since i fixed the issue regarding the broken cable to the door harness, fixed after i pulled the connector from the chassis. but now my ABS control unit does not respond. Monday on a friday, i guess. any one got a clue other than bin the one i have and find another?
Friday,18,October,2024,17:19:38:53543
VCDS Version: 24.7.1.0 (x64)
VIN: TMBJF73TXE9052661 License Plate: SHITBOX
Mileage: 374240km-232541mi Repair Order:
Chassis Type: 3T-SK46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 25 36 37 42 44 46 52 55 56
61 62 69 6D 72 77
VIN: TMBJF73TXE9052661 Mileage: 374240km-232541miles
03-ABS Brakes -- Status: Cannot be reached 1100
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 RQ HW: 03L 906 018 MH
Component: R4 2.0l TDI H28 9980
Revision: 41H28--- Serial number: CVN: 84D6CD8B
Coding: 001D0012042401080000
Shop #: WSC 60223 003 1048576
ASAM Dataset: EV_ECM20TDI01103L906018RQ 003007
ROD: EV_ECM20TDI011_SK46.rod
VCID: 0A1065C7ADEE6EC695-805E
VINID: 91D49A5870E4A152401421860420DAA83B
4713 - No Communication with ABS Brake Control Module
U0121 00 [10100111] - -
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
Engine RPM: 832.00 /min
Normed load value: 25.9 %
Vehicle speed: 255 km/h
Coolant temperature: 55 C
Intake air temperature: 30 C
Voltage terminal 30: 13.240 V
Cruise Control System (CCS): status-Bits 0-7: 44
selected gear-Bits 0-7: 0
Part No SW: 02E 300 062 A HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4008
Revision: 05652104 Serial number: 00001403080606
Coding: 0000024
Shop #: WSC 33361 790 00052
VCID: 132E78A332A4AF0E66-8046
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller
Mileage: 374245 km
Date: 2019.03.11.
Time: 04:19:08
Address 03: ABS Brakes
Part No SW: 3T0 907 044 CE HW: 3T0 907 044 CE
Component: Climatronic H19 0709
Revision: 00001009
Coding: 0010000003
Shop #: WSC 33361 790 00999
ROD: EV_ClimaAutoBasis_SK46.rod
VCID: 77F62C33CE1C632EFA-8022
13701392 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
Part No SW: 1K0 937 087 AN HW: 1K0 937 087 AN
Component: BCM PQ35 H+ 112 0779
Revision: AF112771
Coding: 60190AB8E80508C0500800C8710089EC4F7000AE636D85608081E7040041
Shop #: WSC 43050 004 104857
VCID: 7DFA3E1BE420497EA0-8028
Subsystem 1 - Part No: 3T1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 20031 26 0700
Coding: 00DFB7
Component: RLS 210314 05 54 0403
Coding: 0630ED
Reset counter: 12
Mileage: 374245 km
Date: 2019.03.11.
Time: 04:19:08
Voltage: 13.15 V
Term 50 On
00984 - Left Tail Light (M4)
014 - Defective
Fault Status: 01101110
Reset counter: 12
Mileage: 374245 km
Date: 2019.03.11.
Time: 04:19:09
Voltage: 13.15 V
Term 50 On
00985 - Right Tail Light (M2)
014 - Defective
Reset counter: 12
Mileage: 374245 km
Date: 2019.03.11.
Time: 04:19:09
Voltage: 13.15 V
Term 50 On
01502 - Bulb for Rear Fog; Left (L46)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 12
Mileage: 374245 km
Date: 2019.03.11.
Time: 04:19:09
Voltage: 13.15 V
Term 50 On
01506 - Bulb for Rear Fog; Right (L47)
Reset counter: 12
Mileage: 374245 km
Date: 2019.03.11.
Time: 04:19:09
Voltage: 13.15 V
Term 50 On
Address 10: Park/Steer Assist (J791) Labels:| 3T0-919-475-V2.clb
Part No SW: 3T0 919 475 F HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0012
Revision: -------- Serial number: 56231433502983
Coding: 25C302
Shop #: WSC 12345 678 95875
ASAM Dataset: EV_EPHVA2CAS46X0000 003001
ROD: EV_EPHVA2CAS46X0000_003_SK46.rod
VCID: 408487EFDB52E4968B-8014
8 Faults Found:
12656928 - Databus
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
12656929 - Databus
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
12656930 - Databus
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
12656931 - Databus
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
12656932 - Databus
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
12656933 - Databus
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
12656934 - Databus
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
12656935 - Databus
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
Part No SW: 3T0 959 655 D HW: 3T0 959 655 D
Component: J234__LD5 VW10 HI 2518
Revision: 25019000 Serial number: 003LEP4TWFLZ
Coding: 0017461
VCID: 42808DE71D5EF6869D-8016
Subsystem 1 - Serial number: 6332MTS625360694
Subsystem 2 - Serial number: 6342MTS625020694
Subsystem 3 - Serial number: 6351HTS6CQB2MCKR
Subsystem 4 - Serial number: 6361HTS68UA2MCKJ
Subsystem 5 - Serial number: 63727TS62DAFMCKJ
Reset counter: 12
Mileage: 374245 km
Date: 2019.03.11.
Time: 04:19:08
Part No SW: 5K0 953 521 DD HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140325100305
Coding: 188A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 71E2122BA0783D1E34-8024
Subsystem 1 - Part No SW: 5E0 919 719 F HW: 5E0 919 719 F
Component: E221__MFL-PR6 H04 0130
Coding: 820000
Part No SW: 3T1 920 841 M HW: 3T1 920 841 M
Component: KOMBI H08 0811
Coding: 111E00
VCID: 3D7AFE1BACA0897EE0-8068
12656896 - Function Restricted due to Missing Message(s)
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
Part No SW: 7N0 907 530 AL HW: 7N0 907 530 AL
Component: J533 Gateway H58 1642
Revision: H58 Serial number: 260314F2000679
Coding: 359302
Shop #: WSC 12345 928 07238
VCID: 7AF03507F50E7E4685-802E
Reset counter: 12
Mileage: 374245 km
Date: 2019.03.11.
Time: 04:19:08
Part No SW: 5K0 857 511 B HW: 8P0 857 511 C
Component: FLA H04 0006
Revision: AA001002
Coding: 0201826B74745D545420363E00
VCID: 2D5ACE5B74C019FE50-8078
Reset counter: 12
Mileage: 374245 km
Date: 2019.03.11.
Time: 00:39:12
Component: IMMO H08 0811
VCID: 6AD005478DAECEC675-803E
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 C HW: 3C8 959 760 A
Component: Sitzmemory H05 2901
Revision: 00H05000
Coding: 000039
Shop #: WSC 12336 024 394758
VCID: 356AE63B9C90513E28-8060
Part No SW: 3T0 035 192 S HW: 3T0 035 192 S
Component: RNS315-EU H76 0410
Serial number: SKZAZ2P0037456
Coding: 000004310405000001008000
ROD: EV_RNS315EUV2UDS_VW25.rod
VCID: 3E78F917A1A69266F9-806A
Component: EUR_W_V5 0055
1048658 - Function Restricted due to Missing Message(s)
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:12
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H10 0415
Coding: 011D0320DE00001000
VCID: 52A0BDA70D3E66062D-8006
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 196 3501
Revision: 00H22000
VCID: 3972EA0B7088B55ECC-806C
Fault Status: 11100100
Reset counter: 12
Mileage: 374245 km
Date: 2019.03.11.
Time: 04:19:07
Voltage: 13.25 V
DU
Temperature: 37.0 C
RPM: 826 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H10 0415
VCID: 51A2B2AB08381D1E14-8004
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: -------------- Dataset Number: 3T0036t____ 0005
Coding: 01C200003F000000
ROD: EV_HeadlRegulVWAFSPt_VW46.rod
VCID: 3776EC338E9CA32E3A-8062
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0003
Coding: 8E0000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0003
Coding: 8E0000
13705472 - Databus
U1121 00 [10001001] - Missing Message
Reset counter: 12
Mileage: 374245 km
Date: 2024.10.18.
Time: 04:19:07
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1642
Coding: 030F185A
VCID: 71E2122BA8783D1E34-8024
Component: J367-BDM H07 0180
Serial number: 31062C31051491794329
Address 62: Door, Rear Left (J388) Labels:. 8X0-959-795.clb
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H07 0415
Coding: 010C01200000001000
VCID: 50A4B7AF033214161B-8004
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030511463
Coding: 0100000100000000
VCID: 3064D72F63F274167B-8064
Reset counter: 12
Mileage: 374245 km
Date: 2019.03.11.
Time: 00:39:11
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7N0 959 107 E HW: 7N0 959 107 A
Component: HDSG-Modul H11 0243
Revision: 41011001 Serial number: 074400942 Dataset Number: 3t0771t____ 0001
Coding: 082301C003
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462.rod
VCID: 3972EA0BB888B55ECC-806C
Address 72: Door, Rear Right (J389) Labels:. 8X0-959-795.clb
Component: TSG HR H07 0415
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0982
Revision: -------- Serial number: 35502105128292
Coding: 020000000100110000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi.rod
VCID: 244C2B7F2F0AD8B68F-8070
End-------------------------(Elapsed Time: 03:36)--------------------------
