Resolved Engine starts and stalls after 3 seconds (2011 1.6 TDI)
Resolved
saidi
Ales, France
C?ID=526854
Saturday,05,October,2024,01:10:46:56271
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WVWZZZ6RZBY115834   License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZBY115834   Mileage: 203800km-126635miles
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 D    HW: 03L 906 023 D
   Component: R4 1.6l TDI   H13 9979
   Revision: --H13---    Serial number:                CVN: 75AF83D8
   Coding: 00114014002400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM16TDI02103L906023D 003014
   ROD: EV_ECM16TDI02103L906023AH_003.rod
   VCID: 270094549F60A8C23E1-8072
   VINID: 9E69EAAAA1A2A92A4104520310592632AB
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416E00B7842D14E582D500421300
   VCID: 065EF9D0786A91CA657-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
   Component: Climatic       25 0660
   Revision: 00 11 25
   VCID: 353C4E1C554CCA52BCD-8060
   Part No SW: 6R0 937 087 F    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0221
   Revision: BF046001    Serial number: 0345 261102758
   Coding: 34B029BF08A10000002800007C2B0CD00080410F60840000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 40D22FC81A8E7FFA1FB-8014
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0912
   Serial number: KU0-KU006.09.1016331
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0912
   Serial number: KU0-KU015.09.1012159
   Coding: 08BC30
   Subsystem 3 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0109844
   Coding: 020000
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71391025670489
   Coding: 100001
   ASAM Dataset: EV_VW250ParkiAssis2 S01006
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 7BA898243368DC220A9-802E
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag007 H09 0020
   Revision: --------    Serial number: 003GX008CEUU Dataset Number: v00304616R0 0001
   Coding: 003037
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4AC60DE02C32B5AAC1F-801E
   Serial number: 3572SRB40000CA253A55
   Serial number: 3582SRB40000CA3051C2
   Serial number: 3515RRB406101NFS60LC
   Serial number: 3525RRB406101NFSLOI6
   Part No SW: 6R0 920 861 F    HW: 6R0 920 861 F
   Component: KOMBI         H04 0304
   Coding: 140A00
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
   VCID: 3822472842DE373AA7B-806C
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0221
   Coding: 002000
   VCID: 70B2BF086AAEAF7AAFB-8024
   Component: IMMO          H04 0304
   VCID: 6A86AD604CF255AAE1F-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668661868
   VCID: 270094549FE0A8C23E1-8072
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F307C74BE50F082F61-807A
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 00000000    Serial number: VWZ1Z2K8528604
   Coding: 0100040002
   VCID: 6B88A86443884CA29A9-803E
End----(Elapsed Time: 01:38, VBatt start/end: 11.8V/12.1V. VIgn 11.7V)-----
RGH0
Australia
C?ID=433612
Your battery does not look well charged. I would fix that first
saidi
Ales, France
C?ID=526854
Hello, even with a well-charged battery, the engine starts and then stalls after 5 seconds.
davisev5225
C?ID=263265
Immobilizer. Check if your key is being recognized in 09 Central Electric and/or 17 Instruments.
saidi
Ales, France
C?ID=526854
hello
FIRST OF ALL I AM SORRY FOR MY ENGLISH I AM FRENCH I USE A TRANSLATOR
I COME BACK TO MY PROBLEM OF THE POLO WHICH STARTS AND STALLS AFTER 5 SECONDS MAX
I THINK HE IS RIGHT FOR THE 09 power plant WHICH DOES NOT RECOGNIZE THE KEY
MY PROBLEM THE SECURE ACCESS CODE I HAVE A LIST (31347/20107/42013/48396)
BUT MY POWER PLANT DOES NOT RECOGNIZE ANY
saidi
Ales, France
C?ID=526854
ENG108927-ENG99427 Service_Key_Master_Counter-Counter ID-Geber 0
ENG108927-ENG100006 Service_Key_Master_Counter-Counter Key-ID1 834
ENG108927-ENG103077 Service_Key_Master_Counter-Counter Key-ID2 9488
Jef
HQ
If this was an immobilizer issue, I would expect the ECM to something like P1570 Engine Start Blocked by Immobilizer or similar. And there are no DTCs in the Immobilizer as well.
Do you have fuel getting into the combustion chambers? In the ECM, see what fuel pressure looks like. Ignition on, engine off, go into address 01: Engine, then Advanced Measuring Values:
  • IDE00201-ENG102664-High fuel pressure: specified value-FUP_SP_KPA
  • IDE00589-ENG167462-Fuel pressure
Now fire the engine up and see what kind of numbers you get.
Do everything you can to verify fuel is moving from the tank to the combustion chamber as per factory design. Also, if you have the intake hose off and some one sprays a small amount of starter fluid or brake cleaner into the intake (small amounts), can that keep the engine running? If yes, return to the start of this paragraph.
Micky 32
Longford, Ireland
C?ID=3392
When the battery was bad on my Passat it used to stall after a couple of seconds in the morning sometimes.
