Can Gateway Multiple Entries
d*n
C?ID=165828
Hi,
I recent purchased a 2016 A6 Allroad and it has an error in the list of installed modules when I perform a scan (see below).
When I look at the installation list inteh CAN gateway, module 17 appears twice and both instanses are ticked.
I therefore have three questions:
1) why is module 17 appearing twice in the installation list?
2) should I untick one of the instances to clear this error?
3) does it matter which instance I untick?
Thanks in advance
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 34 36 3B 42 44 46 52 53
55 5F 62 69 6C 6D 72 AC 47
17-Instruments -- Status: Cannot be reached 0100
19-CAN Gateway -- Status: Malfunction 0010 <-- relates to aftermarket backup camera
6C-Back-up Cam. -- Status: Malfunction 0010 <-- Basic settings / Calibration
Reactions: d*n
d*n
C?ID=165828
Thursday,10,Octobber,2024,12:18:31:15913
VCDS Version: 24.7.0.0
VIN: WAUZZZ4G0HN024478   License Plate:
VIN: WAUZZZ4G0HN024478   Mileage: 147649km-91744miles
Address 01: Engine (J623-CRTD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G2 907 401 B    HW: 4G2 907 401
   Component: 3.0TDI EDC17  X34 0007
   Revision: 92X34---    CVN: 0B26E231C19C77718947E11D
   Coding: 32254012052609030000
   Shop #: WSC 23914 003 1048576
   ASAM Dataset: EV_ECM30TDI0114G2907401B 001007
   ROD: EV_ECM30TDI011_AU57.rod
   VCID: 2441D20E2FE5D6B687-8070
   VINID: 9D196AAAA117018780084107200AEEBE64
   Part No SW: 4G0 927 166 H    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0004
   Revision: --H03---    CVN: 000067C8
   Coding: 100001
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 326D24566511480605-8066
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 27A6DE45E4657BA29B00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 418F7B9AD0B7E39E8C-8014
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0824
   Coding: 01B9704E000000000000
   VCID: 7CF1CA6EFFD54E769F-8028
   Serial number: 3216000137892015
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 07071600040463
   Coding: 36221178210000
   VCID: 63C391126A6B918EBE-8036
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 15020001    Serial number: 00001416877401
   Coding: 0105001440349FE049014083A0001800CF9D6708AF08022100000894E100170200400024030000
   VCID: 74E1E24ED7850636D7-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 160525  H38 0080
   Serial number:         160602095721
   Coding: 0045F7
   Serial number: 62013983
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 30 06 2016  00000021
   Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0030
   Serial number: 0000000094CE02038132
   Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: C228483800PAG0MUFU03
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P100AH15J Dataset Number: 4G0909602M  0003
   Coding: 30333130313730323737554A305234473053
   VCID: 3B730972B25B894ED6-806E
   Serial number: 3575HRB400655CG069AJ
   Serial number: 3585HRB404R4410QFOKX
   Serial number: 3515JRB401655B78IPK9
   Serial number: 3525JRB400I571NCMHEN
   Serial number: 3554VRB400Q577JUTHBQ
   Serial number: 3564VRB40025752KC0JY
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 91560PFU000AQ
   Coding: 000035
   VCID: 3B730972BA5B894ED6-806E
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 13 03 2017  A0027745
   Part No SW: 4G9 920 951 M    HW: 4G9 920 951 M
   Component: TDieGb    Nv  H14 0225
   Revision: 11001108    Serial number: 658060716596042
   Coding: 33A725081B412600010600
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002267213 Dataset Number: 4G0909515K  0022
   Coding: C0CD078118
   Shop #: WSC 57030 001 1048576
   GVL: FD83E948DC27600300040800
   VCID: 3D77076AAC4F877EE8-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 1708640704
   Voltage stabilizer:
   Serial number: 1604120000000000040E
5807 - Rear View Camera System Control Module
          U104C 00 [00001001] - No communication
                    Reset counter: 77
                    Mileage: 147649 km
                    Date: 2024.09.19
                    Time: 12:06:36
                    Voltage terminal 30: 14.3 V
                    Voltage terminal 15: 14.2 V
                    Control Module temperature: 23 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 67DB85029653FDAE62-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 06071600040498
   Coding: 22
   Dataset Number: 4G0909553G  0036
   Coding: 008001
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2F6B2D22762365EE6A-807A
   Revision: AA000000    Serial number: 00000206687123
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77FBD542C6F36D2EF2-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820BUNN5 Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 366518468979542629-8062
   Component: TSG FA        H03 0511
   Coding: 011F16015E01620002080002
   VCID: 479B6582F693DDAE42-8012
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000076013 Dataset Number: 4G0909852L  0037
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A7D0C76BD61B046CD-806E
   Revision: 00002001    Serial number: 0410106292
   Coding: 013F0622A0B97080C320098420010F470000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000086919
   Subsystem 2 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 4 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00022956421
   Component: TSG BF        H03 0511
   VCID: 46856886F199C4A6B9-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001904292 Dataset Number: 4G0909522F  0008
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 316F2B5A6017731E7C-8064
   Revision: --------    Serial number: -------------- Dataset Number: 4G0909865D  0018
   Coding: 04FE02102A630200
   VCID: 3461224E9F05463617-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 P    HW: 4G1 035 021 D
   Component: MU-H-LND-EU   052 1425
   Serial number: A733A0J7530145 Dataset Number: 4G1909545F  0036
   Coding: 01754201FF0A000013111101000A00332F000AE7F1700100DF
   Shop #: WSC 28701 003 1048576
   VCID: 275BC5025ED33DAEA2-8072
   Subsystem 1 - Part No SW: V03 959 802 TS    HW: -----------
   Component: ECE 2024  --- 0350
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY805KGZ
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349PG5000KF
   Compact disc data bank:
   Subsystem 4 - Part No SW: V03 959 800 GG    HW: -----------
   Component: Gracenote2  --- 1021
   Component: TSG HL        H03 0511
   Coding: 010F14004001620002080002
   VCID: 499F63BAE0872BDE54-801C
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H07 0072
   Revision: 5G001001    Serial number: 00000135966549
   Coding: 0100000000000000
   VCID: 71EFEB5AA897331E3C-8024
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556 A    HW: 4M0 980 556 A
   Component: RVC Compact   H18 0201
   Dataset Number: 0005
   Coding: 0275000102002003000040
   Shop #: WSC 19460 666 12345
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
   ROD: EV_CamSysRVRVCPANAAU57X_002_AU57.rod
   VCID: 397F137AB867BB5EC4-806C
10489856 - No Basic Setting
          B2010 00 [00001001] - -
                    Reset counter: 77
                    Mileage: 147649 km
                    Date: 2024.09.19
                    Time: 12:06:36
                    passive
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 176601279 Dataset Number: 4G0909541E  0004
   Coding: 093205C011
   ROD: EV_HDSGAu571_AU57.rod
   Component: TSG HR        H03 0511
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 161590791 Dataset Number: 4G0909571H  0017
   ROD: EV_RDCMA00100.rod
End-------------------------(Elapsed Time: 06:16)--------------------------
I'm stumped on the "17-Instruments -- Status: Cannot be reached" issue since it clearly can be reached as evidenced by:
Maybe try un-checking one or the other of the 17-Instruments entries in the GW to see if you can make that nonsense in the Installation List go away?
d*n
C?ID=165828
Well thats weird.......
I de-seleted one module 17 in the CAN gateway and got a module 17 not registered error when I did a freash scan.
I then reversed the module selections, cleared all the errors and did a freash scan.
The error "17-Instruments -- Status: Cannot be reached" has disappeared.
When I checked the installation list, both module 17's are selected.
