04-Steering Angle -- Status: Cannot be reached 1100
Boki Ar
Arandjelovac, Serbia
C?ID=57300
I looked, 653 and 654, they look similar but the price difference is very noticeable. ;)
Pin out, and the number of pins also differs, of course. 654 = 11pins, on one of the connectors.
   #23
Boki Ar
C?ID=57300
Do you suspect that the OP has the wrong component on the vehicle?
   #25
Steinrawr
Norway
C?ID=211299
Okay, so I guess we can assume the steering angle sensor is the g85 external type on the steering wheel column, I trust you guys more than the dealership.
I tried clearing all DTCs before coding the ABS. Can try doing it again. Is there perhaps another security access code I should use? 20103 is what I used when I tried.
I parked the car at the dealership that made all my problems in the first place today, and I have no idea when I will have it back. Not sure what they are going to try to do, but they mentioned they would take a look with ODIN.
   #27
Boki Ar
C?ID=57300
They should go through the entire vehicle and the entire SVM with ODIS.
   #28
Steinrawr
Norway
C?ID=211299
I tried getting help from the dealership, they had the car for a full day, could Find anything. I paid 4000 NOK for "you need a new abs central and new engine harness, cost 40.000 NOK and zero guarantee for it to help".
But I will call them and ask if they can provide it for me.
   #29
Steinrawr
Norway
C?ID=211299
So the workshop that indused the faults didn't find anything with Odin. He said the abs central would not accept what they thought was the correct coding, and that it wasn't correct coded to the VIN, same conclusion as here.
I have another abs central i blew a he'll of a lot money on, but the code on that is something completely different, and it won't accept any new coding either. Part no. 6R0 614 517 BF
The abs central i have in my car is 6R0 614 517 BK GNO
   #30
iichel
Netherlands, Operation Market Garden
C?ID=284912
can you clarify please? did they put in a coding they made themselves? the dealer can retreive the coding online for both your abs and your power steering.
'thought was the correct coding' doesnt count today. we need the exact correct coding.
   #31
Steinrawr
Norway
C?ID=211299
This was not a Skoda dealership, but a key programming specialist.
It was the workshop that coded my keys, but I'm guessing they retrieved the correct code and compared it with what is installed, with Odin. They did not share what codes they retrieved with me, or specify any more than what I wrote.
Conclusion was either way that the current ABS does not under any circumstances accept any code.
I've sendt an inquiry to two different skoda dealerships to supply me with what should be correct coding from factory, and what part.no abs central should be.
   #32
iichel
C?ID=284912
so if i understand correctly?
car in factory condition (factory abs + coding) gets a key made
key specialist programs the key, abs coding gets wiped
you put in a new abs from a rapid 1.6 tdi
tried to code abs
many codings rejected
some codings accepted?
is that the correct timeline? anything i missed? any modules changed, codings?
any codings accepted?
do you have a list of what codes you tried and which ones were accepted/rejected?
   #33
Steinrawr
Norway
C?ID=211299
Almost
  1. Extra Key gets programmed, dashboard lights up (TCS, TPMS, ESP red warning light) .
  2. Two skoda workshops diagnose it two times each, but can't find any specific issue. One of them suggest to change engine harness and abs central. Doesn't give me any more info.
  3. I try to change the abs central. Installed abs central, Part no. 6R0 614 517 BF, it has long code 4129481409B200B9824C12D790A700504B0A00
  4. I couldn't code the "new" abs central at all, it didn't accept the code my abs central had from before (4129481489B300B7825012D991A700504B0800)
  5. A workshop also tried coding the new abs, but could not do it.
  6. I removed the "new" abs central and installed the original one, part.no 6R0 614 517 BK GNO, long code 4129481489B300B7825012D991A700504B0800
  7. I ask for help here
  8. Abs won't accept any of the codes mentioned here in this post
  9. 44 - steering assist is changed from 2007 to 0003
  10. Slip ring is changed from 6RA 959 653 to 6RA 959 653 A
  11. Abs still won't accept any of the codes mentioned here in this post
Error messages when trying to code the abs
"Coding rejected, Error 31 request out of range"
and
"Coding rejected, error 22: conditions not correct or sequence error.
   #35
Steinrawr
Norway
C?ID=211299
I will!
I get the car back tomorrow, will post then
   #37
Boki Ar
C?ID=57300
Checked the coding 4129481489B300B7825012D991A700504B0800 according to the VIN number TMBET6NH1E4523977, it is valid.
The entered data is valid for the following control unit:
EV_Brake1ESPAEntryTRW
My suspicion is that an error has crept in somewhere (01, 17 or 25) in the VIN number.
   #38
Steinrawr
Norway
C?ID=211299
Didn't get the car back as planned. BUT: It's back, and everything is fine again. The Key-tech figured it out.
So... The VIN (or CAR ID) in 17 - intstruments was "#=¤(%#=)_ØY"U*Q#¤, or somthing like that. He reprogrammed the instrument cluster with Odin and everything else was then OK. So, the ABS Long code was actually correct for this car: 4129481489B300B7825012D991A700504B0800.
Here's a full scan from after this fix, including advanced info on 3, 17 and 44 in the following boxes.
Friday,18,October,2024,13:33:09:35578
Workshop Code: 210 01369 040505
VIN: TMBET6NH1E4523977   License Plate:
Mileage: 258050km-160344mi   Repair Order:
Chassis Type: NH-SK25 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 37 44 56 61 69 0B
VIN: TMBET6NH1E4523977   Mileage: 258050km-160344miles
Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 GD    HW: 03C 906 016 GD
   Component: 1.4l R4 TSI   H01 4583
   Revision: LPH01---    Serial number:                CVN: F291B5BC
   Coding: 00250032002401000000
   Shop #: WSC 73430 031 00016
   ASAM Dataset: EV_ECM14TFS01103C906016GD 001003
   ROD: EV_ECM14TFS01103C906016GD.rod
   VCID: 678BB7CBDFE57B92F69-8032
   VINID: 91D4959067980551050832471CDA5CE923
Readiness: 1110 0101
   Part No SW: 0AM 300 062 M    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6561
   Revision: 00043014    Serial number: CU501401155558
   Shop #: WSC 51729 001 1048576
   VCID: 36352A8FC44FD21ABDF-8062
Address 03: ABS Brakes (J104)       Labels:. 6R0-614-517-TRW460.clb
   Part No SW: 6R0 614 517 BK    HW: 6R0 614 517 BK
   Component: EBC 460 ESP   H08 0004
   Serial number: A00ICBD
   Coding: 4129481489B300B7825012D991A700504B0800
   Shop #: WSC 73430 031 00021
   ASAM Dataset: EV_Brake1ESPAEntryTRW 002011
   ROD: EV_Brake1ESPAEntryTRW.rod
   VCID: 7DA7F5A3AD79C1423C5-8028
Address 08: Auto HVAC (J255)       Labels: 6Q0-907-044.lbl
   Part No SW: 5JA 907 044     HW: 5JA 907 044
   Component: Climatronic   H04 0106
   Revision: A1001000    Serial number:  1311191A-0046
   VCID: 78A9E4B782DBE46A6F3-802C
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 018140590
   Coding: 24980B0000092000000809302E0B0CC00E80400F60820040020000004000
   Shop #: WSC 01369 210 40505
   VCID: 2D0705E33D1991C2CC5-8078
   Subsystem 1 - Part No SW: 5E0 919 719 F    HW: 5E0 919 719 F  Labels: 3C8-959-537.CLB
   Serial number: 000000000B0626240114
   Coding: 820000
Address 10: Park/Steer Assist (J446)       Labels:| 5JA-919-475.clb
   Part No SW: 5JA 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 3K  H11 0005
   Revision: --------    Serial number: 32901401600160
   Coding: 110103
   ASAM Dataset: EV_EPHVA14SK25X0000 001002
   ROD: EV_EPHVA14SK25X0000.rod
   VCID: 44D140478E13708A33B-8010
   Part No SW: 34D 959 655 B    HW: 34D 959 655 B
   Component: AirbagVW20    004 0365
   Serial number: 003K7R02TEU3 Dataset Number: 5JA003t____ 0013
   Coding: 88CCC00000000000540000C8000000000065
   Shop #: WSC 73430 790 00021
   ASAM Dataset: EV_AirbaVW20SMEVW253 001108
   ROD: EV_AirbaVW20SMEVW253.rod
   VCID: 34311087DEB3C00A83B-8060
   Subsystem 1 - Part No SW: -----------    HW: 480 411 801 14
   Component: SideSensor_Df  003 0148
   Serial number: 349651A016EB02A48D9U
   Subsystem 2 - Part No SW: -----------    HW: 480 411 801 14
   Component: SideSensor_Pf  003 0148
   Serial number: 350651A0119A0D543C35
   Subsystem 3 - Part No SW: -----------    HW: 480 411 801 14
   Component: SideSensor_Dr  003 0148
   Serial number: 351651A0146C4F02CFAQ
   Subsystem 4 - Part No SW: -----------    HW: 480 411 801 14
   Component: SideSensor_Pr  003 0148
   Serial number: 352651A0119C89234FAK
   Part No SW: 5JA 920 840 D    HW: 5JA 920 840 D
   Component: KOMBI         H04 0709
   Coding: 110C00
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
   VCID: 3B233BBBF3ED0F72421-806E
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 03A277
   VCID: 70B9DC97EAABBC2AA73-8024
   Component: IMMO          H04 0709
   VCID: 6A8DCEFFCCF746FAE97-803E
   Revision: A1001003    Serial number: 7665752742
   Coding: 030100
   VCID: 2B030BFB030D9FF2D21-807E
   Part No SW: 5JA 035 192 J    HW: 5JA 035 192 J
   Component: RNS315-EU   H76 0410
   Serial number: SKZAZ2P0041600
   Coding: 040004010207000001000002
   ROD: EV_RNS315EUV2UDS_SK25.rod
   VCID: 3E2532AFE0FF1A5A65F-806A
   Component: EUR_W_V5  0055
1048632 - Antenna 1 for Radio
          B1119 13 [00001001] - Open Circuit
                    Reset counter: 122
                    Mileage: 258059 km
                    Date: 2024.10.18
                    Time: 13:24:40
1048636 - Digital Radio Antenna
          B1103 13 [00001001] - Open Circuit
                    Reset counter: 122
                    Mileage: 258059 km
                    Date: 2024.10.18
                    Time: 13:24:40
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 R    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  311 3111
   Serial number: CE1V0003 Dataset Number: 5JJ074t____ 0014
   Coding: 0003
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 46D55A4FB82F429A2DF-8012
1091584 - invalid data record
          B2005 00 [00001001] - -
          [DEM_INVALID_DATASET_FAULT]
                    Reset counter: 122
                    Mileage: 258059 km
                    Date: 2024.10.18
                    Time: 13:24:40
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H74 0712
   Coding: 032B7A64
   VCID: 6B83CBFBC38D5FF2921-803E
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 51007K09162031593138
   Revision: 3A001001    Serial number: 00008200034725
   Coding: 410D000100000000
   VCID: 30391C972A2BFC2AE73-8064
End----------(Elapsed Time: 01:32, VBatt start/end: 12.6V/12.4V)-----------
Friday,18,October,2024,13:29:23:35578
Control Module Part Number: 5JA 920 840 D
  Component and/or Version: KOMBI         H04 0709
           Software Coding: 110C00
            Work Shop Code: WSC 73430
Advanced Identification/FAZIT
     Identification: VD1-048
     Date: 24.01.14
     Manufacturer number: 7394
     Test stand number: 6597
Flash Status
     Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0
     Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
     Programming Status: 00000000
     Flash Date: 00.00.00
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5JA 920 840 D
     Workshop System Name: J285
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A04723
Car Info
     Chassis Number: TMBET6NH1E4523977
VCDS Info:
       Labels: 5K0-920-xxx-17.clb-SRI1
Friday,18,October,2024,13:28:42:35578
Control Module Part Number: 6R1 909 144 R
  Component and/or Version: EPS_TRW_ALow  311 3111
           Software Coding: 0003
            Work Shop Code: WSC 01369
     Identification: TW8-206
     Date: 31.01.14
     Manufacturer number: 6104
     Test stand number: 0003
Flash Status
     Programming Attempts(application): 1/4/4
     Programming Attempts(data): 6/2
     Successful Attempts(data): 2/2
     Flash Date: 15.10.06
     Flash Tool Code(data): 2097151 1023 131071
Misc.
     Hardware number: 6R1 909 144 E
     Workshop System Name: J792
     Equipment/PR Code: FFFFFFFFFFFFFFFFFFFFFFFE
     Dataset Version: 0014
     ASAM Dataset Revision: 011021
Car Info
     Chassis Number: -------------3977
VCDS Info:
       Labels: 6Rx-909-144-V2.clb
Friday,18,October,2024,13:26:43:35578
Control Module Part Number: 6R0 614 517 BK
  Component and/or Version: EBC 460 ESP   H08 0004
           Software Coding: 4129481489B300B7825012D991A700504B0800
     Identification: GNO-KOB
     Date: 15.01.14
     Manufacturer number: 0013
     Test stand number: 0642
Flash Status
     Flash Date: 14.01.14
Misc.
     Hardware number: 6R0 614 517 BK
     Workshop System Name: J104
     Equipment/PR Code: 00000000000000000056437A
     ASAM Dataset Revision: 002011
VCDS Info:
       Labels: 6R0-614-517-TRW460.clb
