Any ideas what may be causing this error, checksum fault, Analogue (traditional dash) fault was on the car when I bought it, ignore the other codes they have now mostly been cleared.
Dash appears to be working fine with no issues.
Sunday,20,October,2024,11:15:14:04690
VCDS Version: 24.7.1.0 (x64)
VIN: WVWZZZAUZGW097438 License Plate: YIJ120
Mileage: 265501km-164974mi Repair Order: own
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZGW097438 Mileage: 265501km-164974miles
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BR HW: 04L 907 309 R
Component: R4 2.0l TDI H21 7724
Revision: B5H21--- CVN: DA58EB22
Coding: 01190012034505083000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20TDI01104L906026BR 004006
ROD: EV_ECM20TDI01104L906026BR_004.rod
VCID: 7BF599C1F2F7324E9E-802E
VINID: 9E69EAAAA465A979C024710320BF81952C
4987 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 00 [10101111] - Electrical Fault
Mileage: 264551 km
Date: 2024.10.01
Time: 15:42:13
Engine RPM: 954.50 /min
Normed load value: 23.9 %
Coolant temperature: 12 C
Intake air temperature: 14 C
Voltage terminal 30: 11.640 V
Electric auxiliary heater: shut-off conditions-Bits 0-7: 130
Electric auxiliary heater: shut-off conditions-Bits 0-7: 148
Electric auxiliary heater: relay activation-Bits 0-7: 0
Pre-glow time: 2000 ms
Glow status-Bits 0-7: 0
Glow cycles above temperature threshold-Bits 0-7: 0
Glow cycles above temperature threshold-Bits 0-7: 4
Glow cycles below temperature threshold-Bits 0-7: 0
Glow cycles below temperature threshold-Bits 0-7: 2
Outside temperature sensor 1: B1: raw value: 13.0 C
Readiness: 1 1 0 0 0
Part No SW: 3Q0 907 379 AF HW: 3Q0 907 379 F
Component: ESC H42 0625
Revision: 00000000 Serial number: 62145000002393
Coding: 01FA8AA134290973077B060341CB2980512C90E0608294F514605078C009
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 7EF390D5E1E52766B9-802A
Revision: 00021000 Serial number: 0377001768 Dataset Number: V03935197YW 0001
Coding: 030C0C
VCID: 3A7B5CC5BD4DCB46C5-806E
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08 Dataset Number: 0000
Coding: 00120104202100011005000000101002
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6ADBAC858D6DBBC675-803E
Air quality sensor:
B10CD 00 [00001000] - -
Reset counter: 58
Mileage: 264131 km
Date: 2024.09.10
Time: 16:19:11
Voltage terminal 30: 11.0 V
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 3
CAN input signal(s) status-Back-up lamp: OFF
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061521800129 Dataset Number: V03935222AW 0001
Coding: 03010A46C24122FB0BA44080B11C07281800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 0919F309A82B10DE9C-805C
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150722 042 0551
Serial number: 150731003620
Component: RLHS 037 0059
Serial number: S4Y15M08D20H09M33S39
Coding: 90A8DD
Component: Sensor, DWA 006 0326
Serial number: 000000000ZY1518836QJ
Serial number: 00000000000033114238
6922 - Bulb for Low Beam Headlamp Right
B1218 15 [00001000] - Open or Short to Plus
Reset counter: 78
Mileage: 265466 km
Date: 2024.10.17
Time: 13:46:42
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: operated
Voltage: 14.7 V
Outside temperature: 14.0 C
19210 - Right LED Module for DRL and Parking Lights
B12ED F2 [00001000] - Voltage Supply Open or Short to Plus
Reset counter: 78
Mileage: 265466 km
Date: 2024.10.17
Time: 13:46:22
CAN-Bus_aktiv: On
OFF: operated
Low beam: Not operated
Voltage: 11.6 V
262912 - Sensor for Anti-Theft Alarm System
B1330 F5 [00001000] - Alert Emergency Activation Stage 1
Reset counter: 45
Mileage: 263670 km
Date: 2024.06.20
Time: 11:49:41
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.9 V
Outside temperature: 22.5 C
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331521104091 Dataset Number: 5G0039v__A_ 0023
Coding: 0071051801
VCID: 43852121CA878A8E96-8016
1112084 - Front Left Center Parking Aid Sensor
B10F8 14 [00001000] - Open or Short to Ground
Fault Frequency: 46
Reset counter: 80
Mileage: 264551 km
Date: 2024.09.30
Time: 17:41:01
1112113 - Front Left Center Parking Aid Sensor
B10F8 31 [00001000] - No Signal
Fault Frequency: 155
Reset counter: 80
Mileage: 264821 km
Date: 2024.10.08
Time: 07:43:23
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 15071503212736 Dataset Number: 5g0114v____ 1027
Coding: 00000300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR10E8V+ Dataset Number: 5G0003v____ 0094
VCID: 7F0D6DD1E6EF2E6EB2-802A
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34169677B18081570672
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34169676B21081570508
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 708 15
Serial number: 35767000000AF720F51/
Subsystem 4 - Part No SW: ----------- HW: 480 000 708 15
Serial number: 35867000000E02B4F51
Subsystem 5 - Part No SW: ----------- HW: 480 400 808 15
Serial number: 3516502991D1B623202
Subsystem 6 - Part No SW: ----------- HW: 480 400 808 15
Serial number: 3526502BB1C1EFA260EY
Subsystem 7 - Part No SW: ----------- HW: 480 400 808 15
Serial number: 3556502C51D1B6252378
Part No SW: 5Q0 953 549 E HW: 5Q0 953 549 E
Revision: -------- Serial number: 13112004720115
Coding: 0C00
Shop #: WSC 26498 005 1048576
ROD: EV_SMLSKLOMQB_018_VW37.rod
VCID: 3E7350D5A165E766F9-806A
Part No SW: 5G1 920 957 A HW: 5G1 920 957 A
Component: KOMBI 302 6420
Coding: 27AD09102F80260001886A011400000000000000
VCID: 2E536095710517E669-807A
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [00001001] - Internal Electronic Failure
Mileage: 260962 km
Date: 2023.12.20
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1224
Revision: -------- Serial number: 0003805149 Dataset Number: 5G0067V____ 2215
Coding: 030100041F087300FB00027E080F00010001050000000000000000000000
GVL: 01543C1000000600400C90000000480000000000000000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 75E18FF9D4D3643EE8-8020
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0040
Serial number: 29150001592510095324
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 7992167503
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [00001000] - Performance
Reset counter: 70
Mileage: 263712 km
Date: 2024.06.22
Time: 19:43:37
Terminal 30 power supply: 12.3 V
Terminal 15: OFF
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000180138004
Coding: 5500000000000000
VCID: 346772FD9F293D361F-8060
Component: TSG FS 020 0041
Serial number: 210715BGL04864 Dataset Number: 5G0222v____ 0064
Coding: 003E1220D001048000001000
ROD: EV_DCUDriveSideEWMAXKLO.rod
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007085693
Coding: 0D0000
65593 - Switch for Central Locking
B122D 29 [00001001] - Signal Implausible
Reset counter: 34
65799 - Door Warning / Entry Lighting
B1775 01 [00001001] - Electrical Failure
Reset counter: 4
Mileage: 263670 km
Date: 2024.06.20
Time: 11:26:59
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Dataset Number: V03935226XD 0001
Coding: 8303
VCID: 397943C9B84BC05ECC-806C
23552 - Databus
Reset counter: 4
Mileage: 263670 km
Date: 2024.06.20
Time: 11:28:47
Motor status: 01
System status: Driving mode
Supply voltage: 14.00 V
Temperature: 34.0 C
KFC: 5C
KFA: 00 00
Freeze frame conditions: 5F
uioUdNotFilt_xdu16: 14.03 V
uAdSensI_SwitchedKl30_xdu16: 14.03 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
17152 - Indicator Lamp for Electro-Mechanical Power Steering
C10D5 04 [00001001] - Internal System Fault
Mileage: 265501 km
Date: 2024.10.20
Time: 11:08:34
Motor status: 00
Supply voltage: 10.25 V
Temperature: 15.0 C
KFC: 43
KFA: 00 00
uioUdNotFilt_xdu16: 10.22 V
uAdSensI_SwitchedKl30_xdu16: 10.22 V
Component: TSG BFS 020 0041
Serial number: 110815BH717402 Dataset Number: 5G0157v____ 0060
Coding: 003F1020DE01048000801000
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 428B2425D59D83869D-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006855646
Coding: 150000
65586 - Window Regulator Switch
B132C 29 [00001000] - Signal Implausible
Reset counter: 59
Mileage: 264137 km
Date: 2024.09.13
Time: 14:20:16
Reset counter: 6
Mileage: 263676 km
Date: 2024.06.20
Time: 15:40:22
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: -------------- Dataset Number: V03935205NP 0001
Coding: 029E01000B000200
ROD: EV_HeadlRegulVWAFS_VW37.rod
VCID: 408F2E2DDB9191968B-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
5276400 - Power Output Module for Right Headlamp
C1082 F0 [00001000] - Not Coded
Reset counter: 78
5276209 - Power Output Module for Right Headlamp
C1082 31 [00001000] - No Signal
Fault Frequency: 51
Reset counter: 78
Mileage: 264638 km
Date: 2024.10.03
Time: 12:34:06
9574400 - Bulb for Low Beam Headlamp Right
B1218 00 [00001000] - -
Reset counter: 78
Mileage: 265466 km
Date: 2024.10.17
Time: 13:46:45
Part No SW: 3Q0 035 874 A HW: 3Q0 035 874 A
Component: MU-S-ND-ER 820 0633
Serial number: Dataset Number: 5G0CV1v____ 0001
Coding: 02730001FF00000051111101008808031F0202C601200100CF
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 306F7EED6B3101167B-8064
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4064
Serial number: VWZ6Z9R2230242
Subsystem 2 - Part No SW: 3G0 919 866 H HW: -----------
Component: ECE 2015/16 --- 0430
2562 - Navigation System
B126C F0 [00001000] - Navigation Database Faulty
Reset counter: 47
Mileage: 263697 km
Date: 2024.06.21
Time: 14:36:05
Voltage terminal 30: 12.4 V
3086 - Antenna for Telephone Mount
B1564 01 [00001001] - Electrical Failure
Fault Frequency: 14
Reset counter: 38
Mileage: 263670 km
Date: 2024.06.20
Time: 11:27:12
Voltage terminal 30: 12.2 V
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150715203499
VCID: 6BD5A9818297A2CE0E-803E
End-------------------------(Elapsed Time: 05:03)--------------------------
Address 01: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 10: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 42: DTCs cleared
Address 44: DTCs cleared
Address 52: DTCs cleared
Address 55: DTCs cleared
Address 5F: DTCs cleared
Coding: 030C0C
Air quality sensor:
Coding: 90A8DD
Coding: 0071051801
Coding: 333135
Coding: 333135
Coding: 0C00
Mileage: 260962 km
Date: 2023.12.20
Generator:
Coding: 2CFFFF
Coding: 0D0000
Coding: 8303
23552 - Databus
Mileage: 265501 km
Date: 2024.10.20
Time: 11:19:46
Motor status: 01
Supply voltage: 14.75 V
Temperature: 26.0 C
KFC: 5C
KFA: 00 00
uioUdNotFilt_xdu16: 14.81 V
uAdSensI_SwitchedKl30_xdu16: 14.81 V
Coding: 150000
Coding: 2E0000
Coding: 2E0000
Mileage: 265501 km
Date: 2024.10.20
Time: 11:21:05
Voltage terminal 30: 14.7 V
End-------------------------(Elapsed Time: 04:42)--------------------------
Address 0x17,5G1 920 957 A,UDS Selective Output Tests,IDE00283-Gong
Address 0x17,5G1 920 957 A,UDS Selective Output Tests,IDE02986-Indicator lamps
