P2147 - Supply Voltage for Fuel Injector Group A - Short to Ground
bert682
Ireland
C?ID=580016
Morning all!
Having the above error somewhat randomly after fitting a replacement injector to cylinder #3. The injector I used is sold as "recon" and as a result comes with a set of risks, I just want to try and narrow down if this "new" injector is at fault to speak to the seller to see what my options are;
Full Auto Scan;
Sunday,13,October,2024,11:43:08:47896
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WV1ZZZ2KZBX223902   License Plate:
Mileage: 351850km-218629mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
VIN: WV1ZZZ2KZBX223902   Mileage: 351850km-218629miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 DB    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9978
   Revision: --H43---    Serial number: 00000000000000 CVN: D0EF36E6
   Coding: 00114014032500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023DB 003011
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 698FAA1309F253C2E8D-803C
   VINID: 9E606AAAA09BA92A02083240083D1CB9BD
7594 - Supply Voltage for Fuel Injector Group A
          P2146 00 [00100000] - Open Circuit
                    Engine RPM: 0.00 /min
                    Coolant temperature: 6 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 11.181 V
                    Error information regarding selected piezo output stage-LF_STATE_PPS_SPI[0]: 0
                    Control Module temperature-TECU: -5 °C
                    Supply voltage of analog output 1-VCC_1: 5.03 V
                    Supply voltage of analog output 2-VCC_2: 5.01 V
7078 - Supply Voltage for Fuel Injector Group A
          P2147 00 [00100000] - Short to Ground
                    Mileage: 351854 km
                    Date: 2024.10.13.
                    Time: 11:25:29
                    Engine RPM: 1940.00 /min
                    Normed load value: 44.3 %
                    Vehicle speed: 51 km/h
                    Coolant temperature: 82 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.118 V
                    Error information regarding selected piezo output stage-LF_STATE_PPS_SPI[0]: 2
                    Injection valve 1: voltage-V_INJ_MAIN[0]: 132.19 V
                    Injection valve 2: voltage-V_INJ_MAIN[1]: 142.99 V
                    Supply voltage of analog output 1-VCC_1: 5.04 V
                    Injection valve 3: voltage-V_INJ_MAIN[2]: 131.70 V
                    Injection valve 4: voltage-V_INJ_MAIN[3]: 133.14 V
9835 - Injector: Cylinder 3 (N32)
          P1203 10 Z00100001] -!Chrbuit!M`lgunction
  !       Intermittent - Not Confirmed - Testee Sincd Lelosy Clear
  ! !   !   !Fseeze Fr`md:
  ! !               Fault Priority: 2
                    Mileage: 351855 km
                    Date: 2024.10.13.
                    Time: 11:27:14
                    Engine RPM: 910.25 /min
                    Normed load value: 16.1 %
                    Coolant temperature: 87 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 13.101 V
          (         Error information regarding selected piezo output stage-LF_STATE_PPS_SPI[0]: 0
                    Injector valve 2: capacity-CAPA_INJ_MAIN[1]: 0.0289 µF
                    Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1]: 6.4 µAs
                    Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1]: 0.694 mJ
                    Supply voltage of analog output 2-VCC_2: 5.00 V
                    Injection valve 2: voltage-V_INJ_MAIN[1]: 218.95 V
   Revision: 00H31001
   Coding: 633C400D092403FDC61402E4901BC081300000
   Shop #: WSC 04941 123 12345
   VCID: 76B5F16F48CC8C3A75F-8022
   Part No SW: 7N0 907 426 F    HW: 7N0 907 426 F
   Component: AC Manuell    H15 0101
   Revision: 00010001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW32.rod
   VCID: 372B3C6B0FC63532AE9-8062
   Part No SW: 2K5 937 085     HW: 2K5 937 085
   Component: BCM PQ35 B+   011 1044
   Revision: BB011001
   Coding: 401A581A8025186B08800082900000644301728852028060648000000040
   Shop #: WSC 35110 377 00154
   VCID: 72BDCD7F24A4901A597-8026
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 12041  26  0512
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 14
                    Mileage: 351836 km
                    Date: 2019.03.06.
                    Time: 08:51:56
                    Voltage: 11.65 V
                    Reset counter: 14
                    Mileage: 351836 km
                    Date: 2019.03.06.
                    Time: 08:51:56
                    Voltage: 11.85 V
                    Reset counter: 14
                    Mileage: 351836 km
                    Date: 2019.03.06.
                    Time: 08:51:56
                    Voltage: 11.65 V
                    Reset counter: 14
                    Mileage: 351836 km
                    Date: 2019.03.06.
                    Time: 15:25:53
                    Voltage: 14.15 V
                    Reset counter: 14
                    Mileage: 351836 km
                    Date: 2019.03.06.
                    Time: 15:25:53
                    Voltage: 14.15 V
   Component: VW10Airbag00U H06 0013
   Revision: --------    Serial number: 003HL001UZ6R Dataset Number: 2KC003v____ 0221
   Coding: 000000000000000000000000000000003055
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3537366315CAC722BC5-8060
   Revision: --------    Serial number:  90422KCO0002X Dataset Number: 5K0953507AH D005
   Coding: 008A160000
   Shop #: WSC 00028 028 00025
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B5F16F484C8C3A75F-8022
   Serial number: 30000000000000335235
   Coding: E20000
365080 - Controls in Steering Wheel
          U108E 00 [00001000] - No Communications
                    Reset counter: 54
                    Mileage: 351836 km
                    Date: 2024.10.13.
                    Time: 08:51:59
   Part No SW: 2K0 920 965 A    HW: 2K0 920 965 A
   Component: KOMBI         H04 0404
   Coding: 480000
   VCID: 2D071E03FD9A8FE2C45-8078
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 290910F2002012
   Coding: E9801F0600020200007401
   VCID: 6D87DE03319A4FE2845-8038
   Component: IMMO          H04 0404
   VCID: 6A8DD51F0CF458DAE17-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000624
   VCID: 48C94F977EB84ACAD73-801C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 140    3001
   Revision: 00H17000
   VCID: 313F0273ED22EB02E0D-8064
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000624
   VCID: 47CB4CAB73A645B2DE9-8012
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         541 5814
   Revision: --------    Serial number: VWZZZ4H6290655
   Coding: 16000440040005
   Shop #: WSC 127395 840 08317
   VCID: 46D541AF78AC5CBA25F-8012
00856 - Radio Antenna
                    Reset counter: 14
                    Mileage: 351836 km
                    Date: 2019.03.06.
                    Time: 15:25:48
                    Reset counter: 14
                    Mileage: 351836 km
                    Date: 2019.03.06.
                    Time: 08:51:54
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 14
                    Mileage: 351836 km
                    Date: 2019.03.06.
                    Time: 08:51:54
                    Reset counter: 14
                    Mileage: 351836 km
                    Date: 2019.03.06.
                    Time: 08:51:54
                    Reset counter: 14
                    Mileage: 351836 km
                    Date: 2019.03.06.
                    Time: 08:51:54
End----------(Elapsed Time: 00:57, VBatt start/end: 13.9V/13.9V)-----------
Specifically the faults that I am interested in. I was driving and the engine just cut out, was able to restart with an ignition cycle only for it to quit 30 seconds later. The second stop, the engine would just crank and never fire, I disconnected Injector 3 (the one I replaced) and was able to limp home. Sadly I cant recreate this issue with any consistency.
Sunday,13,October,2024,11:37:01:47896
                Address 01: Engine       Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 DB    HW: 03L 907 425 C
  Component and/or Version: R4 1.6l TDI   H43 9978
           Software Coding: 00114014032500080000
            Work Shop Code: WSC 35110 790 50316
              ASAM Dataset: EV_ECM16TDI02103L906023DB 003011 (VN35)
                    Mileage: 351854 km
                    Date: 2127.14.31
                    Time: 11:25:29
          P0203 00 [00100000] - Circuit Malfunction
                    Mileage: 351855 km
                    Date: 2127.14.31
                    Time: 11:27:14
Few stats that may be useful ?
Sunday,13,October,2024,11:39:54:47896
                Address 01: Engine  (03L 906 023 DB)
11:39:46
  IDE00365-ENG99400   Injection quantity deviation cylinder 1-FAC_CYL_BAL1 -0.2672 mg/stroke
  IDE00366-ENG101187   Injection quantity deviation cylinder 2-FAC_CYL_BAL2 1.1164 mg/stroke
  IDE00367-ENG101684   Injection quantity deviation cylinder 3-FAC_CYL_BAL3 -1.3453 mg/stroke
  IDE00368-ENG103465   Injection quantity deviation cylinder 4-FAC_CYL_BAL4 0.3408 mg/stroke
  IDE00437-ENG99390   Injector valve 1: capacity-CAPA_INJ_MAIN[0] 6.4365 µF
  IDE00438-ENG103101   Injector valve 2: capacity-CAPA_INJ_MAIN[1] 5.9555 µF
  IDE00439-ENG102776   Injector valve 3: capacity-CAPA_INJ_MAIN[2] 7.1076 µF
  IDE00440-ENG104221   Injector valve 4: capacity-CAPA_INJ_MAIN[3] 6.2240 µF
  IDE03893-ENG101196   Injection valve 1: voltage-V_INJ_MAIN[0] 117.58 V
  IDE03894-ENG104143   Injection valve 2: voltage-V_INJ_MAIN[1] 121.89 V
  IDE03895-ENG101536   Injection valve 3: voltage-V_INJ_MAIN[2] 111.05 V
  IDE03896-ENG102925   Injection valve 4: voltage-V_INJ_MAIN[3] 120.21 V
Ive chatted to a mechanic friend and he suggested the fault (P2147) from his experience is signs of a bad injector, testing is confirmed by disconnecting each in sequence and trying to crank the engine. The issue I have is that my fault seems to clear itself with ignition cycle so I cant get 100% repeatable tests to confirm the suspect #3 injector.
Has anyone maybe seen the issue before or notice any extremes in my very narrow data logs?
Dr Sheldon
Windsor UK
C?ID=334979
Remove that injector then - Bin it
Dr Sheldon
Windsor UK
C?ID=334979
Yes but never never relied on Serial processed data logs for anything ever !!
7594 - Supply Voltage for Fuel Injector Group A P2146 00 [00100000] - Open Circuit
For sure that is Open Circuit !!
Measure it with your DVM - Can you see it go open circuit ??
bert682
Ireland
C?ID=580016
Sorry, I forgot to add that, I have tested for breaks in the wiring and not able to find anything, cant get the multi-meter to beep over any of the injector loom / connectors. I appreciate all signs point to #3 but just if there is a way to 100% confirm this with my intermittent issue.
The old #3 fought me coming out so I had to remove the electrical connector and split the unit, I dont think id get useful comparable results back.
Dr Sheldon
Windsor UK
C?ID=334979
Those injectors fire for just milliseconds. Your window of opportunity to run any useful test on them is just those milliseconds . For that you will need a Digital Storage Oscilloscope with at least 4 channels and a Pair of Amp Clamps. Nope, your Multimeter wont do it !!
Ideally you want to swap injector 3 with another known good one in that engine but if they dont come out easy then that is not an option !
Why not return the New Injector and get a replacement - If that fails then it could be the Driver in the ECU
bert682
Ireland
C?ID=580016
So, few weeks later and an update;
I have swapped out for 4 "recon" injectors, I know this in itself is a gamble so I accept I may need to just give up this crusade and bite the bullet for new. However, it would be really useful to try and narrow in (if I can) on which Injector is failing me.
Multiple repeated errors of P2147 where the van will just die.
Been able to trigger the issue by leaving the car to idle while logging some metrics;
LOGGING
My reading of this would indicate that its #3 as the issue as its the item where I have no data (line 663) for capacity-CAPA. The values for capacity in #3 seems to trend higher than the others also, unsure what the normal range of these is. My alternative reading of this is that the failure could be #2, as this went "bad" and then caused the short in the circuit which shut things down yielding no data for #3
Maybe someone with more understanding that me could read the last few rows and see if there is anything of value.
Thanks!
bert682
Ireland
C?ID=580016
Further update!
Decided to bite the bullet and order new injectors after being unable to reliably recreate the fault or find anything wrong wiring wise.
4 new injectors and van is running perfect now, tried to put stress on it during the road test (previously what caused the short) and kept on going.
Im suspecting at least one of the "recon" units is failing under load, perhaps an insulation test would show its on the way out but at £500 for a tester I may never know.
Just if anyone else finds this thread, P2147 for me sadly was fixed by new injectors.
