2013 Vw CC 2.0T 03841, 03842
logan
C?ID=231137
Saturday,28,September,2024,09:45:31:61848
VCDS Version: 24.7.0.0 (x64)
VIN: WVWBN7AN0DE517983   License Plate: EUNICE
Mileage: 269750km-167614mi   Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 53 55 56
          62 65 72 77
VIN: WVWBN7AN0DE517983   Mileage: 269750km-167614miles
1C-Position Sensing -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 1010
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 FE    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2 06 3952
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 0404010A1C070160
   Shop #: WSC 05314 000 00000
   VCID: 73E5F2981244B00ECE-8026
   VINID: 9E69D278745E0145450472480C034A20C5
               U1017 - 000 -
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 12:35:20
                    Temperature: 39.0°C
                    Temperature: 34.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.065 V
006438 - Relay for Aux Coolant Pump (J496)
               P1926 - 000 - Short to Ground
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 12:35:20
                    Temperature: 39.0°C
                    Temperature: 34.0°C
                    Voltage: 12.065 V
009217 - EVAP Leak Detection Pump Control Circuit
               P2401 - 000 - Short to GND - MIL ON
                    Fault Status: 11100000
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 12:43:53
                    RPM: 1369 /min
                    Load: 14.9 %
                    Temperature: 38.0°C
                    Temperature: 33.0°C
                    Voltage: 11.811 V
Readiness: 1110 0101
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3522
   Revision: 05551213    Serial number: 00001205222839
   Shop #: WSC 05311 000 00000
   VCID: 2541DCC0EC109EBE90-8070
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
                    Reset counter: 1
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 12:43:53
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V431 0024
   Revision: --H07---    Serial number: 00000005865209
   Coding: 0004495
   VCID: 71E9F8906858821E3C-8024
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Fault Status: 01101100
                    Fault Frequency: 9
                    Reset counter: 49
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 12:37:52
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 179
                    Hex Value: 0x0000
03842 - RPM Sensor Rear Right: Incorrect Signal
                    Fault Frequency: 20
                    Reset counter: 49
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 12:37:53
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 157
                    Hex Value: 0x0000
                    Fault Status: 00111000
                    Reset counter: 49
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 19:51:39
                    Speed: 6.0 km/h
                    Hex Value: 0x0001
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 34
                    Hex Value: 0x0000
                    Fault Frequency: 9
                    Reset counter: 49
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 12:37:52
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 179
                    Hex Value: 0x0000
                    Reset counter: 49
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 19:51:39
                    Speed: 6.0 km/h
                    Hex Value: 0x0001
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 34
                    Hex Value: 0x0000
                    Reset counter: 49
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 19:51:39
                    Speed: 6.0 km/h
                    Hex Value: 0x0001
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 34
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 AN    HW: 3AA 907 044 AN
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0010001008
   Shop #: WSC 00015 115 00000
   VCID: 7CF7D9A4F71AFF769F-8028
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
                    Reset counter: 87
                    Mileage: 269740 km
                    Date: 2024.09.28.
                    Time: 17:09:47
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 0465
   Revision: BD421001
   Coding: 0008000000000000008802819400094C2055000840200D20E484402400C0
   VCID: 41896850D878529E8C-8014
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 230212  010 0604
   Serial number: 230212
   Coding: 00B795
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0024
   Serial number: Y12M06D05h17m28s07S4
   Coding: 0280DD
   Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
   Component: J234__713 VW10 HI   2118
   Revision: 24017000    Serial number: 003LDPBFSXW9
   Coding: 0012595
   VCID: 4E93436CD926BDE601-801A
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 000000000090HQ
   Subsystem 3 - Serial number: 0010.05.120000300000640081ÿ†63
   Subsystem 4 - Serial number: 640081ÿ†6332MTS619031442 ÿ†63
   Subsystem 5 - Serial number: 31442 ÿ†6342MTS605381442 ÿ†63
   Subsystem 6 - Serial number: 81442 ÿ†6351HTS6OQ9S5BKJ ÿ†63
   Subsystem 7 - Serial number: S5BKJ ÿ†6361HTS6L1CU4BKR ÿ†63
   Subsystem 8 - Serial number: U4BKR ÿ†63727TS6REPT4BKR ÿ†63
   Subsystem 9 - Serial number: T4BKR ÿ†63827TS6IRDS3BKJ ÿ
   Subsystem 10 - Serial number: S3BKJ ÿ
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - MIL ON
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 12:42:58
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20120613100073
   Coding: 098A270000
   VCID: 6BD5EAF8827468CE06-803E
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
   Part No SW: 3C8 920 971 B    HW: 3C8 920 971 B
   Component: KOMBI         H05 0705
   Coding: 240F00
   Shop #: WSC 05314 115 00000
   VCID: 2C5729E447FAAFF64F-8078
9459995 - Covering for fuel level indicator sensor 1
          B1059 1B [00001001] - Resistance Too High
                    Reset counter: 49
                    Mileage: 269756 km
                    Date: 2024.09.28.
                    Time: 15:29:59
9459994 - Covering for fuel level indicator sensor 1
          B1059 1A [00001000] - Resistance Too Low
                    Reset counter: 89
                    Mileage: 269756 km
                    Date: 2024.09.28.
                    Time: 15:30:51
   Part No SW: 7N0 907 530 AA    HW: 7N0 907 530 G
   Component: J533  Gateway H41 1632
   Revision:   H41       Serial number: 060612F2002479
   Coding: 469006
   VCID: 6FEDFEE8BE6C94EE2A-803A
                    Fault Status: 00110100
                    Reset counter: 87
                    Mileage: 269740 km
                    Date: 2019.02.19.
                    Time: 17:09:45
                    Reset counter: 87
                    Mileage: 269740 km
                    Date: 2019.02.19.
                    Time: 17:09:45
   Part No SW: 3C8 919 965     HW: 3C8 919 965
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1614128R357F03
   Coding: 0000002
   VCID: 75E1CC801C30AE3EE0-8020
                    Reset counter: 87
                    Mileage: 269740 km
                    Date: 2019.02.19.
                    Time: 17:09:47
   Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
   Component:    IMMO         042 0400
   VCID: 377D068846BC1C2E32-8062
02823 - Requirements for Locking the Steering Column Lock not met
                    Reset counter: 49
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 12:44:48
   Revision: A1001003    Serial number: 7662553089
   VCID: 2959D0F04008BADEB4-807C
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0551
   Revision: 12110009    Serial number: 0005108502
   Coding: 0004B7
   Shop #: WSC 05311 115 00000
   ROD: EV_TSGFPQ35BRFVW46X_VW46.rod
   VCID: 6DD1E4E0BC6066FE18-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000002966975
   Coding: 010490
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.302 1101
   Revision: 1AH03735    Serial number: 00121520251401
   Coding: 0000258
   VCID: 3D7114A06480367EE8-8068
                    Fault Status: 11101101
                    Fault Frequency: 12
                    Reset counter: 49
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 12:41:13
                    (no units): 4.0
                    Voltage: 12.10 V
   Component:    KSG PQ47 ELV 042 0634
   Coding: 1B910F8001862E521204141FF08A0F0E105801
00625 - Vehicle Speed Signal
                    Reset counter: 87
                    Mileage: 269740 km
                    Date: 2019.02.19.
                    Time: 17:09:43
                    Fault Frequency: 8
                    Reset counter: 88
                    Mileage: 269756 km
                    Date: 2019.02.19.
                    Time: 12:59:43
   Part No SW: 7N0 907 532     HW: 7N0 907 530 G
   Component: EZE_2         H41 1632
   Coding: 00000008
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0551
   Revision: 14110009    Serial number: 0005107898
   Coding: 0004B6
   VCID: 6ED3E3ECB1669DE621-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000002968063
   Coding: 010490
   Revision:   H19       Serial number: 00000000259988
   Coding: 0022156
   VCID: 36630B8C41B6E52629-8062
                    Fault Status: 01101101
                    Reset counter: 49
                    Mileage: 241545 km
                    Date: 2017.03.17.
                    Time: 15:51:54
                    Voltage: 13.70 V
                    Count: 104
                    Speed: 12.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
02779 - Databus for Electric Parking Brake
                    Reset counter: 86
                    Voltage: 11.90 V
                    Count: 62
                    Hex Value: 0x0270
                    Hex Value: 0x0082
                    Hex Value: 0x0101
   Component: AFS-ECU       H04 0111
   Coding: 071200010B000400
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 377D06888EBC1C2E32-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
13705472 - Databus
                    Reset counter: 87
                    Mileage: 269740 km
                    Date: 2024.09.28.
                    Time: 17:09:46
13705985 - Databus
          U1123 00 [10001001] - Received Error Message
                    Fault Frequency: 14
                    Reset counter: 49
                    Mileage: 269740 km
                    Date: 2024.09.28.
                    Time: 12:21:52
13705987 - Databus
                    Fault Frequency: 24
                    Reset counter: 49
                    Mileage: 269737 km
                    Date: 2024.09.28.
                    Time: 13:46:34
   Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
   Component: Radio Prem-8  H04 0008
   Revision: -----08S    Serial number: VWZ4Z7M1122416
   Coding: 0100040004000F
   VCID: 64C781C467AA27B647-8030
                    Reset counter: 47
                    Mileage: 269737 km
                    Date: 2019.02.19.
                    Time: 13:46:38
                    Reset counter: 87
                    Mileage: 269740 km
                    Date: 2019.02.19.
                    Time: 17:09:43
                    Fault Status: 00101011
                    Reset counter: 49
                    Mileage: 269740 km
                    Date: 2019.02.19.
                    Time: 12:19:20
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000131513
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   VCID: 35610C8094B0EE3E20-8060
12656647 - No Communication with ABS Brake Control Module
          U0121 00 [00001000] - -
                    Reset counter: 87
                    Mileage: 269740 km
                    Date: 2024.09.28.
                    Time: 17:09:46
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007662656418 Dataset Number: 7P6035730K  0001
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A7B1FBCBDAE0146CD-806E
End-------------------------(Elapsed Time: 03:45)--------------------------
Address 0x53,3AA 907 801 H,Basic Settings,Group 007
Address 0x53,3AA 907 801 H,Basic Settings,Group 006
Good afternoon Fists time I ever post here don't know if I am doing it the right way. I need help on this vehicle. Long story short customer got her car out from another shop because they where not able to fix the issue, I got the car with a complete mess. I have to mention brake calipers were not bolted on and E brake was on service mode when she drove it to my shop. We replaced Rear brake pads, rear wheel bearings and ABS sensors as well as the ABS module but can not get rid of the 03841 and 03842 codes, look's like coding is correct but I am stuck with this situation. I have posted the first full scan and will post the the second one in my next thread.
logan
C?ID=231137
Here is the second scan that I mention previously
Saturday,12,October,2024,17:54:07:61848
VCDS Version: 24.7.1.0 (x64)
VIN: WVWBN7AN0DE517983   License Plate: EUNICE ULTIMO SCAN
Mileage: 269760km-167621mi   Repair Order: 10000000000
          62 65 72 77
VIN: WVWBN7AN0DE517983   Mileage: 269760km-167621miles
   VCID: 73E5F2981244B00EC6-8026
               U1017 - 000 -
                    Mileage: 269768 km
                    Date: 2019.03.05.
                    Time: 18:43:30
                    Temperature: 96.0°C
                    Temperature: 49.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.065 V
                    Mileage: 269768 km
                    Date: 2019.03.05.
                    Time: 18:43:30
                    Temperature: 96.0°C
                    Temperature: 49.0°C
                    Voltage: 12.065 V
                    Mileage: 269768 km
                    Date: 2019.03.05.
                    Time: 18:59:12
                    RPM: 1238 /min
                    Load: 12.9 %
                    Temperature: 85.0°C
                    Temperature: 52.0°C
                    Voltage: 12.065 V
Readiness: 0010 0101
   VCID: 2541DCC0EC109EBE98-8070
            P1847 - 000 -
                    Reset counter: 1
                    Mileage: 269768 km
                    Date: 2019.03.05.
                    Time: 18:59:12
   Part No SW: 3AA 614 109 BM    HW: 3AA 614 109 BM
   Component: J104   C2 450M VD35 0040
   Revision: --H07---    Serial number: 00000008201471
   Coding: 0004495
   Shop #: WSC 05311 000 00001
   VCID: 79F9C0B03028CA5E8C-802C
                    Reset counter: 53
                    Mileage: 269768 km
                    Date: 2019.03.05.
                    Time: 01:51:29
                    Hex Value: 0x0001
                    Voltage: 13.50 V
                    Bin. Bits: 00011111
                    Count: 156
                    Hex Value: 0x0000
                    Reset counter: 53
                    Mileage: 269768 km
                    Date: 2019.03.05.
                    Time: 01:51:29
                    Hex Value: 0x0001
                    Voltage: 13.50 V
                    Bin. Bits: 00011111
                    Count: 157
                    Hex Value: 0x0000
   Revision: 00001K02
   Coding: 0010001008
   VCID: 7CF7D9A4F71AFF7697-8028
   Coding: 0012595
   VCID: 4E93436CD926BDE609-801A
            000 - - - MIL ON
                    Mileage: 269759 km
                    Date: 2019.03.05.
                    Time: 01:41:21
   Coding: 098A270000
   VCID: 6BD5EAF8827468CE0E-803E
   Coding: E20000
   Coding: 240F00
   VCID: 2C5729E447FAAFF647-8078
          B1059 1B [00001000] - Resistance Too High
                    Fault Frequency: 16
                    Reset counter: 92
                    Mileage: 269759 km
                    Date: 2024.10.12.
                    Time: 01:02:20
                    Reset counter: 92
                    Mileage: 269759 km
                    Date: 2024.10.12.
                    Time: 01:37:26
   Coding: 469006
   VCID: 6FEDFEE8BE6C94EE22-803A
   Coding: 0000002
   VCID: 75E1CC801C30AE3EE8-8020
   VCID: 377D068846BC1C2E3A-8062
                    Reset counter: 52
                    Mileage: 269768 km
                    Date: 2019.03.05.
                    Time: 21:05:23
   VCID: 2959D0F04008BADEBC-807C
   Coding: 0004B7
   VCID: 6DD1E4E0BC6066FE10-8038
   Slave Driver:
   Coding: 010490
   Coding: 0000258
   VCID: 3D7114A06480367EE0-8068
                    Reset counter: 53
                    Mileage: 269769 km
                    Date: 2019.03.05.
                    Time: 02:11:48
                    RPM: 948 /min
                    (no units): 7.0
                    Voltage: 13.40 V
   Coding: 00000008
   Coding: 0004B6
   VCID: 6ED3E3ECB1669DE629-803A
   Slave Passenger:
   Coding: 010490
   Coding: 0022156
   VCID: 36630B8C41B6E52621-8062
                    Fault Frequency: 28
                    Reset counter: 53
                    Mileage: 269759 km
                    Date: 2019.03.05.
                    Time: 01:02:21
                    Voltage: 12.20 V
                    Count: 104
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   VCID: 377D06888EBC1C2E3A-8062
   Coding: 350000
   Coding: 350000
13705985 - Databus
                    Fault Frequency: 32
                    Reset counter: 53
                    Mileage: 269759 km
                    Date: 2024.10.12.
                    Time: 01:02:21
13705987 - Databus
                    Fault Frequency: 32
                    Reset counter: 53
                    Mileage: 269759 km
                    Date: 2024.10.12.
                    Time: 01:02:21
   VCID: 64C781C467AA27B64F-8030
                    Reset counter: 50
                    Mileage: 269759 km
                    Date: 2019.03.05.
                    Time: 01:02:20
   VCID: 35610C8094B0EE3E28-8060
   VCID: 3A7B1FBCBDAE0146C5-806E
End-------------------------(Elapsed Time: 03:29)--------------------------
Address 03: DTCs cleared
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 1C: DTCs cleared
Address 25: DTCs cleared
Address 2E: DTCs cleared
Address 42: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 4F: DTCs cleared
Address 52: DTCs cleared
Address 53: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 65: DTCs cleared
Address 77: DTCs cleared
Address 0x03,3AA 614 109 BM,Basic Settings,Group 060
How sure are you that the ABS sensors you installed are the correct ones for this car?
logan
C?ID=231137
Thanks for the response I am not sure, I know about the PR code but I don't know how to get the correct part number for the abs sensor with the PR code any help will be much appreciated.
As a general rule of thumb, part numbers are looked up in a parts catalog by VIN, not by PR-Codes.
logan
C?ID=231137
yes sir I totally agree with that as a matter of fact the system that we use is mitchel1 and gets all that info into the system automatically so we can order the parts, I am looking in to it and came to find out that we did get the wrong parts numbers so I will be getting the correct sensors and keep you posted on the result of that, thank you very much for the input
Dr Sheldon
Windsor UK
C?ID=334979
Drive the car Graphing all 4 WSS Speeds
logan
C?ID=231137
Sorry for not posting the conclusion on this fix earlier so here it is, I will try to be as clear as possible and strait to the point, the fix was easy as it can be when you know what to look for which was not the case for me, but I hope this can help someone out there.
Yes at the end it was the wrong sensors on the rear wheel hubs we notice that the part numbers were incorrect of course thanks to UWE , again is a simple mistake and something to look for, sensors look identical the program I am using suggested the sensors and I just click to order , again tanks for the help.
Dr Sheldon
Windsor UK
C?ID=334979
The fix is almost always easy !!
It is the man made faults (as is the case here) that make things more awkward !!
