TYRE PRESURE MONITORING SYSTEM (2016 Seat Toledo)
thanosxx
Greece
C?ID=298538
Hello.I want reset the tyre presure monitoring system,also It want security access I insert the code for basic enabling 40168 and code accepted but I have the message security access required
Thursday,10,October,2024,10:24:22:57658
VCDS Version: 24.7.1.0  HEX-V2 CB: 0.4654.4
VIN: VSSZZZNHZG1016978   License Plate: ITH1251
Mileage: 149284km-92760mi   Repair Order:
Chassis Type: NH-SK25 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: VSSZZZNHZG1016978   Mileage: 149284km-92760miles
Address 01: Engine (J623-CJZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H23 9086
   Revision: R4H23---    CVN: 2DF50523
   Coding: 01190012232410080000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM12TFS01104E906027BC 001009
   ROD: EV_ECM12TFS011_VW26.rod
   VCID: 6696BC4058E9DE9AC57-8032
   VINID: 9A38EAAAA798A9704004624720E561B460
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-614-517-TRW460.clb
   Part No SW: 6R0 614 517 CA    HW: 6R0 614 517 CA
   Component: EBC 460 ESP   H52 0002
   Serial number: A010VQC
   Coding: 43F84876897F00D9C22C1231912A0069170500C1
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1ESCEBC460PQ26L 003014
   ROD: EV_Brake1ESCEBC460PQ26L_003.rod
   VCID: 74B2D6081E353C0A4B3-8020
0459 - Tire Pressure Warning
          C102D 00 [10001001] - -
                    Reset counter: 53
                    Mileage: 149284 km
                    Date: 2024.10.10
                    Time: 10:18:11
                    DTC: 00 01 CB
Address 08: Auto HVAC (J255)       Labels:| 6C0-907-044.clb
   Part No SW: 6P0 907 044 B    HW: 6P0 907 044 B
   Component: Climatronic   H02 0202
   Serial number:  1511042A-1452
   Coding: 010000000011100001
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26_001_SK25.rod
   VCID: 303A1A18AAAD402AEFB-8064
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0086
   Serial number: 001588108971 Dataset Number: 5JA063t____
   Coding: 08000840401500DB438040004001030000015900530A3500000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   Driver door control module:
   Subsystem 1 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
   Component: FHSG DRV  007 0001
   Serial number: 00000000000002617788
   Coding: 011200
   Humidity sensor: interior:
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Component: G355_FeuchteS  H07 0002
   Serial number: 71281924
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
   Component: VW20Airbag821 002 0380
   Revision: --------    Serial number: 003TJ0004HXJ Dataset Number: 605003T____ 0167
   Coding: 88CCC00000000000540000C8002800000000
   Shop #: WSC 73430 790 00000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3B203D3473EBB3724A9-806E
   Subsystem 1 - Part No SW: -----------    HW: 442 152 111 15
   Component: SideSensor_Df  1CA 0148
   Serial number: 3497A00B91E4D0A0719Q
   Subsystem 2 - Part No SW: -----------    HW: 442 152 111 15
   Component: SideSensor_Pf  1CA 0148
   Serial number: 3507A009F1EAED43F240
   Subsystem 3 - Part No SW: -----------    HW: 442 152 111 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00C11EAED41710I
   Subsystem 4 - Part No SW: -----------    HW: 442 152 111 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A009D1EAED42E14/
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI3
   Part No SW: 6JA 920 740 F    HW: 6JA 920 740 F
   Component: KOMBI         205 1422
   Coding: 072404002180000801082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 3D24332C6DFFBD4274D-8068
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0086
   Revision: --------    Serial number: 001588108971 Dataset Number: 5JA067t____ 2604
   Coding: 01010008200A640000000000000000000001050000000000000000000000
   GVL: 01403C0000000000400000000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_SK25.rod
   VCID: 6594BB4CA5EFD582CCD-8030
   Subsystem 1 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B  Labels: 3C8-959-537.CLB
   Serial number: 000000000B1607141015
   Coding: 002000
          U1101 00 [00001001] - Active
                    Reset counter: 53
                    Mileage: 149284 km
                    Date: 2024.10.10
                    Time: 09:41:39
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: CFC20406 Dataset Number: 5JJ074t____ 0107
   Coding: 000700
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6D84C36C7D1FEDC284D-8038
   Part No SW: 5F0 035 871     HW: 5F0 035 871
   Component: MU-E--ER      06481
   Serial number: 15021200010001
   Coding: 00000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 6390A554ABDBABB2229-8036
1545 - Internal Control Module Memory Check Sum Error
          B2000 43 [00001000] - Special Memory Failure
          [Control module faulty: CAN controller RAM check]
End----------(Elapsed Time: 00:34, VBatt start/end: 12.2V/12.2V)-----------
Does this car not have a button, or an item in the menus to do that?
thanosxx
Greece
C?ID=298538
There isn't button also I look in menu but there isn't anything for reset tyre
Jef
HQ
What I find in owner's manuals for 2016 Toledo Stylance, 2 version to pick from... page 216 or 219 is the same info:
Store the new tyre pressure in the Easy Connect system with the button [CAR] and the function button [Setup].
Then it directs to page 20 or 25 (again, depending on what version you download)..... but from there it looks like you'd find a menu listing of [Tyres], followed by a submenu of [Tyre pressure monitoring], with an option to [Tyre pressure storing (Calibration)].
thanosxx
Greece
C?ID=298538
There isn't nothing in menu ,but I have a complaint from the customer that <dissapear >one page from menu on display
Hmmm...
thanosxx
Greece
C?ID=298538
How can I repair this problem?
thanosxx
Greece
C?ID=298538
Also why I can't reset the tpms from vcds?I insert the login code for basic settings(40168) but I have error that I need insert login code
How exactly are you trying to reset the TPMS in that ABS? Step-by-step, please.
Jef
HQ
In most cases, this means said control module, 5F in this case, would need to be replaced. I would verify the powers/grounds for this module are to factory design, no voltage drop under load.
Why the ABS Basic Settings IDE03650-Basic setting for brake pressure sensor isn't working... I'm not sure.... maybe there is some sort of exchange of data in the background with the 5F, but with a questionable 5F the request is denied. VCDS can only send a request, how the control module reacts is based on how it was designed to behave under the current conditions.
Are the tires/tyres 100% matching? Same size, brand, model, tread depth and pressure? Normally on a passive system, they sort themselves out with short test drive. But if there are mismatched tires/tyres then it will be an unhappy system.
thanosxx
Greece
C?ID=298538
I try with VCDS go to basic settings and i find tpms reset it ask for security login I input 40168 for basic settings but I have again error and ask again for security login
So you tried this?
IDE05334 -- Reset tire pressure monitoring display warnings
As far as I'm aware, 40168 should be correct for that.
