- Oct 13, 2022
- 379
- 73
- New Jersey, USA
- C?ID=445722
I have a 12 Jetta 2.0 SOHC and I'm getting some o2 sensor codes no activity and resistance to high. How would I test the wiring to the o2 sensor to confirm it isn't a wiring issue before I put a new sensor in? I checked the fuses already and the o2 sensor is a 4 wire sensor.
Sunday,13,October,2024,12:54:16:58701
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: 3VW2K7AJ4CM311089 License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 56
VIN: 3VW2K7AJ4CM311089 Mileage: 244790km-152105miles
Address 01: Engine (CBP) Labels: 06G-906-055-CBP.clb
Part No SW: 06G 906 055 AE HW: 06G 906 055 B
Component: 2.0l 85 KW G01 1302
Revision: T5H06--- Serial number:
Coding: 0001015
Shop #: WSC 57883 001 1048576
VCID: 6C81CDFEBA85A3BA93B-8038
VINID: 0E69C26C745A113743041008241720A809
050210 - Implausible Data Received from Body Control Module (Central Electric)
U0422 - 000 -
Mileage: 244798 km
Date: 2019.03.06.
Time: 03:20:37
RPM: 833 /min
Load: 26.7 %
Temperature: 51.0°C
Temperature: 25.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
000320 - Oxygen (Lambda) Sensor B1 S2
P0140 - 000 - No Activity
Mileage: 244798 km
Date: 2019.03.06.
Time: 21:30:37
RPM: 762 /min
Load: 22.7 %
Temperature: 92.0°C
Temperature: 57.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
004372 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 000 - Internal Resistance too High
Mileage: 244798 km
Date: 2019.03.06.
Time: 21:30:37
RPM: 770 /min
Load: 22.7 %
Temperature: 92.0°C
Temperature: 57.0°C
Voltage: 13.970 V
Readiness: 0110 0101
Part No SW: 09G 927 750 LE HW: 09G 927 750 LE
Component: AQ 250 6F 2618
Revision: 00H97000 Serial number:
Coding: 0000840
Shop #: WSC 43988 001 1048576
VCID: 7F5B0AB2DBF32822269-802A
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: B14B240C512308FB8D0B24EC8A221061A70000
Shop #: WSC 00066 000 00000
VCID: 7BA3FEA2C3EB34020A1-802E
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AM HW: 5C0 820 047 AM
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000487300
VCID: 6B83CEE2BF8BA4829A1-803E
00898 - Control Circuit A/C compressor
Fault Status: 00110111
Reset counter: 118
Mileage: 244798 km
Date: 2019.03.06.
Time: 00:04:44
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0251
Revision: B2066001 Serial number: 04371208110261
Coding: 7B994B1808AB0B0000302000240884D40042502E60000000300000000000
Shop #: WSC 00066 123 12345
VCID: 2F3B1AF2471318A2F69-807A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3464
Coding: 820000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3464
Coding: 800000
Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3464
Coding: 800000
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 013 0807
Serial number: 003GTM00S7YA Dataset Number: 160003v____ 0154
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3431159EAEB53B7A8BB-8060
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100005YBC0V
Coding: 303148
Serial number: 3572MSME08341660ZZZL
Serial number: 3582MSME0A590560ZZZT
Serial number: 3516KSME73632711ZZZJ
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME44462411ZZZG
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME02001B12ZZZB
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME29031B12ZZZO
Part No SW: 5C6 920 951 HW: 5C6 920 951
Component: KOMBI H04 0604
Coding: 270201
Shop #: WSC 00066 000 00123
VCID: 6889B1EEA2FD8F9AF73-803C
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0251
Revision: B2066001
Coding: 102200
VCID: 70B9D98E9AAD475AAF3-8024
Component: IMMO H04 0604
Shop #: WSC 00066 000 00199
VCID: 6A8DCBE6BCF1BD8AE17-803E
Part No SW: 1K0 035 164 D HW: 1K0 035 164 D
Component: LOW NAR H02 0004
Revision: -----03S Serial number: VWZ4Z6L3163870
Coding: 05000400010006
VCID: 2313E6C21BDBACC2621-8076
End----------(Elapsed Time: 01:01, VBatt start/end: 13.8V/13.9V)-----------
