Audi A3 2020 - Disable door chime when open with lights on or in gear
2020_A3
Brazil
C?ID=595558
Desperately looking to make these annoying chimes stop. Would also like the car to honk when locking with the control but the adaptions I've tried so far haven't worked.
Full scan:
Friday,04,October,2024,06:14:00:43973
VIN: 99ADJ78V0L4000343   License Plate:
Mileage: 35716km-22192mi   Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 08 09 10 15 17 19 42 44 52 5F
VIN: 99ADJ78V0L4000343   Mileage: 35716km-22192miles
Address 01: Engine (J623-CWLA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HH    HW: 04E 907 309 BP
   Component: R4 1.4l TFS   H23 4253
   Revision: RDH23---    CVN: 16B2B602
   Coding: 021A0032232401082000
   Shop #: WSC 01530 935 00200
   ASAM Dataset: EV_ECM14TFS01104E906027HH 002013
   ROD: EV_ECM14TFS01104E906027HH.rod
   VCID: 71B80DE0D123A6D2A05-8024
   VINID: 24945468722601C1000000C40C29ABBC82
12620 - Sensor for Fuel Composition / Quality (G446)
          P0177 00 [00100000] - Implausible Signal
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [01100000] - -
10591 - Cylinder 1
          P0301 00 [01100000] - Misfire Detected
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09G 927 158 AA    HW: 09G 927 158
   Component: AISIN AG6 G3  201 3254
   CVN: E24AD600
   Coding: 010100010C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 72BA02ECD4259DCA59F-8026
   Part No SW: 5Q0 614 517 FA    HW: 5Q0 614 517 BR
   Component: ESC           H82 0190
   Revision: 00000000    Serial number: 62159000001088
   Coding: 13F16AA22020226C897A0E0461C625C8560444917086A47A0241F07492084A0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038_AU37.rod
   VCID: 75B039F0A54B8AF27CD-8020
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
   Part No SW: 8V0 820 047 F    HW: 8V0 820 047 F
   Component: AC Manuell el H03 0130
   Revision: 20002000    Serial number: 00000000338480
   Coding: 03000004100000001000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008018
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 3928F5C0C9D32E92585-806C
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0312
   Serial number: 01001921201523 Dataset Number: 8V0909514AE 0028
   Coding: 000000000000008000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_AU27.rod
   VCID: 01585D20E183B652505-8054
   Component: WWS371 190717  043  0585
   Serial number:         190812130938
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8V0 941 531 BG    HW: 8V0 941 531 BG
   Component: E1 - LDS MQB  H06  0032
   Serial number: 09 06 2019  20000699
   Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY192101RVR
   Component: Sirene, DWA  005  0314
   Serial number: 00000000000047440730
   Steering Column Switch:
   Subsystem 5 - Part No SW: 82A 953 521 AC    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000030071904400479
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000259540119236 Dataset Number: 8VB909526G  0022
   Coding: 0470051011
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_VW41.rod
   VCID: 50FEA8647A698FDA8FB-8004
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    008 0403
   Serial number: 003FNR5TGLT$ Dataset Number: 8V0909602AC 0002
   Coding: 98CCC000000000005C5400000048000000C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 137467688BFF34C2F29-8046
   Subsystem 1 - Part No SW: -----------    HW: 480 000 409 19
   Serial number: 35700000000C67E0EE3%
   Subsystem 2 - Part No SW: -----------    HW: 480 000 409 19
   Serial number: 35800000000DCCA43F32
   Subsystem 3 - Part No SW: -----------    HW: 480 401 507 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001A8F092D9561FH
   Subsystem 4 - Part No SW: -----------    HW: 480 401 507 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001A8F092D95B3AK
   Subsystem 5 - Part No SW: -----------    HW: 480 402 405 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001B6F051DB4B99N
   Part No SW: 8V0 920 740     HW: 8V0 920 740
   Component: KOMBI         H21 2700
   Coding: 07A51A082B8000081A00A8001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 74B604F4AE3193FA4B3-8020
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000058656 Dataset Number: 8VB909515H  0031
   Coding: 030100043F0857085B000048180B00000001010000000000000000000000
   GVL: 01443C0000000000400C00000000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 70BE08E4DA29AFDAAFB-8024
   Generator:
   Component: 4-01-13-01-04
   Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
   Component: J453 MFL  H04 0004
   Serial number: 20190606072327 20909
   Serial number: 2047956600
   Part No SW: 5Q0 959 393 K    HW: 5Q0 959 393 F
   Component: TSG FS002 0320
   Serial number: YE007SH62261D Dataset Number: 8VB909872G  0028
   Coding: 00100A204D00000000001002
   VCID: 47CC83388F274862DE1-8012
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000032838006
   Coding: 110000
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Dataset Number: 8VB909852G  0001
   Coding: 011F0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 5Q0 959 392 K    HW: 5Q0 959 392 F
   Component: TSG BFS002 0320
   Serial number: YE007SHH19084 Dataset Number: 8VB909873G  0028
   Coding: 001002204D00000000001002
   VCID: 46D28E3C882D516A257-8012
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000033805210
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels:* 8V0-035-MIB-STD2.clb
   Part No SW: 81A 035 824 D    HW: 81A 035 824 D
   Component: MU-S--ER      722 0962
   Serial number:                Dataset Number: 8VB909545M  0010
   Coding: 01730100FF00000011220001001A00002F0024C40170010002
   ASAM Dataset: EV_MUStd6C3DELP 001013
   ROD: EV_MUStd6C3DELP_AU37.rod
   VCID: 241634B45E51437A1B3-8070
   Multimedia System 1:
   Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9K1Y0KXQQ
   Subsystem 2 - Part No SW: 8V0 919 614 BA    HW: 8V0 919 614 BA
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL124011900060230
End----------(Elapsed Time: 00:59, VBatt start/end: 12.5V/12.5V)-----------
