Was involved in a crash, but believe the abs fault pre date this. The ABS sensor and wheel bearing changed. ECU has been tested.
Sunday,13,October,2024,14:09:24:05999
VCDS Version: 24.7.1.0 (x64)
VIN: WV1ZZZ7HZJH096181 License Plate:
Mileage: 255720km-158897mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZJH096181 Mileage: 255720km-158897miles
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KL HW: 04L 907 445
Component: R4 2.0l TDI H02 3802
Revision: 23002001
Coding: 00194014432401090000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KL 004003
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 0103B87E901E659EC4-8054
VINID: 9E606AAAA1D8A9A60024604804753BCA22
16091 - Accelerator Position Sensor 2 (G185)
P2128 00 [10100011] - Signal too High
Mileage: 255727 km
Date: 2074.01.22
Time: 14:02:26
Engine RPM: 0.00 /min
Coolant temperature: 8 °C
Intake air temperature: 14 °C
Voltage terminal 30: 12.203 V
Camshaft RPM: 0 /min
Camshaft adaptation intake bank 1: phase position: 1.8 °
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 63297000001663
Coding: 517E4098256B84848A76027EA48321E679F100
VCID: 3F877E86A66AD36EF2-806A
0055 - Front Right Wheel Speed Sensor
C101B 4A [10001001] - Incorrect Component(s) Installed
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 14:00:26
0088 - Rear Right Wheel Speed Sensor
C101D 01 [10001001] - Electrical Failure
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 14:00:26
8208 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 14:00:26
8216 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 14:00:26
8217 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 14:00:26
8338 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 14:00:26
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 15111713471240
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF9C382E1E01A66B9-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ROD: EV_ClimaT5Basis_VN75.rod
VCID: 73EFE2B6DAA2470EC6-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 322170755
Coding: A0A4303A0A61343193284F746CEB8E740F84708F60CC6D60330400220840
Shop #: WSC 02739 022 1247279
VCID: 2B5F3AD64A125FCE4E-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 151117 04 47 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 004 0653
Serial number: KU0KU003111773070403
Coding: 1400B0
Subsystem 3 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P
Component: J387__TSG_BT 004 0653
Serial number: KU0KU007111773112182
Coding: 0400A0
Subsystem 4 - Part No: 7E1 951 172
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 6 - Part No: 7E1 951 172
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 39170002736790057466
Coding: B0FFFF
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 T HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0212
Revision: -------- Serial number: 32931729907357
Coding: 10800A
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K_001_VN75.rod
VCID: 438F7276CA82B78E96-8016
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Serial number: 1811170438A292 Dataset Number: 7E0114v____ 0009
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ROD: EV_ACCBEGVW361.rod
VCID: 36691BA28950122621-8062
10 Faults Found:
1067 - Brake Temperature
C10DF 00 [00001001] - -
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 13:56:56
Control Module temperature: 28 °C
Voltage terminal 15: 12.1 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1058 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 13:56:56
1059 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 13:56:56
1088 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 13:56:56
1037 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 13:56:56
1544 - Function restriction
C10C2 00 [00001000] - -
Reset counter: 28
Mileage: 255727 km
Date: 2024.10.13.
Time: 14:00:24
Control Module temperature: 29 °C
Vehicle speed: 0.37 m/s
Acceleration: -0.01 m/s²
1118 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 13:56:56
1119 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 13:56:56
1081 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 13:56:56
1082 - Databus
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 13:56:56
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag021 H08 0018
Revision: -------- Serial number: 003V30073ZKG Dataset Number: 7E0003V____ 0905
Coding: 000000000000000000000000000000003231
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A710F92BD48F646C5-806E
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1107
Coding: 450B010300
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 042305
VCID: 68D585DA9B64B4D663-803C
Component: IMMO H03 1107
VCID: 6AD1FFD28D6886C675-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 L HW: 1K8 035 150 L
Component: MU-E-D-ER 056 7205
Serial number: 07111700010477 Dataset Number: V03935266VJ 0001
Coding: 065700003C00000041111101008000001F0000C60000010001
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 2E5933C271002AE669-807A
0001 - Antenna 1 for Radio
B1119 13 [00001001] - Open Circuit
Reset counter: 243
Mileage: 255727 km
Date: 2024.10.13.
Time: 13:42:11
Voltage terminal 30: 12.4 V
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030B7A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Serial number: 75885700001711120066
End-------------------------(Elapsed Time: 03:25)--------------------------
