2013 JSW TDI CJA, lost ABS coding (MK60EC1)
DaylenMulder
C?ID=598900
I lost my ABS coding because of a VIN mismatch. I tried swapping both ecu and guage cluster and now the ABS malfunction, ASR manually deactivated and ESC lights are all flashing. I put the old ECU and guage cluster back in and the car has a stage 3 tune from tunezilla, and the TCU tune to match. I have drove it and everything works fine. I have stopped driving it now because of learning about this thread and rule 0 being not to drive it. Can anyone help get new code to get rid of the lights and allow for functioning ABS or am I screwed? Thanks!
Westbury, UK
To generate an ABS code the experts here need at least a complete unedited Auto-Scan.
DaylenMulder
C?ID=598900
Friday,04,October,2024,17:14:37:07335
VIN: 3VWPL7AJ5DM683299   License Plate: OBP-889
Mileage: 205150km-127476mi   Repair Order: ABS Lights Fix
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 4F 52 56
          62 72
VIN: 3VWPL7AJ5DM683299   Mileage: 205150km-127474miles
   Part No SW: 03L 997 030 E    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H15---    Serial number:
   Coding: 0050078
   Shop #: WSC 23116 035 00000
   VCID: 303EC848F62299FAEFB-8064
   VINID: 0E69E070745A1547462030892419FBAB6C
000115 - Sensor for Ambient Air Temperature (G17)
               P0073 - 000 - Signal too High - MIL ON
                    Fault Status: 11100000
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:44:54
                    Voltage: 13.38 V
                    Temperature: 49.5°C
                    Temperature: 30.6°C
                    Temperature: 36.9°C
                    Temperature: -90.0°C
Readiness: 1 1 0 X X
   Component: GSG DSG AG6     512 9430
   Revision: 05651213    Serial number: 00001302081272
   Shop #: WSC 00066 000 00000
   VCID: 147664D8627A45DAEB3-8040
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU - Intermittent
                    Fault Frequency: 0
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:12
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -  - Intermittent
                    Reset counter: 39
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:12
01196 - Engine-Transmission Data Bus
                    Reset counter: 39
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:13
   Revision: 00H31001
   VCID: 7DA0217C7DF0A49234D-8028
                    Reset counter: 87
                    Date: 2019.02.25.
                    Time: 05:33:55
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 50688
                    Fault Status: 01100101
                    Reset counter: 87
                    Mileage: 205158 km
                    Date: 2019.02.25.
                    Time: 05:30:10
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 279
                    Count: 50944
                    Count: 512
                    Reset counter: 87
                    Mileage: 205158 km
                    Date: 2019.02.25.
                    Time: 05:30:10
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 295
                    Count: 50944
                    Count: 512
                    Reset counter: 87
                    Mileage: 205158 km
                    Date: 2019.02.25.
                    Time: 05:30:10
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 270
                    Count: 50944
                    Count: 512
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0202293123 Dataset Number: 5K0116v____ 1K07
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 3436C4580EBAA5DA8B3-8060
10487040 - invalid data record
          B2005 00 [00001000] - -
          [Kein gültiger Datensatz]
                    Date: 2015.07.06.
                    Time: 01:11:03
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010002002
   Shop #: WSC 00066 000 00119
   VCID: 7BA42F646364AAA20A9-802E
          U1111 00 [00001000] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2024.10.04.
                    Time: 04:31:11
13701968 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [Steuergerät im Schalttafeleinsatz - bitte Fehlerspeicher auslesen]
                    Fault Frequency: 19
                    Reset counter: 87
                    Mileage: 205150 km
                    Date: 2024.10.03.
                    Time: 00:22:15
   Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
   Component: BCM PQ35 B    021 3068
   Revision: BG021001
   Coding: 6F380E1F802F3EC4008800C17000004449000086575D05F064802020A040
   Shop #: WSC 27578 001 1048576
   VCID: 3928F56C295858B2585-806C
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 22041  26  0512
   Coding: 009795
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:13
                    Voltage: 13.35 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 87
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 01:42:34
                    Voltage: 11.80 V
                    Reset counter: 86
                    Mileage: 205150 km
                    Date: 2019.02.24.
                    Time: 00:23:08
                    Voltage: 12.00 V
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R01HFY-   Dataset Number: 1KM003v__B_ 0047
   Coding: 00004E42
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C26EC7826EA6D9A433-8068
   Subsystem 1 - Part No SW: 1KM 959 339 B    HW: 1KM 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00007ET600
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME00666578ZZZV
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME60796478ZZZ+
   Serial number: 3511HSME051B242FZZZL
   Serial number: 3521HSME5616242FZZZN
   Serial number: 35527SME191D342FZZZO
   Serial number: 35627SME2118342FZZZD
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20130226100604
   Coding: 100A140000
   Shop #: WSC 00066 000 00184
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA0217C7D70A49234D-8028
   Coding: 820000
   Part No SW: 5K0 920 973 C    HW: 5K0 920 973 C
   Component: KOMBI         H05 0705
   Coding: 270F01
   VCID: 3138CD4CF1A890F2E05-8064
9453330 - Outside temperature sensor
          B103F 1B [00001001] - Resistance Too High
                    Reset counter: 86
                    Mileage: 205150 km
                    Date: 2024.10.03.
                    Time: 00:34:36
12648448 - Function Restricted due to Missing Message(s)
          [Steuergerät für Motor: keine Kommunikation]
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2024.10.04.
                    Time: 04:31:10
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 12041303290329
   Coding: 352002
   VCID: 76B23E5058C6F7CA757-8022
                    Fault Status: 00110100
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:12
   Component: IMMO          H05 0705
   Coding: 000007
   VCID: 6A8A1A201CFE232AE1F-803E
   Revision: 00000000    Serial number: 13000032643005
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 303EC848FAA299FAEFB-8064
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664404389
   Coding: 020100
   VCID: 2A0ADA20DCFEE32A21F-807E
                    Reset counter: 126
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H58 0319
   Serial number: VWZAZ2N0090036
   Coding: 04000401040007000000100A
   Shop #: WSC 01383 790 50316
   ROD: EV_RNS315NARV2UDS_VW36.rod
   VCID: 2510291CB560CC520CD-8070
   Component: NAR_V3_(0037)  0037
                    Reset counter: 86
                    Mileage: 205150 km
                    Date: 2024.10.04.
                    Time: 02:19:29
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0006570501
   Coding: 0004B5
   VCID: 5BE44FE4C3A44AA26A9-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1509
   Serial number: 00000007722511
   Coding: 000490
68108 - Function Restricted due to Missing Message(s)
          [Front CAN MSG]
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2024.10.04.
                    Time: 04:31:11
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 372CF354134C4EC2AE1-8062
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:12
                    Voltage: 13.38 V
                        DU
                    Temperature: 29.0°C
                    RPM: 1498 /min
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 050B0500
   VCID: 6FBC0B34279CC602B61-803A
   Component: J245EE20SKB13  H05 0220
   Component: J394EE20SKB13  H05 0220
02907 - Control Module for Roof Shade (J394)
                    Reset counter: 86
                    Mileage: 205150 km
                    Date: 2019.02.24.
                    Time: 00:22:15
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0006585865
   Coding: 0004B4
   VCID: 5CE64CF8C6AA4D9A633-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1509
   Serial number: 00000007668253
   Coding: 000490
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [00001001] - Electrical Failure
                    Reset counter: 87
                    Mileage: 205153 km
                    Date: 2024.10.04.
                    Time: 04:58:29
          [Front CAN MSG]
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2024.10.04.
                    Time: 04:31:11
End----------(Elapsed Time: 01:27, VBatt start/end: 14.1V/14.1V)-----------
Jef
HQ
For VIN 3VWPL7AJ5DM683299, ABS coding should be:
114B600C492A00FD880D06ED92220042B70000
You need to post a follow up Auto-Scan... all good :D or more issues :banghead:
DaylenMulder
C?ID=598900
Saturday,05,October,2024,13:53:55:07335
VCDS Version: Release 24.7.1 (x64) Running on Windows 11 x64
                Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BL    HW: 1K0 907 379 BL
  Component and/or Version: ESP MK60EC1   H31 0152
           Software Coding: 114B600C492A00FD880D06ED92220042B70000
            Work Shop Code: WSC 00066 123 12345
                    Reset counter: 90
                    Mileage: 205242 km
                    Date: 2019.02.26.
                    Time: 04:11:59
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 16390
                    Count: 44544
                    Count: 256
                    Reset counter: 90
                    Mileage: 205242 km
                    Date: 2019.02.26.
                    Time: 04:11:59
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 212
                    Count: 44544
                    Count: 256
                    Reset counter: 90
                    Mileage: 205242 km
                    Date: 2019.02.26.
                    Time: 04:11:59
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 279
                    Count: 44544
                    Count: 256
                    Reset counter: 90
                    Mileage: 205242 km
                    Date: 2019.02.26.
                    Time: 04:11:59
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 295
                    Count: 44544
                    Count: 256
                    Reset counter: 90
                    Mileage: 205242 km
                    Date: 2019.02.26.
                    Time: 04:11:59
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 270
                    Count: 44544
                    Count: 256
00667 - Ambient Temperature Signal
                    Fault Status: 01101000
                    Reset counter: 90
                    Mileage: 205242 km
                    Date: 2019.02.26.
                    Time: 04:11:59
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 8259
                    Count: 44544
                    Count: 256
It worked but didn't... lights don't show up when I have the controller closed but when open they pop back up. ESC light still on and now low tire pressure light is on. I think ESC is only on because the tire pressure sensors are trying to work now and I don't have those installed at the moment. You are the professionals though and the way this whole project has been going I'm likely wrong :)
DaylenMulder
C?ID=598900
Saturday,05,October,2024,14:52:35:07335
          62 72
VIN: 3VWPL7AJ5DM683299   Mileage: 205240km-127530miles
   Coding: 0050078
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:44:54
                    Voltage: 13.38 V
                    Temperature: 49.5°C
                    Temperature: 30.6°C
                    Temperature: 36.9°C
               P0299 - 000 - Control Range Not Reached
                    Mileage: 205226 km
                    Date: 2019.02.25.
                    Time: 11:10:57
                    RPM: 3312 /min
                    Speed: 138.0 km/h
                    Load: 100.0 %
                    (no units): 2901.6
                    (no units): 2480.4
                    Lambda: 54.4 %
                    Lambda: 55.2 %
               P0299 - 001 - Control Range Not Reached - MIL ON
                    Fault Status: 11100001
                    Mileage: 205226 km
                    Date: 2019.02.25.
                    Time: 11:10:57
                    RPM: 3312 /min
                    Speed: 138.0 km/h
                    Load: 100.0 %
                    (no units): 2901.6
                    (no units): 2480.4
                    Lambda: 54.4 %
                    Lambda: 55.2 %
Readiness: 1 2 0 X X
                    Fault Frequency: 0
                    Reset counter: 37
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:12
                    Reset counter: 36
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:12
                    Reset counter: 36
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:13
   Revision: 00H31001
   Shop #: WSC 00066 123 12345
                    Reset counter: 90
                    Mileage: 205242 km
                    Date: 2019.02.26.
                    Time: 04:56:37
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 8259
                    Count: 49920
                    Count: 257
                    Reset counter: 90
                    Mileage: 205242 km
                    Date: 2019.02.26.
                    Time: 04:56:37
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 16390
                    Count: 49920
                    Count: 257
   Coding: 030C0C
                    Date: 2015.07.06.
                    Time: 01:11:03
   Revision: 00001018
   Coding: 0010002002
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2024.10.04.
                    Time: 04:31:11
                    Fault Frequency: 27
                    Reset counter: 90
                    Mileage: 205150 km
                    Date: 2024.10.03.
                    Time: 00:22:15
   Revision: BG021001
   Coding: 009795
                    Reset counter: 128
                    Mileage: 205203 km
                    Date: 2019.02.25.
                    Time: 10:34:50
                        Term 15 Off
                    Voltage: 12.70 V
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:13
                    Voltage: 13.35 V
                    Fault Status: 00101010
                    Reset counter: 129
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 01:42:34
                    Voltage: 11.80 V
                    Reset counter: 86
                    Mileage: 205150 km
                    Date: 2019.02.24.
                    Time: 00:23:08
                    Voltage: 12.00 V
   Coding: 00004E42
   Coding: 100A140000
   Coding: 820000
   Coding: 270F01
                    Reset counter: 86
                    Mileage: 205150 km
                    Date: 2024.10.03.
                    Time: 00:34:36
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2024.10.04.
                    Time: 04:31:10
   Coding: 352002
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:12
   Coding: 000007
   Coding: 020100
                    Reset counter: 126
                    Reset counter: 86
                    Mileage: 205150 km
                    Date: 2024.10.04.
                    Time: 02:19:29
   Coding: 0004B5
   Slave Driver:
   Coding: 000490
                    Reset counter: 87
                    Mileage: 205159 km
                    Date: 2024.10.04.
                    Time: 08:33:51
          [Front CAN MSG]
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2024.10.04.
                    Time: 04:31:11
   Revision: 00H22000
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2019.02.25.
                    Time: 04:31:12
                    Voltage: 13.38 V
                        DU
                    Temperature: 29.0°C
                    RPM: 1498 /min
   Coding: 050B0500
                    Reset counter: 86
                    Mileage: 205150 km
                    Date: 2019.02.24.
                    Time: 00:22:15
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
                    Reset counter: 87
                    Mileage: 205153 km
                    Date: 2024.10.04.
                    Time: 04:58:29
          [Front CAN MSG]
                    Reset counter: 126
                    Mileage: 205150 km
                    Date: 2024.10.04.
                    Time: 04:31:11
End----------(Elapsed Time: 01:29, VBatt start/end: 13.9V/14.0V)-----------
This worked. Now only the one TPM Light (which should be one because of no tire pressure monitors). Thanks, if anything else seems wrong or you can help with the other 1010/0010 codes if they are an issue that'd be great. or if I must post a separate thread for those that can also be done.
Jef
HQ
TPMS does need to know the ambient air temp, so get that G17 sensor fixed... broken wire or unplugged by chance?
