- Feb 25, 2014
- 2,883
- 4,668
- Garrettsville, OH
- C?ID=25607
Did programmed maintenance and SRI reset on my wife's daily 2020 Tiguan today. It's been having intermittent issues with not unlocking in response to a door handle touch. There are multiple faults in address 42, for both the locking motor and what I'm assuming is the interior door lock button itself. The variety of faults make me think this is a general Vbat or ground issue, something in the door harness. Google leads me to a recall that vw.com says her Tiguan isn't subject to, and a bunch of whinging and class actions on similar topics. It seems to be a whole thing. The precise failure point is not immediately clear to me.
Anyone know what the bottom line is here for a 2020 Tiguan? I'm down to order and swap a harness if I need to, just looking to understand if that's the probable cause.
Sunday,13,October,2024,14:33:14:50497
VCDS Version: 24.9.1.0 (x64) HEX-NET2 CB: 0.4656.5
Data version: 20240926 DS359.0
Dealer/Shop Name: Southwest Ohio Luxobarge Rescue
Workshop Code: 444 08607 000006
VIN: 3VV4B7AX4LM074301 License Plate:
Mileage: 110676km-68770mi Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 36 39 3C 42 44 47 4B
52 5F 6C 6D 75 A5 BB BC CA D6 D7
VIN: 3VV4B7AX4LM074301 Mileage: 110676km-68770miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA) Labels:. 06L-907-115-V1.clb
Part No SW: 83A 907 115 B HW: 06L 907 309 B
Component: R4 2.0l TFS H31 0005
Revision: 1DH31000 CVN: BDBE2D29
Coding: 012A00122466012FB4000000000000000000000000000000
Shop #: WSC 03207 444 00000
ASAM Dataset: EV_ECM20TFS01183A907115B 001006
ROD: EV_ECM20TFS0115NA907115K.rod
VCID: 251C9ADD456D523234D-8070
VINID: 0E698448746811C7401C40C004F05615FD
40571 - Voltage Supply 1 for Control Module
U3501 00 [00100110] - Too Low
Mileage: 110676 km
Date: 2024.10.13
Time: 13:53:00
Engine RPM: 1177.50 /min
Normed load value: 14.1 %
Coolant temperature: 38 C
Intake air temperature: 23 C
Voltage terminal 30: 10.920 V
Engine status: COENG_RUNNING
23765 - Control unit for information electronics 1
U1054 00 [00100000] - No Communication
[Information electronics control module 1No Communication]
Address 02: Auto Trans (J217) Labels: 09P-927-749-V1.clb
Part No SW: 09G 927 158 DT HW: 09G 927 158
Component: AISIN AQ8 206 3698
CVN: 2408AAFC
Coding: 0002000100000000000000000000000000000000
Shop #: WSC 00066 790 00439
ROD: EV_TCMAQ450031_VW37.rod
VCID: 0842F369D2BF6F5A2FB-805C
Part No SW: 5Q0 614 517 FE HW: 5Q0 614 517 BP
Component: ESC H35 0191
Revision: 00000000 Serial number: 52979000000369
Coding: 0BFA6BA450271B70C57A0300A2C449D0D60AD8A3C045927438415058D2AA4A0B00402F641A1B13111435351919323200
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 79A486AD995506D2205-802C
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0527017560 Dataset Number: V03935294AC 0001
Coding: 132C2C0723
Shop #: WSC 00066 790 00217
ROD: EV_KessyHellaMQBAB.rod
VCID: 45DC3A5DA52DB23214D-8010
Subsystem 1 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11997800
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NN 907 044 AA HW: 5NN 907 044 AA
Component: AC Automat H36 4803
Revision: 20K03000 Serial number: 00000D00484106
Coding: 00020024200118001104010C1211140E
ASAM Dataset: EV_ACClimaPrehVW37X 002027
VCID: 0B48CC65C3C90442029-805E
Part No SW: 5Q0 937 087 BG HW: 5Q0 937 087 BA
Component: BCM PQ37BOSCH 038 0303
Revision: -------- Serial number: C86412111901L9 Dataset Number: V03935294RH 0001
Shop #: WSC 00066 790 00276
ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
ROD: EV_BCMBOSCH_020_VW37.rod
VCID: 0154EE4DF1855E12685-8054
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 191021 034 0373
Serial number: 19101821075430
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: S4Y19M09D06H11M21S34
Coding: 0008DD
Humidity sensor: interior:
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 R HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0170
Serial number: 0300011120190C200388
204290 - Remote key 1
B1479 18 [00001001] - Current Too Low
Reset counter: 72
Mileage: 110256 km
Date: 2024.10.03
Time: 08:00:22
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
last_wakeup: Pin C14 Kessy Weckleitung
Voltage: 12.0 V
Outside temperature: 11.5 C
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000259540119314 Dataset Number: V03935295QM 0001
Coding: 0471255811
ASAM Dataset: EV_EPHVA18AU3700000 009046
VCID: 50F21B096A6F679AB7B-8004
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Dataset Number: V03935305AH 0001
Coding: 320007D258FF8728749C810530409700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
VCID: 43D82445AB198C023A9-8016
1236 - Databus
[FAULT_TIMEOUT_BV1_POSITION]
Reset counter: 114
Mileage: 109273 km
Date: 2024.09.08
Time: 12:00:08
Voltage terminal 15: 12.9 V
Control Module temperature: 34 C
Vehicle speed: 18.38 m/s
Longitudinal acceleration: -0.06 m/s
Adaptive distance regulation: status: ACC_StandBy
Part No SW: 5Q0 959 655 BM HW: 5Q0 959 655 BM
Component: AirbagVW21 008 0403
Serial number: 003FGM06LRF$ Dataset Number: V03935282LS 0001
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 0C4ACF79C6C7037A0B3-8058
Component: BF-Gewichtss. H14 0022
Serial number: IBH00000000000CIDYKE
Coding: 303352
Subsystem 2 - Part No SW: ----------- HW: 480 002 509 19
Serial number: 3570000000079029814C
Subsystem 3 - Part No SW: ----------- HW: 480 002 409 19
Serial number: 358000000004EB39C04U
Subsystem 4 - Part No SW: ----------- HW: 480 402 009 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001B8F2FD200B719
Subsystem 5 - Part No SW: ----------- HW: 480 402 009 19
Component: SideSensor_Pr 005 6149
Serial number: 3520001B2F322723B5F3
Subsystem 6 - Part No SW: ----------- HW: 480 401 610 19
Component: FrontSensor_D 005 6149
Serial number: 3550001B4F2F5557C6CR
Subsystem 7 - Part No SW: ----------- HW: 480 401 610 19
Component: FrontSensor_P 005 6149
Serial number: 3560001B4F2F5557C37K
Part No SW: 3G0 920 890 E HW: 3G0 920 890 E
Component: KOMBI 503 4192
Coding: 08A42008EF88CF050288634B10010000A0000F07
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
VCID: 2B086CE523896442E29-807E
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 13111900841378 Dataset Number: V03935300FR 0001
Coding: 030500347F085900FB03225A1E0F00010001070000000000000000000000
GVL: 01C63C000800040040DC80008002C80010000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 70B2BB89CA2F479A97B-8024
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5NA 959 442 B HW: 5NA 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0025
Serial number: 0362014593801442FG2B
Coding: 2E0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 3818756900
8531970 - Quiescent Current
U1406 00 [00001000] - Too High
[Ruhestrom oberer Grenzwert berschritten]
Reset counter: 122
Mileage: 95986 km
Date: 2024.02.11
Time: 22:13:38
Terminal 30 power supply: 12.2 V
Terminal 15: OFF
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00005.08.19 Dataset Number: v1260x015G0 0000
Coding: 0101
VCID: 4CCA0F798647437ACB3-8018
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 E HW: 5Q0 959 760 E
Component: Sitzmemory H09 0026
Serial number: Y0007SI739837 Dataset Number: V03935289ZA
Coding: 0010000000000500018280808080000000008101000000F400
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_SeatMemorDriveSide 002022
ROD: EV_SeatMemorDriveSide_VW37.rod
VCID: 3FD028B5C7F1E8E25E1-806A
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0148
Serial number: 11230018969676 Dataset Number: V03935308HF 0001
Coding: 52954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
VCID: 392446ADD9D5C6D2605-806C
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0148
Serial number: 11230018983817
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 12058931400686 Dataset Number: V03935300DV 0001
Coding: 003F1B205200048000000000
VCID: 4DCC027D7D5D4A72DCD-8018
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000004632516
Coding: 011000
196650 - Motors for Central Locking
B122B 12 [00001000] - Short to Plus
Reset counter: 114
Mileage: 108945 km
Date: 2024.09.06
Time: 13:44:46
196651 - Motors for Central Locking
B122B 11 [00001000] - Short to Ground
Reset counter: 114
Mileage: 108800 km
Date: 2024.09.03
Time: 07:51:27
196665 - Switch for Central Locking
B122D 29 [00001000] - Signal Implausible
Fault Frequency: 14
Reset counter: 114
Mileage: 108800 km
Date: 2024.09.03
Time: 07:51:28
Part No SW: 5QM 909 144 C HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 173 1082
Dataset Number: V03935302RN 0001
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 51F41E0D61656E92B85-8004
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1KMD0692ZY Dataset Number: V03935266BX 0001
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
VCID: 2E0E65F1109B116AC57-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 11111900840711 Dataset Number: V03935302YF 0001
Coding: 0000000509001D52002103010B0000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 37204095EFC1D0A2961-8062
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 13058931100723 Dataset Number: V03935300DW 0001
Coding: 003F13205E00048000000000
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000004642112
Coding: 091000
Part No SW: 2GM 035 876 B HW: 2GM 035 876 B
Component: MU-S-NS-US 854 0520
Serial number: Dataset Number: V03935311FZ 0001
Coding: 027306020000000051220002001808211F0506E401200405C6
ROD: EV_MUStd4CDELP_VW37.rod
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav 254 8130
Serial number: VWZ6ZMW3175626
Subsystem 2 - Part No SW: 5NA 919 866 P HW: -----------
Component: NAR 2019/20 --- 0910
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG061956 Dataset Number: V03935295TM 0001
Coding: 01230601A20F20003000400C
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C758-8680-4 Dataset Number: V03935297GM 0001
Coding: 0A28
VCID: 48C23369923FAF5AEFB-801C
Part No SW: 5WA 035 283 C HW: 5WA 035 283
Component: OCUGen3Low H10 0304
Serial number: 0000000909NVCL4 Dataset Number: V03935314UT 0001
Coding: 0232602019682C208005461160100607
ASAM Dataset: EV_OCUGen3Low 003008
ROD: EV_OCUGen3Low_003_VW27.rod
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 20081915K25557 Dataset Number: V03935311DJ 0001
Coding: 0003070601020201002213468150490084000E20012000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D22B49BA0F971A27B-8014
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935300SR 0001
Coding: 00804073260C
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75BC8A9DB54D62B244D-8020
Part No SW: 7P5 941 572 AG HW: 7P5 941 572 A
Component: LED1L H07 0008
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481_VW37.rod
VCID: 0052EB49FA8F571A67B-8054
Component: LED1R H07 0008
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 02:01, VBatt start/end: 14.9V/14.6V)-----------
VCDS Beta 24.9.1: SRI Reset-SRI3.CLB
Control Module Part Number: 3G0 920 890 E Labels: .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI 503 4192, Coding:08A42008EF88CF050288634B10010000A0000F07
Channel Description Current val. New val.
IDE00342-ESI: Resetting ESI ESI: Service Status Warning active ---
IDE00510-ESI: distance driven from inspection ESI: Distance SINCE last Oil Service 16827 km ---
IDE00511-ESI: time from inspection ESI: Time SINCE last Oil Service 269 d ---
IDE00512-ESI: minimum value km-driving distance/inspection ESI: Minimum Distance to Oil Service(s) 15000 km ---
IDE00513-ESI: maximum value km-driving distance/inspection ESI: Maximum Distance to Oil Service(s) 30000 km ---
IDE00827-ESI: minimum value of time between inspections ESI: Minimum Time to Oil Service(s) 365 d ---
IDE00514-ESI: maximum value of time between inspections ESI: Maximum Time to Oil Service(s) 730 d ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection FIX: Distance SINCE last mileage-dependent Inspection 16800 km ---
IDE03352-FIX: Time since last time-dependent inspection FIX: Time SINCE last time-dependent Inspection 269 d ---
IDE03349-FIX:Max. distance driven until next mileage-related inspection FIX: Max. Distance to mileage-dependent Inspection(s) 32200 km ---
IDE03350-FIX: Maximum time until next time-dependent inspection FIX: Max. Time to time-dependent Inspection(s) 730 d ---
IDE01153-SIA: maximum value of distance to service SIA/SID: Maximum Distance to Service/Inspection 16100 km ---
IDE01154-SIA: maximum value of time to service SIA/SID: Maximum Time to Service/Inspection 365 d ---
ESI/INFO: Theoretical Oil Service Interval ---
ESI/INFO: Remaining Distance to Oil Service ---
ESI/INFO: Remaining Time to Oil Service ---
ESI/INFO: Oil Service Exceedance ---
INFO: Day Counter (since Delivery Inspection) ---
INFO: Vehicle/Odomoter Mileage --- ---
IDE00517-ESI: soot entry ESI/INFO: Soot Entry 0 km ---
IDE00518-ESI: thermal load ESI/INFO: Thermal Load 28100 km ---
IDE00515-ESI: oil quality ESI/INFO: Oil Quality poor oil quality ---
ESI/CODING: Oil Level Evaluation --- ---
ESI/CODING: ESI-SIA/SID ON/OFF --- ---
ESI/CODING: ESI or SIA/SID --- ---
ESI/CODING: Oil Pressure Warning --- ---
ESI/CODING: Remote Clock Receiver --- ---
ESI/CODING: Oil Quality --- ---
ESI/CODING: Oil Level & Thermal Sensor --- ---
Operation: Reset ESI / OIL,(North America) or (Rest of World second service and later)
IDE00342-ESI: Resetting ESI ESI: Service Status Warning active 0
Address 17,3G0 920 890 E,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Resetting ,
