2001 Jetta TDI ALH
Carter Lagle
Mocksville, NC, USA
C?ID=591552
I have a 2001 Jetta TDI ALH Manual, I have been trying to fix it and get it running properly for my ALH rabbit pick up swap. When I start it up it starts fine but ben I give it some throttle it smokes like crazy and it sounds like it is hitting the limiter ( it is not but that's the best I can describe I don't know how to add a video to this) It will only go to like 2500 rpm even if I have it to the floor. I have checked the fuses and they all check out I just don't know where to go from here.
Here is the codes when I scan the car.
Thank you in advance
Address 01: Engine Labels: 038-906-012-AGR.clb
Control Module Part Number: 038 906 012 BD
Component and/or Version: 1,9l R4 EDC G400SG 2507
Software Coding: 00002
Work Shop Code: WSC 09220
VCID: 53F4A6ED32E660A2BA1-4B1E
19561 - Valve for Intake Manifold Flap (N239)
P3105 - 35-10 - Open or Short to Ground - Intermittent
18027 - Glow Plug Relay (J52)
P1619 - 35-10 - Open or Short to Ground - Intermittent
17957 - Boost Pressure Regulation Valve (N75)
P1549 - 35-10 - Open or Short to Ground - Intermittent
17849 - EGR Valve (N18)
P1441 - 35-10 - Open Circuit or Short to Ground - Intermittent
17660 - Commencement of Injection Valve (N108)
P1252 - 35-10 - Open or Short to Ground - Intermittent
Readiness: 1 4 0 1 0
"Open or Short to Ground" can mean a missing +12V on the other side of the actuator. Have you got a wiring diagram? If I had to guess those things all share a common source of +12V and when you find that, you will have found the problem.
Carter Lagle
Mocksville, NC, USA
C?ID=591552
yes i have checked all the plugs it has ground and voltage
JMR
Romania
C?ID=432218
You have shortcircuited wires for sure , i remember fixing something like this , on the right side of the car ( your left when you look at the engine )
Carter Lagle
Mocksville, NC, USA
C?ID=591552
do you remember where?
JMR
Romania
C?ID=432218
You ll see a loom of wires coming around the engine on that side , strip the wires in that area
