_table-wiper_error_8_power_supply,0.0, V
ENG122923-ENG256697,shadow_error_table-wiper_error_8_temp,0, °C
ENG122923-ENG256699,shadow_error_table-wiper_error_8_timestamp,0.0000, min
ENG122923-ENG256700,shadow_error_table-wiper_error_9_code,0,
ENG122923-ENG256701,shadow_error_table-wiper_error_9_count,0,
ENG122923-ENG256702,shadow_error_table-wiper_error_9_data_ec4,0,
ENG122923-ENG256703,shadow_error_table-wiper_error_9_data_ec5,0,
ENG122923-ENG256704,shadow_error_table-wiper_error_9_power_supply,0.0, V
ENG122923-ENG256705,shadow_error_table-wiper_error_9_temp,0, °C
ENG122923-ENG256707,shadow_error_table-wiper_error_9_timestamp,0.0000, min
ENG254816,Snapshot_DTC_Notlaufpfad,No malfunction,
ENG250298-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254825,steuergeraetinterne_Messwert,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-Odometer reading,508, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.5, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.7, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,12.1, V
ENG122921-ENG121628,values_motorloads-mod_temp_fast,18, °C
ENG122921-ENG121627,values_motorloads-mod_temp_slow,21, °C
ENG122921-ENG121629,values_motorloads-temp_pcb,18, °C
ENG122921-ENG121631,values_motorloads-wiper_energymodel_load,0,
ENG122921-ENG121632,values_motorloads-wiper_energymodel_status,0,
ENG122921-ENG121633,values_motorloads-wiper_power_supply_PWM,0, %
ENG122921-ENG121630,values_motorloads-wiper_thermomodel_status,0,
ENG254854-ENG161480,Wischer_Flash_Historie-Betriebsstundenzaehler_1,0.000000, s
ENG254854-ENG161481,Wischer_Flash_Historie-Betriebsstundenzaehler_2,0.000000, s
ENG254854-ENG161482,Wischer_Flash_Historie-Betriebsstundenzaehler_3,0.000000, s
ENG254854-ENG161483,Wischer_Flash_Historie-Betriebsstundenzaehler_4,0.000000, s
ENG254854-ENG161484,Wischer_Flash_Historie-Betriebsstundenzaehler_5,0.000000, s
ENG254854-ENG162659,Wischer_Flash_Historie-geflashte_SW_Version_2,0,
ENG254854-ENG162660,Wischer_Flash_Historie-geflashte_SW_Version_3,0,
ENG254854-ENG162661,Wischer_Flash_Historie-geflashte_SW_Version_4,0,
ENG254854-ENG162662,Wischer_Flash_Historie-geflashte_SW_Version_5,0,
ENG254854-ENG162663,Wischer_Flash_Historie-geflashte_SW_Version1,0,
ENG254854-ENG163410,Wischer_Flash_Historie-Programmierdatum_1_Jahr,0,
ENG254854-ENG163411,Wischer_Flash_Historie-Programmierdatum_1_Monat,0,
ENG254854-ENG163412,Wischer_Flash_Historie-Programmierdatum_1_Tag,0,
ENG254854-ENG163413,Wischer_Flash_Historie-Programmierdatum_2_Jahr,0,
ENG254854-ENG163414,Wischer_Flash_Historie-Programmierdatum_2_Monat,0,
ENG254854-ENG163415,Wischer_Flash_Historie-Programmierdatum_2_Tag,0,
ENG254854-ENG163416,Wischer_Flash_Historie-Programmierdatum_3_Jahr,0,
ENG254854-ENG163417,Wischer_Flash_Historie-Programmierdatum_3_Monat,0,
ENG254854-ENG163418,Wischer_Flash_Historie-Programmierdatum_3_Tag,0,
ENG254854-ENG163419,Wischer_Flash_Historie-Programmierdatum_4_Jahr,0,
ENG254854-ENG163420,Wischer_Flash_Historie-Programmierdatum_4_Monat,0,
ENG254854-ENG163421,Wischer_Flash_Historie-Programmierdatum_4_Tag,0,
ENG254854-ENG163422,Wischer_Flash_Historie-Programmierdatum_5_Jahr,0,
ENG254854-ENG163423,Wischer_Flash_Historie-Programmierdatum_5_Monat,0,
ENG254854-ENG163424,Wischer_Flash_Historie-Programmierdatum_5_Tag,0,
ENG254854-ENG164205,Wischer_Flash_Historie-Tester_Seriennummer_1,00 00 00 00 00 00,
ENG254854-ENG164206,Wischer_Flash_Historie-Tester_Seriennummer_2,00 00 00 00 00 00,
ENG254854-ENG164207,Wischer_Flash_Historie-Tester_Seriennummer_3,00 00 00 00 00 00,
ENG254854-ENG164208,Wischer_Flash_Historie-Tester_Seriennummer_4,00 00 00 00 00 00,
ENG254854-ENG164209,Wischer_Flash_Historie-Tester_Seriennummer_5,00 00 00 00 00 00,
ENG254854-ENG164431,Wischer_Flash_Historie-Wischzyklenzaehler_1,0,
ENG254854-ENG164432,Wischer_Flash_Historie-Wischzyklenzaehler_2,0,
ENG254854-ENG164433,Wischer_Flash_Historie-Wischzyklenzaehler_3,0,
ENG254854-ENG164434,Wischer_Flash_Historie-Wischzyklenzaehler_4,0,
ENG254854-ENG164435,Wischer_Flash_Historie-Wischzyklenzaehler_5,0,
ENG133751-ENG124960,Wischermesswerte 1-aktuelle Schwelle (kalt oder warm),0,
ENG133751-ENG161419,Wischermesswerte 1-Anzahl Wischzyklen(aktueller Wert),10881,
ENG133751-ENG98439,Wischermesswerte 1-Battery voltage,12.0790, V
ENG133751-ENG124957,Wischermesswerte 1-Energiemodell Daten 1 gerechneter Wert,0,
ENG133751-ENG124958,Wischermesswerte 1-Energiemodell Daten 2 gerechneter Wert,0,
ENG133751-ENG124959,Wischermesswerte 1-Energiemodell Daten 3 gerechneter Wert,0,
ENG133751-ENG98786,Wischermesswerte 1-Engine angle,6553.4, °
ENG133751-ENG124964,Wischermesswerte 1-Motor PWM,0.000, %
ENG133751-ENG115795,Wischermesswerte 1-Operating Hours,159473.360, s
ENG133751-ENG115650,Wischermesswerte 1-PCB-Temperatur,66351.063, °C
ENG133751-ENG124961,Wischermesswerte 1-Schwellwert 'kalt',1348101225,
ENG133751-ENG124962,Wischermesswerte 1-Schwellwert 'warm',1687603450,
ENG133751-ENG147706,Wischermesswerte 1-Schwellwert zum loeschen,200,
ENG133751-ENG99062,Wischermesswerte 1-Wipe speed,0.00, /min
ENG133752-ENG124978,Wischermesswerte 2-aktuelle obere Wendelage,136.4, °
ENG133752-ENG124973,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Beifahrerseite,0.6210, °
ENG133752-ENG124972,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Fahrerseite,0.5260, °
ENG133752-ENG255292,Wischermesswerte 2-aktueller_Motor_kurbelwinkel,6553.4, °
ENG133752-ENG124984,Wischermesswerte 2-Anstehende Wischmodus,34,
ENG133752-ENG124981,Wischermesswerte 2-Arbeitswinkel der Motorabtriebswelle bei Fehlereintritt,0.0, °
ENG133752-ENG147708,Wischermesswerte 2-Blockzaehler (Ueberlast),0,
ENG133752-ENG147709,Wischermesswerte 2-Fehlerzustaende (Errorstate),0,
ENG133752-ENG124982,Wischermesswerte 2-Funktion bei Fehlereintritt 1,0,
ENG133752-ENG124983,Wischermesswerte 2-Funktion bei Fehlereintritt 2,0,
ENG133752-ENG124976,Wischermesswerte 2-Ist-Wischgeschwindigkeit,0, /min
ENG133752-ENG124985,Wischermesswerte 2-Master-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG121977,Wischermesswerte 2-No. of wisher cycles,0,
ENG133752-ENG98396,Wischermesswerte 2-Operating time,70668.258, s
ENG133752-ENG124970,Wischermesswerte 2-OWL Obere Wendelage,144.9, °
ENG133752-ENG124986,Wischermesswerte 2-RLS-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG124975,Wischermesswerte 2-Soll-Wischgeschwindigkeit,0, /min
ENG133752-ENG99020,Wischermesswerte 2-Supply voltage,13.2818, V
ENG133752-ENG98969,Wischermesswerte 2-Temperature,17.096, °C
ENG133752-ENG124971,Wischermesswerte 2-UWL Untere Wendelage,7.5, °
ENG133743-ENG125002,Wischermesswerte 3-Chip number,00 00 00 00 00 00 00 00,
ENG133743-ENG255531,Wischermesswerte 3-Chip number Infineon,13 CB 45 01 07 7F FE E0 40 A8 1D E9,
ENG133743-ENG125000,Wischermesswerte 3-EOL number,30,
ENG133743-ENG125001,Wischermesswerte 3-Error state,0,
ENG133743-ENG124999,Wischermesswerte 3-ICT (NG) measurement value,0,
ENG133743-ENG124998,Wischermesswerte 3-ICT (OK) measurement value,0,
ENG133743-ENG98897,Wischermesswerte 3-Serial number,39 30 37 34 35 33 46 30 33 30 32 34 31 31 31 30 34 31 31 39,
ENG254856-ENG255353,WWS Historie-Anzahl Wischzyklen max MCU Temperatur,13,
ENG254856-ENG255354,WWS Historie-Anzahl Wischzyklen max. LIN Temperatur,0,
ENG254856-ENG255356,WWS Historie-Anzahl Wischzyklen max. UBatt,6511,
ENG254856-ENG263779,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_0,126,
ENG254856-ENG263780,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_1,10158,
ENG254856-ENG263781,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_2,239,
ENG254856-ENG263782,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_3,233,
ENG254856-ENG263783,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_4,64,
ENG254856-ENG263784,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_5,10,
ENG254856-ENG263785,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_6,1,
ENG254856-ENG263786,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_7,50,
ENG254856-ENG255393,WWS Historie-Betriebsstunden max MCU Temperatur,59.945885, s
ENG254856-ENG255394,WWS Historie-Betriebsstunden max. LIN Temperatur,22.351329, s
ENG254856-ENG255396,WWS Historie-Betriebsstunden max. UBatt,353.873517, s
ENG254856-ENG289707,WWS Historie-extern_Temp,0, °C
ENG254856-ENG255812,WWS Historie-Kl_15_Zyklenzaehler,181,
ENG254856-ENG255813,WWS Historie-Kl_X_Zyklenzaehler,359,
ENG254856-ENG289722,WWS Historie-LIN_Signal_max_Exterior_Temp,-100, °C
ENG254856-ENG289704,WWS Historie-max_Intern_Temp,112, °C
ENG254856-ENG256046,WWS Historie-max_power_supply,15.4, V
ENG254856-ENG256320,WWS Historie-Sleep_Counter,0,
ENG254856-ENG256640,WWS Historie-Wakeup_Counter,1332,
Elapsed Time: 01:24
blockmap-10-5WA-919-298-B_VSSZZZKM2RR140480-20241020-1508.CSV
;SW:5WA-919-298-B   HW:5WA-919-298 ---  Park/Steer Assist
;Component:PLA 12 Kanal  H05 0578, Coding:8300022011
;EV_EPHBO2CVW3800000,002028,EV_EPHBO2CVW3800000_VW38.rod
;Sunday,20,October,2024,15:08:09:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 55F05894B58D7A925CD-8000
Group,Description,Actual
IDE00018,Voltage terminal 15,11.7, V
IDE00957-MAS01632,Resulting distance of front sensors-Status,79, cm
IDE00958-MAS01632,Resulting distance of rear sensors-Status,28, cm
IDE00973,Outside temperature,16.00, °
IDE00974,Outside air temperature internally calculated,15.00, °
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,99, cm
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,37, cm
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,28, cm
IDE01127-MAS01632,Distance sensor for left front park assist-Status,84, cm
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,83, cm
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,79, cm
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,0.560, ms
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,0.560, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,0.480, ms
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,0.560, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,0.512, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,Malfunction,
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,0.512, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,0.512, ms
IDE01165,Park assist activation tone,OFF,
IDE01166,Supply voltage for park assist sensor,12.7, V
IDE01167,Convertible offset for volume level 1,1,
IDE01169,Audio lowering request,No,
IDE01175-MAS01632,Distance of side left rear parking aid sensors-Status,infinite,
IDE01176-MAS01632,Distance of side right rear parking aid sensors-Status,infinite,
IDE01177-MAS01632,Oscillating time of side left rear parking aid sensors-Status,0.560, ms
IDE01178-MAS01632,Oscillating time of side right rear parking aid sensors-Status,0.512, ms
IDE01185-MAS01632,Distance sensor for left front parking aid-Status,infinite,
IDE01186-MAS01632,Distance sensor for right front parking aid-Status,infinite,
IDE01187-MAS01632,Decay time for side left front parking aid sensor-Status,0.560, ms
IDE01188-MAS01632,Decay time for right side front parking aid sensor-Status,Malfunction,
IDE01588,Driving direction,not detected,
IDE03008-IDE03726,Stop process prevented-Parallel Parking Assistance,passive,
IDE03008-MAS00825,Stop process prevented-Parking Aid Control Module,active,
IDE03010-IDE03726,Number of prevented stop processes-Parallel Parking Assistance,0,
IDE03010-MAS00825,Number of prevented stop processes-Parking Aid Control Module,0,
IDE03011-IDE03726,Number of requested start processes-Parallel Parking Assistance,0,
IDE03011-MAS00825,Number of requested start processes-Parking Aid Control Module,0,
IDE03684,Vehicle stopped,Yes,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE10300,OBD Driving Cycle detected,active,
IDE10925-MAS00106,ARA discharge reasons (ring memory)-Year,2000,
IDE10925-MAS00107,ARA discharge reasons (ring memory)-Month,0,
IDE10925-MAS00108,ARA discharge reasons (ring memory)-Day,0,
IDE10925-MAS00109,ARA discharge reasons (ring memory)-Hours,0,
IDE10925-MAS00110,ARA discharge reasons (ring memory)-Minutes,0,
IDE10925-MAS00111,ARA discharge reasons (ring memory)-Seconds,0,
IDE10925-MAS09002,ARA discharge reasons (ring memory)-Last reason,Unknown (0)
IDE10925-MAS09003,ARA discharge reasons (ring memory)-second last reasons,Unknown (0)
IDE10925-MAS09004,ARA discharge reasons (ring memory)-third last reason,Unknown (0)
IDE10925-MAS09005,ARA discharge reasons (ring memory)-fourth last reason,Unknown (0)
IDE10925-MAS09006,ARA discharge reasons (ring memory)-fifth last reason,Unknown (0)
IDE11152-MAS12261,Wheel circumferences-Right front wheel circumference,1013, mm
IDE11152-MAS12262,Wheel circumferences-Left front wheel circumference,0, mm
IDE11152-MAS12263,Wheel circumferences-Right rear wheel circumference,409, mm
IDE11152-MAS12264,Wheel circumferences-Left rear wheel circumference,0, mm
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,0, %/s
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,0, bar
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2000,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,0,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,0,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,0,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,0,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,0,
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-20.0, km/h
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,not active,
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,-5.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-5.0, m
MAS10122,ARA operating condition,Unknown (0)
MAS10122-MAS11700,ARA operating condition-ARA function request door control module,no request,
Elapsed Time: 00:06
blockmap-13-5WA-907-572-C_VSSZZZKM2RR140480-20241020-1508.CSV
;SW:5WA-907-572-C   HW:5WA-907-572-A ---  Auto Dist. Reg
;Component:ACC BOSCH MQB H45 0461, Coding:0A03007D407740451247400000D00004AE4020000000000000000000000000
;EV_FRONTRADARBOSCHVW380,004021,EV_FRONTRADARBOSCHVW380_004_VW38.rod
;Sunday,20,October,2024,15:08:24:49859
;VCID: 4EC2B7F8905B094A9D7-801A
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,14.0, V
IDE00102,Control Module temperature,37, °C
IDE00310,Outside temperature,16.0, °C
IDE00391,Adaptive distance regulation: status,ACC_StandBy,
IDE00924,Steering angle,-6.500, °
IDE00925,Yaw rate,0.000, rad/s
IDE01268-MAS02506,Windshield wiper-Wiper active,not active,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,DB D3 8D 83,
IDE02057-MAS02356,Dynamic calibration: status-Type of calibration,static,
IDE02057-MAS05634,Dynamic calibration: status-Progress,0, %
IDE02057-ENG279299,Dynamic calibration: status-Absolute_driving_distance,0, m
IDE02057-ENG279303,Dynamic calibration: status-Acceleration_out_of_range,Framework conditions currently not met,
IDE02057-ENG98465,Dynamic calibration: status-Calibration status,not started,
IDE02057-ENG279396,Dynamic calibration: status-Effective_driving_distance,0, m
IDE02057-ENG279410,Dynamic calibration: status-Fault_signal_active,Framework conditions currently not met,
IDE02057-ENG279411,Dynamic calibration: status-Few_locations,Framework conditions currently not met,
IDE02057-ENG279533,Dynamic calibration: status-Speed_out_of_range,Framework conditions currently not met,
IDE02057-ENG279572,Dynamic calibration: status-Yaw_rate_out_of_range,Framework conditions currently not met,
IDE02068-MAS00106,Time stamp-Year,2024,
IDE02068-MAS00107,Time stamp-Month,10,
IDE02068-MAS00108,Time stamp-Day,20,
IDE02068-MAS00109,Time stamp-Hours,15,
IDE02068-MAS00110,Time stamp-Minutes,7,
IDE02068-MAS00111,Time stamp-Seconds,13,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead starts driving: ACC passive,35,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead starts driving: ACC off,117,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead starts driving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead starts driving: ACC off,34,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-MAS01447,Driving profile selection-Act.val.,4,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE08343,Immobilizer Challenge,BC 7E 6B E9,
IDE08936,Misalignment angle: horiz,0.123, °
IDE09906,Vertical deadjustment,-0.799, °
IDE10902-IDE00018,Expanded ambient data 1-Voltage terminal 15,14.2, V
IDE10902-IDE00102,Expanded ambient data 1-Control Module temperature,37, °C
IDE10902-IDE00310,Expanded ambient data 1-Outside temperature,16.0, °C
IDE10902-IDE03660,Expanded ambient data 1-Longitudinal acceleration,0.00, m/s²
IDE10902-MAS00370,Expanded ambient data 1-Vehicle speed,0.00, m/s
IDE10902-MAS01632,Expanded ambient data 1-Status,ACC_StandBy,
IDE10903-IDE00924,Expanded ambient data 2-Steering angle,-6.500, °
IDE10903-IDE00925,Expanded ambient data 2-Yaw rate,0.000, rad/s
IDE10903-IDE01268,Expanded ambient data 2-Windshield wiper,not active,
IDE10903-IDE08936,Expanded ambient data 2-Misalignment angle: horiz,0.123, °
IDE10903-IDE09906,Expanded ambient data 2-Vertical deadjustment,-0.799, °
IDE10903-MAS00106,Expanded ambient data 2-Year,2024,
IDE10903-MAS00107,Expanded ambient data 2-Month,10,
IDE10903-MAS00108,Expanded ambient data 2-Day,20,
IDE10903-MAS00109,Expanded ambient data 2-Hours,15,
IDE10903-MAS00110,Expanded ambient data 2-Minutes,7,
IDE10903-MAS00111,Expanded ambient data 2-Seconds,15,
IDE10903-MAS00711,Expanded ambient data 2-Odometer reading,1626, km
IDE10903-MAS13429,Expanded ambient data 2-Horizontal correction angle: currently,0.120, °
IDE10903-MAS13430,Expanded ambient data 2-Vertical correction angle: currently,-0.880, °
IDE10903-ENG255471,Expanded ambient data 2-Blindness_combined,0, %
IDE10903-ENG255476,Expanded ambient data 2-Blindness_indicator_1,0, %
IDE10903-ENG255477,Expanded ambient data 2-Blindness_indicator_2,100, %
IDE10903-ENG255478,Expanded ambient data 2-Blindness_indicator_3,0, %
IDE10903-ENG255479,Expanded ambient data 2-Blindness_indicator_4,98, %
IDE10903-ENG255480,Expanded ambient data 2-Blindness_indicator_5,0, %
IDE10903-ENG255481,Expanded ambient data 2-Blindness_indicator_6,0, %
IDE10903-ENG255628,Expanded ambient data 2-Distance_index,0.00, m
IDE10903-ENG256311,Expanded ambient data 2-Sensor_FRKL,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|2|2|2|2|2|2|2|2|2|,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|,
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.120, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,-0.880, °
IDE12062,Counter for terminal 15 reset,187,
IDE12238,I network: discarded messages counter,0,
IDE13845,Production mode status,not active,
IDE14997,Number of events: sensor blind,1,
IDE14998,Number of events: misalignment,0,
IDE15000-IDE08936,History data sensor calibration-Misalignment angle: horiz,0.000, °
IDE15000-IDE09906,History data sensor calibration-Vertical deadjustment,-1.200, °
IDE15000-IDE14999,History data sensor calibration-Duration of calibration,0.20, s
IDE15000-IDE15022,History data sensor calibration-Result of calibration,OK,
IDE15000-MAS00106,History data sensor calibration-Year,2024,
IDE15000-MAS00107,History data sensor calibration-Month,5,
IDE15000-MAS00108,History data sensor calibration-Day,28,
IDE15000-MAS00109,History data sensor calibration-Hours,12,
IDE15000-MAS00110,History data sensor calibration-Minutes,17,
IDE15000-MAS00111,History data sensor calibration-Seconds,43,
IDE15000-MAS00711,History data sensor calibration-Odometer reading,0, km
IDE15000-MAS02356,History data sensor calibration-Type of calibration,static,
IDE15000-MAS13429,History data sensor calibration-Horizontal correction angle: currently,0.000, °
IDE15000-MAS13430,History data sensor calibration-Vertical correction angle: currently,-1.190, °
IDE15006,History data sensor 01,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15007,History data sensor 02,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15008,History data sensor 03,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15009,History data sensor 04,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15010,History data sensor 05,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15011,History data sensor 06,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15012,History data sensor 07,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15013,History data sensor 08,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15014,History data sensor 09,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15015,History data sensor 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15016,History data sensor 11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15017,History data sensor 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15018,History data sensor 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15019,History data sensor 14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15020,History data sensor 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE16615,Control module internal information,00 00 00,
IDE17075-MAS06854,Functions that can be enabled: FoD slave enhanced status-Version,10,
IDE17075-ENG298547,Functions that can be enabled: FoD slave enhanced status-Extended_state_payload,00 01 00 D6 02 02 01 02 00 00 03 03 00 00 00 00 00 00 00 F4 00 00 00 00 03 00 00 00 14 00 00 00 00 00 00 3A 98 00 02 BF 20 00 00 01 F4 00 0A 02 0F 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE17075-ENG298612,Functions that can be enabled: FoD slave enhanced status-Payload_length,51,
MAS00370,Vehicle speed,0.00, m/s
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 01 01 00,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,10,
ENG302951,DTCCodeRef_for_FAULT_CS520_TIMESTAMP,00 00 00,
ENG302952,DTCCodeRef_for_FAULT_MMIC_TIMESTAMP,00 00 00,
ENG302953,DTCCodeRef_for_FAULT_RIF_TIMESTAMP,00 00 00,
ENG302954,DTCCodeRef_for_FAULT_SPU_TIMESTAMP,00 00 00,
ENG302955,DTCCodeRef_for_FAULT_UC_TIMESTAMP,00 00 00,
ENG254718-MAS17521,Function_On_Demand_Unlock_ID_Status_Dev-Unlockable functions: activation status,|ID number,Release code for a SWaP function
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,10,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
ENG139832,Sw_version_supplier,EV_FRONTRADARBOSCHVW38000402100µ©Ø=04615WA907572C SysC_37w_MOPF_0461_RC2000,
Elapsed Time: 00:17
blockmap-15-1EA-959-655-FB_VSSZZZKM2RR140480-20241020-1508.CSV
;SW:1EA-959-655-FB   HW:1EA-959-655-FB ---  Airbags
;Component:VW40Airbag    011 0185, Coding:88CC008000C0C000000000000000000051540000205400004000F68000930065
;EV_AirbaVW40ALVVW38X,001016,EV_AirbaVW40ALVVW38X_VW41.rod
;Sunday,20,October,2024,15:08:51:49859
;VCID: 06524FD838AB010A657-8052
IDE00821-MAS01632,Seat belt switch 2nd row driver's side-Status,connected,
IDE00821-MAS05030,Seat belt switch 2nd row driver's side-Resistance,too large,
IDE00822-MAS01632,Safety belt switch 2nd row frt.passenger side-Status,connected,
IDE00822-MAS05030,Safety belt switch 2nd row frt.passenger side-Resistance,too large,
IDE00823-MAS01632,Seat belt switch 2nd row center-Status,connected,
IDE00823-MAS05030,Seat belt switch 2nd row center-Resistance,too large,
IDE00824-MAS01632,Seat belt switch 3rd row driver's side-Status,not installed,
IDE00824-MAS05030,Seat belt switch 3rd row driver's side-Resistance,no measured value present,
IDE00825-MAS01632,Passenger side 3rd row seat belt switch-Status,not installed,
IDE00825-MAS05030,Passenger side 3rd row seat belt switch-Resistance,no measured value present,
IDE00826-MAS01632,Seat belt switch 3rd row center-Status,not installed,
IDE00826-MAS05030,Seat belt switch 3rd row center-Resistance,no measured value present,
IDE00947-MAS01632,Driver side rear curtain airbag igniter-Status,not installed,
IDE00947-MAS05030,Driver side rear curtain airbag igniter-Resistance,no measured value present,
IDE00948-MAS01632,Frt.passenger side rear curtain airbag igniter-Status,not installed,
IDE00948-MAS05030,Frt.passenger side rear curtain airbag igniter-Resistance,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01357-MAS01632,Left pedestrian protection igniter-Status,not installed,
IDE01357-MAS05030,Left pedestrian protection igniter-Resistance,no measured value present,
IDE01358-MAS01632,Right pedestrian protection igniter-Status,not installed,
IDE01358-MAS05030,Right pedestrian protection igniter-Resistance,no measured value present,
IDE01359-MAS01632,Front pedestrian protection trigger-Status,not installed,
IDE01359-MAS05030,Front pedestrian protection trigger-Resistance,no measured value present,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,0,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,0,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,0,
IDE01555,Number of frontal crashes,0,
IDE01560,Number of activations of active head restraint,0,
IDE02852-MAS01632,Battery Interrupt Igniter High-Voltage Battery-Status,not installed,
IDE02852-MAS05030,Battery Interrupt Igniter High-Voltage Battery-Resistance,no measured value present,
IDE03800-MAS01632,Driver airbag release valve igniter-Status,not installed,
IDE03800-MAS05030,Driver airbag release valve igniter-Resistance,no measured value present,
IDE03801-MAS01632,Frt.pass. airbag release valve igniter-Status,not installed,
IDE03801-MAS05030,Frt.pass. airbag release valve igniter-Resistance,no measured value present,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Target value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,not calculated,
IDE05726-MAS09976,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'off': frt. pass. side,0.0, %
IDE05726-MAS09977,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'on': frt. pass. side,0.0, %
IDE05726-MAS09978,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'text': frt. pass. side,0.0, %
IDE06034-MAS01632,Rollover protection trigger: driver side-Status,not installed,
IDE06034-MAS05030,Rollover protection trigger: driver side-Resistance,no measured value present,
IDE06035-MAS01632,Rollover protection trigger: front passenger side-Status,not installed,
IDE06035-MAS05030,Rollover protection trigger: front passenger side-Resistance,no measured value present,
IDE07190-MAS01632,Igniter for battery open circuit 2nd battery-Status,not installed,
IDE07190-MAS05030,Igniter for battery open circuit 2nd battery-Resistance,no measured value present,
IDE07192-MAS01632,Thorax airbag igniter-Status,not installed,
IDE07192-MAS05030,Thorax airbag igniter-Resistance,no measured value present,
IDE08436-MAS01632,Driver side seat belt tensioner igniter 3-Status,not installed,
IDE08436-MAS05030,Driver side seat belt tensioner igniter 3-Resistance,no measured value present,
IDE08437-MAS01632,Front passenger side third row seat belt tensioner igniter-Status,not installed,
IDE08437-MAS05030,Front passenger side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE11715-MAS01632,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Status,not installed,
IDE11715-MAS05030,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,not installed,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,correct,
IDE12056-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,2.5, Ohm
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12158-MAS01632,Front pedestrian protection trigger 2-Status,not installed,
IDE12158-MAS05030,Front pedestrian protection trigger 2-Resistance,no measured value present,
IDE12208-MAS01632,Igniter for deactivation of A/C system 1-Status,not installed,
IDE12208-MAS05030,Igniter for deactivation of A/C system 1-Resistance,no measured value present,
IDE12209-MAS01632,Igniter for deactivation of A/C system 2-Status,not installed,
IDE12209-MAS05030,Igniter for deactivation of A/C system 2-Resistance,no measured value present,
IDE12257-IDE00821,Extended belts witch diagnostic-Seat belt switch 2nd row driver's side,0,
IDE12257-IDE00822,Extended belts witch diagnostic-Safety belt switch 2nd row frt.passenger side,0,
IDE12257-IDE00823,Extended belts witch diagnostic-Seat belt switch 2nd row center,0,
IDE12257-IDE00824,Extended belts witch diagnostic-Seat belt switch 3rd row driver's side,0,
IDE12257-IDE00825,Extended belts witch diagnostic-Passenger side 3rd row seat belt switch,0,
IDE12257-IDE00826,Extended belts witch diagnostic-Seat belt switch 3rd row center,0,
IDE12257-IDE14842,Extended belts witch diagnostic-Center seat belt switch,0,
IDE12257-IDE14843,Extended belts witch diagnostic-Seat belt switch: 4th row driver side,0,
IDE12257-IDE14844,Extended belts witch diagnostic-Seat belt switch: 4th row passenger side,0,
IDE12257-IDE14845,Extended belts witch diagnostic-Seat belt switch: 4th row center,0,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,1,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,13,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,3,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,0,
IDE12257-MAS00026,Extended belts witch diagnostic-Front passenger side safety belt switch,0,
IDE12257-MAS00478,Extended belts witch diagnostic-Reserved,0,
IDE12257-MAS00478,Extended belts witch diagnostic-Reserved,1,
IDE12257-MAS01632,Extended belts witch diagnostic-Status,not installed,
IDE12257-MAS01632,Extended belts witch diagnostic-Status,not connected,
IDE12257-MAS09326,Extended belts witch diagnostic-Function,not active,
IDE12257-MAS09326,Extended belts witch diagnostic-Function,active,
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,no measured value present,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,no measured value present,
IDE14239-MAS01632,Igniter for high-voltage battery 2 open circuit-Status,not installed,
IDE14239-MAS05030,Igniter for high-voltage battery 2 open circuit-Resistance,no measured value present,
IDE14240-MAS01632,Driver side seat occupancy detection-Status,not installed,
IDE14240-MAS05030,Driver side seat occupancy detection-Resistance,no measured value present,
IDE14662-IDE13284,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 3rd row driver side,0,
IDE14662-IDE13586,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 3rd row front passenger side,0,
IDE14662-IDE14240,Expanded diagnosis of seat occupancy detection-Driver side seat occupancy detection,0,
IDE14662-IDE14846,Expanded diagnosis of seat occupancy detection-Seat occupancy detection: center,0,
IDE14662-IDE14847,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row driver side,0,
IDE14662-IDE14848,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row front passenger side,0,
IDE14662-IDE14849,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row center,0,
IDE14662-MAS00038,Expanded diagnosis of seat occupancy detection-Seat occupied recognition: driver side: rear,0,
IDE14662-MAS00039,Expanded diagnosis of seat occupancy detection-Seat occupied recognition: passenger side: rear,0,
IDE14662-MAS00040,Expanded diagnosis of seat occupancy detection-Seat occupied recognition: center: rear,0,
IDE14662-MAS00231,Expanded diagnosis of seat occupancy detection-Seat occupied recognition passenger side,0,
IDE14662-MAS00478,Expanded diagnosis of seat occupancy detection-Reserved,0,
IDE14662-MAS01632,Expanded diagnosis of seat occupancy detection-Status,not installed,
IDE14662-MAS09326,Expanded diagnosis of seat occupancy detection-Function,not active,
IDE14662-MAS18987,Expanded diagnosis of seat occupancy detection-Seat occupancy detection: 3rd row center,0,
IDE14740-IDE13284,Wireless seat occupancy detection-Seat-occupied recognition: 3rd row driver side,not installed,
IDE14740-IDE13586,Wireless seat occupancy detection-Seat-occupied recognition: 3rd row front passenger side,not installed,
IDE14740-IDE14240,Wireless seat occupancy detection-Driver side seat occupancy detection,not installed,
IDE14740-IDE14846,Wireless seat occupancy detection-Seat occupancy detection: center,not installed,
IDE14740-IDE14847,Wireless seat occupancy detection-Seat-occupied recognition: 4th row driver side,not installed,
IDE14740-IDE14848,Wireless seat occupancy detection-Seat-occupied recognition: 4th row front passenger side,not installed,
IDE14740-IDE14849,Wireless seat occupancy detection-Seat-occupied recognition: 4th row center,not installed,
IDE14740-MAS00038,Wireless seat occupancy detection-Seat occupied recognition: driver side: rear,not installed,
IDE14740-MAS00039,Wireless seat occupancy detection-Seat occupied recognition: passenger side: rear,not installed,
IDE14740-MAS00040,Wireless seat occupancy detection-Seat occupied recognition: center: rear,not installed,
IDE14740-MAS00231,Wireless seat occupancy detection-Seat occupied recognition passenger side,not installed,
IDE14740-MAS18987,Wireless seat occupancy detection-Seat occupancy detection: 3rd row center,not installed,
IDE14741-IDE00821,Wireless belt buckle query-Seat belt switch 2nd row driver's side,not installed,
IDE14741-IDE00822,Wireless belt buckle query-Safety belt switch 2nd row frt.passenger side,not installed,
IDE14741-IDE00823,Wireless belt buckle query-Seat belt switch 2nd row center,not installed,
IDE14741-IDE00824,Wireless belt buckle query-Seat belt switch 3rd row driver's side,not installed,
IDE14741-IDE00825,Wireless belt buckle query-Passenger side 3rd row seat belt switch,not installed,
IDE14741-IDE00826,Wireless belt buckle query-Seat belt switch 3rd row center,not installed,
IDE14741-IDE14842,Wireless belt buckle query-Center seat belt switch,not installed,
IDE14741-IDE14843,Wireless belt buckle query-Seat belt switch: 4th row driver side,not installed,
IDE14741-IDE14844,Wireless belt buckle query-Seat belt switch: 4th row passenger side,not installed,
IDE14741-IDE14845,Wireless belt buckle query-Seat belt switch: 4th row center,not installed,
IDE14741-MAS00025,Wireless belt buckle query-Driver seat belt switch,not installed,
IDE14741-MAS00026,Wireless belt buckle query-Front passenger side safety belt switch,not installed,
IDE14841-MAS01632,Seat Belt Tensioner Igniter: center 3rd row-Status,not installed,
IDE14841-MAS05030,Seat Belt Tensioner Igniter: center 3rd row-Resistance,no measured value present,
IDE14842-MAS01632,Center seat belt switch-Status,not installed,
IDE14842-MAS05030,Center seat belt switch-Resistance,no measured value present,
IDE14846-MAS01632,Seat occupancy detection: center-Status,not installed,
IDE14846-MAS05030,Seat occupancy detection: center-Resistance,no measured value present,
IDE15772-MAS14174,Wireless belt request/seat occupancy detection status-2nd Row Center,not configured,
IDE15772-MAS20984,Wireless belt request/seat occupancy detection status-1st Row Driver Side,not configured,
IDE15772-MAS20985,Wireless belt request/seat occupancy detection status-1st Row Passenger Side,not configured,
IDE15772-MAS20986,Wireless belt request/seat occupancy detection status-1st Row Center,not configured,
IDE15772-MAS20987,Wireless belt request/seat occupancy detection status-3rd Row Center,not configured,
IDE15772-MAS20988,Wireless belt request/seat occupancy detection status-4th Row Center,not configured,
IDE15772-MAS20989,Wireless belt request/seat occupancy detection status-4th Row Passenger Side,not configured,
IDE15772-MAS20990,Wireless belt request/seat occupancy detection status-3rd Row Passenger Side,not configured,
IDE15772-MAS20991,Wireless belt request/seat occupancy detection status-2nd Row Passenger Side,not configured,
IDE15772-MAS20992,Wireless belt request/seat occupancy detection status-2nd Row Driver Side,not configured,
IDE15772-MAS20993,Wireless belt request/seat occupancy detection status-3rd Row Driver Side,not configured,
IDE15772-MAS20994,Wireless belt request/seat occupancy detection status-4th Row Driver Side,not configured,
IDE16064-MAS01632,Driver Head Curtain Airbag Igniter 2-Status,not installed,
IDE16064-MAS05030,Driver Head Curtain Airbag Igniter 2-Resistance,no measured value present,
IDE16065-MAS01632,Front Passenger Head Curtain Airbag Igniter 2-Status,not installed,
IDE16065-MAS05030,Front Passenger Head Curtain Airbag Igniter 2-Resistance,no measured value present,
MAS00001-MAS01632,Driver airbag igniter-Status,correct,
MAS00001-MAS05030,Driver airbag igniter-Resistance,2.9, Ohm
MAS00002-MAS01632,Driver's Airbag Igniter 2-Status,not installed,
MAS00002-MAS05030,Driver's Airbag Igniter 2-Resistance,no measured value present,
MAS00003-MAS01632,Front passenger airbag igniter-Status,correct,
MAS00003-MAS05030,Front passenger airbag igniter-Resistance,2.0, Ohm
MAS00004-MAS01632,Front passenger airbag igniter 2-Status,not installed,
MAS00004-MAS05030,Front passenger airbag igniter 2-Resistance,no measured value present,
MAS00005-MAS01632,Driver thorax airbag igniter-Status,correct,
MAS00005-MAS05030,Driver thorax airbag igniter-Resistance,2.4, Ohm
MAS00006-MAS01632,Front passenger side airbag igniter-Status,correct,
MAS00006-MAS05030,Front passenger side airbag igniter-Resistance,2.0, Ohm
MAS00007-MAS01632,Driver side rear thorax airbag igniter-Status,not installed,
MAS00007-MAS05030,Driver side rear thorax airbag igniter-Resistance,no measured value present,
MAS00008-MAS01632,Passenger side rear thorax airbag igniter-Status,not installed,
MAS00008-MAS05030,Passenger side rear thorax airbag igniter-Resistance,no measured value present,
MAS00009-MAS01632,Driver head curtain airbag igniter-Status,correct,
MAS00009-MAS05030,Driver head curtain airbag igniter-Resistance,2.2, Ohm
MAS00010-MAS01632,Front passenger head curtain airbag igniter-Status,correct,
MAS00010-MAS05030,Front passenger head curtain airbag igniter-Resistance,2.4, Ohm
MAS00011-MAS01632,Driver knee airbag igniter-Status,not installed,
MAS00011-MAS05030,Driver knee airbag igniter-Resistance,no measured value present,
MAS00012-MAS01632,Front passenger knee airbag igniter-Status,not installed,
MAS00012-MAS05030,Front passenger knee airbag igniter-Resistance,no measured value present,
MAS00013-MAS01632,Driver side seat belt tension igniter-Status,correct,
MAS00013-MAS05030,Driver side seat belt tension igniter-Resistance,2.6, Ohm
MAS00014-MAS01632,Front passenger side seat belt tension igniter-Status,correct,
MAS00014-MAS05030,Front passenger side seat belt tension igniter-Resistance,2.4, Ohm
MAS00015-MAS01632,Driver's Safety Belt Tensioner Igniter 2-Status,not installed,
MAS00015-MAS05030,Driver's Safety Belt Tensioner Igniter 2-Resistance,no measured value present,
MAS00016-MAS01632,Front passenger seat belt tensioner igniter 2-Status,not installed,
MAS00016-MAS05030,Front passenger seat belt tensioner igniter 2-Resistance,no measured value present,
MAS00017-MAS01632,Driver's Belt Force Limiter-Status,not installed,
MAS00017-MAS05030,Driver's Belt Force Limiter-Resistance,no measured value present,
MAS00018-MAS01632,Front passenger side belt force limiter igniter-Status,not installed,
MAS00018-MAS05030,Front passenger side belt force limiter igniter-Resistance,no measured value present,
MAS00019-MAS01632,Driver side rear safety belt tension igniter-Status,correct,
MAS00019-MAS05030,Driver side rear safety belt tension igniter-Resistance,2.6, Ohm
MAS00020-MAS01632,Passenger side rear seat belt tensioner igniter-Status,correct,
MAS00020-MAS05030,Passenger side rear seat belt tensioner igniter-Resistance,2.6, Ohm
MAS00021-MAS01632,Center rear seat belt tensioner igniter-Status,not installed,
MAS00021-MAS05030,Center rear seat belt tensioner igniter-Resistance,no measured value present,
MAS00022-MAS01632,Battery Interrupt Igniter-Status,not installed,
MAS00022-MAS05030,Battery Interrupt Igniter-Resistance,no measured value present,
MAS00023-MAS01632,Driver side active head restraint igniter-Status,not installed,
MAS00023-MAS05030,Driver side active head restraint igniter-Resistance,no measured value present,
MAS00024-MAS01632,Igniter for active head restraint on frt. passenger side-Status,not installed,
MAS00024-MAS05030,Igniter for active head restraint on frt. passenger side-Resistance,no measured value present,
MAS00025-MAS01632,Driver seat belt switch-Status,not connected,
MAS00025-MAS05030,Driver seat belt switch-Resistance,0.0, Ohm
MAS00026-MAS01632,Front passenger side safety belt switch-Status,not connected,
MAS00026-MAS05030,Front passenger side safety belt switch-Resistance,0.0, Ohm
MAS00030-MAS01632,Seat occupied recognition-Status,Not assigned,
MAS00030-MAS05030,Seat occupied recognition-Resistance,408.0, Ohm
MAS00031,Airbag deactivation status,On,
MAS00032-MAS01632,Key switch terminal 1-Status,On,
MAS00032-MAS05030,Key switch terminal 1-Resistance,660.0, Ohm
MAS00033-MAS01632,Key switch terminal 2-Status,On,
MAS00033-MAS05030,Key switch terminal 2-Resistance,1280.0, Ohm
MAS00035-MAS01632,Seat position sensor: driver side-Status,not installed,
MAS00035-MAS04136,Seat position sensor: driver side-Current,no measured value present,
MAS00036-MAS01632,Seat position sensor: front passenger side-Status,not installed,
MAS00036-MAS04136,Seat position sensor: front passenger side-Current,no measured value present,
MAS00038-MAS01632,Seat occupied recognition: driver side: rear-Status,assigned,
MAS00038-MAS05030,Seat occupied recognition: driver side: rear-Resistance,too large,
MAS00039-MAS01632,Seat occupied recognition: passenger side: rear-Status,assigned,
MAS00039-MAS05030,Seat occupied recognition: passenger side: rear-Resistance,too large,
MAS00040-MAS01632,Seat occupied recognition: center: rear-Status,assigned,
MAS00040-MAS05030,Seat occupied recognition: center: rear-Resistance,too large,
MAS01634-IDE00020,Supply voltage-Terminal 15 status,On,
MAS01634-IDE00773,Supply voltage-Terminal 15 status via CAN,On,
MAS01634-IDE02537,Supply voltage-Terminal 30 status,correct,
MAS01634-MAS06489,Supply voltage-Terminal 15 signal,13.6, V
MAS01634-MAS06982,Supply voltage-Terminal 15 status signal,On,
MAS01634-MAS15175,Supply voltage-Terminal 30,14.6, V
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18987-MAS01632,Seat occupancy detection: 3rd row center-Status,not installed,
MAS18987-MAS05030,Seat occupancy detection: 3rd row center-Resistance,no measured value present,
Elapsed Time: 00:19
blockmap-17-5FA-920-790-C_VSSZZZKM2RR140480-20241020-1456.CSV
;SW:5FA-920-790-C   HW:5FA-920-790-C ---  Instruments
;Component:KOMBI         311 7360, Coding:242C04416B940600018162032000080800300400
;EV_DashBoardVDDMQB37W,003035,EV_DashBoardVDDMQB37W_003_VW49.rod
;Sunday,20,October,2024,14:56:59:49859
;VCID: 3A2AEB283CD3B5EA51F-806E
IDE00019,Voltage terminal 30,12.0, V
IDE00021,Engine RPM,0.00, /min
IDE00025,Coolant temperature,65.25, °C
IDE00196,Engine oil temperature,49, °C
IDE00316-IDE00500,Time-Hour,14, H
IDE00316-IDE00501,Time-Minute,55, min
IDE00316-MAS00111,Time-Seconds,49, s
IDE00317-IDE00502,Date-Year,2024, yr
IDE00317-IDE00503,Date-Month,10, Months
IDE00317-IDE00504,Date-Day,20, d
IDE00706,Fuel level gasoline,101.6, %
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,2040, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2122, mm
IDE01076,Time since ignition off,3106, s
IDE01985-MAS06855,FAZIT identification test sum-Test sum,34 D0 26 F8,
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,15.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,232,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,0,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,100,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,254,
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assist,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Traffic sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03471-ENG164384,Vehicle configuration-virtual_side_mirror,Correct coding,
IDE03471-ENG174709,Vehicle configuration-zFAS,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,21.7, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,49.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,51.5, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,21.2, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,13.9, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,37.9, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,37.9, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,14.3, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,18.9, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,39.9, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,39.9, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,19.5, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,41.8, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,49.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,51.5, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,42.0, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,140.0, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,120.0, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,100.0, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,60.0, km
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,107, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,1, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,32767, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,32767, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,32767, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,1439,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,108,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,2216,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,235,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,38.8, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,106, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,40.3, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-IDE00802,Calculated volume-Full volume,49.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,40.3, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,3276.7, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,3276.7, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,3276.7, l
IDE03474-MAS18153,Calculated volume-Calculated volume unlimited: sensor 1,40.3, l
IDE03474-MAS18154,Calculated volume-Calculated volume unlimited: sensor 2,3276.7, l
IDE03474-MAS18155,Calculated volume-Calculated volume unlimited: sensor 3,3276.7, l
IDE03474-MAS18156,Calculated volume-Calculated volume unlimited: sensor 4,3276.7, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000,
IDE03474-ENG102894,Calculated volume-averaged_volume,40.3, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,40.3, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,40.3, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,1.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,-0.40625, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-11.93750, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,40.3, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000,
IDE03474-ENG99683,Calculated volume-version_of_application,117,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0016661,
IDE03477-IDE00500,GPS time-Hour,1, H
IDE03477-IDE00501,GPS time-Minute,57, min
IDE03477-IDE00501,GPS time-Minute,56, min
IDE03477-IDE00502,GPS time-Year,2024, yr
IDE03477-IDE00503,GPS time-Month,10, Months
IDE03477-IDE00504,GPS time-Day,20, d
IDE03477-MAS00111,GPS time-Seconds,2, s
IDE03477-MAS00111,GPS time-Seconds,45, s
IDE03477-MAS03493,GPS time-last synchronization year,2024, yr
IDE03506,Distance: high resolution,00 18 D2 74,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 69,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 07,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 07,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 69,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-ENG263219,Service -interval- display: history 1-Block_16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-ENG263219,Service -interval- display: history 2-Block_16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-ENG263219,Service -interval- display: history 3-Block_16,FF FF FF FF,
IDE03914-ENG263219,Service -interval- display: history 4-Block_16,FF FF FF FF,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE06924,Performance display,4093,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,08,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08343,Immobilizer Challenge,CC 6C 99 38,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 14|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 14 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,133,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12972,Oil: theoretical service interval,29000.00, km
IDE12973,Oil: service interval exceeded in km,0, km
IDE12974,Oil service interval exceeded in days,0, d
IDE12975,Oil: remaining driving distance,27400, km
IDE12976,Oil: remaining running time,666, d
IDE12977-MAS07266,Oil status-Oil change: unit of dist. travelled,miles,
IDE12977-MAS07267,Oil status-Oil change: dist. travelled,17100,
IDE12977-MAS07268,Oil status-Oil change: stat. of dist. travelled,Service in,
IDE12977-MAS07269,Oil status-Oil change: stat. of time,Service in,
IDE12977-MAS07270,Oil status-Inspection: stat. of dist. travelled,Service in,
IDE12977-MAS07271,Oil status-Inspection: unit of dist. travelled,miles,
IDE12977-MAS07272,Oil status-Inspection: dist. travelled,19000,
IDE12977-MAS07273,Oil status-Inspection: time,690,
IDE12977-MAS07274,Oil status-Oil change warning,no warning,
IDE12977-MAS07277,Oil status-Inspections warning,no warning,
IDE12977-MAS07305,Oil status-Oil change: time,666,
IDE12977-MAS07308,Oil status-Inspection: status time,Service in,
IDE12977-MAS10768,Oil status-Daily mileage,100,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,VSSZZZKM2RR140480,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,11,
IDE14124-IDE03840,Gong status-Volume of actuator test,0, %
IDE14124-MAS01167,Gong status-Actuation time,Unknown (0)
IDE14124-MAS05781,Gong status-Acoustics,all_acoustics,
IDE14124-ENG261531,Gong status-IO Reached Status,Output diagnostic test not active,
IDE14126-MAS01167,Other function lights status-Actuation time,Unknown (0)
IDE14126-MAS01168,Other function lights status-Start parameter,00 00 00,
IDE14126-ENG261531,Other function lights status-IO Reached Status,Output diagnostic test not active,
IDE14127-MAS01167,Lights status-Actuation time,Unknown (0)
IDE14127-MAS01168,Lights status-Start parameter,00 00 00,
IDE14127-ENG261531,Lights status-IO Reached Status,Output diagnostic test not active,
IDE14129-IDE04290,Segment test status-Color code,White,
IDE14129-MAS01167,Segment test status-Actuation time,Unknown (0)
IDE14129-ENG261531,Segment test status-IO Reached Status,Output diagnostic test not active,
IDE14130-MAS01167,Test image in center display status-Actuation time,Unknown (0)
IDE14130-MAS01168,Test image in center display status-Start parameter,Unknown (0)
IDE14130-ENG261531,Test image in center display status-IO Reached Status,Output diagnostic test not active,
IDE14132-MAS01167,Indicator lamp status-Actuation time,Unknown (0)
IDE14132-MAS01168,Indicator lamp status-Start parameter,00 00 00,
IDE14132-ENG261531,Indicator lamp status-IO Reached Status,Output diagnostic test not active,
IDE14185-IDE00301,Gas systems test-Mileage,0, km
IDE14185-IDE00502,Gas systems test-Year,2001, yr
IDE14185-IDE00503,Gas systems test-Month,1, Months
IDE14185-IDE00504,Gas systems test-Day,1, d
IDE14185-MAS17869,Gas systems test-Time since last reset,0, d
IDE14185-MAS17870,Gas systems test-Number of resets,0,
IDE14212-ENG103300,Service Key Master daily data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14213-ENG103300,Service Key Master current data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14214-ENG263244,Service Key Master write counter-Counter_current_clamp_15,0,
IDE14214-ENG263245,Service Key Master write counter-Counter_current_total,371,
IDE14214-ENG263246,Service Key Master write counter-Counter_daily_clamp_15,0,
IDE14214-ENG263247,Service Key Master write counter-Counter_daily_total,152,
IDE14214-ENG119822,Service Key Master write counter-Error_Counter,0,
IDE14214-ENG263298,Service Key Master write counter-state_current,Engine_off,
IDE14214-ENG263299,Service Key Master write counter-State_daily,Engine_off,
IDE14214-ENG263221,Service Key Master write counter-transponder_id,00 00 00 00,
IDE14214-ENG263220,Service Key Master write counter-Transponder_type,00 00,
IDE14236-MAS00106,Authentic time: last confirmed time-Year,1970, yr
IDE14236-MAS00107,Authentic time: last confirmed time-Month,1, Months
IDE14236-MAS00108,Authentic time: last confirmed time-Day,1, d
IDE14236-MAS00109,Authentic time: last confirmed time-Hours,0, H
IDE14236-MAS00110,Authentic time: last confirmed time-Minutes,0, min
IDE14236-MAS00111,Authentic time: last confirmed time-Seconds,0, s
IDE14236-MAS03617,Authentic time: last confirmed time-Time zone,0, H
IDE14237-MAS00106,Authentic time: actual time-Year,1970, yr
IDE14237-MAS00107,Authentic time: actual time-Month,1, Months
IDE14237-MAS00108,Authentic time: actual time-Day,1, d
IDE14237-MAS00109,Authentic time: actual time-Hours,0, H
IDE14237-MAS00110,Authentic time: actual time-Minutes,0, min
IDE14237-MAS00111,Authentic time: actual time-Seconds,0, s
IDE14237-MAS03617,Authentic time: actual time-Time zone,0, H
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,00,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,|Verification failed|00 00|,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,|failed signature creation|00 00|,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,00,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,00,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,00,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 20 9A 17 E9 9B 36 72,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,00,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,7,
IDE14496-ENG103935,Secure Onboard Communication: Freshness Values information-Parameter,|SOC PDU ID to which this freshness information is assigned,Freshness Value query status
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,|Missing key|00 00|,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,00,
IDE15081,Authentic time: status of distribution signal trigger,0,
MAS00902-ENG99140,Extended Service Intervals (ESI)-advance_warning_fixed_days,not active,
MAS00902-ENG100265,Extended Service Intervals (ESI)-advance_warning_fixed_km,not active,
MAS00902-ENG101600,Extended Service Intervals (ESI)-advance_warning_WIV_days,not active,
MAS00902-ENG102887,Extended Service Intervals (ESI)-advance_warning_WIV_km,not active,
MAS00902-ENG99971,Extended Service Intervals (ESI)-in_calculation,active,
MAS00902-ENG101015,Extended Service Intervals (ESI)-no_calculation_available,not active,
MAS00902-ENG101477,Extended Service Intervals (ESI)-service_warning_fixed_days,not active,
MAS00902-ENG101550,Extended Service Intervals (ESI)-service_warning_fixed_km,not active,
MAS00902-ENG101709,Extended Service Intervals (ESI)-service_warning_WIV_days,not active,
MAS00902-ENG102993,Extended Service Intervals (ESI)-service_warning_WIV_km,not active,
MAS10768,Daily mileage,100, km
ENG186121,Authentic_time_current_counter_kl15_since_last_sync,186,
ENG262946,Authentic_time_last_backend_response,|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||,
ENG186123,Authentic_time_last_client_response,1970-01-01T00:00:00Z,
ENG186123,Authentic_time_last_client_response,186,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0.0,
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,92, %
ENG105830-ENG100577,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_day,0.0,
ENG105830-ENG263248,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_night,0, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,0, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG263249,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_blue,0.0,
ENG105830-ENG263250,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_green,0.0,
ENG105830-ENG263251,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_red,0.0,
ENG105830-ENG263252,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_yellow,0.0,
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,67, %
ENG105830-ENG261530,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_internal characteristic_phototransistor,1505,
ENG99439,Instrument_recorder,07 73 60 00 4D 51 42 32 30 32 30 32 32 53 31 46 41 43 47 36 35 39 34 33 37 35 5F 00 03 00 D6 00 1F 00 00 02 8A 00 00 00 02 00 00 00 02 00 06 24 4B 5B 04 17 F0 00 C4 00 20 00 00 02 97 00 00 00 01 80 00 00 02 00 06 24 4B 5B 04 17 F0 01 33 00 30 00 00 01 21 00 00 00 00 00 00 00 02 00 06 23 51 AB 16 04 B0 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 FF FF FF FF FF FF FF FF FF 00 00 20 00 C4 00 97 02 00 00 01 00 00 00 4B 24 06 00 F0 17 04 5B 1F 00 D6 00 8A 02 00 00 02 00 00 00 4B 24 06 00 F0 17 04 5B 30 00 33 01 21 01 00 00 00 00 00 00 51 23 06 00 B0 04 16 AB FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 5E 00 03 00 00 00 04 00 04 00 02 00 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 02 00 8C FF B7 00 00 10 3B 00 8C FF FF FF 00 00 B8 86 C8 B1 4E 4E 84 AC 00 00 00 01 F3 B0 FF B7 00 00 00 00 00 00 54 41 A8 48 80 00 40 00 03 38 0E 00 00 00 A8,
ENG128745,Instrument_recorder_graphic,05 73 60 00 4D 51 42 32 30 32 30 32 32 53 31 46 47 43 5F 53 45 E9 24 06 00 75 2C 20 BB D4 02 00 00 3E 00 00 00 7B 00 00 00 00 00 00 00 31 03 00 00 4B 03 00 00 02 00 00 00 E9 24 06 00 C5 2C 20 BB 11 01 00 00 0F 00 00 00 88 01 00 00 00 00 00 00 31 03 00 00 4B 03 00 80 02 00 00 00 E8 24 06 00 B7 F3 2D FA 84 00 00 00 06 00 00 00 00 01 0F 00 00 00 00 00 30 03 00 00 47 00 00 00 02 00 00 00 E7 24 06 00 E4 60 53 F3 0C 01 00 00 0E 00 00 00 0E 04 00 00 01 00 00 00 2C 03 00 00 08 00 00 00 02 00 00 00 52 23 06 00 66 EE 17 35 BD 04 00 00 66 00 00 00 55 01 01 00 00 00 00 00 7E 02 00 00 13 00 00 00 02 00 00 00 6B 24 06 00 08 21 C6 3A AD 02 00 00 37 00 00 00 BB 04 00 00 00 00 00 00 F9 02 00 00 4D 00 00 00 02 00 00 00 B8 23 06 00 A7 A7 52 14 8C 00 00 00 07 00 00 00 95 00 44 00 44 23 00 00 C6 02 00 00 18 01 00 00 02 00 00 00 B8 23 06 00 F0 B3 51 14 8C 00 00 00 07 00 00 00 95 00 44 00 44 23 00 00 C6 02 00 00 03 00 00 00 02 00 00 00 8E 23 06 00 6F 73 2D B0 95 03 00 00 4C 00 00 00 E4 03 0C 00 00 00 00 00 C3 02 00 00 01 00 00 00 02 00 00 00 BB 24 06 00 59 34 9A 82 82 02 00 00 2F 00 00 00 E8 00 00 00 00 00 00 00 15 03 00 00 49 01 00 00 04 00 00 00 36 24 06 00 5D 71 03 A5 8C 00 00 00 07 00 00 00 95 00 44 00 3B 23 00 00 DD 02 00 00 24 00 00 00 02 00 00 00 36 24 06 00 B4 7F 02 A5 8C 00 00 00 07 00 00 00 95 00 44 00 3B 23 00 00 DD 02 00 00 01 00 00 00 02 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 7E 00 00 00 9D 01 00 00 62 11 13 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 38 64 31 37 35 38 36 78 02 00 00 00 31 03 00 00 02 00 00 00 AB FA FF FF 00 00 00 00 D1 C4 FF FF 0C 00 00 00 1A 20 7F 05 01 FF FF FF,
ENG264452,Instrument_recorder_graphic_3,||05|73|60|00|4D|51|42|32|30|32|30|32|32|53|31|46|47|43|5F|53|45|E8|24|06|00|A5|1A|9A|B5|D4|02|00|00|3E|00|00|00|7B|00|00|00|00|00|00|00|2F|03|00|00|49|03|00|00|02|00|00|00|E8|24|06|00|E6|1A|9A|B5|11|01|00|00|0F|00|00|00|88|01|00|00|00|00|00|00|2F|03|00|00|49|03|00|00|02|00|00|00|E8|24|06|00|B7|F3|2D|FA|84|00|00|00|06|00|00|00|00|01|0F|00|00|00|00|00|30|03|00|00|47|00|00|80|02|00|00|00|E7|24|06|00|E4|60|53|F3|0C|01|00|00|0E|00|00|00|0E|04|00|00|01|00|00|00|2C|03|00|00|08|00|00|00|02|00|00|00|52|23|06|00|66|EE|17|35|BD|04|00|00|66|00|00|00|55|01|01|00|00|00|00|00|7E|02|00|00|13|00|00|00|02|00|00|00|6B|24|06|00|08|21|C6|3A|AD|02|00|00|37|00|00|00|BB|04|00|00|00|00|00|00|F9|02|00|00|4D|00|00|00|02|00|00|00|B8|23|06|00|A7|A7|52|14|8C|00|00|00|07|00|00|00|95|00|44|00|44|23|00|00|C6|02|00|00|18|01|00|00|02|00|00|00|B8|23|06|00|F0|B3|51|14|8C|00|00|00|07|00|00|00|95|00|44|00|44|23|00|00|C6|02|00|00|03|00|00|00|02|00|00|00|8E|23|06|00|6F|73|2D|B0|95|03|00|00|4C|00|00|00|E4|03|0C|00|00|00|00|00|C3|02|00|00|01|00|00|00|02|00|00|00|BB|24|06|00|59|34|9A|82|82|02|00|00|2F|00|00|00|E8|00|00|00|00|00|00|00|15|03|00|00|49|01|00|00|04|00|00|00|36|24|06|00|5D|71|03|A5|8C|00|00|00|07|00|00|00|95|00|44|00|3B|23|00|00|DD|02|00|00|24|00|00|00|02|00|00|00|36|24|06|00|B4|7F|02|A5|8C|00|00|00|07|00|00|00|95|00|44|00|3B|23|00|00|DD|02|00|00|01|00|00|00|02|00|00|00|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|00|00|00|00|7E|00|00|00|9D|01|00|00|62|11|16|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|38|64|31|37|35|38|36|78|02|00|00|00|30|03|00|00|02|00|00|00|AC|FA|FF|FF|00|00|00|00|D1|C4|FF|FF|0C|00|00|00|D3|43|8B|10|02|FF|FF|FF|,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,130,
Elapsed Time: 00:17
blockmap-19-5WA-907-530-AB_VSSZZZKM2RR140480-20241020-1458.CSV
;SW:5WA-907-530-AB   HW:5WA-907-530-L ---  CAN Gateway
;Component:GW2020 High   778 7105, Coding:0000808D0F00000000000000012303135101610B02000300030100000001010000000000000000000000000000000000
;EV_GatewMQB2020,006012,EV_GatewMQB2020_006_VW38.rod
;Sunday,20,October,2024,14:58:02:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 084E41E032BF177A17B-805C
Group,Description,Actual
IDE00056,History data 1,000*2000-01-01-00:00*0000*00**,
IDE00056,History data 1,000*2024-10-14-17:13*0000*01**,
IDE00056,History data 1,000*2024-10-11-09:45*0000*01**,
IDE00056,History data 1,000*2024-09-30-10:20*0000*01*00000**,
IDE00056,History data 1,000*2024-10-19-07:24*0000*01*01794**,
IDE00056,History data 1,000*2000-01-01-00:00*0000*00*00000**,
IDE00057,History data 2,000*2000-01-01-00:00*000*000*+0.000*0-0-0-0-0-0-0*0*00*00000**,
IDE00057,History data 2,000*2000-01-01-00:00*000*000*+0.000*0-0-0-0-0-0-0*0*00**,
IDE00058,History data 3,000*2000-01-01-00:00*0*0*000*000*0-0-0-0-0-0-0*0*0*00.0*00.0**,
IDE00059,History data 4,000*2000-01-01-00:00*00*000*---*----------*00000*00000*000.0*000.0*000.0**,
IDE00059,History data 4,000*2024-05-28-00:13*01*059*VAO*340515F0AZ*10008*00180*000.0*000.0*000.0**,
IDE00060,History data 5,000*2000-01-01-00:00*0*+0.000*13.50*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0-0*0*0*0*00.0*00.0*000.0*00*00*00*00*00**,
IDE00061,History data 6,000*2024-10-20-09:34*044*+15*+000.5*00.00*0.00*000**,
IDE00061,History data 6,000*2024-10-20-10:08*050*+15*+002.0*00.60*0.00*001**,
IDE00061,History data 6,000*2024-10-20-12:20*048*+18*-000.1*00.00*0.00*000**,
IDE00061,History data 6,000*2024-10-20-14:01*048*+22*+000.3*00.00*0.00*000**,
IDE00061,History data 6,000*2024-10-20-11:00*048*+16*+001.3*00.60*0.00*000**,
IDE00061,History data 6,000*2024-10-20-12:14*047*+17*+000.4*00.00*0.00*000**,
IDE00061,History data 6,000*2024-10-20-13:42*049*+21*+000.4*00.00*0.00*000**,
IDE00061,History data 6,000*2024-10-20-12:52*047*+19*+000.4*00.00*0.00*000**,
IDE00061,History data 6,000*2024-10-20-12:48*047*+19*+000.4*00.00*0.00*000**,
IDE00061,History data 6,000*2024-10-20-12:03*047*+17*+000.2*00.00*0.00*000**,
IDE00062,History data 7,000*2024-10-20-12:21*047*+000.4*000.0*00.0*00.0**,
IDE00062,History data 7,000*2024-10-20-12:50*046*+000.2*000.0*00.0*00.0**,
IDE00062,History data 7,000*2024-10-20-12:16*046*+000.3*000.0*00.0*00.0**,
IDE00062,History data 7,000*2024-10-20-12:55*048*+000.4*000.0*00.0*00.0**,
IDE00062,History data 7,000*2024-10-20-10:45*049*+001.1*000.0*00.0*00.0**,
IDE00062,History data 7,000*2024-10-20-13:45*048*+000.3*000.0*00.0*00.0**,
IDE00062,History data 7,000*2024-10-20-09:38*044*+000.3*000.0*00.0*00.0**,
IDE00062,History data 7,000*2024-10-20-12:06*047*+000.3*000.0*00.0*00.0**,
IDE00062,History data 7,000*2024-10-20-11:37*047*+000.5*000.0*00.0*00.0**,
IDE00062,History data 7,000*2024-10-20-09:01*045*+000.6*000.0*00.0*00.0**,
IDE00063,History data 8,000*2000-01-01-00:00*4*02*00*00*99*2024-09-30-08:36*01**,
IDE00063,History data 8,000*2000-01-01-00:00*4*02*00*00*95*2024-09-30-08:31*01**,
IDE00063,History data 8,000*2000-01-01-00:00*4*02*00*00*97*2024-09-30-08:36*01**,
IDE00064,History data 9,000*2024-09-29-19:13*100*100*100*100*00040*15.00*-40*00*01*00.00*00000*00000**,
IDE00064,History data 9,000*2024-09-29-19:09*088*096*062*041*00040*12.30*+13*04*01*00.00*00000*00000**,
IDE00064,History data 9,000*2024-09-30-06:25*100*100*100*100*00043*15.00*-40*00*01*00.00*00000*00000**,
IDE00064,History data 9,000*2024-09-29-19:32*100*100*100*100*00041*15.00*-40*00*01*00.00*00000*00000**,
IDE00064,History data 9,000*2024-09-27-13:15*100*100*100*100*00039*15.00*-40*00*01*00.00*00000*00000**,
IDE00064,History data 9,000*2024-05-28-00:00*100*100*100*100*00000*15.00*-40*00*01*00.00*00000*00000**,
IDE00064,History data 9,000*2024-10-13-13:30*082*088*078*051*00124*12.50*+18*04*01*03.10*00000*00000**,
IDE00064,History data 9,000*2024-08-30-11:20*099*100*061*046*00022*12.30*+13*03*01*00.00*00000*00000**,
IDE00064,History data 9,000*2024-09-29-19:22*100*100*100*100*00041*15.00*-40*00*01*00.00*00000*00000**,
IDE00064,History data 9,000*2024-09-30-06:20*100*100*100*100*00043*15.00*-40*00*01*00.00*00000*00000**,
IDE00064,History data 9,000*2024-09-29-20:49*100*100*100*100*00042*15.00*-40*00*01*00.00*00000*00000**,
IDE00064,History data 9,000*2024-08-30-11:22*100*100*100*100*00022*15.00*-40*00*01*00.00*00000*00000**,
IDE00065,History data 10,000*2000-01-01-00:00*0*000.0*0000.0*0*000.0*0000.0*00.00*0000000**,
IDE00065,History data 10,000*2000-01-01-00:00*00*00.0*13.50*000.0**,
IDE00066,History data 11,000*2024-10-20-12:03*000*000*000*000*0000*002*00.0*00.0*072*045*072*047*01**,
IDE00066,History data 11,000*2024-10-20-11:00*000*000*000*000*0000*036*00.0*00.0*073*046*074*048*01**,
IDE00066,History data 11,000*2024-10-20-12:14*000*000*000*000*0000*002*00.0*00.0*071*046*071*047*01**,
IDE00066,History data 11,000*2024-10-20-10:35*000*000*000*000*0000*037*00.0*00.0*075*050*075*050*02**,
IDE00066,History data 11,000*2024-10-20-12:20*000*000*000*000*0000*000*00.0*00.0*070*047*070*048*01*00026*00032*00003*00000*00331**,
IDE00067,History data 12,000*2000-01-01-00:00*0-0-0-0-0-0-0-0**,
IDE00067,History data 12,000*2000-01-01-00:00*0*000*000*-40*00*000*+00.00*13.5*0**,
IDE00067,History data 12,00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00067,History data 12,000*2024-09-30-14:34*2*060*037*+13*04*025*+41.60*11.6*1**,
IDE00067,History data 12,00000*00668*00000**,
IDE00068,History data 13,000*2000-01-01-00:00*0-0-0-0-0*000.0*00000**,
IDE00068,History data 13,000*2000-01-01-00:00*0-0-0-0-0*000.0**,
IDE00069,History data 14,000*2000-01-01-00:00*000.0*20.0*20.0**,
IDE00069,History data 14,000*2024-10-20-13:45*0*00021*0000*0000*00.00*131072*+21**,
IDE00069,History data 14,00078*00221*00080*00000*00000**,
IDE00069,History data 14,000*2024-10-20-14:04*0*00018*0000*0000*00.00*131072*+22*0000.1*0000.4*0000.0**,
IDE00069,History data 14,000*2024-10-20-14:04*000.0*04.0*04.0*0000.0**,
IDE00069,History data 14,000*2024-10-20-12:55*0*00021*0000*0000*00.00*000000*+19**,
IDE00069,History data 14,000*2024-10-20-12:50*0*00018*0000*0000*00.00*000000*+19**,
IDE00069,History data 14,000*2024-10-20-12:21*1*00013*0000*0000*00.00*000008*+18**,
IDE00071,History data 16,00003*00038*00139*00001*00000**,
IDE00071,History data 16,00133*00111*00001*00000**,
IDE00071,History data 16,00112*00031*00020**,
IDE00071,History data 16,00013*00001*00000**,
IDE00071,History data 16,00000*00006*00003*00000**,
IDE00071,History data 16,00000*00000*00000*00000**,
IDE00071,History data 16,00056*00060*00015*00032**,
IDE00071,History data 16,00001*00000*00000**,
IDE00071,History data 16,00000*00000*00000**,
IDE00071,History data 16,0001626km**,
IDE00071,History data 16,00042*00014*00008*00009*00003*00001*00004*00001*00002*00005*00000**,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-IDE15905,Cruise Control System (CCS): switch position-Travel Assist,Not operated,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,11,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,121,
IDE00634,Vehicle electrical system current,16.313, A
IDE00767-ENG280618,No. of unscheduled ECU resets-FCCU_RF_S0_Status,00 04 00 00,
IDE00767-ENG280619,No. of unscheduled ECU resets-FCCU_RF_S1_Status,00 00 00 00,
IDE00767-ENG280620,No. of unscheduled ECU resets-FCCU_RF_S2_Status,00 00 00 00,
IDE00767-ENG280621,No. of unscheduled ECU resets-FCCU_RF_S3_Status,00 00 00 00,
IDE00767-ENG136152,No. of unscheduled ECU resets-KL30_Reset_Counter,9,
IDE00767-ENG280656,No. of unscheduled ECU resets-Muc_Reset_Counter,1,
IDE00767-ENG280678,No. of unscheduled ECU resets-Reason_of_2th_last_reset,0,
IDE00767-ENG280679,No. of unscheduled ECU resets-Reason_of_3th_last_reset,0,
IDE00767-ENG280680,No. of unscheduled ECU resets-Reason_of_4th_last_reset,22,
IDE00767-ENG280681,No. of unscheduled ECU resets-Reason_of_5th_last_reset,4,
IDE00767-ENG280682,No. of unscheduled ECU resets-Reason_of_latest_reset,1,
IDE00767-ENG280768,No. of unscheduled ECU resets-Watchdog_Reset_Counter,75,
IDE01803,History data 17,000*2000-01-01-00:00*00*0*000*15.0*+00*00.0**,
IDE01803,History data 17,000*2000-01-01-00:00*00*0*000*15.0*+00*00.0*000*000**,
IDE01803,History data 17,000*2000-01-01-00:00*0*00.0*000*+00*000*000**,
IDE01803,History data 17,000*2000-01-01-00:00*0*00.0*000*+00**,
IDE01803,History data 17,00000*00000*00000*00000*00000*00000**,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.4, H
IDE01807-MAS00106,History data 21-Year,2024,
IDE01807-MAS00107,History data 21-Month,5,
IDE01807-MAS00108,History data 21-Day,28,
IDE01807-MAS00109,History data 21-Hours,0, H
IDE01807-MAS00110,History data 21-Minutes,40, min
IDE01807-MAS14375,History data 21-Cycle counter,4,
IDE01807-MAS14376,History data 21-ECU 1,00 73,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.4, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,00 00,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,00 00,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,00 00,
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,00 00,
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01807-ENG159905,History data 21-Bus_ECU_1,Infotainment data bus,
IDE01807-ENG159908,History data 21-Bus_ECU_2,Unknown,
IDE01807-ENG159911,History data 21-Bus_ECU_3,Unknown,
IDE01807-ENG159914,History data 21-Bus_ECU_4,Unknown,
IDE01807-ENG159917,History data 21-Bus_ECU_5,Unknown,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.4, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.1, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS05972,History data 22-Local data bus 3,0.0, H
IDE01808-MAS12185,History data 22-Hybrid data bus,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.4, H
IDE01808-MAS16909,History data 22-Data bus driver assistance systems,0.0, H
IDE01808-MAS16910,History data 22-Migration data bus,0.0, H
IDE01808-MAS16912,History data 22-VLAN_FAS,0.0, H
IDE01808-MAS16913,History data 22-VLAN_Infotainment,0.0, H
IDE01808-MAS16915,History data 22-VLAN_Komfort,0.0, H
IDE01808-MAS16916,History data 22-VLAN_Powertrain,0.0, H
IDE01808-MAS16917,History data 22-VLAN_Diagnose,0.0, H
IDE01808-MAS18934,History data 22-VLAN Connect,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,00 00,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,00 00,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,00 00,
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,00 00,
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,00 00,
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01809-ENG255497,History data 23-Bus_Waking_ECU_1,Unknown,
IDE01809-ENG255498,History data 23-Bus_Waking_ECU_2,Unknown,
IDE01809-ENG255499,History data 23-Bus_Waking_ECU_3,Unknown,
IDE01809-ENG255500,History data 23-Bus_Waking_ECU_4,Unknown,
IDE01809-ENG255501,History data 23-Bus_Waking_ECU_5,Unknown,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,1.2, H
IDE01810-MAS00106,History data 24-Year,2024,
IDE01810-MAS00107,History data 24-Month,9,
IDE01810-MAS00108,History data 24-Day,30,
IDE01810-MAS00109,History data 24-Hours,7, H
IDE01810-MAS00110,History data 24-Minutes,13, min
IDE01810-MAS14375,History data 24-Cycle counter,61,
IDE01810-MAS14392,History data 24-CarWakeUp Bit,0,
IDE01810-MAS14393,History data 24-ID of the alerting message,1B 00 00 0E,
IDE01810-MAS14394,History data 24-Bus of the alerting message,Comfort data bus,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,255,
IDE01810-MAS20473,History data 24-Alerting message counter,255,
IDE01812-MAS01468,History data 26-Terminal 15,187,
IDE01812-MAS03173,History data 26-Powertrain data bus,3,
IDE01812-MAS03174,History data 26-Comfort data bus,1360,
IDE01812-MAS03177,History data 26-Infotainment data bus,3,
IDE01812-MAS03178,History data 26-Suspension data bus,3,
IDE01812-MAS03180,History data 26-Local data bus,0,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS12185,History data 26-Hybrid data bus,0,
IDE01812-MAS14374,History data 26-Totals,1369,
IDE01812-MAS16909,History data 26-Data bus driver assistance systems,0,
IDE01812-MAS16910,History data 26-Migration data bus,0,
IDE01812-MAS16917,History data 26-VLAN_Diagnose,0,
IDE01813-MAS03173,History data 27-Powertrain data bus,0,
IDE01813-MAS03174,History data 27-Comfort data bus,41,
IDE01813-MAS03177,History data 27-Infotainment data bus,217,
IDE01813-MAS03178,History data 27-Suspension data bus,10,
IDE01813-MAS12185,History data 27-Hybrid data bus,0,
IDE01813-MAS14374,History data 27-Totals,268,
IDE01813-MAS16909,History data 27-Data bus driver assistance systems,0,
IDE01813-MAS16910,History data 27-Migration data bus,0,
IDE01813-MAS16912,History data 27-VLAN_FAS,0,
IDE01813-MAS16913,History data 27-VLAN_Infotainment,0,
IDE01813-MAS16915,History data 27-VLAN_Komfort,0,
IDE01813-MAS16916,History data 27-VLAN_Powertrain,0,
IDE01813-MAS18934,History data 27-VLAN Connect,0,
IDE01814-MAS03173,History data 28-Powertrain data bus,0,
IDE01814-MAS03174,History data 28-Comfort data bus,1846,
IDE01814-MAS03177,History data 28-Infotainment data bus,281,
IDE01814-MAS03178,History data 28-Suspension data bus,28,
IDE01814-MAS12185,History data 28-Hybrid data bus,0,
IDE01814-MAS14374,History data 28-Totals,2155,
IDE01814-MAS16909,History data 28-Data bus driver assistance systems,0,
IDE01814-MAS16910,History data 28-Migration data bus,0,
IDE01814-MAS16912,History data 28-VLAN_FAS,0,
IDE01814-MAS16913,History data 28-VLAN_Infotainment,0,
IDE01814-MAS16915,History data 28-VLAN_Komfort,0,
IDE01814-MAS16916,History data 28-VLAN_Powertrain,0,
IDE01814-MAS18934,History data 28-VLAN Connect,0,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,2.8, H
IDE01816-MAS00106,History data 30-Year,2024,
IDE01816-MAS00107,History data 30-Month,9,
IDE01816-MAS00108,History data 30-Day,30,
IDE01816-MAS00109,History data 30-Hours,10, H
IDE01816-MAS00110,History data 30-Minutes,38, min
IDE01816-MAS14375,History data 30-Cycle counter,61,
IDE01816-ENG151642,History data 30-Bus_1,Comfort data bus,
IDE01816-ENG151644,History data 30-Bus_2,Migration data bus,
IDE01816-ENG151646,History data 30-Bus_3,Unknown,
IDE01816-ENG151648,History data 30-Bus_4,Unknown,
IDE01816-ENG151650,History data 30-Bus_5,Unknown,
IDE01816-ENG151643,History data 30-Bus_Active_Time_1,2.9, H
IDE01816-ENG151645,History data 30-Bus_Active_Time_2,0.1, H
IDE01816-ENG151647,History data 30-Bus_Active_Time_3,0.0, H
IDE01816-ENG151649,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG151651,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.4, H
IDE01817-MAS00106,History data 31-Year,2024,
IDE01817-MAS00107,History data 31-Month,5,
IDE01817-MAS00108,History data 31-Day,28,
IDE01817-MAS00109,History data 31-Hours,0, H
IDE01817-MAS00110,History data 31-Minutes,40, min
IDE01817-MAS14375,History data 31-Cycle counter,4,
IDE01817-MAS14376,History data 31-ECU 1,00 73,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.4, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,00 00,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,00 00,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,00 00,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,00 00,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01817-ENG159905,History data 31-Bus_ECU_1,Infotainment data bus,
IDE01817-ENG159908,History data 31-Bus_ECU_2,Unknown,
IDE01817-ENG159911,History data 31-Bus_ECU_3,Unknown,
IDE01817-ENG159914,History data 31-Bus_ECU_4,Unknown,
IDE01817-ENG159917,History data 31-Bus_ECU_5,Unknown,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,00 00,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01818-MAS20474,History data 32-Cluster,00 00 00,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,1.2, H
IDE01819-MAS00106,History data 33-Year,2024,
IDE01819-MAS00107,History data 33-Month,9,
IDE01819-MAS00108,History data 33-Day,30,
IDE01819-MAS00109,History data 33-Hours,7, H
IDE01819-MAS00110,History data 33-Minutes,13, min
IDE01819-MAS14375,History data 33-Cycle counter,61,
IDE01819-MAS14393,History data 33-ID of the alerting message,1B 00 00 0E,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01819-MAS20474,History data 33-Cluster,00 00 00,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,0.0, H
IDE01820-MAS00106,History data 34-Year,2024,
IDE01820-MAS00107,History data 34-Month,10,
IDE01820-MAS00108,History data 34-Day,20,
IDE01820-MAS00109,History data 34-Hours,14, H
IDE01820-MAS00110,History data 34-Minutes,54, min
IDE01820-MAS14375,History data 34-Cycle counter,186,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 4C,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2024,
IDE01823-MAS00107,History data 37-Month,5,
IDE01823-MAS00108,History data 37-Day,28,
IDE01823-MAS00109,History data 37-Hours,7, H
IDE01823-MAS00110,History data 37-Minutes,34, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,187,
IDE01823-MAS14429,History data 37-Time in current cycle,0.0, H
IDE01831-MAS03159,Generator variant-Manufacturer,Valeo GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,82A - 140A,
IDE01831-MAS06311,Generator variant-ASIC manufacturer,1,
IDE01831-MAS06312,Generator variant-ASIC variant,4,
IDE01831-MAS21176,Generator variant-Generator model,5,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.0, Ah
IDE01848-IDE01849,Energy balance of last driving cycle-Previous journey duration,0.0, H
IDE01985-MAS06855,FAZIT identification test sum-Test sum,C2 F9 77 F3,
IDE01992-ENG100904,Installation list: current installations-ECUs present,|ECU present Bit 0,ECU present Bit 1
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0
IDE02384-ENG102478,Status of event memory-ECU Dtcs,|ECU Dtc Bit 0,ECU Dtc Bit 1
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03150-ENG299090,Readiness for bus sleep mode-ECU_Sleepindication,|Sleep-Bit 0,Sleep-Bit 1
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG299091,Bus identification-ECU_databus_identification,|bus_number,bus_type|0
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG256034,Driving profile selection: system status-link_state,not engaged,
IDE05740-ENG256107,Driving profile selection: system status-operation_state,engaged,
IDE05740-ENG255187,Driving profile selection: system status-profile_state,engaged,
IDE05814,Individualization characteristic,BD 14 EA F7 E8,
IDE05960-IDE01827,Generator-Specified generator voltage,10.6, V
IDE05960-IDE01828,Generator-Generator DF Signal,0.025, %
IDE05960-IDE01829,Generator-Generator exciter current,0.000, A
IDE05960-IDE01830,Generator-Generator Status,OFF,
IDE05960-IDE01855,Generator-Generator current,0.0, A
IDE05960-MAS06306,Generator-Status generator release by engine,no request,
IDE05960-MAS06307,Generator-Status of battery charging function,not active,
IDE05960-MAS11758,Generator-Identification,Yes,
IDE05960-MAS14589,Generator-mechanical power,0, W
IDE05960-MAS21174,Generator-Generator reserve current,0.0, A
IDE05960-MAS21325,Generator-Ramp time,6, s
IDE06011-ENG118665,Selected driving profile-driving_profile,Comfort,
IDE06011-ENG256033,Selected driving profile-link_profile,link_profile_1,
IDE06011-ENG157286,Selected driving profile-Operation_mode,Unknown (0)
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,1997, min
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0, min
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,22, min
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0, min
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,0, min
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0, min
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0, min
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0, min
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0, min
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0, min
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0, min
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2001,
IDE06230-MAS00107,Break recommend.: last message-Month,1,
IDE06230-MAS00108,Break recommend.: last message-Day,1,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,07,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07628-MAS06341,Status power receptacle-After-run for power receptacle,not active,
IDE07628,Status power receptacle,---,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,14.3, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,0, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,0, A
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.30,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,3.10, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,3.05, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,736, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,728, A
IDE07640,Analysis of start voltage behavior,---,
IDE08343,Immobilizer Challenge,5A 9A 48 F7,
IDE08346-MAS06117,Generator Analysis-Specified voltage,10.6, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,12.1, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,564, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,48, °C
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,0, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08794,Battery cell analysis,---,
IDE09058-IDE06233,Energy management: consumer releases-Auxiliary heater: controlled,0, W
IDE09058-IDE06234,Energy management: consumer releases-Auxiliary heater: in stages,not enabled,
IDE09058-IDE80251,Energy management: consumer releases-Head area heater,not enabled,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,not active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,not enabled,
IDE09058-MAS01564,Energy management: consumer releases-Front windshield heater,not enabled,
IDE09058-MAS05213,Energy management: consumer releases-Mirror heater,not enabled,
IDE09058-MAS05214,Energy management: consumer releases-Steering wheel heating,not enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heater,not enabled,
IDE09058-MAS05887,Energy management: consumer releases-Battery cut out relay 2,not enabled,
IDE09058-MAS06551,Energy management: consumer releases-Seat ventilation,not enabled,
IDE09058-MAS06552,Energy management: consumer releases-Front seat heating,not enabled,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09058-MAS21177,Energy management: consumer releases-Shut-off status,not active,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Conventional combustion engine,
IDE09074-MAS08256,Vehicle properties-Max energy content,327400, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),14.0, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,7.6, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,13.0, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,33.8, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,400, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,10.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,476, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,0, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,13, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,476, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,476, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,0, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,2047, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,300,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,300,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,2045,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,miles,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,5.0, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,5.0, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,5.0, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,5.0, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,5.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,5.0, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.0, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,13.0, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,13.0, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,13.0, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,13.0, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,13.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,13.0, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.0, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,36.3, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery: RWB-internal deduction,0, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.0, l
IDE10300,OBD Driving Cycle detected,active,
IDE10674-MAS23872,Extended battery diagnosis-Available extractable charge,13, Ah
IDE10674-ENG98590,Extended battery diagnosis-ERROR,---,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,23,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,No component function,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,No malfunction detected,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,OFF,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,0,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,good: link available,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11732,Ethernet signal quality: branch 5,good: link available,
IDE11733,Ethernet signal quality: branch 6,good: link available,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,3,
IDE11739,Ethernet counter connection interruptions: branch 4,3,
IDE11740,Ethernet counter connection interruptions: branch 5,3,
IDE11741,Ethernet counter connection interruptions: branch 6,3,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11748,Ethernet counter checksum error: branch 5,0,
IDE11749,Ethernet counter checksum error: branch 6,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 10|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 61|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 37|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 5B|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 10|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0F|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0E|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 19|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0D|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0B|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1B|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1A|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|3|4|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,224,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,182,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|44 20 63 02 4D E2|,
IDE11762-IDE02766,Information break recommendation-Malfunction status,No malfunction,
IDE11762-MAS03095,Information break recommendation-Function status,Initialization,
IDE11762-MAS04622,Information break recommendation-Break recommend. message,No message,
IDE11762-MAS13162,Information break recommendation-Icon deactivated,No,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,Write only channel,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|02 7D FA 00 14 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|44 3C 88 5A 36 98|,
IDE11992-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 5-MAC address,|MAC address|30 0E B8 5A 3F 10|,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,|MAC address|30 0E B8 CB DB 2D|,
IDE12084-IDE02185,Component protection participant status-IKA key,stored,
IDE12084-IDE10163,Component protection participant status-Authorization status,valid authentication,
IDE12084-MAS06772,Component protection participant status-Component protection generation,Generation 2,
IDE12084-MAS13795,Component protection participant status-Node address,00 0E,
IDE12084-MAS16977,Component protection participant status-Shut-off of the start authentication,locked,
IDE12084-MAS16978,Component protection participant status-Start authentication,switched on,
IDE12084-MAS18011,Component protection participant status-Query message,Sent,
IDE12084-ENG157306,Component protection participant status-Status_of_component_protection_slaves,|Node address,IKA key
IDE12133-MAS01896,Freewheel - energy-Free run,25, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,No enabling,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Release,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,Write only channel,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|5|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|5|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|2|,
IDE12234-MAS14856,IP network: VLANs of Ethernet switch ports branch 5-VLAN,|VLAN|3|,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,189,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12625,IP network: current link deceleration: branch 1,65535, µs
IDE12626,IP network: current link deceleration: branch 2,65535, µs
IDE12627,IP network: current link deceleration: branch 3,65535, µs
IDE12628,IP network: current link deceleration: branch 4,65535, µs
IDE12629,IP network: current link deceleration: branch 5,65535, µs
IDE12630,IP network: current link deceleration: branch 6,65535, µs
IDE12633,IP Network maximum correction of the synchronized clock,-1, µs
IDE12806-ENG299124,Diagnostic capability of the bus interface-Diag_paths,|Diag_path Bit 0,Diag_path Bit 1
IDE12807-ENG299127,Participant authenticity-Ecu_authentications,|Ecu_authentication Bit 0,Ecu_authentication Bit 1
IDE12844-ENG299092,Installation list of the 10 bit node addresses-Node_addresses,|Node address,ECM name
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13679-MAS01461,Power generator status-Electrical malfunction,electrically OK,
IDE13679-MAS01574,Power generator status-Mechanical malfunction,Mechanical OK,
IDE13679-MAS06304,Power generator status-Status overvoltage diagnosis,not active,
IDE13679-MAS06305,Power generator status-Status of diagnosis for energy balance,not active,
IDE13679-MAS21175,Power generator status-Generator temperature error,Thermal OK,
IDE13679-ENG255704,Power generator status-error_primary_circuit,not active,
IDE13754-IDE04447,Diagnosis filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,0, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,Not deactivated,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,00001626*2024-10-20-14:53:55*0*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,00001625*2024-10-20-14:01:46*0*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,00001624*2024-10-20-13:42:12*0*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,00001624*2024-10-20-13:22:56*0*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,00001623*2024-10-20-12:52:30*0*,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,VSSZZZKM2RR140480,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13845,Production mode status,not active,
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,650, W
IDE14151-MAS14375,Route-based range calculation-Cycle counter,0,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not active,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,30.0, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,22.5, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,20.0, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,17.0, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,16.5, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,17.0, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,17.5, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,18.0, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,20.0, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,22.0, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,30.0, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,22.5, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,20.0, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,17.0, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,16.5, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,17.0, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,17.5, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,18.0, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,20.0, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,22.0, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,650, W
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,65533,
IDE14151-MAS17928,Route-based range calculation-Maximum range,65533,
IDE14151-MAS17929,Route-based range calculation-Total coverage,65532,
IDE14151-MAS17930,Route-based range calculation-Range from destination,65532,
IDE14151-MAS17931,Route-based range calculation-Route-based range,65532,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14169-IDE08660,Autonomous recharging-Recharging the NV battery,no request,
IDE14169-MAS07409,Autonomous recharging-Status automatic recharging of low-voltage battery,Malfunction,
IDE14260-MAS12984,12V lead battery test pulse: low-voltage energy management-Reason for rejection,0,
IDE14260-MAS21182,12V lead battery test pulse: low-voltage energy management-Bad counter,0,
IDE14260-MAS21183,12V lead battery test pulse: low-voltage energy management-Test pulse counter not OK,121,
IDE14260-MAS21184,12V lead battery test pulse: low-voltage energy management-Counter increase not OK,134,
IDE14260-ENG255502,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_request,2,
IDE14260-ENG255503,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_result,3,
IDE14265,Battery display: source of initiation,0,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC time server,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 20 9A 17 E9 9B 3A A9,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2E,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15027-MAS21296,Low-voltage EM on middle-voltage EM signals-48V electrical system charging approval,No,
IDE15027-MAS21297,Low-voltage EM on middle-voltage EM signals-Low-voltage energy management status,not active,
IDE15027-MAS21328,Low-voltage EM on middle-voltage EM signals-Low-voltage EM request for lowering medium-voltage EM,No,
IDE15027-MAS21329,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,Yes,
IDE15027-MAS21330,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,No,
IDE15027-MAS21331,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approved charge capacity for medium-voltage EM,0, W
IDE15101,Status of lithium-ion battery,OK,
IDE16801-ENG352080,Medium-voltage energy management: error data in the safety zone-Mvem_active_Drive_session,not active,
IDE16801-ENG355113,Medium-voltage energy management: error data in the safety zone-Mvem_BMS_EnergyReserve_Limitation,not active,
IDE16801-ENG353935,Medium-voltage energy management: error data in the safety zone-Mvem_BMS_EnergyReserve_Status_Qualification,1,
IDE16801-ENG357199,Medium-voltage energy management: error data in the safety zone-Mvem_BMS_MV_EnergyReserve,3,
IDE16801-ENG355681,Medium-voltage energy management: error data in the safety zone-Mvem_BMS_MV_FehlerNotfallreserve_CommunicationError,active,
IDE16801-ENG354958,Medium-voltage energy management: error data in the safety zone-Mvem_BMS_MV_FehlerNotfallreserve_Init_Failure,active,
IDE16936-IDE01834,Low-voltage energy management: key figures of the lead battery-Battery voltage,12.170, V
IDE16936-IDE01836,Low-voltage energy management: key figures of the lead battery-Battery current,-16, A
IDE16936-IDE12072,Low-voltage energy management: key figures of the lead battery-Warning displays,no warning,
IDE16936-IDE17292,Low-voltage energy management: key figures of the lead battery-Charge indicator,50.290,
IDE16936-MAS04059,Low-voltage energy management: key figures of the lead battery-Battery temperature,29, °C
IDE16936-MAS05030,Low-voltage energy management: key figures of the lead battery-Resistance,4.2, mOhm
IDE16936-MAS23197,Low-voltage energy management: key figures of the lead battery-Reason for warning display,0,
IDE16936-MAS23866,Low-voltage energy management: key figures of the lead battery-Limit resistance,9.0, mOhm
IDE16936-MAS23867,Low-voltage energy management: key figures of the lead battery-Escalation counter for battery alerts,0,
MAS00464-MAS00106,Standard - ambient data 1-Year,2035,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,9,
MAS00464-MAS00109,Standard - ambient data 1-Hours,9,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,31,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,11,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,57,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,1626, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,10,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,Seat,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,0,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS02672-IDE03212,Start-stop-Start/stop conditions,Stop release,
MAS02672-IDE03213,Start-stop-Start/stop enable,All releases are present,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE07621,Start-stop-Permitted engine stop time,max.value,
MAS02672-IDE07622,Start-stop-Power consumption during idle phase,25, A
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS03023,Engine running status-Driving mode,not active,
MAS04447-MAS05129,Engine running status-Motor,Engine off,
MAS04447-MAS20972,Engine running status-Redundant supply target mode,not active,
MAS12666-ENG299104,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|00 1D
MAS12668-ENG299105,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1
MAS12669-ENG299103,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|81|81|81|0|0|0|0|0|82|82|0|0|0|0|0|0|83|83|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
MAS16744-IDE01836,12V battery-Battery current,-16.261, A
MAS16744-IDE01837,12V battery-Temperature of battery sensor,29, °C
MAS16744-IDE01838,12V battery-Battery temperature,23, °C
MAS16744-IDE01839,12V battery-Battery charge level,68, %
MAS16744-IDE01841,12V battery-Battery internal resistance,4.4, mOhm
MAS16744-IDE01842,12V battery-Usable battery charge,45, Ah
MAS16744-IDE01948,12V battery-Battery internal resistance not normed,4.2, mOhm
MAS16744-IDE04186,12V battery-Battery terminal recognition,connected,
MAS16744-IDE08347,12V battery-adapted battery capacity,101, Ah
MAS16744-MAS00362,12V battery-Battery voltage,12.170, V
MAS16744-MAS06086,12V battery-Total re-charge,192.0, Ah
MAS16744-MAS06087,12V battery-Entire energy throughput,181.7, Ah
MAS16744-MAS22232,12V battery-Battery aging: charge-related,84, %
MAS16744-MAS22233,12V battery-Battery aging: performance-related,90, %
MAS16744,12V battery,---,
MAS16745-IDE01839,Quiescent current management-Battery charge level,140,
MAS16745-IDE01843,Quiescent current management-Battery voltage at rest,12.4, V
MAS16745-IDE01846,Quiescent current management-Static current shut-off stage,Deactivation stage 0,
MAS16745-IDE01852,Quiescent current management-Static current measurement: result,4094, mA
MAS16745-IDE01853,Quiescent current management-Static current measurement: status,Initialization,
MAS16745-IDE07623,Quiescent current management-Open-circuit voltage gateway,invalid,
MAS16745-IDE07907,Quiescent current management-Bus communication,active,
MAS16745-IDE09561,Quiescent current management-Static current last LIN sleep phase,-0.128, A
MAS16745,Quiescent current management,Initialization,
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,available.,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,valid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 00 03 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,available.,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,28,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,03,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,available.,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,BD 14 EA F7 E8 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,66 55 BF 05,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 75,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Valid transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,5,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,1,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,14,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 09,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,186,
ENG186123-ENG255560,Authentic_time_last_client_response-Current_time_ used,1970-01-01T00:00:00Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,1970-01-01T00:00:00Z,
ENG254617-ENG299125,DoIP_Status-DoIP_Status_ECU,|Node_address,number_tcp_connections_ecu
ENG254617-ENG280661,DoIP_Status-number_of_total_ecu,0,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,Emergency running mode,
ENG137077-ENG137157,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG137077-ENG137156,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG137077-ENG255696,EHR_pool_load-ehr_speedlimit_pool_load,0.0, %
ENG254621-ENG255502,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_request,2,
ENG254621-ENG255503,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_result,3,
ENG254621-ENG255504,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_status,3,
ENG254621-ENG255545,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Consumer_test_pulse_request,0,
ENG254621-ENG255551,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_increase_not_ok,134,
ENG254621-ENG255553,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_test_pulse_not_ok,121,
ENG254621-ENG255557,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_battery_BEM,-16.284, A
ENG254621-ENG255558,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_DcDc_test_pulse_actual,0, A
ENG254621-ENG255559,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_test_pulse_target_value,0, A
ENG254621-ENG256044,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Max_current_last_start,736, A
ENG254621-ENG256064,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Min_voltage_last_start,9.30,
ENG254621-ENG256101,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV_EM_test_pulse_status,3,
ENG254621-ENG256097,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_enabled,3,
ENG254621-ENG256098,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_request,3,
ENG254621-ENG256099,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_enabled,0,
ENG254621-ENG256100,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_request,3,
ENG254621-ENG256270,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Reduction_internal_fan_by_request_test_pulse,0,
ENG254621-ENG256620,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Voltage_battery_BEM,12.169, V
ENG254622-MAS21178,Energy_management_dashboard_display-Battery reports,0,
ENG254622-MAS21179,Energy_management_dashboard_display-Energy generator reports,1,
ENG254622-MAS21180,Energy_management_dashboard_display-Battery service,0,
ENG254622-MAS21181,Energy_management_dashboard_display-Vehicle system diagnostic,0,
ENG118782-ENG299130,Gateway app. software identification-Gateway_applikation_software_identifikation,|nf_name,SW_VERSION|routing_gateway
ENG254725-ENG255697,HV-EM_consumer_contingent-Enabling_climate_aggregates,No enabling,
ENG254725-ENG256045,HV-EM_consumer_contingent-max_power_climate_aggregates,0, A
ENG254725-ENG152043,HV-EM_consumer_contingent-RWV_reduction_level,no request,
ENG254725-ENG255205,HV-EM_consumer_contingent-shutdown_request_low_voltage_systems,none,
ENG254727-ENG152029,HV-EM_energy_specification-High_voltage_battery_energy_information,102350,
ENG254727-ENG152032,HV-EM_energy_specification-HV-EM_high_voltage_battery_energy_information,102300, Wh
ENG254727-ENG152039,HV-EM_energy_specification-NV_energy_requirement,2550, W
ENG254728-ENG152030,HV-EM_high_voltage_activation-HV_system_error,No malfunction,
ENG254728-ENG152033,HV-EM_high_voltage_activation-HV-EM_HV_requirement,no request,
ENG254728-ENG152036,HV-EM_high_voltage_activation-HV-EM_recharging_requirement,no request,
ENG254728-ENG152037,HV-EM_high_voltage_activation-HV-LM_HV_requirement,not_requested,
ENG254729-ENG255533,HV-EM_operation_data-climate_power,12700, W
ENG254729-ENG255581,HV-EM_operation_data-dcdc_power,0, W
ENG254729-ENG125881,HV-EM_operation_data-HV-EM_operation_mode,OFF,
ENG254730-ENG152028,HV-EM_operation_limitation-High_voltage_battery_current_limitation,0, A
ENG254730-ENG255206,HV-EM_operation_limitation-High_voltge_battery_state_of_charge,127.0, %
ENG254730-ENG263259,HV-EM_operation_limitation-HV-EM_approval_dcdc_converter,No enabling,
ENG254730-ENG152034,HV-EM_operation_limitation-HV-EM_NV_power_limitation,0, W
ENG254730-ENG152035,HV-EM_operation_limitation-HV-EM_power_limitation,0, W
ENG254777,Middle_voltage_energy_management_to_low_voltage_energy_management_function_support,Unknown (0)
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60054,
ENG151185-ENG140446,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG151185-ENG140442,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG151185-ENG140441,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG151185-ENG140440,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG151186-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK.,
ENG151186,MV-EM_48V_electrical_system_diagnosis_typ_1,---,
ENG151186-ENG140420,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG151186-ENG140421,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG151187-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG151187,MV-EM_48V_electrical_system_diagnosis_typ_2,Initialization,
ENG151187,MV-EM_48V_electrical_system_diagnosis_typ_2,---,
ENG151187-ENG140423,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG151187-ENG140416,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG151187-ENG140424,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,63.50, V
ENG151187-ENG256301,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltage,1023.50, mV
ENG151188-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG151188,MV-EM_48V_overvoltage_check,---,
ENG151188-ENG140416,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG151188-ENG140417,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0, %
ENG151189-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG151190-ENG140438,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG151190-ENG140439,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG151191,MV-EM_dc_current_Mv,0.0, A
ENG151192,MV-EM_dc_power_desired,0, W
ENG151193,MV-EM_DC_voltage_desired,0.00, V
ENG151194,MV-EM_dc_voltage_Mv,0.00, V
ENG151195-ENG140270,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG151195-ENG140271,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG151195-ENG140272,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG151195-ENG140409,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG151196,MV-EM_EMG_level_of_capacity,0.025, %
ENG151197,MV-EM_Mv_current,0, A
ENG151198-ENG140414,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,active,
ENG151198-ENG140415,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG151199-ENG140410,MV-EM_release-12V_coldstart_release,No enabling,
ENG151199-ENG140411,MV-EM_release-12V_warmstart_release,No enabling,
ENG151199-ENG140412,MV-EM_release-48V_coldstart_release,No enabling,
ENG151199-ENG140413,MV-EM_release-start_stopp_support_release,No enabling,
ENG151200,MV-EM_RSG_maximal_current,0, A
ENG151201,MV-EM_RSG_maximal_voltage,0.00, V
ENG254783-ENG246261,NVEM_12V_Rekuperation-48V_emergency_run,0,
ENG254783-ENG274259,NVEM_12V_Rekuperation-Batterie_Ladezustand,0,
ENG254783-ENG274260,NVEM_12V_Rekuperation-Batterie_Regeneration,1,
ENG254783-ENG274261,NVEM_12V_Rekuperation-Batterie_Spannung,1,
ENG254783-ENG274262,NVEM_12V_Rekuperation-Batterie_Temperatur,1,
ENG254783-ENG255379,NVEM_12V_Rekuperation-Batteriealterung_Ladung,1,
ENG254783-ENG255380,NVEM_12V_Rekuperation-Batteriealterung_Leistung,1,
ENG254783-ENG255700,NVEM_12V_Rekuperation-Energienetz,1,
ENG254783-ENG255703,NVEM_12V_Rekuperation-Entnehmbare_Ladung,1,
ENG254783-ENG255737,NVEM_12V_Rekuperation-Freigabe_KFG,1,
ENG254783-ENG255738,NVEM_12V_Rekuperation-Freigabe_Klima,1,
ENG254783-ENG99756,NVEM_12V_Rekuperation-Generatordiagnose,1,
ENG254783-ENG100106,NVEM_12V_Rekuperation-Leerlaufanhebung,1,
ENG254783-ENG252593,NVEM_12V_Rekuperation-limited_by_48V_consumer,0,
ENG254783-ENG104009,NVEM_12V_Rekuperation-LIN-Kommunikation,1,
ENG254783-ENG256076,NVEM_12V_Rekuperation-Modus_Rekuperation_Motor,Neutral,
ENG254783-ENG256106,NVEM_12V_Rekuperation-opening_recuperation_by_BCM,Yes,
ENG254783-ENG255165,NVEM_12V_Rekuperation-Parallel Parking Assistance,0,
ENG254783-ENG256273,NVEM_12V_Rekuperation-Rekuperation_light,0,
ENG254783-ENG256306,NVEM_12V_Rekuperation-Saeureschichtung,1,
ENG254783-ENG101873,NVEM_12V_Rekuperation-Sonderveto,1,
ENG254783-ENG256364,NVEM_12V_Rekuperation-Spannungsanforderung_BCM,0,
ENG254783-ENG256365,NVEM_12V_Rekuperation-Spannungsanforderung_Bremse,0,
ENG254783-ENG256366,NVEM_12V_Rekuperation-Spannungsanforderung_KFG,0,
ENG254783-ENG256367,NVEM_12V_Rekuperation-Spannungsanforderung_Klima,0,
ENG254783-ENG256368,NVEM_12V_Rekuperation-Spannungsanforderung_Lenkung,0,
ENG254783-ENG256369,NVEM_12V_Rekuperation-Spannungsanforderung_Motor,0,
ENG254783-ENG256399,NVEM_12V_Rekuperation-Status_Rekuperation,not active,
ENG254783-ENG256400,NVEM_12V_Rekuperation-Status_Stromregelung,not active,
ENG254784-ENG255286,NVEM_Analoge_Batterieueberwachung-Aktuelle_Differenzspannung,0.000, V
ENG254784-ENG255298,NVEM_Analoge_Batterieueberwachung-Analoge_Batteriespannung,0.000, V
ENG254784-ENG255179,NVEM_Analoge_Batterieueberwachung-Difference limit voltage,0.00, V
ENG254784-ENG255754,NVEM_Analoge_Batterieueberwachung-Gefilterte_Batteriespannung,13.500, V
ENG254784-ENG256398,NVEM_Analoge_Batterieueberwachung-Status_internes_BatterieAb,connected,
ENG254784-ENG256720,NVEM_Analoge_Batterieueberwachung-Zaehler_BatterieAb,0,
ENG250370,NVEM_Grund_BEM_falsch_codiert,0,
ENG254786-ENG255308,NVEM_HLR_Kurzstreckenprofil-Anteil_Entladung_aktuelle Fahrt,0, %
ENG254786-ENG255209,NVEM_HLR_Kurzstreckenprofil-Number_of_short_tracks,0,
ENG254787-ENG255299,NVEM_HLR_Master-Anforderung_Leerlaufanhebung,no request,
ENG254787-ENG255300,NVEM_HLR_Master-Anforderung_Reduzierung_Innengeblaese,no request,
ENG254787-ENG255779,NVEM_HLR_Master-Heizleistungskontingent,1000, W
ENG254787-ENG255780,NVEM_HLR_Master-Heizleistungskontingent_Stufe,not active,
ENG254788-ENG255369,NVEM_Zustand_HLR-BA2_ZuendungEin,1,
ENG254788-ENG255370,NVEM_Zustand_HLR-BA3_ZuendungAus,0,
ENG254788-ENG256423,NVEM_Zustand_HLR-TabA_StartStopp,0,
ENG254788-ENG256424,NVEM_Zustand_HLR-TabB_Fahrtbetrieb,0,
ENG254788-ENG256425,NVEM_Zustand_HLR-TabD_Kurzzeitverbraucher,0,
ENG254788-ENG256426,NVEM_Zustand_HLR-TabE_Crash,0,
ENG254788-ENG256427,NVEM_Zustand_HLR-TabK_Kontingent_geregelt,0,
ENG254788-ENG256428,NVEM_Zustand_HLR-TabM_Leistungsgefuehrt_praediktiv,0,
ENG254788-ENG256429,NVEM_Zustand_HLR-TabNQ,0,
ENG280376,Reason_nvem_vehicle_electrical_system_state_diagnosis,0,
ENG280381-ENG280515,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_emergency_strategy,0,
ENG280381-ENG280516,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_failure_warning,not active,
ENG280381-ENG280517,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operating_quadrant,Normal operating mode,
ENG280381-ENG280518,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operational_restriction,not active,
ENG280381-ENG280519,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_service_information,OK,
Elapsed Time: 01:14
blockmap-23-5WA-909-059-AB_VSSZZZKM2RR140480-20241020-1509.CSV
;SW:5WA-909-059-AB   HW:3Q0-909-059-C ---  Brake Booster
;Component:EBKV          H09 0372, Coding:1002C500740000CE39E79C73000049922449922400
;EV_BrakeBoostG2BoschVW37W,016028,EV_BrakeBoostG2BoschVW37W_016_VW38.rod
;Sunday,20,October,2024,15:09:22:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 107E69804AEF5FBACFB-8044
Group,Description,Actual
IDE05816-IDE00075,Input signals from data bus-Vehicle speed,28.000, km/h
IDE05816-IDE00773,Input signals from data bus-Terminal 15 status via CAN,Terminal 15 on,
IDE05816-IDE02211,Input signals from data bus-Brake pressure,0.90000, bar
IDE05816-IDE09696,Input signals from data bus-Charisma driving program: CAN output value,No program,
IDE05816-MAS01078,Input signals from data bus-Vehicle model,Combustion engine,
IDE05816-MAS02357,Input signals from data bus-Vehicle identification,00 34 30 34 38 30,
IDE05816-MAS08111,Input signals from data bus-OBD std.,EOBD,
IDE05816-MAS19863,Input signals from data bus-Status of parking brake: electromechanical,Bremse_geschl_(Spannkraft_voll/reduziert),
IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
IDE08586-IDE02955,Status: electromechanical power brake-System status,ready,
IDE08587-MAS08097,Power brake displays-Status: OBD lamp,OFF,
IDE08588-IDE00020,Sensor signals for electromechanical power brake-Terminal 15 status,Terminal 15 on,
IDE08588-IDE00102,Sensor signals for electromechanical power brake-Control Module temperature,32.0, °C
IDE08588-IDE02222,Sensor signals for electromechanical power brake-Driver brakes: qualification,OFF,
IDE08588-IDE02713,Sensor signals for electromechanical power brake-Brake lamp switch,OFF,
IDE08588-IDE02714,Sensor signals for electromechanical power brake-Brake test switch,On,
IDE08588-IDE11037,Sensor signals for electromechanical power brake-Brake light switch: qualification,On,
IDE08588-MAS00043,Sensor signals for electromechanical power brake-Terminal 30 power supply,14.4, V
IDE08588-MAS05192,Sensor signals for electromechanical power brake-Driver braking,OFF,
IDE08588-MAS06928,Sensor signals for electromechanical power brake-Supply voltage pedal travel sensor,4.9, V
IDE08588-MAS10345,Sensor signals for electromechanical power brake-Position of booster,0.0546875000, mm
IDE08588-MAS10346,Sensor signals for electromechanical power brake-Engine torque,0.00000, Nm
IDE08588-MAS11639,Sensor signals for electromechanical power brake-Input rod travel,0.000000, mm
IDE08588-MAS18095,Sensor signals for electromechanical power brake-Output rod,0.000000, mm
IDE08588-MAS18096,Sensor signals for electromechanical power brake-Brake pedal travel,Initialization,
IDE08588-MAS18097,Sensor signals for electromechanical power brake-Brake test switch: qualification,On,
IDE08588-MAS18098,Sensor signals for electromechanical power brake-Driver brakes clearly,OFF,
IDE08623-MAS02163,OBD configuration-coded,EOBD,
IDE08623-MAS08097,OBD configuration-Status: OBD lamp,OFF,
IDE08623-MAS14472,OBD configuration-calculated,EOBD,
IDE08623-MAS19862,OBD configuration-Status of generic scan tool,OFF,
IDE13138-MAS03034,Sluggishness test-Pressure,0.00000, bar
IDE13138-MAS10346,Sluggishness test-Engine torque,0.00000000000, Nm
IDE13138-MAS19863,Sluggishness test-Status of parking brake: electromechanical,Open,
IDE13138-MAS19866,Sluggishness test-Travel pressure rod,0.0000000, mm
IDE14229-MAS18099,Brake booster control status-Control mode,No activation,
IDE14229-MAS18101,Brake booster control status-Actuator Position,0.05467, mm
IDE14229-MAS18102,Brake booster control status-Actuator torque,0.00000, Nm
IDE14229-MAS18103,Brake booster control status-Actuator speed,0.00000, mm/s
IDE14229-MAS18104,Brake booster control status-Remaining hold time,0, s
IDE14696-MAS03458,Leakage test-Differential pressure,0.0000, bar
IDE14696-MAS19863,Leakage test-Status of parking brake: electromechanical,Open,
IDE14696-MAS19864,Leakage test-Brake pressure 1,0, bar
IDE14696-MAS19865,Leakage test-Brake pressure 2,0, bar
IDE80221-ENG252453,Analysis 221-Driver On Pedal,false,
IDE80221-ENG252454,Analysis 221-iBooster Ready for Actuation,OFF,
IDE80221-ENG252457,Analysis 221-iBooster System Mode,ready,
IDE80221-ENG252455,Analysis 221-Pedal Apply Recognition HW Output,false,
IDE80221-ENG252458,Analysis 221-Thermal Limitation,not_active,
IDE80221-ENG252452,Analysis 221-Wakeup Information HW,On,
IDE80221-ENG252456,Analysis 221-Wakeup Information NET,On,
IDE80222,Analysis 222,00 05 98,
IDE80223,Analysis 223,102.8750000, mm/s
IDE80223,Analysis 223,40.7421875, mm
IDE80223,Analysis 223,1.7578125, mm/s
IDE80223,Analysis 223,0.0000000, mm
IDE80223,Analysis 223,0.00000000000, Nm
IDE80223,Analysis 223,1.78027343750, Nm
IDE80225,Analysis 225,0,
IDE80225,Analysis 225,not active,
IDE80226-ENG249302,Analysis 226-Umgesetztes Charisma-Fahrprogramm_Wert,0,
MAS10409-MAS00106,Time stamp-Year,2024,
MAS10409-MAS00107,Time stamp-Month,10,
MAS10409-MAS00108,Time stamp-Day,20,
MAS10409-MAS00109,Time stamp-Hours,15,
MAS10409-MAS00110,Time stamp-Minutes,8,
MAS10409-MAS00111,Time stamp-Seconds,12,
Elapsed Time: 00:02
blockmap-2B-2Q0-905-861-B_VSSZZZKM2RR140480-20241020-1509.CSV
;SW:2Q0-905-861-B   HW:2Q0-905-861-B ---  Steer. Col. Lock
;Component:ELV-MQBB      H10 0040, Coding:8800000000000000
;EV_ELVMarqMQBA0,002004,EV_ELVMarqMQBA0_VW38.rod
;Sunday,20,October,2024,15:09:35:49859
;VCID: 323AC308E4A34DAA99F-8066
IDE00019,Voltage terminal 30,14.4,
IDE00021,Engine RPM,927.50, /min
IDE00021-MAS00058,Engine RPM-Implausible,No,
IDE00021-MAS00103,Engine RPM-invalid,No,
IDE00021-MAS02239,Engine RPM-outdated,No,
IDE00021-MAS02246,Engine RPM-Timeout,No,
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-outdated,No,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,OK,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,0,
IDE01766-MAS03715,Distance impulses-Right front wheel,0,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,Not operated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,locked,
IDE02580,Number of unlocks,175,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,Open,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine RPM,Condition not met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-MAS02349,Locking requirements-Learn mode,Adapted,
IDE06746-MAS08251,Locking requirements-Vehicle speed signals: communication status,Condition met,
IDE06746-MAS08252,Locking requirements-Terminal status signal: communication status,Condition not met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Vehicle speed signals: cyclical reception,Condition met,
IDE06746-MAS08792,Locking requirements-Signals for distance pulses: cyclical reception,Condition met,
IDE06746-MAS08794,Locking requirements-Terminal status signal: cyclical reception,Condition met,
IDE06746-MAS11697,Locking requirements-Signals for distance pulses: communication status,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
MAS00464-MAS00106,Standard - ambient data 1-Year,2024,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,20,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,8,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,25,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG162685,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG162686,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128820,Free_Releases_Numbers,256,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Not confirmed,
ENG128822-ENG255750,functional_check-Functional_Check_VW_EOL,Confirmed,
Elapsed Time: 00:04
blockmap-36-5WA-959-760-H_VSSZZZKM2RR140480-20241020-1509.CSV
;SW:5WA-959-760-H   HW:5WA-959-760-H ---  Seat Mem. Drvr
;Component:MEM-FS        009 0362, Coding:01789A000000A0408803010101010000000000212100000000000000215000
;EV_SCMDriveSideCONTIAU736,006013,EV_SCMDriveSideCONTIAU736_VW38.rod
;Sunday,20,October,2024,15:09:44:49859
;VCID: 59E854A4D9955EF2785-800C
IDE00019-MAS00043,Voltage terminal 30-Terminal 30 power supply,14.40, V
IDE00102,Control Module temperature,41,
IDE00323,Security Access: Number of invalid keys,1,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,0, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,0, s
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems not supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Adjustment for backrest angle-Block 1,34040,
IDE06510-MAS01391,Adjustment for backrest angle-Block 2,32457,
IDE06510-MAS02282,Adjustment for backrest angle-Position,32844,
IDE06510-MAS02955,Adjustment for backrest angle-Engine temperature,25, °C
IDE06510-MAS03129,Adjustment for backrest angle-Reset counter,43,
IDE06510-MAS04160,Adjustment for backrest angle-Load change,44,
IDE06510-MAS04337,Adjustment for backrest angle-Engine current,0, A
IDE06510-MAS05370,Adjustment for backrest angle-Direction of movement,Not operated,
IDE06510-MAS05563,Adjustment for backrest angle-Norming,standardized,
IDE06510-MAS05719,Adjustment for backrest angle-Maximum travel,1583,
IDE06510-MAS12838,Adjustment for backrest angle-Standardization flag,standardized,
IDE06511-MAS01390,Seat height adjustment-Block 1,33127,
IDE06511-MAS01391,Seat height adjustment-Block 2,32548,
IDE06511-MAS02282,Seat height adjustment-Position,33116,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,6,
IDE06511-MAS04160,Seat height adjustment-Load change,45,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,Not operated,
IDE06511-MAS05563,Seat height adjustment-Norming,standardized,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,579,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,standardized,
IDE06512-MAS01390,Adjustment for seat forward/back position-Block 1,32775,
IDE06512-MAS01391,Adjustment for seat forward/back position-Block 2,32118,
IDE06512-MAS02282,Adjustment for seat forward/back position-Position,32428,
IDE06512-MAS02955,Adjustment for seat forward/back position-Engine temperature,25, °C
IDE06512-MAS03129,Adjustment for seat forward/back position-Reset counter,58,
IDE06512-MAS04160,Adjustment for seat forward/back position-Load change,67,
IDE06512-MAS04337,Adjustment for seat forward/back position-Engine current,0, A
IDE06512-MAS05370,Adjustment for seat forward/back position-Direction of movement,Not operated,
IDE06512-MAS05563,Adjustment for seat forward/back position-Norming,standardized,
IDE06512-MAS05719,Adjustment for seat forward/back position-Maximum travel,657,
IDE06512-MAS12838,Adjustment for seat forward/back position-Standardization flag,standardized,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,33003,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32728,
IDE06683-MAS02282,Seat inclination adjustment-Position,32892,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,37,
IDE06683-MAS04160,Seat inclination adjustment-Load change,39,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,Not operated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,standardized,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,275,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,standardized,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,31886,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,32953,
IDE06684-MAS02282,Lumbar support height adjustment-Position,31926,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,25, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,2,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,7,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,Not operated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,standardized,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,1067,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,standardized,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,32751,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,33227,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,32760,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,25, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,2,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,4,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,Not operated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,standardized,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,476,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,standardized,
IDE06871-IDE06510,Seat adjustment control head-Adjustment for backrest angle,Not operated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,Not operated,
IDE06871-IDE06512,Seat adjustment control head-Adjustment for seat forward/back position,Not operated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,Not operated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,Not operated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,Not operated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,Not operated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,Not operated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,Not operated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,Not operated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,Not operated,
IDE07159,Control module switch-off: counter,512,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Adjustment for backrest angle,0,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,0,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,0,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Adjustment for backrest angle,0,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,0,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,0,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Adjustment for backrest angle,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Adjustment for backrest angle,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Adjustment for backrest angle,32844,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,33116,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Adjustment for seat forward/back position,32428,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,32892,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,31926,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,32760,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,0,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,0,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08989-MAS01390,Seat depth adjustment-Block 1,0,
IDE08989-MAS01391,Seat depth adjustment-Block 2,0,
IDE08989-MAS02282,Seat depth adjustment-Position,0,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,0, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,0,
IDE08989-MAS04160,Seat depth adjustment-Load change,0,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,Not operated,
IDE08989-MAS05563,Seat depth adjustment-Norming,not normed,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,0,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,never normed,
IDE08990-MAS01390,Backrest top adjustment-Block 1,0,
IDE08990-MAS01391,Backrest top adjustment-Block 2,0,
IDE08990-MAS02282,Backrest top adjustment-Position,0,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,0, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,0,
IDE08990-MAS04160,Backrest top adjustment-Load change,0,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,Not operated,
IDE08990-MAS05563,Backrest top adjustment-Norming,not normed,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,0,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,never normed,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,Not operated,
IDE08991-MAS05563,Belt height adjustment-Norming,not normed,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,Not operated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,Not operated,
IDE09081-MAS08293,Seat switch module-Paddle,Not operated,
IDE09082,Massage button,Not operated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,Not operated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,Not operated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,Not operated,
IDE09085,Backrest limit switch,Not operated,
IDE10995-IDE06510,Calibrating the motors: status-Adjustment for backrest angle,standardized,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,standardized,
IDE10995-IDE06512,Calibrating the motors: status-Adjustment for seat forward/back position,standardized,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,standardized,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,standardized,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,standardized,
IDE10995-IDE08988,Calibrating the motors: status-Head restraint adjustment,not normed,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,not normed,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,not normed,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not normed,
IDE10995-IDE11957,Calibrating the motors: status-Display unit adjustment,not normed,
IDE10995-IDE11969,Calibrating the motors: status-Adjustment of foot rest,not normed,
IDE10995-IDE11986,Calibrating the motors: status-Adjustment 2 of visual display unit,not normed,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,standardized,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,not normed,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,0,
IDE11024-MAS01391,Headrest height adjustment-Block 2,0,
IDE11024-MAS02282,Headrest height adjustment-Position,0,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,0, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,0,
IDE11024-MAS04160,Headrest height adjustment-Load change,0,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,Not operated,
IDE11024-MAS05563,Headrest height adjustment-Norming,not normed,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,0,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,never normed,
IDE11025-MAS01390,Headrest length adjustment-Block 1,31886,
IDE11025-MAS01391,Headrest length adjustment-Block 2,32953,
IDE11025-MAS02282,Headrest length adjustment-Position,31926,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,25, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,2,
IDE11025-MAS04160,Headrest length adjustment-Load change,7,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,Not operated,
IDE11025-MAS05563,Headrest length adjustment-Norming,standardized,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,1067,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,standardized,
IDE11957-MAS01390,Display unit adjustment-Block 1,31886,
IDE11957-MAS01391,Display unit adjustment-Block 2,32953,
IDE11957-MAS02282,Display unit adjustment-Position,31926,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,25, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,2,
IDE11957-MAS04160,Display unit adjustment-Load change,7,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,Not operated,
IDE11957-MAS05563,Display unit adjustment-Norming,standardized,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,1067,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,standardized,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,32751,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,33227,
IDE11969-MAS02282,Adjustment of foot rest-Position,32760,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,25, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,2,
IDE11969-MAS04160,Adjustment of foot rest-Load change,4,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,Not operated,
IDE11969-MAS05563,Adjustment of foot rest-Norming,standardized,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,476,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,standardized,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,32751,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,33227,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,32760,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,25, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,2,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,4,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,Not operated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Norming,standardized,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,476,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,standardized,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,Not operated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,Not operated,
MAS12838-IDE06510,Standardization flag-Adjustment for backrest angle,standardized,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,standardized,
MAS12838-IDE06512,Standardization flag-Adjustment for seat forward/back position,standardized,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,standardized,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,standardized,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,standardized,
MAS12838-IDE08988,Standardization flag-Head restraint adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,never normed,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,never normed,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-IDE11957,Standardization flag-Display unit adjustment,never normed,
MAS12838-IDE11969,Standardization flag-Adjustment of foot rest,never normed,
MAS12838-IDE11986,Standardization flag-Adjustment 2 of visual display unit,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,standardized,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,never normed,
ENG139951-IDE06510,Account_1-Adjustment for backrest angle,32844,
ENG139951-IDE06511,Account_1-Seat height adjustment,33116,
ENG139951-IDE06512,Account_1-Adjustment for seat forward/back position,32428,
ENG139951-IDE06683,Account_1-Seat inclination adjustment,32892,
ENG139951-IDE06684,Account_1-Lumbar support height adjustment,31926,
ENG139951-IDE06685,Account_1-Lumbar support longitudinal position adjustment,32760,
ENG139951-IDE08989,Account_1-Seat depth adjustment,0,
ENG139951-IDE08990,Account_1-Backrest top adjustment,0,
ENG139951-IDE08991,Account_1-Belt height adjustment,0,
ENG139951-IDE11024,Account_1-Headrest height adjustment,0,
ENG139952-IDE06510,Account_2-Adjustment for backrest angle,0,
ENG139952-IDE06511,Account_2-Seat height adjustment,0,
ENG139952-IDE06512,Account_2-Adjustment for seat forward/back position,0,
ENG139952-IDE06683,Account_2-Seat inclination adjustment,0,
ENG139952-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG139952-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG139952-IDE08989,Account_2-Seat depth adjustment,0,
ENG139952-IDE08990,Account_2-Backrest top adjustment,0,
ENG139952-IDE08991,Account_2-Belt height adjustment,0,
ENG139952-IDE11024,Account_2-Headrest height adjustment,0,
ENG139953-IDE06510,Account_3-Adjustment for backrest angle,0,
ENG139953-IDE06511,Account_3-Seat height adjustment,0,
ENG139953-IDE06512,Account_3-Adjustment for seat forward/back position,0,
ENG139953-IDE06683,Account_3-Seat inclination adjustment,0,
ENG139953-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG139953-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG139953-IDE08989,Account_3-Seat depth adjustment,0,
ENG139953-IDE08990,Account_3-Backrest top adjustment,0,
ENG139953-IDE08991,Account_3-Belt height adjustment,0,
ENG139953-IDE11024,Account_3-Headrest height adjustment,0,
ENG139954-IDE06510,Account_4-Adjustment for backrest angle,0,
ENG139954-IDE06511,Account_4-Seat height adjustment,0,
ENG139954-IDE06512,Account_4-Adjustment for seat forward/back position,0,
ENG139954-IDE06683,Account_4-Seat inclination adjustment,0,
ENG139954-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG139954-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG139954-IDE08989,Account_4-Seat depth adjustment,0,
ENG139954-IDE08990,Account_4-Backrest top adjustment,0,
ENG139954-IDE08991,Account_4-Belt height adjustment,0,
ENG139954-IDE11024,Account_4-Headrest height adjustment,0,
ENG139955-IDE06510,Account_5-Adjustment for backrest angle,0,
ENG139955-IDE06511,Account_5-Seat height adjustment,0,
ENG139955-IDE06512,Account_5-Adjustment for seat forward/back position,0,
ENG139955-IDE06683,Account_5-Seat inclination adjustment,0,
ENG139955-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG139955-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG139955-IDE08989,Account_5-Seat depth adjustment,0,
ENG139955-IDE08990,Account_5-Backrest top adjustment,0,
ENG139955-IDE08991,Account_5-Belt height adjustment,0,
ENG139955-IDE11024,Account_5-Headrest height adjustment,0,
ENG139956-IDE06510,Account_6-Adjustment for backrest angle,0,
ENG139956-IDE06511,Account_6-Seat height adjustment,0,
ENG139956-IDE06512,Account_6-Adjustment for seat forward/back position,0,
ENG139956-IDE06683,Account_6-Seat inclination adjustment,0,
ENG139956-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG139956-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG139956-IDE08989,Account_6-Seat depth adjustment,0,
ENG139956-IDE08990,Account_6-Backrest top adjustment,0,
ENG139956-IDE08991,Account_6-Belt height adjustment,0,
ENG139956-IDE11024,Account_6-Headrest height adjustment,0,
ENG139957-IDE06510,Account_7-Adjustment for backrest angle,0,
ENG139957-IDE06511,Account_7-Seat height adjustment,0,
ENG139957-IDE06512,Account_7-Adjustment for seat forward/back position,0,
ENG139957-IDE06683,Account_7-Seat inclination adjustment,0,
ENG139957-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG139957-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG139957-IDE08989,Account_7-Seat depth adjustment,0,
ENG139957-IDE08990,Account_7-Backrest top adjustment,0,
ENG139957-IDE08991,Account_7-Belt height adjustment,0,
ENG139957-IDE11024,Account_7-Headrest height adjustment,0,
ENG139950-IDE06510,BAP_Seat_Adjustment_Button_Status-Adjustment for backrest angle,Not operated,
ENG139950-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,Not operated,
ENG139950-IDE06512,BAP_Seat_Adjustment_Button_Status-Adjustment for seat forward/back position,Not operated,
ENG139950-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,Not operated,
ENG139950-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,Not operated,
ENG139950-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,Not operated,
ENG139950-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,Not operated,
ENG139950-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,Not operated,
ENG139950-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,Not operated,
ENG139950-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,Not operated,
ENG139950-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,Not operated,
ENG139950-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,Not operated,
ENG139950-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,Not operated,
ENG139950-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,Not operated,
ENG139950-ENG140668,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,Not operated,
ENG139950-ENG140669,BAP_Seat_Adjustment_Button_Status-footmat,Not operated,
ENG139950-ENG140667,BAP_Seat_Adjustment_Button_Status-side_bolster,Not operated,
ENG136330-ENG136340,Cause of de-normalization-Axis_1,Normierroutine,
ENG136330-ENG136349,Cause of de-normalization-Axis_10,Normierroutine,
ENG136330-ENG136341,Cause of de-normalization-Axis_2,Normierroutine,
ENG136330-ENG136342,Cause of de-normalization-Axis_3,Normierroutine,
ENG136330-ENG136343,Cause of de-normalization-Axis_4,Normierroutine,
ENG136330-ENG136344,Cause of de-normalization-Axis_5,Achse decodiert,
ENG136330-ENG136345,Cause of de-normalization-Axis_6,Achse decodiert,
ENG136330-ENG136346,Cause of de-normalization-Axis_7,Achse decodiert,
ENG136330-ENG136347,Cause of de-normalization-Axis_8,Achse decodiert,
ENG136330-ENG136348,Cause of de-normalization-Axis_9,Normierroutine,
ENG136325-ENG101098,crash_precrash-Crash,not active,
ENG136325-ENG131963,crash_precrash-Precrash,not active,
ENG247801-ENG248126,info_developer-ax_da,7E AC 7D 76 80 07 00 07 80 4C 7E C9 84 F8 00 07 81 5C 7F 24 81 67 00 07 80 7C 7F D8 80 EB 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 7F F8 7F EF 81 CB 00 07 7C B6 7C 8E 80 B9 00 07,
ENG247801-ENG248078,info_developer-gl_lo,35 57 41 39 35 39 37 36 30 48 20 00 00 00 00 00 30 33 36 32 00 00 00 00 32 35 33 35 00 00 00 00 53 43 58 58 4D 51 42 56 57 33 38 58 00 00 00 00 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG247947,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 03 03 03 03 00 00 04 04 00 00 00 00,
ENG247801-ENG248107,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG248040,info_developer-so_deb,06 02 00 00 00 00 00 00 81 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG136350-ENG136426,key_memory_activated-mmi_key_memory_activated,active,
ENG157282-ENG161450,Maximum travel-Axis_1_current,657,
ENG157282-ENG161451,Maximum travel-Axis_1_last,656,
ENG157282-ENG161452,Maximum travel-Axis_10_current,1067,
ENG157282-ENG161453,Maximum travel-Axis_10_last,0,
ENG157282-ENG161454,Maximum travel-Axis_2_current,1583,
ENG157282-ENG161455,Maximum travel-Axis_2_last,0,
ENG157282-ENG161456,Maximum travel-Axis_3_current,579,
ENG157282-ENG161457,Maximum travel-Axis_3_last,0,
ENG157282-ENG161458,Maximum travel-Axis_4_current,275,
ENG157282-ENG161459,Maximum travel-Axis_4_last,0,
ENG157282-ENG161460,Maximum travel-Axis_5_current,65535,
ENG157282-ENG161461,Maximum travel-Axis_5_last,0,
ENG157282-ENG161462,Maximum travel-Axis_6_current,65535,
ENG157282-ENG161463,Maximum travel-Axis_6_last,0,
ENG157282-ENG161464,Maximum travel-Axis_7_current,65535,
ENG157282-ENG161465,Maximum travel-Axis_7_last,0,
ENG157282-ENG161466,Maximum travel-Axis_8_current,65535,
ENG157282-ENG161467,Maximum travel-Axis_8_last,0,
ENG157282-ENG161468,Maximum travel-Axis_9_current,476,
ENG157282-ENG161469,Maximum travel-Axis_9_last,0,
ENG136323-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG136323-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG136323-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG136323-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG136323-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG136323-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG136323-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG136323-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG136324-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG136324-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,active,
ENG136324-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,active,
ENG136324-ENG140350,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG136324-ENG136335,Memory_ID_CAN_2-Hardware_onoff,active,
ENG136324-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG136324-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG136324-ENG248058,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG158048-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG158048-ENG247932,missing_pre_conditions-_reserviert,0,
ENG158048-ENG161471,missing_pre_conditions-backrest_locked,active,
ENG158048-ENG161472,missing_pre_conditions-backrest_unlocked,active,
ENG158048-ENG161506,missing_pre_conditions-button_pressed,not active,
ENG158048-ENG161716,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG158048-ENG163288,missing_pre_conditions-other_adjustment_already_active,not active,
ENG158048-ENG100589,missing_pre_conditions-Reserviert 2,0,
ENG158048-ENG163523,missing_pre_conditions-reset_problem,not active,
ENG158048-ENG163733,missing_pre_conditions-speed_above_5kmh,not active,
ENG158048-ENG159469,missing_pre_conditions-Voltage_supply,not active,
ENG158102-ENG161674,personalization_last_function-cause_of_termination,0,
ENG158102,personalization_last_function,none,
ENG158102-ENG99298,personalization_last_function-State,none,
ENG136328-ENG136337,pwm_generator-pwm_generator_group_1_overload,not active,
ENG136328-ENG136338,pwm_generator-pwm_generator_group_2_overload,not active,
ENG136326-ENG99389,Resets-Resetcounter,7,
ENG136329-ENG136339,sbc-sbc_overload,not active,
ENG136351-ENG136438,Seat_Actual_Positions-Current_Position_fsv,32760,
ENG136351-ENG136434,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG136351-ENG136441,Seat_Actual_Positions-Current_Position_kks,32768,
ENG136351-ENG136437,Seat_Actual_Positions-Current_Position_ksv_x,31926,
ENG136351-ENG136431,Seat_Actual_Positions-Current_Position_ksv_z,32768,
ENG136351-ENG136436,Seat_Actual_Positions-Current_Position_ldh,31926,
ENG136351-ENG136435,Seat_Actual_Positions-Current_Position_ldw,32760,
ENG136351-ENG136433,Seat_Actual_Positions-Current_Position_lkv,32768,
ENG136351-ENG136428,Seat_Actual_Positions-Current_Position_lnv,32844,
ENG136351-ENG136439,Seat_Actual_Positions-Current_Position_rse1,31926,
ENG136351-ENG136440,Seat_Actual_Positions-Current_Position_rse2,32760,
ENG136351-ENG136429,Seat_Actual_Positions-Current_Position_shv,33116,
ENG136351-ENG136427,Seat_Actual_Positions-Current_Position_slv,32428,
ENG136351-ENG136430,Seat_Actual_Positions-Current_Position_snv,32892,
ENG136351-ENG136432,Seat_Actual_Positions-Current_Position_stv,32768,
ENG123054-ENG136421,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG136422,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG136423,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG136424,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG136425,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,Key 2,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,Key 2,
ENG123053-ENG136417,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG136412,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG136418,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG136415,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG136420,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG136419,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG136416,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG136413,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG136414,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG136411,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG158188-IDE06510,Seat_Position_Memory_Remote_Control_5-Adjustment for backrest angle,0,
ENG158188-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG158188-IDE06512,Seat_Position_Memory_Remote_Control_5-Adjustment for seat forward/back position,0,
ENG158188-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG158188-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG158188-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG158188-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG158188-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG158188-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG158188-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG158189-IDE06510,Seat_Position_Memory_Remote_Control_6-Adjustment for backrest angle,0,
ENG158189-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG158189-IDE06512,Seat_Position_Memory_Remote_Control_6-Adjustment for seat forward/back position,0,
ENG158189-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG158189-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG158189-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG158189-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG158189-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG158189-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG158189-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG158190-IDE06510,Seat_Position_Memory_Remote_Control_7-Adjustment for backrest angle,0,
ENG158190-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG158190-IDE06512,Seat_Position_Memory_Remote_Control_7-Adjustment for seat forward/back position,0,
ENG158190-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG158190-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG158190-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG158190-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG158190-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG158190-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG158190-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG136327-ENG116986,Source_Last_Reset-Low_Voltage,active,
ENG136327-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,not active,
ENG136327-ENG123072,Source_Last_Reset-Power_On_Reset,not active,
ENG136327-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG136327-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG136327-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:21
blockmap-42-5Q4-959-593-P_VSSZZZKM2RR140480-20241020-1510.CSV
;SW:5Q4-959-593-P   HW:5Q4-959-593-P ---  Door Elect, Driver
;Component:TSG FS        015 0912, Coding:00351020D201020000001000
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_VW27.rod
;Sunday,20,October,2024,15:10:28:49859
;VCID: 52FAA38884636DAAB9F-8006
IDE00310,Outside temperature,17.00, °C
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,not attainable,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear Driver Side Door Control Module,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,14.40, V
IDE02262,synchronous mirror adjustment,active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,14.40, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,active,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04411,Child safety button,Not operated,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,52, %
IDE04539-MAS02229,Mirror memory-Y coordinate,46, %
IDE04539-MAS02476,Mirror memory-installed,installed,
IDE04540,Mirror adjustment (X/Y direction),Position center,
IDE04580,Dimming of inside door handle lighting,Not available,
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,not installed,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,89, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,Not available,
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,Not operated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,9902,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,127.50, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.50, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,active,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,25, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,Not available,
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatically dimming exterior mirrors-Status,not installed,
IDE10164-MAS03691,Automatically dimming exterior mirrors-Dimming,255, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Not available,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE15336,Light output 1 pin D8 target brightness on front driver side,Not available,
IDE15338,Light output 3 pin C1/B3 target brightness on front driver side,0, %
IDE15339,Light output 4 pin D16 target brightness on front driver side,0, %
IDE15636,Light output 2 pin D3 target brightness on front driver side,Not available,
IDE16389-MAS25781,Front ambient Lighting configuration - light output 1-Malfunction location:,Unknown (255)
IDE16390-MAS25781,Front ambient Lighting configuration - light output 2-Malfunction location:,Unknown (255)
IDE16391-MAS25781,Front ambient Lighting configuration - light output 3-Malfunction location:,Unknown (255)
IDE16392-MAS25781,Front ambient Lighting configuration - light output 4-Malfunction location:,Unknown (255)
MAS01872,Rear lid remote control lock switch,not installed,
MAS02101,Child safety lock,active,
MAS06010,Ambient light,Not available,
ENG117315-ENG163906,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J926 ,
Elapsed Time: 00:09
blockmap-44-5WA-907-145-G_VSSZZZKM2RR140480-20241020-1510.CSV
;SW:5WA-907-145-G   HW:5WA-907-145-C ---  Steering Assist
;Component:BASGEN1MQB37  502 1040, Coding:0000000000000001000102010100010000000101010101
;EV_SteerAssisBASGEN1MQB37,007046,EV_SteerAssisBASGEN1MQB37_007_VW38.rod
;Sunday,20,October,2024,15:10:50:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 4EC2B7F8905B094A9D7-801A
Group,Description,Actual
IDE00019,Voltage terminal 30,14.46, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine RPM,934, /min
IDE00323-IDE01022,Security Access: Number of invalid keys-Counter: incorrect inputs of key-code,0,
IDE00323-MAS01155,Security Access: Number of invalid keys-Control module,Not blocked,
IDE00323-MAS02913,Security Access: Number of invalid keys-Remaining running time,0,
IDE02202,End stage temperature,24, °C
IDE02955,System status,Driving mode,
IDE03682-IDE04457,motor position sensor-Electric motor speed,-18000.0, /min
IDE03682-MAS02961,motor position sensor-Engine angle,6, °
IDE03735,Steering torque,0.0, Nm
IDE04183,Steering assistance: target engine torque,0.0, Nm
IDE04184,Steering assistance: engine output,100, %
IDE04448,Steering angle sensor: angle,-6.49999, °
IDE04454,Steering angle sensor: angle speed,0, °/s
IDE04458,Steering angle sensor: mechanical steering stroke,160.9, mm
IDE04459,Steering angle sensor: offset index mark mechanical middle,235, mm
IDE04460,Steering angle sensor: offset straight line running,-2.2, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,not detected,
IDE05155,Power steering current consumption,0.0, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05162-MAS11513,Software end stop-End stop left,80.45, mm
IDE05162-MAS11514,Software end stop-End stop right,-80.47, mm
IDE05162-MAS12179,Software end stop-Validation of end stops: left and right,Condition met,
IDE05162-MAS12180,Software end stop-Validation of end stops: steering stroke,not performed,
IDE05162-MAS12181,Software end stop-Validation of end stops: center,not performed,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS04460,Network diagnosis-Validity,No,
IDE05713-MAS06528,Network diagnosis-Release status,No,
IDE07543,Vehicle speed,0, km/h
IDE10300,OBD Driving Cycle detected,active,
IDE11591-IDE11629,Result of basic setting of steering angle-Status of the active routine,Finish routine: routine OK,
IDE11591-MAS05584,Result of basic setting of steering angle-Result,Preconditions met,
IDE11591-MAS14036,Result of basic setting of steering angle-Number of iterations,2,
IDE11591-MAS14037,Result of basic setting of steering angle-RESTRICTION,no restriction,
IDE11591-MAS14038,Result of basic setting of steering angle-Type of restriction,Precondition,
IDE11602-IDE11629,Result of steering angle sensor: initialization-Status of the active routine,Finish routine: routine OK,
IDE11602-MAS05584,Result of steering angle sensor: initialization-Result,Preconditions met,
IDE11602-MAS14036,Result of steering angle sensor: initialization-Number of iterations,2,
IDE11602-MAS14037,Result of steering angle sensor: initialization-RESTRICTION,no restriction,
IDE11602-MAS14038,Result of steering angle sensor: initialization-Type of restriction,Precondition,
IDE11603-IDE11629,Result of steering angle sensor: move to mechanical center-Status of the active routine,Finish routine: routine OK,
IDE11603-MAS05584,Result of steering angle sensor: move to mechanical center-Result,Preconditions met,
IDE11603-MAS14036,Result of steering angle sensor: move to mechanical center-Number of iterations,2,
IDE11603-MAS14037,Result of steering angle sensor: move to mechanical center-RESTRICTION,no restriction,
IDE11603-MAS14038,Result of steering angle sensor: move to mechanical center-Type of restriction,Precondition,
IDE11604-IDE11629,Result of steer.angle sens.: zero calibr.steer.wheel balance-Status of the active routine,Finish routine: routine OK,
IDE11604-MAS05584,Result of steer.angle sens.: zero calibr.steer.wheel balance-Result,Preconditions met,
IDE11604-MAS14036,Result of steer.angle sens.: zero calibr.steer.wheel balance-Number of iterations,2,
IDE11604-MAS14037,Result of steer.angle sens.: zero calibr.steer.wheel balance-RESTRICTION,no restriction,
IDE11604-MAS14038,Result of steer.angle sens.: zero calibr.steer.wheel balance-Type of restriction,Precondition,
IDE11605-IDE11629,Result of resetting of all adaptation values-Status of the active routine,Finish routine: routine OK,
IDE11605-MAS05584,Result of resetting of all adaptation values-Result,Preconditions met,
IDE11605-MAS14036,Result of resetting of all adaptation values-Number of iterations,2,
IDE11605-MAS14037,Result of resetting of all adaptation values-RESTRICTION,no restriction,
IDE11605-MAS14038,Result of resetting of all adaptation values-Type of restriction,Precondition,
IDE11606-IDE11629,Result of resetting of all adjustments-Status of the active routine,Finish routine: routine OK,
IDE11606-MAS05584,Result of resetting of all adjustments-Result,Preconditions met,
IDE11606-MAS14036,Result of resetting of all adjustments-Number of iterations,2,
IDE11606-MAS14037,Result of resetting of all adjustments-RESTRICTION,no restriction,
IDE11606-MAS14038,Result of resetting of all adjustments-Type of restriction,Precondition,
IDE11607-IDE11629,Result of resetting all software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11607-MAS05584,Result of resetting all software end-stops-Result,Preconditions met,
IDE11607-MAS14036,Result of resetting all software end-stops-Number of iterations,2,
IDE11607-MAS14037,Result of resetting all software end-stops-RESTRICTION,no restriction,
IDE11607-MAS14038,Result of resetting all software end-stops-Type of restriction,Precondition,
IDE11608-IDE11629,Result of resetting to factory setting-Status of the active routine,Finish routine: routine OK,
IDE11608-MAS05584,Result of resetting to factory setting-Result,Preconditions met,
IDE11608-MAS14036,Result of resetting to factory setting-Number of iterations,2,
IDE11608-MAS14037,Result of resetting to factory setting-RESTRICTION,no restriction,
IDE11608-MAS14038,Result of resetting to factory setting-Type of restriction,Precondition,
IDE11609-IDE11629,Result of steering angle sensor: software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11609-MAS05584,Result of steering angle sensor: software end-stops-Result,Preconditions met,
IDE11609-MAS14036,Result of steering angle sensor: software end-stops-Number of iterations,2,
IDE11609-MAS14037,Result of steering angle sensor: software end-stops-RESTRICTION,no restriction,
IDE11609-MAS14038,Result of steering angle sensor: software end-stops-Type of restriction,Precondition,
IDE11863,Support power reduction,100.0, %
IDE11865-IDE00021,Reason for engagement steering support-Engine RPM,Met,
IDE11865-IDE00075,Reason for engagement steering support-Vehicle speed,Met,
IDE11865-MAS01737,Reason for engagement steering support-Diagnosis,not met,
IDE11865-MAS08112,Reason for engagement steering support-Drive readiness,not met,
MAS02126-IDE05744,Steering angle sensor: status-Steering angle sensor: initialization,initialized,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,invalid,
MAS02126-MAS10118,Steering angle sensor: status-Steering angle sensor: status of calibration,calibrated,
MAS08112,Drive readiness,not active,
ENG157712,Current_gradient_limiting,11.9, %
ENG157713,Current_limiting,0.0, %
Elapsed Time: 00:07
blockmap-52-5Q4-959-592-P_VSSZZZKM2RR140480-20241020-1511.CSV
;SW:5Q4-959-592-P   HW:5Q4-959-592-P ---  Door Elect, Pass.
;Component:TSG BFS       015 0912, Coding:00351020DE01020000001000
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHCONT_VW27.rod
;Sunday,20,October,2024,15:11:06:49859
;VCID: 51F8AC84816516B2805-8004
IDE01993-MAS12276,Control module reference number-Front door control module,Front passenger door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear Passenger Door Control Module,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,14.40, V
IDE02266,Passenger side rear power window button,Not operated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,14.40, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04539-MAS02228,Mirror memory-X coordinate,58, %
IDE04539-MAS02229,Mirror memory-Y coordinate,52, %
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not installed,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,Not available,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,Not operated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,9902,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE06941,Rear window regulator child lock: frt.pass. side,active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,25, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,Not available,
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,127.50, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.50, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
IDE15340,Light output 1 pin D8 target brightness on front passenger side,Not available,
IDE15341,Light output 2 pin D3 target brightness on front passenger side,Not available,
IDE15342,Light output 3 pin C1/B3 target brightness on front passenger side,0, %
IDE15343,Light output 4 pin D16 target brightness on front passenger side,0, %
ENG117316-ENG163906,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J927 ,
Elapsed Time: 00:08
blockmap-5F-5FA-035-862-R_VSSZZZKM2RR140480-20241020-1511.CSV
;SW:5FA-035-862-R   HW:5FA-035-862 ---  Information Electr.
;Component:MU-O-ND-EU    H67 1969, Coding:43161008000100000000000000000000000000000000000000
;EV_MUOIMQB37w,001002,EV_MUOIMQB37w_001_SE38.rod
;Sunday,20,October,2024,15:11:27:49859
;VCID: 46D28FD8782BC10A257-8012
IDE00019,Voltage terminal 30,14.40, V
IDE00021,Engine RPM,880.00, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,55, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,0, °C
IDE00655-MAS02238,Temperature of processor circuit board-Up-to-date,46, °C
IDE00767,No. of unscheduled ECU resets,0,
IDE00916-ENG249445,Speaker status-loudspeaker_config_channel_1,Right rear bass speaker,
IDE00916-ENG249480,Speaker status-loudspeaker_config_channel_10,Not available,
IDE00916-ENG249518,Speaker status-loudspeaker_config_channel_11,Not available,
IDE00916-ENG249486,Speaker status-loudspeaker_config_channel_12,Not available,
IDE00916-ENG249341,Speaker status-loudspeaker_config_channel_13,Not available,
IDE00916-ENG249407,Speaker status-loudspeaker_config_channel_14,Not available,
IDE00916-ENG249456,Speaker status-loudspeaker_config_channel_15,Not available,
IDE00916-ENG249515,Speaker status-loudspeaker_config_channel_16,Not available,
IDE00916-ENG249507,Speaker status-loudspeaker_config_channel_17,Not available,
IDE00916-ENG249452,Speaker status-loudspeaker_config_channel_18,Not available,
IDE00916-ENG249466,Speaker status-loudspeaker_config_channel_19,Not available,
IDE00916-ENG249455,Speaker status-loudspeaker_config_channel_2,Right front bass speaker,
IDE00916-ENG249434,Speaker status-loudspeaker_config_channel_20,Not available,
IDE00916-ENG249416,Speaker status-loudspeaker_config_channel_21,Not available,
IDE00916-ENG249527,Speaker status-loudspeaker_config_channel_22,Not available,
IDE00916-ENG249489,Speaker status-loudspeaker_config_channel_23,Not available,
IDE00916-ENG249520,Speaker status-loudspeaker_config_channel_24,Not available,
IDE00916-ENG249288,Speaker status-loudspeaker_config_channel_3,Left front bass speaker,
IDE00916-ENG249509,Speaker status-loudspeaker_config_channel_4,Left rear bass speaker,
IDE00916-ENG249362,Speaker status-loudspeaker_config_channel_5,Not available,
IDE00916-ENG249491,Speaker status-loudspeaker_config_channel_6,Not available,
IDE00916-ENG249410,Speaker status-loudspeaker_config_channel_7,Not available,
IDE00916-ENG249340,Speaker status-loudspeaker_config_channel_8,Not available,
IDE00916-ENG249470,Speaker status-loudspeaker_config_channel_9,Not available,
IDE00916-ENG249411,Speaker status-loudspeaker_state_channel_1,Condition not met,
IDE00916-ENG249429,Speaker status-loudspeaker_state_channel_10,Measuring value not available,
IDE00916-ENG249464,Speaker status-loudspeaker_state_channel_11,Measuring value not available,
IDE00916-ENG249451,Speaker status-loudspeaker_state_channel_12,Measuring value not available,
IDE00916-ENG249436,Speaker status-loudspeaker_state_channel_13,Measuring value not available,
IDE00916-ENG249447,Speaker status-loudspeaker_state_channel_14,Measuring value not available,
IDE00916-ENG249426,Speaker status-loudspeaker_state_channel_15,Measuring value not available,
IDE00916-ENG249317,Speaker status-loudspeaker_state_channel_16,Measuring value not available,
IDE00916-ENG249528,Speaker status-loudspeaker_state_channel_17,Measuring value not available,
IDE00916-ENG249492,Speaker status-loudspeaker_state_channel_18,Measuring value not available,
IDE00916-ENG249409,Speaker status-loudspeaker_state_channel_19,Measuring value not available,
IDE00916-ENG249305,Speaker status-loudspeaker_state_channel_2,Condition not met,
IDE00916-ENG249435,Speaker status-loudspeaker_state_channel_20,Measuring value not available,
IDE00916-ENG249417,Speaker status-loudspeaker_state_channel_21,Measuring value not available,
IDE00916-ENG249404,Speaker status-loudspeaker_state_channel_22,Measuring value not available,
IDE00916-ENG249319,Speaker status-loudspeaker_state_channel_23,Measuring value not available,
IDE00916-ENG249408,Speaker status-loudspeaker_state_channel_24,Measuring value not available,
IDE00916-ENG249290,Speaker status-loudspeaker_state_channel_3,Condition not met,
IDE00916-ENG249312,Speaker status-loudspeaker_state_channel_4,Condition not met,
IDE00916-ENG249303,Speaker status-loudspeaker_state_channel_5,Measuring value not available,
IDE00916-ENG249399,Speaker status-loudspeaker_state_channel_6,Measuring value not available,
IDE00916-ENG249508,Speaker status-loudspeaker_state_channel_7,Measuring value not available,
IDE00916-ENG249335,Speaker status-loudspeaker_state_channel_8,Measuring value not available,
IDE00916-ENG249382,Speaker status-loudspeaker_state_channel_9,Measuring value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,0,
IDE01351,Terminal 75 status,On,
IDE01627-MAS01167,Search for Bluetooth devices-Actuation time,0 s,
IDE01627-ENG170421,Search for Bluetooth devices-IoReached Status,Output diagnostic test not active,
IDE01628-MAS01167,Establish connection to last Bluetooth device-Actuation time,0 s,
IDE01628-ENG170421,Establish connection to last Bluetooth device-IoReached Status,Output diagnostic test not active,
IDE01700-MAS01763,Status of tuner for digital radio (DAB)-Signal Strength,51,
IDE01700-MAS02572,Status of tuner for digital radio (DAB)-Mute,not active,
IDE01700-MAS02949,Status of tuner for digital radio (DAB)-Frequency,216928,
IDE01700-MAS03786,Status of tuner for digital radio (DAB)-Audio Codec,MPEG4 HE AAC v2,
IDE01700-MAS06242,Status of tuner for digital radio (DAB)-Signal quality,88,
IDE01700-MAS19004,Status of tuner for digital radio (DAB)-DAB fault bit rate FIC,0.00,
IDE01700-MAS19005,Status of tuner for digital radio (DAB)-DAB fault bit rate NET,0.44,
IDE01700-MAS19006,Status of tuner for digital radio (DAB)-DAB fault bit rate MSC,0.00,
IDE01700-MAS19007,Status of tuner for digital radio (DAB)-TP traffic data,Not available,
IDE01700-MAS19010,Status of tuner for digital radio (DAB)-TPEG,Not available,
IDE01700-MAS19011,Status of tuner for digital radio (DAB)-Ensemble ID,49614,
IDE01700-MAS19012,Status of tuner for digital radio (DAB)-Ensemble Label,SDL National    þáÌç!Absolute Country                                 cX,
IDE01700-MAS19013,Status of tuner for digital radio (DAB)-Ensemble label mask,65040,
IDE01700-MAS19014,Status of tuner for digital radio (DAB)-Ensemble country code,225,
IDE01700-MAS19018,Status of tuner for digital radio (DAB)-Bit rate,32,
IDE01700-MAS19019,Status of tuner for digital radio (DAB)-Sample Rate,16,
IDE01700-MAS19020,Status of tuner for digital radio (DAB)-Audio mode,05,
IDE01700-MAS19022,Status of tuner for digital radio (DAB)-DAB transfer mode,1,
IDE01700-MAS19023,Status of tuner for digital radio (DAB)-SYNC / OFDM Lock,active,
IDE01700-MAS19024,Status of tuner for digital radio (DAB)-Audio quality,99,
IDE01700-MAS19041,Status of tuner for digital radio (DAB)-Protection level,3_A_equal_protection_level,
IDE01700-ENG117346,Status of tuner for digital radio (DAB)-Charset,00,
IDE01700-ENG249430,Status of tuner for digital radio (DAB)-Count_Audio_Services,30,
IDE01700-ENG249296,Status of tuner for digital radio (DAB)-Count_Services,30,
IDE01700-ENG117340,Status of tuner for digital radio (DAB)-Data_Service_Identifier,00 00 00 00,
IDE01700-ENG117341,Status of tuner for digital radio (DAB)-Data_Service_Label,                 cX,
IDE01700-ENG117345,Status of tuner for digital radio (DAB)-Data_Service_Label_Mask,00 00,
IDE01700-ENG117335,Status of tuner for digital radio (DAB)-Program_Service_Identifier,52455,
IDE01700-ENG117336,Status of tuner for digital radio (DAB)-Service_Component_Identifier,0,
IDE01700-ENG117338,Status of tuner for digital radio (DAB)-Service_Label,Absolute Country                                 cX,
IDE01700-ENG117343,Status of tuner for digital radio (DAB)-Service_Label_Mask,80 7F,
IDE01700-ENG117337,Status of tuner for digital radio (DAB)-Sub_Channel_Identifier,33,
IDE01700-ENG117339,Status of tuner for digital radio (DAB)-Sub_Service_Label,                                 cX,
IDE01700-ENG117344,Status of tuner for digital radio (DAB)-Sub_Service_Label_Mask,00 00,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,16,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,16,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,OK,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,121, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,48, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01770-MAS01632,Status of GPS antenna-Status,Not available,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,Not available,
IDE01771-MAS01808,Status of digital radio antenna 1-Antenna current,53, mA
IDE01771-MAS03938,Status of digital radio antenna 1-Connection between radio and antenna amplifier,electrically OK,
IDE01771-MAS03939,Status of digital radio antenna 1-Connection between antenna amplifier and antenna,electrically OK,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,0E A6 CE 78,
IDE02178-MAS01167,Status remote control-Actuation time,0 s,
IDE02178-ENG170421,Status remote control-IoReached Status,Output diagnostic test not active,
IDE02179-MAS01167,Remote control for selecting the audio source-Actuation time,0 s,
IDE02179-ENG170421,Remote control for selecting the audio source-IoReached Status,Output diagnostic test not active,
IDE02180-MAS01167,Remote control for FM frequency selection-Actuation time,0 s,
IDE02180-ENG170421,Remote control for FM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02181-MAS01167,Remote control for AM frequency selection-Actuation time,0 s,
IDE02181-ENG170421,Remote control for AM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02326-MAS17347,GPS signal strength-Satellite 1: identification,0,
IDE02326-MAS17348,GPS signal strength-Satellite 1: signal strength,63, dBµV
IDE02326-MAS17349,GPS signal strength-Satellite 2: signal strength,63, dBµV
IDE02326-MAS17350,GPS signal strength-Satellite 3: signal strength,63, dBµV
IDE02326-MAS17351,GPS signal strength-Satellite 4: signal strength,63, dBµV
IDE02326-MAS17352,GPS signal strength-Satellite 2: identification,0,
IDE02326-MAS17353,GPS signal strength-Satellite 3: identification,0,
IDE02326-MAS17354,GPS signal strength-Satellite 4: identification,0,
IDE02449-MAS01167,Remote control for satellite radio station selection-Actuation time,0 s,
IDE02449-ENG170421,Remote control for satellite radio station selection-IoReached Status,Output diagnostic test not active,
IDE02452-IDE02451,Satellite radio tuner status-Satellite radio antenna status,electrically OK,
IDE02452-IDE02453,Satellite radio tuner status-Channel selection for satellite radio,0,
IDE02452-MAS01765,Satellite radio tuner status-Audio Signal,Not available,
IDE02452-MAS01808,Satellite radio tuner status-Antenna current,0, mA
IDE02452-MAS02573,Satellite radio tuner status-Reception quality,No signal,
IDE02452-MAS13343,Satellite radio tuner status-Satellite radio tuner: pre-activation status,factory_activation_successful,
IDE02452-MAS13344,Satellite radio tuner status-Satellite radio tuner: pre-activation value,00,
IDE02454-MAS01167,Remote control for digital radio service selection (DSB)-Actuation time,0 s,
IDE02454-ENG170421,Remote control for digital radio service selection (DSB)-IoReached Status,Output diagnostic test not active,
IDE02470-MAS01167,Remote control frequency selection digital radio (band III)-Actuation time,0 s,
IDE02470-ENG170421,Remote control frequency selection digital radio (band III)-IoReached Status,Output diagnostic test not active,
IDE02475-MAS01167,Acoustic check of loudspeakers-Actuation time,0 s,
IDE02475-ENG170421,Acoustic check of loudspeakers-IoReached Status,Output diagnostic test not active,
IDE02476-MAS01167,Electrical test of speakers-Actuation time,0 s,
IDE02476-ENG170421,Electrical test of speakers-IoReached Status,Output diagnostic test not active,
IDE02501-MAS01167,Remote control for voice operation-Actuation time,0 s,
IDE02501-ENG170421,Remote control for voice operation-IoReached Status,Output diagnostic test not active,
IDE02505-MAS01763,Status of tuner 2 for digital radio (DAB)-Signal Strength,77,
IDE02505-MAS02949,Status of tuner 2 for digital radio (DAB)-Frequency,223936,
IDE02505-MAS06242,Status of tuner 2 for digital radio (DAB)-Signal quality,99,
IDE02505-MAS19004,Status of tuner 2 for digital radio (DAB)-DAB fault bit rate FIC,0.00,
IDE02505-MAS19005,Status of tuner 2 for digital radio (DAB)-DAB fault bit rate NET,Not available,
IDE02505-MAS19006,Status of tuner 2 for digital radio (DAB)-DAB fault bit rate MSC,Not available,
IDE02505-MAS19011,Status of tuner 2 for digital radio (DAB)-Ensemble ID,00 00 C1 B8,
IDE02505-MAS19012,Status of tuner 2 for digital radio (DAB)-Ensemble Label,                c,
IDE02505-MAS19023,Status of tuner 2 for digital radio (DAB)-SYNC / OFDM Lock,active,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth not visible: connection possible,
IDE02766,Malfunction status,00 00,
IDE02766-ENG249300,Malfunction status-amount_communication_errors,0,
IDE03477-MAS00106,GPS time-Year,2024,
IDE03477-MAS00107,GPS time-Month,10,
IDE03477-MAS00108,GPS time-Day,20,
IDE03477-MAS00109,GPS time-Hours,14,
IDE03477-MAS00110,GPS time-Minutes,10,
IDE03477-MAS00111,GPS time-Seconds,52,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,0, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,0, %
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,15, min
IDE04317-MAS00108,Total system run time-Day,1, d
IDE04317-MAS00109,Total system run time-Hours,15, H
IDE04317-MAS00110,Total system run time-Minutes,16, min
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04546-IDE00301,Calibration of navigation-Mileage,343.13, mm
IDE04546-MAS03647,Calibration of navigation-Calibration condition,complete,
IDE04548-MAS00106,Electronic toll collection-Year,2000,
IDE04548-MAS00107,Electronic toll collection-Month,0,
IDE04548-MAS00108,Electronic toll collection-Day,OFF,
IDE04548-MAS00109,Electronic toll collection-Hours,0,
IDE04548-MAS00110,Electronic toll collection-Minutes,0,
IDE04548-MAS00111,Electronic toll collection-Seconds,0,
IDE04548-MAS01156,Electronic toll collection-Communication status,not OK,
IDE04548-MAS01161,Electronic toll collection-Communication malfunction,0,
IDE04548-MAS01758,Electronic toll collection-Date / time,invalid,
IDE04548-MAS04385,Electronic toll collection-Authorization,not OK,
IDE04548-MAS04386,Electronic toll collection-Write card,not OK,
IDE04548-MAS04387,Electronic toll collection-Read card,not OK,
IDE04548-MAS04388,Electronic toll collection-Card type,no card available,
IDE04548-MAS04389,Electronic toll collection-Number of repeat attempts,0,
IDE04548-MAS04394,Electronic toll collection-Connection status,not connected,
IDE04548-MAS04460,Electronic toll collection-Validity,not OK,
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 1,
IDE04649-MAS06857,Activation for housing fan-Speed,4320, /min
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,invalid,
IDE04767-MAS02112,Update software via medium-Programmability,Waiting for data transmission,
IDE04768,Bluetooth: device address,FC 84 A7 85 26 9E,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05107-MAS01167,Test image display unit 1 for multimedia system-Actuation time,0 s,
IDE05107-ENG170421,Test image display unit 1 for multimedia system-IoReached Status,Output diagnostic test not active,
IDE05535-MAS01632,Traffic data antenna-Status,not OK,
IDE05570-MAS01632,DSRC antenna-Status,Unknown (0)
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2000,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,0,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,OFF,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,0,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,0,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,0,
IDE05596-MAS00106,Last time GPS position outside map-Year,2024,
IDE05596-MAS00107,Last time GPS position outside map-Month,10,
IDE05596-MAS00108,Last time GPS position outside map-Day,20,
IDE05596-MAS00109,Last time GPS position outside map-Hours,14,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,10,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,51,
IDE05602-IDE03615,Bluetooth: connected device 1-Variant,
IDE05602-IDE04768,Bluetooth: connected device 1-Bluetooth: device address,00 00 00 00 00 00,
IDE05602-MAS01483,Bluetooth: connected device 1-Software version,
IDE05602-MAS02159,Bluetooth: connected device 1-Remote SIM Access Profile (rSAP),0,
IDE05602-MAS02160,Bluetooth: connected device 1-Hands free profile (HFP),0,
IDE05602-MAS03159,Bluetooth: connected device 1-Manufacturer,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,
IDE05602-MAS17538,Bluetooth: connected device 1-Received Signal Strength Indicator (RSSI),0,
IDE05602-MAS17539,Bluetooth: connected device 1-Determining the existing profile (SDP),0,
IDE05602-MAS17540,Bluetooth: connected device 1-Serial data transfer (SPP),0,
IDE05602-MAS17541,Bluetooth: connected device 1-Streaming audio data (A2DP),0,
IDE05602-MAS17542,Bluetooth: connected device 1-Remote control for audio/video (AVRCP),0,
IDE05602-MAS17543,Bluetooth: connected device 1-Network connections (PAN),0,
IDE05602-MAS17544,Bluetooth: connected device 1-Message exchange between devices (MAP),0,
IDE05602-MAS17545,Bluetooth: connected device 1-Generic data transfer between two devices (OBEX),0,
IDE05602-MAS17546,Bluetooth: connected device 1-Sending individual files (OPP),0,
IDE05602-MAS17547,Bluetooth: connected device 1-File transfer (FTP),0,
IDE05602-MAS17548,Bluetooth: connected device 1-Read-only access to telephone directory (PBAP),0,
IDE05602-MAS17549,Bluetooth: connected device 1-Telephone directory download (AT),0,
IDE05602-MAS17550,Bluetooth: connected device 1-Sharing calendars or notes between two devices (CTN),0,
IDE05602-MAS17551,Bluetooth: connected device 1-iAP protocol (iAP),0,
IDE05603-IDE03615,Bluetooth: connected device 2-Variant,
IDE05603-IDE04768,Bluetooth: connected device 2-Bluetooth: device address,00 00 00 00 00 00,
IDE05603-MAS01483,Bluetooth: connected device 2-Software version,
IDE05603-MAS02159,Bluetooth: connected device 2-Remote SIM Access Profile (rSAP),0,
IDE05603-MAS02160,Bluetooth: connected device 2-Hands free profile (HFP),0,
IDE05603-MAS03159,Bluetooth: connected device 2-Manufacturer,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,
IDE05603-MAS17538,Bluetooth: connected device 2-Received Signal Strength Indicator (RSSI),0,
IDE05603-MAS17539,Bluetooth: connected device 2-Determining the existing profile (SDP),0,
IDE05603-MAS17540,Bluetooth: connected device 2-Serial data transfer (SPP),0,
IDE05603-MAS17541,Bluetooth: connected device 2-Streaming audio data (A2DP),0,
IDE05603-MAS17542,Bluetooth: connected device 2-Remote control for audio/video (AVRCP),0,
IDE05603-MAS17543,Bluetooth: connected device 2-Network connections (PAN),0,
IDE05603-MAS17544,Bluetooth: connected device 2-Message exchange between devices (MAP),0,
IDE05603-MAS17545,Bluetooth: connected device 2-Generic data transfer between two devices (OBEX),0,
IDE05603-MAS17546,Bluetooth: connected device 2-Sending individual files (OPP),0,
IDE05603-MAS17547,Bluetooth: connected device 2-File transfer (FTP),0,
IDE05603-MAS17548,Bluetooth: connected device 2-Read-only access to telephone directory (PBAP),0,
IDE05603-MAS17549,Bluetooth: connected device 2-Telephone directory download (AT),0,
IDE05603-MAS17550,Bluetooth: connected device 2-Sharing calendars or notes between two devices (CTN),0,
IDE05603-MAS17551,Bluetooth: connected device 2-iAP protocol (iAP),0,
IDE05604-IDE03615,Bluetooth: connected device 3-Variant,
IDE05604-IDE04768,Bluetooth: connected device 3-Bluetooth: device address,00 00 00 00 00 00,
IDE05604-MAS01483,Bluetooth: connected device 3-Software version,
IDE05604-MAS02159,Bluetooth: connected device 3-Remote SIM Access Profile (rSAP),0,
IDE05604-MAS02160,Bluetooth: connected device 3-Hands free profile (HFP),0,
IDE05604-MAS03159,Bluetooth: connected device 3-Manufacturer,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,
IDE05604-MAS17538,Bluetooth: connected device 3-Received Signal Strength Indicator (RSSI),0,
IDE05604-MAS17539,Bluetooth: connected device 3-Determining the existing profile (SDP),0,
IDE05604-MAS17540,Bluetooth: connected device 3-Serial data transfer (SPP),0,
IDE05604-MAS17541,Bluetooth: connected device 3-Streaming audio data (A2DP),0,
IDE05604-MAS17542,Bluetooth: connected device 3-Remote control for audio/video (AVRCP),0,
IDE05604-MAS17543,Bluetooth: connected device 3-Network connections (PAN),0,
IDE05604-MAS17544,Bluetooth: connected device 3-Message exchange between devices (MAP),0,
IDE05604-MAS17545,Bluetooth: connected device 3-Generic data transfer between two devices (OBEX),0,
IDE05604-MAS17546,Bluetooth: connected device 3-Sending individual files (OPP),0,
IDE05604-MAS17547,Bluetooth: connected device 3-File transfer (FTP),0,
IDE05604-MAS17548,Bluetooth: connected device 3-Read-only access to telephone directory (PBAP),0,
IDE05604-MAS17549,Bluetooth: connected device 3-Telephone directory download (AT),0,
IDE05604-MAS17550,Bluetooth: connected device 3-Sharing calendars or notes between two devices (CTN),0,
IDE05604-MAS17551,Bluetooth: connected device 3-iAP protocol (iAP),0,
IDE05605-IDE03615,Bluetooth: connected device 4-Variant,
IDE05605-IDE04768,Bluetooth: connected device 4-Bluetooth: device address,00 00 00 00 00 00,
IDE05605-MAS01483,Bluetooth: connected device 4-Software version,
IDE05605-MAS02159,Bluetooth: connected device 4-Remote SIM Access Profile (rSAP),0,
IDE05605-MAS02160,Bluetooth: connected device 4-Hands free profile (HFP),0,
IDE05605-MAS03159,Bluetooth: connected device 4-Manufacturer,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,
IDE05605-MAS17538,Bluetooth: connected device 4-Received Signal Strength Indicator (RSSI),0,
IDE05605-MAS17539,Bluetooth: connected device 4-Determining the existing profile (SDP),0,
IDE05605-MAS17540,Bluetooth: connected device 4-Serial data transfer (SPP),0,
IDE05605-MAS17541,Bluetooth: connected device 4-Streaming audio data (A2DP),0,
IDE05605-MAS17542,Bluetooth: connected device 4-Remote control for audio/video (AVRCP),0,
IDE05605-MAS17543,Bluetooth: connected device 4-Network connections (PAN),0,
IDE05605-MAS17544,Bluetooth: connected device 4-Message exchange between devices (MAP),0,
IDE05605-MAS17545,Bluetooth: connected device 4-Generic data transfer between two devices (OBEX),0,
IDE05605-MAS17546,Bluetooth: connected device 4-Sending individual files (OPP),0,
IDE05605-MAS17547,Bluetooth: connected device 4-File transfer (FTP),0,
IDE05605-MAS17548,Bluetooth: connected device 4-Read-only access to telephone directory (PBAP),0,
IDE05605-MAS17549,Bluetooth: connected device 4-Telephone directory download (AT),0,
IDE05605-MAS17550,Bluetooth: connected device 4-Sharing calendars or notes between two devices (CTN),0,
IDE05605-MAS17551,Bluetooth: connected device 4-iAP protocol (iAP),0,
IDE05606-IDE03615,Bluetooth: connected device 5-Variant,
IDE05606-IDE04768,Bluetooth: connected device 5-Bluetooth: device address,00 00 00 00 00 00,
IDE05606-MAS01483,Bluetooth: connected device 5-Software version,
IDE05606-MAS02159,Bluetooth: connected device 5-Remote SIM Access Profile (rSAP),0,
IDE05606-MAS02160,Bluetooth: connected device 5-Hands free profile (HFP),0,
IDE05606-MAS03159,Bluetooth: connected device 5-Manufacturer,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,
IDE05606-MAS17538,Bluetooth: connected device 5-Received Signal Strength Indicator (RSSI),0,
IDE05606-MAS17539,Bluetooth: connected device 5-Determining the existing profile (SDP),0,
IDE05606-MAS17540,Bluetooth: connected device 5-Serial data transfer (SPP),0,
IDE05606-MAS17541,Bluetooth: connected device 5-Streaming audio data (A2DP),0,
IDE05606-MAS17542,Bluetooth: connected device 5-Remote control for audio/video (AVRCP),0,
IDE05606-MAS17543,Bluetooth: connected device 5-Network connections (PAN),0,
IDE05606-MAS17544,Bluetooth: connected device 5-Message exchange between devices (MAP),0,
IDE05606-MAS17545,Bluetooth: connected device 5-Generic data transfer between two devices (OBEX),0,
IDE05606-MAS17546,Bluetooth: connected device 5-Sending individual files (OPP),0,
IDE05606-MAS17547,Bluetooth: connected device 5-File transfer (FTP),0,
IDE05606-MAS17548,Bluetooth: connected device 5-Read-only access to telephone directory (PBAP),0,
IDE05606-MAS17549,Bluetooth: connected device 5-Telephone directory download (AT),0,
IDE05606-MAS17550,Bluetooth: connected device 5-Sharing calendars or notes between two devices (CTN),0,
IDE05606-MAS17551,Bluetooth: connected device 5-iAP protocol (iAP),0,
IDE05700-MAS01456,USB connection-Speed,Low speed,
IDE05700-MAS01632,USB connection-Status,not OK.,
IDE05700-MAS03159,USB connection-Manufacturer,0,
IDE05700-MAS04393,USB connection-USB device class,0,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,0,
IDE05700-MAS06173,USB connection-Protocol,0,
IDE05700-MAS06174,USB connection-Product ID,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05726,Dimmer terminal 58xd,92.43, %
IDE05814,Individualization characteristic,FF FF FF FF FF,
IDE06028-MAS02317,Control head button operation-Button code 1,0,
IDE06028-MAS02318,Control head button operation-Button code 2,0,
IDE06028-MAS04151,Control head button operation-Joystick,0,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,-127,
IDE06028-MAS04414,Control head button operation-Volume control,-127,
IDE06516-MAS01424,Temperature: optical drive-max.value,Not available,
IDE06516-MAS01425,Temperature: optical drive-min.value,Not available,
IDE06516-MAS02238,Temperature: optical drive-Up-to-date,Not available,
IDE06517-MAS01424,Temperature: audio amplifier-max.value,70, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,0, °C
IDE06517-MAS02238,Temperature: audio amplifier-Up-to-date,50, °C
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,Not available,
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,Not available,
IDE06519-MAS02238,Temperature of MOST transceiver-Up-to-date,Not available,
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,61, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,0, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Up-to-date,51, °C
IDE06522-MAS01424,Temperature of phone unit-max.value,64, °C
IDE06522-MAS01425,Temperature of phone unit-min.value,0, °C
IDE06522-MAS02238,Temperature of phone unit-Up-to-date,53, °C
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07364,GPS reception status,GPS data available,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE08531-MAS07133,Connection status online license services-No. of license serv.,0,
IDE08531-ENG98502,Connection status online license services-Data,|ID services,Activation status
IDE09544-MAS01167,Locking information electronic 1 operation-Actuation time,0 s,
IDE09544-ENG170421,Locking information electronic 1 operation-IoReached Status,Output diagnostic test not active,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10300,OBD Driving Cycle detected,not active,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10481-MAS01167,Interface for external media: diagnosis-Actuation time,0 s,
IDE10481-ENG170421,Interface for external media: diagnosis-IoReached Status,Output diagnostic test not active,
IDE10600-MAS01632,Status of the navigation database-Status,valid,
IDE10600-ENG98502,Status of the navigation database-Data,|Country Code,Region Code
IDE10843-ENG98502,Function module: identification-Data,|Device name,Module Name
IDE10857-MAS02476,Touchless loading of mobile phone: status-installed,available.,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-Charging,No,
IDE11034-MAS01482,Satellite radio: module information-Hardware version,
IDE11034-MAS11961,Satellite radio: module information-Serial number,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,
IDE11034-MAS11966,Satellite radio: module information-Database Version,
IDE11034-ENG249454,Satellite radio: module information-apogee_traffic,
IDE11034-ENG249326,Satellite radio: module information-canadian_fuel,
IDE11034-ENG249344,Satellite radio: module information-channel_arts,
IDE11034-ENG249291,Satellite radio: module information-ev_stations,
IDE11034-ENG249490,Satellite radio: module information-fuel_stations,
IDE11034-ENG249493,Satellite radio: module information-internal_sxm,
IDE11034-ENG249368,Satellite radio: module information-movies,
IDE11034-ENG249268,Satellite radio: module information-Parking,
IDE11034-ENG249458,Satellite radio: module information-phonetics,
IDE11034-ENG249496,Satellite radio: module information-safety_alerts,
IDE11034-ENG176820,Satellite radio: module information-States,
IDE11034-ENG249463,Satellite radio: module information-stocks,
IDE11034-ENG249431,Satellite radio: module information-sxm_pics,
IDE11034-ENG249499,Satellite radio: module information-tabular_weather,
IDE11034-ENG249467,Satellite radio: module information-weather_alerts,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,0,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11504,Satellite radio tuner: pre-activated subscription,No,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,no link,
IDE11730,Ethernet signal quality: branch 3,no link,
IDE11731,Ethernet signal quality: branch 4,no link,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,0,
IDE11739,Ethernet counter connection interruptions: branch 4,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FE 80 00 00 00 00 00 00 32 0E B8 FF FE 5A 3F 10|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73|FE 80 00 00 00 00 00 00 32 0E B8 FF FE 5A 3F 10|FD 53 7C B8 03 83 00 07 00 00 00 00 00 00 00 73|FE 80 00 00 00 00 00 00 32 0E B8 FF FE 5A 3F 10|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 07|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|3|4|5|0|0|0|0|0|0|0|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,48,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|30 0E B8 CB DB 2D|44 20 63 02 4D E2|44 20 63 02 4D E2|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|3|3|3|3|3|3|3|3|3|3|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|3|3|3|3|3|3|3|3|3|3|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|3|3|3|3|3|3|3|3|3|3|,
IDE12238,I network: discarded messages counter,48,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10
IDE12625,IP network: current link deceleration: branch 1,4864, ns
IDE12626,IP network: current link deceleration: branch 2,0, ns
IDE12627,IP network: current link deceleration: branch 3,4864, ns
IDE12628,IP network: current link deceleration: branch 4,4864, ns
IDE12633,IP Network maximum correction of the synchronized clock,-589880670, ns
IDE12939-MAS02643,Public key for SWaP function (3072)-Key,D4 97 D6 D5 42 7D 31 5F C9 C2 58 C5 21 E0 16 C6 74 B6 54 3D D5 BA 59 5A F9 0B 9C 4C 09 48 A3 61 DA CC C2 97 46 26 8B BB F6 32 06 3A BB 43 18 A4 20 89 31 63 D6 2A D5 C6 B5 A4 50 82 BA 47 31 5C 90 09 76 06 4D 40 C1 8D DB 0B AE BD 58 5F 45 F0 52 B6 B2 BB E1 07 B0 20 BE 2D 99 DF D3 5D 61 91 D5 6C 35 08 91 4D 26 FC 0E 00 AA 9B 18 AC FD CA E0 23 71 57 F3 24 A7 AE A0 20 EA 92 3F 31 9A 00 89 5B 5C 23 65 A0 B7 B4 67 4D 8C 26 68 2F C9 CB 24 05 66 F6 B8 41 6A F6 6E 72 9F 98 B4 0B 1C 8E A7 62 52 02 FD 7A 6F 1B D6 1A C7 40 5D 41 4E 55 E7 8F 11 30 88 65 D3 43 42 23 74 62 3D DF B1 60 AD 99 DD 79 AB 8B 18 69 32 B3 8B 5C DF AE 9A 51 65 AE 9A 85 A3 FC 75 77 04 E9 A9 62 16 F4 87 05 7B C0 3B 7E B7 50 7F 70 81 B4 87 B3 7B 53 D1 5D 0E 24 2F 8F 81 C8 47 CF 1E 5B AC 08 1D 08 34 C0 51 8A A9 FD EE 69 55 48 83 52 80 EC 22 B8 40 AA 69 20 B2 0F 5D 7D 94 34 D2 AE DC 96 92 A0 94 5A E0 83 E4 50 30 D1 B5 EB 3D D6 FD CD 59 C5 E5 A5 CC 34 4E 57 26 3C 26 28 A9 74 ED EE 6C D0 1F AA F1 01 9D BC DA 43 6E C3 9C 01 9C 99 8A D2 47 EC 9E AD AF 66 5D 3D F0 65 C5 71 27 A6 1E D4 52 F7 B5 D7 A2 37 DB C6 87 49 C0 1A 6C 06 E6 85 2A F2 42 E2 86 0D 22 70 F7 CB 48 92 0D 77 F8 06 AE 65 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11,
IDE13323-MAS13737,Acceleration sensor for navigation-Acceleration on the X axis,0.00, m/s²
IDE13323-MAS13738,Acceleration sensor for navigation-Acceleration on the Y axis,0.00, m/s²
IDE13323-MAS13739,Acceleration sensor for navigation-Acceleration on the Z axis,0.00, m/s²
IDE13344-MAS01167,Acoustic check of loudspeakers: sequential analysis-Actuation time,0 s,
IDE13344-ENG170421,Acoustic check of loudspeakers: sequential analysis-IoReached Status,Output diagnostic test not active,
IDE13737-MAS01763,Status of tuner for digital radio 1b (DAB)-Signal Strength,49,
IDE13737-MAS19004,Status of tuner for digital radio 1b (DAB)-DAB fault bit rate FIC,Not available,
IDE13737-MAS19005,Status of tuner for digital radio 1b (DAB)-DAB fault bit rate NET,Not available,
IDE13737-MAS19006,Status of tuner for digital radio 1b (DAB)-DAB fault bit rate MSC,Not available,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,VSSZZZKM2RR140480,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,10,
IDE14128-MAS01167,Activation for blower housing status-Actuation time,0 s,
IDE14128-ENG170421,Activation for blower housing status-IoReached Status,Output diagnostic test not active,
IDE14344,Automotive audio bus (A2B): status,|Node number,Node name
IDE14344-ENG249700,Automotive audio bus (A2B): status-amount_of_nodes,2,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant (challenge response only),
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,1,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 31,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14715-MAS18871,Acoustic test of loudspeakers: status-Current channel,OFF,
IDE14715-MAS18921,Acoustic test of loudspeakers: status-Current loudspeaker,Not available,
IDE14733-MAS00106,SDARS subscription status-Year,2000,
IDE14733-MAS00107,SDARS subscription status-Month,0, Months
IDE14733-MAS00108,SDARS subscription status-Day,Not available,
IDE14733-MAS00109,SDARS subscription status-Hours,0, H
IDE14733-MAS00110,SDARS subscription status-Minutes,0, min
IDE14733-MAS00111,SDARS subscription status-Seconds,0, s
IDE14733-MAS10690,SDARS subscription status-Activation condition,not active,
IDE14733-MAS19035,SDARS subscription status-Procedure status,not expired,
IDE14733-MAS19036,SDARS subscription status-Expiration warning,0,
IDE14734-MAS01766,SDARS Service Status-Traffic data,not active,
IDE14734-MAS19037,SDARS Service Status-Audio Service,not active,
IDE14734-MAS19040,SDARS Service Status-Travel link,not active,
IDE14743-MAS01167,Control panel simulation of button key codes-Actuation time,0 s,
IDE14743-ENG170421,Control panel simulation of button key codes-IoReached Status,Output diagnostic test not active,
MAS00778-IDE03619,Multimedia System 1-System condition,On,
MAS00778-IDE05228,Multimedia System 1-Operating hour counter,36, H
MAS00778-MAS00110,Multimedia System 1-Minutes,24, min
MAS00778-MAS01634,Multimedia System 1-Supply voltage,14.70, V
MAS00778-MAS02200,Multimedia System 1-Highest measured temperature,68, °C
MAS00778-MAS02201,Multimedia System 1-Temperature,42, °C
MAS00778-MAS03691,Multimedia System 1-Dimming,85, %
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,0,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Digital,
MAS01760-MAS02949,Radio Tuner 1-Frequency,0.00, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,0,
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,0,
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),0,
MAS01760-MAS19025,Radio Tuner 1-IBOC fault rate,0, %
MAS01760-MAS19026,Radio Tuner 1-IBOC audio signal:,Not available,
MAS01760-MAS19028,Radio Tuner 1-IBOC DRM Service,0,
MAS01760-MAS19030,Radio Tuner 1-IBOC DRM counter,OFF,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,32,
MAS03782-MAS17355,WLAN-MAC address 2: tethering,FE 84 A7 85 B4 CC,
MAS03782-MAS17356,WLAN-MAC address 1,FC 84 A7 85 B3 CC,
MAS03782-MAS17357,WLAN-MAC address 2,00 00 00 00 00 00,
MAS03782-MAS17559,WLAN-MAC address 1: tethering,FE 84 A7 85 24 B4,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,00 00 00 00,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1704,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via SWaP,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,BF FF,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
ENG117866-ENG117457,DAB_FM_linking-dab_mute_status,No,
ENG117866-ENG117456,DAB_FM_linking-DAB_quality,99, %
ENG117866-ENG117455,DAB_FM_linking-fm_quality,0, %
ENG117866-ENG117458,DAB_FM_linking-service_linking_status,no_link,
ENG249164-MAS09154,Proximity_Sensor_slider_1-Proximity sensor 1,No object in sector,
ENG249168-MAS01167,Remote_Seek_Activation_status-Actuation time,0 s,
ENG249168-ENG170421,Remote_Seek_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249169-MAS01167,Remote_Set_AF_status-Actuation time,0 s,
ENG249169-ENG170421,Remote_Set_AF_status-IoReached Status,Output diagnostic test not active,
ENG249170-MAS01167,Remote_Set_Concealment_Level_status-Actuation time,0 s,
ENG249170-ENG170421,Remote_Set_Concealment_Level_status-IoReached Status,Output diagnostic test not active,
ENG249171-MAS01167,Remote_Set_DAB_Announcement_status-Actuation time,0 s,
ENG249171-ENG170421,Remote_Set_DAB_Announcement_status-IoReached Status,Output diagnostic test not active,
ENG249172-MAS01167,Remote_Set_DAB_Default_status-Actuation time,0 s,
ENG249172-ENG170421,Remote_Set_DAB_Default_status-IoReached Status,Output diagnostic test not active,
ENG249173-MAS01167,Remote_Set_DAB_Linking_status-Actuation time,0 s,
ENG249173-ENG170421,Remote_Set_DAB_Linking_status-IoReached Status,Output diagnostic test not active,
ENG249174-MAS01167,Remote_Set_DAB_Mute_status-Actuation time,0 s,
ENG249174-ENG170421,Remote_Set_DAB_Mute_status-IoReached Status,Output diagnostic test not active,
ENG249175-MAS01167,Remote_Set_Hidden_Tune_status-Actuation time,0 s,
ENG249175-ENG170421,Remote_Set_Hidden_Tune_status-IoReached Status,Output diagnostic test not active,
ENG249176-MAS01167,Remote_Set_IBOC_Service_status-Actuation time,0 s,
ENG249176-ENG170421,Remote_Set_IBOC_Service_status-IoReached Status,Output diagnostic test not active,
ENG249177-MAS01167,Remote_Set_TP_status-Actuation time,0 s,
ENG249177-ENG170421,Remote_Set_TP_status-IoReached Status,Output diagnostic test not active,
ENG249178-MAS01167,Remote_Shift_Frequency_AM_Activation_status-Actuation time,0 s,
ENG249178-ENG170421,Remote_Shift_Frequency_AM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249179-MAS01167,Remote_Shift_Frequency_DAB_Activation_status-Actuation time,0 s,
ENG249179-ENG170421,Remote_Shift_Frequency_DAB_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249180-MAS01167,Remote_Shift_Frequency_FM_Activation_status-Actuation time,0 s,
ENG249180-ENG170421,Remote_Shift_Frequency_FM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249197-MAS01167,set_amfm_measurement_mode_status-Actuation time,0 s,
ENG249197-ENG170421,set_amfm_measurement_mode_status-IoReached Status,Output diagnostic test not active,
ENG249198-MAS01167,set_tuner_mode_status-Actuation time,0 s,
ENG249198-ENG170421,set_tuner_mode_status-IoReached Status,Output diagnostic test not active,
ENG249205-MAS01632,Status_Position_Touch_Slider_1-Status,operated,
ENG249205-ENG117402,Status_Position_Touch_Slider_1-calibrate_delta_x,0,
ENG249205-ENG117396,Status_Position_Touch_Slider_1-position_x1,0,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,Not operated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,0,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,0,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,0,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,0,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,0,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,0,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,0,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,0,
ENG117870-MAS00106,VICS_Infrared_Beacon_State-Year,2000,
ENG117870-MAS00107,VICS_Infrared_Beacon_State-Month,0,
ENG117870-MAS00108,VICS_Infrared_Beacon_State-Day,OFF,
ENG117870-MAS00109,VICS_Infrared_Beacon_State-Hours,0,
ENG117870-MAS00110,VICS_Infrared_Beacon_State-Minutes,0,
ENG117870-MAS00111,VICS_Infrared_Beacon_State-Seconds,0,
ENG117870-MAS01632,VICS_Infrared_Beacon_State-Status,Not available,
ENG117870-ENG117771,VICS_Infrared_Beacon_State-vics_id,0,
ENG117871-MAS00106,VICS_Radio_Beacon_State-Year,2000,
ENG117871-MAS00107,VICS_Radio_Beacon_State-Month,0,
ENG117871-MAS00108,VICS_Radio_Beacon_State-Day,0,
ENG117871-MAS00109,VICS_Radio_Beacon_State-Hours,0,
ENG117871-MAS00110,VICS_Radio_Beacon_State-Minutes,0,
ENG117871-MAS00111,VICS_Radio_Beacon_State-Seconds,0,
ENG117871-MAS01632,VICS_Radio_Beacon_State-Status,Not available,
ENG117871-ENG117771,VICS_Radio_Beacon_State-vics_id,0,
Elapsed Time: 00:41
blockmap-6C-5WA-980-556-D_VSSZZZKM2RR140480-20241020-1513.CSV
;SW:5WA-980-556-D   HW:5WA-980-556-B ---  Back-up Cam.
;Component:RV eCompact   H31 0364, Coding:04033200843000
;EV_CamSysRVCCompaFicos,010026,EV_CamSysRVCCompaFicos_010_VW38.rod
;Sunday,20,October,2024,15:13:11:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 52FAA38884636DAAB9F-8006
Group,Description,Actual
IDE00019,Voltage terminal 30,14.37, V
IDE00303-MAS00222,Status: doors/lids 1-Rear lid,closed,
IDE00303-MAS01374,Status: doors/lids 1-Trailer,not detected,
IDE00924-IDE08941,Steering angle-Rack position,0.00,
IDE00924-MAS02471,Steering angle-Sign,Negative,
IDE00924-MAS02983,Steering angle-Steering wheel angle,6.5,
IDE00924,Steering angle,0.4000,
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,0.00,
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE06449-MAS05746,Camera system calibration-Rearview camera calibration status,Calibration ended,
IDE06449-MAS05748,Camera system calibration-Rearview camera calibration progress,0, %
IDE06449-MAS05750,Camera system calibration-Rearview camera calibration repeat attempts,0,
IDE06449-MAS05753,Camera system calibration-Cause of rearview camera calibration error,calibrated,
IDE06449-MAS05803,Camera system calibration-Rearview camera calibration resumption,No resumption,
IDE07402-MAS10858,External activation-Rear camera,not active,
IDE10589-MAS10858,Temperature of the camera-Rear camera,37, °C
IDE10740-IDE03619,System state area view-System condition,active,
IDE10779,Ethernet signal quality,good: link available,
IDE10780-MAS11932,Ethernet counter connection interruptions-Counter open circuit,0, dB
IDE10781-MAS11933,Ethernet counter checksum malfunction-Counter CRC error,0, dB
IDE11010-MAS00106,Rear camera: calibration time-Year,2024, yr
IDE11010-MAS00107,Rear camera: calibration time-Month,1, Months
IDE11010-MAS00108,Rear camera: calibration time-Day,28, d
IDE11010-MAS00109,Rear camera: calibration time-Hours,12, H
IDE11010-MAS00110,Rear camera: calibration time-Minutes,35, min
IDE11010-MAS00111,Rear camera: calibration time-Seconds,0, s
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE12625,IP network: current link deceleration: branch 1,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,-1e+007,
IDE13845,Production mode status,No function restriction,
MAS02356-MAS10858,Type of calibration-Rear camera,TopView: calibration with calibration panel,
Elapsed Time: 00:05
blockmap-75-5WA-035-284-F_VSSZZZKM2RR140480-20241020-1513.CSV
;SW:5WA-035-284-F   HW:5WA-035-284-C ---  Telematics
;Component:OCU3HMQB37W   H14 0144, Coding:043160009068A8209005460061402E07
;EV_OCU3HMQB37W,002012,EV_OCU3HMQB37W_002_VW38.rod
;Sunday,20,October,2024,15:13:23:49859
;VCID: 49C884E469352E72C85-801C
IDE00019,Voltage terminal 30,14.5, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,45, °C
IDE00608,Fuel type,Gas,
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button -E450-,Not available,
IDE00767,No. of unscheduled ECU resets,0,
IDE01215,Dimmer terminal 58d,94.09, %
IDE01216,Dimmer terminal 58s,100, %
IDE01588,Driving direction,0, °
IDE01588-MAS01632,Driving direction-Status,available.,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01630-MAS01167,Key illumination in telephone operating unit-Actuation time,0 s,
IDE01630-ENG170421,Key illumination in telephone operating unit-IoReached Status,Output diagnostic test not active,
IDE01631-MAS01167,Output of variable test tones via radio/radio navigation system-Actuation time,0 s,
IDE01631-ENG170421,Output of variable test tones via radio/radio navigation system-IoReached Status,Output diagnostic test not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS02230,GPS Position-Height,32, m
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,26, mA
IDE01971,Lowest recorded control module temperature,3, °C
IDE01972,Highest recorded control module temperature,61, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,39, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,100, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,5,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,13,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,14,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,15,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,34, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,45, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,47, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,47, dBµV
IDE03477-MAS00110,GPS time-Minutes,13,
IDE03477-MAS00111,GPS time-Seconds,26,
IDE04293,Operating state for emer call module,registerstate_searching,
IDE04750-MAS03876,SIM card-active SIM card,internal,
IDE04750-MAS03878,SIM card-SIM IMSI,901280016652528,
IDE04750-MAS04226,SIM card-Telephone number,               ,
IDE04750-MAS08401,SIM card-SIM intern,operational,
IDE04750-MAS08402,SIM card-SIM extern,Unknown,
IDE04750-MAS11003,SIM card-ICCID,89882390000795554362,
IDE04750-MAS11004,SIM card-UICCID,89033023312150000000036101342155,
IDE04790,Call for help button,Not operated,
IDE05430,Telephone serial number,353775369534862,
IDE05431-MAS01167,Lock for high-voltage charging connector-Actuation time,0 s,
IDE05431-ENG170421,Lock for high-voltage charging connector-IoReached Status,Output diagnostic test not active,
IDE07007-MAS01167,Air conditioning/heating function via remote control-Actuation time,0 s,
IDE07007-ENG170421,Air conditioning/heating function via remote control-IoReached Status,Output diagnostic test not active,
IDE07543,Vehicle speed,0.00, km/h
IDE07589-IDE07590,Update programming: status-Currently processed module,26,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,28,
IDE07589-MAS00106,Update programming: status-Year,2021,
IDE07589-MAS00107,Update programming: status-Month,12,
IDE07589-MAS00108,Update programming: status-Day,15,
IDE07589-MAS00109,Update programming: status-Hours,6,
IDE07589-MAS00110,Update programming: status-Minutes,54,
IDE07589-MAS00111,Update programming: status-Seconds,4,
IDE07911-MAS01167,Microphone signal via audio output-Actuation time,0 s,
IDE07911-ENG170421,Microphone signal via audio output-IoReached Status,Output diagnostic test not active,
IDE07975-MAS01167,Remote control for charging function of high-voltage battery-Actuation time,0 s,
IDE07975-ENG170421,Remote control for charging function of high-voltage battery-IoReached Status,Output diagnostic test not active,
IDE08156-MAS01167,Transmission of configuration for online services-Actuation time,0 s,
IDE08156-ENG170421,Transmission of configuration for online services-IoReached Status,Output diagnostic test not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,6, s
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 05 73 00 00 00 00 00 0C 03 00 3C,
IDE08343,Immobilizer Challenge,BC 63 2A DA,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,electrically OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,38, µA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,100, %
IDE09602-MAS01167,Locale hazard warning-Actuation time,0 s,
IDE09602-ENG170421,Locale hazard warning-IoReached Status,Output diagnostic test not active,
IDE10300,OBD Driving Cycle detected,active,
IDE11307-IDE01839,eCall battery status-Battery charge level,91, %
IDE11307-MAS08415,eCall battery status-Battery status,normal,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FE 80 00 00 00 00 00 00 32 0E B8 FF FE CB DB 2D|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67|FD 53 7C B8 03 83 00 07 00 00 00 00 00 00 00 67|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 00|FF 02 00 00 00 00 00 00 00 00 00 01 FF CB DB 2D|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 67|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|4|7|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,65535,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|30 0E B8 CB DB 2D|,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|44 20 63 02 4D E2|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|4|7|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,65535,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12732,Button for ERA/Glonass test,Not available,
IDE13159-MAS01167,Loudspeaker test for emergency call module-Actuation time,0 s,
IDE13159-ENG170421,Loudspeaker test for emergency call module-IoReached Status,Output diagnostic test not active,
IDE13593-MAS07135,Emergency call SIM profile-Activation status,not activated,
IDE13593-MAS07967,Emergency call SIM profile-profile,Not available,
IDE13593-MAS11003,Emergency call SIM profile-ICCID,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,17,
IDE13957-MAS00106,Mobile Online Service: connection status-Year,2024, yr
IDE13957-MAS00107,Mobile Online Service: connection status-Month,9, Months
IDE13957-MAS00108,Mobile Online Service: connection status-Day,10, d
IDE13957-MAS00109,Mobile Online Service: connection status-Hours,10, H
IDE13957-MAS00110,Mobile Online Service: connection status-Minutes,12, min
IDE13957-MAS00111,Mobile Online Service: connection status-Seconds,53, s
IDE13957-MAS00976,Mobile Online Service: connection status-Counter,0,
IDE13957-MAS07131,Mobile Online Service: connection status-ID steps,0,
IDE13957-MAS07132,Mobile Online Service: connection status-Code status,30,
IDE13957-MAS16770,Mobile Online Service: connection status-Year (UTC: universal time coordinated),2024, yr
IDE13957-MAS16772,Mobile Online Service: connection status-Month (UTC: universal time coordinated),9, Months
IDE13957-MAS16773,Mobile Online Service: connection status-Day (UTC: universal time coordinated),10, d
IDE13957-MAS16774,Mobile Online Service: connection status-Hour (UTC: universal time coordinated),10, H
IDE13957-MAS16775,Mobile Online Service: connection status-Minute (UTC: universal time coordinated),12, min
IDE13957-MAS16776,Mobile Online Service: connection status-Seconds (UTC: universal time coordinated),53, s
IDE13957-ENG151979,Mobile Online Service: connection status-Server_HTTP_Status_Code_Textual,Data connection established,
IDE13958-MAS00106,Mobile Online Service: service status-Year,2255, yr
IDE13958-MAS00107,Mobile Online Service: service status-Month,255, Months
IDE13958-MAS00108,Mobile Online Service: service status-Day,255, d
IDE13958-MAS00109,Mobile Online Service: service status-Hours,255, H
IDE13958-MAS00110,Mobile Online Service: service status-Minutes,255, min
IDE13958-MAS00111,Mobile Online Service: service status-Seconds,255, s
IDE13958-MAS07134,Mobile Online Service: service status-ID services,cc_breakdown_v2,
IDE13958-MAS07135,Mobile Online Service: service status-Activation status,activated,
IDE13958-MAS07136,Mobile Online Service: service status-Exp. year,2023, yr
IDE13958-MAS07137,Mobile Online Service: service status-Exp. month,9, Months
IDE13958-MAS07138,Mobile Online Service: service status-Exp. day,10, d
IDE13958-MAS16770,Mobile Online Service: service status-Year (UTC: universal time coordinated),2255, yr
IDE13958-MAS16772,Mobile Online Service: service status-Month (UTC: universal time coordinated),255, Months
IDE13958-MAS16773,Mobile Online Service: service status-Day (UTC: universal time coordinated),255, d
IDE13958-MAS16774,Mobile Online Service: service status-Hour (UTC: universal time coordinated),255, H
IDE13958-MAS16775,Mobile Online Service: service status-Minute (UTC: universal time coordinated),255, min
IDE13958-MAS16776,Mobile Online Service: service status-Seconds (UTC: universal time coordinated),255, s
IDE13958-ENG246084,Mobile Online Service: service status-status_last_fail,65535,
IDE13958-ENG246255,Mobile Online Service: service status-status_last_ok,65535,
IDE13958-ENG246120,Mobile Online Service: service status-status_second_last_fail,65535,
IDE13958-ENG246279,Mobile Online Service: service status-status_second_last_ok,65535,
IDE14344-MAS18506,Automotive audio bus (A2B): status-Node name,Microphone module in roof,
IDE14344-MAS18507,Automotive audio bus (A2B): status-Node number,0,
IDE14344-MAS18509,Automotive audio bus (A2B): status-Node status,electrically OK,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 00 00 00 00 00 00 00,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2F,
IDE15695,Front radar-based localization,not active,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,73,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00106,Standard - ambient data 1-Year,2024,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,20,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,12,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,30,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,57,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,1626, km
MAS01490-MAS08403,Energy management-Remaining short term energy budget,539, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,140,
MAS03615-MAS01167,Connection setup-Actuation time,0 s,
MAS03615-ENG170421,Connection setup-IoReached Status,Output diagnostic test not active,
MAS04394-IDE03580,Connection status-Country recognition for mobile network,234,
MAS04394-IDE07699,Connection status-Mobile network operator,15,
MAS04394-MAS03991,Connection status-Reception level antenna 1,100, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,Not available,
MAS04394-MAS08407,Connection status-Data connection,not active,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,30177,
MAS04394-ENG123308,Connection status-TCP_Connection_State,not active,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08200,Emergency call speaker status,electrically OK,
MAS08374-MAS01167,Remote control for lights and horn-Actuation time,0 s,
MAS08374-ENG170421,Remote control for lights and horn-IoReached Status,Output diagnostic test not active,
MAS10430,Indicator light for emerg. call,Emergency call function available,
MAS13076-MAS12732,Error valid: error path traversed-Dataset download,full working order,
MAS13076,Error valid: error path traversed,Active diagnosis,
MAS16678-MAS01167,Test mode for emergency call-Actuation time,0 s,
MAS16678-ENG170421,Test mode for emergency call-IoReached Status,Output diagnostic test not active,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,Support from metadata version 0x10,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 19,
MAS18223-ENG299118,History of sent driver assistance data-beginn array,|ID,Number|0
MAS18223-ENG104031,History of sent driver assistance data-Number,0,
MAS18224-ENG299118,History of causes for sent driver assistance data-beginn array,|ID,Number|0
MAS18224-ENG104031,History of causes for sent driver assistance data-Number,0,
MAS18225-ENG98987,Transmission delay for driver assistance data-Time,0, ms
MAS18226-MAS01167,Sending the driver assistance data-Actuation time,0 s,
MAS18226-ENG170421,Sending the driver assistance data-IoReached Status,Output diagnostic test not active,
MAS18461-MAS18463,FoD product list-Product number,0,
MAS18461-MAS18464,FoD product list-Function ID,
MAS18461-MAS18465,FoD product list-Import regulation,No Info,
MAS18461-MAS18471,FoD product list-Product regulation,No Info,
MAS18461-MAS18474,FoD product list-Change information regulation,No Info,
MAS18461-MAS18477,FoD product list-Notification control,No Info,
MAS18461-MAS18481,FoD product list-Activate regulation,No Info,
MAS18461-MAS18484,FoD product list-Deactivate regulation,No Info,
MAS18461-MAS18487,FoD product list-Warning interval,0,
MAS18461-MAS18488,FoD product list-additional meta info 1,00,
MAS18461-MAS18489,FoD product list-additional meta info 2,00,
MAS18490-IDE06260,Read FoD assignment products on FSIDs-ID number,00 00 00 00,
MAS18490-MAS18463,Read FoD assignment products on FSIDs-Product number,0,
MAS18799-MAS01167,Radio / radio navigation system muting test-Actuation time,0 s,
MAS18799-ENG170421,Radio / radio navigation system muting test-IoReached Status,Output diagnostic test not active,
MAS18800,Version of audio dataset used,YH04,
MAS19234,Status of user-related refresh tokens,invalid,
MAS19235,Back end (MBB) active user ID,#anonymousGuest#              ,
MAS19236-MAS00106,Expiration date of user-related refresh tokens-Year,2000,
MAS19236-MAS00107,Expiration date of user-related refresh tokens-Month,0,
MAS19236-MAS00108,Expiration date of user-related refresh tokens-Day,0,
MAS19237,Status of user-related safety pin in vehicle,locked,
MAS19245-MAS19246,Safety mode-Safety mode status,OFF,
MAS19247-MAS19256,Authentication stage-User-related instantaneous authentication stage,0,
MAS19248-MAS19257,User role-User role for active user,Main user,
MAS19255-MAS19238,Status of user image for current user-Image reference value,00 00,
MAS19270,Parameter list,|Parameter ID,Data description
MAS19273,Shadow drive metadata,|User ID,Year
MAS19295,Historical memory for synchronization,Write only channel,
MAS19313,BAP historical memory,|Year,Month
MAS19326,CAN signals for OCU customization,|Year,Month
ENG123206,Antenna_Switch,LTE antenna 1,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,186,
ENG186123-ENG187669,Authentic_time_last_client_response-Current_time_used,1970-01-01T00:00:00Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,1970-01-01T00:00:00Z,
ENG254564-ENG255490,Backup_Battery_SoH-BUB_ci,79.550,
ENG254564-ENG256057,Backup_Battery_SoH-mcharge_time,0, s
ENG254564-ENG256085,Backup_Battery_SoH-mSoH,100,
ENG254564-ENG256302,Backup_Battery_SoH-rSoH,98,
ENG247784-ENG118139,Hazard_Information-function_state,State_0,
ENG125913,Hybrid_Type,no_Hybrid_Car,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,0.0.0.0,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,11568,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,14128,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,No malfunction,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,4100, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,12601,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,Malfunction,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,14896,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,No malfunction,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,0,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,12336,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,12346,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,14896,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,12336,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,11568,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,0,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,12628,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,48,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,12334,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,No malfunction,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,12378,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,23040, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,Malfunction,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,805306368, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,47616,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,808333358, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,Malfunction,
ENG245690,OCU_Internal_Status_Field,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123204,Outgoing_call_line_state,Idle,
ENG247809,Position_Confidence,35, m
ENG247810-ENG248070,REM_Available_Transmission_Buffer-Buffer,0, KByte
ENG247811-ENG98502,REM_Development_Interface-Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 16 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 16 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 18 03 00 00 62 16 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG157421-MAS04460,Scan_Network_List-Validity,valid,
ENG157421-MAS08406,Scan_Network_List-Network type,LTE,
ENG157421-MAS08406,Scan_Network_List-Network type,GSM,
ENG157421-MAS08406,Scan_Network_List-Network type,UMTS,
ENG157421-ENG159652,Scan_Network_List-Mobile_Country_Code,234,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,30,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,20,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,15,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,32,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,10,
ENG247812-ENG159329,Second_Last_Position-Latitude,53°37'11.2"N,
ENG247812-ENG159328,Second_Last_Position-Longitude,  0°19'8.7"W  ,
ENG247822-ENG159329,Third_Last_Position-Latitude,53°37'9.6"N,
ENG247822-ENG159328,Third_Last_Position-Longitude,  0°19'8.6"W  ,
ENG254851-MAS01779,VTT_First_GPS_fix-Length,---           ,
ENG254851-MAS01780,VTT_First_GPS_fix-Width,---           ,
ENG254851-MAS02230,VTT_First_GPS_fix-Height,65034, m
Elapsed Time: 01:18
blockmap-A5-5WA-980-653-D_VSSZZZKM2RR140480-20241020-1515.CSV
;SW:5WA-980-653-D   HW:5WA-980-653 ---  Frt Sens. Drv. Assist
;Component:MQB MFK 3.0   H12 3405, Coding:000309082148C040409E00801020002000018000000000000000000000000000
;EV_MFK3ValeoMQB,005055,EV_MFK3ValeoMQB_005_AU38.rod
;Sunday,20,October,2024,15:15:18:49859
;VCID: 50FEA9808A6F1FBA8FB-8004
IDE00018,Voltage terminal 15,14.6, V
IDE00973,Outside temperature,15.0, °C
IDE01968,Dynamic calibration: yaw angle offset,-0.078, °
IDE01969,Dynamic calibration: pitch angle offset,-0.314, °
IDE01970,Dynamic calibration: roll angle offset,-0.076, °
IDE01971,Lowest recorded control module temperature,5, °C
IDE01972,Highest recorded control module temperature,70, °C
IDE01974-MAS01167,Steering wheel vibration-Actuation time,Write only channel,
IDE01974-MAS08863,Steering wheel vibration-Status of actuator test,Write only channel,
IDE02007-MAS01167,Yellow indicator light for directional stabilization assistance-Actuation time,Write only channel,
IDE02007-MAS08863,Yellow indicator light for directional stabilization assistance-Status of actuator test,Write only channel,
IDE02008-MAS01167,Green indicator light for directional stabilization assistance-Actuation time,Write only channel,
IDE02008-MAS08863,Green indicator light for directional stabilization assistance-Status of actuator test,Write only channel,
IDE02009-MAS01167,Directional stabilization assistance display-Actuation time,Write only channel,
IDE02009-MAS08863,Directional stabilization assistance display-Status of actuator test,Write only channel,
IDE02057,Dynamic calibration: status,Passive values stored,
IDE02486,Data logger triggering,not initialized,
IDE02608-MAS01167,Window defogger for front sensor system-Actuation time,Write only channel,
IDE02608-MAS08863,Window defogger for front sensor system-Status of actuator test,Write only channel,
IDE03222-MAS02534,Blindness detection-Clear view,No,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS17450,Blindness detection-Blindness: space detection,No,
IDE03222-MAS17452,Blindness detection-Windshield heater blindness request,No,
IDE03222-MAS17453,Blindness detection-Clear view currently detected,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,533, km
IDE03948-MAS01167,High beam recommendation-Actuation time,Write only channel,
IDE03948-MAS08863,High beam recommendation-Status of actuator test,Write only channel,
IDE04036-MAS01632,High beam assistant: status-Status,not active,
IDE04036-MAS17492,High beam assistant: status-Switching state,OFF,
IDE04036-MAS17493,High beam assistant: status-Sensor view,Not assigned,
IDE04036-MAS17494,High beam assistant: status-Higher sensitivity active,No,
IDE04123-MAS01480,High beam: reason for shut-off-excessive temperature,No,
IDE04123-MAS06833,High beam: reason for shut-off-Ambient brightness too high,No,
IDE04123-MAS06846,High beam: reason for shut-off-Location detected,No,
IDE04123-MAS14875,High beam: reason for shut-off-Fog detected,No,
IDE04123-MAS17489,High beam: reason for shut-off-Oncoming vehicle detected,No,
IDE04123-MAS17490,High beam: reason for shut-off-Vehicle ahead detected,No,
IDE04123-MAS17491,High beam: reason for shut-off-Speed not achieved,Yes,
IDE04123,High beam: reason for shut-off,4,
IDE04123,High beam: reason for shut-off,0,
IDE04227,Directional stab. asst w/ pwr steering asst: steering status,Lane assist deactivated in steering,
IDE04229,Directional stab. asst w/ pwr steering asst: steering torque,-0.00, Nm
IDE04904-MAS01167,Traffic sign display in instrument cluster-Actuation time,Write only channel,
IDE04904-MAS08863,Traffic sign display in instrument cluster-Status of actuator test,Write only channel,
IDE06592-MAS00478,Status: special functions-Reserved,00,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,used,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE07214,Dynamic calibration: camera height offset,-36, mm
IDE09433-MAS01632,Perception module for light assistant-Status,Deactivated,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,1023, m
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,1023, m
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,25.650001, °
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,25.650001, °
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,35.150001, °
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,35.150001, °
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,51.15, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,51.15, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,Not available,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,Not available,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,Not available,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,Not available,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,active,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Right hand driv.,
IDE09492-MAS11790,Temperatures-Control Module temperature,42, °C
IDE09492-MAS17447,Temperatures-Temperature of the EyeQ chip,47, °C
IDE09492-MAS17448,Temperatures-Temperature of the memory in the EyeQ chip,44, °C
IDE09492-MAS17449,Temperatures-High temperature shutdown,OFF,
IDE10220,Initial online calibration active,not active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,0.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,0.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,0.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,0.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.000, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,0.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,0.000, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,0.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,0.000, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,0.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1200, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,0.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0,
IDE10406-MAS00106,Last initial calibrations: details-Year,2024,
IDE10406-MAS00107,Last initial calibrations: details-Month,5,
IDE10406-MAS00108,Last initial calibrations: details-Day,28,
IDE10406-MAS00109,Last initial calibrations: details-Hours,12,
IDE10406-MAS00110,Last initial calibrations: details-Minutes,17,
IDE10406-MAS00111,Last initial calibrations: details-Seconds,56,
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2024,
IDE10664-MAS00107,Current initial calibration: details-Month,5,
IDE10664-MAS00108,Current initial calibration: details-Day,28,
IDE10664-MAS00109,Current initial calibration: details-Hours,12,
IDE10664-MAS00110,Current initial calibration: details-Minutes,17,
IDE10664-MAS00111,Current initial calibration: details-Seconds,56,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,0,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,VSSZZZKM2RR140480,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE10924-MAS02479,Initial calibration: result-Yaw angle,0.395, °
IDE10924-MAS05286,Initial calibration: result-Roll angle,0.183, °
IDE10924-MAS05287,Initial calibration: result-Pitch angle,-1.106, °
IDE10924-MAS10678,Initial calibration: result-Camera height,1367, mm
IDE11752-ENG277500,IP network: IPv6-addresses-Ip_ipv6_addresses_list,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 4F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|, hex
IDE11753-ENG277501,IP network: IPv6-multicast-addresses-Ip_ipv6_multicast_addresses_list,|IPv6 Multicast address|FF 14 00 00 00 0B|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11755-ENG277505,IP network: VLANs-Ip_vlans_list,|VLAN|2|0|0|0|0|0|0|0|0|0|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,256,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,256,
IDE11761-ENG277502,IP network: MAC addresses-Ip_mac_addresses_list,|MAC address|74 90 50 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11869-ENG277503,IP network: NDP cache-Ip_ndp_cache_list,|MAC address,IPv6 address
IDE11988-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 1-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|74 90 50 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11989-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 2-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11990-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 3-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11991-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 4-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11992-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 5-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11993-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 6-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11994-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 7-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11995-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 8-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE12230-ENG277505,IP network: VLANs of Ethernet switch ports branch 1-Ip_vlans_list,|VLAN|2|0|0|0|0|0|0|0|0|0|,
IDE12231-ENG277505,IP network: VLANs of Ethernet switch ports branch 2-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12232-ENG277505,IP network: VLANs of Ethernet switch ports branch 3-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12233-ENG277505,IP network: VLANs of Ethernet switch ports branch 4-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12234-ENG277505,IP network: VLANs of Ethernet switch ports branch 5-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12235-ENG277505,IP network: VLANs of Ethernet switch ports branch 6-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12236-ENG277505,IP network: VLANs of Ethernet switch ports branch 7-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12237-ENG277505,IP network: VLANs of Ethernet switch ports branch 8-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12239-ENG277504,IP network: test feedback value of communications relationships-Ip_return_value_test_communication_connection,|IPv6 address,Result|02 FD 53 7C B8 03 83 02 00 00 00 00 00 00 00 00
IDE12626,IP network: current link deceleration: branch 2,0, µs
IDE12627,IP network: current link deceleration: branch 3,0, µs
IDE12628,IP network: current link deceleration: branch 4,0, µs
IDE12629,IP network: current link deceleration: branch 5,0, µs
IDE12630,IP network: current link deceleration: branch 6,0, µs
IDE12631,IP network: current link deceleration: branch 7,0, µs
IDE12632,IP network: current link deceleration: branch 8,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,Not available,
IDE13994-MAS17458,Intrinsic calibration: result-Main point x,645.20, px
IDE13994-MAS17463,Intrinsic calibration: result-Main point y,555.32, px
IDE13994-MAS17464,Intrinsic calibration: result-Focal length x,1461.91, px
IDE13994-MAS17465,Intrinsic calibration: result-Focal length y,1461.91, px
IDE13994-MAS17466,Intrinsic calibration: result-Distortion in k1,-0.000468891,
IDE13994-MAS17467,Intrinsic calibration: result-Distortion in k2,-0.000363679,
IDE13994-MAS17468,Intrinsic calibration: result-Distortion in k3,-0.000638848,
IDE13994-MAS17469,Intrinsic calibration: result-Distortion in t1,-0.000000000,
IDE13994-MAS17470,Intrinsic calibration: result-Distortion in t2,-0.000000000,
IDE13994-MAS17471,Intrinsic calibration: result-Gamma,1.00,
IDE13994-MAS17472,Intrinsic calibration: result-Incline,0.00, px
IDE13995-MAS08824,Calibration target position: stored values-Target 1: calibration mark 1: x-coordinate,2400.00, mm
IDE13995-MAS08825,Calibration target position: stored values-Target 1: calibration mark 1: y-coordinate,733.00, mm
IDE13995-MAS08826,Calibration target position: stored values-Target 1: calibration mark 1: z-coordinate,1694.00, mm
IDE13995-MAS08827,Calibration target position: stored values-Target 1: calibration mark 2: x-coordinate,2400.00, mm
IDE13995-MAS08828,Calibration target position: stored values-Target 1: calibration mark 2: y-coordinate,-733.00, mm
IDE13995-MAS08829,Calibration target position: stored values-Target 1: calibration mark 2: z-coordinate,1694.00, mm
IDE13995-MAS08830,Calibration target position: stored values-Target 1: calibration mark 3: x-coordinate,2400.00, mm
IDE13995-MAS08831,Calibration target position: stored values-Target 1: calibration mark 3: y-coordinate,733.00, mm
IDE13995-MAS08832,Calibration target position: stored values-Target 1: calibration mark 3: z-coordinate,1106.00, mm
IDE13995-MAS08833,Calibration target position: stored values-Target 1: calibration mark 4: x-coordinate,2400.00, mm
IDE13995-MAS08834,Calibration target position: stored values-Target 1: calibration mark 4: y-coordinate,-733.00, mm
IDE13995-MAS08835,Calibration target position: stored values-Target 1: calibration mark 4: z-coordinate,1106.00, mm
IDE13996-IDE05717,Axle offset: stored values-Front axle transverse position,0.3, mm
IDE13996-IDE05718,Axle offset: stored values-Rear axle transverse position,0.4, mm
IDE13997-IDE02001,Body height to wheel house edge: stored values-Body height left front wheel house edge,764.00, mm
IDE13997-IDE02002,Body height to wheel house edge: stored values-Body height right front wheel house edge,767.50, mm
IDE13997-IDE02003,Body height to wheel house edge: stored values-Body height left rear wheel house edge,766.00, mm
IDE13997-IDE02004,Body height to wheel house edge: stored values-Body height right rear wheel house edge,769.50, mm
IDE13998,Distance to calibration field: stored values,1500.00, mm
IDE14000,Windshield defogger camera: activation status,OFF,
MAS01634-MAS09193,Supply voltage-PLA,14.6, V
MAS01634-MAS17440,Supply voltage-Supply voltage 1V0,1.0, V
MAS01634-MAS17441,Supply voltage-Supply voltage 1V1,1.1, V
MAS01634-MAS17442,Supply voltage-Supply voltage 1V2,0.0, V
MAS01634-MAS17443,Supply voltage-Supply voltage 1V25,1.2, V
MAS01634-MAS17444,Supply voltage-Supply voltage 1V8,1.8, V
MAS01634-MAS17445,Supply voltage-Supply voltage 3V3,3.2, V
MAS01634-MAS17446,Supply voltage-Supply voltage 5V0,4.1, V
MAS11502-MAS10691,Self-glare recognition-Self-glare quality,0, %
MAS11502-MAS11503,Self-glare recognition-Self-glare status,active,
MAS11502-MAS15965,Self-glare recognition-Glare detected,No,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17473,Functional state and lane boundary information,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,available.,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 0E 0F 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,available.,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,2,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS19593-MAS01167,Upload for expanded static navigation data activation-Actuation time,Write only channel,
MAS19593-MAS08863,Upload for expanded static navigation data activation-Status of actuator test,Write only channel,
MAS19594-MAS01167,Upload for expanded dynamic navigation data activation-Actuation time,Write only channel,
MAS19594-MAS08863,Upload for expanded dynamic navigation data activation-Status of actuator test,Write only channel,
ENG152732-MAS06854,CRC32 Checksum of FAZIT Identification String-Version,81,
ENG152732-MAS06855,CRC32 Checksum of FAZIT Identification String-Test sum,89 C2 0C 52,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,2,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,2,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG179902-ENG247044,Function_On_Demand_Freischalt_ID_Status_Dev-Function_On_Demand_Freischalt_ID_Status,|Authentication,Functions
ENG106922,Immobilizer - Challenge,25 0D C5 47,
ENG185847-MAS01167,Light_assist_blockage_detection-Actuation time,Write only channel,
ENG185847-MAS08863,Light_assist_blockage_detection-Status of actuator test,Write only channel,
ENG185858-MAS01167,Light_assist_self_glare_detection-Actuation time,Write only channel,
ENG185858-MAS08863,Light_assist_self_glare_detection-Status of actuator test,Write only channel,
ENG185848-MAS01167,Main_beam_defect_message-Actuation time,Write only channel,
ENG185848-MAS08863,Main_beam_defect_message-Status of actuator test,Write only channel,
ENG251654-MAS01167,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Actuation time,Write only channel,
ENG251654-MAS08863,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Status of actuator test,Write only channel,
ENG251655-MAS01167,REM_Static_EyeQ_Data_Test_Trigger_status-Actuation time,Write only channel,
ENG251655-MAS08863,REM_Static_EyeQ_Data_Test_Trigger_status-Status of actuator test,Write only channel,
ENG185865-MAS01167,SAE_mode_activation-Actuation time,Write only channel,
ENG185865-MAS08863,SAE_mode_activation-Status of actuator test,Write only channel,
Elapsed Time: 00:46
blockmap-D6-992-941-571-AG_VSSZZZKM2RR140480-20241020-1516.CSV
;SW:992-941-571-AG   HW:992-941-571-A ---  Light Ctrl Left 2
;Component:LED1L         H17 9104, Coding:
;EV_LLPGen3LKEBODPO68X,002003,EV_LLPGen3LKEBODPO68X_002_VW27.rod
;Sunday,20,October,2024,15:16:21:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 678C625C1FE1F802FE1-8032
Group,Description,Actual
IDE00102-MAS02201,Control Module temperature-Temperature,34, °C
IDE08742-MAS07015,Operating time-Running light,0.00, H
IDE08742-MAS07234,Operating time-Eco mode 1,19.62, H
IDE08742-MAS07235,Operating time-Eco mode 2,0.00, H
IDE08742-MAS13654,Operating time-Auxiliary high beam,0.00, H
IDE08742-MAS14159,Operating time-Coming Home,0.00, H
IDE08742-MAS14160,Operating time-Leaving Home,0.00, H
IDE08742-MAS18763,Operating time-Headlight contour light,0.00, H
IDE08742,Operating time,0.00, H
IDE08742,Operating time,1.72, H
IDE08742,Operating time,11.81, H
IDE08742,Operating time,22.13, H
IDE08742,Operating time,45.55, H
IDE08742-ENG187666,Operating time-cornerlight,0.00, H
IDE08742-ENG255609,Operating time-designlight 2,0.00, H
IDE08742-ENG274345,Operating time-designlight 3,0.00, H
IDE08742-ENG351726,Operating time-designlight 4,0.00, H
IDE08742-ENG351657,Operating time-designlight 5,0.00, H
IDE08742-ENG247934,Operating time-Express light,0.00, H
IDE08742-ENG186523,Operating time-Highbeam,0.00, H
IDE08742-ENG186491,Operating time-Low beam,22.53, H
IDE08742-ENG166761,Operating time-Sidemarker,0.00, H
IDE08742-ENG166116,Operating time-Turn_indicator,1.97, H
IDE09770-MAS04136,High side channel 1-Current,0, mA
IDE09770-MAS09022,High side channel 1-PWM value,0.0, %
IDE09770-MAS09326,High side channel 1-Function,no function,
IDE09770-ENG186571,High side channel 1-Output,ERROR,
IDE09771-MAS04136,High side channel 2-Current,0, mA
IDE09771-MAS09022,High side channel 2-PWM value,0.0, %
IDE09771-MAS09326,High side channel 2-Function,no function,
IDE09771-ENG186571,High side channel 2-Output,ERROR,
IDE09772-MAS04136,High side channel 3-Current,0, mA
IDE09772-MAS09022,High side channel 3-PWM value,0.0, %
IDE09772-MAS09326,High side channel 3-Function,no function,
IDE09772-ENG186571,High side channel 3-Output,ERROR,
IDE09774-MAS02923,Number of activations-Highway light,0,
IDE09774-MAS07015,Number of activations-Running light,0,
IDE09774-MAS07234,Number of activations-Eco mode 1,894,
IDE09774-MAS07235,Number of activations-Eco mode 2,0,
IDE09774-MAS13654,Number of activations-Auxiliary high beam,0,
IDE09774-MAS14159,Number of activations-Coming Home,0,
IDE09774-MAS14160,Number of activations-Leaving Home,0,
IDE09774-ENG186684,Number of activations-All weather light,0,
IDE09774-ENG108961,Number of activations-Camera lock,0,
IDE09774-ENG186410,Number of activations-City light,0,
IDE09774-ENG186757,Number of activations-daytimerunning light,276,
IDE09774-ENG187759,Number of activations-design light,0,
IDE09774-ENG255609,Number of activations-designlight 2,0,
IDE09774-ENG274345,Number of activations-designlight 3,0,
IDE09774-ENG351726,Number of activations-designlight 4,0,
IDE09774-ENG351657,Number of activations-designlight 5,0,
IDE09774-ENG247934,Number of activations-Express light,0,
IDE09774-ENG187761,Number of activations-higbeam,34,
IDE09774-ENG186491,Number of activations-Low beam,209,
IDE09774-ENG186411,Number of activations-Parking light,0,
IDE09774-ENG186853,Number of activations-position light,534,
IDE09774-ENG166761,Number of activations-Sidemarker,0,
IDE09774-ENG186659,Number of activations-Static cornering light,0,
IDE09774-ENG186553,Number of activations-Tourist light,0,
IDE09774-ENG187378,Number of activations-turn indicator,917,
IDE09828,Head lamp variant,E0,
IDE09828-MAS16183,Head lamp variant-Headlamp coding variant via bus,E0,
IDE09828-MAS18770,Head lamp variant-Country version via data bus,ECE,
IDE09828-MAS18771,Head lamp variant-Headlamp coding variant 2 via bus,BE,
IDE09828-MAS18772,Head lamp variant-Headlamp coding variant 2 via control module,BE,
IDE09828-MAS23141,Head lamp variant-Country version via data record,ECE,
IDE09828-MAS30455,Head lamp variant-Variant comparison status,Finished and OK,
IDE10048-IDE00019,Supply information-Voltage terminal 30,14.4, V
IDE10048-MAS18767,Supply information-Voltage terminal 30G,0.0, V
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,25, °C
IDE10165-MAS04121,LED channel 1: Master 1-Voltage,0.00, V
IDE10165-MAS04136,LED channel 1: Master 1-Current,0, mA
IDE10165-MAS04625,LED channel 1: Master 1-Power: actual value,0, W
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,0.0, %
IDE10165-MAS09326,LED channel 1: Master 1-Function,Highbeam,
IDE10165-MAS09327,LED channel 1: Master 1-LED brightness class,LK2,
IDE10165-ENG186571,LED channel 1: Master 1-Output,LED,
IDE10167-MAS02201,LED channel 1: Slave-Temperature,200, °C
IDE10167-MAS04121,LED channel 1: Slave-Voltage,0.00, V
IDE10167-MAS04136,LED channel 1: Slave-Current,0, mA
IDE10167-MAS04625,LED channel 1: Slave-Power: actual value,0, W
IDE10167-MAS09022,LED channel 1: Slave-PWM value,0.0, %
IDE10167-MAS09326,LED channel 1: Slave-Function,no function,
IDE10167-MAS09327,LED channel 1: Slave-LED brightness class,Not Used,
IDE10167-ENG186571,LED channel 1: Slave-Output,ERROR,
IDE10168-MAS02201,LED channel 2: Master-Temperature,59, °C
IDE10168-MAS04121,LED channel 2: Master-Voltage,14.33, V
IDE10168-MAS04136,LED channel 2: Master-Current,720, mA
IDE10168-MAS04625,LED channel 2: Master-Power: actual value,11, W
IDE10168-MAS09022,LED channel 2: Master-PWM value,100.0, %
IDE10168-MAS09326,LED channel 2: Master-Function,DRL & PO,
IDE10168-MAS09327,LED channel 2: Master-LED brightness class,LK2,
IDE10168-ENG186571,LED channel 2: Master-Output,LED,
IDE10169-MAS02201,LED channel 2: Slave-Temperature,200, °C
IDE10169-MAS04121,LED channel 2: Slave-Voltage,0.00, V
IDE10169-MAS04136,LED channel 2: Slave-Current,0, mA
IDE10169-MAS04625,LED channel 2: Slave-Power: actual value,0, W
IDE10169-MAS09022,LED channel 2: Slave-PWM value,0.0, %
IDE10169-MAS09326,LED channel 2: Slave-Function,no function,
IDE10169-MAS09327,LED channel 2: Slave-LED brightness class,Not Used,
IDE10169-ENG186571,LED channel 2: Slave-Output,ERROR,
IDE10170-MAS02201,LED channel 3: Master-Temperature,200, °C
IDE10170-MAS04121,LED channel 3: Master-Voltage,1.67, V
IDE10170-MAS04136,LED channel 3: Master-Current,0, mA
IDE10170-MAS04625,LED channel 3: Master-Power: actual value,0, W
IDE10170-MAS09022,LED channel 3: Master-PWM value,0.0, %
IDE10170-MAS09326,LED channel 3: Master-Function,no function,
IDE10170-MAS09327,LED channel 3: Master-LED brightness class,Not Used,
IDE10170-ENG186571,LED channel 3: Master-Output,ERROR,
IDE10171-MAS02201,LED channel 3: Slave-Temperature,200, °C
IDE10171-MAS04121,LED channel 3: Slave-Voltage,0.00, V
IDE10171-MAS04136,LED channel 3: Slave-Current,0, mA
IDE10171-MAS04625,LED channel 3: Slave-Power: actual value,0, W
IDE10171-MAS09022,LED channel 3: Slave-PWM value,0.0, %
IDE10171-MAS09326,LED channel 3: Slave-Function,no function,
IDE10171-MAS09327,LED channel 3: Slave-LED brightness class,Not Used,
IDE10171-ENG186571,LED channel 3: Slave-Output,ERROR,
IDE10173,Operating times in temperature ranges,0.00, H
IDE10173,Operating times in temperature ranges,45.56, H
IDE10205,Control module version,MIN_MQB,
IDE11123-MAS04136,High side channel 4-Current,0, mA
IDE11123-MAS09022,High side channel 4-PWM value,0.0, %
IDE11123-MAS09326,High side channel 4-Function,no function,
IDE11123-ENG186571,High side channel 4-Output,ERROR,
IDE11124-ENG188404,Headlamp Range Control Motor-LWR__speed_adjustment,warm,
IDE11124-ENG188356,Headlamp Range Control Motor-LWR_fault_position,not active,
IDE11124-ENG187101,Headlamp Range Control Motor-LWR_motor_position_in_mm,-1.00, mm
IDE11124-ENG187107,Headlamp Range Control Motor-LWR_motor_position_in_percent,44.0, %
IDE11124-ENG188443,Headlamp Range Control Motor-LWR_reference_run,erfolgt,
IDE11918-MAS03378,Headlights production data-Supplier,              ,
IDE11918-ENG187298,Headlights production data-partnumber headlamp,              ,
IDE11918-ENG186473,Headlights production data-production date,              ,
IDE11918-ENG98897,Headlights production data-Serial number,              ,
IDE13678-MAS02201,LED channel 4: Master-Temperature,28, °C
IDE13678-MAS04121,LED channel 4: Master-Voltage,2.00, V
IDE13678-MAS04136,LED channel 4: Master-Current,0, mA
IDE13678-MAS04625,LED channel 4: Master-Power: actual value,0, W
IDE13678-MAS09022,LED channel 4: Master-PWM value,0.0, %
IDE13678-MAS09326,LED channel 4: Master-Function,lowbeam,
IDE13678-MAS09327,LED channel 4: Master-LED brightness class,LK2,
IDE13678-ENG186571,LED channel 4: Master-Output,LED,
IDE13897-MAS18765,Headlamp identification-Identification,ERROR,
IDE13898-MAS02201,LED channel 5: Master-Temperature,58, °C
IDE13898-MAS04121,LED channel 5: Master-Voltage,2.00, V
IDE13898-MAS04136,LED channel 5: Master-Current,0, mA
IDE13898-MAS04625,LED channel 5: Master-Power: actual value,0, W
IDE13898-MAS09022,LED channel 5: Master-PWM value,0.0, %
IDE13898-MAS09326,LED channel 5: Master-Function,turn indicator,
IDE13898-MAS09327,LED channel 5: Master-LED brightness class,LK1,
IDE13898-ENG186571,LED channel 5: Master-Output,LED,
IDE13899-MAS02201,LED channel 6: Master-Temperature,64, °C
IDE13899-MAS04121,LED channel 6: Master-Voltage,2.00, V
IDE13899-MAS04136,LED channel 6: Master-Current,0, mA
IDE13899-MAS04625,LED channel 6: Master-Power: actual value,0, W
IDE13899-MAS09022,LED channel 6: Master-PWM value,0.0, %
IDE13899-MAS09326,LED channel 6: Master-Function,no function,
IDE13899-MAS09327,LED channel 6: Master-LED brightness class,Not Used,
IDE13899-ENG186571,LED channel 6: Master-Output,ERROR,
IDE13900-MAS02201,LED channel 7: Master-Temperature,200, °C
IDE13900-MAS04121,LED channel 7: Master-Voltage,0.00, V
IDE13900-MAS04136,LED channel 7: Master-Current,0, mA
IDE13900-MAS04625,LED channel 7: Master-Power: actual value,0, W
IDE13900-MAS09022,LED channel 7: Master-PWM value,0.0, %
IDE13900-MAS09326,LED channel 7: Master-Function,no function,
IDE13900-MAS09327,LED channel 7: Master-LED brightness class,Not Used,
IDE13900-ENG186571,LED channel 7: Master-Output,ERROR,
IDE13901-MAS02201,LED channel 8: Master-Temperature,200, °C
IDE13901-MAS04121,LED channel 8: Master-Voltage,0.00, V
IDE13901-MAS04136,LED channel 8: Master-Current,0, mA
IDE13901-MAS04625,LED channel 8: Master-Power: actual value,0, W
IDE13901-MAS09022,LED channel 8: Master-PWM value,0.0, %
IDE13901-MAS09326,LED channel 8: Master-Function,no function,
IDE13901-MAS09327,LED channel 8: Master-LED brightness class,Not Used,
IDE13901-ENG186571,LED channel 8: Master-Output,ERROR,
IDE13902-MAS02201,LED channel 9: Master-Temperature,200, °C
IDE13902-MAS04121,LED channel 9: Master-Voltage,0.00, V
IDE13902-MAS04136,LED channel 9: Master-Current,0, mA
IDE13902-MAS04625,LED channel 9: Master-Power: actual value,0, W
IDE13902-MAS09022,LED channel 9: Master-PWM value,0.0, %
IDE13902-MAS09326,LED channel 9: Master-Function,no function,
IDE13902-MAS09327,LED channel 9: Master-LED brightness class,Not Used,
IDE13902-ENG186571,LED channel 9: Master-Output,ERROR,
IDE13903-MAS02201,LED channel 10: Master-Temperature,200, °C
IDE13903-MAS04121,LED channel 10: Master-Voltage,0.00, V
IDE13903-MAS04136,LED channel 10: Master-Current,0, mA
IDE13903-MAS04625,LED channel 10: Master-Power: actual value,0, W
IDE13903-MAS09022,LED channel 10: Master-PWM value,0.0, %
IDE13903-MAS09326,LED channel 10: Master-Function,no function,
IDE13903-MAS09327,LED channel 10: Master-LED brightness class,Not Used,
IDE13903-ENG186571,LED channel 10: Master-Output,ERROR,
IDE13904-MAS02201,LED channel 11: Master-Temperature,200, °C
IDE13904-MAS04121,LED channel 11: Master-Voltage,0.00, V
IDE13904-MAS04136,LED channel 11: Master-Current,0, mA
IDE13904-MAS04625,LED channel 11: Master-Power: actual value,0, W
IDE13904-MAS09022,LED channel 11: Master-PWM value,0.0, %
IDE13904-MAS09326,LED channel 11: Master-Function,no function,
IDE13904-MAS09327,LED channel 11: Master-LED brightness class,Not Used,
IDE13904-ENG186571,LED channel 11: Master-Output,ERROR,
IDE13905-MAS02201,LED channel 12: Master-Temperature,200, °C
IDE13905-MAS04121,LED channel 12: Master-Voltage,0.00, V
IDE13905-MAS04136,LED channel 12: Master-Current,0, mA
IDE13905-MAS04625,LED channel 12: Master-Power: actual value,0, W
IDE13905-MAS09022,LED channel 12: Master-PWM value,0.0, %
IDE13905-MAS09326,LED channel 12: Master-Function,no function,
IDE13905-MAS09327,LED channel 12: Master-LED brightness class,Not Used,
IDE13905-ENG186571,LED channel 12: Master-Output,ERROR,
IDE13906-MAS09833,PWM values channel 1-LED 1,0.0, %
IDE13906-MAS09834,PWM values channel 1-LED 2,0.0, %
IDE13906-MAS09835,PWM values channel 1-LED 3,0.0, %
IDE13906-MAS09836,PWM values channel 1-LED 4,0.0, %
IDE13906-MAS09837,PWM values channel 1-LED 5,0.0, %
IDE13906-MAS09838,PWM values channel 1-LED 6,0.0, %
IDE13906-MAS09839,PWM values channel 1-LED 7,0.0, %
IDE13906-MAS09840,PWM values channel 1-LED 8,0.0, %
IDE13906-MAS09841,PWM values channel 1-LED 9,0.0, %
IDE13906-MAS09842,PWM values channel 1-LED 10,0.0, %
IDE13906-MAS09843,PWM values channel 1-LED 11,0.0, %
IDE13906-MAS09844,PWM values channel 1-LED 12,0.0, %
IDE13907-MAS09833,PWM values channel 2-LED 1,0.0, %
IDE13907-MAS09834,PWM values channel 2-LED 2,0.0, %
IDE13907-MAS09835,PWM values channel 2-LED 3,0.0, %
IDE13907-MAS09836,PWM values channel 2-LED 4,0.0, %
IDE13907-MAS09837,PWM values channel 2-LED 5,0.0, %
IDE13907-MAS09838,PWM values channel 2-LED 6,0.0, %
IDE13907-MAS09839,PWM values channel 2-LED 7,0.0, %
IDE13907-MAS09840,PWM values channel 2-LED 8,0.0, %
IDE13907-MAS09841,PWM values channel 2-LED 9,0.0, %
IDE13907-MAS09842,PWM values channel 2-LED 10,0.0, %
IDE13907-MAS09843,PWM values channel 2-LED 11,0.0, %
IDE13907-MAS09844,PWM values channel 2-LED 12,0.0, %
IDE13908-MAS09833,PWM values channel 3-LED 1,0.0, %
IDE13908-MAS09834,PWM values channel 3-LED 2,0.0, %
IDE13908-MAS09835,PWM values channel 3-LED 3,0.0, %
IDE13908-MAS09836,PWM values channel 3-LED 4,0.0, %
IDE13908-MAS09837,PWM values channel 3-LED 5,0.0, %
IDE13908-MAS09838,PWM values channel 3-LED 6,0.0, %
IDE13908-MAS09839,PWM values channel 3-LED 7,0.0, %
IDE13908-MAS09840,PWM values channel 3-LED 8,0.0, %
IDE13908-MAS09841,PWM values channel 3-LED 9,0.0, %
IDE13908-MAS09842,PWM values channel 3-LED 10,0.0, %
IDE13908-MAS09843,PWM values channel 3-LED 11,0.0, %
IDE13908-MAS09844,PWM values channel 3-LED 12,0.0, %
IDE13909-MAS09833,PWM values channel 4-LED 1,0.0, %
IDE13909-MAS09834,PWM values channel 4-LED 2,0.0, %
IDE13909-MAS09835,PWM values channel 4-LED 3,0.0, %
IDE13909-MAS09836,PWM values channel 4-LED 4,0.0, %
IDE13909-MAS09837,PWM values channel 4-LED 5,0.0, %
IDE13909-MAS09838,PWM values channel 4-LED 6,0.0, %
IDE13909-MAS09839,PWM values channel 4-LED 7,0.0, %
IDE13909-MAS09840,PWM values channel 4-LED 8,0.0, %
IDE13909-MAS09841,PWM values channel 4-LED 9,0.0, %
IDE13909-MAS09842,PWM values channel 4-LED 10,0.0, %
IDE13909-MAS09843,PWM values channel 4-LED 11,0.0, %
IDE13909-MAS09844,PWM values channel 4-LED 12,0.0, %
IDE13910-MAS09833,PWM values channel 5-LED 1,0.0, %
IDE13910-MAS09834,PWM values channel 5-LED 2,0.0, %
IDE13910-MAS09835,PWM values channel 5-LED 3,0.0, %
IDE13910-MAS09836,PWM values channel 5-LED 4,0.0, %
IDE13910-MAS09837,PWM values channel 5-LED 5,0.0, %
IDE13910-MAS09838,PWM values channel 5-LED 6,0.0, %
IDE13910-MAS09839,PWM values channel 5-LED 7,0.0, %
IDE13910-MAS09840,PWM values channel 5-LED 8,0.0, %
IDE13910-MAS09841,PWM values channel 5-LED 9,0.0, %
IDE13910-MAS09842,PWM values channel 5-LED 10,0.0, %
IDE13910-MAS09843,PWM values channel 5-LED 11,0.0, %
IDE13910-MAS09844,PWM values channel 5-LED 12,0.0, %
IDE13911-MAS09833,PWM values channel 6-LED 1,0.0, %
IDE13911-MAS09834,PWM values channel 6-LED 2,0.0, %
IDE13911-MAS09835,PWM values channel 6-LED 3,0.0, %
IDE13911-MAS09836,PWM values channel 6-LED 4,0.0, %
IDE13911-MAS09837,PWM values channel 6-LED 5,0.0, %
IDE13911-MAS09838,PWM values channel 6-LED 6,0.0, %
IDE13911-MAS09839,PWM values channel 6-LED 7,0.0, %
IDE13911-MAS09840,PWM values channel 6-LED 8,0.0, %
IDE13911-MAS09841,PWM values channel 6-LED 9,0.0, %
IDE13911-MAS09842,PWM values channel 6-LED 10,0.0, %
IDE13911-MAS09843,PWM values channel 6-LED 11,0.0, %
IDE13911-MAS09844,PWM values channel 6-LED 12,0.0, %
IDE13912-MAS09833,PWM values channel 7-LED 1,0.0, %
IDE13912-MAS09834,PWM values channel 7-LED 2,0.0, %
IDE13912-MAS09835,PWM values channel 7-LED 3,0.0, %
IDE13912-MAS09836,PWM values channel 7-LED 4,0.0, %
IDE13912-MAS09837,PWM values channel 7-LED 5,0.0, %
IDE13912-MAS09838,PWM values channel 7-LED 6,0.0, %
IDE13912-MAS09839,PWM values channel 7-LED 7,0.0, %
IDE13912-MAS09840,PWM values channel 7-LED 8,0.0, %
IDE13912-MAS09841,PWM values channel 7-LED 9,0.0, %
IDE13912-MAS09842,PWM values channel 7-LED 10,0.0, %
IDE13912-MAS09843,PWM values channel 7-LED 11,0.0, %
IDE13912-MAS09844,PWM values channel 7-LED 12,0.0, %
IDE13913-MAS09833,PWM values channel 8-LED 1,0.0, %
IDE13913-MAS09834,PWM values channel 8-LED 2,0.0, %
IDE13913-MAS09835,PWM values channel 8-LED 3,0.0, %
IDE13913-MAS09836,PWM values channel 8-LED 4,0.0, %
IDE13913-MAS09837,PWM values channel 8-LED 5,0.0, %
IDE13913-MAS09838,PWM values channel 8-LED 6,0.0, %
IDE13913-MAS09839,PWM values channel 8-LED 7,0.0, %
IDE13913-MAS09840,PWM values channel 8-LED 8,0.0, %
IDE13913-MAS09841,PWM values channel 8-LED 9,0.0, %
IDE13913-MAS09842,PWM values channel 8-LED 10,0.0, %
IDE13913-MAS09843,PWM values channel 8-LED 11,0.0, %
IDE13913-MAS09844,PWM values channel 8-LED 12,0.0, %
IDE13914-MAS09833,PWM values channel 9-LED 1,0.0, %
IDE13914-MAS09834,PWM values channel 9-LED 2,0.0, %
IDE13914-MAS09835,PWM values channel 9-LED 3,0.0, %
IDE13914-MAS09836,PWM values channel 9-LED 4,0.0, %
IDE13914-MAS09837,PWM values channel 9-LED 5,0.0, %
IDE13914-MAS09838,PWM values channel 9-LED 6,0.0, %
IDE13914-MAS09839,PWM values channel 9-LED 7,0.0, %
IDE13914-MAS09840,PWM values channel 9-LED 8,0.0, %
IDE13914-MAS09841,PWM values channel 9-LED 9,0.0, %
IDE13914-MAS09842,PWM values channel 9-LED 10,0.0, %
IDE13914-MAS09843,PWM values channel 9-LED 11,0.0, %
IDE13914-MAS09844,PWM values channel 9-LED 12,0.0, %
IDE13915-MAS09833,PWM values channel 10-LED 1,0.0, %
IDE13915-MAS09834,PWM values channel 10-LED 2,0.0, %
IDE13915-MAS09835,PWM values channel 10-LED 3,0.0, %
IDE13915-MAS09836,PWM values channel 10-LED 4,0.0, %
IDE13915-MAS09837,PWM values channel 10-LED 5,0.0, %
IDE13915-MAS09838,PWM values channel 10-LED 6,0.0, %
IDE13915-MAS09839,PWM values channel 10-LED 7,0.0, %
IDE13915-MAS09840,PWM values channel 10-LED 8,0.0, %
IDE13915-MAS09841,PWM values channel 10-LED 9,0.0, %
IDE13915-MAS09842,PWM values channel 10-LED 10,0.0, %
IDE13915-MAS09843,PWM values channel 10-LED 11,0.0, %
IDE13915-MAS09844,PWM values channel 10-LED 12,0.0, %
IDE13916-MAS09833,PWM values channel 11-LED 1,0.0, %
IDE13916-MAS09834,PWM values channel 11-LED 2,0.0, %
IDE13916-MAS09835,PWM values channel 11-LED 3,0.0, %
IDE13916-MAS09836,PWM values channel 11-LED 4,0.0, %
IDE13916-MAS09837,PWM values channel 11-LED 5,0.0, %
IDE13916-MAS09838,PWM values channel 11-LED 6,0.0, %
IDE13916-MAS09839,PWM values channel 11-LED 7,0.0, %
IDE13916-MAS09840,PWM values channel 11-LED 8,0.0, %
IDE13916-MAS09841,PWM values channel 11-LED 9,0.0, %
IDE13916-MAS09842,PWM values channel 11-LED 10,0.0, %
IDE13916-MAS09843,PWM values channel 11-LED 11,0.0, %
IDE13916-MAS09844,PWM values channel 11-LED 12,0.0, %
IDE13917-MAS09833,PWM values channel 12-LED 1,0.0, %
IDE13917-MAS09834,PWM values channel 12-LED 2,0.0, %
IDE13917-MAS09835,PWM values channel 12-LED 3,0.0, %
IDE13917-MAS09836,PWM values channel 12-LED 4,0.0, %
IDE13917-MAS09837,PWM values channel 12-LED 5,0.0, %
IDE13917-MAS09838,PWM values channel 12-LED 6,0.0, %
IDE13917-MAS09839,PWM values channel 12-LED 7,0.0, %
IDE13917-MAS09840,PWM values channel 12-LED 8,0.0, %
IDE13917-MAS09841,PWM values channel 12-LED 9,0.0, %
IDE13917-MAS09842,PWM values channel 12-LED 10,0.0, %
IDE13917-MAS09843,PWM values channel 12-LED 11,0.0, %
IDE13917-MAS09844,PWM values channel 12-LED 12,0.0, %
MAS00468,Unlearning counter,57,
Elapsed Time: 00:09
blockmap-D7-992-941-571-AG_VSSZZZKM2RR140480-20241020-1516.CSV
;SW:992-941-571-AG   HW:992-941-571-A ---  Light Ctrl Right 2
;Component:LED1R         H17 9104, Coding:
;EV_LLPGen3RKEBODPO68X,002003,EV_LLPGen3RKEBODPO68X_002_VW27.rod
;Sunday,20,October,2024,15:16:35:49859
IDE08742-MAS07234,Operating time-Eco mode 1,19.63, H
IDE08742,Operating time,22.01, H
IDE08742,Operating time,11.70, H
IDE08742,Operating time,45.56, H
IDE08742-ENG166116,Operating time-Turn_indicator,2.20, H
IDE09770-ENG186571,High side channel 1-Output,16,
IDE09771-ENG186571,High side channel 2-Output,16,
IDE09772-ENG186571,High side channel 3-Output,16,
IDE09774-IDE03638,Number of activations-Stationary cornering lamp,0,
IDE09774-IDE05723,Number of activations-Clearance light,526,
IDE09774-MAS07249,Number of activations-High Beam,34,
IDE09774-MAS09325,Number of activations-Daytime running lamps,259,
IDE09774-MAS25532,Number of activations-Headlights: contour lighting,0,
IDE09774-ENG186491,Number of activations-Low beam,207,
IDE09774-ENG187378,Number of activations-turn indicator,888,
IDE09828-MAS16182,Head lamp variant-Headlamp coding variant via control module,E0,
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,26, °C
IDE10167-ENG186571,LED channel 1: Slave-Output,16,
IDE10168-MAS02201,LED channel 2: Master-Temperature,61, °C
IDE10169-ENG186571,LED channel 2: Slave-Output,16,
IDE10170-ENG186571,LED channel 3: Master-Output,16,
IDE10171-ENG186571,LED channel 3: Slave-Output,16,
IDE11123-ENG186571,High side channel 4-Output,16,
IDE11124-ENG188255,Headlamp Range Control Motor-LWR_speed_adjustment,warm,
IDE13678-MAS02201,LED channel 4: Master-Temperature,30, °C
IDE13897-MAS18765,Headlamp identification-Identification,16,
IDE13898-MAS02201,LED channel 5: Master-Temperature,62, °C
IDE13899-ENG186571,LED channel 6: Master-Output,16,
IDE13900-ENG186571,LED channel 7: Master-Output,16,
IDE13901-ENG186571,LED channel 8: Master-Output,16,
IDE13902-ENG186571,LED channel 9: Master-Output,16,
IDE13903-ENG186571,LED channel 10: Master-Output,16,
IDE13904-ENG186571,LED channel 11: Master-Output,16,
IDE13905-ENG186571,LED channel 12: Master-Output,16,
Elapsed Time: 00:09
Gaz@VDS
Lincolnshire, UK
C?ID=592224
blockmap-811E-5WA-962-133-F_VSSZZZKM2RR140480-20241020-1516.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  Burglary Protection FL
;Component:Kessy RSAD    070 0636, Coding:
;EV_RSADVL37w,002013,EV_RSADVL37w_002_VW38.rod
;Sunday,20,October,2024,15:16:48:49859
;VCID: 4BC4BEEC63493C62FA9-801E
IDE00019,Voltage terminal 30,14562, mV
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,14.5, V
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,VSSZZZKM2RR140480,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,2,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,Software_Request_Flashbootloader,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,Power_On_Reset,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,Power_On_Reset,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,Power_On_Reset,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,Unexpected_Watchdog_Reset,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,Power_On_Reset,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,Default,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,Default,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Default,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,Software_Request_Flashbootloader,
ENG254755-ENG276707,Learned_state-Learned_position_in_car,Position_front_driver_side,
ENG108452,Reset_counter,7,
Elapsed Time: 00:01
blockmap-811F-5WA-962-133-F_VSSZZZKM2RR140480-20241020-1516.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  Burglary Protection FR
;EV_RSADVR37w,002013,EV_RSADHL37w_002_VW38.rod
;Sunday,20,October,2024,15:16:54:49859
IDE00019,Voltage terminal 30,14558, mV
ENG254755-ENG276707,Learned_state-Learned_position_in_car,Position_front_codriver_side,
Elapsed Time: 00:01
blockmap-8120-5WA-962-133-F_VSSZZZKM2RR140480-20241020-1516.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  Burglary Protection RL
;EV_RSADHL37w,002013,EV_RSADHL37w_002_VW38.rod
;Sunday,20,October,2024,15:16:59:49859
IDE00019,Voltage terminal 30,14548, mV
ENG254755-ENG276707,Learned_state-Learned_position_in_car,Position_rear_driver_side,
Elapsed Time: 00:01
blockmap-8121-5WA-962-133-F_VSSZZZKM2RR140480-20241020-1517.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  Burglary Protection RR
;EV_RSADHR37w,002013,EV_RSADHL37w_002_VW38.rod
;Sunday,20,October,2024,15:17:05:49859
IDE00019,Voltage terminal 30,14529, mV
ENG254755-ENG276707,Learned_state-Learned_position_in_car,Position_rear_codriver_side,
Elapsed Time: 00:01
blockmap-OBD_VSSZZZKM2RR140480-20241020-1517.CSV
;33-OBD2
;Sunday,20,October,2024,15:17:17:49859
;VCID: 55F05894BC0D7A925CD-8000
03,Fuel system 1/2 status,Closed loop
04,Calculated load value,23.5 %,23.1 %
05,Engine coolant temperature,79 °C,79 °C
06,Short Term Trim - Bank 1,4.7 %
07,Long Term Trim - Bank 1,-4.7 %
0B,Intake Manifold Absolute Pressure,29 kPa abs
0C,Engine RPM,930 /min,928 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,0.0 Degrees
0F,Intake air temperature,34 °C
11,Absolute Throttle Position,11.4 %
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.765 V
1C,OBD Requirements Met,Euro-OBD
1F,Time since engine start,555 s
21,Distance travelled with MIL on,0 km
2E,Commanded Evaporative Purge,11.8 %
2F,Fuel Level Input,75.7 %
30,Warm-ups since DTC cleared,45
31,Distance since DTC cleared,1615 km
33,Barometric pressure,99 kPa abs
34,Bank 1 Sensor 1 Status,1.016 Lambda,0.000 mA
3C,B1S1 Cat. Temp.,360.9 °C
42,Control module voltage,14.480 V,14.500 V
43,Absolute Load Value,19 %
44,Commanded Equivalence Ratio,1.000 Lambda
45,Relative Throttle Position,0.8 %
46,Ambient Air Temp,18 °C
47,Absolute Throttle Position B,11 %
49,Accelerator Pedal Position D,14.9 %,14.9 %
4A,Accelerator Pedal Position E,14.9 %
4C,Commanded Throttle Actuator Control,1.2 %
51,Fuel type,Gasoline
53,Abs. evap. vapour press.,97895 kPa abs
56,Long term sec. O2 trim bank 1/3,0.0 %
5E,Engine Fuel Rate,0.85 L/h
62,Torque actual,10.0 %
63,Torque Reference,250 Nm
65,Auxiliary Input/Output,GEAR_RCMD: 1
67,Engine Coolant Temp,ECT 1:79 °C,ECT 2:83 °C
68,Intake Air Temp,IAT 11:31 °C,IAT 12:33 °C
6D,Fuel Press. Control A/B,FRP CMD:---/--- kPa,FRP ACT:16890/--- kPa
70,Boost Press Ctrl A/B,BP_A act:99.6 kPa
72,Wastegate Ctrl A/B,WG_A cmd/act:---/98 %,WG_B cmd/act:---/--- %
73,Exhaust Press 1/2,EP1:99.81 kPa
8B,Aftertreatment status,PF_Regen:Status:N,PF_Load: 0.0 %
8E,Eng. friction %torque,5.0 %
9D,Fuel rate,Engine: 0.18 g/s,Vehicle: 0.18 g/s
9E,Exhaust flow rate,10.0 kg/h
A4,Transm gear,N
A6,Odometer,1626.7 km
Type 02 - VIN : VSSZZZKM2RR140480 (Address E8)
Type 04 - Calibration ID : 05E012H 0956BEAJ (Address E8)
Type 04 - Calibration ID : 0GC906556D++4161 (Address E9)
Type 06 - Calibration Verification Number : D99C9D74 (Address E8)
Type 06 - Calibration Verification Number : 0A547824 (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 30
    Ignition cycle count : 162
         Catalyst monitor bank 1 : 44 / 30
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 39 / 30
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 57 / 30
         AIR monitor : 0 / 0
         EVAP monitor : 0 / 0
         Secondary O2 Sensor monitor bank 1 : 40 / 30
         Secondary O2 Sensor monitor bank 2 : 0 / 0
         Air Fuel Ratio Imbalance Monitor bank 1 : 0 / 0
         Air Fuel Ratio Imbalance Monitor bank 2 : 0 / 0
         Particulate Filter Monitor bank 1 : 0 / 0
         Particulate Filter Monitor bank 2 : 0 / 0
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Type 17 - Vehicle Operation Data - Distance-Fuel Used, Recent/Lifetime:
         Total Distance Traveled : -0.1 km / 1626.6 km
         Total Fuel Consumed : -0.01 L / 143.74 L
Gaz@VDS
Lincolnshire, UK
C?ID=592224
AutoScan: VSSZZZKM2RR140480
Sunday,20,October,2024,15:17:36:49859
Dealer/Shop Name: VDS
VIN: VSSZZZKM2RR140480   License Plate:
Chassis Type: KM-SE38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 42 44 52 5F 6C 75
          A5 BB BC D6 D7 811E 811F 8120 8121 C002 C003
VIN: VSSZZZKM2RR140480   Mileage: 1626km-1010miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DPCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 012 H    HW: 05E 907 309 D
   Component: R4 1.5l TFS   H20 0956
   Revision: 8AH20000    CVN: D99C9D74
   Coding: 012500322364150830080000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906012H 002003
   ROD: EV_ECM15TFS01105E906012H.rod
   VCID: 24163550AE57D31A1B3-8070
   VINID: 9A38EAAAA6DD0A2881100108002F21CBE1
23765 - Control unit for information electronics 1
          U1054 00 {00100000} - No Communication
          {Information electronics control module 1No Communication}
                    Reset counter: 32
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
                    Engine RPM: 912.50 /min
                    Normed load value: 28.2 %
                    Coolant temperature: 85 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 13.240 V
                    Unlearning counter according OBD: 32
                    Outside temperature: 20 °C
                    Absolute intake pressure: 36 kPa abs
                    Engine torque: 31.1 Nm
                    Fuel: tank fill level: 16.0 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0GC 906 556 D    HW: 0GC 300 048 J
   Component: GSG DQ381     H06 4161
   CVN: 0A547824
   ASAM Dataset: EV_TCMDQ381062 001001
   ROD: EV_TCMDQ381062_VW38.rod
   VCID: 3D20E0342DFD82D274D-8068
   Subsystem 1 - Part No SW: 5WA 713 033 CD    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20240419000092187590
   Subsystem 2 - Part No SW: 5FA 713 059 B    HW: 5FA 713 059 B
   Component: ZSB_SB_Mono    H03 0014
   Serial number: 92478XDR01676
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810700006553203
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 CF    HW: 5WA 614 517 N
   Component: ESC           H13 0135
   Serial number: 61204000011313  Dataset Number: V03935398JX 0002 CVN: BCB3764D
   Coding: 34042C994224426C527BA00805C365A62DB458F58AC8670821BCA431018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013058
   ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
   VCID: 0E4277F850DB494ADD7-805A SFD
33015 - Switch for Electric Parking Brake
          C100C 29 {00100000} - Signal Implausible
          {Switch_disturbance_failure}
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 Q    HW: 5WA 959 436 Q
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935364NR 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004_VW38.rod
   VCID: 629A7348F4C39D2A29F-8036
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 727 BC    HW: 5WA 907 727 BC
   Component: Climatronic   H02 0462
   Coding: 000100010011020010100010101011110000112100200000000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005069
   ROD: EV_ACClimaBHBVW38X_SE38.rod
   VCID: 127A638844E3ADAAF9F-8046
   Subsystem 1 - Part No SW: 11A 907 049     HW: 11A 907 049
   Component: E265 KPH       H02 0183
   Serial number: G07S26.04.2400972287
   Interior temperature sensor:
   Subsystem 2 - Part No SW: 5WA 907 527     HW: 5WA 907 527
   Component: E857           H01 0103
   Serial number: 00001200424081920514
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 {01100000} - -
                    Reset counter: 35
                    Mileage: 200 km
                    Date: 2024.10.03
                    Time: 08:26:26
                    Voltage terminal 30: 12.20 V
                    Compressor shut-off condition: Engine running time too short: engine start not detected by CAN
   Part No SW: 5WA 937 086 BS    HW: 5WA 937 086 BA
   Component: BCM37w_M1134 0183
   Serial number: BXJ53F170524940 Dataset Number: V03935381UV 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_AU38.rod
   VCID: 2314364CAB59D422629-8076 SFD
   Subsystem 1 - Part No SW: 5FH 955 113 B    HW: 5FH 955 113 B
   Component: FWISCHER_MYJT  067 0053
   Serial number: 907453F0302411104119
   Component: G397_RLFSS     H06 0004
   Serial number: 23477547X81A955555B0
   Subsystem 3 - Part No SW: 5H0 941 193 AG    HW: 5H0 941 193 AG
   Component: LiSi           H04 0513
   Serial number: RRB71511052400027134
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA    004 0007
   Serial number: 00000000000004497130
   Subsystem 5 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA    005 0403
   Serial number: 0000000000000JQG4V00
   Subsystem 6 - Part No SW: 5H0 959 561 BM    HW: 5H0 959 561 BM
   Component: -VW----LINDA-  504 0831
   Serial number: MW3LND03052400013114
   Steering Column Switch:
   Subsystem 7 - Part No SW: 5Q1 953 507 GA    HW: 5Q1 953 549 F
   Serial number: 00000008052408491731
   left tail lamp 1:
   left tail lamp 2:
   Right rear tail lamp 1:
   Part No SW: 5WA 919 298 B    HW: 5WA 919 298
   Component: PLA 12 Kanal  H05 0578
   Serial number: 000023042495580 Dataset Number: V03935347TP 0003
   Coding: 8300022011
   ASAM Dataset: EV_EPHBO2CVW3800000 002028
   ROD: EV_EPHBO2CVW3800000_VW38.rod
   VCID: 55F05894B58D7A925CD-8000
1080304 - Parking Sensor(s); Rear
          B107B F0 {00101000} - Function Limitation due to External Factors
                    Reset counter: 14
                    Mileage: 1443 km
                    Date: 2024.10.18
                    Time: 17:20:11
1113328 - Parking Sensor(s); Front
          B10FC F0 {00101000} - Function Limitation due to External Factors
          {Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse}
                    Reset counter: 14
                    Mileage: 1443 km
                    Date: 2024.10.18
                    Time: 17:20:27
   Part No SW: 5WA 907 572 C    HW: 5WA 907 572 A
   Component: ACC BOSCH MQB H45 0461
   Dataset Number: V03935382KT 0001
   Coding: 0A03007D407740451247400000D00004AE4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4EC2B7F8905B094A9D7-801A
8 Faults Found:
1127 - Databus
          U1121 00 {00101000} - Missing Message
          {FAULT_TIMEOUT_PSD_04}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
1218 - Databus
          {FAULT_TIMEOUT_PSD_05}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
1219 - Databus
          {FAULT_TIMEOUT_PSD_06}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
1396 - Sensor for Automatic Distance Control
          C110B F0 {00101000} - Limited Visibility
          {FAULT_SENSOR_NO_FREE_SIGHT}
                    Reset counter: 1
                    Mileage: 159 km
1538 - Sensor for Automatic Distance Control
          {FAULT_SENSOR_BLINDNESS}
                    Reset counter: 1
                    Mileage: 157 km
                    Date: 2024.10.01
                    Time: 17:50:00
1592 - Sensor for Automatic Distance Control
          C110B F0 {01101100} - Limited Visibility
          {FAULT_SENSOR_NO_FREE_SIGHT_TIMESTAMP}
                    Reset counter: 1
                    Mileage: 159 km
                    Date: 2024.10.01
                    Time: 17:51:49
209054 - Databus
          U1123 00 {00101000} - Received Error Message
          {FAULT_BV_BLINDNESS_ERROR}
                    Reset counter: 39
                    Mileage: 1538 km
                    Date: 2024.10.19
                    Time: 18:05:57
2425 - Databus
          U1122 00 {00101000} - Implausible Message
          {FAULT_SENSORFUSION_INPUT_CAMERA_NOT_AVAILABLE}
                    Reset counter: 39
                    Mileage: 1539 km
                    Date: 2024.10.19
                    Time: 18:05:58
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 FB    HW: 1EA 959 655 FB
   Component: VW40Airbag    011 0185
   Serial number: Y124MuE0265     Dataset Number: V03935420UA 0001
   Coding: 88CC008000C0C000000000000000000051540000205400004000F68000930065
   Shop #: WSC 00049 770 00210
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001016
   ROD: EV_AirbaVW40ALVVW38X_VW41.rod
   VCID: 06524FD838AB010A657-8052 SFD
   Subsystem 1 - Part No SW: -----------    HW: 440 003 004 24
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ0000004B09CBE6S
   Subsystem 2 - Part No SW: -----------    HW: 440 001 405 24
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ0000003F561AE6K
   Subsystem 3 - Part No SW: -----------    HW: 440 001 505 24
   Component: SideSensor_Pr  00B 0149
   Serial number: 352CJB0CF73712C3300V
   Subsystem 4 - Part No SW: -----------    HW: 440 001 505 24
   Component: SideSensor_Dr  00B 0149
   Serial number: 351CJAECF7371A86A00E
   Subsystem 5 - Part No SW: -----------    HW: 440 002 404 24
   Component: FrontSensor_P  00B 014A
   Serial number: 356CJA8CE3DA4848700H
   Subsystem 6 - Part No SW: -----------    HW: 440 002 404 24
   Component: FrontSensor_D  00B 014A
   Serial number: 355ckA8CE3DA4848B00L
   Part No SW: 5FA 920 790 C    HW: 5FA 920 790 C
   Component: KOMBI         311 7360
   Coding: 242C04416B940600018162032000080800300400
   ASAM Dataset: EV_DashBoardVDDMQB37W 003035
   ROD: EV_DashBoardVDDMQB37W_003_VW49.rod
   VCID: 3A2AEB283CD3B5EA51F-806E SFD
16777018 - Control unit for information electronics 1
          U1054 00 {00001000} - No Communication
          {Audio_0x31 communication error bap_error_timeout heartbeat}
                    Fault Frequency: 8
                    Reset counter: 95
                    Mileage: 177 km
                    Date: 2024.10.01
                    Time: 18:27:01
16777020 - Control unit for information electronics 1
          {TEL_0x28 communication error bap_error_timeout heartbeat}
                    Fault Frequency: 56
                    Reset counter: 95
                    Mileage: 251 km
                    Date: 2024.10.03
                    Time: 16:14:10
16777022 - Control unit for information electronics 1
          {NAV_SD_0x32 communication error bap_error_timeout heartbeat}
                    Reset counter: 95
                    Mileage: 251 km
                    Date: 2024.10.03
                    Time: 16:14:10
   Part No SW: 5WA 907 530 AB    HW: 5WA 907 530 L
   Component: GW2020 High   778 7105
   Revision: --------    Serial number: 771049110024124 Dataset Number: V03935370TJ 0002
   Coding: 0000808D0F00000000000000012303135101610B02000300030100000001010000000000000000000000000000000000
   GVL: 3D0000000208409C80008002C800004004004000004000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 006012
   ROD: EV_GatewMQB2020_006_VW38.rod
   VCID: 084E41E032BF177A17B-805C SFD
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5WA 915 181 D    HW: 5WA 915 181 D
   Component: J367-BDMConti  H04 1070
   Serial number: 76407104002405040591
   Subsystem 3 - Part No SW: 5FA 919 719 H    HW: 5FA 919 719 H
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440059128240174
2175091 - Control unit for information electronics 1
          U1054 00 {00101000} - No Communication
          {Information_electronics_control_module_1_no_communication}
          B184C 00 {00100000} - -
          {Unlock_protection_of_vehicle_diagnosis_active}
8466689 - VKMS
          B18B0 F0 {00100000} - Missing Adaptation
          {VKMS_new_download_container_required_due_to_vehicle_change}
   Part No SW: 5WA 909 059 AB    HW: 3Q0 909 059 C
   Component: EBKV          H09 0372
   Serial number: BPA085150424013 Dataset Number: V03935358NG 0001
   Coding: 1002C500740000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: 107E69804AEF5FBACFB-8044 SFD
107008 - No Communication with Transmission Control Module
          U0101 00 {00101000} - -
          {ComScl_Getriebe_11_Timeout}
                    Reset counter: 7
                    Mileage: 1199 km
                    Date: 2024.10.16
                    Time: 14:21:50
107024 - Transmission Control Module
          U14E4 00 {00100000} - Received Malfunction Value
          {Scl_Getriebe_11_GE_Fahrstufe_Error}
1024368 - Brake Booster
          C1187 F6 {00101000} - Function Limitation due to External Brake Pressure Build-Up
          {ActiveRestrictionDetected}
                    Fault Frequency: 19
                    Reset counter: 36
                    Mileage: 279 km
                    Date: 2024.10.05
                    Time: 10:24:40
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 24000128905015
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 323AC308E4A34DAA99F-8066
   Part No SW: 5WA 959 760 H    HW: 5WA 959 760 H
   Component: MEM-FS        009 0362
   Serial number: 2450301KA03057
   Coding: 01789A000000A0408803010101010000000000212100000000000000215000
   Shop #: WSC 00049 770 00068
   VCID: 59E854A4D9955EF2785-800C
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        015 0912
   Serial number: 0000528601453  Dataset Number: V03935382ZB 0002
   Coding: 00351020D201020000001000
   Shop #: WSC 00049 770 00185
   VCID: 52FAA38884636DAAB9F-8006
   Subsystem 1 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000081548028
   Coding: 3D0000
   Part No SW: 5WA 907 145 G    HW: 5WA 907 145 C
   Component: BASGEN1MQB37  502 1040
   Serial number: 03732975 Dataset Number: V03935356Z  0002
   Coding: 0000000000000001000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       015 0912
   Serial number: 0000528674110  Dataset Number: V03935382ZC 0002
   Coding: 00351020DE01020000001000
   VCID: 51F8AC84816516B2805-8004
   Subsystem 1 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000081506352
   Coding: 250000
   Part No SW: 5FA 035 862 R    HW: 5FA 035 862
   Component: MU-O-ND-EU    H67 1969
   Serial number: WG8LGM100524000 Dataset Number: V03935423GB 0001
   Coding: 43161008000100000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_SE38.rod
   VCID: 46D28FD8782BC10A257-8012 SFD
   Subsystem 1 - Part No SW: 5FA 919 606 C    HW: 5FA 919 606 C
   Component: ABT_W_12       H46 6091
   Serial number: APUFP201052400040097
   Subsystem 2 - Part No SW: V03 959 820 GB    HW: -----------
   Component: EUR 2023/24    --- 9085
12316 - Clock Syncronization Failure
          U138F 00 {00001000} - -
                    Fault Frequency: 9
                    Reset counter: 33
                    Mileage: 59 km
                    Date: 2024.09.30
                    Time: 15:24:25
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H31 0364
   Serial number: FCLK20260424010 Dataset Number: V03935373WX 0001
   Coding: 04033200843000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010026
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   Part No SW: 5WA 035 284 F    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H14 0144
   Serial number: 0000000405VIFW0 Dataset Number: V03935357XP 0001
   Coding: 043160009068A8209005460061402E07
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 49C884E469352E72C85-801C SFD
7248 - Function Restricted due to Missing Message(s)
          U1111 00 {00001000} - -
          {InfotainmentSettings (0x50) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful}
                    Reset counter: 38
                    Mileage: 1541 km
                    Date: 2024.10.20
                    Time: 09:34:51
                    Voltage terminal 30: 11.8 V
   Part No SW: 5WA 980 653 D    HW: 5WA 980 653
   Component: MQB MFK 3.0   H12 3405
   Serial number: EB7590903241310 Dataset Number: V03935413PS 0001
   Coding: 000309082148C040409E00801020002000018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005055
   ROD: EV_MFK3ValeoMQB_005_AU38.rod
   VCID: 50FEA9808A6F1FBA8FB-8004
1122664 - Databus
          U1121 00 {00001000} - Missing Message
          {TIMEOUT_PSD_04}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
1122672 - Databus
          {Timeout_PSD_06}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
1122665 - Databus
          {Timeout_PSD_05}
                    Reset counter: 31
                    Mileage: 1265 km
                    Date: 2024.10.16
                    Time: 19:24:17
   Part No SW: 992 941 571 AG    HW: 992 941 571 A
   Component: LED1L         H17 9104
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   Component: LED1R         H17 9104
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 F    HW: 5WA 962 133 F
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----------(Elapsed Time: 20:40, VBatt start/end: 12.1V/14.5V)-----------
adpmap-01-05E-906-012-H_VSSZZZKM2RR140480-20241020-1500.CSV
;SW:05E-906-012-H   HW:05E-907-309-D ---  Engine
;Component:R4 1.5l TFS   H20 0956, Coding:012500322364150830080000000000000000000000000000
;EV_ECM15TFS01105E906012H,002003,EV_ECM15TFS01105E906012H.rod
;Sunday,20,October,2024,15:00:33:49859
;VCID: 24163550AE57D31A1B3-8070
IDE04158-Activation of start/stop function,active ,1
IDE07903-Adaptation of ash mass,0.00 g,2
IDE12045-MAS13895-Adaptation of correction angle position detection bank 1 intake-Error angle sensor,-70.31 °,4
IDE12045-MAS13896-Adaptation of correction angle position detection bank 1 intake-Error angle sensor wheel,0.00 °,4
IDE12048-MAS13895-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor,-170.31 °,4
IDE12048-MAS13896-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor wheel,0.00 °,4
IDE12080-MAS13895-Adaptation of correction angle of crankshaft position detection-Error angle sensor,3.13 °,4
IDE12080-MAS13896-Adaptation of correction angle of crankshaft position detection-Error angle sensor wheel,0.00 °,4
IDE12081-MAS13897-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 1,-11.72 °,32
IDE12081-MAS13898-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 2,9.38 °,32
IDE12081-MAS13899-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 3,-6.25 °,32
IDE12081-MAS13900-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 4,3.13 °,32
IDE12081-MAS13901-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 5,0.00 °,32
IDE12081-MAS13902-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 6,0.00 °,32
IDE12081-MAS13903-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 7,0.00 °,32
IDE12081-MAS13904-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 8,0.00 °,32
IDE12081-MAS13905-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 1,42.19 °,32
IDE12081-MAS13906-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 2,-18.75 °,32
IDE12081-MAS13907-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 3,17.97 °,32
IDE12081-MAS13908-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 4,-27.34 °,32
IDE12081-MAS13909-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 5,0.00 °,32
IDE12081-MAS13910-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 6,0.00 °,32
IDE12081-MAS13911-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 7,0.00 °,32
IDE12081-MAS13912-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 8,0.00 °,32
Elapsed Time: 00:02
adpmap-02-0GC-906-556-D_VSSZZZKM2RR140480-20241020-1501.CSV
;SW:0GC-906-556-D   HW:0GC-300-048-J ---  Auto Trans
;Component:GSG DQ381     H06 4161, Coding:0014
;EV_TCMDQ381062,001001,EV_TCMDQ381062_VW38.rod
;Sunday,20,October,2024,15:01:25:49859
;VCID: 3D20E0342DFD82D274D-8068
IDE00001-ENG252070-Production mode-Haltemagnet ausschalten,not activated ,3
IDE00001-ENG252086-Production mode-Longpush,not activated ,3
IDE00001-ENG252078-Production mode-NER aktiv halten,not activated ,3
IDE00001-ENG252050-Production mode-N-Haltephase deaktivieren,not activated ,3
IDE00001-ENG98860-Production mode-Production mode,not activated ,3
IDE00001-ENG252054-Production mode-P-Taste deaktivieren,not activated ,3
Elapsed Time: 00:01
adpmap-03-5WA-614-517-CF_VSSZZZKM2RR140480-20241020-1501.CSV
;SW:5WA-614-517-CF   HW:5WA-614-517-N ---  ABS Brakes
;Component:ESC           H13 0135, Coding:34042C994224426C527BA00805C365A62DB458F58AC8670821BCA431018FF100002814
;EV_Brake1ESCEPBMQB37W,013058,EV_Brake1ESCEPBMQB37W_013_AU38.rod
;Sunday,20,October,2024,15:01:46:49859
;VCID: 0E4277F850DB494ADD7-805A
IDE00820-ENG264053-Activating and deactivating all development messages-Activation of Development Message EPB00,Security access required,3
IDE00820-ENG264054-Activating and deactivating all development messages-Activation of Development Message EPB01,Security access required,3
IDE00820-ENG264055-Activating and deactivating all development messages-Activation of Development Message EPB02,Security access required,3
IDE00820-ENG264056-Activating and deactivating all development messages-Activation of Development Message ESC00,Security access required,3
IDE00820-ENG264057-Activating and deactivating all development messages-Activation of Development Message ESC01,Security access required,3
IDE00820-ENG264058-Activating and deactivating all development messages-Activation of Development Message ESC02,Security access required,3
IDE00820-ENG264059-Activating and deactivating all development messages-Activation of Development Message ESC03,Security access required,3
IDE00820-ENG264060-Activating and deactivating all development messages-Activation of Development Message ESC04,Security access required,3
IDE00820-ENG264061-Activating and deactivating all development messages-Activation of Development Message ESC05,Security access required,3
IDE00820-ENG264062-Activating and deactivating all development messages-Activation of Development Message ESC06,Security access required,3
IDE00820-ENG264063-Activating and deactivating all development messages-Activation of Development Message ESC07,Security access required,3
IDE00820-ENG264064-Activating and deactivating all development messages-Activation of Development Message ESC08,Security access required,3
IDE00820-ENG264065-Activating and deactivating all development messages-Activation of Development Message ESC10,Security access required,3
IDE00820-ENG264066-Activating and deactivating all development messages-Activation of Development Message FDR01,Security access required,3
IDE03659-Roller test bench mode,Security access required,3
IDE04456-Brake disk drying,Security access required,3
IDE04765-Counter steer support,Security access required,3
IDE05055-Hydraulic brake assistant,Security access required,3
IDE05057-Brake prefill,Security access required,3
IDE05161-Straight ahead brake stabilization,Security access required,3
IDE07292-Brake pre-filling,Security access required,2
IDE07565-ABS in lower speed range,Security access required,2
IDE11985-Expected OBD requirements,Security access required,2
IDE12030-Rough road optimization,Security access required,2
IDE14225-IDE07280-Delay management-Multiple collision brake,Security access required,2
IDE14225-MAS00919-Delay management-Pedestrian protection,Security access required,2
IDE14225-MAS05087-Delay management-ACC,Security access required,2
IDE14225-MAS05506-Delay management-Stopping distance reduction,Security access required,2
IDE14225-MAS10858-Delay management-Rear camera,Security access required,2
IDE14225-MAS12321-Delay management-Trailer positioning assistant,Security access required,2
IDE14225-MAS15696-Delay management-Rear cross traffic assistant,Security access required,2
IDE14225-MAS15806-Delay management-Parking assistant,Security access required,2
IDE14225-MAS18082-Delay management-Emergency assistant,Security access required,2
IDE14226-Electronic engine braking torque reduction,Security access required,2
IDE15332-MAS17834-Vehicle curb weight-Curb weight of rear axle,619.0 kg,4
IDE15332-MAS17837-Vehicle curb weight-Curb weight of front axle,857.0 kg,4
MAS03691-Dimming,Security access required,4
MAS09595-IDE01211-Production mode-Static current measuring mode,Deactivating ,3
MAS09595-IDE02939-Production mode-Activate/lock control,Deactivating ,3
MAS09595-IDE09543-Production mode-Vehicle holding function,Deactivating ,3
MAS09595-MAS16682-Production mode-Production mode after-run monitoring,Deactivating ,3
MAS09595-MAS18521-Production mode-Production mode: recuperation,Deactivating ,3
MAS09595-Production mode-,not active ,3
MAS14035-Precondition,Security access required,3
MAS16144-Wheel loose detection: warning threshold,Security access required,3
ENG264022-Developer_Function_01,Security access required,3
ENG264037-Developer_Function_02,Security access required,3
ENG264035-ENG264163-Developer_Function_03-Developer_Function_03_Bremsdrucksensor,Security access required,3
ENG264035-ENG264164-Developer_Function_03-Developer_Function_03_PYA,Security access required,3
ENG264021-Developer_Function_10,Security access required,3
ENG122844-ENG264130-dimming_characteristic_1-Daempfung_Abdimmen_KL_58xD_PWM,Security access required,3
ENG122844-ENG154584-dimming_characteristic_1-Daempfung_Aufdimmen_KL_58xd_PWM,Security access required,3
ENG122844-ENG101574-dimming_characteristic_1-X1,Security access required,3
ENG122844-ENG99557-dimming_characteristic_1-X2,Security access required,3
ENG122844-ENG102140-dimming_characteristic_1-X3,Security access required,3
ENG122844-ENG102936-dimming_characteristic_1-X4,Security access required,3
ENG122844-ENG103548-dimming_characteristic_1-X5,Security access required,3
ENG122844-ENG113992-dimming_characteristic_1-X6,Security access required,3
ENG122844-ENG99777-dimming_characteristic_1-Y1,Security access required,3
ENG122844-ENG100480-dimming_characteristic_1-Y2,Security access required,3
ENG122844-ENG100773-dimming_characteristic_1-Y3,Security access required,3
ENG122844-ENG100631-dimming_characteristic_1-Y4,Security access required,3
ENG122844-ENG102174-dimming_characteristic_1-Y5,Security access required,3
ENG122844-ENG113993-dimming_characteristic_1-Y6,Security access required,3
ENG122845-ENG264130-dimming_characteristic_2-Daempfung_Abdimmen_KL_58xD_PWM,Security access required,3
ENG122845-ENG154584-dimming_characteristic_2-Daempfung_Aufdimmen_KL_58xd_PWM,Security access required,3
ENG122845-ENG101574-dimming_characteristic_2-X1,Security access required,3
ENG122845-ENG99557-dimming_characteristic_2-X2,Security access required,3
ENG122845-ENG102140-dimming_characteristic_2-X3,Security access required,3
ENG122845-ENG102936-dimming_characteristic_2-X4,Security access required,3
ENG122845-ENG103548-dimming_characteristic_2-X5,Security access required,3
ENG122845-ENG113992-dimming_characteristic_2-X6,Security access required,3
ENG122845-ENG99777-dimming_characteristic_2-Y1,Security access required,3
ENG122845-ENG100480-dimming_characteristic_2-Y2,Security access required,3
ENG122845-ENG100773-dimming_characteristic_2-Y3,Security access required,3
ENG122845-ENG100631-dimming_characteristic_2-Y4,Security access required,3
ENG122845-ENG102174-dimming_characteristic_2-Y5,Security access required,3
ENG122845-ENG113993-dimming_characteristic_2-Y6,Security access required,3
ENG264029-ENG264073-Dynamic_Developer_Function_01-ASAP_Address_0,Security access required,3
ENG264029-ENG264074-Dynamic_Developer_Function_01-ASAP_Address_1,Security access required,3
ENG264029-ENG264075-Dynamic_Developer_Function_01-ASAP_Address_10,Security access required,3
ENG264029-ENG264076-Dynamic_Developer_Function_01-ASAP_Address_100,Security access required,3
ENG264029-ENG264077-Dynamic_Developer_Function_01-ASAP_Address_11,Security access required,3
ENG264029-ENG264078-Dynamic_Developer_Function_01-ASAP_Address_12,Security access required,3
ENG264029-ENG264079-Dynamic_Developer_Function_01-ASAP_Address_13,Security access required,3
ENG264029-ENG264080-Dynamic_Developer_Function_01-ASAP_Address_14,Security access required,3
ENG264029-ENG264081-Dynamic_Developer_Function_01-ASAP_Address_15,Security access required,3
ENG264029-ENG264082-Dynamic_Developer_Function_01-ASAP_Address_2,Security access required,3
ENG264029-ENG264083-Dynamic_Developer_Function_01-ASAP_Address_3,Security access required,3
ENG264029-ENG264084-Dynamic_Developer_Function_01-ASAP_Address_4,Security access required,3
ENG264029-ENG264085-Dynamic_Developer_Function_01-ASAP_Address_5,Security access required,3
ENG264029-ENG264086-Dynamic_Developer_Function_01-ASAP_Address_6,Security access required,3
ENG264029-ENG264087-Dynamic_Developer_Function_01-ASAP_Address_7,Security access required,3
ENG264029-ENG264088-Dynamic_Developer_Function_01-ASAP_Address_8,Security access required,3
ENG264029-ENG264089-Dynamic_Developer_Function_01-ASAP_Address_81,Security access required,3
ENG264029-ENG264090-Dynamic_Developer_Function_01-ASAP_Address_82,Security access required,3
ENG264029-ENG264091-Dynamic_Developer_Function_01-ASAP_Address_83,Security access required,3
ENG264029-ENG264092-Dynamic_Developer_Function_01-ASAP_Address_84,Security access required,3
ENG264029-ENG264093-Dynamic_Developer_Function_01-ASAP_Address_85,Security access required,3
ENG264029-ENG264094-Dynamic_Developer_Function_01-ASAP_Address_86,Security access required,3
ENG264029-ENG264095-Dynamic_Developer_Function_01-ASAP_Address_87,Security access required,3
ENG264029-ENG264096-Dynamic_Developer_Function_01-ASAP_Address_88,Security access required,3
ENG264029-ENG264097-Dynamic_Developer_Function_01-ASAP_Address_89,Security access required,3
ENG264029-ENG264098-Dynamic_Developer_Function_01-ASAP_Address_9,Security access required,3
ENG264029-ENG264099-Dynamic_Developer_Function_01-ASAP_Address_90,Security access required,3
ENG264029-ENG264100-Dynamic_Developer_Function_01-ASAP_Address_91,Security access required,3
ENG264029-ENG264101-Dynamic_Developer_Function_01-ASAP_Address_92,Security access required,3
ENG264029-ENG264102-Dynamic_Developer_Function_01-ASAP_Address_93,Security access required,3
ENG264029-ENG264103-Dynamic_Developer_Function_01-ASAP_Address_94,Security access required,3
ENG264029-ENG264104-Dynamic_Developer_Function_01-ASAP_Address_95,Security access required,3
ENG264029-ENG264105-Dynamic_Developer_Function_01-ASAP_Address_96,Security access required,3
ENG264029-ENG264106-Dynamic_Developer_Function_01-ASAP_Address_97,Security access required,3
ENG264029-ENG264107-Dynamic_Developer_Function_01-ASAP_Address_98,Security access required,3
ENG264029-ENG264108-Dynamic_Developer_Function_01-ASAP_Address_99,Security access required,3
ENG264029-ENG264109-Dynamic_Developer_Function_01-ASAP_Data_Type_100,Security access required,3
ENG264029-ENG264110-Dynamic_Developer_Function_01-ASAP_Data_Type_81,Security access required,3
ENG264029-ENG264111-Dynamic_Developer_Function_01-ASAP_Data_Type_82,Security access required,3
ENG264029-ENG264112-Dynamic_Developer_Function_01-ASAP_Data_Type_83,Security access required,3
ENG264029-ENG264113-Dynamic_Developer_Function_01-ASAP_Data_Type_84,Security access required,3
ENG264029-ENG264114-Dynamic_Developer_Function_01-ASAP_Data_Type_85,Security access required,3
ENG264029-ENG264115-Dynamic_Developer_Function_01-ASAP_Data_Type_86,Security access required,3
ENG264029-ENG264116-Dynamic_Developer_Function_01-ASAP_Data_Type_87,Security access required,3
ENG264029-ENG264117-Dynamic_Developer_Function_01-ASAP_Data_Type_88,Security access required,3
ENG264029-ENG264118-Dynamic_Developer_Function_01-ASAP_Data_Type_89,Security access required,3
ENG264029-ENG264119-Dynamic_Developer_Function_01-ASAP_Data_Type_90,Security access required,3
ENG264029-ENG264120-Dynamic_Developer_Function_01-ASAP_Data_Type_91,Security access required,3
ENG264029-ENG264121-Dynamic_Developer_Function_01-ASAP_Data_Type_92,Security access required,3
ENG264029-ENG264122-Dynamic_Developer_Function_01-ASAP_Data_Type_93,Security access required,3
ENG264029-ENG264123-Dynamic_Developer_Function_01-ASAP_Data_Type_94,Security access required,3
ENG264029-ENG264124-Dynamic_Developer_Function_01-ASAP_Data_Type_95,Security access required,3
ENG264029-ENG264125-Dynamic_Developer_Function_01-ASAP_Data_Type_96,Security access required,3
ENG264029-ENG264126-Dynamic_Developer_Function_01-ASAP_Data_Type_97,Security access required,3
ENG264029-ENG264127-Dynamic_Developer_Function_01-ASAP_Data_Type_98,Security access required,3
ENG264029-ENG264128-Dynamic_Developer_Function_01-ASAP_Data_Type_99,Security access required,3
ENG264029-ENG264131-Dynamic_Developer_Function_01-Data_position_0_Bit_position,Security access required,3
ENG264029-ENG264132-Dynamic_Developer_Function_01-Data_position_0_Byte_position,Security access required,3
ENG264029-ENG264133-Dynamic_Developer_Function_01-Data_position_1_Bit_position,Security access required,3
ENG264029-ENG264134-Dynamic_Developer_Function_01-Data_position_1_Byte_position,Security access required,3
ENG264029-ENG264135-Dynamic_Developer_Function_01-Data_position_10_Bit_position,Security access required,3
ENG264029-ENG264136-Dynamic_Developer_Function_01-Data_position_10_Byte_position,Security access required,3
ENG264029-ENG264137-Dynamic_Developer_Function_01-Data_position_11_Bit_position,Security access required,3
ENG264029-ENG264138-Dynamic_Developer_Function_01-Data_position_11_Byte_position,Security access required,3
ENG264029-ENG264139-Dynamic_Developer_Function_01-Data_position_12_Bit_position,Security access required,3
ENG264029-ENG264140-Dynamic_Developer_Function_01-Data_position_12_Byte_position,Security access required,3
ENG264029-ENG264141-Dynamic_Developer_Function_01-Data_position_13_Bit_position,Security access required,3
ENG264029-ENG264142-Dynamic_Developer_Function_01-Data_position_13_Byte_position,Security access required,3
ENG264029-ENG264143-Dynamic_Developer_Function_01-Data_position_14_Bit_position,Security access required,3
ENG264029-ENG264144-Dynamic_Developer_Function_01-Data_position_14_Byte_position,Security access required,3
ENG264029-ENG264145-Dynamic_Developer_Function_01-Data_position_15_Bit_position,Security access required,3
ENG264029-ENG264146-Dynamic_Developer_Function_01-Data_position_15_Byte_position,Security access required,3
ENG264029-ENG264147-Dynamic_Developer_Function_01-Data_position_2_Bit_position,Security access required,3
ENG264029-ENG264148-Dynamic_Developer_Function_01-Data_position_2_Byte_position,Security access required,3
ENG264029-ENG264149-Dynamic_Developer_Function_01-Data_position_3_Bit_position,Security access required,3
ENG264029-ENG264150-Dynamic_Developer_Function_01-Data_position_3_Byte_position,Security access required,3
ENG264029-ENG264151-Dynamic_Developer_Function_01-Data_position_4_Bit_position,Security access required,3
ENG264029-ENG264152-Dynamic_Developer_Function_01-Data_position_4_Byte_position,Security access required,3
ENG264029-ENG264153-Dynamic_Developer_Function_01-Data_position_5_Bit_position,Security access required,3
ENG264029-ENG264154-Dynamic_Developer_Function_01-Data_position_5_Byte_position,Security access required,3
ENG264029-ENG264155-Dynamic_Developer_Function_01-Data_position_6_Bit_position,Security access required,3
ENG264029-ENG264156-Dynamic_Developer_Function_01-Data_position_6_Byte_position,Security access required,3
ENG264029-ENG264157-Dynamic_Developer_Function_01-Data_position_7_Bit_position,Security access required,3
ENG264029-ENG264158-Dynamic_Developer_Function_01-Data_position_7_Byte_position,Security access required,3
ENG264029-ENG264159-Dynamic_Developer_Function_01-Data_position_8_Bit_position,Security access required,3
ENG264029-ENG264160-Dynamic_Developer_Function_01-Data_position_8_Byte_position,Security access required,3
ENG264029-ENG264161-Dynamic_Developer_Function_01-Data_position_9_Bit_position,Security access required,3
ENG264029-ENG264162-Dynamic_Developer_Function_01-Data_position_9_Byte_position,Security access required,3
ENG264029-ENG264166-Dynamic_Developer_Function_01-Dynamic_Developer_Function_Groupe_1,Security access required,3
ENG264029-ENG264167-Dynamic_Developer_Function_01-Dynamic_Developer_Function_Groupe_2,Security access required,3
ENG264027-ENG264073-Dynamic_Developer_Function_02-ASAP_Address_0,Security access required,3
ENG264027-ENG264074-Dynamic_Developer_Function_02-ASAP_Address_1,Security access required,3
ENG264027-ENG264075-Dynamic_Developer_Function_02-ASAP_Address_10,Security access required,3
ENG264027-ENG264076-Dynamic_Developer_Function_02-ASAP_Address_100,Security access required,3
ENG264027-ENG264077-Dynamic_Developer_Function_02-ASAP_Address_11,Security access required,3
ENG264027-ENG264078-Dynamic_Developer_Function_02-ASAP_Address_12,Security access required,3
ENG264027-ENG264079-Dynamic_Developer_Function_02-ASAP_Address_13,Security access required,3
ENG264027-ENG264080-Dynamic_Developer_Function_02-ASAP_Address_14,Security access required,3
ENG264027-ENG264081-Dynamic_Developer_Function_02-ASAP_Address_15,Security access required,3
ENG264027-ENG264082-Dynamic_Developer_Function_02-ASAP_Address_2,Security access required,3
ENG264027-ENG264083-Dynamic_Developer_Function_02-ASAP_Address_3,Security access required,3
ENG264027-ENG264084-Dynamic_Developer_Function_02-ASAP_Address_4,Security access required,3
ENG264027-ENG264085-Dynamic_Developer_Function_02-ASAP_Address_5,Security access required,3
ENG264027-ENG264086-Dynamic_Developer_Function_02-ASAP_Address_6,Security access required,3
ENG264027-ENG264087-Dynamic_Developer_Function_02-ASAP_Address_7,Security access required,3
ENG264027-ENG264088-Dynamic_Developer_Function_02-ASAP_Address_8,Security access required,3
ENG264027-ENG264089-Dynamic_Developer_Function_02-ASAP_Address_81,Security access required,3
ENG264027-ENG264090-Dynamic_Developer_Function_02-ASAP_Address_82,Security access required,3
ENG264027-ENG264091-Dynamic_Developer_Function_02-ASAP_Address_83,Security access required,3
ENG264027-ENG264092-Dynamic_Developer_Function_02-ASAP_Address_84,Security access required,3
ENG264027-ENG264093-Dynamic_Developer_Function_02-ASAP_Address_85,Security access required,3
ENG264027-ENG264094-Dynamic_Developer_Function_02-ASAP_Address_86,Security access required,3
ENG264027-ENG264095-Dynamic_Developer_Function_02-ASAP_Address_87,Security access required,3
ENG264027-ENG264096-Dynamic_Developer_Function_02-ASAP_Address_88,Security access required,3
ENG264027-ENG264097-Dynamic_Developer_Function_02-ASAP_Address_89,Security access required,3
ENG264027-ENG264098-Dynamic_Developer_Function_02-ASAP_Address_9,Security access required,3
ENG264027-ENG264099-Dynamic_Developer_Function_02-ASAP_Address_90,Security access required,3
ENG264027-ENG264100-Dynamic_Developer_Function_02-ASAP_Address_91,Security access required,3
ENG264027-ENG264101-Dynamic_Developer_Function_02-ASAP_Address_92,Security access required,3
ENG264027-ENG264102-Dynamic_Developer_Function_02-ASAP_Address_93,Security access required,3
ENG264027-ENG264103-Dynamic_Developer_Function_02-ASAP_Address_94,Security access required,3
ENG264027-ENG264104-Dynamic_Developer_Function_02-ASAP_Address_95,Security access required,3
ENG264027-ENG264105-Dynamic_Developer_Function_02-ASAP_Address_96,Security access required,3
ENG264027-ENG264106-Dynamic_Developer_Function_02-ASAP_Address_97,Security access required,3
ENG264027-ENG264107-Dynamic_Developer_Function_02-ASAP_Address_98,Security access required,3
ENG264027-ENG264108-Dynamic_Developer_Function_02-ASAP_Address_99,Security access required,3
ENG264027-ENG264109-Dynamic_Developer_Function_02-ASAP_Data_Type_100,Security access required,3
ENG264027-ENG264110-Dynamic_Developer_Function_02-ASAP_Data_Type_81,Security access required,3
ENG264027-ENG264111-Dynamic_Developer_Function_02-ASAP_Data_Type_82,Security access required,3
ENG264027-ENG264112-Dynamic_Developer_Function_02-ASAP_Data_Type_83,Security access required,3
ENG264027-ENG264113-Dynamic_Developer_Function_02-ASAP_Data_Type_84,Security access required,3
ENG264027-ENG264114-Dynamic_Developer_Function_02-ASAP_Data_Type_85,Security access required,3
ENG264027-ENG264115-Dynamic_Developer_Function_02-ASAP_Data_Type_86,Security access required,3
ENG264027-ENG264116-Dynamic_Developer_Function_02-ASAP_Data_Type_87,Security access required,3
ENG264027-ENG264117-Dynamic_Developer_Function_02-ASAP_Data_Type_88,Security access required,3
ENG264027-ENG264118-Dynamic_Developer_Function_02-ASAP_Data_Type_89,Security access required,3
ENG264027-ENG264119-Dynamic_Developer_Function_02-ASAP_Data_Type_90,Security access required,3
ENG264027-ENG264120-Dynamic_Developer_Function_02-ASAP_Data_Type_91,Security access required,3
ENG264027-ENG264121-Dynamic_Developer_Function_02-ASAP_Data_Type_92,Security access required,3
ENG264027-ENG264122-Dynamic_Developer_Function_02-ASAP_Data_Type_93,Security access required,3
ENG264027-ENG264123-Dynamic_Developer_Function_02-ASAP_Data_Type_94,Security access required,3
ENG264027-ENG264124-Dynamic_Developer_Function_02-ASAP_Data_Type_95,Security access required,3
ENG264027-ENG264125-Dynamic_Developer_Function_02-ASAP_Data_Type_96,Security access required,3
ENG264027-ENG264126-Dynamic_Developer_Function_02-ASAP_Data_Type_97,Security access required,3
ENG264027-ENG264127-Dynamic_Developer_Function_02-ASAP_Data_Type_98,Security access required,3
ENG264027-ENG264128-Dynamic_Developer_Function_02-ASAP_Data_Type_99,Security access required,3
ENG264027-ENG264131-Dynamic_Developer_Function_02-Data_position_0_Bit_position,Security access required,3
ENG264027-ENG264132-Dynamic_Developer_Function_02-Data_position_0_Byte_position,Security access required,3
ENG264027-ENG264133-Dynamic_Developer_Function_02-Data_position_1_Bit_position,Security access required,3
ENG264027-ENG264134-Dynamic_Developer_Function_02-Data_position_1_Byte_position,Security access required,3
ENG264027-ENG264135-Dynamic_Developer_Function_02-Data_position_10_Bit_position,Security access required,3
ENG264027-ENG264136-Dynamic_Developer_Function_02-Data_position_10_Byte_position,Security access required,3
ENG264027-ENG264137-Dynamic_Developer_Function_02-Data_position_11_Bit_position,Security access required,3
ENG264027-ENG264138-Dynamic_Developer_Function_02-Data_position_11_Byte_position,Security access required,3
ENG264027-ENG264139-Dynamic_Developer_Function_02-Data_position_12_Bit_position,Security access required,3
ENG264027-ENG264140-Dynamic_Developer_Function_02-Data_position_12_Byte_position,Security access required,3
ENG264027-ENG264141-Dynamic_Developer_Function_02-Data_position_13_Bit_position,Security access required,3
ENG264027-ENG264142-Dynamic_Developer_Function_02-Data_position_13_Byte_position,Security access required,3
ENG264027-ENG264143-Dynamic_Developer_Function_02-Data_position_14_Bit_position,Security access required,3
ENG264027-ENG264144-Dynamic_Developer_Function_02-Data_position_14_Byte_position,Security access required,3
ENG264027-ENG264145-Dynamic_Developer_Function_02-Data_position_15_Bit_position,Security access required,3
ENG264027-ENG264146-Dynamic_Developer_Function_02-Data_position_15_Byte_position,Security access required,3
ENG264027-ENG264147-Dynamic_Developer_Function_02-Data_position_2_Bit_position,Security access required,3
ENG264027-ENG264148-Dynamic_Developer_Function_02-Data_position_2_Byte_position,Security access required,3
ENG264027-ENG264149-Dynamic_Developer_Function_02-Data_position_3_Bit_position,Security access required,3
ENG264027-ENG264150-Dynamic_Developer_Function_02-Data_position_3_Byte_position,Security access required,3
ENG264027-ENG264151-Dynamic_Developer_Function_02-Data_position_4_Bit_position,Security access required,3
ENG264027-ENG264152-Dynamic_Developer_Function_02-Data_position_4_Byte_position,Security access required,3
ENG264027-ENG264153-Dynamic_Developer_Function_02-Data_position_5_Bit_position,Security access required,3
ENG264027-ENG264154-Dynamic_Developer_Function_02-Data_position_5_Byte_position,Security access required,3
ENG264027-ENG264155-Dynamic_Developer_Function_02-Data_position_6_Bit_position,Security access required,3
ENG264027-ENG264156-Dynamic_Developer_Function_02-Data_position_6_Byte_position,Security access required,3
ENG264027-ENG264157-Dynamic_Developer_Function_02-Data_position_7_Bit_position,Security access required,3
ENG264027-ENG264158-Dynamic_Developer_Function_02-Data_position_7_Byte_position,Security access required,3
ENG264027-ENG264159-Dynamic_Developer_Function_02-Data_position_8_Bit_position,Security access required,3
ENG264027-ENG264160-Dynamic_Developer_Function_02-Data_position_8_Byte_position,Security access required,3
ENG264027-ENG264161-Dynamic_Developer_Function_02-Data_position_9_Bit_position,Security access required,3
ENG264027-ENG264162-Dynamic_Developer_Function_02-Data_position_9_Byte_position,Security access required,3
ENG264027-ENG264166-Dynamic_Developer_Function_02-Dynamic_Developer_Function_Groupe_1,Security access required,3
ENG264027-ENG264167-Dynamic_Developer_Function_02-Dynamic_Developer_Function_Groupe_2,Security access required,3
ENG264028-ENG264073-Dynamic_Developer_Function_03-ASAP_Address_0,Security access required,3
ENG264028-ENG264074-Dynamic_Developer_Function_03-ASAP_Address_1,Security access required,3
ENG264028-ENG264075-Dynamic_Developer_Function_03-ASAP_Address_10,Security access required,3
ENG264028-ENG264076-Dynamic_Developer_Function_03-ASAP_Address_100,Security access required,3
ENG264028-ENG264077-Dynamic_Developer_Function_03-ASAP_Address_11,Security access required,3
ENG264028-ENG264078-Dynamic_Developer_Function_03-ASAP_Address_12,Security access required,3
ENG264028-ENG264079-Dynamic_Developer_Function_03-ASAP_Address_13,Security access required,3
ENG264028-ENG264080-Dynamic_Developer_Function_03-ASAP_Address_14,Security access required,3
ENG264028-ENG264081-Dynamic_Developer_Function_03-ASAP_Address_15,Security access required,3
ENG264028-ENG264082-Dynamic_Developer_Function_03-ASAP_Address_2,Security access required,3
ENG264028-ENG264083-Dynamic_Developer_Function_03-ASAP_Address_3,Security access required,3
ENG264028-ENG264084-Dynamic_Developer_Function_03-ASAP_Address_4,Security access required,3
ENG264028-ENG264085-Dynamic_Developer_Function_03-ASAP_Address_5,Security access required,3
ENG264028-ENG264086-Dynamic_Developer_Function_03-ASAP_Address_6,Security access required,3
ENG264028-ENG264087-Dynamic_Developer_Function_03-ASAP_Address_7,Security access required,3
ENG264028-ENG264088-Dynamic_Developer_Function_03-ASAP_Address_8,Security access required,3
ENG264028-ENG264089-Dynamic_Developer_Function_03-ASAP_Address_81,Security access required,3
ENG264028-ENG264090-Dynamic_Developer_Function_03-ASAP_Address_82,Security access required,3
ENG264028-ENG264091-Dynamic_Developer_Function_03-ASAP_Address_83,Security access required,3
ENG264028-ENG264092-Dynamic_Developer_Function_03-ASAP_Address_84,Security access required,3
ENG264028-ENG264093-Dynamic_Developer_Function_03-ASAP_Address_85,Security access required,3
ENG264028-ENG264094-Dynamic_Developer_Function_03-ASAP_Address_86,Security access required,3
ENG264028-ENG264095-Dynamic_Developer_Function_03-ASAP_Address_87,Security access required,3
ENG264028-ENG264096-Dynamic_Developer_Function_03-ASAP_Address_88,Security access required,3
ENG264028-ENG264097-Dynamic_Developer_Function_03-ASAP_Address_89,Security access required,3
ENG264028-ENG264098-Dynamic_Developer_Function_03-ASAP_Address_9,Security access required,3
ENG264028-ENG264099-Dynamic_Developer_Function_03-ASAP_Address_90,Security access required,3
ENG264028-ENG264100-Dynamic_Developer_Function_03-ASAP_Address_91,Security access required,3
ENG264028-ENG264101-Dynamic_Developer_Function_03-ASAP_Address_92,Security access required,3
ENG264028-ENG264102-Dynamic_Developer_Function_03-ASAP_Address_93,Security access required,3
ENG264028-ENG264103-Dynamic_Developer_Function_03-ASAP_Address_94,Security access required,3
ENG264028-ENG264104-Dynamic_Developer_Function_03-ASAP_Address_95,Security access required,3
ENG264028-ENG264105-Dynamic_Developer_Function_03-ASAP_Address_96,Security access required,3
ENG264028-ENG264106-Dynamic_Developer_Function_03-ASAP_Address_97,Security access required,3
ENG264028-ENG264107-Dynamic_Developer_Function_03-ASAP_Address_98,Security access required,3
ENG264028-ENG264108-Dynamic_Developer_Function_03-ASAP_Address_99,Security access required,3
ENG264028-ENG264109-Dynamic_Developer_Function_03-ASAP_Data_Type_100,Security access required,3
ENG264028-ENG264110-Dynamic_Developer_Function_03-ASAP_Data_Type_81,Security access required,3
ENG264028-ENG264111-Dynamic_Developer_Function_03-ASAP_Data_Type_82,Security access required,3
ENG264028-ENG264112-Dynamic_Developer_Function_03-ASAP_Data_Type_83,Security access required,3
ENG264028-ENG264113-Dynamic_Developer_Function_03-ASAP_Data_Type_84,Security access required,3
ENG264028-ENG264114-Dynamic_Developer_Function_03-ASAP_Data_Type_85,Security access required,3
ENG264028-ENG264115-Dynamic_Developer_Function_03-ASAP_Data_Type_86,Security access required,3
ENG264028-ENG264116-Dynamic_Developer_Function_03-ASAP_Data_Type_87,Security access required,3
ENG264028-ENG264117-Dynamic_Developer_Function_03-ASAP_Data_Type_88,Security access required,3
ENG264028-ENG264118-Dynamic_Developer_Function_03-ASAP_Data_Type_89,Security access required,3
ENG264028-ENG264119-Dynamic_Developer_Function_03-ASAP_Data_Type_90,Security access required,3
ENG264028-ENG264120-Dynamic_Developer_Function_03-ASAP_Data_Type_91,Security access required,3
ENG264028-ENG264121-Dynamic_Developer_Function_03-ASAP_Data_Type_92,Security access required,3
ENG264028-ENG264122-Dynamic_Developer_Function_03-ASAP_Data_Type_93,Security access required,3
ENG264028-ENG264123-Dynamic_Developer_Function_03-ASAP_Data_Type_94,Security access required,3
ENG264028-ENG264124-Dynamic_Developer_Function_03-ASAP_Data_Type_95,Security access required,3
ENG264028-ENG264125-Dynamic_Developer_Function_03-ASAP_Data_Type_96,Security access required,3
ENG264028-ENG264126-Dynamic_Developer_Function_03-ASAP_Data_Type_97,Security access required,3
ENG264028-ENG264127-Dynamic_Developer_Function_03-ASAP_Data_Type_98,Security access required,3
ENG264028-ENG264128-Dynamic_Developer_Function_03-ASAP_Data_Type_99,Security access required,3
ENG264028-ENG264131-Dynamic_Developer_Function_03-Data_position_0_Bit_position,Security access required,3
ENG264028-ENG264132-Dynamic_Developer_Function_03-Data_position_0_Byte_position,Security access required,3
ENG264028-ENG264133-Dynamic_Developer_Function_03-Data_position_1_Bit_position,Security access required,3
ENG264028-ENG264134-Dynamic_Developer_Function_03-Data_position_1_Byte_position,Security access required,3
ENG264028-ENG264135-Dynamic_Developer_Function_03-Data_position_10_Bit_position,Security access required,3
ENG264028-ENG264136-Dynamic_Developer_Function_03-Data_position_10_Byte_position,Security access required,3
ENG264028-ENG264137-Dynamic_Developer_Function_03-Data_position_11_Bit_position,Security access required,3
ENG264028-ENG264138-Dynamic_Developer_Function_03-Data_position_11_Byte_position,Security access required,3
ENG264028-ENG264139-Dynamic_Developer_Function_03-Data_position_12_Bit_position,Security access required,3
ENG264028-ENG264140-Dynamic_Developer_Function_03-Data_position_12_Byte_position,Security access required,3
ENG264028-ENG264141-Dynamic_Developer_Function_03-Data_position_13_Bit_position,Security access required,3
ENG264028-ENG264142-Dynamic_Developer_Function_03-Data_position_13_Byte_position,Security access required,3
ENG264028-ENG264143-Dynamic_Developer_Function_03-Data_position_14_Bit_position,Security access required,3
ENG264028-ENG264144-Dynamic_Developer_Function_03-Data_position_14_Byte_position,Security access required,3
ENG264028-ENG264145-Dynamic_Developer_Function_03-Data_position_15_Bit_position,Security access required,3
ENG264028-ENG264146-Dynamic_Developer_Function_03-Data_position_15_Byte_position,Security access required,3
ENG264028-ENG264147-Dynamic_Developer_Function_03-Data_position_2_Bit_position,Security access required,3
ENG264028-ENG264148-Dynamic_Developer_Function_03-Data_position_2_Byte_position,Security access required,3
ENG264028-ENG264149-Dynamic_Developer_Function_03-Data_position_3_Bit_position,Security access required,3
ENG264028-ENG264150-Dynamic_Developer_Function_03-Data_position_3_Byte_position,Security access required,3
ENG264028-ENG264151-Dynamic_Developer_Function_03-Data_position_4_Bit_position,Security access required,3
ENG264028-ENG264152-Dynamic_Developer_Function_03-Data_position_4_Byte_position,Security access required,3
ENG264028-ENG264153-Dynamic_Developer_Function_03-Data_position_5_Bit_position,Security access required,3
ENG264028-ENG264154-Dynamic_Developer_Function_03-Data_position_5_Byte_position,Security access required,3
ENG264028-ENG264155-Dynamic_Developer_Function_03-Data_position_6_Bit_position,Security access required,3
ENG264028-ENG264156-Dynamic_Developer_Function_03-Data_position_6_Byte_position,Security access required,3
ENG264028-ENG264157-Dynamic_Developer_Function_03-Data_position_7_Bit_position,Security access required,3
ENG264028-ENG264158-Dynamic_Developer_Function_03-Data_position_7_Byte_position,Security access required,3
ENG264028-ENG264159-Dynamic_Developer_Function_03-Data_position_8_Bit_position,Security access required,3
ENG264028-ENG264160-Dynamic_Developer_Function_03-Data_position_8_Byte_position,Security access required,3
ENG264028-ENG264161-Dynamic_Developer_Function_03-Data_position_9_Bit_position,Security access required,3
ENG264028-ENG264162-Dynamic_Developer_Function_03-Data_position_9_Byte_position,Security access required,3
ENG264028-ENG264166-Dynamic_Developer_Function_03-Dynamic_Developer_Function_Groupe_1,Security access required,3
ENG264028-ENG264167-Dynamic_Developer_Function_03-Dynamic_Developer_Function_Groupe_2,Security access required,3
Elapsed Time: 00:13
adpmap-05-5WA-959-436-Q_VSSZZZKM2RR140480-20241020-1502.CSV
;SW:5WA-959-436-Q   HW:5WA-959-436-Q ---  Acc/Start Auth.
;Component:Kessy IOBOX   100 0725, Coding:
;EV_Kessy37w,004024,EV_Kessy37w_004_VW38.rod
;Sunday,20,October,2024,15:02:11:49859
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 629A7348F4C39D2A29F-8036
ENG253038-ENG258893-DevCod_ Search lights-Suchbeleuchtung_ZAT_bei_KL58_aktiv,activated ,5
ENG253038-ENG258265-DevCod_ Search lights-Suchbeleuchtung_ZAT_Beleuchtung_SES_Variante_aktiv,activated ,5
ENG253038-ENG260629-DevCod_ Search lights-Suchbeleuchtung_ZAT_Normierung_aktiv,activated ,5
ENG253038-ENG259779-DevCod_ Search lights-Suchbeleuchtung_ZAT_OpenLoadErkennung_aktiv,not activated ,5
ENG253038-ENG260681-DevCod_ Search lights-Suchbeleuchtung_ZAT_SES_Mode,activated ,5
ENG253096-DevCod_AutomatischeFunktionen,not activated ,6
ENG253395-ENG141964-DevCod_Fahrzeugkonfiguration-Steering alignment,Right ,5
ENG253395-ENG273785-DevCod_Fahrzeugkonfiguration-Transponding_Antennen_Strom_reduziert_aktiv,not active ,5
ENG253143-ENG258965-DevCod_Passive_EntryExit-Toggle-Datalogging_LFDebug_aktiv,not activated ,5
ENG253143-ENG258844-DevCod_Passive_EntryExit-Toggle-Gleichzeitiges_Senden_Innenraumantennen_aktiv,activated ,5
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,6
ENG129029-ENG259793-Easy_close_alignment-VIT_AktivTasteB_Zyklus,1.0 s,6
ENG253331-ENG258816-Par_Automatische_Funktionen-AutomatikFunktionen_Timeout,4320 min,10
ENG253331-ENG260182-Par_Automatische_Funktionen-AutomatikFunktionen_Zyklus_IDGeber_Anwesenheit,300 ms,10
ENG253220-IDE15282-Par_Bedienstellen-Door: driver control section: installation variant,0 ,36
ENG253220-IDE15283-Par_Bedienstellen-Door: front passenger control section: installation variant,0 ,36
ENG253220-IDE15284-Par_Bedienstellen-5th control section: installation variant,5 ,36
ENG253220-IDE15285-Par_Bedienstellen-Fuel filler cap control section: installation variant,5 ,36
ENG253220-IDE15286-Par_Bedienstellen-Rear driver side control section: installation variant,5 ,36
ENG253220-IDE15287-Par_Bedienstellen-Rear passenger side control section: installation variant,5 ,36
ENG253220-ENG259190-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_5teT,3600 min,36
ENG253220-ENG259838-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_BT,3600 min,36
ENG253220-ENG260574-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_FT,0 min,36
ENG253220-ENG261264-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HBFS,3600 min,36
ENG253220-ENG258369-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HFS,3600 min,36
ENG253220-ENG258148-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_Tank,3600 min,36
ENG253220-ENG261229-Par_Bedienstellen-Bedienstelle_Aktivierungsschwelle_Spielschutzzaehler,80 ,36
ENG253220-ENG259917-Par_Bedienstellen-Bedienstelle_Ausschaltzeit_Spielschutz_aktiv,1800 s,36
ENG253220-ENG261227-Par_Bedienstellen-Bedienstelle_Deaktivierung_SchwelleFahrendesFzg,20 km/h,36
ENG253220-ENG261134-Par_Bedienstellen-Bedienstelle_Deaktivierungsschwelle_Spielschutzzaehler,60 ,36
ENG253220-ENG258448-Par_Bedienstellen-Bedienstelle_MaxBetaetigung,120 s,36
ENG253220-ENG259922-Par_Bedienstellen-Bedienstelle_MaxKomfortUnterbrechung,10 ms,36
ENG253220-ENG261271-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_5teT,500 ms,36
ENG253220-ENG259320-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_BT,500 ms,36
ENG253220-ENG259918-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_FT,1500 ms,36
ENG253220-ENG260179-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HBFS,500 ms,36
ENG253220-ENG260090-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HFS,500 ms,36
ENG253220-ENG260565-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_Tank,500 ms,36
ENG253220-ENG261322-Par_Bedienstellen-Bedienstelle_MinBetaetigung_ToggleTaster,140 ms,36
ENG253220-ENG259707-Par_Bedienstellen-Bedienstelle_MinBetaetigung_Verriegelungssensor,140 ms,36
ENG253220-ENG258814-Par_Bedienstellen-Bedienstelle_Reaktivierung_SchwelleStehendesFzg,10 km/h,36
ENG253220-ENG258395-Par_Bedienstellen-Bedienstelle_Reduzierung_Zaehlerstand_Spielschutzzaehler,15420 s,36
ENG253190-ENG258772-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Diagnose,71 ms,35
ENG253190-ENG258701-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Entry,10400 µs,35
ENG253190-ENG261026-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Exit,40400 µs,35
ENG253190-ENG258968-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Naeherung,20400 µs,35
ENG253190-ENG259906-Par_Näherungssensoren-Naeherungssensor_MaxPausenlaenge,10 ms,35
ENG253190-ENG260803-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Diagnose,42 ms,35
ENG253190-ENG259643-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Entry,6200 µs,35
ENG253190-ENG259840-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Exit,24200 µs,35
ENG253190-ENG259205-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Naeherung,12200 µs,35
ENG253190-ENG260098-Par_Näherungssensoren-Verzoegerung_PowerOn_Reset,1960 ms,35
ENG253285-ENG260495-Par_PassiveKomfort-Delay_Reichweitenbegrenzung_Start,0 ms,10
ENG253285-ENG260385-Par_PassiveKomfort-KomfortReichweitenbegr_Timout,75 s,10
ENG253285-ENG261013-Par_PassiveKomfort-PassiveKomfortFunktionen_MaxSignalisierungsdauer,60 s,10
ENG253285-ENG263587-Par_PassiveKomfort-PassiveKomfortFunktionen_Zeitfenster_fuer_Bedienhandlung,800 ms,10
ENG253285-ENG261279-Par_PassiveKomfort-Reichweitenbegrenzung_Zyklus,90 ms,10
ENG253106-ENG258919-Par_ScanStrategie_RetryHandling-anz_RetriesRegistering,1 Num,22
ENG253106-ENG259329-Par_ScanStrategie_RetryHandling-Erste_Warnschwelle_thermische_Überlast,45 °C,22
ENG253106-ENG259473-Par_ScanStrategie_RetryHandling-P2_Pause_zwischen_Transponding_Telegrammen,200 ms,22
ENG253106-ENG259392-Par_ScanStrategie_RetryHandling-Sperrzeit_LFTreiber_nach_thermischer_Ueberlast,5.0 s,22
ENG253106-ENG263515-Par_ScanStrategie_RetryHandling-t_CANSignalDelayAfterSleep,30 ms,22
ENG253106-ENG258479-Par_ScanStrategie_RetryHandling-t_LFDebug_Nachsignaslisierung,100 ms,22
ENG253106-ENG263591-Par_ScanStrategie_RetryHandling-Temperaturschaltschwelle_LF_Wavetable,100 °C,22
ENG253106-ENG276176-Par_ScanStrategie_RetryHandling-Timeout_Grundwert_RetryRegistering,52 ms,22
ENG253106-ENG276194-Par_ScanStrategie_RetryHandling-Timeout_Inkrementwert_RetryRegistering,7 ms,22
ENG253106-ENG261110-Par_ScanStrategie_RetryHandling-Verzoegerung_LFSenden_nach_Weckleitungziehen,0 ms,22
ENG253106-ENG260133-Par_ScanStrategie_RetryHandling-Zweite_Warnschwelle_thermische_Überlast,65 °C,22
ENG253086-MAS18911-Passive_Komfort-Convenience closing by locking using door handle active,activated ,5
ENG253086-ENG280093-Passive_Komfort-Noise_filter_aktiv,activated ,5
ENG253086-ENG261176-Passive_Komfort-Passive_Komfort_Oeffnen_aktiv,not activated ,5
ENG253086-ENG259864-Passive_Komfort-Passive_Komfort_Togglen_aktiv,not activated ,5
ENG253352-ENG259594-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Abdimmen,0.0 ,30
ENG253352-ENG259617-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Aufdimmen,0.0 ,30
ENG253352-ENG261228-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ausschalten_KL15,10 min,30
ENG253352-ENG258605-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_0Prozent_Dimmkurve,0.0 %,30
ENG253352-ENG258785-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Deltawert_50Prozent_Dimmkurve,50.0 %,30
ENG253352-ENG263542-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Fehlerdimmwert,80 %,30
ENG253352-ENG260556-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Nennspannung,13.0 V,30
ENG253352-ENG258781-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_OffsetDimmwert,1.0 ,30
ENG253352-ENG259791-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Deltawert_100Prozent_Dimmkurve,100.0 %,30
ENG253287-ENG261242-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES1,6.0 %,32
ENG253287-ENG260274-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES2,2.0 %,32
ENG253287-ENG258981-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES1,4.0 %,32
ENG253287-ENG260137-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES2,1.0 %,32
ENG253287-ENG259846-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES1,60.0 %,32
ENG253287-ENG261362-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES2,60.0 %,32
ENG253287-ENG258809-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_1,0 %,32
ENG253287-ENG258501-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_2,0 %,32
ENG253287-ENG260497-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_1,80 %,32
ENG253287-ENG258157-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_2,100 %,32
ENG253287-ENG261138-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES1,100.0 %,32
ENG253287-ENG258211-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES2,100.0 %,32
ENG253287-ENG261183-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_faktor,0.1 ,32
ENG253287-ENG259175-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_Offset,10.0 Num,32
ENG253287-ENG261051-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Fall_OFF,500 ms,32
ENG253287-ENG260479-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_OFF,0 ms,32
ENG253287-ENG258704-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_ON,80 ms,32
ENG253287-ENG260922-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Rise_ON,100 ms,32
ENG253287-ENG260304-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Fall_OFF,1000 ms,32
ENG253287-ENG258413-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_OFF,0 ms,32
ENG253287-ENG260729-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_ON,500 ms,32
ENG253287-ENG258296-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Rise_ON,0 ms,32
ENG253287-ENG258477-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES1,10.0 %,32
ENG253287-ENG259506-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES2,4.0 %,32
ENG253287-ENG258902-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES1,4.0 %,32
ENG253287-ENG260830-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES2,1.0 %,32
Elapsed Time: 00:05
adpmap-08-5WA-907-727-BC_VSSZZZKM2RR140480-20241020-1502.CSV
;SW:5WA-907-727-BC   HW:5WA-907-727-BC ---  Auto HVAC
;Component:Climatronic   H02 0462, Coding:000100010011020010100010101011110000112100200000000000000000
;EV_ACClimaBHBVW38X,005069,EV_ACClimaBHBVW38X_SE38.rod
;Sunday,20,October,2024,15:02:39:49859
;VCID: 127A638844E3ADAAF9F-8046
IDE00001-ENG128289-Production mode-Air_condition_compressor_deactivate,not active ,3
IDE00001-ENG128290-Production mode-Battery_cooling_and_heating_deactivate,not active ,3
IDE00001-ENG128291-Production mode-ClearResetEmissionRelated-DiagnosticInformation_Mode$04,not active ,3
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01476-Store air recirculation setting with terminal 15 OFF,Service life-dependent store ,1
IDE01479-Gear ratio of engine - A/C compressor,1.2 ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01483-Blower voltage with voice control,not activated ,1
IDE01488-Auxiliary heating retrofit without CAN,not installed ,1
IDE01493-Sensitivity of air quality sensor,Medium ,1
IDE01503-Running time of basic setting for compressor break-in,120 s,1
IDE01536-Post heating of auxiliary heating,0 min,1
IDE02371-Time until seat heating performance is reduced from stage 3 to stage 2,0 min,1
IDE02372-Time until seat heating performance is reduced from stage 2 to stage 1,0 min,1
IDE02744-Steering wheel heating,long_push ,1
IDE03176-Duration of compressor run in,60 s,1
IDE04074-Driving program,not installed ,1
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,10
IDE04927-MAS12610-Window heater-Activation of wiper arm heater,-2.00 °C,10
IDE04927-ENG263527-Window heater-Config_heating_voltage_request,No_set_point_voltage ,10
IDE04927-ENG263525-Window heater-Heating_rear_window_activation_time,320 s,10
IDE04927-ENG263512-Window heater-Heating_rear_window_cutoff_temperature,35.00 °C,10
IDE04927-ENG263556-Window heater-Heating_rear_window_temperature_activation_time,active ,10
IDE04927-ENG263570-Window heater-Window_heating_front_activation_time_pause,320 s,10
IDE04927-ENG263505-Window heater-Window_heating_front_cutoff_temperature,35.00 °C,10
IDE04927-ENG263589-Window heater-Window_heating_front_maximum_temperature_activation_time,1200 s,10
IDE04927-ENG263529-Window heater-Window_heating_front_temperature_activation_time,active ,10
IDE06089-ENG263584-Seat heater level current consumption allocation-Config_seat_heating_high_voltage_request,Sollspannungsanforderung 14.7 ,17
IDE06089-ENG263533-Seat heater level current consumption allocation-Config_seat_heating_low_voltage_request,Keine Spannungsanforderung ,17
IDE06089-ENG263526-Seat heater level current consumption allocation-Seat_heating_correction_of_temperature_regulation_on_heat_flow,0.0 °C,17
IDE06089-ENG263552-Seat heater level current consumption allocation-Seat_heating_filter_constant_for_heat_flow,1 s,17
IDE06089-ENG263578-Seat heater level current consumption allocation-Seat_heating_offset_voltage,15.7 V,17
IDE06089-ENG263544-Seat heater level current consumption allocation-Seat_heating_stage_1_lower_threshold,21.0 °C,17
IDE06089-ENG263507-Seat heater level current consumption allocation-Seat_heating_stage_1_upper_threshold,23.0 °C,17
IDE06089-ENG263592-Seat heater level current consumption allocation-Seat_heating_stage_2_lower_threshold,21.0 °C,17
IDE06089-ENG263559-Seat heater level current consumption allocation-Seat_heating_stage_2_upper_threshold,23.0 °C,17
IDE06089-ENG263539-Seat heater level current consumption allocation-Seat_heating_stage_3_lower_threshold,37.0 °C,17
IDE06089-ENG263554-Seat heater level current consumption allocation-Seat_heating_stage_3_upper_threshold,39.0 °C,17
IDE06089-ENG263536-Seat heater level current consumption allocation-Seat_heating_stage_4_lower_threshold,37.0 °C,17
IDE06089-ENG263549-Seat heater level current consumption allocation-Seat_heating_stage_4_upper_threshold,39.0 °C,17
IDE06089-ENG263566-Seat heater level current consumption allocation-Seat_heating_stage_5_lower_threshold,54.0 °C,17
IDE06089-ENG263597-Seat heater level current consumption allocation-Seat_heating_stage_5_upper_threshold,56.0 °C,17
IDE06089-ENG263562-Seat heater level current consumption allocation-Seat_heating_stage_6_lower_threshold,54.0 °C,17
IDE06089-ENG263524-Seat heater level current consumption allocation-Seat_heating_stage_6_upper_threshold,56.0 °C,17
IDE06097-Target temperature of A/C - heater function via remote control,22.0 °C,1
IDE06544-Speed shut-off threshold for compressor break-in (engine speed),1500 l/min,1
IDE06545-Blower voltage for production routines,6.0 V,1
IDE06593-Air recirculation for production routines,No effect ,1
IDE07108-A/C styles,Readout ,1
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,70 s,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,41 s,2
IDE07301-Remote start function: activation of seat heating,Seat heater request driver side ,1
IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
IDE07304-Remote start function: activation of seat ventilation,activated ,1
IDE07305-Rem. start funct.: activat.temper. of seat heating,25.0 °C,1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation,32.0 °C,1
IDE07307-Remote start function: activation stage of seat heating,4 ,1
IDE07308-Remote start function: activation stage of seat ventilation,4 ,1
IDE07398-Blower logic with manual adjustment,Fan setting: absolute ,1
IDE07418-Additional filter,not installed ,1
IDE07585-Hand heater function during cold start,active ,1
IDE07865-Automatic activation of front windshield defroster at MAX-Defrost,not active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE07951-Time until head area heater performance is reduced from stage 3 to stage 2,0 min,1
IDE07952-Time until head area heater performance is reduced from stage 2 to stage 1,0 min,1
IDE08356-ENG125698-Left seat backrest fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08356-ENG125700-Left seat backrest fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08356-ENG125697-Left seat backrest fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08356-ENG125699-Left seat backrest fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08356-ENG125701-Left seat backrest fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08356-ENG134731-Left seat backrest fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08356-ENG125695-Left seat backrest fan 1-Overvoltage_treshold,16 V,10
IDE08356-ENG125696-Left seat backrest fan 1-Undervoltage_treshold,9 V,10
IDE08357-ENG125698-Left seat backrest fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08357-ENG125700-Left seat backrest fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08357-ENG125697-Left seat backrest fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08357-ENG125699-Left seat backrest fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08357-ENG125701-Left seat backrest fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08357-ENG134731-Left seat backrest fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08357-ENG125695-Left seat backrest fan 2-Overvoltage_treshold,16 V,10
IDE08357-ENG125696-Left seat backrest fan 2-Undervoltage_treshold,9 V,10
IDE08358-ENG125698-Left seat cushion fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08358-ENG125700-Left seat cushion fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08358-ENG125697-Left seat cushion fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08358-ENG125699-Left seat cushion fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08358-ENG125701-Left seat cushion fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08358-ENG134731-Left seat cushion fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08358-ENG125695-Left seat cushion fan 1-Overvoltage_treshold,16 V,10
IDE08358-ENG125696-Left seat cushion fan 1-Undervoltage_treshold,9 V,10
IDE08359-ENG125698-Left seat cushion fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08359-ENG125700-Left seat cushion fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08359-ENG125697-Left seat cushion fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08359-ENG125699-Left seat cushion fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08359-ENG125701-Left seat cushion fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08359-ENG134731-Left seat cushion fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08359-ENG125695-Left seat cushion fan 2-Overvoltage_treshold,16 V,10
IDE08359-ENG125696-Left seat cushion fan 2-Undervoltage_treshold,9 V,10
IDE08360-ENG125698-Right seat backrest fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08360-ENG125700-Right seat backrest fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08360-ENG125697-Right seat backrest fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08360-ENG125699-Right seat backrest fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08360-ENG125701-Right seat backrest fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08360-ENG134731-Right seat backrest fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08360-ENG125695-Right seat backrest fan 1-Overvoltage_treshold,16 V,10
IDE08360-ENG125696-Right seat backrest fan 1-Undervoltage_treshold,9 V,10
IDE08361-ENG125698-Right seat backrest fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08361-ENG125700-Right seat backrest fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08361-ENG125697-Right seat backrest fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08361-ENG125699-Right seat backrest fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08361-ENG125701-Right seat backrest fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08361-ENG134731-Right seat backrest fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08361-ENG125695-Right seat backrest fan 2-Overvoltage_treshold,16 V,10
IDE08361-ENG125696-Right seat backrest fan 2-Undervoltage_treshold,9 V,10
IDE08362-ENG125698-Right seat cushion fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08362-ENG125700-Right seat cushion fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08362-ENG125697-Right seat cushion fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08362-ENG125699-Right seat cushion fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08362-ENG125701-Right seat cushion fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08362-ENG134731-Right seat cushion fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08362-ENG125695-Right seat cushion fan 1-Overvoltage_treshold,16 V,10
IDE08362-ENG125696-Right seat cushion fan 1-Undervoltage_treshold,9 V,10
IDE08363-ENG125698-Right seat cushion fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08363-ENG125700-Right seat cushion fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08363-ENG125697-Right seat cushion fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08363-ENG125699-Right seat cushion fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08363-ENG125701-Right seat cushion fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08363-ENG134731-Right seat cushion fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08363-ENG125695-Right seat cushion fan 2-Overvoltage_treshold,16 V,10
IDE08363-ENG125696-Right seat cushion fan 2-Undervoltage_treshold,9 V,10
IDE10118-Fan speed reduction for telephony,activated ,1
IDE10278-Behavior of compressor during moderate outside temperatures,not active ,1
IDE11935-Personalization,activated ,1
IDE12229-Filtering of interior air: store,Service life-dependent store ,1
IDE13371-Interior humidity sensor: sensitivity,Medium ,1
IDE13676-Remote start function: rear window defogger,activated ,1
IDE13677-Remote start function: seat climate control takeover,activated ,1
IDE14087-Time until seat heat recovery within the maximum level,120 min,1
IDE15635-Number of interruptions permitted during compressor run-in,0 ,1
IDE80009-Analysis 9,not activated ,1
IDE80010-Analysis 10,not activated ,1
IDE80011-Analysis 11,not activated ,1
IDE80251-MAS09644-Head area heater-Vent temperature,0 ,1
IDE80251-MAS10293-Head area heater-Fan speed,0 ,1
MAS01651-Display and control unit: rear,Temperature ,1
MAS06414-Temperature tuning,normal tuning ,1
MAS06415-Blower adjustment,normal tuning ,1
MAS06416-Blower display in auto operation,not activated ,1
MAS06417-Amplified overshoots heater operation,not activated ,1
MAS14860-Remote start function: windshield defogger takeover,activated ,1
MAS14861-Remote start function: windshield defogger,activated ,1
MAS19885-Remote start function: rear windshield heater transfer,activated ,1
MAS19886-Interior temperature sensor: after-run time,180 s,2
ENG263483-AC_evaporator_temperature_offset,-0.70 K,1
ENG276128-air_recirculation_deactivate_at_open_sunroof,not activated ,1
ENG263479-Auto-Toggle,not activated ,1
ENG263474-ENG263585-Development_Messages_Mode_Activation-General_Messages,0 ,18
ENG263474-ENG263519-Development_Messages_Mode_Activation-LIN_1_Messages,0 ,18
ENG263474-ENG263517-Development_Messages_Mode_Activation-LIN_2_Messages,0 ,18
ENG263474-ENG263537-Development_Messages_Mode_Activation-LIN_3_Messages,0 ,18
ENG263474-ENG263573-Development_Messages_Mode_Activation-LIN_4_Messages,0 ,18
ENG263474-ENG263548-Development_Messages_Mode_Activation-LIN_5_Messages,0 ,18
ENG263474-ENG263518-Development_Messages_Mode_Activation-LIN_6_Messages,0 ,18
ENG263474-ENG263550-Development_Messages_Mode_Activation-LIN_7_Messages,0 ,18
ENG263474-ENG263508-Development_Messages_Mode_Activation-LIN_8_Messages,0 ,18
ENG263440-Entwicklungs-ID für Entwicklungszwecke freischalten,0 ,2
ENG153885-Knockout_test_mode,0 ,1
ENG263490-manuel_air_recirculation_deacivate_AUTO_mode,activated ,1
ENG263452-OnBoardDiagnose für Entwicklungszwecke freischalten,not active ,1
ENG125614-Reset_Blower_1_Backrest_Left,not active ,1
ENG125615-Reset_Blower_1_Backrest_Right,not active ,1
ENG125613-Reset_Blower_1_Cushion_Left,not active ,1
ENG125616-Reset_Blower_1_Cushion_Right,not active ,1
ENG125623-Reset_Blower_2_Backrest_Left,not active ,1
ENG125624-Reset_Blower_2_Backrest_Right,not active ,1
ENG125621-Reset_Blower_2_Cushion_Left,not active ,1
ENG125622-Reset_Blower_2_Cushion_Right,not active ,1
ENG263461-Schedule-Link_Switsh,according_coding_brand ,1
ENG263450-seat_dependent_climatisation,not activated ,1
ENG263443-seatheatin_function_switch,lear_seatheating_function ,1
ENG263458-winterfunction,not installed ,1
Elapsed Time: 00:27
adpmap-09-5WA-937-086-BS_VSSZZZKM2RR140480-20241020-1504.CSV
;SW:5WA-937-086-BS   HW:5WA-937-086-BA ---  Cent. Elect.
;Component:BCM37w_M1134 0183, Coding:
;EV_BCM37w,007001,EV_BCM37w_007_AU38.rod
;Sunday,20,October,2024,15:04:36:49859
;VCID: 2314364CAB59D422629-8076
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE00001-ENG259333-Production mode-pa_ambiente_aussenlicht_pmode,not active ,3
IDE00001-ENG258242-Production mode-pa_auto_abschaltung_pmode,not active ,3
IDE00001-ENG263594-Production mode-pa_klemme_15_pmode,not active ,3
IDE00001-ENG263561-Production mode-pa_klemme_50_pmode,not active ,3
IDE00001-ENG260387-Production mode-pa_sitzpneumatik_pmode,not active ,3
IDE00001-ENG281100-Production mode-Remotestart_Pmode,not active ,3
IDE00301-Mileage,0 km,4
IDE01550-Service position,145.010845 °,2
IDE02455-ENG116601-Light function "Coming/Leaving Home"-Coming Home Verbaustatus,automatic ,2
IDE02455-ENG260981-Light function "Coming/Leaving Home"-Darstellung Coming-home Verlauf,not active ,2
IDE02455-ENG261352-Light function "Coming/Leaving Home"-Darstellung Leaving-home Verlauf,not active ,2
IDE02455-ENG115657-Light function "Coming/Leaving Home"-Leaving-Home Verbausstatus,Enabled ,2
IDE02455-ENG115863-Light function "Coming/Leaving Home"-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,2
IDE02455-ENG116602-Light function "Coming/Leaving Home"-Menuesteuerung Coming Home Werkseinstellung,active ,2
IDE02455-ENG116606-Light function "Coming/Leaving Home"-Menuesteuerung Leaving-home Freischaltung per BAP,active ,2
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE02711-ENG112304-Rear wiper-Heckwischer,1Draht_Heckwischer ,8
IDE02711-ENG258487-Rear wiper-Heckwischer_Kaltstart,Heckwischerstopp bei Wiederstart und Erststart ,8
IDE02711-ENG289598-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall LSS AUS,10 s,8
IDE02711-ENG261056-Rear wiper-Modus_Heckintervall,statische Intervallpausenzeit ,8
IDE02711-ENG259069-Rear wiper-Rueckfahrwischen_Temp,OFF ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE03787-Activate left/right hand drive switch-over,Unknown (255),1
IDE05534-ENG116609-Headlamp washer system-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,7
IDE05534-ENG115769-Headlamp washer system-SRA bei Waschwassermangel,active ,7
IDE05534-ENG115767-Headlamp washer system-SRA Einweichpausenzeit,0 ms,7
IDE05534-ENG115768-Headlamp washer system-SRA Nachwaschzeit,0 ms,7
IDE05534-ENG116611-Headlamp washer system-SRA Pausenzeit,10000 ms,7
IDE05534-ENG258416-Headlamp washer system-SRA Untersetzung Init,0 ,7
IDE05534-ENG116610-Headlamp washer system-SRA Verzoegerungszeit,0 ms,7
IDE05534-ENG115766-Headlamp washer system-SRA Waschzeit,2000 ms,7
IDE05822-Anti-theft alarm system vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 08 07 00 43 53 0A 78 01 14 0A 33 81 33 0C FF 00 00 01 C3 16 06 00 0F 1E 00 84 05 41 F7 65 23 65 53 57 9B 26 44 3F 3A 69 58 85 2E 0A A3 02 7A 06 56 00 0F 17 00 88 0A 2F F7 68 0F E3 42 87 1B 06 34 3F 3A 69 58 83 08 0A A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 06 24 3F 3A 69 47 83 08 0A A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 06 24 3F 3A 69 58 82 05 0A A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 55 53 57 9B 26 24 0C FA 0A 34 85 2E 0A A3 21 03 00 02 02 02 02 02 02 B1 31 A2 2A 1C ,172
IDE06274-MAS05958-Light functions for special-purpose vehicle-intermittent low beam,Low beam ,4
IDE06274-MAS05960-Light functions for special-purpose vehicle-intermittent high beam,High Beam ,4
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,255 min,2
IDE07161-temporary VIN,Conditions not correct or request sequence error,2
IDE07356-Position during interval mode,7.010982 °,2
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,2
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,2
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,2
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,2
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,2
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,2
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,2
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,2
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,2
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,2
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,2
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,2
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,2
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,2
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,2
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,2
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,2
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,2
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,2
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,2
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,2
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,2
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,2
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,present ,9
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,500 ms,9
IDE08786-ENG259537-Assistance light functions-Maskierung_Regenlichtmenü,not active ,9
IDE09377-IDE00761-Multi contour seat driver's side-Run-on time,No Response From Subnet Component,9
IDE09377-IDE03006-Multi contour seat driver's side-Running time of massage function,No Response From Subnet Component,9
IDE09377-IDE03007-Multi contour seat driver's side-Component location,No Response From Subnet Component,9
IDE09377-IDE03099-Multi contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09377-IDE03100-Multi contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09378-IDE00761-Multicontour seat passenger side-Run-on time,No Response From Subnet Component,9
IDE09378-IDE03006-Multicontour seat passenger side-Running time of massage function,No Response From Subnet Component,9
IDE09378-IDE03007-Multicontour seat passenger side-Component location,No Response From Subnet Component,9
IDE09378-IDE03099-Multicontour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09378-IDE03100-Multicontour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,9
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,No Response From Subnet Component,9
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,9
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,No Response From Subnet Component,9
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE09767-ENG133381-Position lamps-Bedingungen zur Parklichtbegrenzung,Switch-off due to energy management ,7
IDE09767-ENG133380-Position lamps-Bedingungen zur Standlichtbegrenzung,Switch-off due to energy management ,7
IDE09767-ENG137034-Position lamps-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,7
IDE09767-ENG115862-Position lamps-Lichtwarnungsverhalten,klemmenabhaengig ,7
IDE09767-ENG115859-Position lamps-Parklicht ueber LSS aktiviert,One-sided ,7
IDE09767-ENG126816-Position lamps-Standlicht aus,active ,7
IDE09767-ENG115829-Position lamps-Standlichtreduzierung mit beidseitigem Parklicht,active ,7
IDE09767-ENG133383-Position lamps-Standlicht-Verfügbarkeit,24 s,7
IDE10283-Key identification: transponder ID,Conditions not correct or request sequence error,7
IDE10298-Alternating park position 1,0.010989 °,2
IDE10299-Alternating park position 2,7.010982 °,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
IDE10844-Control module rear lid opening: duration status query,4960 ms,2
IDE10845-Control module rear lid opening: vehicle type-,00 ,12
IDE10845-ENG258964-Control module rear lid opening: vehicle type-p_a_p_mode_aktivieren_vip,00 ,12
IDE10845-ENG259328-Control module rear lid opening: vehicle type-p_t_delay_VIP_Freigabe_ZV_Ansteuerung,0 s,12
IDE10845-ENG260538-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell,0 ms,12
IDE10845-ENG259913-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell_offen,0 ms,12
IDE10845-ENG260941-Control module rear lid opening: vehicle type-p_t_VIP_Sperrzeit_Schlüsselsuche,0 s,12
IDE10845-ENG259196-Control module rear lid opening: vehicle type-p_t_VIP_Verzoegerung,0 ms,12
IDE10845-ENG259996-Control module rear lid opening: vehicle type-p_v_VIP_aktiv,0 km/h,12
IDE10845-ENG261214-Control module rear lid opening: vehicle type-p_v_VIP_deaktiv,2 km/h,12
IDE12119-Garage door opener: frequency range of bi-directional communication,No Response From Subnet Component,12
IDE12120-Garage door opener: piloted parking,No Response From Subnet Component,12
IDE12121-Garage door opener: vehicle variant,No Response From Subnet Component,12
IDE12122-Garage door opener: continuous transmission mode for level measurement,No Response From Subnet Component,12
IDE12302-SFT00022-Identification of sub-bus participant-Steering column electronics systems,old ,6
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,old ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,old ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,old ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,old ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,old ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,old ,6
IDE12302-SFT271909-Identification of sub-bus participant-left tail lamp 1,old ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,old ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,old ,6
IDE12302-SFT271950-Identification of sub-bus participant-Rear lid opener control module,New ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heater,old ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heater,old ,6
IDE12302-SFT272014-Identification of sub-bus participant-Control head for driving and comfort functions,New ,6
IDE12302-SFT272057-Identification of sub-bus participant-Valve block 1 in front seat driver side,old ,6
IDE12302-SFT272061-Identification of sub-bus participant-Valve block 1 in front seat passenger side,old ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,old ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,old ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,old ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,old ,6
IDE12302-SFT272121-Identification of sub-bus participant-Control unit 2 for driving and convenience functions,old ,6
IDE12302-SFT272142-Identification of sub-bus participant-left tail lamp 2,old ,6
IDE12302-SFT272143-Identification of sub-bus participant-Right rear tail lamp 1,old ,6
IDE12302-SFT272144-Identification of sub-bus participant-Right rear tail lamp 2,old ,6
IDE12302-SFT272221-Identification of sub-bus participant-Radio receiver for remote start,old ,6
IDE12302-SFT272238-Identification of sub-bus participant-Wiper motor control unit 2,old ,6
IDE12302-SFT272272-Identification of sub-bus participant-Virtual pedal door opening: rear driver side,old ,6
IDE12302-SFT272286-Identification of sub-bus participant-Virtual pedal door opening: rear passenger side,old ,6
IDE12488-Antenna 1 for short-range communication,No Response From Subnet Component,6
IDE12489-Antenna 2 for short-range communication,No Response From Subnet Component,6
IDE13065-Left tail lamp 1: parameter set,No Response From Subnet Component,6
IDE13066-Left tail lamp 2: parameter set,No Response From Subnet Component,6
IDE13067-Right tail lamp 1: parameter set,No Response From Subnet Component,6
IDE13068-Right tail lamp 2: parameter set,No Response From Subnet Component,6
IDE13391-ENG246968-BAP function status-CHo_LHo_Nachlauf,0 ms,16
IDE13391-ENG115656-BAP function status-Coming Home Leuchten,Low beam ,16
IDE13391-ENG116604-BAP function status-Coming-home Einschaltereignis,Drivers door open ,16
IDE13391-ENG116608-BAP function status-Helligkeitsschwelle Forward-Messung,60 lx,16
IDE13391-ENG116605-BAP function status-Helligkeitsschwelle Infrarot-Messung,800 lx,16
IDE13391-ENG116603-BAP function status-Menueeinstellung Cominghome,10 seconds ,16
IDE13391-ENG258918-BAP function status-Menueeinstellung Cominghome bei Tag,not active ,16
IDE13391-ENG259258-BAP function status-Menueeinstellung Leaving-home bei Tag,not active ,16
IDE13391-ENG116607-BAP function status-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,16
IDE13391-ENG258405-BAP function status-Tagfahrlicht mit CHO bei Tag in Stellung AUTO,not active ,16
IDE13391-ENG259717-BAP function status-Tagfahrlicht mit LHO bei Tag in Stellung AUTO,not active ,16
IDE15901-Direct entry keys,not installed ,2
IDE15902-MAS10541-rotary light switch-Light rotary switch with fog light,Yes ,4
IDE15902-MAS10542-rotary light switch-Light rotary switch with fog tail light,Yes ,4
IDE15902-MAS10543-rotary light switch-Light rotary sw. with AFL,Yes ,4
IDE15902-MAS10544-rotary light switch-Light rotary switch with park. light pos.,Yes ,4
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer,No Response From Subnet Component,4
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,4
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung,No Response From Subnet Component,4
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle,No Response From Subnet Component,4
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle,No Response From Subnet Component,4
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf,No Response From Subnet Component,4
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m,No Response From Subnet Component,4
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o,No Response From Subnet Component,4
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u,No Response From Subnet Component,4
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,4
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,4
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m,No Response From Subnet Component,4
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o,No Response From Subnet Component,4
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u,No Response From Subnet Component,4
IDE80008-ENG259691-Analysis 8-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,4
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage,No Response From Subnet Component,4
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,4
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,4
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,4
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung,No Response From Subnet Component,4
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,4
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,4
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,4
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung,No Response From Subnet Component,4
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle,No Response From Subnet Component,4
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle,No Response From Subnet Component,4
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf,No Response From Subnet Component,4
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m,No Response From Subnet Component,4
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o,No Response From Subnet Component,4
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u,No Response From Subnet Component,4
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,4
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,4
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m,No Response From Subnet Component,4
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o,No Response From Subnet Component,4
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u,No Response From Subnet Component,4
IDE80013-ENG259691-Analysis 13-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,4
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage,No Response From Subnet Component,4
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,4
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,4
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung,No Response From Subnet Component,4
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,4
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,4
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,4
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,4
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,4
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,4
IDE80016-Analysis 16,No Response From Subnet Component,4
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM,No Response From Subnet Component,4
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO,No Response From Subnet Component,4
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU,No Response From Subnet Component,4
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH,No Response From Subnet Component,4
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM,No Response From Subnet Component,4
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO,No Response From Subnet Component,4
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU,No Response From Subnet Component,4
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH,No Response From Subnet Component,4
IDE80017-ENG289601-Analysis 17-Offset_PP1,No Response From Subnet Component,4
IDE80017-ENG289602-Analysis 17-Offset_PP2,No Response From Subnet Component,4
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM,No Response From Subnet Component,4
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO,No Response From Subnet Component,4
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU,No Response From Subnet Component,4
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH,No Response From Subnet Component,4
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO,No Response From Subnet Component,4
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU,No Response From Subnet Component,4
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH,No Response From Subnet Component,4
IDE80017-ENG289603-Analysis 17-Offset_T1,No Response From Subnet Component,4
IDE80017-ENG289604-Analysis 17-Offset_T2,No Response From Subnet Component,4
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy,No Response From Subnet Component,4
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout,No Response From Subnet Component,4
IDE80017-ENG133491-Analysis 17-p_longpush_time,No Response From Subnet Component,4
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,4
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei,No Response From Subnet Component,4
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins,No Response From Subnet Component,4
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,4
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier,No Response From Subnet Component,4
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,4
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,4
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,4
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,4
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,4
IDE80017-ENG133465-Analysis 17-s_MaxIntervall,No Response From Subnet Component,4
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung,No Response From Subnet Component,4
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,4
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung,No Response From Subnet Component,4
IDE80017-ENG133468-Analysis 17-s_Sitzvariante,No Response From Subnet Component,4
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,4
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,4
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u,No Response From Subnet Component,4
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o,No Response From Subnet Component,4
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM,No Response From Subnet Component,4
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU,No Response From Subnet Component,4
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH,No Response From Subnet Component,4
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM,No Response From Subnet Component,4
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO,No Response From Subnet Component,4
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU,No Response From Subnet Component,4
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH,No Response From Subnet Component,4
IDE80018-ENG289601-Analysis 18-Offset_PP1,No Response From Subnet Component,4
IDE80018-ENG289602-Analysis 18-Offset_PP2,No Response From Subnet Component,4
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM,No Response From Subnet Component,4
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO,No Response From Subnet Component,4
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU,No Response From Subnet Component,4
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH,No Response From Subnet Component,4
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO,No Response From Subnet Component,4
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU,No Response From Subnet Component,4
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH,No Response From Subnet Component,4
IDE80018-ENG289603-Analysis 18-Offset_T1,No Response From Subnet Component,4
IDE80018-ENG289604-Analysis 18-Offset_T2,No Response From Subnet Component,4
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO,No Response From Subnet Component,4
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy,No Response From Subnet Component,4
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout,No Response From Subnet Component,4
IDE80018-ENG133491-Analysis 18-p_longpush_time,No Response From Subnet Component,4
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,4
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei,No Response From Subnet Component,4
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins,No Response From Subnet Component,4
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,4
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier,No Response From Subnet Component,4
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,4
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,4
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,4
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,4
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,4
IDE80018-ENG133465-Analysis 18-s_MaxIntervall,No Response From Subnet Component,4
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung,No Response From Subnet Component,4
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,4
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung,No Response From Subnet Component,4
IDE80018-ENG133468-Analysis 18-s_Sitzvariante,No Response From Subnet Component,4
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,4
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,4
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u,No Response From Subnet Component,4
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u,No Response From Subnet Component,4
MAS05055-lower turn position,7.505487 °,2
MAS05056-upper turn position,145.010845 °,2
MAS05807-ENG264052-Coding-Abparken nach Stop Haubenkontak (1bit),On ,3
MAS05807-ENG264068-Coding-adaptive Nachwischzyklen SRA (1bit),OFF ,3
MAS05807-ENG264069-Coding-APS bei Abparken (1bit),On ,3
MAS05807-ENG264070-Coding-APS bei Klemme 15 Wechsel (1bit),On ,3
MAS05807-ENG264071-Coding-APS für 100 Zyklen deaktiv (1bit),On ,3
MAS05807-ENG264072-Coding-APS2 Verlassen bei Geschwindigkeit (1bit),On ,3
MAS05807-ENG264178-Coding-geräusch optimierte Wischkennlinie (1bit),OFF ,3
MAS05807-ENG264181-Coding-langsames Abparken (1bit),OFF ,3
MAS05807-ENG264190-Coding-Produktionsmodus möglich (1bit),On ,3
MAS05807-ENG264192-Coding-Regensensoraktivierung über Fahrfreigabe (1bit),On ,3
MAS05807-ENG264194-Coding-Schleppfunktion Poti (1bit),On ,3
MAS05807-ENG264195-Coding-schnelles Tippwischen (1bit),On ,3
MAS05807-ENG264271-Coding-softe Geschwindigkeitsrückschaltung (1bit),OFF ,3
MAS05807-ENG264272-Coding-Start bei Klemme 15 EIN (1bit),OFF ,3
MAS05807-ENG264274-Coding-Stop bei Haubenkontakt (1bit),On ,3
MAS05807-ENG264275-Coding-Stop bei Klemme 15 AUS (1bit),On ,3
MAS05807-ENG264276-Coding-Tränenwischen (1bit),On ,3
MAS05807-ENG264279-Coding-v-abhängige Wischstufenrückschaltung (1bit),On ,3
MAS05807-ENG264280-Coding-variable Intervallwischgeschwindigkeit (1bit),OFF ,3
MAS05894-IDE13022-Engine run on-Function activation,not active ,4
MAS05894-MAS13391-Engine run on-Delay time timer,0 ms,4
MAS07146-MAS13125-Button 1-Function of button 1,not coded/not installed ,1
MAS07146-MAS13128-Button 1-Indicator lamp button 1,installed ,1
MAS07147-MAS13129-Button 2-Function of button 2,not coded/not installed ,1
MAS07147-MAS13131-Button 2-Indicator lamp button 2,installed ,1
MAS07148-MAS13132-Button 3-Function of button 3,not coded/not installed ,1
MAS07148-MAS13134-Button 3-Indicator lamp button 3,installed ,1
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 1E ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,3500 lx,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,Medium ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,3800 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,3500 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
MAS09325-IDE13878-Daytime running lamps-Activation: daytime running lights,Daytime running lamps ,8
MAS09325-MAS09335-Daytime running lamps-Daytime running lights/parking light,not active ,8
MAS09325-MAS16273-Daytime running lamps-Speed warning active: rear fog lamps,0 km/h,8
MAS09325-MAS21314-Daytime running lamps-Daytime running indicator lamp,not active ,8
MAS09325-ENG142193-Daytime running lamps-Geschwindigkeitsabhaengiges TFL,0 km/h,8
MAS09325-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,8
MAS09325-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,8
MAS09325-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO,active ,8
MAS09325-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,8
MAS09325-ENG142192-Daytime running lamps-TFL_Abschaltung_ueber_Geschwindigkeit,not active ,8
MAS09325-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,8
MAS12382-MAS06760-Dynamic turn signal control-Emergency flashers in roll mode,not active ,8
MAS12382-MAS07029-Dynamic turn signal control-Crash flashing,not active ,8
MAS12382-MAS07032-Dynamic turn signal control-Emergency flashing,not active ,8
MAS12382-MAS07033-Dynamic turn signal control-Panic flashing,not active ,8
MAS12382-MAS07034-Dynamic turn signal control-Theft flashing,not active ,8
MAS12382-MAS07036-Dynamic turn signal control-Garage door opener adaptation flashing,not active ,8
MAS12382-MAS07041-Dynamic turn signal control-Taxi alarm flashing,not active ,8
MAS12382-MAS07044-Dynamic turn signal control-Rear lid opening angle adaptation flashing,not active ,8
MAS12382-MAS12781-Dynamic turn signal control-Telematic blinking or blinking by positioning assistant,not active ,8
MAS12382-MAS14169-Dynamic turn signal control-Confirmation flashing of the central locking system when unlocking,not active ,8
MAS12382-MAS14170-Dynamic turn signal control-Confirmation flashing of the central locking system when locking,not active ,8
MAS12382-ENG122206-Dynamic turn signal control-DWA_Schaerfungsquittung,not active ,8
MAS12382-ENG142195-Dynamic turn signal control-Dynamische_Blink_Delay,0 ms,8
MAS12382-ENG261058-Dynamic turn signal control-IPA_RPA_Blinkbestätugung,not active ,8
MAS12382-ENG260850-Dynamic turn signal control-IPA_RPA_blinken_links,not active ,8
MAS12382-ENG258687-Dynamic turn signal control-IPA_RPA_blinken_rechts,not active ,8
MAS12382-ENG260708-Dynamic turn signal control-Multikollisions_blinken,not active ,8
MAS12382-ENG122209-Dynamic turn signal control-Notwarn_blinken_NBA_Phase_2,not active ,8
MAS12382-ENG122211-Dynamic turn signal control-Richtungs_blinken_links,not active ,8
MAS12382-ENG122210-Dynamic turn signal control-Richtungs_blinken_rechts,not active ,8
MAS12382-ENG260812-Dynamic turn signal control-SWA_blinken_links,not active ,8
MAS12382-ENG260466-Dynamic turn signal control-SWA_blinken_rechts,not active ,8
MAS12382-ENG122214-Dynamic turn signal control-Warnblinken_Zuendung_AUS,not active ,8
MAS12382-ENG122213-Dynamic turn signal control-Warnblinken_Zuendung_EIN,not active ,8
MAS13139-MAS13135-Button 4-Function of button 4,not coded/not installed ,1
MAS13139-MAS13136-Button 4-Indicator lamp button 4,installed ,1
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,No Response From Subnet Component,1
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,No Response From Subnet Component,1
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,No Response From Subnet Component,1
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,No Response From Subnet Component,1
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,No Response From Subnet Component,1
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,No Response From Subnet Component,1
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,No Response From Subnet Component,1
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,No Response From Subnet Component,1
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,No Response From Subnet Component,1
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,No Response From Subnet Component,1
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,No Response From Subnet Component,1
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,No Response From Subnet Component,1
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,No Response From Subnet Component,1
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,No Response From Subnet Component,1
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,No Response From Subnet Component,1
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,No Response From Subnet Component,1
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,No Response From Subnet Component,1
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,No Response From Subnet Component,1
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,No Response From Subnet Component,1
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,No Response From Subnet Component,1
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,No Response From Subnet Component,1
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,No Response From Subnet Component,1
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,No Response From Subnet Component,1
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,No Response From Subnet Component,1
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,No Response From Subnet Component,1
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,No Response From Subnet Component,1
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,No Response From Subnet Component,1
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,No Response From Subnet Component,1
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,No Response From Subnet Component,1
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,No Response From Subnet Component,1
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,No Response From Subnet Component,1
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,No Response From Subnet Component,1
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,No Response From Subnet Component,1
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,No Response From Subnet Component,1
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,No Response From Subnet Component,1
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,No Response From Subnet Component,1
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,No Response From Subnet Component,1
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,No Response From Subnet Component,1
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,No Response From Subnet Component,1
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,No Response From Subnet Component,1
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,No Response From Subnet Component,1
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,No Response From Subnet Component,1
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,No Response From Subnet Component,1
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,No Response From Subnet Component,1
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,No Response From Subnet Component,1
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,No Response From Subnet Component,1
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,No Response From Subnet Component,1
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,No Response From Subnet Component,1
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,No Response From Subnet Component,1
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,No Response From Subnet Component,1
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,No Response From Subnet Component,1
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,No Response From Subnet Component,1
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,No Response From Subnet Component,1
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,No Response From Subnet Component,1
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,No Response From Subnet Component,1
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,No Response From Subnet Component,1
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,No Response From Subnet Component,1
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle model,No Response From Subnet Component,1
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,No Response From Subnet Component,1
MAS14140-IDE15905-Flashing function-Travel Assist,not active ,4
MAS14140-ENG154601-Flashing function-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,4
MAS14140-ENG259090-Flashing function-Hupen_durch_Fahrerassistenz,not active ,4
MAS14140-ENG142029-Flashing function-Warnblinken_durch_Fahrerassistenz,not active ,4
MAS18831-IDE80001-Control module for optical rear lid opening: dataset-Analysis 1,No Response From Subnet Component,4
MAS18831-IDE80002-Control module for optical rear lid opening: dataset-Analysis 2,No Response From Subnet Component,4
MAS18831-IDE80003-Control module for optical rear lid opening: dataset-Analysis 3,No Response From Subnet Component,4
MAS18831-IDE80004-Control module for optical rear lid opening: dataset-Analysis 4,No Response From Subnet Component,4
MAS18831-IDE80005-Control module for optical rear lid opening: dataset-Analysis 5,No Response From Subnet Component,4
MAS18831-IDE80006-Control module for optical rear lid opening: dataset-Analysis 6,No Response From Subnet Component,4
MAS18831-IDE80007-Control module for optical rear lid opening: dataset-Analysis 7,No Response From Subnet Component,4
MAS18831-IDE80008-Control module for optical rear lid opening: dataset-Analysis 8,No Response From Subnet Component,4
MAS18831-IDE80009-Control module for optical rear lid opening: dataset-Analysis 9,No Response From Subnet Component,4
MAS18831-IDE80010-Control module for optical rear lid opening: dataset-Analysis 10,No Response From Subnet Component,4
MAS18831-IDE80011-Control module for optical rear lid opening: dataset-Analysis 11,No Response From Subnet Component,4
MAS18831-IDE80012-Control module for optical rear lid opening: dataset-Analysis 12,No Response From Subnet Component,4
MAS18831-IDE80013-Control module for optical rear lid opening: dataset-Analysis 13,No Response From Subnet Component,4
MAS18831-IDE80014-Control module for optical rear lid opening: dataset-Analysis 14,No Response From Subnet Component,4
MAS18831-IDE80015-Control module for optical rear lid opening: dataset-Analysis 15,No Response From Subnet Component,4
MAS18831-IDE80016-Control module for optical rear lid opening: dataset-Analysis 16,No Response From Subnet Component,4
MAS18831-IDE80017-Control module for optical rear lid opening: dataset-Analysis 17,No Response From Subnet Component,4
MAS18831-IDE80018-Control module for optical rear lid opening: dataset-Analysis 18,No Response From Subnet Component,4
MAS18831-IDE80019-Control module for optical rear lid opening: dataset-Analysis 19,No Response From Subnet Component,4
MAS18831-IDE80020-Control module for optical rear lid opening: dataset-Analysis 20,No Response From Subnet Component,4
MAS18831-IDE80021-Control module for optical rear lid opening: dataset-Analysis 21,No Response From Subnet Component,4
MAS18831-IDE80022-Control module for optical rear lid opening: dataset-Analysis 22,No Response From Subnet Component,4
MAS18831-IDE80023-Control module for optical rear lid opening: dataset-Analysis 23,No Response From Subnet Component,4
MAS18831-IDE80024-Control module for optical rear lid opening: dataset-Analysis 24,No Response From Subnet Component,4
MAS18831-IDE80025-Control module for optical rear lid opening: dataset-Analysis 25,No Response From Subnet Component,4
MAS18831-IDE80026-Control module for optical rear lid opening: dataset-Analysis 26,No Response From Subnet Component,4
MAS18831-IDE80027-Control module for optical rear lid opening: dataset-Analysis 27,No Response From Subnet Component,4
MAS18831-IDE80028-Control module for optical rear lid opening: dataset-Analysis 28,No Response From Subnet Component,4
MAS18831-IDE80029-Control module for optical rear lid opening: dataset-Analysis 29,No Response From Subnet Component,4
MAS18831-IDE80030-Control module for optical rear lid opening: dataset-Analysis 30,No Response From Subnet Component,4
MAS18831-IDE80031-Control module for optical rear lid opening: dataset-Analysis 31,No Response From Subnet Component,4
MAS18831-IDE80032-Control module for optical rear lid opening: dataset-Analysis 32,No Response From Subnet Component,4
MAS18831-IDE80033-Control module for optical rear lid opening: dataset-Analysis 33,No Response From Subnet Component,4
MAS18831-IDE80034-Control module for optical rear lid opening: dataset-Analysis 34,No Response From Subnet Component,4
MAS18831-IDE80035-Control module for optical rear lid opening: dataset-Analysis 35,No Response From Subnet Component,4
MAS18831-IDE80036-Control module for optical rear lid opening: dataset-Analysis 36,No Response From Subnet Component,4
MAS18831-IDE80037-Control module for optical rear lid opening: dataset-Analysis 37,No Response From Subnet Component,4
MAS18831-IDE80038-Control module for optical rear lid opening: dataset-Analysis 38,No Response From Subnet Component,4
MAS18831-IDE80039-Control module for optical rear lid opening: dataset-Analysis 39,No Response From Subnet Component,4
MAS18831-IDE80040-Control module for optical rear lid opening: dataset-Analysis 40,No Response From Subnet Component,4
MAS18831-IDE80041-Control module for optical rear lid opening: dataset-Analysis 41,No Response From Subnet Component,4
MAS18831-IDE80042-Control module for optical rear lid opening: dataset-Analysis 42,No Response From Subnet Component,4
MAS18831-IDE80043-Control module for optical rear lid opening: dataset-Analysis 43,No Response From Subnet Component,4
MAS18831-IDE80044-Control module for optical rear lid opening: dataset-Analysis 44,No Response From Subnet Component,4
MAS18831-IDE80045-Control module for optical rear lid opening: dataset-Analysis 45,No Response From Subnet Component,4
MAS18831-IDE80046-Control module for optical rear lid opening: dataset-Analysis 46,No Response From Subnet Component,4
MAS18831-IDE80047-Control module for optical rear lid opening: dataset-Analysis 47,No Response From Subnet Component,4
MAS18831-IDE80048-Control module for optical rear lid opening: dataset-Analysis 48,No Response From Subnet Component,4
MAS18831-IDE80049-Control module for optical rear lid opening: dataset-Analysis 49,No Response From Subnet Component,4
MAS18831-IDE80050-Control module for optical rear lid opening: dataset-Analysis 50,No Response From Subnet Component,4
MAS18831-IDE80051-Control module for optical rear lid opening: dataset-Analysis 51,No Response From Subnet Component,4
MAS18831-IDE80052-Control module for optical rear lid opening: dataset-Analysis 52,No Response From Subnet Component,4
MAS18831-IDE80053-Control module for optical rear lid opening: dataset-Analysis 53,No Response From Subnet Component,4
MAS18831-IDE80054-Control module for optical rear lid opening: dataset-Analysis 54,No Response From Subnet Component,4
MAS18831-IDE80055-Control module for optical rear lid opening: dataset-Analysis 55,No Response From Subnet Component,4
MAS18831-IDE80056-Control module for optical rear lid opening: dataset-Analysis 56,No Response From Subnet Component,4
MAS18831-IDE80057-Control module for optical rear lid opening: dataset-Analysis 57,No Response From Subnet Component,4
MAS18831-IDE80058-Control module for optical rear lid opening: dataset-Analysis 58,No Response From Subnet Component,4
MAS18831-IDE80059-Control module for optical rear lid opening: dataset-Analysis 59,No Response From Subnet Component,4
MAS18831-IDE80060-Control module for optical rear lid opening: dataset-Analysis 60,No Response From Subnet Component,4
MAS20279-WFS transponder gateway coding,Transponder GW in Kessy OK box ,4
SFT00061-MAS10520-Special Function-Special function 1,not installed ,4
SFT00061-SFT00048-Special Function-Special Function 2,not enabled ,4
SFT00061-ENG260472-Special Function-Blinkerueberwachug_Sonderfunktions_SG,not installed ,4
ENG253311-IDE01058-604 UGDO Sender-Country coding,No Response From Subnet Component,4
ENG253311-MAS07183-604 UGDO Sender-Oper. concept,No Response From Subnet Component,4
ENG253311-MAS07186-604 UGDO Sender-Multimedia system,No Response From Subnet Component,4
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,0 ,9
ENG253358-ENG258212-Anpassungen_Exterior_Light-Delay_Max,0 ms,270
ENG253358-ENG259279-Anpassungen_Exterior_Light-Events_Szene_1,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260085-Anpassungen_Exterior_Light-Events_Szene_10,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260997-Anpassungen_Exterior_Light-Events_Szene_11,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG258638-Anpassungen_Exterior_Light-Events_Szene_12,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259456-Anpassungen_Exterior_Light-Events_Szene_13,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260535-Anpassungen_Exterior_Light-Events_Szene_14,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259560-Anpassungen_Exterior_Light-Events_Szene_15,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259132-Anpassungen_Exterior_Light-Events_Szene_16,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260337-Anpassungen_Exterior_Light-Events_Szene_17,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259462-Anpassungen_Exterior_Light-Events_Szene_18,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG258627-Anpassungen_Exterior_Light-Events_Szene_19,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260067-Anpassungen_Exterior_Light-Events_Szene_2,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259484-Anpassungen_Exterior_Light-Events_Szene_20,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260587-Anpassungen_Exterior_Light-Events_Szene_21,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260042-Anpassungen_Exterior_Light-Events_Szene_22,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259549-Anpassungen_Exterior_Light-Events_Szene_23,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260635-Anpassungen_Exterior_Light-Events_Szene_24,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG258179-Anpassungen_Exterior_Light-Events_Szene_25,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259599-Anpassungen_Exterior_Light-Events_Szene_26,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260140-Anpassungen_Exterior_Light-Events_Szene_27,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG258932-Anpassungen_Exterior_Light-Events_Szene_28,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG258855-Anpassungen_Exterior_Light-Events_Szene_29,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259951-Anpassungen_Exterior_Light-Events_Szene_3,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259306-Anpassungen_Exterior_Light-Events_Szene_30,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260976-Anpassungen_Exterior_Light-Events_Szene_31,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260284-Anpassungen_Exterior_Light-Events_Szene_32,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260168-Anpassungen_Exterior_Light-Events_Szene_4,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259646-Anpassungen_Exterior_Light-Events_Szene_5,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260432-Anpassungen_Exterior_Light-Events_Szene_6,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259181-Anpassungen_Exterior_Light-Events_Szene_7,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG258154-Anpassungen_Exterior_Light-Events_Szene_8,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG260860-Anpassungen_Exterior_Light-Events_Szene_9,00 00 00 00 00 00 00 00 ,270
ENG253358-ENG259092-Anpassungen_Exterior_Light-MappingArray,0 ,270
ENG253358-ENG263521-Anpassungen_Exterior_Light-MappingArray_Umfeld,0 ,270
ENG253358-ENG258812-Anpassungen_Exterior_Light-p_Abstand_IDG_Inszenierung,0.0 m,270
ENG253358-ENG258950-Anpassungen_Exterior_Light-p_Kessy_ID,not active ,270
ENG253358-ENG289605-Anpassungen_Exterior_Light-p_vip30_Dimmung_SalR,00 ,270
ENG253358-ENG289606-Anpassungen_Exterior_Light-p_vip30_Dimmung_TSG,00 ,270
ENG253358-ENG289607-Anpassungen_Exterior_Light-p_vip30_Dimmzeit,0 ms,270
ENG253358-ENG259215-Anpassungen_Exterior_Light-pa_ambExtLight_Installation,not active ,270
ENG253358-ENG258160-Anpassungen_Exterior_Light-pa_ext_Ambiente,not active ,270
ENG253358-ENG260968-Anpassungen_Exterior_Light-Passive_Timeout,0.00 s,270
ENG253358-ENG258460-Anpassungen_Exterior_Light-PSO_active_participant_ambient_lighting_exterieur_enabled,not active ,270
ENG253358-ENG261089-Anpassungen_Exterior_Light-Verzoegerung_Blinken,not active ,270
ENG253146-ENG141986-Aussenlicht-SG-Architektur-Abblendlicht_Leuchtentyp,HID ,8
ENG253146-ENG258089-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Prüfung,not active ,8
ENG253146-ENG141987-Aussenlicht-SG-Architektur-Bremslicht_ist_auch_Blinklicht,No ,8
ENG253146-ENG259743-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_1,FF ,8
ENG253146-ENG260787-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_2,FF ,8
ENG253146-ENG259890-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_3,FF ,8
ENG253146-ENG260564-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_1,FF ,8
ENG253146-ENG258294-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_2,FF ,8
ENG253146-ENG259373-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_3,FF ,8
ENG253146-ENG115861-Aussenlicht-SG-Architektur-Lichthupe bei Zuendung aus moeglich,active ,8
ENG253146-ENG115832-Aussenlicht-SG-Architektur-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,8
ENG253146-ENG115831-Aussenlicht-SG-Architektur-Schlusslicht mit Bremslichtfunktion,active ,8
ENG253146-ENG115860-Aussenlicht-SG-Architektur-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,8
ENG253356-ENG258933-Automatische_Funktionen-Automatik_Funktionen_Warnungen_aktiv,not activated ,4
ENG253356-ENG258835-Automatische_Funktionen-Automatik_Funktionen_WarnungWenn_AusserhalbExitBereich_aktiv,not activated ,4
ENG253356-ENG260748-Automatische_Funktionen-AutomatikFunktionen_WarnungWenn_VerlassenBeiHautNichtGeschlossen_aktiv,not activated ,4
ENG253356-ENG281101-Automatische_Funktionen-AutomatikFunktionen_WarnungWennIDGeberImInnenraum_aktiv,not activated ,4
ENG253356-ENG258145-Automatische_Funktionen-AutomatischeFunktionen_Beschleunigtes_Entry_aktiv,not activated ,4
ENG253356-ENG260562-Automatische_Funktionen-Automatisches_Entriegeln_aktiv,not activated ,4
ENG253356-ENG260693-Automatische_Funktionen-Automatisches_Verriegeln_aktiv,not activated ,4
ENG253240-ENG263541-Automatisierte Abschaltungen-Abschalt_verzögerungs_zeit,60 s,8
ENG253240-ENG263514-Automatisierte Abschaltungen-Abschalt_wunsch_entprellung,1.0 s,8
ENG253240-ENG259987-Automatisierte Abschaltungen-Abschaltung nur in P,Alle Fahrstufen ,8
ENG253240-ENG277086-Automatisierte Abschaltungen-Dauer für Ausführung des Abschaltwunsch an SPN,2.0 s,8
ENG253240-ENG277087-Automatisierte Abschaltungen-Dauer Hinweistext Komfortabschaltung,10.0 s,8
ENG253240-ENG259819-Automatisierte Abschaltungen-Signalisierungsdauer Automatische Abschaltung erfolgt,5.0 s,8
ENG253240-ENG258392-Automatisierte Abschaltungen-Stillstandsdrehzahlschwelle Verbrennungsmotor,400 ,8
ENG253240-ENG258639-Automatisierte Abschaltungen-Verfügbarkeit Komfortabschaltung,available. ,8
ENG253240-ENG258110-Automatisierte Abschaltungen-Zündungsabschaltung über Energiemanagement,available. ,8
ENG253240-ENG126843-Automatisierte Abschaltungen-ZV verriegeln bei Klemme 15 Ein,active ,8
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG134731-Blower_1_Backrest_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG134731-Blower_1_Backrest_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG134731-Blower_1_Cushion_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG134731-Blower_1_Cushion_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG253018-Clamp_Control,Driver door ,1
ENG253221-ENG259820-Clamp_Coordinator-Clamp_Coordinator_priority_AAA,100 ,40
ENG253221-ENG260325-Clamp_Coordinator-Clamp_Coordinator_priority_DIAG,200 ,40
ENG253221-ENG260088-Clamp_Coordinator-Clamp_Coordinator_priority_MWS,10 ,40
ENG253221-ENG259040-Clamp_Coordinator-Clamp_Coordinator_priority_ORU,1 ,40
ENG253221-ENG259149-Clamp_Coordinator-Clamp_Coordinator_priority_PHP,100 ,40
ENG253221-ENG261099-Clamp_Coordinator-Clamp_Coordinator_priority_RPA,100 ,40
ENG253221-ENG258680-Clamp_Coordinator-Clamp_Coordinator_priority_RWK,100 ,40
ENG253221-ENG260388-Clamp_Coordinator-Clamp_Coordinator_priority_SPN,10 ,40
ENG253221-ENG259706-Clamp_Coordinator-Clamp_Coordinator_priority_ZAS,10 ,40
ENG253350-ENG258402-Coding_seat_pneumatics_driver_side-Function_easy_entry,No Response From Subnet Component,40
ENG253350-ENG260372-Coding_seat_pneumatics_driver_side-Function_massage,No Response From Subnet Component,40
ENG253350-ENG260893-Coding_seat_pneumatics_driver_side-Function_memory,No Response From Subnet Component,40
ENG253350-ENG261225-Coding_seat_pneumatics_driver_side-Function_off_autocorrection,No Response From Subnet Component,40
ENG253350-ENG259055-Coding_seat_pneumatics_driver_side-Function_off_delay,No Response From Subnet Component,40
ENG253350-ENG259290-Coding_seat_pneumatics_driver_side-Function_personalisation,No Response From Subnet Component,40
ENG253350-ENG259372-Coding_seat_pneumatics_driver_side-Function_pre_crash_lordosis,No Response From Subnet Component,40
ENG253350-ENG259654-Coding_seat_pneumatics_driver_side-Function_precrash_side_support,No Response From Subnet Component,40
ENG253350-ENG259159-Coding_seat_pneumatics_driver_side-Function_race_mode,No Response From Subnet Component,40
ENG253350-ENG261329-Coding_seat_pneumatics_driver_side-Function_side_support,No Response From Subnet Component,40
ENG253350-ENG258695-Coding_seat_pneumatics_driver_side-Level_self_diagnostics,No Response From Subnet Component,40
ENG253175-ENG258402-Coding_seat_pneumatics_passenger_side-Function_easy_entry,No Response From Subnet Component,40
ENG253175-ENG260372-Coding_seat_pneumatics_passenger_side-Function_massage,No Response From Subnet Component,40
ENG253175-ENG260893-Coding_seat_pneumatics_passenger_side-Function_memory,No Response From Subnet Component,40
ENG253175-ENG261225-Coding_seat_pneumatics_passenger_side-Function_off_autocorrection,No Response From Subnet Component,40
ENG253175-ENG259055-Coding_seat_pneumatics_passenger_side-Function_off_delay,No Response From Subnet Component,40
ENG253175-ENG259290-Coding_seat_pneumatics_passenger_side-Function_personalisation,No Response From Subnet Component,40
ENG253175-ENG259372-Coding_seat_pneumatics_passenger_side-Function_pre_crash_lordosis,No Response From Subnet Component,40
ENG253175-ENG259654-Coding_seat_pneumatics_passenger_side-Function_precrash_side_support,No Response From Subnet Component,40
ENG253175-ENG259159-Coding_seat_pneumatics_passenger_side-Function_race_mode,No Response From Subnet Component,40
ENG253175-ENG261329-Coding_seat_pneumatics_passenger_side-Function_side_support,No Response From Subnet Component,40
ENG253175-ENG258695-Coding_seat_pneumatics_passenger_side-Level_self_diagnostics,No Response From Subnet Component,40
ENG253229-ENG258467-Define_Const-Dimm2Bin,50 %,4
ENG253229-ENG259386-Define_Const-Dimmzeit_SAL_Umfeld,1.00 s,4
ENG253229-ENG253468-Define_Const-Gamma,2.0 ,4
ENG253142-ENG258099-Design_switching-Display_Nachtdesign-Umschaltung,Standlicht/Fahrlicht_u_RLS ,5
ENG253142-ENG261004-Design_switching-RLS_Nachtdesign_Schwelle,20 ,5
ENG253142-ENG260371-Design_switching-RLS_Tagdesign_Schwelle,100 ,5
ENG253142-ENG258254-Design_switching-Werteanzahl_Mittelwert,100 ,5
ENG253142-ENG260585-Design_switching-Werteanzahl_Mittelwert_Start-,05 ,5
ENG253216-MAS18908-DevCod_Automatische_Verriegelung-Terminal 15: behavior of the automatic locking function,Function only allowed for terminal 15 off ,6
ENG253216-ENG261088-DevCod_Automatische_Verriegelung-AutomatikFunktionen_HVLaden_EigenerBereich_aktiv,not activated ,6
ENG253216-ENG258169-DevCod_Automatische_Verriegelung-AutomatikFunktionen_Sonderfall_ZyklischeSucheBeiKlemme15_aktiv,not_activated ,6
ENG253216-ENG277085-DevCod_Automatische_Verriegelung-Automatische_FunktionBeiAnnaeherung_Entfernung_aktiv,not activated ,6
ENG253028-DevCod_Bedienstellen,not activated ,1
ENG253195-IDE04159-DevCod_Dienste_Byte1-Deactivation of start/stop function,not active ,6
ENG253195-ENG281096-DevCod_Dienste_Byte1-Entry_Deaktivierung_aktiv,activated ,6
ENG253195-ENG258846-DevCod_Dienste_Byte1-Entry_GoDeaktivierung_Aktivierungs_Variante,not activated ,6
ENG253195-ENG258351-DevCod_Dienste_Byte1-ErkennungFahrzeug_Verlassen_aktiv,activated ,6
ENG253195-ENG261030-DevCod_Dienste_Byte1-ErkennungFahrzeug_Zugang_aktiv,activated ,6
ENG253195-ENG260255-DevCod_Dienste_Byte1-ErkennungFahrzeugZugang_bei_Remotestart,not activated ,6
ENG253195-ENG259070-DevCod_Dienste_Byte1-ErkennungFahrzeugZugangVerlassen_Triggerung_aktiv,activated ,6
ENG253102-ENG258819-DevCod_Dienste_Byte2-BereichsueberwachungPilotiertesParken_Variante,not activated ,6
ENG253102-ENG259756-DevCod_Dienste_Byte2-BewussteGesamtEntriegelung_aktiv,activated ,6
ENG253102-ENG261309-DevCod_Dienste_Byte2-Paketbotenmodus_aktiv,not activated ,6
ENG253102-ENG277103-DevCod_Dienste_Byte2-RSAD_Krypto_Checks_aktivieren,activated ,6
ENG253102-ENG259641-DevCod_Dienste_Byte2-RSADMassnahme_aussen_aktiv,activated ,6
ENG253102-ENG259949-DevCod_Dienste_Byte2-RSADMassnahme_innen_aktiv,not activated ,6
ENG253102-ENG260061-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_aktiv,not activated ,6
ENG253102-ENG259459-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_NichtKessyEntr_aktiv,not activated ,6
ENG253102-ENG259282-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_OeffnenFT_aktiv,activated ,6
ENG253202-ENG259475-DevCod_Dienste_Byte3-VIT_close,not activated ,6
ENG253202-ENG259049-DevCod_Dienste_Byte3-VIT_KESSY_Inversbit,not activated ,6
ENG253296-ENG259208-DevCod_Fahrzeugkonfiguration_Byte1-BEM_verbaut,activated ,6
ENG253296-ENG174999-DevCod_Fahrzeugkonfiguration_Byte1-Convertible,not activated ,6
ENG253296-ENG259388-DevCod_Fahrzeugkonfiguration_Byte1-HBFS_Schiebetuer,not activated ,6
ENG253296-ENG259603-DevCod_Fahrzeugkonfiguration_Byte1-HFS_Schiebetuer,not activated ,6
ENG253296-ENG260764-DevCod_Fahrzeugkonfiguration_Byte1-NFZ_mit_2Zonen,not activated ,6
ENG253296-ENG259616-DevCod_Fahrzeugkonfiguration_Byte1-Reaktivierung_all_Tueren_VK2,not activated ,6
ENG253183-ENG259579-DevCod_Fahrzeugkonfiguration_Byte2-Softtouch_verbaut,installed ,6
ENG253183-ENG277104-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_1_aktiv,not activated ,6
ENG253183-ENG277105-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_2_aktiv,not activated ,6
ENG253183-ENG277106-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_3_aktiv,not activated ,6
ENG253183-ENG277107-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_4_aktiv,not activated ,6
ENG253183-ENG277108-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_5_aktiv,not activated ,6
ENG253183-ENG141964-DevCod_Fahrzeugkonfiguration_Byte2-Steering alignment,Right ,6
ENG253369-ENG260810-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Fahrertuer,activated ,6
ENG253369-ENG258777-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Verdeck_offen,not activated ,6
ENG253369-ENG258088-DevCod_IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_Schließverhinderung,activated ,6
ENG253369-ENG258863-DevCod_IDGeber_Suche-InnenraumsucheMitEEAuth_Variante,not activated ,6
ENG253369-ENG281080-DevCod_IDGeber_Suche-Unterdrueckung_zyklischer _Suchen_bei_entriegeltem_Fahrzeug_aktiv,not activated ,6
ENG253170-ENG281102-DevCod_Nutzerkonfigurationen-HMIMenue_Aktivierung_Nah_Mittel_Fern_aktiv,not activated ,6
ENG253170-ENG259272-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_Advanced_aktiv,not activated ,6
ENG253170-ENG258478-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_aktiv,activated ,6
ENG253170-ENG281078-DevCod_Nutzerkonfigurationen-HMIMenue_Nutzer_Warnung_AutomatikFunktion_aktiv,not activated ,6
ENG253247-IDE02474-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive entry exit function,Function only allowed for terminal 15 off ,7
ENG253247-MAS18909-DevCod_Passive_EntryExit_Toggle-Terminal 15: behavior of the unlock/lock button function,not activated ,7
ENG253247-MAS18910-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive exit function,Function only allowed for terminal 15 on or off ,7
ENG253247-ENG260696-DevCod_Passive_EntryExit_Toggle-FunkkommunikationFuerPassiveEntryExit_Wiederholung_aktiv,not activated ,7
ENG253247-ENG261245-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offenen_Tueren,activated ,7
ENG253247-ENG261070-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offener_Zugangstuer,not activated ,7
ENG253247-ENG258791-DevCod_Passive_EntryExit_Toggle-Passive_Toggle_bei_offenen_Tueren,not activated ,7
ENG253247-ENG260751-DevCod_Passive_EntryExit_Toggle-PassiveEntryExit_aktiv,activated ,7
ENG253117-ENG260289-DevCod_Passive_Go-Innenraumsuche_IDGeberFreigeben_bei_Remotestart,not activated ,6
ENG253117-ENG259313-DevCod_Passive_Go-PassiveGo_bei_offener_Heckklappe,activated ,6
ENG253117-ENG261220-DevCod_Passive_Go-PassiveGo_bei_offener_Schiebetür,activated ,6
ENG253197-ENG260990-Diebstahlschutz Schnittstelle-DWA_HSB_HSK_ueberwachung_aktiv,not active ,6
ENG253197-ENG258293-Diebstahlschutz Schnittstelle-DWA_mit_Einfachhorn,sounder_installed ,6
ENG253197-ENG258890-Diebstahlschutz Schnittstelle-DWA_mit_NGS,active ,6
ENG253197-ENG258731-Diebstahlschutz Schnittstelle-DWA_ohne_Thatcham,limited ,6
ENG253197-ENG258944-Diebstahlschutz Schnittstelle-DWA_Scheinwerferueberwachung_aktiv,not active ,6
ENG253197-ENG258663-Diebstahlschutz Schnittstelle-DWA_verbaut,installed ,6
ENG253197-ENG258162-Diebstahlschutz Schnittstelle-IRUE_NGS_Deaktivierung_via_MMI,active ,6
ENG253197-ENG261022-Diebstahlschutz Schnittstelle-Irue_verbaut,installed ,6
ENG253197-ENG261072-Diebstahlschutz Schnittstelle-Sirene_alarmzahl,10_Alarme ,6
ENG253197-ENG260442-Diebstahlschutz Schnittstelle-Verbau_Deaktivierungstaster_DWA_Sensor,not active ,6
ENG253244-MAS10115-Diebstahlschutz.Modulsoftware-Anti-theft blinkers by inter. door handle activ.,OFF ,6
ENG253244-Diebstahlschutz.Modulsoftware-,active ,6
ENG253244-ENG258423-Diebstahlschutz.Modulsoftware-Akustischer Alarm ueber Hupe,not active ,6
ENG253244-ENG258401-Diebstahlschutz.Modulsoftware-Anhaengerueberwachung_aktiv,not active ,6
ENG253244-ENG146510-Diebstahlschutz.Modulsoftware-beeptime,10_ms ,6
ENG253244-ENG260066-Diebstahlschutz.Modulsoftware-dwa_alarm_ton,frequency_modulated ,6
ENG253244-ENG258606-Diebstahlschutz.Modulsoftware-DWA_campermode,not active ,6
ENG253244-ENG260322-Diebstahlschutz.Modulsoftware-DWA_Verdeckoeffnungsueberwachung_aktiv,not active ,6
ENG253244-ENG261182-Diebstahlschutz.Modulsoftware-IRUE_NGS_bewusst_entschaerfen,not active ,6
ENG253365-ENG260723-Dienste-BeeinflussungStartStopp_aktiv,not activated ,4
ENG253365-ENG258656-Dienste-BereichsueberwachungPilotiertesParken_aktiv,not activated ,4
ENG253365-ENG259029-Dienste-EntryGoDeaktivierung_Nutzerkonfiguration_aktiv,activated ,4
ENG253365-ENG260489-Dienste-EntryGoDeaktivierung_Quittierung_aktiv,not activated ,4
ENG253365-ENG258571-Dienste-GenerischeOrtung_aktiv,not activated ,4
ENG253365-ENG260124-Dienste-Keyfinder_Aussen_aktiv,not activated ,4
ENG253365-ENG259116-Dienste-Keyfinder_Innen_aktiv,not activated ,4
ENG253144-ENG259520-Dimmung (der Suchbeleuchtung Kl. 58)-p_delta_KL58D_min,3.0 %,21
ENG253144-ENG253461-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xd,160 %,21
ENG253144-ENG253462-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xs,160 %,21
ENG253144-ENG253463-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xt,160 %,21
ENG253144-ENG259127-Dimmung (der Suchbeleuchtung Kl. 58)-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck,10 ,21
ENG253144-ENG261206-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_max,90.0 %,21
ENG253144-ENG258780-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_min,10.0 %,21
ENG253144-ENG259198-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_tol,5.0 %,21
ENG253144-ENG261308-Dimmung (der Suchbeleuchtung Kl. 58)-p_langer_Tastendruck,1.0 s,21
ENG253144-ENG260197-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xs_Nachlauf_lang,900 s,21
ENG253144-ENG261144-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xt_Nachlauf_kurz,30 s,21
ENG253144-ENG258180-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Master,10 min,21
ENG253144-ENG253464-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Slave,12 min,21
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,21
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,21
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,21
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,21
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,21
ENG179017-ENG125667-Driver_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125666-Driver_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125668-Driver_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125673-Driver_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125672-Driver_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125674-Driver_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125670-Driver_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125669-Driver_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125671-Driver_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125676-Driver_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125675-Driver_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125677-Driver_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125664-Driver_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125663-Driver_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125665-Driver_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125667-Driver_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125666-Driver_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125668-Driver_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125673-Driver_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125672-Driver_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125674-Driver_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125670-Driver_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125669-Driver_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125671-Driver_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125676-Driver_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125675-Driver_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125677-Driver_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125664-Driver_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125663-Driver_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125665-Driver_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125667-Driver_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125666-Driver_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125668-Driver_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125673-Driver_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125672-Driver_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125674-Driver_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125670-Driver_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125669-Driver_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125671-Driver_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125676-Driver_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125675-Driver_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125677-Driver_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125664-Driver_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125663-Driver_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125665-Driver_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,21
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,21
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,21
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,21
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,21
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,21
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,21
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,21
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,21
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,21
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,21
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,21
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,21
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,21
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,21
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,21
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,21
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,21
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,21
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,21
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,21
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,21
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,21
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,21
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,21
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,21
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,21
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,21
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,21
ENG286142-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,21
ENG286142-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,21
ENG286142-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,21
ENG286142-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,21
ENG286142-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,21
ENG286142-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,21
ENG286142-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,21
ENG286142-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,21
ENG286142-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,21
ENG286142-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,21
ENG286142-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,21
ENG286142-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,21
ENG286142-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,21
ENG286142-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,21
ENG286142-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,21
ENG286142-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,21
ENG286142-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,21
ENG286142-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,21
ENG286142-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,21
ENG286142-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,21
ENG286142-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,21
ENG286142-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,21
ENG286142-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,21
ENG286142-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,21
ENG286142-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,21
ENG286142-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,21
ENG286142-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,21
ENG286142-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,21
ENG286142-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,21
ENG286142-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,21
ENG286142-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,21
ENG286142-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,21
ENG286142-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,21
ENG286142-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,21
ENG286142-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,21
ENG286142-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,21
ENG286142-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,21
ENG286142-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,21
ENG286142-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,21
ENG286142-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,21
ENG286142-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,21
ENG286142-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,21
ENG286142-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,21
ENG286142-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,21
ENG286142-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,21
ENG286142-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,21
ENG286142-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,21
ENG286142-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,21
ENG286142-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,21
ENG286142-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,21
ENG286142-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,21
ENG286142-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,21
ENG286142-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,21
ENG286142-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,21
ENG286142-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,21
ENG286142-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,21
ENG286142-IDE80057-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,21
ENG286142-IDE80058-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,21
ENG286142-IDE80059-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,21
ENG286142-IDE80060-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,21
ENG286143-IDE00047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,21
ENG286143-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,21
ENG286143-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,21
ENG286143-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,21
ENG286143-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,21
ENG286143-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,21
ENG286143-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,21
ENG286143-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,21
ENG286143-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,21
ENG286143-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,21
ENG286143-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,21
ENG286143-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,21
ENG286143-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,21
ENG286143-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,21
ENG286143-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,21
ENG286143-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,21
ENG286143-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,21
ENG286143-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,21
ENG286143-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,21
ENG286143-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,21
ENG286143-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,21
ENG286143-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,21
ENG286143-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,21
ENG286143-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,21
ENG286143-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,21
ENG286143-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,21
ENG286143-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,21
ENG286143-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,21
ENG286143-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,21
ENG286143-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,21
ENG286143-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,21
ENG286143-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,21
ENG286143-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,21
ENG286143-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,21
ENG286143-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,21
ENG286143-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,21
ENG286143-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,21
ENG286143-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,21
ENG286143-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,21
ENG286143-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,21
ENG286143-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,21
ENG286143-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,21
ENG286143-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,21
ENG286143-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,21
ENG286143-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,21
ENG286143-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,21
ENG286143-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,21
ENG286143-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,21
ENG286143-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,21
ENG286143-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,21
ENG286143-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,21
ENG286143-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,21
ENG286143-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,21
ENG286143-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,21
ENG286143-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,21
ENG286143-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,21
ENG286143-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,21
ENG286143-MAS01078-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,21
ENG286143-MAS14087-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,21
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG253243-ENG286261-Easy Open-p_a_Schiebetürentriegelung_durch_VIP_bei_Tankklappe_offen,not active ,4
ENG253243-ENG258420-Easy Open-p_a_VIP_Freigabeentzug_bei_Anhaenger,not active ,4
ENG253243-ENG258644-Easy Open-Virtuelles_Pedal_Aktiv_Kl_15,not active ,4
ENG253243-ENG259016-Easy Open-Virtuelles_Pedal_Aktiv_Kl_S,not active ,4
ENG253243-ENG260097-Easy Open-Virtuelles_Pedal_Aktiv_Motorlauf,not active ,4
ENG253243-ENG286386-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_15,not active ,4
ENG253243-ENG286387-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_S,not active ,4
ENG253243-ENG286388-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Motorlauf,not active ,4
ENG129029-ENG258264-Easy_close_alignment-delta_rssi_hysterese,15 ,15
ENG129029-ENG260847-Easy_close_alignment-min_HD_Oeffungswinkel,50 %,15
ENG129029-ENG259133-Easy_close_alignment-min_HD_Oeffungswinkel_Rev,10 %,15
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,15
ENG129029-ENG259762-Easy_close_alignment-VIT_RSSI_Verlassensscans,20.0 s,15
ENG129029-ENG260687-Easy_close_alignment-VIT_RSSI_Wiedereintrittscans,7.0 s,15
ENG166045-ENG258452-EASYCLOSE-EasyCloseAktiv,not activated ,4
ENG166045-ENG260520-EASYCLOSE-ECL_ext_verriegeln,not activated ,4
ENG166045-ENG248655-EASYCLOSE-ECL_Start_ueber_ViP,not activated ,4
ENG122934-erase_error_table,00 00 00 ,3
ENG122933-error_mask,00 00 ,2
ENG253250-ENG130581-Fahrlichthinweis-Fahrlicht_Hinweis_mehrfach,active ,4
ENG253250-ENG126818-Fahrlichthinweis-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,4
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,not installed ,6
ENG141682-ENG11583
