O2 sensor or wiring?
   #61
You mentioned that the Immobilizer was defeated , was this ECU replaced or altered for some reason?
   #62
q76767
New Jersey, USA
C?ID=445722
When I bought the car I bought it not running and person I got from thought was issue ecu so that put a random one in. Actual issue was timing belt sheared.
   #63
06G-906-055-AE
It appears the PN for the ECU in your car presently is for a 2014-2015 Jetta ; well at least according to this link:
That may explain your concern, but I'm not sure. One letter different suffix can make a difference if the replacement ecu was not flashed with your original data.
I recently had this service (Immo. defeat) for a replacement ECU ; the member who did the transfer requested that I get the exact same PN. This may be the reason (?????).
   #64
Dr Sheldon
Windsor UK
C?ID=334979
Go into OBD and read the Codes and Live data there - Do some diagnosis there.
I can't, from memory, tell you how to get in to that in VCDS - Hopefully someone here can guide you ??
   #65
q76767
New Jersey, USA
C?ID=445722
Just Had a freind come over that has an 11 jetta put ithe ecu in his car and it throws same code b1 s2 no activity after driving a few miles! I just ordered another ecu and sending it to have immo deleted.
   #69
Westbury, UK
I now have a lean condition I started another thread on that.
Might be a good idea to post a link to this thread in the new one to provide background and context.
