Resolved 2018 Passat B7 (NMS) - Heated Steering Wheel -Clock Spring Help
Resolved
sheetrock0958
MN, USA
C?ID=590393
Hello Ross-Tech Experts!
1st post Newbie Here! I recently purchased a Ross-Tech VCDS for a diagnostic issue and now I've gotten greedy! I'm attempting to install a heated steering wheel in my 2018 Passat SE (autoscan provided in next post). I've scoured many forums and i've done about as much research/digging as I'm capable of. I'm hoping someone with more experience has some advice or potential solutions.
I purchased a heated wheel from a 2020 Tiguan that is nearly identical to my Passat wheel - with the exception of a couple different buttons. My plan is to swap the buttons and module from my Passat into the new heated wheel... and everything after that gets tricky. The B7 NMS platform never had an option for a heated steering wheel, so there is no clock spring available that I'm aware of. I've consulted the Ross-Tech "Steering Wheel Control Module Version" page that has a table of all the variations, and tried to cross-reference a clock spring configuration that might work - to no avail.
When I started this project, I resigned myself to the fact that I wouldn't be able to fully integrate the heating function into the vehicle (no button, icon, or code option), so I purchased a 6 position knob and control module and plan to control it independent from the vehicle.
So, my question is: Is there a clock spring that I could possibly use or modify to work? When I say modify - I'm thinking along the lines of purchasing a clock spring that does have HSW connector and using the connector face and ribbon cable and retrofitting it into my original clock spring. Ultimately, all I'm really after is a reliable way to provide power to the heating element and I'll control everything outside the vehicle software/canbus/circuitry.
sheetrock0958
MN, USA
C?ID=590393
Saturday,12,October,2024,19:41:56:06219
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.5
VIN: 1VWBA7A34JC         License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1C 25 2B 3C 42 44 46 4F 52
          5F 61 62 72 75
VIN: 1VWBA7A34JC        Mileage: 152140km-94535miles
Address 01: Engine (J623-DDSA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 016 C    HW: 06K 907 309
   Component: R4 2.0l TSI   H30 9609
   Revision: 1EH30000    CVN: E4997CC0
   Coding: 411A00922444000F1000
   Shop #: WSC 64717 003 1048576
   ASAM Dataset: EV_ECM20TFS01106K906016C 002006
   ROD: EV_ECM20TFS01106K906016C_002.rod
   VCID: 2A0ADBD6DC7EADEA217-807E
   VINID: 0669D244744311A4C004324014E8D031B2
   Part No SW: 09G 927 158 AB    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3318
   CVN: 19ED60D6
   Coding: 010200000C000000000000000000000000000000
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 73B406B24B34AC22521-8026
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F5492300FDA31403E4921E004100F0F01A
   VCID: 75B038AA45C0B2127C5-8020
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 145
                    Mileage: 151453 km
                    Date: 2019.02.28.
                    Time: 21:02:55
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 52329
                    Count: 765
   Part No SW: 5K0 959 434 J    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1403
   Revision: 00092000    Serial number: 0447245580 Dataset Number: V03935267BW 0001
   Coding: 032C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 3C26ED8E26EA235A43B-8068
   Part No SW: 561 907 044 BD    HW: 561 907 044 BD
   Component: Climatronic   H08 0910
   Revision: 00001K05
   Coding: 0070019082
   VCID: 5AEA4B16CC9EFD6A717-800E
9473393 - Motor for Right Temperature Flap
          B108D 71 [00001000] - Actuator Stuck
                    Reset counter: 168
                    Mileage: 149304 km
                    Date: 2024.09.14.
                    Time: 00:08:05
   Part No SW: 5K0 937 085 AE    HW: 5K0 937 085 AE
   Component: BCM PQ35 B+   122 0186
   Revision: BH122001
   Coding: EF200E1B9C2B0CD4098802010400044800F1000644801DB0E4806200AC70
   VCID: 76B23FA658C6B90A75F-8022
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 2908170466A11D Dataset Number: V03935263DJ 0001
   Coding: 01001002FE0739
   ROD: EV_ACCBEGVW361.rod
   VCID: 3632FFA618C6F90AB5F-8062
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM0DH4A0 Dataset Number: V03935261GJ 0001
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 639476F2FBD43CA2221-8036
   Serial number: IBH000000000007L67BC
   Coding: 30324C
   Subsystem 2 - Part No SW: -----------    HW: 480 002 906 17
   Serial number: 35700000000908B4952K
   Subsystem 3 - Part No SW: -----------    HW: 480 000 807 17
   Serial number: 35800000000349513525
   Subsystem 4 - Part No SW: -----------    HW: 480 022 007 17
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001992600D35C5F3
   Subsystem 5 - Part No SW: -----------    HW: 480 020 708 17
   Component: SideSensor_Pr  000 0148
   Serial number: 35200019F2711E33E1FA
   Subsystem 6 - Part No SW: -----------    HW: 480 020 708 17
   Component: FrontSensor_D  000 0189
   Serial number: 3550001A72600D4295F1
   Subsystem 7 - Part No SW: -----------    HW: 480 020 708 17
   Component: FrontSensor_P  000 0189
   Serial number: 3560001A72600D41136P
   Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20170823100934
   Coding: 0002C40008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7F5CDA82777CF842269-802A
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 2301716182301391AF2B
   Coding: 2C0000
   Part No SW: 561 920 971 B    HW: 561 920 971 B
   Coding: 221E010000
   VCID: 1A6A0B168C1E3D6AB17-804E
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 20081703010372
   Coding: 461020
   VCID: 7BA42E9263E4E4620A1-802E
Address 1C: Position Sensing
   Component: IMMO          H03 1104
   Coding: 000007
   VCID: 6A8A1BD61CFE6DEAE17-803E
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 17000277503005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 3138CCBAF1A8DE32E0D-8064
   Serial number: 0452574080 Dataset Number: 5G9764V____ 0041
   Coding: 01011102
   ROD: EV_HREntryHella_VW41.rod
   Serial number: 0451578044
   Coding: 010111
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0011024543
   Coding: 0404B5
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E6207069036514A4DF-804A
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  022 1472
   Serial number: 14102746171019211309
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 311    3501
   Revision: 00H22000
   Shop #: WSC 19460 666 12345
   VCID: 3928F49A2558167258D-806C
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1682
   Coding: 01030100
   VCID: 6FBC0AC2279C88C2B69-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011708900905
   Coding: 181100
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0011032051
   Coding: 0405B4
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F1C3A02973C5842469-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  022 1472
   Serial number: 14102747171019222903
   Part No SW: 5C0 035 200 D    HW: 5C0 035 200 D
   Component: MU-S-S-US     H42 0447
   Serial number: VWZAZ2T1608756 Dataset Number: V03935263LS 0001
   Coding: 02140100BE00000051220001001808009F0100D40020010002
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 16721F267806190A95F-8042
6720 - Rear View Camera
          B1102 31 [00001000] - No Signal
                    Reset counter: 166
                    Mileage: 149657 km
                    Date: 2024.09.15.
                    Time: 20:21:33
                    Voltage terminal 30: 11.9 V
   Component: Batt.regelung H56 1682
   Coding: E1201859
   VCID: 71B80CBA31A89E32A0D-8024
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     024 0160
   Serial number: 000003554140567 Dataset Number: 561098V____ 0017
   Coding: 02140102C21632107F1606C00000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 1476652E6EFA0B1AEBB-8040
End----------(Elapsed Time: 01:14, VBatt start/end: 12.7V/12.7V)-----------
Spacewalker
Poland
C?ID=159607
no clock spring for PQ platform and heated MFSW exist
over google - you can find how people modyfi current clock spring
after hardware mod ...... you need to strat control it
relay with timer, or toogether with seat, or heated windscreen.....up to you
  • Informative
sheetrock0958
MN, USA
C?ID=590393
Spacewalker - Do you have any specific examples you can share from a B7 NMS Passat? I've done many, many searches without finding what I'm looking for and can't find a completed project for a North American Passat. Perhaps I'm searching with the wrong words/terms.
I've been able to find several great examples for Golf MK7as well as other vehicles - the difference with the Passat is it was never offered. So all of the examples I find - people are simply purchasing the clock spring that does contain the HSW connector, adding the circuit with Kufatec harness, coding in VCDS, and everything works. I don't get that option, so I'm trying to get creative... the problem is I have very limited knowledge of the variations in the clock springs. Since I only have my original clock spring, I can't measure/compare/evaluate whether it's possible to buy a donor clock spring and use the center section of it and it's ribbon cable to modify my 5K0 953 569 BF. This is ultimately the information that I'm after.
I've found an instructable as well as a few other videos that show how the clock spring works and how to replace the ribbon cable - what I haven't found is the feasibility to modify one to get to a solution that will work. There are so many variations of the clock springs that I have no idea which center section would adapt to my clock spring. I'm comfortable making mechanical and electrical modifications - I just don't currently possess the necessary information to move forward.
That seems rather unlikely, since the NMS is not at all like the B7 that was sold in Europe, where Spacewalker is.
teal2
C?ID=578564
That's partially correct. While the SWCM "doesn't" support it I'm pretty sure the CC had it and CC was definitely a PQ car. I'm pretty sure it was controlled by the heated seats button which activated both.
teal2
C?ID=578564
You would have to open your SWCM and modify the pins to add support for heated steering wheel & then get a CC wheel that is heated (or a euro wheel that's heated, but again needs to talk PQ) and then you can do what Spacewalker said & run a relay and some wiring over to the heated seats button, if that's not in your car already.
sheetrock0958
MN, USA
C?ID=590393
Follow Up/Solved:
I've never been one to take the easy route so I continued down the path, hellbent to add the heated steering wheel!
As stated in the original post, I knew if I were able to complete this project, I wouldn't be able to embed/adapt the added feature through the vehicle.
Because the B7 North American Passat was never offered with a HSW, the hardware and coding were never developed and regardless of my coding skills or any other engineered solution I could come up with, it wasn't likely going to work or be worth the effort and hours required. I was perfectly content resigned to the fact I would have to control it independent of the vehicle and here are my reasons why:
- When remote starting, I didn't have to deal with trying to activate the HSW. Simply crank the knob to highest setting when exiting the vehicle, and when the vehicle remote starts it's already on.
- I don't have to deal with manufacturer determined temperature set points (i.e. not warm enough, wish it would be hotter). With the selector knob, I get to determine when it's warm/hot enough and then dial it down from there.
- This goes along the same line as above point... most modern vehicles will current limit auxiliary devices depending on full system draw and is often times the reason for sub standard performance of seat heaters and steering wheels. I now get to mindlessly drive down the road consuming more current than the alternator can output and end up paying for it with a potentially low battery later!
I'm happy to report that I've been using the HSW for the past 10 days and am extremely happy with the results. Its about the best $245.26 I've spent in a long time!
Breakdown on the spend: $132.87 for the heated steering wheel, $87.39 for the donor clockspring, and $25 for the controller w/selector knob.
A few more notes about the project:
- I tried many, many different avenues to route power and ground through the center of the steering wheel and absolutely could not come up with a reliable solution that would allow for the one and a half revolutions in each direction from steering center point. It absolutely had to utilize the clockspring to make this feasible.
- Before installation, I tested the controller and heated wheel outside of the vehicle using a car battery. I was mostly happy with the results, but the wheel took longer than I expected to get hot... and this was in a 70 degree garage, not -20 degree outside temp where I will expect this to perform admirably and the reason I'm installing it. I didn't have a whole lot of options when it came to off-the-shelf control modules - so I was limited to the current output of the purchased product. I pushed forward with the install knowing that it works and I would continue to look for alternate controller solutions. - After installation in the vehicle, the performance is the exact opposite of the bench testing.... now with the vehicle outputting 14.4-14.6V - the steering wheel heats up in under a minute. Within a couple of minutes, it's getting to the point you must turn it down. Now my problem is that even on the lowest setting it's too warm and have to toggle between 'Off' and lowest setting. I'm on the fence if I'll leave it "as-is" or install a 12V-10A regulator that will maintain a constant supply voltage of 12V to the controller and then deal with longer warmup duration.
- In hindsight, there was a fair amount of risk modifying my original clockspring without a backup on hand. I do have an extra vehicle that allows for these types of activities, but had I damaged/broke my original - the vehicle would've been down for a week or better - waiting for a new one to arrive. I'm happy to report that I was able to completely disassemble the original unit twice (once for learning/research, once to execute plan), make the necessary modifications, reassemble, install and everything works perfectly.
Clockspring and HSW selector pics
scfkevin
PA, USA
C?ID=539454
Follow Up/Solved:
Can you share more information as to what controller you used. Did it come with a wiring diagram or do you have a wiring diagram? I am wanting to have HSW on my 2015 NMS Passat. Touareg has a similar wheel with heat as my Passat. They also have a button on the dash that can control the HSW part # 7P6 927 121 B. As far as clockspring, mine has 5K0 953 569 AE. Is there a reason I can't use 5Q0 953 569 B or (C).
I appreciate any more info you have on this.
Kevin
sheetrock0958
MN, USA
C?ID=590393
Kevin - as stated in previous posts, you won't be able to utilize the button to work on CAN. The coding/option doesn't exist for the NMS B7 Passat platform. Also, there are no clockspring iterations that will plug and play either. If you go find images on fleebay of your 5K0 953 569 AE and compare them with 5Q0 953 569 you will see that the mounting tabs & connector locations are different. I've attached a link of my original and the 5Q1 Donor that I used to modify my original.
scfkevin
PA, USA
C?ID=539454
Thanks for the clarification and pictures of the clockspring. I'm comfortable with modifying one to solve that problem.
I would still like to know what HSW controller you used. I'd much rather use an aftermarket controller than have no HSW. But I have not had success in finding one. Any help with that would be appreciated.
sheetrock0958
MN, USA
C?ID=590393
Sorry for the delayed response. I didn't get mine from ebay, but here is a link for the exact same one that I purchased: https://www.ebay.com/itm/373822280935
You will discard the heating element and cut off the barrel connector and wire it directly to your modified clockspring. As stated in previous post you may want to consider installing a 10A - 12V regulator to limit the voltage to the controller. When my vehicle is running the alternator output is 14.6-14.7v and the wheel gets uncomfortably hot. I mentioned this as one of the improvements I'd like to make but haven't yet.
