Please help: golf 5 rear doors no power
Mllzy86
Pirate
Walking the Plank
LP/IP
Hi,
Thanks for taking some time to read this, I’m not sure if it’s posted in the correct sub however I’m desperate for assistance.
The rear two doors seem to get no power at all. The window, switches, speakers, door lock all do not work - I can’t control the window/lock from the front either.
I have replaced the wiring loom for one of the doors and no luck, I have checked the power to the window module on the replaced loom and I get no power. I checked the fuses and they’re all okay.
I have changed out the lock unit and the window control module and no luck either. :(
I took apart the interior panels and checked for power going to the exterior connector and I got 0 power excluding the black wire and a yellow/green wire. However it wasn’t constant it was a fluctuating power. (Only checked drivers side)
This is the error I get, I will get a full VCDS report and post it soon.
46- comfort system - 00931, 00930 - lock unit for central locking. Rear right+left
i have coded out the rear doors temporarily so the car confirms with me when I lock it, however when I did buy the car the two rear doors were not coded in.
Anyone have a clue what’s going on
Mllzy86
Pirate
Walking the Plank
LP/IP
VCDS SCAN (i deleted some bits from other modules to make it quicker to read)
Removed.  Data from a clone/pirate copy of VCDS is not acceptable in Ross-Tech's forum.
