"Park/Steer Assist" EEPROM Error
micheldonk
C?ID=347002
Hello!
Is anyone known with this issue on a A3 8P 2009, is the module done for or is there something I can try myself?
Sunday,13,October,2024,14:55:15:00846
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUZZZ8P99A044263 License Plate: NTAS1712
Mileage: 162740km-101121mi Repair Order: 1
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 47 52 55 56 62 72
77
VIN: WAUZZZ8P99A044263 Mileage: 162740km-101121miles
Address 10: Park/Steer Assist (J791) Labels:. 8P0-919-475-7X5.clb
Part No SW: 8P0 919 475 E HW: 8P0 919 475 B
Component: PARKHILFE PLA H07 0102
Revision: 11001001 Serial number: 84530823900627
Coding: 100005
Shop #: WSC 06314 000 00000
VCID: 40D9438D7A83F7EA1FB-8014
16347 - Control Module - EEPROM Error
014 - Defective
Fault Status: 01101110
Reset counter: 0
Temperature: 6.0°C
Seeing that it is not registering a Mileage and other info I think its done for, but no clue..
Thanks in advance!
micheldonk
C?ID=347002
Hello!
77
Coding: 100005
014 - Defective
Reset counter: 0
Temperature: 6.0°C
Thanks in advance!
A bit of extra info:
Parking sensors are not working at the moment, front and back.
Both buttons for the parking sensors, and the steering assist are both blinking and not functional.
Once I press the parking sensor button there is a single long beep and than nothing, also the RNS-E doesnt trigger the parking sensor screen.
Hoping this extra info brings something..
Jef
HQ
When asking for assistance, please post a complete Auto-Scan. Do not post snippets or limited info... always post the complete Auto-Scan.
98.992% chance this is a failed J791 and will need to be replaced. 1.007% chance you have a voltage drop issue on a power or ground for the control module. If you load test powers/grounds and they are good, replace the module. 0.001% some other unknown issue causing this.
micheldonk
C?ID=347002
I have read that this usually happens cause of low voltage, and with a reflash the module would likely work again. Is this correct, or am I better of just buying something else?
Do you maybe have a clue where it is located on the A3 8P?
micheldonk
C?ID=347002
Off the top of my head, no. But once you post a complete Auto-Scan I'll be able to get that info quickly.
I doubt it, but it's pretty much impossible to be sure without a complete Auto-Scan.
Under the steering wheel.
Here you go:
          77
04-Steering Angle -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 8P7 907 115 D    HW: 8P0 907 115 Q
   Component: 1.8l R4/4V TFSI     0020
   Revision: AAH03---    Serial number: AUX7Z0H8FN50CU
   Coding: 0103000C18070160
   Shop #: WSC 66565 257 00032
   VCID: 3A2D3165105FAD3A51F-806E
   VINID: 9D196AAAA2202494401040860C4EF02694
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 000 -  - Intermittent
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:43:51
                    RPM: 840 /min
                    Load: 10.2 %
                    Temperature: 78.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 12.065 V
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:47:22
                    RPM: 852 /min
                    Load: 9.0 %
                    Temperature: 85.0°C
                    Temperature: 25.0°C
                    Voltage: 11.938 V
Readiness: 0110 0101
   Part No SW: 1K0 907 379 CE    HW: 1K0 907 379 AE
   Revision: 00H35001
   Coding: 11424012492600FE880D02EA921C00413D00
   Shop #: WSC 48226 001 104857
   VCID: 77ABE8516FCD70526E1-8022
                    Reset counter: 251
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:43:51
                    Count: 2
                    Count: 2
                    Count: 12800
                    Count: 166
                    Count: 42752
                    Count: 1
   Part No SW: 8P0 820 043 BH    HW: 8P0 820 043 BH
   Component: KlimavollautomatH09 0100
   Revision: 000214      Serial number: 8P0820043BH
   VCID: 73B3DC4177B51C72529-8026
                    Fault Frequency: 13
                    Reset counter: 94
                    Mileage: 272050 km
                    Date: 2023.07.06
                    Time: 20:10:41
01232 - A/C Compressor Regulator Valve (N280)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 12
                    Reset counter: 251
                    Mileage: 162613 km
                    Date: 2024.10.04
                    Time: 14:54:34
                    Load: 50.0 %
                    Current: 0.040 A
                    Reset counter: 251
                    Mileage: 162743 km
                    Date: 2024.10.12
                    Time: 20:12:33
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000008921567
   Coding: FD8E9F81903C1380FF00000A0000000000094E0564060603648000000000
   Shop #: WSC 06314 123 08192
   VCID: 48C95BAD5EB3CFAAD7B-801C
   Subsystem 1 - Part No: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00054547
   Shop #: WSC 06314
   Coding: 08604717
   Shop #: WSC 06314
01117 - Generator Terminal DF Load Signal
                    Fault Status: 01101000
                    Reset counter: 251
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:44:00
                    Voltage: 12.00 V
                    Reset counter: 251
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:41:00
                    Voltage: 12.15 V
                    Reset counter: 251
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:41:00
                    Voltage: 12.15 V
   Coding: 100005
            014 - Defective
                    Reset counter: 0
                    Temperature: 6.0°C
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000 Dataset Number: 8P0909602L  0001
   Coding: 303142383038303030354A55304C38503053
   VCID: 49CF5EA9493936A2C85-FFFE
   Subsystem 1 - Serial number: 3582DRB400007950E2E
   Subsystem 2 - Serial number: 35128RB40000407308B8
   Subsystem 3 - Serial number: 35228RB400003FDEDFBH
   Subsystem 4 - Serial number: 35547RB4000041E0157C
   Subsystem 5 - Serial number: 35647RB4000041E01C3G
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0004042
   VCID: 41DF46897D89FEE2105-8014
   Component: E0221           H06 0030
   Part No SW: 8P0 920 931 T    HW: 8P0 920 931 T
   Component: KOMBIINSTR. VDO H18 0830
   Revision: D0H18006    Serial number: 2248H006015377
   Coding: 0132019
   Shop #: WSC 65536 773 2073257
   VCID: 44D14F9D629BEBCA3B3-8010
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K089150844
   Coding: E9A17F065006022102
   VCID: 3537225939414242BCD-8060
                    Reset counter: 251
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:42:29
                    Reset counter: 251
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:42:29
                    Reset counter: 35
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:43:52
   Revision: D0H18006    Serial number: AUX7Z0H8FN50CU
16346 - Control Module - ROM Error
            014 - Defective
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8P0 035 193 C    HW: 8P0 035 193 C
   Component: RNS-E PU EU     H04 0220
   Revision: 0000006S    Serial number: AUZBZ7K6000055
   Coding: 0225765
   VCID: 3039134DC623676AEFB-8064
02444 - Disk Drive Load / Eject Malfunction
                    Reset counter: 251
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:42:53
                    Reset counter: 251
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:42:55
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 10000000 00000000
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 232    2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0D0125E0FF1DBA21F-807E
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:44:45
                    Battery Volts: 12.0 V
                        DU
                    Temperature: 20.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 L
   Component:    KSG          H11 0080
   Coding: 1880200002586D0905054C8F0167
   Shop #: WSC 06314 123 12345
   VCID: 45D7529969A1D2C22CD-8010
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
   Component: AB2 SUBWOOFERBOXH06 0180
   Revision: 00005       Serial number: 30674802859794
00422 - Rear Right DSP Midrange Speaker (R106)
                    Reset counter: 251
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:45:11
                    Temperature: 23.0°C
   Part No SW: 8P0 959 802 J    HW: 8P0 959 802 J
   Component: Tuer-SG         H03 0060
   Coding: 0000508
   VCID: 43D34C816795ECF2029-8016
00121 - Outside Warning Light/Door exit Light Passenger Side
   Part No: 8P0 907 357 J
   Component: Dynamische LWR  H01 0020
   Coding: 0000013
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0225765
                    Reset counter: 251
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:42:53
                    Reset counter: 251
                    Mileage: 162744 km
                    Date: 2024.10.13
                    Time: 14:42:55
Address 62: Door, Rear Left
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Component: Tuer-SG         H04 0040
   Coding: 0000216
   Shop #: WSC 06314 000 1012544
   VCID: 42DD4985788FE5FA09F-8016
00123 - Outside Warning Light/Door Exit Light; Rear Right
   Part No SW: 8P0 862 335 S    HW: 8P0 862 335 S
   Component: FSE_256x BT     H34 0550
   Revision: 00000000    Serial number: 00000005035673
   Coding: 0011211
   VCID: 46D5559554A7D9DA257-8012
End----(Elapsed Time: 01:30, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Jef
HQ
1 - Control units on right in luggage compartment
Components: -J345-, -J393-, -J446-, -J791-
Park assist steering control unit (J791) is located in the right rear area. Look like you would find it close to the tail light, behind a trim panel and fitted to a bracket.
Looks to have 3 wiring harness connections going to it. T12i, T12t and T16f.
micheldonk
C?ID=347002
Thanks for the tip, ill keep you posted once I have swapped the module.
Reactions: Jef
micheldonk
C?ID=347002
Hello!
It took a bit, but I got the module swapped.
I tried to code it, but long coding is giving me an error. I right now have some errors in it, which are legit cause the car doesnt have it. But I have no clue what to code there instead, anyone got a list of options for the thing which bits I should enable / disable.
Thanks in advance!
Oh here is the scan..
Saturday,02,November,2024,11:11:37:00846
Mileage: 162930km-101240mi   Repair Order: 1
          77
VIN: WAUZZZ8P99A044263   Mileage: 162930km-101240miles
               P0441 - 000 - Incorrect Flow - Intermittent
                    Mileage: 162874 km
                    Date: 2024.11.01
                    Time: 19:11:39
                    RPM: 843 /min
                    Load: 10.6 %
                    Temperature: 100.0°C
                    Temperature: 40.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.843 V
   Revision: 00H35001
                    Fault Status: 00101010
                    Reset counter: 47
                    Mileage: 162874 km
                    Date: 2024.11.01
                    Time: 18:58:50
                    Load: 39.0 %
                    Current: 0.044 A
   Coding: 00054547
   Shop #: WSC 06314
   Coding: 08604717
   Shop #: WSC 06314
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 8
                    Mileage: 162874 km
                    Date: 2024.11.01
                    Time: 19:05:00
                    Voltage: 13.80 V
                    Reset counter: 46
                    Mileage: 162874 km
                    Date: 2024.11.01
                    Time: 19:23:00
                    Voltage: 12.00 V
02604 - Low Vehicle Voltage from Power Steering Control Module
                    Reset counter: 46
                    Mileage: 162874 km
                    Date: 2024.11.01
                    Time: 19:43:00
                    Voltage: 9.90 V
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 01111100
                    Reset counter: 8
                    Mileage: 162874 km
                    Date: 2024.11.01
                    Time: 19:05:00
                    Voltage: 13.80 V
Address 10: Park/Steer Assist (J791)       Labels: None
   Part No SW: 8P0 919 475 B    HW: 8P0 919 475 B
   Component: PARKHILFE PLA H07 X150
   Revision: --H07---    Serial number: --------------
   Coding: 010103
   VCID: 3D273A790D719A0274D-8068
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Reset counter: 8
                    Mileage: 162930 km
                    Date: 2024.11.02
                    Time: 11:09:21
                    Temperature: 8.0°C
                    Reset counter: 8
                    Mileage: 162930 km
                    Date: 2024.11.02
                    Time: 11:09:21
                    Temperature: 8.0°C
   Subsystem 1 - Serial number: 3572DRB40000795C828.
   Subsystem 2 - Serial number: 3582DRB400007950E2E
   Subsystem 3 - Serial number: 35128RB40000407308B8
   Subsystem 4 - Serial number: 35228RB400003FDEDFBH
   Subsystem 5 - Serial number: 35547RB4000041E0157C
   Subsystem 6 - Serial number: 35647RB4000041E01C3G
   Coding: 0004042
   Coding: 0132019
            014 - Defective
   Coding: 0229755
02005 - Coding Pin
                    Reset counter: 6
                    Mileage: 162874 km
                    Date: 2024.11.01
                    Time: 19:37:42
                    Reset counter: 6
                    Mileage: 162874 km
                    Date: 2024.11.01
                    Time: 19:07:59
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 J    HW: 8P0 959 801 J
   Coding: 0004350
            002 - Lower Limit Exceeded
   Revision: 00H15000
                    Reset counter: 46
                    Mileage: 162874 km
                    Date: 2024.11.01
                    Time: 19:43:39
                    Battery Volts: 10.2 V
                        DU
                    Temperature: 35.0°C
                    Torque: -0.000 Nm
                    Torque: 0.0 Nm
                    Drive Current: 1.5 A
   Coding: 0004350
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
   Coding: 0000013
   Coding: 0229755
02005 - Coding Pin
                    Reset counter: 6
                    Mileage: 162874 km
                    Date: 2024.11.01
                    Time: 19:37:42
                    Reset counter: 6
                    Mileage: 162874 km
                    Date: 2024.11.01
                    Time: 19:07:59
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0000216
   Shop #: WSC 06314 000 1012551
   Coding: 0000216
   Coding: 0011211
End----------(Elapsed Time: 01:36, VBatt start/end: 14.0V/14.0V)-----------
Regards,
Michel
Dr Sheldon
Windsor UK
C?ID=334979
Coding: 100005
Before and After
Coding: 010103
Try the original Coding
micheldonk
C?ID=347002
Before and After
Coding: 010103
Tried it and it seems to work, atleast the errors are gone.
Is there any way to check it though, I have seem allot of wrong programming already with the car thats why I would like to check it with a programming list which bit is what.
Hoping to find that somewhere..
Sebastian
Magdeburg, Germany
HN0-nnnnnn
   Coding: 010103
                    Reset counter: 8
                    Mileage: 162930 km
                    Date: 2024.11.02
                    Time: 11:09:21
                    Temperature: 8.0°C
                    Reset counter: 8
                    Mileage: 162930 km
                    Date: 2024.11.02
                    Time: 11:09:21
                    Temperature: 8.0°C
Not sure where you got that module from, but that is certainly a pre-series/development software on that module. This also why VCDS doesn't recognize it properly. I've made some changes to our data, this updater includes data which should now cover this as well. Install it on top of your existing VCDS installation.
In addition to the coding, you MUST make sure the ADP channels on these PLA modules are properly set. There is some correlation between coding and adaptation channels, as well as model types associated but reality is, we have no idea what this pre-series software supports or doesn't.
P.S.: As a rule of thumb, never install a module that is older than the originally installed one. Also make sure to never ever have any X or Y software levels in replacement modules. ;)
micheldonk
C?ID=347002
Hi Sebastian,
First thank you for the quick response and the explanation!
I know that zou usually dont install an older part number but the part number was "officially" also not for this car in the first place. (I looked up the part number with ETKA, so this one is for the car)
I just installed the software. So if I understand correctly I dont have to change anything in VCDS manually and it should now recognize the module within Long Coding Helper?
I will try tomorrow, and get back to you if it worked :-)
Dr Sheldon
Windsor UK
C?ID=334979
something doesnt come up with an error does not mean all functionality is there as it should be
Well we are not mind readers my friend !!!
Have you got full function or not ?
An updated Autoscan will help now
Sebastian
Magdeburg, Germany
HN0-nnnnnn
If you look at the scan, there is a difference in HW/SW P/N's, so the hardware itself is likely fine but the SW level would have me being careful. Since this is a semi-automated assistance system, be especially careful when testing (and further using) it in real life/traffic.
Yes.
Based on past experience with X software levels, you won't know until you run into issues while using functions of this module and even then it's not guaranteed you will ever find why this SW level was never meant for public consumption. This could be anything from excessive power drain to incorrect/dangerous functionality when doing automated parking.
Dr Sheldon
Windsor UK
C?ID=334979
One wonders how this has ended up in circulation !!
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Not really, back in those days many pre-series models were sold to scrap yards with limited requirements as to what had to be physically destroyed and what not. For example often safety components MUST be destroyed while other parts may not. Also there are always a few pre-series models brought up to series sw levels and sold/used for educational purposes etc. These days the contracts are often more tight, but still plenty of room for pre-series parts making it into the wild.
One of our German distribs has had a few of those over the years, so we have some real life experience with that. 😉
Aside from that, before I started with Ross-Tech I was buying/reselling VAG parts and bought my fair share of rare stuff from authorized junk yards which at the time did not know what they were selling. The most exotic case I have come across over the last 20 years was a laser/lidar based adaptive cruise control which came up for auction a while back, that system was never sold by VW and never made it to a level where it was certified etc. for road use. Yet people where still discussing and attempting to retrofit it.
golfi_vend
Tartu, Estonia
C?ID=195131
...The most exotic case I have come across over the last 20 years was a laser/lidar based adaptive cruise control which came up for auction a while back, that system was never sold by VW and never made it to a level where it was certified etc. for road use. Yet people where still discussing and attempting to retrofit it.
Ah yes. This one.
Luckily the 7N0 radar does much better job nowadays. Supposedly the issue was that it wasn't able to detect all cars depending on weather.
It did get some pages in user manual though.
