Resolved New Beetle 2012 - Engine Light and Glow plug light on + limp mode
Resolved
TJD123
C?ID=150899
2012 Beetle, 2ltr TDI (CFFB), 56k, FVWSH inc belt
My wife's lovely Beetle has just thrown up 2 dash lights while on the motorway home. Engine light & Glowplug light. Won't go above 60mph so limping I think..
Full scan below.
It's got 4 engine fault codes! Looks like it's the turbo actuator that's stuck/not moving. Reading other posts it could be a few things.
I'm looking for recommendations as to where to start fault finding based on the codes thrown up if possible.
There are other fault codes from earlier this month that I'm not worried about...yet. :)
Does the EGR failure throw up these faults? Are they a 'mare to change?
tia
Tuesday,15,October,2024,07:56:52:61373
VCDS Version: 24.7.1.0 (x64)
VIN: WVWZZZ16ZCM661931   License Plate:
Mileage: 91250km-56700mi   Repair Order:
Chassis Type: 16-VW32 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 2E 44 56 77
VIN: WVWZZZ16ZCM661931   Mileage: 91250km-56700miles
   Part No SW: 03L 906 018 PN    HW: 03L 907 309 AD
   Component: R4 2.0l TDI   H25 9979
   Revision: 42H25---    Serial number: 00000000000000 CVN: D2652D6D
   Coding: 00190012042500080000
   Shop #: WSC 00429 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018PN 003008
   ROD: EV_ECM20TDI01103L906018RP_VW36.rod
   VCID: 050AEA7084CE9BBEF8-8050
   VINID: 9E69EAAAA046A9374618124304A87A1BD0
17262 - Terminal 30
          U140A 00 [00100000] - Open Circuit
4629 - ECM Power Relay Load Circuit
          P068A 00 [00100000] - Opens Too Early
7934 - Turbocharger Boost Control Position Sensor Circuit
          P2563 00 [11101101] - Implausible Signal
                    Mileage: 89260 km
                    Date: 2024.10.01.
                    Time: 11:34:15
                    Engine RPM: 1387.00 /min
                    Normed load value: 60.0 %
                    Vehicle speed: 23 km/h
                    Coolant temperature: 76 �C
                    Intake air temperature: 29 �C
                    Voltage terminal 30: 14.080 V
                    Charge Pressure Actuator: activation: 99.83 %
                    Charge air pressure actuator: acknowledgment: 13.29 %
                    Turbocharger boost control: offset closed: 0.85 %
                    High press turbocharger actuator: status-Bits 0-7: 0
                    High press turbocharger actuator: status-Bits 0-7: 8
                    High press turbocharger actuator: status-Bits 0-7: 55
                    High press turbocharger actuator: actual uncond volt value: 3325.2 mV
                    Accelerator pedal travel: 32.73 %
9127 - Actuator Module for Turbocharger 1
          P00AF 00 [11101101] - Stuck
                    Mileage: 91228 km
                    Date: 2024.10.14.
                    Time: 17:26:50
                    Engine RPM: 898.50 /min
                    Normed load value: 17.6 %
                    Vehicle speed: 11 km/h
                    Intake air temperature: 27 �C
                    Voltage terminal 30: 14.100 V
                    Charge Pressure Actuator: activation: 100.00 %
Readiness: 1 2 0 0 0
   Part No SW: 5C0 907 379 C    HW: 5C0 907 379 C
   Component: ESP MK60EC1   H31 0156
   Revision: 00H31001
   Coding: E63B40F8092800FB671402E7901A0082251000
   Shop #: WSC 00066 000 00000
   VCID: 2E5875DC79F8F8E669-807A
                    Reset counter: 50
                    Mileage: 89420 km
                    Date: 2024.10.03.
                    Time: 17:52:22
                    Count: 2
                    Count: 4096
                    Count: 8194
                    Count: 43776
                    Count: 64768
                    Count: 1022
   Part No SW: 5C0 907 044 M    HW: 5C0 907 044 M
   Component: Climatronic   043 0202
   Revision: 00001001
   Coding: 3010004002
   Shop #: WSC 00066 000 00235
   ROD: EV_ClimaAutoBasis_VW32.rod
   VCID: 2D5A72D07CFE83FE50-8078
          U1111 00 [00001000] - -
                    Reset counter: 50
                    Mileage: 89420 km
                    Date: 2024.10.03.
                    Time: 17:52:23
   Part No SW: 5C5 937 087     HW: 5C5 937 087
   Component: BCM25 JLB H+4 H48 0256
   Revision: B7048001    Serial number: 04441163120022
   Coding: 7CB8293808410C0092A808006C0F84D50082430F60840000B20004000000
   Shop #: WSC 00439 210 105791
   VCID: 6FE6A8D8BE72B1EE22-803A
   Subsystem 1 - Part No SW: 6R0 959 802 BA    HW: 6R0 959 802 BA  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 1060
   Serial number: KU0KU008121200012501
   Coding: 0DBC30
   Subsystem 2 - Part No SW: 6R0 959 801 AR    HW: 6R0 959 801 AR  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 1060
   Serial number: KU0KU013121200015871
   Coding: 0DBC30
   Subsystem 5 - Part No: 1K8 951 171
   Subsystem 6 - Part No SW: 5C0 959 442     HW: 5C0 959 442
   Component: E221__MFL-YVJ  H02 0103
   Coding: E20000
01816 - Exterior Door Handle Switch in Drivers Door (F272)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 197
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5C5 919 475     HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0005
   Revision: --------    Serial number: 83491213201722
   Coding: 108001
   Shop #: WSC 00066 000 00125
   ASAM Dataset: EV_EPHVA18VW3240000 001004
   ROD: EV_EPHVA18VW3240000.rod
   VCID: 70E4ABA4AB4CAE163B-8024
   Part No SW: 5C0 959 655 F    HW: 5C0 959 655 F
   Component: AirbagVW10    013 0613
   Serial number: 003JQM00KS4-   Dataset Number: 5C5003v____ 0099
   Coding: 0000424A
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 356A5AB094AECB3E28-8060
   Serial number: 3572MSME1D2D256CZZZ4
   Serial number: 3582MSME232D256CZZZ$
   Part No SW: 5C5 920 970 A    HW: 5C5 920 970 A
   Component: KOMBI         H13 0016
   Revision: X0013004    Serial number:
   Coding: 450B01
   ASAM Dataset: EV_KombiUDSMM9RM10 A04305
   ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
   VCID: 295286C048169FDEBC-807C
12648448 - Function Restricted due to Missing Message(s)
                    Reset counter: 50
                    Mileage: 89420 km
                    Date: 2024.10.03.
                    Time: 17:52:22
   Part No SW: 6N0 909 901     HW: 5C5 937 087
   Component: GW-K-CAN TP20 H48 0256
   Revision: B7048001
   Coding: 402100
   VCID: 70E4ABA4A34CAE163B-8024
                    Reset counter: 50
                    Mileage: 89420 km
                    Date: 2024.10.03.
                    Time: 17:52:23
   Part No SW: 5K0 953 234     HW: 5C5 920 970 A
   Component: IMMO          H13 0016
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
   VCID: 6AD0B9CC8D9054C675-803E
   Revision: A1001003    Serial number: 7662317421
   VCID: 295286C040169FDEBC-807C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 377650B846A2392E3A-8062
00750 - Warning Lamp
                    Fault Status: 00101101
                    Voltage: 9.50 V
                        PD
                    Temperature: 26.0�C
                    Reset counter: 50
                    Mileage: 89420 km
                    Date: 2024.10.03.
                    Time: 17:52:22
                    Voltage: 12.13 V
                        DU
                    Temperature: 44.0�C
                    RPM: 1498 /min
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 G    HW: 3C8 035 195 G
   Component: Radio RCD510  050 0207
   Revision: 00000001    Serial number: VWZ1Z3M7093655
   Coding: 01000400040002
   VCID: 2C5C7FD44FE48AF647-8078
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007662383553 Dataset Number: 5K0035730E  0001
   Coding: 0200000000010101
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 275680F85E02A9AEAA-8072
End-------------------------(Elapsed Time: 02:53)--------------------------
davisev5225
Democratic People's Republic of Commifornia, USA
C?ID=263265
Two of your codes are self-explanatory, and probably the source of your MILs and limp mode. Your turbo actuator (probably the waste gate actuator...) is stuck, so the sensor that tells the ECU what position it is in is reporting "incorrect" data most of the time. The two most common causes are vacuum leak or corrosion.
Clean and lubricate the actuator for your waste gate, verify functionality by hand, then clear codes and see what comes back. If the actuator is vacuum controlled, then you should also inspect the diaphragm if possible; if not possible, then test it using a hand vacuum pump.
Check wiring and connector to the G581 position sensor. Faults from that sensor can throw both turbo-related codes in your scan.
See also:
Finally, have you considered upgrading your interface? You'll get additional information from each error code stored instead of the message "[New feature! Extended UDS fault detail is only supported by current gen. interfaces]".
TJD123
C?ID=150899
Thanks for the reply.
I've started the job of diagnosing, all vacuum pipes and wires good but I found oil in the pipe that leads form the engine cylinder head to the cold in of the turbo, not a lot but I thought this should be dry!?
Is this normal/ok?
davisev5225
C?ID=263265
There's always a little bit of blow-by, anyone who says those lines should be bone-dry is technically correct, but clearly doesn't live in the real world! If it's just a thin film, I wouldn't worry. If it's pouring/running out of the lines, then you've got an issue with your turbo seals, your PCV, or something else.
  • Agree
TJD123
C?ID=150899
That's what I thought (hoped), it's just a thin film. Thanks for confirming!
What's the PCV agin?
davisev5225
C?ID=263265
"Positive Crankcase Ventilation", a whole series of hoses, check valves, etc. that take the positive pressure in the crankcase (generated by the small amount of blow-by that gets past the piston rings into the crankcase) and redirects it back into the intake manifold. Usually, though, people say "PCV" to specifically refer to the oil separator diaphragm that's in-line.
TJD123
C?ID=150899
Ahh ok. Thanks for all the info! :thanks:
TJD123
C?ID=150899
Resolved!
Faulty/failed N75. Replaced with a new one. All good.
Thanks!
