Injector coding on 2012 tdi with a "new to car body" engine
ncfatherof1
Elon, NC, USA
C?ID=572468
I replaced my #3 injector yesterday and while doing the adaptation I noticed that the other 3 injectors code on the injectors do not match with the id numbers that was listed in the vcds software. I know the engine was changed at some point prior to me buying the car. I assume, whomever that changed the engine, did not take the time to code the ecm to the injectors numbers that are in the new engine. I've been driving the car for over a year with no injector codes with exception to the #3 injector that I changed out, and also have noticed I'm not getting as good fuel economy that I maybe should. Only truly noticeable issue is quite a bit of fuel smoke out of exhaust when initially starting car after several hours of the car sitting. Also tends to be more smoke when its temps are cooler.
Should I code the ecm to the correct injector numbers that are remaining in the engine, or just let it ride till I can afford to swap out the remaining injectors with new and code them correct at that time??
Thanks!
Saturday,12,October,2024,15:43:31:50408
VIN: 3VWLL7AJ1CM087703   License Plate:
Mileage: 304760km-189369mi   Repair Order: rep inj #3
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56
VIN: 3VWLL7AJ1CM087703   Mileage: 304760km-189369miles
2E-Media Player 3 -- Status: Sporadic communication error 1000
37-Navigation -- Status: Cannot be reached 1100
56-Radio -- Status: Sporadic communication error 1000
   Part No SW: 03L 997 030 M    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number:
   Coding: 0050078
   Shop #: WSC 74291 008 00000
   VCID: 382938057E5FC54AA7B-806C
   VINID: 0E69DC70745A0537402071C00C39831722
Readiness: 0 0 0 X X
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 9334
   Revision: 05351113    Serial number: 00001110060861
   Shop #: WSC 00066 000 00000
   VCID: 176BDBB91381EA328E1-8042
Address 03: ABS Brakes
   Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0802
   Revision: 00085000    Serial number: 0152507223 Dataset Number: 5K0116v____ 1608
   Coding: 030C0C
   ASAM Dataset: EV_KESSY_PQ35GP A01018
   ROD: EV_KESSY_PQ35GP_VW32.rod
   VCID: 33330F296BB92612929-8066
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000696611
   VCID: 6FBBC3594B9142F2B61-803A
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0257
   Revision: B2066001    Serial number: 04371342110204
   Coding: 7B994B9A08AB0B0008382000240884C50082502E6020000030A000000000
   Shop #: WSC 09060 003 104857
   VCID: 2F3B0359871102F2F61-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H09 0007
   Serial number:     WRH0003MN1J
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0727707
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM0340H8   Dataset Number: 160003v____ 0154
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 34310C356EB7212A8B3-8060
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y1100009M5308
   Coding: 303036
   Serial number: 3572MSME53556065ZZZS
   Serial number: 3582MSME3A573464ZZZ-
   Serial number: 3516KSME4B536C14ZZZZ
   Serial number: 3526KSME1A6A1115ZZZP
   Serial number: 3556LSME04126A10ZZZI
   Serial number: 3566LSME3C110A20ZZZO
   Part No SW: 5C6 920 951 A    HW: 5C6 920 951 A
   Component: KOMBI         H04 0604
   Coding: 270A01
   Shop #: WSC 00066 000 00119
   VCID: 290FED41B9756CC2285-807C
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0257
   Revision: B2066001
   Coding: 102200
   VCID: 70B9C0255AAF5D0AAFB-8024
01304 - Radio
                    Reset counter: 160
                    Mileage: 299369 km
                    Date: 2019.03.05.
                    Time: 10:31:26
                    Reset counter: 21
                    Mileage: 299369 km
                    Date: 2019.03.05.
                    Time: 10:31:26
02078 - Media Player Position 3 (R120)
                    Fault Frequency: 234
                    Reset counter: 160
                    Mileage: 299369 km
                    Date: 2019.03.05.
                    Time: 10:31:26
   Component: IMMO          H04 0604
   Coding: 000007
   VCID: 6A8DD24D7CF3A7DAE1F-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000191314001
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 2E051E5D809B0BFAFD7-807A
   Revision: A1001003    Serial number: 7660769803
   Coding: 020000
   VCID: 290FED41B9F56CC2285-807C
Address 37: Navigation
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 70     3301
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 35373131694D3822BCD-8060
   Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
   Component: KonzernAmp10K H06 0362
   Revision: --------    Serial number: BP225319949189 Dataset Number: 560050v____ 1604
   ROD: EV_AudioVerst10KanalSTT3_VW32.rod
   VCID: 303900259AAF1D0AEFB-8064
Address 56: Radio        Labels:
   VCID: 55F791B1CC0D18225CD-FFFE
End----------(Elapsed Time: 03:32, VBatt start/end: 12.0V/12.0V)-----------
I would have a look at injector deviations. If they're acceptable, leave it alone until you replace the other three. If they're not, then I'd try to code them in.
ncfatherof1
Elon, NC, USA
C?ID=572468
Couldn't get the photo to load here, but here are my results with the information you inquired about:
Engine speed (G28): 828 /min
Coolant (G62): 90.0C
Injector quantity deviation Cyl 1: -0.71 mg/str
Injector quantity deviation Cyl 2: -0.28 mg/str
Injector quantity deviation Cyl 3: 0.71 mg/str
Injector quantity deviation Cyl 4: 0.24 mg/str
fuel consumption: 0.63 l/h
Dr Sheldon
Windsor UK
C?ID=334979
Leave well alone !!
I say that because you do not have enough info from the past to make any decision !!
Quite often Injectors are "rebuilt" and the rebuilder has no way to test and produce a calibration number for that rebuilt injector - So the code stamped on it is wrong.
All that is perfect !! Leave the thing alone !!
If you really cannot help your self then at least note the codes in there now so you have a rewind strategy !!
I agree, that's not bad at all, and I'd leave it alone.
