2015 jetta tdi no start no crank
Words
Alberta, Canada
C?ID=531042
Hello my first time using the ross tech forums
i have a 2015 jetta tdi auto dsg
my car just stopped working i have copy pasted one of the vcds scans i did the date is wrong on the scan a new pc i just put together to use vcds.
there is an aftermarket stereo
just got the car towed home car wont start push button does nothing,
steering wheel controls dont work at all steering lock doesnt work either
my drivers window is down can not get it to go up.
i bought a new battery and installed it nothing changed, i replaced the batterys in both key fobs
nothing changed. i searched google for a day and now i think it is a more serious issue so i got the vcds out and here i go!
any help? Would be greatly appreited ****i usally only work on ALH and this is a first at going with the newer tdis
Tuesday,23,January,2024,20:31:59:22826
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: 3VWLA7AJ5FM203852   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 04 05 08 09 13 15 17 19 25 2B 2E 37 3C 44 47 55 56
          77
37-Navigation -- Status: Cannot be reached 1100
47-Sound System -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 AK    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 9287
   Revision: 8AH20---    CVN: DF25D31B38D3FF82
   Coding: 011D001A042410085000
   Shop #: WSC 99919 999 00000
   ASAM Dataset: EV_ECM20TDI01104L906016AK 004012
   ROD: EV_ECM20TDI01104L906016AK_004.rod
   VCID: 72BDD696042AB33A297-8026
   VINID: 0E69DC44745A15674200320508AF7B2D81
17919 - Cruise Control Switch (E45)
          P0568 00 [00100111] - Implausible Signal
                    Mileage: 272283 km
                    Date: 2113.14.29
                    Time: 01:13:33
                    Engine RPM: 0.00 /min
                    Coolant temperature: 17  C
                    Intake air temperature: 17  C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 10.940 V
                    ACC variants-Bits 0-7: 0
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 33
                    ACC variants (coding)-Bits 0-7: 1
                    Acceleration: 0.000 m/s
4714 - Steering Column Control Module
          U0212 00 [00100111] - No Communications
                    Mileage: 272283 km
                    Date: 2113.14.14
                    Time: 10:46:12
                    Coolant temperature: 38  C
                    Intake air temperature: 38  C
                    Voltage terminal 30: 12.240 V
                    Limitation: accelerator pedal: 140.0 Nm
                    selected gear-Bits 0-7: 0
18875 - Cruise Control Switch (E45)
          P0568 00 [00100110] - Implausible Signal
                    Fault Frequency: 102
                    Mileage: 272283 km
                    Date: 2113.14.14
                    Time: 10:46:12
                    Coolant temperature: 39  C
Readiness: 0 0 0 1 1
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4517
   Revision: 05652104    Serial number: 00001406110706
   Shop #: WSC 44551 111 44551
   VCID: 2517FDCA89E494827C5-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -
                    Fault Frequency: 103
                    Mileage: 272283 km
                    Date: 2049.14.14
                    Time: 10:46:14
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527)
                    Fault Frequency: 105
                    Mileage: 272283 km
                    Date: 2049.14.14
                    Time: 10:46:14
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B400C492200FD851302E9921B0042A110F018
   Shop #: WSC 38657 001 1048576
   VCID: 0451804E2E1E8D8A0BB-8050
03409 - Rolling Mode recognized
                    Reset counter: 57
                    Mileage: 272283 km
                    Date: 2049.14.14
                    Time: 00:37:03
                    Count: 2
                    Count: 12
                    Count: 4096
                    Count: 396
                    Count: 43776
                    Count: 1791
02849 - Control Module for Lane Change Assistance (J769)
                    Reset counter: 57
                    Mileage: 272283 km
                    Date: 2049.14.14
                    Time: 09:48:47
                    Count: 4608
                    Count: 8270
                    Count: 51472
                    Count: 64762
                    Count: 767
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0336320337 Dataset Number: 160116v____ 0002
   Coding: 030C0C
   Shop #: WSC 00066 000 00018
   VCID: 372B27822FC81612DE9-8062
65813 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
                    Reset counter: 97
                    Date: 2114.14.02
                    Time: 00:20:27
1053191 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C 11 [00001000] - Short to Ground
                    Reset counter: 97
                    Date: 2113.14.14
   Part No SW: 1K8 907 044 E    HW: 1K8 907 044 E
   Component: Climatronic   H05 0102
   Revision: 00001K02
   Coding: 001000C002
   Shop #: WSC 00066 000 00120
   VCID: 313F199AC1ACC82290D-8064
   Part No SW: 7H0 937 090 E    HW: 7H0 937 090 A
   Component: BCM PQ25 Max3 H74 0725
   Revision: B8074001    Serial number: 27013204140421
   Coding: 7B994B9A082B0F0008382081240884C55286760E608510D0B0A010022844
   Shop #: WSC 00066 000 00000
   VCID: 30391C9ECA26C12A9F3-8064
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14102585140619072404
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14102584140624192142
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Serial number:     WRH000BTFWE
   Coding: 180000
   Subsystem 4 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14102587140620083055
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14102586140612224434
   Coding: 800000
00886 - Turn Signal Switch (E2)
                    Fault Status: 01101000
                    Fault Frequency: 121
                    Reset counter: 57
                    Mileage: 272283 km
                    Date: 2049.14.14
                    Time: 09:51:31
03302 - Response Closing Status of Passenger's Door
                    Reset counter: 83
                    Mileage: 269966 km
                    Date: 2049.14.02
                    Time: 10:38:50
                    Reset counter: 97
                    Mileage: 272283 km
                    Date: 2050.14.02
                    Time: 00:00:08
Address 13: Auto Dist. Reg
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD026M4K   Dataset Number: 160003V____ 0333
   Coding: 00004B4C
   Shop #: WSC 00066 790 00014
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140000Z61F0+
   Coding: 303346
   Serial number: 3572MSME544E1C46ZZZ0
   Serial number: 3582MSME4E4F1C46ZZZB
   Serial number: 3516KSME303A7B2EZZZ$
   Serial number: 3526KSME7E187B2EZZZB
   Serial number: 3556LSME1A17622FZZZ
   Serial number: 3566LSME5218622FZZZ-
          B10B4 00 [00001000] - Function Restriction due to Undervoltage
                    Reset counter: 97
                    Mileage: 272283 km
                    Date: 2114.14.02
                    Time: 00:21:07
Address 17: Instruments
   Part No SW: 6N0 909 901     HW: 7H0 937 090 A
   Component: GW-K-CAN TP20 H74 0725
   Revision: B8074001
   Coding: 102200
   VCID: 70B9DC9E0AA6812ADF3-8024
                    Reset counter: 240
                    Mileage: 227113 km
                    Date: 2027.14.10
                    Time: 14:31:46
                    Reset counter: 97
                    Mileage: 272283 km
                    Date: 2049.14.21
                    Time: 00:00:13
   Component: IMMO          H04 0818
   Coding: 000007
   VCID: 6A8DCEF62CFA7BFA917-803E
   Revision: 00000000    Serial number: 14000152232005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 30391C9ECAA6C12A9F3-8064
13635840 - Supply voltage
          [Under voltage (continued)]
                    Reset counter: 97
                    Mileage: 272283 km
                    Date: 2114.14.02
                    Time: 00:00:23
                    ELV State: 0C
                    Information Clamps: 07 00
                    CoCo State: F0 01
                    WFS State: 41 1A
                    Vehicle speed: 655.35 km/h
                    Voltage: 37
          U1400 00 [00001000] - -
          [Under voltage (temporary)]
                    Reset counter: 97
                    Mileage: 272283 km
                    Date: 2114.14.01
                    Time: 23:39:30
                    ELV State: 0A
                    Information Clamps: 00 00
                    CoCo State: F0 01
                    WFS State: 41 1A
                    Voltage: 4C
1049345 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [00001000] - Performance
          [CAN-Bus off]
                    Reset counter: 97
                    Mileage: 272283 km
                    Date: 2114.14.02
                    Time: 00:03:57
                    ELV State: 0C
                    CoCo State: F0 01
                    WFS State: 41 1A
                    Voltage: 2E
Address 2E: Media Player 3
Address 37: Navigation
Address 3C: Lane Change
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 307    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392F21BA155C006228D-806C
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.5 V
                        PD
                    Temperature: 33.0 C
                    Count: 2
                    Steering Angle: 0.00
                    Count: 1
                        SteerAng n.Init
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H08 6815
   Revision: --------    Serial number: EAA098A0154097 Dataset Number: 560050v____ 1607
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 2615FAC6F8629F9A75F-8072
1048588 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [00011000] - Performance
          [No communication]
                    Reset counter: 226
                    Mileage: 226411 km
                    Date: 2090.14.28
                    Time: 16:12:59
                    Reset counter: 97
                    Mileage: 272283 km
                    Date: 2114.14.02
                    Time: 00:00:57
   Component: AFS-ECU       H04 0111
   Revision: --------    Serial number: -------------- Dataset Number: V03935195PL 0001
   Coding: 081200010B000200
   Shop #: WSC 01383 790 50316
   Subsystem 1 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
          [Funktionseinschraenkung durch Unterspannung]
                    Reset counter: 97
                    Mileage: 272283 km
                    Date: 2114.14.02
                    Time: 00:20:54
5275926 - Power Output Module for Left Headlamp
          C1081 16 [00001000] - Voltage Too Low
                    Reset counter: 97
                    Mileage: 272283 km
                    Date: 2113.14.29
                    Time: 01:12:49
5276182 - Power Output Module for Right Headlamp
          C1082 16 [00001000] - Voltage Too Low
                    Reset counter: 97
                    Mileage: 272283 km
                    Date: 2113.14.29
                    Time: 01:12:49
Address 56: Radio
Address 77: Telephone
End----(Elapsed Time: 03:30, VBatt start/end: 12.2V/12.2V. VIgn 0.1V)------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Welcome! Nice first post. :thumbs:
Please verify yourself.
Update VCDS, it's free:
Got it. He joined the forum in May but didn't register his HEX-V2 with us until July.
Moving to Car Repair Support.
Words
Alberta, Canada
C?ID=531042
I registered the hex cable again and i updated the vcds i will scan the car again. a wiring diagram telling me what computers are where and what seems to be stopping power?
i did find some mouse poop.. not alot but some... under the battery, also i am wondering if i can cross the solenoid on the starter to see if the car will crank or start... not sure how a car goes from working great to nothing over the course of a week of sitting.. how many computers does this car have? and would this wiring diagram site have all that info so i can start checking the wires going to the computers.
A wiring diagram will enable you to trace backwards from things that aren't powered up to (hopefully) find the thing that's keeping power from flowing where it needs to. If I were chasing this, I'd start with pin 1 of the diagnostic socket. It's supposed to have power when the ignition is switched on. Follow it back toward the battery in the wiring diagram.
See the list at the top of your scan? I count 21. But some of them have sub-systems so the actual number is probably higher.
EuroX
Northern NJ USA
C?ID=208579
Check connections at battery make sure there is no black cover over the ground post of the battery. I can't tell you how many times I have seen the general public do this. Then check main fuse box under the hood.
Words
Alberta, Canada
C?ID=531042
Hello all! today is a good day i found the bad wire and got my vw started! thank you all for commenting and putting me on the correct path!
EuroX
Northern NJ USA
C?ID=208579
Can you please clarify what was the issue and provide pictures if possible for other that may run into this very issue.
