Climatic to Climatronic Retrofit/Upgrade on a 2018 VW Golf SportWagen...
Marusik
California, USA
C?ID=577993
Hi guys,
I'm in the process of retrofitting/upgrading the A/C control panel on my vehicle. I've found a nice and clean match from an e-bay vendor in the UK. I just tested it on my car and it works as expected. The only issue is that the menu on the infotainment screen, as well as the control knobs are for a right-side driver configuration. I'm looking for the adaptation code to switch to a left-side driver configuration if available...
As always, your input on this matter is truly appreciated!
Marusik
California, USA
C?ID=577993
Sunday,13,October,2024,17:33:51:14621
VIN: 3VW117AU7JM766508   License Plate:
Mileage: 134124km-83340mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 5F
VIN: 3VW117AU7JM766508   Mileage: 134124km-83340miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---    CVN: C87BA4D6
   Coding: 091D00122426002F0000
   Shop #: WSC 00066 790 00012
   ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
   ROD: EV_ECM18TFS020_VW37.rod
   VCID: 46D54166A8247CEA257-8012
   VINID: 0E69C10474651DA7471861402077C0471D
17178 - Databus
          U1123 00 [00100000] - Received Error Message
   Part No SW: 0D9 300 018     HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01803291164 CVN: 0000F57F
   ROD: EV_TCMDQ250021.rod
   VCID: 59EF9A1A099AE312785-800C
          P1734 00 [00000010] - -
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 CS    HW: 5Q0 614 517 AF
   Component: ESC           H62 0973
   Revision: 00000000    Serial number: 51348000000146
   Coding: 04FA6AA124260972807C0300A0CB292056249001C005943400435050C009430B00000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037_VW37.rod
   VCID: 04519B6EDE988EFA7B3-8050
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0012000420011001110500000010102A
   VCID: 6D87DECAED126FB284D-8038
15 Faults Found:
327940 - Motor for Left Temperature Flap
          B108C 71 [00001000] - Actuator Stuck
                    Reset counter: 84
                    Mileage: 134092 km
                    Date: 2024.10.12
                    Time: 17:49:34
                    Voltage terminal 30: 13.3 V
                    Outside temperature: 29.5  C
                    Inside temperature: 27.7  C
                    Left temperature flap - actual value: 24
                    Left temperature flap - actual value: 0.0 %
                    Temperature door left - Specified value: 61
327941 - Motor for Left Temperature Flap
          B108C 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 43
                    Mileage: 134109 km
                    Date: 2024.10.13
                    Time: 13:55:30
                    Voltage terminal 30: 11.4 V
                    Outside temperature: 24.0  C
                    Inside temperature: 27.1  C
                    Temperature door left - Specified value: 204
327943 - Position Sensor for Left Temperature Flap Motor
          B1094 15 [00001000] - Open or Short to Plus
                    Fault Frequency: 8
                    Reset counter: 84
                    Voltage terminal 30: 12.0 V
                    Outside temperature: 63.0  C
                    Inside temperature: 0.0  C
                    Left temperature flap - actual value: 236
                    Left temperature flap - actual value: 100.0 %
                    Temperature door left - Specified value: 25
328196 - Motor for Right Temperature Flap
          B108D 71 [00001001] - Actuator Stuck
                    Reset counter: 42
                    Mileage: 134092 km
                    Date: 2024.10.12
                    Time: 17:49:34
                    Right temperature flap: actual value: 27
                    Right temperature flap: actual value: 0.0 %
                    Temperature door right - Specified value: 58
328197 - Motor for Right Temperature Flap
          B108D 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 43
                    Mileage: 134109 km
                    Date: 2024.10.13
                    Time: 13:55:33
                    Temperature door right - Specified value: 202
328199 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [00001001] - Open or Short to Plus
                    Fault Frequency: 40
                    Reset counter: 45
                    Right temperature flap: actual value: 236
                    Right temperature flap: actual value: 100.0 %
                    Temperature door right - Specified value: 22
329989 - Motor for Defroster Flap
          B1090 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 43
                    Mileage: 134109 km
                    Date: 2024.10.13
                    Time: 13:55:31
                    Defroster flap: actual value: 0.0 %
                    Defroster flap: actual value: 234
                    Defrost door - Specified value: 234
329991 - Position Sensor for Defrost Flap Motor
          B1098 15 [00001001] - Open or Short to Plus
                    Fault Frequency: 61
                    Reset counter: 45
                    Defroster flap: actual value: 19
                    Defrost door - Specified value: 15
328965 - Motor for Front Air Distribution Flap
          B1091 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 43
                    Mileage: 134109 km
                    Date: 2024.10.13
                    Time: 13:55:31
                    Front air distribution flap: actual value: 0.0 %
                    Front air distribution flap: actual value: 131
                    Air distribution door front - Specified value: 131
328967 - Position Sensor for Front Air Distribution Flap Motor
          B1099 15 [00001000] - Open or Short to Plus
                    Fault Frequency: 29
                    Reset counter: 84
                    Front air distribution flap: actual value: 236
                    Air distribution door front - Specified value: 27
329477 - Motor for Fresh Air / Recirculated Air Flap
          B108B 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 43
                    Mileage: 134109 km
                    Date: 2024.10.13
                    Time: 13:55:28
                    Actual value for fresh air/recirculation air flow flap: 90
                    Actual value for fresh air/recirculation air flow flap: 38.5 %
                    Fresh air/recirculating air/back pressure door specified value: 90
329479 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [00001001] - Open or Short to Plus
                    Reset counter: 41
                    Mileage: 134092 km
                    Date: 2024.10.12
                    Time: 17:19:40
                    Voltage terminal 30: 11.5 V
                    Outside temperature: 33.0  C
                    Inside temperature: 30.2  C
                    Actual value for fresh air/recirculation air flow flap: 31.5 %
197122 - Temperature Sensor for Left Vent
          B1087 15 [00001001] - Open or Short to Plus
                    Reset counter: 44
                    Mileage: 134116 km
                    Date: 2024.10.13
                    Time: 14:10:06
                    Outside temperature: 28.0  C
197378 - Temperature Sensor for Right Vent
          B1088 15 [00001001] - Open or Short to Plus
                    Reset counter: 44
                    Mileage: 134116 km
                    Date: 2024.10.13
                    Time: 14:10:06
263426 - Air Quality Sensor
          B10AF 31 [00001001] - No Signal
                    Reset counter: 41
                    Mileage: 134092 km
                    Date: 2024.10.12
                    Time: 17:19:37
                    Voltage terminal 30: 11.6 V
                    System run time-Terminal 15 on: 3 s
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0246
   Revision: --------    Serial number: C86402071802NT Dataset Number: V03935274HK 0001
   Shop #: WSC 00066 790 00074
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0B43B052F3C6C1823A9-805E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    180421  043 0551
   Serial number: 97022066180507021156
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S7Y18M05D24H07M03S15
   Coding: 00A8DD
   Serial number: 003GCR0978LH Dataset Number: V03935251DR 0001
   VCID: 47CB4C62AF2E65E2DE1-8012
   Serial number: IBH000000000009DUXEG
   Coding: 303132
   Subsystem 2 - Part No SW: -----------    HW: 480 000 106 18
   Serial number: 357000000000E8846E2S
   Subsystem 3 - Part No SW: -----------    HW: 480 001 606 18
   Serial number: 35800000000AB0E02E2Q
   Subsystem 4 - Part No SW: -----------    HW: 480 401 905 18
   Component: SideSensor_Dr  004 6149
   Serial number: 35100011C2AF26F64445
   Subsystem 5 - Part No SW: -----------    HW: 480 402 005 18
   Component: SideSensor_Pr  004 6149
   Serial number: 35200011C2B6CEB591EN
   Subsystem 6 - Part No SW: -----------    HW: 480 400 206 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001B129F25F5D4AK
   Subsystem 7 - Part No SW: -----------    HW: 480 400 206 18
   Component: FrontSensor_P  003 6149
   Serial number: 3560001B129F25F5E22C
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 18051820240142
   Coding: 0410
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   VCID: 025D9D76C48C80CA49F-8056
   Part No SW: 5G1 920 840 C    HW: 5G1 920 840 C
   Component: KOMBI         242 0310
   Coding: 0BB5100AA180CF0502087A001000080000000000
   Shop #: WSC 12345 123 61029
   VCID: 270BECE20F6E85E23E1-8072
          U1110 00 [00001001] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 45
                    Mileage: 124662 km
                    Date: 2024.05.26
                    Time: 14:21:51
16777022 - Function Restricted due to Interrupted Communications
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 18
                    Mileage: 124662 km
                    Date: 2024.05.26
                    Time: 13:58:28
   Part No SW: 3Q0 907 530 K    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5323
   Serial number: 15061800840170 Dataset Number: V03935272LR 0001
   Coding: 0101000830085900FA0000081C0F00000001070000000000000000000000
   Shop #: WSC 00066 790 00215
   GVL: 01D03C0000000000400C00000000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 372B3CA2DFCE1562AE1-8062
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 33180000792440091439
   Coding: 31FFFF
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [00001000] - -
          [Timeout Knoten 0x46 / 08 - Steuerger t f r Klima]
                    Reset counter: 84
                    Mileage: 134092 km
                    Date: 2024.10.12
                    Time: 17:35:06
                    Terminal 30 power supply: 12.4 V
                    Terminal 15: OFF
   Serial number: HA1-00012.04.18 Dataset Number: v1260x015G0 0000
   Coding: 0001
   VCID: 4CC1734EB64886BAF33-8018
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Serial number: 7038817403128  Dataset Number: V03935265HB 0001
   Coding: 003003200000020000000000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 45D7466A952277F22CD-8010
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000509182
   Coding: 011000
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  172 1081
   Dataset Number: V03935281SK 0001
   Coding: 010A0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F9673E5A60A25A8FB-8004
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 8038817702796  Dataset Number: V03935265HC 0001
   Coding: 003003200C00020000000000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 44D15B6E9E184EFA3B3-8010
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000522677
   Coding: 091000
   Part No SW: 5G6 035 868     HW: 5G6 035 868
   Component: MU-E--ER      680 8740
   Serial number: 11041800010929 Dataset Number: V03935281LR 0001
   Coding: 02730200FF00000041220001001000009F0200D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 70B9C7BEFA20825AAFB-8024
          U1014 00 [00001001] - -
                    Reset counter: 14
                    Mileage: 124588 km
                    Date: 2024.05.24
                    Time: 18:08:57
                    Voltage terminal 30: 12.5 V
1637 - Interface for External Media
          U11B8 00 [00001000] - No Communications
          [USB - communication error]
                    Reset counter: 80
                    Mileage: 134057 km
                    Date: 2024.10.11
                    Time: 12:20:53
                    Voltage terminal 30: 12.1 V
End----------(Elapsed Time: 01:22, VBatt start/end:12.3V/12.2V)
Marusik
California, USA
C?ID=577993
After installing the Climatronic control module I run a VCDS scan and found a quite large number of faults (15-just on the HVAC section). I'm assuming these are related to the new control panel retrofit.
Since I'm not looking forward to upgrade the whole HVAC unit/box, which is more of a major project, I'm wondering how concerned should I be about all these faults?...
siLc
Tallinn, Estonia
C?ID=330192
The correct HVAC box is a prerequisite to Climatronic working correctly. You’re missing some flap motors and sensors. Would probably be better just to put the Climatic panel back until the correct box can be installed.
Marusik
California, USA
C?ID=577993
Never mind. I was able to switch the driver side configuration by using an OBDeleven. Since having a dual climate zone was not the main goal of this project, I won't bother with the hassle of installing the correct box and rather live with the faults as long as they don't have any effect on the vehicle's operation and drivability. So I will keep the Climatronic control panel, which is working just fine and it offers nicer features, not to mention the upscale appearance it adds to the dashboard...
Cuzoe
C?ID=279487
At minimum you will need to install the "climatronic retrofit" kit which includes a couple of temp sensors, you can grab that on Ali... https://www.aliexpress.us/item/2255801025784216.html
  • You can code out the fault for the air quality sensor. Some of the other faults you'll have to live with even after you add the temp sensors.
  • It will not impact the vehicle operation or drivability, technically, since it's just HVAC.
But as currently installed there is little (to no) chance your system is working fine, although I guess that's up to your definition of "fine" ultimately.
  • The climatronic panel adjusts temperature based on vent temp sensors, which you don't have (the Ali express kit will solve that).
    • This will be single zone of course, but that's no big deal.
  • Right now you have faults for the left temp flap which means no real control over temperature
    • Once you have the temp sensors installed this flap will be used to adjust your temperature.
    • The climatronic panel will control the "left" temp flap which is actually your only temp flap but again, single zone, so no big deal
  • Climatronic HVAC box has a separate motor to control the defrost vent flap.
    • Your car doesn't have that, so the climatronic panel is not able to direct air properly
    • Climatronic can do any combination of foot/face/defrost vents, while climatic an only do 2 of those at a time
    • Lots of people live with this air direction issue when doing the half retrofit.
    • What basically happens is the air will sometimes go where you want, but mostly the system will "hunt" for the right position, never finding it.
    • I could not live with that, mostly because max defrost became useless.
    • You can start at this post, and read through the thread to see how this can be solved.
  • Because of a different air intake box (above/forward of the glovebox) the fresh air/recirc function is not perfect
    • The door will close somewhere near 90% of the way though so most live with this.
The full thread for the half retrofit is here... https://www.golfmk7.com/forums/inde...pgrade-with-instructions-and-pictures.379148/
Marusik
California, USA
C?ID=577993
Thanks for your feedback, Cuzoe.
Yes, after reading more in-depth postings about this kind of retrofit, I did order the harness kit from Ali-Express, which I hope it will help resolve some of the faults, at least those related to temp sensors.
Meanwhile, do you happen to know if the climatic/manual system have any temp sensors, at all?...
So far my partially done retrofit blows through all vents simultaneously, and by setting the air flow in the menu screen, is able to maintain a steady cabin temperature in auto/sync mode (72F) all through out the day, even when the outside temperature fluctuates from morning to evening, and no "hunting" issues detected...
Cuzoe
C?ID=279487
Climatic does not have any sensors. It's possible your system isn't hunting because it doesn't know the position of any of the flaps so it's just not moving them. From what I remember you still end up with somewhere around eight faults after installing the sensors.
At minimum of fault for the Right Temp flap and its position sensor, a fault for the defrost motor and its position sensor, a fault for the other vent temp sensor, a fault for the air intake motor and position sensor (your car has an air intake door motor now but it's the wrong motor and it does not have a position sensor), possibly a fault for the motor that controls flap for air direction because the motor in a climatronic box is a different one.
As I mentioned you can code out the air quality sensor and it looks like your unit is not coded for the sunlight sensor as I don't see that fault in your scan. I don't remember being able to code that out but maybe so.
Marusik
California, USA
C?ID=577993
Great! I appreciate your feedback. At this point I'm still waiting for the connection harness to arrive and will follow up with you guys if I happen to have any other questions. Thanks!
