Hello, looking for some assistance with the VCDS auto scan. I recently replace injector #4 approximately 3k miles ago. On an hour long round trip the glow plug flashing light then the CEL came on - Autoscan shows P0087. Can you please take a look at the scan and point me in a direction? Hopefully I posted the scan correctly?
Thanks!!!
Thanks!!!
Thursday,10,October,2024,15:40:47:19969
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WA1WMBFE5DD004373 License Plate: 10.10.24
Mileage: 212810km-132234mi Repair Order: 2013 Q7
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 36 3C 42 46 47 4C
4F 52 55 56 5F 62 6C 6D 6F 72
VIN: WA1WMBFE5DD004373 Mileage: 212810km-132234miles
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI FSA H20 0014
Revision: 54H20--- Serial number: CVN: 1B2B2502D45710C1755A21130E1FC39E
Coding: 2A2A4012256600050000
Shop #: WSC 15077 004 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401A 001015
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 221DED2CA44B110A697-8076
VINID: 9D10677525951545000040C70CF58E21CB
5215 - Fuel Rail/System Pressure
P0087 00 [11101101] - Too Low
Mileage: 212737 km
Date: 2024.10.10
Time: 14:13:24
Engine RPM: 602.50 /min
Normed load value: 76.5 %
Coolant temperature: 63 °C
Intake air temperature: 39 °C
Voltage terminal 30: 12.120 V
Fuel temperature: 49.6 °C
Mean injection quantity: 18.98 mg/stroke
Rail pressure regulation: status-Bits 0-7: 5
Fuel high-pressure: actual value: 99200 hPa
High fuel pressure: specified value: 250000 hPa
Pressure control valve adaptation factor: 1.0427
Fuel level: 95.00 l
17277 - SCR NOx Catalyst Bank 1
P20EE 00 [01100000] - Efficiency too Low
Mileage: 212223 km
Date: 2024.10.03
Time: 13:28:38
Engine RPM: 2061.00 /min
Normed load value: 69.8 %
Vehicle speed: 124 km/h
Coolant temperature: 86 °C
Intake air temperature: 19 °C
Voltage terminal 30: 14.040 V
SCR efficiency test overall: 3.70 %
SCR error threshold of efficiency test: 45.00 %
SCR efficiency test 2: 0.071
SCR efficiency test 1: 0.007
Particle filter: unburned fuel calculated: 0.001
Mean temperature of SCR catalyst: 324.4 °C
Long-term adaptation of reduction agent dosage: 0.99
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
Component: AL1000 AISIN 002 3399
Serial number: CVN: 0478EC02
Coding: 001378
Shop #: WSC 99999 999 83333
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 7BA3F048636180C20A1-802E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0627825
Shop #: WSC 31414 790 00001
VCID: 34311B74023F8FBA8BB-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702020352
Coding: 0000135
Shop #: WSC 08213 444 56835
VCID: 2517F630B9E5E6320C5-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Component: FBSAUDIC6 KSG H03 0020
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 172
Mileage: 211578 km
Date: 2024.09.26
Time: 17:06:32
00191 - Passenger's Door Handle Touch Sensor (G416)
Reset counter: 172
Mileage: 211578 km
Date: 2024.09.26
Time: 17:06:32
00193 - Rear Right Door Handle Touch Sensor (G418)
Reset counter: 172
Mileage: 211578 km
Date: 2024.09.26
Time: 17:06:32
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AJ
Revision: 00---026 Serial number: 00000000341993
Coding: 0304A036
VCID: 2517F630B5E5E6320C5-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0034223483
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0034222777
Coding: 070000
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H29 0390
Coding: 0133123
VCID: 6E85C91C2C93E56ABDF-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 08213
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 08213
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55901221200310
Coding: 28011F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 34311B740EBF8FBA8BB-8060
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0031118
VCID: 270BFC38C3E9F4223E9-8072
Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 72 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD0A64M6
Coding: 0014130
VCID: 2B030008DF01D042DA1-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME111B0876A
Subsystem 3 - Serial number: 6342QSME211C5768I
Subsystem 4 - Serial number: 6352QSME131A236EH
Subsystem 5 - Serial number: 6362QSME231C4E5EX
Subsystem 6 - Serial number: 63734SME5E142072-
Subsystem 7 - Serial number: 63834SME5E14357CA
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H08000 Serial number: 90055121300148
Coding: 0012152
VCID: 2809FF04CEF7FB5A373-807C
Component: E0221 H03 0030
Address 17: Instruments (J285) Labels:. 4L0-920-KOM-V3.clb
Part No SW: 4L0 920 985 G HW: 4L0 920 985 G
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: ZXK02K1DE
Coding: 8BD664040D01CF05020205
Shop #: WSC 15787 002 1048576
VCID: 38292F4412576BDAA73-806C
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB700037 Serial number: 3700M12804009C
Coding: 00C303
VCID: 3FDB445837795CE2669-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790886179
Reset counter: 212
Mileage: 211578 km
Date: 2024.09.26
Time: 16:55:58
Bin. Bits: 10111
Voltage: 11.60 V
Count: 7
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Revision: 00---010 Serial number: 00000000340244
Coding: 0000006
VCID: 6889BF040E773B5AF73-803C
02597 - Rear Left Upper Body Vent Motor (V315)
003 - Mechanical Failure
Fault Status: 01100011
Fault Frequency: 52
Reset counter: 194
Mileage: 211579 km
Date: 2024.09.26
Time: 17:08:32
Voltage: 13.60 V
Temperature: -100.0°C
(no units): 144.0
(no units): 74.0
Address 34: Level Control Labels: 4L0-910-553.clb
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015510
VCID: 313F1260FD2DBA92E0D-8064
01577 - Turn-Off due to Over-Temp
Fault Status: 00100001
Reset counter: 233
Mileage: 211581 km
Date: 2024.09.26
Time: 17:11:06
Error Code: 68
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000033938862
Coding: 00581B00000011110000
VCID: 323D1D6CF42B818A997-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH02 0050
Revision: 00H02000 Serial number: 6PZ 009 014-10
Coding: 0000001
VCID: 2E05091CEC13A56AFDF-807A
Component: J0770_SWA_Slave_H02 0050
Subsystem 3 - Serial number: 5F23.06.1200H020003C910267ÿ
Subsystem 4 - Serial number: 910267ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000037617076
Coding: 011F57205E40440004
VCID: 48C95F8462B71B5AD73-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01798509180000
Coding: 3569949
VCID: 38292F441E576BDAA73-806C
Reset counter: 214
Mileage: 211683 km
Date: 2024.09.28
Time: 12:47:59
Part No SW: 4L0 035 466 A HW: 4L0 035 466 A
Component: BO Q7 H30 0110
Revision: 07S00000 Serial number: 02405120006943
Coding: 0D000001
VCID: 290FFA00D9FDC25228D-807C
Subsystem 1 - Part No SW: 4L0 910 465 A HW: 4L0 035 465
Component: BO Q7 SLAVE H41 0780
Serial number: 02404120020075
Reset counter: 211
Mileage: 211572 km
Date: 2024.09.13
Time: 00:30:19
Voltage: 12.20 V
Temperature: 31.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 37.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190187754
Coding: 0758733
VCID: 2313E828B7D11802621-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000119039
Coding: 0012001
VCID: 5EE599DCDC3375EA0DF-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000036680100
VCID: 47CB5CB86FA91422DE9-8012
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000032
Part No SW: 4G0 035 080 D HW: 4G0 035 080
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 158B 0D7505754
Coding: 020007010000000000
Shop #: WSC 08260 001 1048576
VCID: 1F1BE4D897B93CE2469-804A
Reset counter: 211
Mileage: 211572 km
Date: 2024.09.26
Time: 14:58:41
Part No SW: 4L2 035 746 A HW: 4L2 035 746 A
Component: H-BNT-NA H43 0552
Revision: -------- Serial number: 224HV0C7504173
Coding: 180200060004FBEF710003456F632003140000000100000000
VCID: 2C010314D60FD77AD3B-8078
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130HV0C2518267
Subsystem 3 - Part No SW: 4E0 910 611 HW: 4E2 919 612 C
Component: E0380 Bedient H01 0050
Serial number: 00000000098042
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000036929205
Coding: 010E57204040230004
VCID: 46D551BC68A30D2A25F-8012
Fault Status: 01101000
Fault Frequency: 103
Reset counter: 194
Mileage: 211578 km
Date: 2024.09.26
Time: 16:55:57
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0053175
Coding: 020C000001000100000102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E85C91C2013E56ABDF-803A
9617993 - Proximity Camera
B145C 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 218
Mileage: 211995 km
Date: 2024.09.30
Time: 14:24:06
Voltage terminal 30: 14.1 V
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81C3141A8F177A93B-8038
Subsystem 2 - Serial number: RD22.08.12--H57001002E0124ÿ
Subsystem 3 - Serial number: 2E0124ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 128877805-----
Coding: 0003595
VCID: 2615F13CC4E3ED2A05F-8072
Component: J_245_EE16_SKB10H12 0220
Component: J_394_EE16_SKB10H12 0220
Component: J_392_EE16_SKB10H12 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000036929202
Reset counter: 172
Mileage: 211578 km
Date: 2024.09.26
Time: 16:55:57
End----(Elapsed Time: 02:38, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
