Why am I in limp mode?
what2be
Eureka, CA, USA
C?ID=598147
I have a abs error (waiting for a replacent ABS pump) and also this new "actuator module for turbocharger 1 stuck" error. Would either of these errors cause it to go into limp mode?
Also, the dash shows "service particulate filter" message. I tried doing a standing particulate filter regen from VCDS but it just fails and says "safety feature" test ended. Any advice?
-Geoff
Friday,11,October,2024,23:24:01:32476
VIN: WA1VMAFE7CD003066   License Plate: OCT 11 1123PM ORIG ABS
Mileage: 296760km-184398mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
          56 5F 62 69 6D 6F 72 76
VIN: WA1VMAFE7CD003066   Mileage: 296760km-184398miles
4C-Tire Pressure II -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401     HW: 4L0 907 401 D
   Component: 3.0TDI FSA    H18 0009
   Revision: 54H18---    Serial number:                CVN: 5B6F114CD45710C1755A2113
   Coding: 2A2A4012253600050000
   Shop #: WSC 27985 004 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401 002008
   ROD: EV_ECM30TDI0114L2910401_002.rod
   VCID: 61987DF911CE47C2305-8034
   VINID: 9D10667515951D35000030061896D2B1F1
14625 - Glow Plug Control Module (J179)
          P0683 00 [00100111] - Electrical Malfunction
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:57
                    Engine RPM: 0.00 /min
                    Coolant temperature: 69 ∞C
                    Intake air temperature: 39 ∞C
                    Voltage terminal 30: 11.840 V
                    Glow-control unit: activation voltage: 0 mV
                    Glow_period_control_unit_ground_offset_voltage: 0 mV
                    Glow-control unit: calculated glow voltage: 0 mV
                    Glow_period_control_unit_energy_integrator_calculated_value: 0.0 V≤s
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 0
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 19
                    Glow status-Bits 0-7: 0
                    Glow status-Bits 0-7: 80
                    Co EOM st Op Mode Short-Bits 0-7: 0
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [00100111] - -
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:57
                    Voltage terminal 30: 11.860 V
                    ACC specified acceleration: 0.000 m/s≤
                    ACC control module: received status-Bits 0-7: 6
                    Active brake system error status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s≤
                    Engine status: COENG_READY
4660 - Implausible Data Received from ABS Control Module
          U0415 00 [00100111] - -
          [Invalid Data Received FromAnti-Lock Brake System Control Module]
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:57
4675 - Implausible Data Received from ABS Control Module
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:57
9127 - Actuator Module for Turbocharger 1
          P00AF 00 [10100111] - Stuck
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:56
                    Charge Pressure Actuator: activation: 5.00 %
                    Charge air pressure actuator: acknowledgment: -4.82 %
                    Turbocharger boost control: offset closed: 0.00 %
                    Turbocharger boost control: offset open: 0.00 %
                    High press turbocharger actuator: actual uncond volt value: 258.8 mV
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 S    HW: 0C8 927 750 S
   Component: AL1000 AISIN  001 3408
   Serial number:                CVN: 44BD1086
   Coding: 001378
   ROD: EV_TCMAL991031_002_AU56.rod
   VCID: 3C26EC8DD6EC4A2A433-8068
12831 - Implausible Data Received from ABS Control Module
          U0415 00 [00001001] - -
                    Reset counter: 201
                    Engine RPM: 0.0 /min
                    Transmission input speed: 0 /min
                    Engine torque: -44 Nm
                    ATF temperature: 54 ∞C
                    Accelerator pedal position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    EOP target revolution: 65534 /min
                    EOP actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    EOP failure status with EOP without HV 1: Motor normal stop
                    EOP target current: 65278 mA
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099473
   Shop #: WSC 31414 790 00001
   VCID: 3436C4ADF23C826A8B3-8060
7 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:53
                    Count: 128
                    Count: 321
                    Count: 283
                    Count: 43008
00814 - Solenoid for Brake Pressure (N247)
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:53
                    Count: 128
                    Count: 321
                    Count: 110
                    Count: 43008
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:53
                    Count: 128
                    Count: 321
                    Count: 166
                    Count: 43008
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:53
                    Count: 128
                    Count: 321
                    Count: 297
                    Count: 43008
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Fault Status: 01101000
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:54
                    Count: 128
                    Count: 321
                    Count: 38
                    Count: 43008
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:54
                    Count: 128
                    Count: 321
                    Count: 40
                    Count: 42752
00493 - ESP-Sensor Unit (G419)
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:53
                    Count: 128
                    Count: 321
                    Count: 12288
                    Count: 43008
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603401893047
   Coding: 0000135
   Shop #: WSC 44055 001 1048576
   VCID: 251029E949E6EBE20CD-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Component: FBSAUDIC6 IDG   H01 0053
Address 08: Auto HVAC (J255)       Labels: 4L0-910-043.clb
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AJ
   Revision: 00---026    Serial number: 00000030208767
   Coding: 0004A036
   VCID: 251029E945E6EBE20CD-8070
   Subsystem 1 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Component: SLR-B8  H05 0006
   Serial number:           0012461892
   Coding: 070000
02874 - Control Module 2 for Central Convenience (J773)
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:58
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:58
                    Temperature: 23.0∞C
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0139123
   VCID: 6E8216C5DC90E8BABD7-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 15: Airbags        Labels: 4L0-910-655.clb
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09VDZ9
   Coding: 0014131
   VCID: 2B04DFD12F02DD92DA9-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME180D265AK
   Subsystem 3 - Serial number: 6342QSME180D2C78R
   Subsystem 4 - Serial number: 6352QSME195E225AP
   Subsystem 5 - Serial number: 6362QSME685C2972T
   Subsystem 6 - Serial number: 63734SME315C3C7CD
   Subsystem 7 - Serial number: 63834SME045B217E3
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
   Component: J0527               0830
   Revision: 00H07000    Serial number: 90025111660484
   Coding: 0012242
   VCID: 280E20DD3EF4F68A37B-807C
   Component: E0221           H03 0030
Address 17: Instruments (J285)       Labels:. 4L0-920-KOM-V3.clb
   Part No SW: 4L0 920 984 R    HW: 4L0 920 984 R
   Component: KOMBIINSTR.   H22 0411
   Revision: 00000000    Serial number: LMZ04009C
   Coding: 8BD664040900CF05020205
   VCID: 42DA9275B4883CDA09F-8016
   Part No SW: 4F0 907 468 Q    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0047
   Revision: MB300033    Serial number: 3300M11819012B
   Coding: 00C303
   VCID: 3D20E189CD76432274D-8068
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790354551
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000000293140
   Coding: 0000006
   VCID: 688E60DDFE74368AF7B-803C
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:58
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:10:03
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000013015459
   Coding: 00581B00000011110000
   VCID: 323AC2B504288C5A99F-8066
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E02D6C51C10A8BAFD7-807A
   Subsystem 3 - Serial number: 5F19.08.1100H010003C912704ˇ
   Subsystem 4 - Serial number: 912704ˇ
                    Reset counter: 208
                    Mileage: 16 km
                    Date: 2011.08.12
                    Time: 00:09:53
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000012886533
   Coding: 011F57205E40440004
   VCID: 48CE805D92B4168AD7B-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H11 0120
   Revision: 0120 ---    Serial number: 01556943850000
   Coding: 3569693
   VCID: 382EF09DEE54660AA7B-806C
   Part No SW: 4L0 035 223 H    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0130
   Revision: CH003000    Serial number: 00000000009532
   Coding: 030000
   VCID: 270C23E13FEAF9F23E1-8072
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005190106726
   Coding: 0758477
   VCID: 231437F147D215D2629-8076
                    Fault Status: 11101101
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:53
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0003
                    Voltage: 12.00 V
                    Temperature: 20.0∞C
                    (no units): 255.0
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:53
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 12.00 V
                    Temperature: 20.0∞C
                    (no units): 0.0
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000095857
   Coding: 0012001
   VCID: 5EE246052C30783A0D7-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000013387741
   VCID: 47CC83619FAA19F2DE1-8012
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:54
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000031
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H52 0076
   Revision: AB001007    Serial number: 156I50B7547359
   Coding: 020007010000000000
   VCID: 1F1C3B0167BA3132461-804A
   Part No SW: 4L2 035 746 B    HW: 4L2 035 746
   Component: H-BNT-NA      H42 0422
   Revision: --------    Serial number: 097I.0B7503442
   Coding: 180200060004E3EF51002345EF632003140000000100000000
   VCID: 2D00D1C91D16D3A2C4D-8078
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H42 0094
   Serial number: 9466GT0A0034437
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000001906487
   Component: CD-Database  3371
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:58
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000013005192
   Coding: 010E57204040230004
   VCID: 46D28E6598A000FA257-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000156551204
   Coding: 0200000000000000
   VCID: 3138CDB9012EB742E05-8064
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C861CCDEA8C1AAA933-8038
   Subsystem 3 - Serial number: RD08.09.11--H57001001A0268ˇ
   Subsystem 4 - Serial number: 1A0268ˇ
   Component: ILM HINTEN 2    H07 0080
   Revision: AAH07080    Serial number: 118895293-----
   Coding: 0003595
   VCID: 26122EE534E0E0FA057-8072
   Component: J_245_EE16_SKB10H11 0220
   Component: J_394_EE16_SKB10H11 0220
   Component: J_392_EE16_SKB10H11 0220
01512 - Control Module for Sliding Roof
                    Fault Status: 01100101
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:53
02906 - Control Module for Sliding Roof; Rear (J392)
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:53
02907 - Control Module for Roof Shade (J394)
                    Reset counter: 208
                    Mileage: 296768 km
                    Date: 2011.08.12
                    Time: 00:09:53
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000013005343
   Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Component: Parkhilfe 8-Kan H03 0500
   Revision: 00H03000    Serial number: 37361123701717
   Coding: 0231266
   VCID: 2A0ADAD520F8C49A21F-807E
End----------(Elapsed Time: 02:17, VBatt start/end: 12.0V/12.0V)-----------
Address 19,4F0 907 468 Q,channel 1,adapted from,0,to,0,
De-activating transport mode...Done.
Address 03,4L0 910 517 M,recoded (Short coding),from,0099473,to,0099473,(31414/790/00001),
Sequential Output Tests
Address 0x01,4L2 910 401 ,UDS Basic Settings,IDE02107-Resetting of learned values of turbocharger
Address 0x01,4L2 910 401 ,UDS Basic Settings,IDE02640-Injector test
Address 0x01,4L2 910 401 ,UDS Selective Output Tests,IDE00222-Throttle Valve Control Module
Address 0x01,4L2 910 401 ,UDS Basic Settings,IDE00457-Test of turbocharger
Westbury, UK
9127 - Actuator Module for Turbocharger 1 P00AF 00 [10100111] - Stuck MIL ON - Not Confirmed - Tested Since Memory Clear
The Auto-Scan tells you the cause of the MIL and limp mode.
what2be
Eureka, CA, USA
C?ID=598147
I see where it says MIL which is the message indicator light but where does it say limp mode?
what2be
Eureka, CA, USA
C?ID=598147
Ok, so what are the odds it's the arm that goes into the turbo that's seized/broken versus the module being bad? And if it is the module Is it easier to takeoff just a module or do you have to take the whole turbo off to take the module off?
Westbury, UK
Mechanical part subject to lots of heat and temperature variation vs electronics in sealed environment?
I know which I think is most likely to be the cause.
what2be
Eureka, CA, USA
C?ID=598147
Why should it say? Isn’t it obvious?
Actually no it isn't because when the cars giving me the message service particulate system it could very well be from that or maybe both but how is one to know when it's not shown in the log of the scan?
TTT
C?ID=547002
I mean, you don't need more than pushing the pedal, to see that the engine is in limp mode. Nevertheless, if you're not happy about it, call VAG group? They design it, built it and not Ross-Tech.
what2be
Eureka, CA, USA
C?ID=598147
Apparently we're not on the same page. I'm well aware that the car is in limp mode but this is not my car ,although I do need it right now to drive to work which is 150 miles away so it sure would be nice since I've already missed a week of work to narrow this down to the minimum needed to make it to work so I can resolve the rest of the issues there not Sitting at home with my finger in my ass doing nothing
TTT
C?ID=547002
Then focus on what is broken as per fault code. The rest limp mode not limp mode just let it go.
Dr Sheldon
Windsor UK
C?ID=334979
Dont worry about odds right now. Do the job correctly and test it properly !! It still could be a broken wire !! No one knows - TEST TEST TEST and confirm !!
I dont know (without looking) but No Pain No Gain - If it has to come off then get your finger out and crack on :facepalm:
It is written into the software of your ECU and may also be in the SSP for your Engine Management. May also pop up in Odis GFF
. Fear not it is there !!!
Ignore the DPF fault and it wont be "Limp" Home - You will be walking Home !!
Take it s both - However you wont fix the DPF until the Turbo Fault is repaired
14625 - Glow Plug Control Module (J179) P0683 00 [00100111] - Electrical Malfunction
You wont go far with the DPF - The Glow Plug fault will need to be fixed before thinking about a DPF Regen
We clearly are !!
We dont care who owns it !! You are a verified member with a genuine VCDS looking for technical help - it can be here in abundance if you have the minerals to absorb and act on that help !!
And if you work that far away from home - Would it not be prudent to have your own car ?? Rail Ticket / Coach Ticket / Rent a Car .....
Then make friends and stop being a brat to those trying to help you with the "Why is it in Limp" nonsense.
Yours is not to reason why, But to do or die!! line from Alfred, Lord Tennyson's poem The Charge of the Light Brigade.
The minimum is the Turbo Fault, Glow Plug Fault and then Dpf - Then re Evaluate
Ignore any of the above and Walking Home could become Not Leaving Home !!
There you go !!
what2be
Eureka, CA, USA
C?ID=598147
Dr Sheldon
Windsor UK
C?ID=334979
Well I'm no electrical engineer but I'm pretty sure the problem is here with the power and ground. and if not can someone point me to which one the ground is and which one the positive is?
That water damage wont help ?
ERWIN is your best friend for now !!
My next question is Does this motor work off of reverse polarity to move One Direction and then polarity the other
Have a look - Some do reverse Polarity using a "H Bridge" - Others Push against a Spring and the Spring Pushes back. Looking at your photo this is a Worm Drive so yes it will be a H Bridge Reversing Polarity. A worm gear will not / cannot push back autonomously.
The circular pcb with the tracks for sure is part of the Position Sensor
Dr Sheldon
Windsor UK
C?ID=334979
Would not help if you were - You need to be a Mechanical Engineer too.
Being a Turbo Pressure fault we are now crossing into Pneumatic Science, bearing in mind the info you have from the fault code and looking at that PCB you have jumped Both Feet First into Electronic Engineering Computer Science designed, I guess by High Achieving Graduates !!
Vag did not design and build your car with a Sunday School Spotty faced talent !!
VCDS is not your enemy !! If you had a VW Phaeton and had the inclination to hide a dead body in the boot / trunk - It can verify the Nationality of that Corpse - Scary Shit Man !!
  • Haha
