I'm getting this code (it's a 2010 mk6 Golf GTD). I suspected the siren battery may be failing/failed based on others' experience. Removed and opened siren. No trace of any battery leakage or water ingress and the battery was reading over 6V.
I then tested by setting the alarm with the windows open and was able to trigger the siren by waving an arm inside.
Thought I should check for wiring damage, but not sure where the wiring runs once it disappears into the wing (tried looking in rain channel/under scuttle panel, but can't see).
Any ideas what may be going on or next steps to diagnose? Are any of the adv. measuring values of any use? I could see one for siren status (value "inactive") for example.
Autoscan below. Aware of air quality sensor (trying to get hold of a part at the moment). Line output/speaker monitoring errors due to aftermarket DSP/amps.
Mileage reported with alarm error is ~current mileage (I've cleared and the code comes back). I've also code the alarm as being "not installed" so that I could remove it and then coded it back to installed after refitting to test.
Friday,18,October,2024,11:20:36:37195
VCDS Version: 23.3.0.0 (x64)
VIN: WVWZZZ1KZBW078726 License Plate: LC60-18-OCT
Mileage: 163680km-101706mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 77
VIN: WVWZZZ1KZBW078726 Mileage: 163680km-101706miles
Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 BB HW: 03L 907 309 R
Component: R4 2,0L EDC H22 7818
Revision: 42H22--- Serial number: 00000000000000 CVN: 7F98B9C8
Coding: 00190012040500080000
ASAM Dataset: EV_ECM20TDI01103L906018BB 003005
ROD: EV_ECM20TDI01103L906018BB_003_VW36.rod
VCID: 6BDFDA668214BBCB06-803E
VINID: 9E69EAAAA05BA929C01C81C2188A16A509
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 163B600D09290002681206E6901F0082310800
VCID: 040D91DA878A54B3E7-8050
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
VCID: 7DFBE43EEC60257BA8-8028
9479189 - Signal Line for Air Quality Sensor
B10A4 15 [009] - Open or Short to Plus
Reset counter: 111
Mileage: 163680 km
Date: 2024.10.17
Time: 13:07:51
Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
Component: BCM PQ35 M 103 0615
Revision: 00103 AD
Coding: 48180A388025F10040080080250081EC46710000533D8160648000200040
VCID: 356B3C1E9CD03D3B20-8060
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 20081 26 0512
Coding: 009795
Component: RLS 220810 05 54 0403
Coding: 0330AD
Component: LIN BACKUP HO H11 9004
Reset counter: 111
Mileage: 163680 km
Date: 2024.10.18
Time: 11:15:12
Voltage: 11.85 V
Term 50 Off
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRABTE33 Dataset Number: 5K0003v____ 0085
Coding: 00003133
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B7F2A26B2F4EB4BD6-806E
Serial number: 3572MSME08664255ZZZT
Serial number: 3582MSME763A4255ZZZ-
Serial number: 3512QSME06386D64ZZZ.
Serial number: 3522QSME36306A14ZZZP
Part No SW: 5K0 953 507 BB HW: 5K0 953 549 D
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JHG0012S Dataset Number: 5K0953507BB D005
Coding: 1082000000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 71E3C80EA038511B3C-8024
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0010252
Coding: 820000
Part No SW: 5K6 920 971 A HW: 5K6 920 971 A
Component: KOMBI H04 0406
Coding: 170B00
VCID: 336F02069AA4230B0E-8066
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 100810F2001801
Coding: E9801F0640061200000001
VCID: 6DDBD47E7400B5FB18-8038
Fault Status: 01110100
Reset counter: 111
Mileage: 163665 km
Date: 2024.10.07
Time: 16:53:32
Component: IMMO H04 0406
VCID: 6AD1DF628DEEA2C37D-803E
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668518320
VCID: 2757E656567C5FABA2-8072
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 C
Component: RNS-MID H55 5269
Revision: AB001001 Serial number: VWZ6Z7K6165042
Coding: 04010002010000A10000
Shop #: WSC 05314 123 12345
VCID: 3B7F2A26BAF4EB4BD6-806E
Subsystem 1 - Part No: 1T0 051 859 AS
Component: EU West V17 8557
00859 - Line-Output; Front Right
Reset counter: 111
Mileage: 163680 km
00823 - Line-Output; Front Left
Reset counter: 111
Mileage: 163680 km
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2150
Coding: 0000628
VCID: 336F020652A4230B0E-8066
00120 - Outside Warning Light/Door exit Light Driver Side
01030 - Central Locking Key Switch; Driver Side; Lock
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 3163080EA8B8111B7C-8064
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2118
Coding: 0000628
VCID: 32610702ADBE2A0305-8066
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 111
Mileage: 163680 km
Reset counter: 111
Mileage: 163680 km
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 B HW: 3C8 035 730 B
Component: Telefon 011 0723
Revision: -------- Serial number: 35909603262939
Coding: 020000010100010000000400
ASAM Dataset: EV_UHVPremi A02003
ROD: EV_UHVPremi_A02.rod
VCID: 2241F742355EBA83F5-8076
End-------------------------(Elapsed Time: 02:43)--------------------------
