Passat B7 2011 both rear speed sensors incorrect signal.
MarkModel13
C?ID=444471
Hi there,
I had an issue with one of the rear speed sensors 2 years ago - I replaced the bearing (rusty and broken speed sensor ring) and everything was fine. But now I have another somehow similar problem - on VCDS I see both rear speed sensors show 0 speed plus many warnings about tire pressure monitor, ABS (scan follows). I replaced the opposite rear bearing and both rear speed sensors. I cleared the errors but no improvement - still 0 speed from both sensors and all the warnings come back immediately after switching the car on. Thank you in advance. Btw. - the radio is replaced so that's why these bus/CD/navigation errors.
Saturday,19,October,2024,21:00:49:55250
VIN: WVWZZZ3CZCE049557   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 4C 4F 52 53 56
          61 62 72
VIN: WVWZZZ3CZCE049557   Mileage: 181790km-112959miles
37-Navigation -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 1110
   Part No SW: 03L 906 018 BG    HW: 03L 907 309 N
   Component: R4 2.0l TDI   H24 9978
   Revision: 47H24---    Serial number: 00000000000000 CVN: 49D706BA
   Coding: 001D0012042401080000
   Shop #: WSC 37605 187 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BG 003010
   ROD: EV_ECM20TDI01103L906018BG.rod
   VCID: 70B82D3B7A2E6EAAAFB-8024
   VINID: 9E69EAAAA0D3A935401091451CE301F4C0
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2708
   Revision: 05351113    Serial number: 00001107280904
   Shop #: WSC 05311 000 00000
   VCID: 176A36A73380D9928E1-8042
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -
                    Fault Frequency: 255
                    Reset counter: 1
                    Mileage: 181791 km
                    Date: 2019.03.12.
                    Time: 20:23:54
   Part No SW: 3AA 614 109 AC    HW: 3AA 614 109 AC
   Component: J104   C2 450M VDB9 0022
   Revision: --H07---    Serial number: 00000004575952
   Coding: 0007603
   VCID: 6E8433436C9A785ABD7-803A
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Reset counter: 185
                    Mileage: 181791 km
                    Date: 2019.03.12.
                    Time: 20:31:35
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.75 V
                    Bin. Bits: 00011111
                    Count: 156
                    Hex Value: 0x0000
03842 - RPM Sensor Rear Right: Incorrect Signal
                    Reset counter: 185
                    Mileage: 181791 km
                    Date: 2019.03.12.
                    Time: 20:31:35
                    Hex Value: 0x0001
                    Voltage: 14.75 V
                    Bin. Bits: 00011111
                    Count: 157
                    Hex Value: 0x0000
                    Reset counter: 185
                    Mileage: 181792 km
                    Date: 2019.03.12.
                    Time: 20:44:18
                    Hex Value: 0x0000
                    Voltage: 13.25 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0004004803
   Shop #: WSC 00015 115 00000
   VCID: 00587DFB4A8E7E2A5FB-8054
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 D    HW: 3AA 937 087 D
   Component: BCM PQ47 H    413 0455
   Revision: BB413001
   Coding: 000000000000000000180080540081E403510088426D85606480C7200041
   VCID: 3B22CA176368DDF24A9-806E
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 05071  10  0603
   Coding: 00B795
   Component: RLS 120811 05  54  0403
   Coding: 02302A
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631120302894
   Coding: 108102
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 7CA0090B26661ACA033-8028
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PGJJS89
   Coding: 0012337
   VCID: 4CC099CB3AC66A4AF33-8018
   Subsystem 1 - Serial number: 6332MTS656732071
   Subsystem 2 - Serial number: 6342MTS684172081
   Subsystem 3 - Serial number: 6351HTS6JUAN9AKJ
   Subsystem 4 - Serial number: 6361HTS6HM2AV9KJ
   Part No SW: 5K0 953 569 AS    HW: 5K0 953 569 AS
   Revision: --X01---    Serial number: 20210128300029
   Coding: 1992250000
   Shop #: WSC 01286 386 08256
   VCID: 094E60DF79B43F62085-805C
   Serial number: 50000000000000463014
   Coding: E30000
   Part No SW: 3AA 920 880 C    HW: 3AA 920 880 C
   Component: KOMBI         H03 0407
   Coding: 161F01
   Shop #: WSC 05314 115 00000
   VCID: 3332E2374BB815B2929-8066
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 290711F1002184
   Coding: 462006
   Shop #: WSC 05314 123 12345
   VCID: 3828D51B525EF6EAA7B-806C
                    Reset counter: 185
                    Mileage: 181791 km
                    Date: 2019.03.12.
                    Time: 20:23:58
01304 - Radio
                    Reset counter: 185
                    Mileage: 181791 km
                    Date: 2019.03.12.
                    Time: 20:31:58
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76B41B2314CA409A757-8022
Address 37: Navigation
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0003311285
   Coding: 0200B7
   Shop #: WSC 05311 115 00000
   ROD: EV_TSGFPQ35BRFVW46X_VW46.rod
   VCID: 3536DC2F45CC0B82BCD-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000002351995
   Coding: 000090
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.310 1002
   Revision: 1AH03733    Serial number: 00112220383501
   Coding: 0000258
   VCID: 3C20C90B6A66DACA433-8068
                    Fault Status: 11101101
                    Reset counter: 185
                    Mileage: 181791 km
                    Date: 2019.03.12.
                    Time: 20:23:54
                    RPM: 833 /min
                    (no units): 7.0
                    Voltage: 14.60 V
   Component:    KSG PQ47 ELV 043 0634
   Coding: 0091020052830E76300494157C084F0B607801
   Component: EZE_2         H40 1620
   Coding: 00000008
   VCID: 6FBA2E4767907152B61-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0003322058
   Coding: 0200B6
   VCID: 3634DB2358CA009AB57-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000002360215
   Coding: 000090
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000149431
   Coding: 0022167
   VCID: 3536DC2F494C0B82BCD-8060
                    Fault Status: 01101101
                    Reset counter: 185
                    Mileage: 181791 km
                    Date: 2019.03.12.
                    Time: 20:23:54
                    Voltage: 14.60 V
                    Count: 104
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 56: Radio
   Component: Batt.regelung H40 1620
   Coding: 030B185A
   VCID: 71BE283F71A467A2A05-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900982409
End----------(Elapsed Time: 01:29, VBatt start/end: 13.2V/13.3V)-----------
Westbury, UK
Have you checked the wiring and connectors to the rear speed sensors - especially any common points?
MarkModel13
C?ID=444471
How can I do this ?. Visually connectors are ok.
Its a bit odd that both rear sensors are faulty ; check to see if you have power and ground at each sensor plug. Also, economy type sensors can fail prematurely.
Genuine or OEM VW / Audi sensors are recommended.
This video should give you some insights:
siLc
Tallinn, Estonia
C?ID=330192
Passat B7 rear ABS sensors are known to fail. What brand sensors did you use?
MarkModel13
C?ID=444471
Original sensors I did not change. But now, I replaced (maybe not necessary, I'm not sure whether they are the problem) with Ridex.
Dr Sheldon
Windsor UK
C?ID=334979
As in before the car has moved -Just at Ignition on ?? If so that will not be a Wheel Bearing or Phaser - Wheel needs to turn before that can be detected.
You will need a Wiring Diagram and test those back to the ABS Module - What you need is a scope to get any level of certainty in your testing !!
MarkModel13
C?ID=444471
Is it nessesary to code when two new speed sensors are installed ? Or to do some adaptation ?
MarkModel13
C?ID=444471
Thank you all who replied !
So, paradoxically I had TWO faulty speed sensors (two rear ones) !
Don't waist your time with non-original electronic parts. FYI - I measured resistance if someone is interested. I have two different values measuring in opposite directions:
RightRightLeftLeft
Faulty (old ones) - original VWopen7.6 MΩopen7.6 MΩ
New - original VW90 kΩ13 kΩ (rising)90 kΩ13 kΩ (rising)
New (didn't work) - Ridex13 MΩ4 MΩ13 MΩ4 MΩ
So I just replaced Ridex with VW, erase error codes and everything works now.
EuroX
Northern NJ USA
C?ID=208579
I mean if you install shit parts you get shit results especially in any German vehicle.
MarkModel13
C?ID=444471
Not exactly, I did it for many mechanical parts, disk brakes, pads, bearings, some suspension stuff - some are better than original ! Obviously for electronics is risky.
EuroX
Northern NJ USA
C?ID=208579
No such thing as better than original.
There have been some exceptions, particularly with mechanical parts, but they are pretty rare.
