2013 Audi S8, aftermarket exhaust and an APR Stage 1 tune. Any help is appreciated. Two things that stand out are the 02856 - Sensing Area for Control Module 2 Blocked and
Video Cable for Image Processing
C1107 02 [009] - Signal Failure
Mon,Oct,14,2024,12:53:23
VCDS Mobile: 0.4643
Data Version: 00000064
VIN: WAUD2AFD1DN029864
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 1B 20 22 28 34 36 3B
3C 42 46 47 52 53 56 5F 62 6C 6D 6F 72 7F 81 84 85 88 89 8B
8E 8F 90 A9 BA
6F-Centr. Conv. II -- Status: Malfunction 0010
7F-Inform. Electr. II -- Status: OK 0000
81-Gear Shift -- Status: Malfunction 0010
8F-Pretension. Front Left -- Status: OK 0000
90-Pretension. Front Right -- Status: OK 0000
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CGTA) Labels: 4H-01.lbl
Part No SW: 4H0 907 557 E HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0004
Revision: NCH62---
Coding: 022A00326546000E1000
Shop #: WSC 21156 003 1048576
ASAM Dataset: EV_ECM40TFS0114H0907557E 001003
ROD: EV_ECM40TFS0114H0907557E.rod
VCID: 3227B9CB9E17E91E557B3B78-8067
18742 - Control Module for Exhaust Flap
P14AB 00 [108] - Mechanical Malfunction
18740 - Control Module for Exhaust Flap 2
P14AC 00 [108] - Mechanical Malfunction
Address 02: Auto Trans (J217-) Labels: 4H-02.lbl
Part No SW: 4H1 927 158 BL HW: 0BK 927 156 AG
Component: 0BK 40TFSIUSA H16 1004
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMALX51011 002020
ROD: EV_TCMALX51011_002.rod
VCID: 7BB954EF09DDE856C65D5EE4-802E
12480 - Internal Control Module
P060A 00 [032] - Processor Performance Monitoring
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 E HW: 4H0 907 379 E
Component: ESP PREMIUM H10 0352
Revision: --------
Coding: C2FDB20043BF4D00E200
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 342BBFD36403E72E47872D50-8061
0694 - Tire Pressure Warning
C102D 00 [009] - -
0728 - Function Restriction due to Faults in Other Modules
U1113 00 [008] -
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CD HW: 4H0 907 064 CD
Component: BCM2 2.0 H33 0433
Coding: 0D872006000000000000
VCID: 6D9D6AB747A96EE648C9A03C-8038
Subsystem 1 -
Subsystem 2 - Part No SW: 4H0-905-852-C
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000
Coding: C018320085043201010001010101112131313333283333
VCID: 352D82D76F79E6267099585C-8060
No fault codes found.
Address 08: Auto HVAC (J255) Labels: 4H0-820-043.clb
Part No SW: 4H0 820 043 L HW: 4H0 820 043 L
Component: Klima 4 Zonen H20 0130
Coding: 680120785C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_AU64.rod
VCID: 29155EA7B3C1AAC6E411D4CC-807C
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002
Coding: 09072091077C9FF3BB000844A0003800009CD3088A0001218001085C7B00
VCID: 6FA170BF4DA59CF67AD5DA14-803A
Subsystem 1 - Part No SW: 4H1-955-119-C Labels: 1Kx-955-119.clb
Component: WWS641 130218H35 0080
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0-955-559-C Labels: 8K0-955-559.clb
Component: RLS H04 0003
Coding: 025523
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4G0-907-410-A
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 4H0-907-472-B
Component: A31 LED Mod1LH03 0006
Coding: 100000
Subsystem 6 - Part No SW: 4H0-907-472-B
Component: A27 LED Mod1RH03 0006
Coding: 100000
Subsystem 7 - Part No SW: 4H0-907-705-K
Component: EVLS-SG H08 0300
Coding: 020300
Subsystem 8 - Part No SW: 4H0-907-658
Component: AQ_Hum_SensorH03 0003
01800 - Light Switch (E1)
03280 - Switch Position of Light-Switch Knob
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001
Coding: A80923
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71A576C75B9192066CE1CC6C-8024
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 561 B HW: 4H0 907 561
Component: ACC3 H19 0410
Coding: 7601010101
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2A17A1ABB6C7A1DEED2BC3D8-807F
145152 - Function Restriction due to Faults in Other Modules
U1113 00 [008] -
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] -
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H45 0042
Revision: --------
Coding: 303143303230303030314A55304C34483053
ROD: EV_AirbaAU10BPAAU64X_AU64.rod
VCID: 373188DF75750C3662A572B4-8062
Subsystem 1 - Part No SW: 4H0-959-339-A
Component: BF-Gewichtss.H03 0040
Serial Number: 5850000R1330807DVD��
Subsystem 2 - Serial Number: 3575HRB401650E6EEOG7
Subsystem 3 - Serial Number: 3585HRB404P1SJR0E15W
Subsystem 4 - Serial Number: 3515JRB400A50G4GPHPL
Subsystem 5 - Serial Number: 3525JRB400A50G4GL0K$
Subsystem 6 - Serial Number: 3554VRB400250FSMBA6H
Subsystem 7 - Serial Number: 3564VRB400U50FSML1NL
1048581 - Databus
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Component: Lenks.Modul H03 0005
Revision: --------
Coding: 00003C
VCID: 373188DF7575143662A572B4-8062
Subsystem 1 - Part No SW: 4H0-951-528-A
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4H0 920 880 G HW: 4H0 920 880 G
Component: TBenUSAACCNV- H51 0515
Revision: 34081076
Coding: 0B470803B740D705020100
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU64.rod
VCID: 2E1FADBB8A2FCDFE3143EF08-807B
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4H0 907 468 AC HW: 4H0 907 468 AC
Component: J533--Gateway H12 0037
Revision: --------
Coding: 00E1034800
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS_001_AU64.rod
VCID: 72A779CB5E97A91E95FBFB78-8027
Subsystem 1 - Part No SW: 4H0-915-181-F
Component: J367-BDM H08 0181
Serial Number: 50079F29191910304299
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4H0 907 144 C HW: 4H0 907 144 C
Component: DYNAMIKLENK. H06 0100
Revision: 51001005
Coding: 090000
VCID: 28135BA3A8CB8BCEFB1FA9C0-807D
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 G HW: 8K0 857 511 G
Component: FLA H04 0020
Revision: AB001001
Coding: 04018B6B74745D545420363E00
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0013
Shop #: WSC 00000 000
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 2711589FA5D59CB6F205A2F4-8072
Address 28: HVAC, Rear (E265) Labels: 4H0-919-158.clb
Part No SW: 4H0 919 158 J HW: 4H0 919 158 J
Component: Klima Fond H16 0121
Coding: 2000000000
ASAM Dataset: EV_AirCondiHeck 001039
ROD: EV_AirCondiHeck_AU64.rod
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008006
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_003_AU64.rod
Component: MEM-FS H08 0153
Revision: AA000000
Coding: C0183B0085053201010001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 L HW: 4H0 907 637 G
Component: SARA 6D red H02 0056
Revision: --------
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_005.rod
VCID: 38338BE3786B034E6BBF7980-806D
Address 3C: Lane Change Labels: None
Part No SW: 4H0 907 566 A HW: 4G0907568
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial Number: 6PZ 010 287-07
Coding: 0000003
VCID: 2E1FADBB8A2F55FE3143EF08-807B
Subsystem 1 - Part No SW: 4H0-907-568-A
Component: J770 SWA Slave H02 0040
Serial Number: 6PZ 010 287-27
Address 42: Door Elect, Driver (J386) Labels: 4H0-959-793.clb
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0273
Revision: --------
Coding: 011F1F005E0062C202003017
VCID: 48D3FB23088B6BCE1B5F0940-801D
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Coding: 0106023A00FA7585B0B0C7C0020301000000000000000000000000000000
Subsystem 1 - Part No SW: 4H0-959-719
Component: GTO BF H01 0080
Subsystem 2 - Part No SW: 1K0-951-605-C
Component: LIN BACKUP HOH05 1501
Subsystem 3 - Part No SW: 4H0-959-591
Component: J245 PS50.030H08 0006
Coding: 101F00
Subsystem 4 - Part No SW: 4H0-947-135-BK
Component: DachelektroniH13 0080
Subsystem 5 - Part No SW: 4H0-959-591-A
Component: V252 PS010 H06 0005
Subsystem 6 - Part No SW: 3AA-962-243
Component: GEB.F.HeckoefH12 0719
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
02616 - Fuel Tank Cap; Unlock
Part No SW: 4H1 035 465 HW: 4H1 035 465
Component: BO G3 D4 ANC H03 0130
Revision: 09S00000
Coding: 020101
VCID: E48B8F931463AFAE9767DD90-80B1
Address 52: Door Elect, Pass. (J387) Labels: 4H0-959-792.clb
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0273
Revision: --------
Coding: 011F1F005E0062C202003007
VCID: 3C3B97F34C53376E8FD785F0-8069
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: --------
ROD: EV_ParkiBrake_AU64.rod
VCID: 2B19A4AFB93DB8D6163DCE24-807E
465152 - Function Restriction due to Faults in Other Modules
U1113 00 [008] -
Address 56: Radio (R) Labels: None
Part No SW: 4H0 035 082 E HW: 4H0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007
Coding: 020007010003000001
VCID: 23094C8FD1ED6896AEED9684-8076
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 746 E HW: 4H0 035 746 C
Component: H-BNT-NA H50 0622
Revision: --------
Coding: 030200000201F9EF75168B1E00000003140001000000000000
VCID: 2A17A1ABB6C7B9DEED2BC3D8-807F
Subsystem 1 - Part No SW: 8R0-060-884-BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 4H0-919-604-G
Component: DU8 D4 SV NB H48 0021
Subsystem 3 - Part No SW: 4H1-919-600-H
Component: E380 BDT D4 H09 0065
Subsystem 4 - Part No SW: 8R0-060-961-E
Component: CD-Database 4949
02244 - Button in Control Head is Stuck
Address 62: Door, Rear Left (J388) Labels: 4H0-959-795.clb
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0273
Revision: --------
Coding: 010F1F00400062C202003007
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0150
Revision: 11001001
Coding: 0209000101010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 006025
ROD: EV_CamerSysteTopViewAUDI_006.rod
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4H0 959 107 AB HW: 4H0 959 107 M
Component: HDSG-Modul H11 0043
Revision: 10011001
Coding: 0210044100
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6E9F6DBB4AAF8DFE71C3AF08-803B
Address 6F: Centr. Conv. II (J773) Labels: None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: --------
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: E3898C8F116DB0966E6DD684-80B6
0086 - Function Restriction due to Faults in Other Modules
U1113 00 [008] -
Address 72: Door, Rear Right (J389) Labels: 4H0-959-795.clb
Component: TSG HR H06 0273
Revision: --------
Address 7F: Inform. Electr. II (J829) Labels: None
Part No SW: 4H0 035 774 F HW: 4H0 035 774 D
Component: H-BN-NA H50 0623
Revision: --------
Coding: 03020000020100400100000400001300000000000000000000
VCID: 2C1BA7B3BC33A7EE1F37F530-8079
Subsystem 1 - Part No SW: 4H0-919-607
Component: DU10 RSE H41 0021
Subsystem 2 - Part No SW: 4H0-919-607
Subsystem 3 - Part No SW: 4H0-919-709-C
Component: E499 BDT 2 H07 0019
Subsystem 5 - Part No SW: 8R0-060-884-BA
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5015
ROD: EV_GSM2x3Mono.rod
10001 - Function Restriction due to Faults in Other Modules
U1113 00 [008] -
Address 84: Night Vision (J853) Labels: 4H0-907-547.clb
Part No SW: 4H0 907 547 F HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0042
Coding: 1100
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Address 85: On Board Cam. (J852) Labels: 7P6-907-217.clb
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: --------
Coding: E8060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 260F559BA2DF85BEC9F3B7E8-8073
Address 88: Multicont. Seat Driver (J873) Labels: None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Coding: 764FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F21B0BF8D25C4F63A551A14-807A
Address 89: Multicont. Seat Pass. (J872) Labels: None
Coding: 364FF2
ROD: EV_IVBPasseSideFrnt.rod
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 541 B HW: 4H0 907 541
Component: ACC3 H19 0400
Coding: 7601010101
ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
ROD: EV_AdaptCruisContr2AU64X.rod
VCID: 28135BA3A8CB93CEFB1FA9C0-807D
U1113 00 [008] -
Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H31 0041
Coding: 01A19A030111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0161 - Video Cable for Image Processing
Address 8F: Pretension. Front Left (J854) Labels: 4H0-980-94x-RGS.clb
Component: RGS-VL H13 0080
Coding: 0066F609031F0376070308014240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3125B6C79B11D2062C610C6C-8064
Address 90: Pretension. Front Right (J855) Labels: 4H0-980-94x-RGS.clb
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4H0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0003
VCID: 2C1BA7B3BC33BFEE1F37F530-8079
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H05 0006
Revision: 00001001
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X.rod
VCID: E68F959BE25FC5BE8973F7E8-80B3
0306 - Actuator 2 for Drivetrain Mounts
C1132 13 [008] - Open Circuit
1291 - Extended Diagnostic Scope
P193D 00 [009] -
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
1295 - Drivetran Mounting
C1154 02 [009] - Signal Failure
End--(Elapsed Time: 06:13, VBatt start/end: 11.8/11.8 Vign: 12.0)-
