Sunday,20,October,2024,22:21:25:45889
VCDS Version: 24.7.1.0 (x64) HEX-NET2 CB: 0.4643.5
Dealer/Shop Name: Turboavant Workshop
Workshop Code: 123 12345 000001
VIN: WVWZZZ7NZJV037xxx License Plate:
Mileage: 232700km-144593mi Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 25 2B 36 3C 42
44 46 4C 52 53 55 5F 61 62 69 6C 6D 72 A5 BE BF
VIN: WVWZZZ7NZJV037xxx Mileage: 232700km-144593miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-DFMA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 JD HW: 04L 907 309 K
Component: R4 2.0l TDI H20 1999
Revision: 8AH20--- CVN: 954846E2B866C2AD
Coding: 0125001A047619083000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01104L906016JD 004002
ROD: EV_ECM20TDI01104L906016HD_004_VW36.rod
VCID: 74BAB1C47E301BBA4B3-8020
VINID: 9E69EAAAA1DEA9A9800C710624A1E7D3DA
Part No SW: 0BH 300 013 D HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 5301
Revision: 00H11V01 CVN: B9ECA0A2
VCID: 251C9C80856A32320CD-8070
Address 03: ABS Brakes (J104) Labels: 5N0-614-109-V1.clb
Part No SW: 5N0 614 109 CM HW: 5N0 614 109 CM
Component: ESC-EBC460iV1 H14 0014
Serial number: A01Q5GG
Coding: 12F0449A4923C273087B480622CC924310394FF8500B4895
ASAM Dataset: EV_Brake1ESCEPBTRW 006353
ROD: EV_Brake1ESCEPBTRW_006.rod
VCID: 78A285F462587FDA67B-802C
Part No SW: 5K0 959 434 K HW: 5K0 959 434
Component: VWKESSYPQ35GP 093 1403
Revision: 00093000 Serial number: 0474197214
Coding: 03300C
Shop #: WSC 00020 999 39850
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 3D2C54E00DFA9AF274D-8068
Part No SW: 7N0 907 044 BG HW: 7N0 907 044 BG
Component: Clima-Sharan H04 0707
Revision: 00001K06
Coding: 021000C549
ASAM Dataset: EV_ClimatronicSharan A01724
VCID: 76BE8BCC684C09AA757-8022
Slave 1:
Subsystem 1 - Part No SW: 7N0 907 049 C HW: 7N0 907 049 C
Component: KBT-H 004 0103
Serial number: 20180328000000164736
Part No SW: 5K0 937 086 T HW: 5K0 937 086 T
Component: BCM PQ35 M 122 0186
Revision: BC122001
Coding: 40590A3FC925E1C0508804C8B500117403FD0008676D2DB2E480CF20A2C9
Shop #: WSC 00020 790 12345
VCID: 45DC3C0065AAD2322CD-8010
Subsystem 1 - Part No SW: 7N1 955 119 C HW: 7N1 955 119 C Labels: 1KX-955-119.CLB
Component: WWS428 220218 024 0646
Serial number: 18021903071121
Coding: 004DBD
Component: RLHS 050 0107
Serial number: S8Y18M04D16H04M43S01
Coding: 0B28BB
Component: Sensor, DWA 0 005 0502
Component: LIN BACKUP HO H01 0008
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39331810200661
Coding: 0071157211
Shop #: WSC 12345 123 00000
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 372046C82FC6B0A2AE1-8062
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Component: ACC Bosch PQx H03 0210
Serial number: 13091804381025 Dataset Number: V03935274UE 0001
Coding: 00001900FE0739
ROD: EV_ACCBEGVW361.rod
VCID: 363E4BCC28CC49AAB57-8062
1060 - Databus
[FAULT_CIS_EPB_FAIL]
Reset counter: 194
Mileage: 232684 km
Date: 2024.10.18.
Time: 12:40:13
Control Module temperature: 20 °C
Voltage terminal 15: 11.9 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 18011800220002
Coding: 010180
Shop #: WSC 00020 790 00000
VCID: 27009688FFE620223E1-8072
Part No SW: 7N0 959 655 D HW: 7N0 959 655 D
Component: VW10Airbag11M H15 0016
Serial number: 003PWP6MYKTO
Coding: 00314D
ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 40D22D147A08F71A1FB-8014
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60851EDB1D9DC
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS60843EDB1D9D5
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60FED3DA1D9DL
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60E515DB1DDD7
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS60B525C81D9DU
Part No SW: 5K0 953 501 ED HW: 5K0 953 569 AN
Component: LENKS.MODUL 016 0180
Revision: FF010042 Serial number: 20180329200001
Coding: 3112C40008
VCID: 70B2BDD40A28279AAFB-8024
Subsystem 1 - Part No SW: 6C0 959 442 B HW: 6C0 959 442 B Labels: 3C8-959-537.CLB
Serial number: 0801812025400499AE1B
Coding: 2D0000
Part No SW: 7N0 920 880 L HW: 7N0 920 880 L
Component: KOMBI H04 1109
Coding: 110F010800
VCID: 3C2A59E416E093FA433-8068
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 E
Component: Standheizer 044 4941
Revision: 00044000 Serial number: 09028239000000
Coding: 0031142
VCID: 372046C82346B0A2AE1-8062
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 150418F1001396
Coding: 468032
VCID: 7BA89AF853EE54C20A9-802E
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7540
Serial number: HA1-00014.03.18 Dataset Number: v1260x015G0 0000
Coding: 0401
ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
VCID: 52F6175CA464758AB9F-8006
Component: IMMO H04 1109
Coding: 000007
VCID: 6A86AFBC2CF4DD4AE1F-803E
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 18000134417004
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 313478D0C1A26E92E05-8064
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 F HW: 3C8 959 760 F
Component: Sitzmemory H03 1301
Revision: 00H03000
Coding: 000018
Shop #: WSC 12336 024 394758
VCID: 382245F42258BFDAA7B-806C
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0476412155
Coding: 02012102
ROD: EV_HREntryHella_VW32.rod
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0476904178
Coding: 020121
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 J HW: 7N0 959 793 G
Component: TSG FA H05 0561
Revision: Serial number: 0000310342120
Coding: 01152E20DE00411001
VCID: 49C4303049B23652C85-801C
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 S HW: 5N1 909 148 K
Component: J500__APA-BS KL.326 1501
Revision: 1BH04741 Serial number: 00180660014201
Coding: 0000258
Shop #: WSC 00046 000 00000
VCID: 42D6271C7884E50A09F-8016
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 J HW: 7N0 959 792 G
Component: TSG BF H05 0561
Revision: Serial number: 0000315728075
Coding: 01152C20DE00411001
VCID: 48C2353452B8CF5AD7B-801C
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H06 0111
Coding: 05BA00104F000200
Shop #: WSC 38395 001 1048576
Subsystem 1 - Part No: 1T0 941 329 A Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 1T0 941 329 A Labels: 3D0-941-329.CLB
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0472
Serial number: VWZAZ2U0952042 Dataset Number: V03935269PZ 0001
Coding: 02240801FF0000001111110100880A031F0100C4002081008F
ROD: EV_MUStd4CTSAT_VW32.rod
Subsystem 1 - Part No SW: 5NA 919 866 DS HW: -----------
Component: ECE AS 2024 --- 2110
1553 - Function Restriction
B200D F0 [00001001] - due to Internal Communcations Error
[Function restriction due to internal communication error: optical drive (fitted)]
Reset counter: 145
Mileage: 232182 km
Date: 2024.10.07.
Time: 07:38:01
Voltage terminal 30: 12.8 V
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1682
Coding: 330F1873
VCID: 71B4B8D001A22E92A05-8024
Subsystem 1 - Part No SW: 1K0 915 181 L HW: 1K0 915 181 L
Component: J367-BDM H07 0270
Serial number: 44283B11005831928523
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 L HW: 7N0 959 794 H
Component: TSG HL H03 0561
Revision: Serial number: 0000312232683
Coding: 01006C200000411001
VCID: 4CCA092446C0237AF33-8018
Address 69: Trailer (J345) Labels:. 7N0-907-383.clb
Part No SW: 7N0 907 383 A HW: 7N0 907 383
Component: Anhaenger H12 0130
Revision: 3I001001 Serial number: 00000476764876
Coding: 410C040003000000
VCID: 343A71C43E305BBA8B3-8060
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Dataset Number: V03935251ED 0001
Coding: 012408012301000700
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428_VW36.rod
VCID: 30327DD4CAA8679AEFB-8064
Address 6D: Trunk Elect. (J605) Labels:| 7N0-959-107.clb
Part No SW: 7N0 959 107 G HW: 7N0 959 107 A
Component: HDSG-Modul H12 0250
Revision: 41012002 Serial number: 074800616
Coding: 0713334003
ASAM Dataset: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
VCID: 3B285AF813EE94C24A9-806E
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H03 0561
Revision: Serial number: 0000312232597
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H06 0220
Serial number: 12041812K24640 Dataset Number: V03935238SK 0001
Coding: 0004020800000401002613578086A90090000E100040
VCID: 3A265FFC1CD4ADCA51F-806E
Address BE: Slid. Door Rear Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 B HW: 7N0 959 244 B
Component: Schiebetuer_l 005 2414
Serial number: 18100679
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
VCID: 382245F422D8BFDAA7B-806C
Address BF: Slid. Door Rear Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2414
Serial number: 18110841
ROD: EV_AST.rod
End----------(Elapsed Time: 02:15, VBatt start/end: 12.2V/12.2V)-----------
